  3. Off Topic
  4. zigbee2mqtt läuft sein heute morgen nicht mehr
    5.9k
14 Beiträge 5 Kommentatoren 1.2k Aufrufe 4 Beobachtet
    @mico sagte in zigbee2mqtt läuft sein heute morgen nicht mehr:
    mein Zigbee2mqtt
    das wäre nich ioBroker!
    Mico
    @arteck
     cd /opt/zigbee2mqtt
    npm start
    > zigbee2mqtt@2.6.1 start
    > node index.js
    Starting Zigbee2MQTT without watchdog.
    Error: EACCES: permission denied, unlink '/opt/zigbee2mqtt/data/log/2025-09-22.0        7-05-31/log.log'
        at unlinkSync (node:fs:1952:11)
        at _unlinkSync (node:internal/fs/rimraf:215:14)
        at rimrafSync (node:internal/fs/rimraf:196:7)
        at node:internal/fs/rimraf:254:9
        at Array.forEach (<anonymous>)
        at _rmdirSync (node:internal/fs/rimraf:251:7)
        at rimrafSync (node:internal/fs/rimraf:194:7)
        at rmSync (node:fs:1247:10)
        at rimrafNativeSync (/opt/zigbee2mqtt/node_modules/.pnpm/rimraf@6.0.1/node_m        odules/rimraf/src/rimraf-native.ts:21:9)
        at /opt/zigbee2mqtt/node_modules/.pnpm/rimraf@6.0.1/node_modules/rimraf/src/        index.ts:78:21
    npm notice
    npm notice New major version of npm available! 10.9.3 -> 11.6.0
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.6.0
    npm notice To update run: npm install -g npm@11.6.0
    npm notice
    pi@raspberrypi5:/opt/zigbee2mqtt $
    Das ist vom Coordinator da gibts keine Verbindung mehr
    • M Mico
      @arteck
       cd /opt/zigbee2mqtt
      npm start
      > node index.js
      npm notice
      npm notice
      Mico
      schrieb am zuletzt editiert von Mico
      und das ist beim Iobroker
      ee2mqtt.1
      	2025-09-22 13:38:57.543	warn	Start try again in 1 seconds...
      zigbee2mqtt.1
      	2025-09-22 13:38:56.542	warn	Start try again in 1 seconds...
      zigbee2mqtt.1
      	2025-09-22 13:38:55.541	warn	Start try again in 1 seconds...
      zigbee2mqtt.1
      	2025-09-22 13:38:54.540	warn	Start try again in 1 seconds...
      zigbee2mqtt.1
      	2025-09-22 13:38:53.539	warn	Start try again in 1 seconds...
      zigbee2mqtt.1
      	2025-09-22 13:38:52.537	warn	Start try again in 1 seconds...
      zigbee2mqtt.1
      	2025-09-22 13:38:51.535	warn	Start try again in 1 seconds...
      zigbee2mqtt.1
      	2025-09-22 13:38:50.534	warn	Start try again in 1 seconds...
      zigbee2mqtt.1
      	2025-09-22 13:38:49.532	warn	Start try again in 1 seconds...
      zigbee2mqtt.1
      	2025-09-22 13:38:48.530	warn	Start try again in 1 seconds...
      zigbee2mqtt.1
      	2025-09-22 13:38:47.529	warn	Start try again in 1 seconds...
      zigbee2mqtt.1
      	2025-09-22 13:38:46.527	warn	Start try again in 1 seconds...
      zigbee2mqtt.1
      	2025-09-22 13:38:45.526	warn	Start try again in 1 seconds...
      zigbee2mqtt.1
      	2025-09-22 13:38:44.526	warn	Start try again in 1 seconds...
      zigbee2mqtt.1
      	2025-09-22 13:38:43.524	warn	Start try again in 1 seconds...
      zigbee2mqtt.1
      	2025-09-22 13:38:42.523	warn	Start try again in 1 seconds...
      • M Mico
        ee2mqtt.1
        zigbee2mqtt.1
        zigbee2mqtt.1
        zigbee2mqtt.1
        zigbee2mqtt.1
        zigbee2mqtt.1
        zigbee2mqtt.1
        zigbee2mqtt.1
        zigbee2mqtt.1
        zigbee2mqtt.1
        zigbee2mqtt.1
        zigbee2mqtt.1
        zigbee2mqtt.1
        zigbee2mqtt.1
        zigbee2mqtt.1
        zigbee2mqtt.1
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @mico Logisch. Solange zigbee2mqtt.io nicht läuft wird der Adapter keine Verbindung aufbauen können.
        Laut dieser Meldung:
        hast du ein Rechte-Problem.
        Ich würde als erstens das System / den Container auf/in dem z2m läuft komplett neu starten. Dann versuchen z2m zu starten um zu sehen mit welchen Meldungen das schief geht. (wenn er nicht läuft)
        Ab da müsstest Du dann bei Zigbee2mqtt nachfragen - da sitzen die Experten für diese Probleme.
        A
        • AsgothianA Asgothian
          A
          Mico
          @asgothian
          Wie mache ich das genau ? Ich habe von Linux keinerlei Ahnung und hatte mir das einrichten lassen, und es lief ja auch deswegen könnte ich mir vorstellen das die Rechte ja noch da sind.
          hat das was mit diesem pnpm zu tun.
          • M Mico
            @asgothian
            Schau nach, was da genau los ist. Wie sehen die Rechte denn momentan aus? Auch am Dateisystem. Wenn es da Probleme gibt wird das z.B. 'nur lesend' eingehängt.
            Sowas steht u.a. in der Ausgabe von
            iob diag
            drin.
              iob diag
              drin.
              Mico
              Hiermal die iob diag
              ```bash
              Script v.2025-08-09
              *** BASE SYSTEM ***
               Static hostname: raspberrypi5
                     Icon name: computer
                        Kernel: Linux 6.12.34+rpt-rpi-2712
                  Architecture: arm64
              OS is similar to:
              Model           : Raspberry Pi 5 Model B Rev 1.0
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               11:24:49 up 1 day,  3:42,  4 users,  load average: 0.25, 0.20, 0.26
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              ~ Under-voltage has occurred
              ~ Arm frequency capping has occurred
              ~ Throttling has occurred
              ~ Soft temperature limit has occurred
              *** TIME AND TIMEZONES ***
                             Local time: Tue 2025-09-23 11:24:49 CEST
                         Universal time: Tue 2025-09-23 09:24:49 UTC
                               RTC time: Tue 2025-09-23 09:24:49
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              pi
              HOME=/home/pi
              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              *** DISPLAY-SERVER SETUP ***
              Display-Server:         true
              Display-Manager:        * lightdm.service - Light Display Manager
              Desktop:
              Session:                tty
              System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
              *** MEMORY ***
              Mem:            8.5G        4.1G        1.9G         28M        2.6G        4.4G
              Swap:           209M          0B        209M
              Total:          8.7G        4.1G        2.1G
              Active iob-Instances:   34
                       8063 M total memory
                       3902 M used memory
                       4344 M active memory
                       1354 M inactive memory
                       1832 M free memory
                        193 M buffer memory
                       2249 M swap cache
                        199 M total swap
                          0 M used swap
                        199 M free swap
              top - 11:24:50 up 1 day,  3:42,  4 users,  load average: 0.25, 0.20, 0.26
              Tasks: 264 total,   1 running, 263 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni, 66.7 id, 33.3 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   8063.2 total,   1832.7 free,   3902.8 used,   2443.0 buff/cache
              MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4160.4 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              udev           devtmpfs  3.9G     0  3.9G   0% /dev
              tmpfs          tmpfs     1.6G  6.0M  1.6G   1% /run
              /dev/mmcblk0p2 ext4       58G   52G  3.5G  94% /
              tmpfs          tmpfs     4.0G  400K  4.0G   1% /dev/shm
              tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
              /dev/mmcblk0p1 vfat      510M   78M  433M  16% /boot/firmware
              tmpfs          tmpfs     807M  176K  807M   1% /run/user/1000
              [Mon Sep 22 07:42:33 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:32:68:16 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=a84847a9-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Mon Sep 22 07:42:34 2025] EXT4-fs (mmcblk0p2): mounted filesystem 5170097f-f1f6-42d8-a2ff-8938cbdfa7be ro with ordered data mode. Quota mode: none.
              [Mon Sep 22 07:42:35 2025] EXT4-fs (mmcblk0p2): re-mounted 5170097f-f1f6-42d8-a2ff-8938cbdfa7be r/w.
              Show mounted filesystems:
              TARGET               SOURCE         FSTYPE      OPTIONS
              /                    /dev/mmcblk0p2 ext4        rw,noatime
              |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              41G     /var/
              38G     /var/lib/influxdb/engine/data
              38G     /var/lib
              Archived and active journals take up 2.3G in the file system.
              /opt/iobroker/backups:
              90M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              1.4G    /opt/iobroker/iobroker-data/
              855M    /opt/iobroker/iobroker-data/history
              381M    /opt/iobroker/iobroker-data/files
              123M    /opt/iobroker/iobroker-data/backup-objects
              52M     /opt/iobroker/iobroker-data/files/vis-2
              38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
              26M     /opt/iobroker/iobroker-data/objects.jsonl
              24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
              20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
              19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
              USB-Devices by-id:
              /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03218114-if00-port0
              *** ZigBee Settings ***
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v22.19.0
              /usr/bin/node           v22.19.0
              /usr/bin/npm            10.9.3
              /usr/bin/npx            10.9.3
              /usr/bin/corepack       0.34.0
              nodejs:
                Installed: 22.19.0-1nodesource1
                Candidate: 22.19.0-1nodesource1
                Version table:
               *** 22.19.0-1nodesource1 600
                      500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                   22.18.0-1nodesource1 600
                   22.17.1-1nodesource1 600
                   22.17.0-1nodesource1 600
                   22.16.0-1nodesource1 600
                   22.15.1-1nodesource1 600
                   22.15.0-1nodesource1 600
                   22.14.0-1nodesource1 600
                   22.13.1-1nodesource1 600
                   22.13.0-1nodesource1 600
                   22.12.0-1nodesource1 600
                   22.11.0-1nodesource1 600
                   22.10.0-1nodesource1 600
                   22.9.0-1nodesource1 600
                   22.8.0-1nodesource1 600
                   22.7.0-1nodesource1 600
                   22.6.0-1nodesource1 600
                   22.5.1-1nodesource1 600
                   22.5.0-1nodesource1 600
                   22.4.1-1nodesource1 600
                   22.4.0-1nodesource1 600
                   22.3.0-1nodesource1 600
                   22.2.0-1nodesource1 600
                   22.1.0-1nodesource1 600
                   22.0.0-1nodesource1 600
                   18.20.4+dfsg-1~deb12u1 500
                      500 http://deb.debian.org/debian bookworm/main arm64 Packages
                      500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              raspberrypi2        raspberrypi2 (version: 7.0.7, hostname: raspberrypi2  , alive, uptime: 110835)
              raspberrypi5        raspberrypi5 (version: 7.0.7, hostname: raspberrypi5  , alive, uptime: 99713)
              Core adapters versions
              js-controller:  7.0.7
              admin:          7.7.2
              javascript:     8.9.2
              nodejs modules from github:     2
              | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
              +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
              Adapter State
              + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : raspberrypi5                             -  enabled
                system.adapter.alias-manager.0          : alias-manager         : raspberrypi5                             - disabled
              + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
              + system.adapter.cloud.0                  : cloud                 : raspberrypi5                             -  enabled
              + system.adapter.device-reminder.0        : device-reminder       : raspberrypi5                             -  enabled
                system.adapter.devices.0                : devices               : raspberrypi5                             - disabled
              + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
              + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi5                             -  enabled
              + system.adapter.geofency.0               : geofency              : raspberrypi5                             -  enabled, port: 7999, bind: 0.0.0.0
              + system.adapter.growatt.0                : growatt               : raspberrypi5                             -  enabled
                system.adapter.habpanel.0               : habpanel              : raspberrypi5                             - disabled
              + system.adapter.history.0                : history               : raspberrypi5                             -  enabled
                system.adapter.ical.0                   : ical                  : raspberrypi5                             -  enabled
                system.adapter.icons-freepic.0          : icons-freepic         : raspberrypi5                             - disabled
                system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi5                             - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi5                             - disabled
              + system.adapter.influxdb.0               : influxdb              : raspberrypi5                             -  enabled, port: 8086
              + system.adapter.iot.0                    : iot                   : raspberrypi5                             -  enabled
              + system.adapter.javascript.0             : javascript            : raspberrypi5                             -  enabled
              + system.adapter.meross.0                 : meross                : raspberrypi5                             -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : raspberrypi2                             -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.mqtt.1                   : mqtt                  : raspberrypi5                             -  enabled, port: 1886, bind: 0.0.0.0
              + system.adapter.node-red.0               : node-red              : raspberrypi5                             -  enabled, port: 1880, bind: 0.0.0.0
                system.adapter.openweathermap.0         : openweathermap        : raspberrypi5                             -  enabled
              + system.adapter.pushover.0               : pushover              : raspberrypi5                             -  enabled
              + system.adapter.reolink.0                : reolink               : raspberrypi5                             -  enabled
              + system.adapter.reolink.1                : reolink               : raspberrypi5                             -  enabled
                system.adapter.samsung.0                : samsung               : raspberrypi5                             - disabled
                system.adapter.samsung_tizen.0          : samsung_tizen         : raspberrypi5                             - disabled, port: 8002
              + system.adapter.scenes.0                 : scenes                : raspberrypi5                             -  enabled
              + system.adapter.shelly.0                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shelly.1                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
                system.adapter.smartthings.0            : smartthings           : raspberrypi5                             - disabled
              + system.adapter.sonoff.0                 : sonoff                : raspberrypi2                             -  enabled, port: 1889, bind: 0.0.0.0
              + system.adapter.statistics.0             : statistics            : raspberrypi5                             -  enabled
              + system.adapter.telegram.0               : telegram              : raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.text2command.0           : text2command          : raspberrypi5                             -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi5                             -  enabled
              + system.adapter.tuya.0                   : tuya                  : raspberrypi5                             -  enabled
              + system.adapter.vis-2.0                  : vis-2                 : raspberrypi5                             -  enabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi5                             - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi5                             - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi5                             - disabled
                system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi5                             - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi5                             - disabled
                system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
              + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.yahka.0                  : yahka                 : raspberrypi5                             -  enabled
                system.adapter.yr.0                     : yr                    : raspberrypi5                             -  enabled
              + system.adapter.zigbee2mqtt.1            : zigbee2mqtt           : raspberrypi5                             -  enabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Upgrade policy: none
              Installed ioBroker-Adapters
              Used repository: stable
              Adapter    "admin"        : 7.7.2    , installed 7.7.2
              Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
              Adapter    "alias-manager": 2.0.0    , installed 2.0.0
              Adapter    "backitup"     : 3.3.5    , installed 3.3.5
              Adapter    "device-reminder": 3.1.2  , installed 3.1.2
              Adapter    "devices"      : 1.2.8    , installed 1.2.8
              Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
              Adapter    "geofency"     : 1.2.4    , installed 1.2.4
              Adapter    "growatt"      : 3.3.1    , installed 3.3.1
              Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
              Adapter    "ical"         : 1.16.2   , installed 1.16.2
              Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
              Adapter    "iot"          : 3.3.0    , installed 3.3.0
              Adapter    "javascript"   : 8.9.2    , installed 8.9.2
              Controller "js-controller": 7.0.7    , installed 7.0.7
              Adapter    "meross"       : 1.17.0   , installed 1.17.0
              Adapter    "node-red"     : 5.2.1    , installed 5.2.1
              Adapter    "openweathermap": 1.1.2   , installed 1.1.2
              Adapter    "pushover"     : 4.1.0    , installed 4.1.0
              Adapter    "reolink"      : 1.2.3    , installed 1.2.3
              Adapter    "samsung"      : 0.6.1    , installed 0.6.1
              Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
              Adapter    "scenes"       : 3.2.3    , installed 3.2.3
              Adapter    "shelly"       : 10.2.0   , installed 10.1.0 [Updatable]
              Adapter    "socketio"     : 6.7.1    , installed 7.0.8
              Adapter    "statistics"   : 2.4.0    , installed 2.4.0
              Adapter    "text2command" : 3.0.3    , installed 3.0.3
              Adapter    "trashschedule": 3.3.0    , installed 3.3.0
              Adapter    "tuya"         : 3.16.0   , installed 3.16.0
              Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
              Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
              Adapter    "web"          : 7.0.8    , installed 7.0.8
              Adapter    "ws"           : 2.6.2    , installed 3.0.19
              Adapter    "yahka"        : 1.1.5    , installed 1.1.5
              Adapter    "yr"           : 5.3.0    , installed 5.3.0
              Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
              Objects and States
              Objects:        14307
              States:         11426
              W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://apt.grafana.com stable InRelease: The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
              W: Failed to fetch https://apt.grafana.com/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
              W: Some index files failed to download. They have been ignored, or old ones used instead.
              Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:4 https://repos.influxdata.com/debian stable InRelease
              Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
              Get:6 https://apt.grafana.com stable InRelease [7661 B]
              Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
              Hit:8 https://repo.mosquitto.org/debian bookworm InRelease
              Err:6 https://apt.grafana.com stable InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       13481      2232/node-red
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       13669      2493/io.shelly.0
              tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      113        5712       826/mosquitto
              tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       12770      2448/io.mqtt.1
              tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       12771      2448/io.mqtt.1
              tcp        0      0 0.0.0.0:42545           0.0.0.0:*               LISTEN      1001       14969      2551/io.yahka.0
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4964       839/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          725830     76392/cupsd
              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       14338      2031/iobroker.js-co
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       11261      2031/iobroker.js-co
              tcp        0      0 127.0.0.1:35259         0.0.0.0:*               LISTEN      1001       974326     2551/io.yahka.0
              tcp6       0      0 :::1884                 :::*                    LISTEN      113        5713       826/mosquitto
              tcp6       0      0 :::22                   :::*                    LISTEN      0          4966       839/sshd: /usr/sbin
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          725829     76392/cupsd
              tcp6       0      0 :::7999                 :::*                    LISTEN      1001       12219      2389/io.geofency.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11813      2082/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15708      2768/io.web.0
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        10181      1440/influxd
              tcp6       0      0 :::3000                 :::*                    LISTEN      112        13322      2030/grafana
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5597       652/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       13692      2508/io.shelly.1
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       12853      2532/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       12854      2532/io.tuya.0
              udp        0      0 0.0.0.0:55972           0.0.0.0:*                           104        5599       652/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                104        5598       652/avahi-daemon: r
              udp6       0      0 :::43836                :::*                                104        5600       652/avahi-daemon: r
              udp6       0      0 fe80::201f:2fec:9bc:546 :::*                                0          10723      783/NetworkManager
              2025-09-23 11:24:56.154  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:24:57.154  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:24:58.156  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:24:59.157  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:00.161  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:01.161  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:02.162  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:03.164  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:04.164  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:05.166  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:06.167  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:07.167  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:08.167  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:09.169  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:10.170  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:11.172  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:12.173  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:13.173  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:14.173  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:15.175  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:16.176  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:17.177  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:18.178  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:19.179  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              2025-09-23 11:25:20.180  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
              iob diag has finished.
              Mico
              • M Mico
                ```bash
                Script v.2025-08-09
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                CPU threads: 4
                Current issues:
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                iobroker
                HOME=/home/iobroker
                Desktop:
                Session:                tty
                *** MEMORY ***
                Swap:           209M          0B        209M
                         8063 M total memory
                         3902 M used memory
                         1832 M free memory
                          193 M buffer memory
                         2249 M swap cache
                          199 M total swap
                            0 M used swap
                          199 M free swap
                *** FILESYSTEM ***
                /var:
                41G     /var/
                38G     /var/lib
                USB-Devices by-id:
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.9.3
                /usr/bin/npx            10.9.3
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.7.2
                javascript:     8.9.2
                Adapter State
                + instance is alive
                Objects and States
                Objects:        14307
                States:         11426
                Pending Updates: 0
                Mico
                Da ist die Spannungsversorgung zu knapp.
                Betreib die Kiste ohne graphische Oberfläche.
                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://apt.grafana.com stable InRelease: The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs engineering@grafana.com
                Leg das Grafana-Repository neu an.
                Zu zigbee2mqtt:
                systemctl status zigbee2mqtt
                sagt?
                  Zu zigbee2mqtt:
                  sagt?
                  Mico
                  @thomas-braun said in zigbee2mqtt läuft sein heute morgen nicht mehr:
                  Grafana nutze ich gar nicht wirklich hatte dieses nur mitinstaliert brauche ich bisher nicht.
                  pi@raspberrypi5:/opt/zigbee2mqtt $ systemctl status zigbee2mqtt
                  ● zigbee2mqtt.service - zigbee2mqtt
                       Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; preset: enabled)
                       Active: active (running) since Tue 2025-09-23 11:59:07 CEST; 44s ago
                     Main PID: 131911 (node)
                        Tasks: 11 (limit: 9572)
                          CPU: 3.211s
                       CGroup: /system.slice/zigbee2mqtt.service
                               └─131911 /usr/bin/node index.js
                  Sep 23 11:59:07 raspberrypi5 systemd[1]: Started zigbee2mqtt.service - zigbee2mqtt.
                  Sep 23 11:59:10 raspberrypi5 node[131911]: [2025-09-23 11:59:10] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Steckdose Keller', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"energy":0,"indicator_mode":"off/on","linkquality":80,"power":0,"power_o>
                  Sep 23 11:59:19 raspberrypi5 node[131911]: [2025-09-23 11:59:19] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/SNZB-02 Gästezimmer', payload '{"battery":100,"humidity":71.5,"linkquality":131,"temperature":18.08,"voltage":3000}'
                  Sep 23 11:59:25 raspberrypi5 node[131911]: [2025-09-23 11:59:25] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Mückensteckdose', payload '{"child_lock":"UNLOCK","current":0.02,"energy":3.39,"indicator_mode":"off","linkquality":29,"power":3,"power_outage_memory>
                  Sep 23 11:59:26 raspberrypi5 node[131911]: [2025-09-23 11:59:26] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Fernseherleiste', payload '{"child_lock":"UNLOCK","countdown":0,"current":0.24,"energy":88.88,"indicator_mode":"off/on","linkquality":138,"power":28,>
                  Sep 23 11:59:26 raspberrypi5 node[131911]: [2025-09-23 11:59:26] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Fernseherleiste', payload '{"child_lock":"UNLOCK","countdown":0,"current":0.24,"energy":90.27,"indicator_mode":"off/on","linkquality":138,"power":28,>
                  Sep 23 11:59:26 raspberrypi5 node[131911]: [2025-09-23 11:59:26] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/IR-Licht Steuerung-01', payload '{"countdown":0,"current":0,"energy":1.92,"indicator_mode":"off","linkquality":80,"power":0,"state":"OFF","update":{">
                  Sep 23 11:59:28 raspberrypi5 node[131911]: [2025-09-23 11:59:28] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/SNZB-02 Bad', payload '{"battery":100,"humidity":78.68,"linkquality":80,"temperature":21.74,"voltage":3000}'
                  Sep 23 11:59:33 raspberrypi5 node[131911]: [2025-09-23 11:59:33] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Steckdose Wasch-Küche', payload '{"child_lock":"UNLOCK","current":0,"energy":6.32,"indicator_mode":"off","linkquality":80,"power":0,"power_outage_mem>
                  Sep 23 11:59:48 raspberrypi5 node[131911]: [2025-09-23 11:59:48] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Steckdose Küche', payload '{"child_lock":"UNLOCK","countdown":0,"current":0.03,"energy":7.75,"indicator_mode":"off/on","linkquality":36,"power":3,"po>
                  lines 1-19/19 (END)
                  Was hat das zu sagen von der pnpm
                  pi@raspberrypi5:/opt/zigbee2mqtt $ sudo pnpm start
                  > zigbee2mqtt@2.6.1 start /opt/zigbee2mqtt
                  > node index.js
                  [2025-09-23 11:57:42] info:     z2m: Logging to console, file (filename: log.log)
                  [2025-09-23 11:57:43] info:     z2m: Starting Zigbee2MQTT version 2.6.1 (commit #d44463a3)
                  [2025-09-23 11:57:43] info:     z2m: Starting zigbee-herdsman (6.0.4)
                  [2025-09-23 11:57:43] info:     zh:zstack:znp: Opening TCP socket with 192.168.178.103:6638
                  [2025-09-23 11:57:43] info:     zh:zstack:znp: Socket connected
                  [2025-09-23 11:57:43] info:     zh:zstack:znp: Socket ready
                  [2025-09-23 11:57:43] info:     zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
                  [2025-09-23 11:57:44] info:     zh:zstack:znp: Skip bootloader for CC2652/CC1352
                  [2025-09-23 11:58:10] error:    z2m: Error while starting zigbee-herdsman
                  [2025-09-23 11:58:10] error:    z2m: Failed to start zigbee-herdsman
                  [2025-09-23 11:58:10] error:    z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
                  [2025-09-23 11:58:10] error:    z2m: Exiting...
                  [2025-09-23 11:58:10] error:    z2m: TypeError: Cannot read properties of undefined (reading 'payload')
                      at AdapterNvMemory.readExtendedTableEntry (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-nv-memory.ts:219:30)
                      at processTicksAndRejections (node:internal/process/task_queues:105:5)
                      at AdapterNvMemory.readTable (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-nv-memory.ts:365:28)
                      at AdapterBackup.getNetworkSecurityMaterialTable (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:508:20)
                      at AdapterBackup.restoreBackup (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:288:44)
                      at ZnpAdapterManager.beginRestore (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:316:9)
                      at ZnpAdapterManager.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:78:21)
                      at ZStackAdapter.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:154:16)
                      at Controller.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
                      at Zigbee.start (/opt/zigbee2mqtt/lib/zigbee.ts:67:27)
                   ELIFECYCLE  Command failed with exit code 1.
                  Mico
                  • M Mico
                            CPU: 3.211s
                    lines 1-19/19 (END)
                    > node index.js
                    Mico
                    Egal, korrigier das.
                    Schau da mal rein.
                    • M Mico
                              CPU: 3.211s
                      lines 1-19/19 (END)
                      > node index.js
                      Mico
                      sudo pnpm start
                      Und da bin ich nicht sicher, ob das der richtige und beste Weg ist zigbee2mqtt zu starten.
                      Das macht man eigentlich über die systemd-Services, wenn es die ja schon gibt. Also
                      systemctl [start|stop|restart] zigbee2mqtt.service
                        sudo pnpm start
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @thomas-braun ne du ist es auch nicht... das ist nur mal zum starten wenn du debug infos haben willst..
                        @Mico hier steht alles beschrieben und bitte die Seite zu ende lesen
                        https://www.zigbee2mqtt.io/guide/installation/01_linux.html#starting-zigbee2mqtt
