  3. Off Topic
  4. Pflege des Betriebssystems
  5. Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie'
    6.8k
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
265 Beiträge 50 Kommentatoren 78.5k Aufrufe 56 Beobachtet
  • R Ritter
    @thomas-braun soll ich den kompletten text posten oder nur bestimmtes?
    #70
    @ritter Das läuft also?
    Poste das mal komplett.
    R 1 Antwort Letzte Antwort
      Ritter
      #71
      @thomas-braun Ja
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: NUC
             Icon name: computer-desktop
               Chassis: desktop 🖥️
                Kernel: Linux 6.12.41+deb13-amd64
          Architecture: x86-64
       Hardware Vendor: Intel corporation
        Hardware Model: NUC6i3SYB
      Firmware Version: SYSKLi35.86A.0070.2019.0401.1729
         Firmware Date: Mon 2019-04-01
          Firmware Age: 6y 4month 2w 2d
      OS is similar to:
      model name      : Intel(R) Core(TM) i3-6100U CPU @ 2.30GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       14:03:16 up  1:07,  2 users,  load average: 1.00, 1.06, 1.03
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** TIME AND TIMEZONES ***
                     Local time: Sat 2025-08-16 14:03:16 CEST
                 Universal time: Sat 2025-08-16 12:03:16 UTC
                       RTC time: Sat 2025-08-16 12:03:16
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      christian
      HOME=/home/christian
      GROUPS=christian cdrom floppy sudo audio dip video plugdev users netdev iobroker
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/christian
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:             33G        5.8G         26G        1.8M        1.4G         27G
      Swap:           1.0G          0B        1.0G
      Total:           34G        5.8G         27G
      Active iob-Instances:   72
              31993 M total memory
               5495 M used memory
               5050 M active memory
                940 M inactive memory
              25572 M free memory
                154 M buffer memory
               1175 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      top - 14:03:16 up  1:07,  2 users,  load average: 1.00, 1.06, 1.03
      Tasks: 198 total,   3 running, 195 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 16.1 us,  5.4 sy,  0.0 ni, 76.8 id,  1.8 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  31993.3 total,  25571.1 free,   5496.2 used,   1330.7 buff/cache
      MiB Swap:    975.0 total,    975.0 free,      0.0 used.  26497.2 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs   16G     0   16G   0% /dev
      tmpfs          tmpfs     3.2G  808K  3.2G   1% /run
      /dev/sda1      ext4      468G   63G  382G  14% /
      tmpfs          tmpfs      16G     0   16G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      tmpfs          tmpfs      16G  668K   16G   1% /tmp
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      tmpfs          tmpfs     3.2G  8.0K  3.2G   1% /run/user/1000
      [Sat Aug 16 12:55:40 2025] EXT4-fs (sda1): mounted filesystem 96448ee6-f182-4f61-a44e-5eb0f63f92f9 ro with ordered data mode. Quota mode: none.
      [Sat Aug 16 12:55:41 2025] EXT4-fs (sda1): re-mounted 96448ee6-f182-4f61-a44e-5eb0f63f92f9 r/w.
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      2.2G    /var/
      1.5G    /var/log/journal/08006622a09d4dd5b7dc7c548ff96709
      1.5G    /var/log
      566M    /var/cache
      Archived and active journals take up 86M in the file system.
      /opt/iobroker/backups:
      8.2G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.6G    /opt/iobroker/iobroker-data/
      1.2G    /opt/iobroker/iobroker-data/files
      308M    /opt/iobroker/iobroker-data/backup-objects
      287M    /opt/iobroker/iobroker-data/files/vis
      278M    /opt/iobroker/iobroker-data/files/vis/widgets
      63M     /opt/iobroker/iobroker-data/states.jsonl
      63M     /opt/iobroker/iobroker-data/objects.jsonl
      49M     /opt/iobroker/iobroker-data/files/0_userdata.0/cam9.mp4
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      33M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
      USB-Devices by-id:
      No Devices found 'by-id'
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.18.0
      /usr/bin/node           v22.18.0
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      /usr/bin/corepack       0.33.0
      nodejs:
        Installed: 22.18.0-1nodesource1
        Candidate: 22.18.0-1nodesource1
        Version table:
       *** 22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.2+dfsg-1 500
              500 http://deb.debian.org/debian trixie/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      NUC                 NUC (version: 7.0.7, hostname: NUC           , alive, uptime: 4058)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.2
      javascript:     9.0.11
      nodejs modules from github:     8
      +-- iobroker.klipper-moonraker@0.1.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.klipper-moonraker.git#0d2851e        98f7443e85ebe29d98d8d725640dd0a8a)
      +-- iobroker.pirate-weather@0.1.4 (git+ssh://git@github.com/ticaki/ioBroker.pirate-weather.git#f70e2e8f1968bfe6        5afabf792ca73253a19f8321)
      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8        635550)
      +-- iobroker.signifylights@1.0.0 (git+ssh://git@github.com/disaster123/ioBroker.signifylights.git#bb475662d63f1        e39993c2b4e9fb395c29dcd1adc)
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      +-- iobroker.tuya@3.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.tuya.git#640df7360a877f37764a31d628e4d6de        3ed1f6e3)
      +-- iobroker.xsense@0.0.12 (git+ssh://git@github.com/arteck/ioBroker.xsense.git#cae2e07ac3d59527f701426739ed0cf        14afdd0de)
      +-- iobroker.yr@5.3.0 (git+ssh://git@github.com/ioBroker/ioBroker.yr.git#dec7b7f69b3968a43a390e2b2a60391c2dca6b        23)
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : NUC                                      -        enabled
      + system.adapter.admin.0                  : admin                 : NUC                                      -        enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : NUC                                      -        disabled
      + system.adapter.backitup.0               : backitup              : NUC                                      -        enabled
      + system.adapter.chromecast.0             : chromecast            : NUC                                      -        enabled
        system.adapter.daswetter.0              : daswetter             : NUC                                      -        enabled
      + system.adapter.device-reminder.0        : device-reminder       : NUC                                      -        enabled
      + system.adapter.device-watcher.0         : device-watcher        : NUC                                      -        enabled
        system.adapter.devices.0                : devices               : NUC                                      -        disabled
      + system.adapter.discovery.0              : discovery             : NUC                                      -        enabled
        system.adapter.drops-weather.0          : drops-weather         : NUC                                      -        disabled
        system.adapter.dwd.0                    : dwd                   : NUC                                      -        enabled
      + system.adapter.echarts.0                : echarts               : NUC                                      -        enabled
      + system.adapter.email.0                  : email                 : NUC                                      -        enabled
      + system.adapter.email.1                  : email                 : NUC                                      -        enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: NUC                                      -        enabled
      + system.adapter.enigma2.0                : enigma2               : NUC                                      -        enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : NUC                                      -        enabled
        system.adapter.feiertage.0              : feiertage             : NUC                                      -        enabled
        system.adapter.flot.0                   : flot                  : NUC                                      -        disabled
      + system.adapter.fullcalendar.0           : fullcalendar          : NUC                                      -        enabled
        system.adapter.habpanel.0               : habpanel              : NUC                                      -        disabled
      + system.adapter.hass.0                   : hass                  : NUC                                      -        enabled, port: 8123
      + system.adapter.heizoel.0                : heizoel               : NUC                                      -        enabled
      + system.adapter.history.0                : history               : NUC                                      -        enabled
      + system.adapter.hm-rega.0                : hm-rega               : NUC                                      -        enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : NUC                                      -        enabled, port: 3000
      + system.adapter.hm-rpc.1                 : hm-rpc                : NUC                                      -        enabled, port: 4000
      + system.adapter.hm-rpc.2                 : hm-rpc                : NUC                                      -        enabled, port: 5000
      + system.adapter.hm-rpc.3                 : hm-rpc                : NUC                                      -        enabled, port: 5500
      + system.adapter.homeconnect.0            : homeconnect           : NUC                                      -        enabled
        system.adapter.ical.0                   : ical                  : NUC                                      -        enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: NUC        - disabled
        system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: NUC        -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : NUC                                      -        disabled
        system.adapter.icons-freepic.0          : icons-freepic         : NUC                                      -        enabled
        system.adapter.icons-icons8.0           : icons-icons8          : NUC                                      -        disabled
        system.adapter.icons-material-png.0     : icons-material-png    : NUC                                      -        disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : NUC                                      -        disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : NUC                                      -        disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : NUC                                      -        disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: NUC        - disabled
        system.adapter.icons-smarthome.0        : icons-smarthome       : NUC                                      -        enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : NUC                                      -        disabled
      + system.adapter.iot.0                    : iot                   : NUC                                      -        enabled
      + system.adapter.javascript.0             : javascript            : NUC                                      -        enabled
        system.adapter.klipper-moonraker.0      : klipper-moonraker     : NUC                                      -        disabled
      + system.adapter.linux-control.0          : linux-control         : NUC                                      -        enabled
        system.adapter.material.0               : material              : NUC                                      -        disabled
      + system.adapter.matter.0                 : matter                : NUC                                      -        enabled
        system.adapter.meross.0                 : meross                : NUC                                      -        disabled
        system.adapter.meteoalarm.0             : meteoalarm            : NUC                                      -        enabled
        system.adapter.mobile.0                 : mobile                : NUC                                      -        disabled
      + system.adapter.mqtt.0                   : mqtt                  : NUC                                      -        enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.nina.0                   : nina                  : NUC                                      -        enabled
        system.adapter.node-red.0               : node-red              : NUC                                      -        disabled, port: 1880, bind: 0.0.0.0
        system.adapter.odl.0                    : odl                   : NUC                                      -        enabled
      + system.adapter.onkyo.0                  : onkyo                 : NUC                                      -        enabled
      + system.adapter.onvif.0                  : onvif                 : NUC                                      -        enabled, port: 8000
      + system.adapter.opendtu.0                : opendtu               : NUC                                      -        enabled
        system.adapter.openweathermap.0         : openweathermap        : NUC                                      -        enabled
      + system.adapter.parser.0                 : parser                : NUC                                      -        enabled
      + system.adapter.ping.0                   : ping                  : NUC                                      -        enabled
        system.adapter.pirate-weather.0         : pirate-weather        : NUC                                      -        disabled
      + system.adapter.places.0                 : places                : NUC                                      -        enabled
      + system.adapter.pollenflug.0             : pollenflug            : NUC                                      -        enabled
      + system.adapter.pushover.0               : pushover              : NUC                                      -        enabled
      + system.adapter.reolink.0                : reolink               : NUC                                      -        enabled
        system.adapter.rickshaw.0               : rickshaw              : NUC                                      -        disabled
      + system.adapter.sainlogic.0              : sainlogic             : NUC                                      -        enabled, port: 45000, bind: 0.0.0.0
      + system.adapter.samsung.0                : samsung               : NUC                                      -        enabled
      + system.adapter.samsung_tizen.0          : samsung_tizen         : NUC                                      -        enabled, port: 8002
      + system.adapter.sayit.0                  : sayit                 : NUC                                      -        enabled
      + system.adapter.sayit.7                  : sayit                 : NUC                                      -        enabled
      + system.adapter.scenes.0                 : scenes                : NUC                                      -        enabled
      + system.adapter.scheduler.0              : scheduler             : NUC                                      -        enabled
      + system.adapter.signifylights.0          : signifylights         : NUC                                      -        enabled
      + system.adapter.simple-api.0             : simple-api            : NUC                                      -        enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.socketio.0               : socketio              : NUC                                      -        enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : NUC                                      -        enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.statistics.0             : statistics            : NUC                                      -        enabled
      + system.adapter.synology.0               : synology              : NUC                                      -        enabled, port: 5000
      + system.adapter.tankerkoenig.0           : tankerkoenig          : NUC                                      -        enabled
      + system.adapter.telegram.0               : telegram              : NUC                                      -        enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : NUC                                      -        enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : NUC                                      -        enabled
      + system.adapter.text2command.1           : text2command          : NUC                                      -        enabled
      + system.adapter.time-switch.0            : time-switch           : NUC                                      -        enabled
      + system.adapter.tr-064.0                 : tr-064                : NUC                                      -        enabled
      + system.adapter.trashschedule.0          : trashschedule         : NUC                                      -        enabled
      + system.adapter.tuya.0                   : tuya                  : NUC                                      -        enabled
      + system.adapter.vesync.0                 : vesync                : NUC                                      -        enabled
        system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: NUC        -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : NUC                                      -        disabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : NUC                                      -        disabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: NUC                                      -        enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: NUC                                      -        disabled
        system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: NUC        -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : NUC                                      -        enabled
        system.adapter.vis-bars.0               : vis-bars              : NUC                                      -        disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : NUC                                      -        disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : NUC                                      -        disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : NUC                                      -        disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : NUC                                      -        enabled
        system.adapter.vis-history.0            : vis-history           : NUC                                      -        disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : NUC                                      -        disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : NUC                                      -        disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : NUC                                      -        enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : NUC                                      -        disabled
        system.adapter.vis-justgage.0           : vis-justgage          : NUC                                      -        disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : NUC                                      -        disabled
        system.adapter.vis-map.0                : vis-map               : NUC                                      -        disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : NUC                                      -        disabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : NUC                                      -        disabled
        system.adapter.vis-material.0           : vis-material          : NUC                                      -        disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : NUC                                      -        disabled
        system.adapter.vis-metro.0              : vis-metro             : NUC                                      -        disabled
        system.adapter.vis-players.0            : vis-players           : NUC                                      -        disabled
        system.adapter.vis-plumb.0              : vis-plumb             : NUC                                      -        enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : NUC                                      -        disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : NUC                                      -        disabled
        system.adapter.vis-weather.0            : vis-weather           : NUC                                      -        disabled
        system.adapter.vis.0                    : vis                   : NUC                                      -        enabled
      + system.adapter.weather-warnings.0       : weather-warnings      : NUC                                      -        enabled
      + system.adapter.web.0                    : web                   : NUC                                      -        enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.windows-control.0        : windows-control       : NUC                                      -        enabled
      + system.adapter.wled.0                   : wled                  : NUC                                      -        enabled
      + system.adapter.xsense.0                 : xsense                : NUC                                      -        enabled
      + system.adapter.yamaha.0                 : yamaha                : NUC                                      -        enabled
        system.adapter.yr.0                     : yr                    : NUC                                      -        enabled
      + system.adapter.zendure-solarflow.0      : zendure-solarflow     : NUC                                      -        enabled
      + system.adapter.zigbee.0                 : zigbee                : NUC                                      -        enabled, port: tcp://192.168.1.49:6638
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name          │ url        │ auto upgrade │
      │ 0       │ 'online'      │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-di        st.json' │ false        │
      │ 1       │ 'fast-online' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 2       │ 'stable'      │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 3       │ 'beta'        │ 'http://download.iobroker.net/sources-dist-latest.json'        │ false        │
      Active repo(s): beta
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: beta
      Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
      Adapter    "admin"        : 7.7.2    , installed 7.7.2
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.12.6  , installed 2.12.6
      Adapter    "devices"      : 1.2.8    , installed 1.2.8
      Adapter    "drops-weather": 1.2.7    , installed 1.2.7
      Adapter    "echarts"      : 2.0.6    , installed 2.0.6
      Adapter    "email"        : 2.0.4    , installed 2.0.4
      Adapter    "energiefluss-erweitert": 0.7.8, installed 0.7.8
      Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
      Adapter    "fb-checkpresence": 1.4.0 , installed 1.4.0
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
      Adapter    "ical"         : 1.16.2   , installed 1.16.2
      Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
      Adapter    "iot"          : 3.6.0    , installed 3.6.0
      Adapter    "javascript"   : 9.0.11   , installed 9.0.11
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "matter"       : 0.5.2    , installed 0.5.2
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "meteoalarm"   : 4.0.1    , installed 4.0.1
      Adapter    "nina"         : 0.0.26   , installed 0.0.26
      Adapter    "node-red"     : 6.0.7    , installed 6.0.7
      Adapter    "odl"          : 5.0.0    , installed 5.0.0
      Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
      Adapter    "openweathermap": 1.4.0   , installed 1.4.0
      Adapter    "parser"       : 2.3.1    , installed 2.3.1
      Adapter    "ping"         : 1.7.9    , installed 1.7.9
      Adapter    "places"       : 1.3.0    , installed 1.3.0
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "reolink"      : 1.2.3    , installed 1.2.3
      Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
      Adapter    "sainlogic"    : 0.12.1   , installed 0.12.1
      Adapter    "samsung"      : 0.6.1    , installed 0.6.1
      Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
      Adapter    "scenes"       : 4.0.3    , installed 4.0.3
      Adapter    "scheduler"    : 1.5.0    , installed 1.5.0
      Adapter    "signifylights": 1.0.0    , installed 1.0.0
      Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
      Adapter    "socketio"     : 7.0.8    , installed 7.0.8
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "statistics"   : 4.0.0    , installed 4.0.0
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
      Adapter    "trashschedule": 4.0.1    , installed 4.0.1
      Adapter    "tuya"         : 3.17.0   , installed 3.17.0
      Adapter    "vesync"       : 0.0.9    , installed 0.0.9
      Adapter    "vis-2"        : 2.12.12  , installed 2.12.12
      Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.1
      Adapter    "vis-2-widgets-inventwo": 0.3.5, installed 0.3.5
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-2-widgets-weather-and-heating": 1.1.1, installed 1.1.1
      Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "vis-material" : 0.2.0    , installed 0.2.0
      Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
      Adapter    "weather-warnings": 0.7.4 , installed 0.7.4
      Adapter    "web"          : 7.0.9    , installed 7.0.9
      Adapter    "windows-control": 0.1.5  , installed 0.1.5
      Adapter    "wled"         : 0.7.3    , installed 0.7.3
      Adapter    "ws"           : 3.0.19   , installed 3.0.19
      Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zendure-solarflow": 2.0.1, installed 2.0.1
      Adapter    "zigbee"       : 3.0.3    , installed 3.0.3
      Objects and States
      Objects:        51207
      States:         39525
      W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, s        ee --audit for details
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://security.debian.org/debian-security trixie-security InRelease
      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists... Done
      Pending Updates: 0
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Progr        am name
      tcp        0      0 0.0.0.0:45000           0.0.0.0:*               LISTEN      1001       16865      3291/io.s        ainlogic.0
      tcp        0      0 192.168.1.31:5500       0.0.0.0:*               LISTEN      1001       9642       1375/io.h        m-rpc.3
      tcp        0      0 192.168.1.31:5000       0.0.0.0:*               LISTEN      1001       11682      1364/io.h        m-rpc.2
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          5905       949/exim4
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       6957       679/iobro        ker.js-con
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       6962       679/iobro        ker.js-con
      tcp        0      0 192.168.1.31:4000       0.0.0.0:*               LISTEN      1001       9638       1347/io.h        m-rpc.1
      tcp        0      0 192.168.1.31:3000       0.0.0.0:*               LISTEN      1001       11657      1332/io.h        m-rpc.0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       11839      1521/io.s        onoff.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       11740      1416/io.m        qtt.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11739      1416/io.m        qtt.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7488       784/sshd:        /usr/sbin
      tcp6       0      0 :::8555                 :::*                    LISTEN      1000       9156       1785/go2r        tc_linux_a
      tcp6       0      0 :::8554                 :::*                    LISTEN      1000       9153       1785/go2r        tc_linux_a
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          5906       949/exim4
      tcp6       0      0 :::1984                 :::*                    LISTEN      1000       11954      1785/go2r        tc_linux_a
      tcp6       0      0 :::22                   :::*                    LISTEN      0          7490       784/sshd:        /usr/sbin
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       15126      2919/io.s        imple-api.
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       16540      2930/io.s        ocketio.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14524      1848/io.w        eb.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5101       965/io.ad        min.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          5867       638/dhcli        ent
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17773      3255/io.m        atter.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17768      3255/io.m        atter.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       15306      3223/io.w        led.0
      udp        0      0 192.168.1.31:5353       0.0.0.0:*                           1001       9042       1543/io.t        r-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11611      1272/io.c        hromecast.
      udp        0 213120 0.0.0.0:38899           0.0.0.0:*                           1001       15070      2900/io.s        ignifyligh
      udp        0      0 0.0.0.0:38900           0.0.0.0:*                           1001       15071      2900/io.s        ignifyligh
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       14547      1797/io.t        uya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       14548      1797/io.t        uya.0
      udp        0      0 192.168.1.31:8555       0.0.0.0:*                           1000       9160       1785/go2r        tc_linux_a
      udp        0      0 0.0.0.0:57856           0.0.0.0:*                           1001       17779      3255/io.m        atter.0
      udp6       0      0 :::5353                 :::*                                1001       17774      3255/io.m        atter.0
      udp6       0      0 :::5353                 :::*                                1001       17769      3255/io.m        atter.0
      udp6       0      0 2003:c5:8f45:2500::8555 :::*                                1000       9162       1785/go2r        tc_linux_a
      udp6       0      0 fd8f:79ab:5076:0:b:8555 :::*                                1000       9161       1785/go2r        tc_linux_a
      udp6       0      0 :::57856                :::*                                1001       17778      3255/io.m        atter.0
      2025-08-16 14:00:52.800  - info: yr.0 (13131) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-08-16 14:00:53.318  - info: host.NUC instance system.adapter.yr.0 having pid 13131 terminated with code 11        (ADAPTER_REQUESTED_TERMINATION)
      2025-08-16 14:00:56.543  - info: openweathermap.0 (13149) Terminated (NO_ERROR): Without reason
      2025-08-16 14:00:57.060  - info: host.NUC instance system.adapter.openweathermap.0 having pid 13149 terminated        with code 0 (NO_ERROR)
      2025-08-16 14:01:48.011  - info: host.NUC instance system.adapter.dwd.0 in version "2.8.5" started with pid 133        10
      2025-08-16 14:01:49.369  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.adapter.d        wd.0.plugins.sentry","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"        }}
      2025-08-16 14:01:49.484  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":tr        ue,"write":true,"role":"value"},"native":{},"_id":"system.adapter.dwd.0.plugins.sentry.enabled","acl":{"object"        :1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2025-08-16 14:01:49.830  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.alive:{"_id":"system.adapter.dwd.0.alive","type":"state","common":{"name":"dwd.0 alive","type":"boole        an","role":"indicator.state","custom":{"lovelace.0":{"enabled":true,"entity":"","name":""}},"read":true,"write"        :true},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.adm        inistrator"},"enums":{},"from":"system.adapter.dwd.0","user":"system.user.admin","ts":1755345709828}
      2025-08-16 14:01:49.965  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.connected:{"_id":"system.adapter.dwd.0.connected","type":"state","common":{"name":"dwd.0 is connected        ","type":"boolean","role":"indicator.state","custom":{"lovelace.0":{"enabled":true,"entity":"","name":""}},"rea        d":true,"write":false},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"        system.group.administrator"},"enums":{},"from":"system.adapter.dwd.0","user":"system.user.admin","ts":175534570        9963}
      2025-08-16 14:01:50.056  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.compactMode:{"_id":"system.adapter.dwd.0.compactMode","type":"state","common":{"name":"dwd.0.compactM        ode","type":"boolean","read":true,"write":false,"role":"indicator.state"},"native":{},"acl":{"object":1636,"sta        te":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.dwd.0","        user":"system.user.admin","ts":1755345709970}
      2025-08-16 14:01:50.319  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.cpu:{"_id":"system.adapter.dwd.0.cpu","type":"state","common":{"name":"dwd.0.cpu","type":"number","re        ad":true,"write":false,"role":"indicator.state","unit":"% of one core"},"native":{},"acl":{"object":1636,"state        ":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.dwd.0","us        er":"system.user.admin","ts":1755345710296}
      2025-08-16 14:01:50.473  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.cputime:{"_id":"system.adapter.dwd.0.cputime","type":"state","common":{"name":"dwd.0.cputime","type":        "number","read":true,"write":false,"role":"indicator.state","unit":"seconds"},"native":{},"acl":{"object":1636,        "state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.dwd.        0","user":"system.user.admin","ts":1755345710450}
      2025-08-16 14:01:50.613  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.memHeapUsed:{"_id":"system.adapter.dwd.0.memHeapUsed","type":"state","common":{"name":"dwd.0 heap act        ually Used","type":"number","role":"indicator.state","unit":"MB","custom":{"lovelace.0":{"enabled":true,"entity        ":"","name":""}},"read":true,"write":false},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.        admin","ownerGroup":"system.group.administrator"},"enums":{},"from":"system.adapter.dwd.0","user":"system.user.        admin","ts":1755345710610}
      2025-08-16 14:01:50.746  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.memHeapTotal:{"_id":"system.adapter.dwd.0.memHeapTotal","type":"state","common":{"name":"dwd.0 total        Size of the Heap","type":"number","role":"indicator.state","unit":"MB","custom":{"lovelace.0":{"enabled":true,"        entity":"","name":""}},"read":true,"write":false},"native":{},"acl":{"object":1636,"state":1636,"owner":"system        .user.admin","ownerGroup":"system.group.administrator"},"enums":{},"from":"system.adapter.dwd.0","user":"system        .user.admin","ts":1755345710744}
      2025-08-16 14:01:50.874  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.memRss:{"_id":"system.adapter.dwd.0.memRss","type":"state","common":{"name":"dwd.0 resident Set Size"        ,"desc":"Resident set size","type":"number","role":"indicator.state","unit":"MB","custom":{"lovelace.0":{"enabl        ed":true,"entity":"","name":""}},"read":true,"write":false},"native":{},"acl":{"object":1636,"state":1636,"owne        r":"system.user.admin","ownerGroup":"system.group.administrator"},"enums":{},"from":"system.adapter.dwd.0","use        r":"system.user.admin","ts":1755345710867}
      2025-08-16 14:01:51.060  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.uptime:{"_id":"system.adapter.dwd.0.uptime","type":"state","common":{"name":"dwd.0 uptime","type":"nu        mber","role":"indicator.state","unit":"seconds","custom":{"lovelace.0":{"enabled":true,"entity":"","name":""}},        "read":true,"write":false},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGrou        p":"system.group.administrator"},"enums":{},"from":"system.adapter.dwd.0","user":"system.user.admin","ts":17553        45711008}
      2025-08-16 14:01:51.199  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.inputCount:{"_id":"system.adapter.dwd.0.inputCount","type":"state","common":{"name":"dwd.0 events inp        ut counter","desc":"State's inputs in 15 seconds","type":"number","read":true,"write":false,"role":"state","uni        t":"events/15 seconds"},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":        "system.group.administrator"},"from":"system.adapter.dwd.0","user":"system.user.admin","ts":1755345711140}
      2025-08-16 14:01:51.356  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.outputCount:{"_id":"system.adapter.dwd.0.outputCount","type":"state","common":{"name":"dwd.0 events o        utput counter","desc":"State's outputs in 15 seconds","type":"number","read":true,"write":false,"role":"state",        "unit":"events/15 seconds"},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGro        up":"system.group.administrator"},"from":"system.adapter.dwd.0","user":"system.user.admin","ts":1755345711293}
      2025-08-16 14:01:51.435  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.eventLoopLag:{"_id":"system.adapter.dwd.0.eventLoopLag","type":"state","common":{"name":"dwd.0 Node.j        s event loop lag","desc":"Node.js event loop lag in ms averaged over 15 seconds","type":"number","read":true,"w        rite":false,"role":"state","unit":"ms"},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admi        n","ownerGroup":"system.group.administrator"},"from":"system.adapter.dwd.0","user":"system.user.admin","ts":175        5345711427}
      2025-08-16 14:01:51.599  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.sigKill:{"_id":"system.adapter.dwd.0.sigKill","type":"state","common":{"name":"dwd.0 kill signal","ty        pe":"number","read":true,"write":false,"desc":"Process id that must survive. All other IDs must terminate itsel        f","role":"state"},"native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"syst        em.group.administrator"},"from":"system.adapter.dwd.0","user":"system.user.admin","ts":1755345711575}
      2025-08-16 14:01:51.767  - silly: vis-2.0 (3092) Objects user redis pmessage system.adapter.*/cfg.o.system.adap        ter.dwd.0.logLevel:{"_id":"system.adapter.dwd.0.logLevel","type":"state","common":{"name":"dwd.0 loglevel","typ        e":"string","read":true,"write":true,"desc":"Loglevel of the adapter. Will be set on start with defined value b        ut can be overridden during runtime","role":"state"},"native":{},"acl":{"object":1636,"state":1636,"owner":"sys        tem.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.dwd.0","user":"system.user.ad        min","ts":1755345711743}
      2025-08-16 14:01:52.050  - info: dwd.0 (13310) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.d        wd, node: v22.18.0, js-controller: 7.0.7
      2025-08-16 14:01:53.179  - info: dwd.0 (13310) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-08-16 14:01:53.739  - info: host.NUC instance system.adapter.dwd.0 having pid 13310 terminated with code 1        1 (ADAPTER_REQUESTED_TERMINATION)
      2025-08-16 14:02:17.123  - error: weather-warnings.0 (3185) [json] No template for key: NewJson!
      iob diag has finished.
      • R Ritter
        @thomas-braun Ja
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
                 Chassis: desktop 🖥️
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 4
                      NTP service: active
                  RTC in local TZ: no
        christian
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:           1.0G          0B        1.0G
        Total:           34G        5.8G         27G
                 5495 M used memory
                25572 M free memory
                  154 M buffer memory
                 1175 M swap cache
                  974 M total swap
                    0 M used swap
                  974 M free swap
        *** FILESYSTEM ***
        /var:
        2.2G    /var/
        1.5G    /var/log
        566M    /var/cache
        USB-Devices by-id:
        HINT:
        tcp
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.3
        /usr/bin/npx            10.9.3
        nodejs:
          Version table:
             20.19.2+dfsg-1 500
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.7.2
        javascript:     9.0.11
        Adapter State
        + instance is alive
        Objects and States
        Objects:        51207
        States:         39525
        Pending Updates: 0
        #72
        @ritter
        Setz den user die Gruppe adm rein.
        Uns stell das LogLevel für vis-2.0.0 auf info oder sowas, aber nicht auf silly.
        Lösch das log mal:
        sudo -u iobroker rm /home/iobroker/iob_diag.log
          @ritter
          Lösch das log mal:
          Ritter
          #73
          @thomas-braun LogLevel umgestellt, log gelöscht,
          mit "Setz den user die Gruppe adm rein." weis nicht genau was ich tun soll.
          christian@NUC:~$ sudo -u iobroker rm /home/iobroker/iob_diag.log
          [sudo] Passwort für christian:
          christian@NUC:~$ iob diag
          /usr/bin/iob: Zeile 21: /home/iobroker/iob_diag.log: Keine Berechtigung
          christian@NUC:~$
          • R Ritter
            christian@NUC:~$
            #74
            @ritter
            sudo usermod -a -G adm christian
            Dann die Kiste einmal sauber neustarten.
            Die Meldung
            macht eigentlich keinen Sinn. Die Zeile 21 schaut so aus:
            sudo -u iobroker curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh && bash /home/iobroker/.diag.sh "$2" | sudo -u iobroker tee /home/iobroker/iob_diag.log
            Das muss eigentlich mit den Rechten funktionieren.
              @ritter
              Die Meldung
              Ritter
              #75
              @thomas-braun Bei dem zweiten Befehl kommt jede Menge Text ungefär wie vorhin. Wenn ich jetzt iob diag eingebe bleibt es so stehen seit einigen Minuten.
              • R Ritter
                #76
                @ritter
                Da muss du das Passwort des christian eingeben.
                Das erfolgt blind, keine Rückmeldung in der Konsole.
                  @ritter
                  Ritter
                  #77
                  @thomas-braun Das habe ich schon, danach bleibt der grüne curser Punkt darunter stehen
                  • R Ritter
                    #78
                    @ritter
                    Da stimmt doch irgendwas mit deiner sudo-Konfiguration nicht...
                    sudo whoami
                    sudo -H -u iobroker whoami
                    liefert?
                      @ritter
                      sudo whoami
                      liefert?
                      Ritter
                      #79
                      @thomas-braun sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                      sudo whoami
                      christian@NUC:~$ sudo whoami
                      root
                      iobroker
                      christian@NUC:~$
                      • R Ritter
                        sudo whoami
                        root
                        iobroker
                        christian@NUC:~$
                        #80
                        @ritter
                        Un jetzt?
                        iob diag
                          @ritter
                          Un jetzt?
                          iob diag
                          Ritter
                          #81
                          @thomas-braun ```
                          Script v.2025-08-09
                          *** BASE SYSTEM ***
                                   Chassis: desktop 🖥️
                          OS is similar to:
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                           17:33:31 up  2:16,  2 users,  load average: 1.39, 1.65, 1.36
                          CPU threads: 4
                                         Local time: Sat 2025-08-16 17:33:31 CEST
                                     Universal time: Sat 2025-08-16 15:33:31 UTC
                                           RTC time: Sat 2025-08-16 15:33:31
                                        NTP service: active
                                    RTC in local TZ: no
                          christian
                          GROUPS=christian adm cdrom floppy sudo audio dip video plugdev users netdev iobroker
                          js-controller is not running
                          Display-Manager:
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Mem:             33G        837M         31G        4.3M        2.1G         32G
                          Swap:           1.0G          0B        1.0G
                          Total:           34G        837M         32G
                          Active iob-Instances:   1
                                    798 M used memory
                                    290 M active memory
                                   1208 M inactive memory
                                  29686 M free memory
                                    329 M buffer memory
                                   1641 M swap cache
                                    974 M total swap
                                      0 M used swap
                                    974 M free swap
                          top - 17:33:31 up  2:16,  2 users,  load average: 1.28, 1.62, 1.35
                          Tasks: 184 total,   1 running, 183 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  1.9 us,  3.8 sy,  0.0 ni, 94.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :  31993.3 total,  29686.8 free,    798.2 used,   1970.8 buff/cache
                          MiB Swap:    975.0 total,    975.0 free,      0.0 used.  31195.1 avail Mem
                            UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                          * iobroker.service loaded failed failed ioBroker Server
                          Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                                  ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                                  SUB    -> The low-level unit activation state, values depend on unit type.
                          1 loaded units listed.
                          *** FILESYSTEM ***
                          /dev/sda1      ext4      468G   62G  382G  14% /
                          tmpfs          tmpfs      16G  3.1M   16G   1% /tmp
                          [Sat Aug 16 15:17:16 2025] EXT4-fs (sda1): mounted filesystem 96448ee6-f182-4f61-a44e-5eb0f63f92f9 ro with ordered data mode. Quota mode: none.
                          [Sat Aug 16 15:17:17 2025] EXT4-fs (sda1): re-mounted 96448ee6-f182-4f61-a44e-5eb0f63f92f9 r/w.
                          /var:
                          2.2G    /var/
                          1.5G    /var/log
                          566M    /var/cache
                          Archived and active journals take up 1.4G in the file system.
                          1.5G    /opt/iobroker/iobroker-data/
                          40M     /opt/iobroker/iobroker-data/objects.jsonl
                          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                          USB-Devices by-id:
                          HINT:
                          tcp
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.9.3
                          /usr/bin/npx            10.9.3
                          nodejs:
                            Version table:
                               20.19.2+dfsg-1 500
                          ioBroker Status
                          iobroker is not running on this host.
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          NUC                 NUC (version: 7.0.7, hostname: NUC           , alive, uptime: 8018)
                          admin:          7.7.2
                          javascript:     9.0.11
                          +-- iobroker.klipper-moonraker@0.1.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.klipper-moonraker.git#0d2851e98f7443e85ebe29d98d8d725640dd0a8a)
                          +-- iobroker.pirate-weather@0.1.4 (git+ssh://git@github.com/ticaki/ioBroker.pirate-weather.git#f70e2e8f1968bfe65afabf792ca73253a19f8321)
                          | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                          +-- iobroker.signifylights@1.0.0 (git+ssh://git@github.com/disaster123/ioBroker.signifylights.git#bb475662d63f1e39993c2b4e9fb395c29dcd1adc)
                          +-- iobroker.tuya@3.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.tuya.git#640df7360a877f37764a31d628e4d6de3ed1f6e3)
                          +-- iobroker.xsense@0.0.12 (git+ssh://git@github.com/arteck/ioBroker.xsense.git#cae2e07ac3d59527f701426739ed0cf14afdd0de)
                          +-- iobroker.yr@5.3.0 (git+ssh://git@github.com/ioBroker/ioBroker.yr.git#dec7b7f69b3968a43a390e2b2a60391c2dca6b23)
                          Adapter State
                          + instance is alive
                          │ 0       │ 'online'      │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │ false        │
                          Objects and States
                          Objects:        51148
                          States:         38799
                          W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                          Hit:1 http://security.debian.org/debian-security trixie-security InRelease
                          Hit:2 http://deb.debian.org/debian trixie InRelease
                          Pending Updates: 0
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          854        935/exim4
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5832       766/sshd: /usr/sbin
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          855        935/exim4
                          tcp6       0      0 :::8555                 :::*                    LISTEN      1000       9071       1751/go2rtc_linux_a
                          tcp6       0      0 :::8554                 :::*                    LISTEN      1000       9067       1751/go2rtc_linux_a
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          5834       766/sshd: /usr/sbin
                          tcp6       0      0 :::1984                 :::*                    LISTEN      1000       10692      1751/go2rtc_linux_a
                          udp        0      0 192.168.1.31:8555       0.0.0.0:*                           1000       9075       1751/go2rtc_linux_a
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          816        626/dhclient
                          udp6       0      0 2003:c5:8f45:2500::8555 :::*                                1000       9077       1751/go2rtc_linux_a
                          udp6       0      0 fd8f:79ab:5076:0:b:8555 :::*                                1000       9076       1751/go2rtc_linux_a
                          2025-08-16 17:31:16.378  - warn: host.NUC instance system.adapter.statistics.0 terminated due to SIGKILL
                          2025-08-16 17:31:16.378  - info: host.NUC instance system.adapter.statistics.0 terminated with code null ()
                          2025-08-16 17:31:16.470  - warn: host.NUC instance system.adapter.tankerkoenig.0 terminated due to SIGKILL
                          2025-08-16 17:31:16.470  - info: host.NUC instance system.adapter.tankerkoenig.0 terminated with code null ()
                          2025-08-16 17:31:16.471  - warn: host.NUC instance system.adapter.text2command.1 terminated due to SIGKILL
                          2025-08-16 17:31:16.471  - info: host.NUC instance system.adapter.text2command.1 terminated with code null ()
                          2025-08-16 17:31:16.491  - warn: host.NUC instance system.adapter.time-switch.0 terminated due to SIGKILL
                          2025-08-16 17:31:16.491  - info: host.NUC instance system.adapter.time-switch.0 terminated with code null ()
                          2025-08-16 17:31:16.511  - warn: host.NUC instance system.adapter.vis-2.0 terminated due to SIGKILL
                          2025-08-16 17:31:16.511  - info: host.NUC instance system.adapter.vis-2.0 terminated with code null ()
                          2025-08-16 17:31:16.548  - warn: host.NUC instance system.adapter.windows-control.0 terminated due to SIGKILL
                          2025-08-16 17:31:16.548  - info: host.NUC instance system.adapter.windows-control.0 terminated with code null ()
                          2025-08-16 17:31:16.588  - warn: host.NUC instance system.adapter.energiefluss-erweitert.0 terminated due to SIGKILL
                          2025-08-16 17:31:16.588  - info: host.NUC instance system.adapter.energiefluss-erweitert.0 terminated with code null ()
                          2025-08-16 17:31:16.588  - warn: host.NUC instance system.adapter.vesync.0 terminated due to SIGKILL
                          2025-08-16 17:31:16.603  - info: host.NUC instance system.adapter.vesync.0 terminated with code null ()
                          2025-08-16 17:31:17.187  - info: host.NUC instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
                          2025-08-16 17:31:17.208  - info: host.NUC instance system.adapter.vis-inventwo.0 terminated while should be started once
                          2025-08-16 17:31:17.237  - warn: host.NUC instance system.adapter.tuya.0 terminated due to SIGKILL
                          2025-08-16 17:31:17.238  - info: host.NUC instance system.adapter.tuya.0 terminated with code null ()
                          2025-08-16 17:31:17.258  - info: host.NUC instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                          2025-08-16 17:31:17.307  - info: host.NUC instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2025-08-16 17:31:17.307  - info: host.NUC instance system.adapter.matter.0 terminated with code 0 (NO_ERROR)
                          2025-08-16 17:31:17.307  - info: host.NUC All instances are stopped.
                          2025-08-16 17:31:17.375  - info: host.NUC terminated
                          christian@NUC:~$
                          • R Ritter
                            @thomas-braun ```
                            Script v.2025-08-09
                            *** BASE SYSTEM ***
                                     Chassis: desktop 🖥️
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            CPU threads: 4
                                          NTP service: active
                                      RTC in local TZ: no
                            christian
                            Display-Manager:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Swap:           1.0G          0B        1.0G
                            Total:           34G        837M         32G
                                      798 M used memory
                                      290 M active memory
                                    29686 M free memory
                                      329 M buffer memory
                                     1641 M swap cache
                                      974 M total swap
                                        0 M used swap
                                      974 M free swap
                            *** FILESYSTEM ***
                            /var:
                            2.2G    /var/
                            1.5G    /var/log
                            566M    /var/cache
                            USB-Devices by-id:
                            HINT:
                            tcp
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.9.3
                            /usr/bin/npx            10.9.3
                            nodejs:
                              Version table:
                                 20.19.2+dfsg-1 500
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.7.2
                            javascript:     9.0.11
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        51148
                            States:         38799
                            Pending Updates: 0
                            christian@NUC:~$
                            #82
                            @ritter
                            Funktioniert also wieder.
                              @ritter
                              Ritter
                              #83
                              @thomas-braun Ja, es funktioniert jetzt. Vielen herzlichen Dank für deine Hilfe und Geduld und die super Anleitung für das upgrade.
                              • CodierknechtC Offline
                                Codierknecht
                                #84
                                Prinzipiell hat das Upgrade dank @Thomas-Braun's detaillierter Anleitung problemlos funktioniert.
                                Zuerst vor dem offiziellen Release auf der Testkiste und dann - nachdem das einwandfrei geklappt hat - gestern auf dem Produktivsystem.
                                Allerdings lief heute Morgen das MySQL-Backup nicht mehr durch:
                                2025-08-16 02:40:25.969 - error: backitup.0 (483) [iobroker/mysql] Error: Command failed: mysqldump -u ioBroker -p**** ioBroker -h 192.168.178.51 -P 3306 > /opt/iobroker/backups/mysql_2025_08_16-02_40_25_backupiobroker.sql
                                2025-08-16 02:40:25.970 - error: backitup.0 (483) [iobroker/mysql] mysqldump: Got error: 2026: "TLS/SSL error: SSL is required, but the server does not support it" when trying to connect
                                2025-08-16 02:40:25.970 - error: backitup.0 (483) [iobroker] Error: Command failed: mysqldump -u ioBroker -p**** ioBroker -h 192.168.178.51 -P 3306 > /opt/iobroker/backups/mysql_2025_08_16-02_40_25_backupiobroker.sql
                                Der DB-Server läuft - genau wie der ioBroker - als LXC unter Proxmox. Das wurde gleichzeitig mit dem Upgrade des ioBroker auf PVE 9.0.5 gehoben.
                                An den LXC's selbst wurde nix weiter geändert.
                                Die Historisierung über den SQL-Adapter funktioniert ja auch weiterhin problemlos.
                                @simatec Was muss ich jetzt hier unternehmen? SSL brauche ich innerhalb meines lokalen Netzes nicht. Kann man dem Backup beibringen, die Option --skip-ssl zu verwenden?
                                HmIP|ZigBee|Tasmota|Unifi
                                Zabbix Certified Specialist
                                • CodierknechtC Codierknecht
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  #85
                                  @codierknecht
                                  Die Frage ist, warum MySQL bei dir überhaupt SSL verlangt.
                                  Normalerweise muss man das für den Server oder für den User Extra konfigurieren.
                                  Schau mal in der Konfiguration einmal hier.
                                  [mysqld]
                                  require_secure_transport = ON
                                  Oder in der Datenbank selbst
                                  SELECT user, host, ssl_type
                                  FROM mysql.user;
                                  Meine Adapter und Widgets
                                  Links im Profil
                                    @eduard77 sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                                    Ich habe jetzt festgestellt dass Ping Adapter bei mir nicht mehr funktioniert.
                                    Versuch mal ping neu zu installieren:
                                    sudo apt-get install iputils-ping --reinstall
                                    Eduard77E Online
                                    Eduard77E Online
                                    Eduard77
                                    #86
                                    @dr-bakterius sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                                    Tut mir leid, dass ich erst jetzt antworte.
                                    Ich habe jetzt versucht nochmals mit deinem Code zu machen.
                                    Hat wieder nichts gebracht.
                                    edi77@DebianIO:~$ sudo apt-get install iputils-ping --reinstall
                                    [sudo] password for edi77:
                                    The following packages were automatically installed and are no longer required:
                                      g++-12 libassuan0 libavcodec59 libavdevice59 libavfilter8 libavformat59 libavutil57 libc-ares2 libcares2 libcodec2-1.0 libdav1d6 libdrm-nouveau2
                                      libdrm-radeon1 libepoxy0 libflac12 libgirepository-1.0-1 libglapi-mesa libjsoncpp25 libjxl0.7 libllvm15 libmbedcrypto7 libmfx1 libnl-3-200
                                      libnl-genl-3-200 libnsl-dev libplacebo208 libpostproc56 libpthread-stubs0-dev librav1e0 librhash0 libssh-gcrypt-4 libstdc++-12-dev libsvtav1enc1
                                      libswresample4 libswscale6 libtheora0 libtirpc-dev libvpx7 libx265-199 libxcb-dri2-0 node-busboy node-cjs-module-lexer node-undici node-xtend
                                      x11proto-core-dev
                                    Use 'sudo apt autoremove' to remove them.
                                    0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
                                    Need to get 51.2 kB of archives.
                                    After this operation, 0 B of additional disk space will be used.
                                    Get:1 http://deb.debian.org/debian trixie/main amd64 iputils-ping amd64 3:20240905-3 [51.2 kB]
                                    Fetched 51.2 kB in 0s (612 kB/s)
                                    (Reading database ... 48784 files and directories currently installed.)
                                    Preparing to unpack .../iputils-ping_3%3a20240905-3_amd64.deb ...
                                    Unpacking iputils-ping (3:20240905-3) over (3:20240905-3) ...
                                    Setting up iputils-ping (3:20240905-3) ...
                                    Processing triggers for man-db (2.13.1-1) ...
                                    edi77@DebianIO:~$
                                    • OliverIOO OliverIO
                                      @codierknecht
                                      [mysqld]
                                      FROM mysql.user;
                                      Codierknecht
                                      #87
                                      @oliverio sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                                      Falsche Richtung. Nicht der "Server" verlangt SSL, sondern das Backup und mysqldump.
                                      Der Server bietet gar kein SSL an - daran stört sich mysqldump und damit das Backup. Aber erst seit dem Update.
                                      Edit
                                      Die mysqldump.cnf sieht wie folgt aus:
                                      [mysqldump]
                                      quick
                                      quote-names
                                      max_allowed_packet      = 16M
                                        Edit
                                        [mysqldump]
                                        quick
                                        quote-names
                                        Codierknecht
                                        #88
                                        @codierknecht sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                                        Ich hab's hinbekommen :-D
                                        Die config muss (auf der ioBroker-Seite) so aussehen:
                                        [mysqldump]
                                        quick
                                        quote-names
                                        ssl = 0
                                        Siggi0904S 1 Antwort Letzte Antwort
                                        • C Offline
                                          cbrocker
                                          #89
                                          Ähnliches macht man mit veralteten und lokal erzeugten Pakten nach Möglichkeit.
                                          apt list '~o'
                                          sudo apt purge '~o'
                                          sudo apt --purge autoremove
                                          sudo apt autoclean
                                          Hallo, das Upgrade auf Trixie lief astrein durch.
                                          Wenn ich das apt list '~o' eingebe, kommt bei mir u.a.:
                                          grafana-enterprise/now 12.1.1 amd64  [Installiert,lokal]
                                          Das möchte ich natürlich behalten.
                                          Kann ich das aus --purge autoremove ausschließen oder
                                          die o.g. Befehle einfach überspringen?
                                          Ist ja nichts, was man unbedingt machen müsste?
                                          Christoph
                                          Proxmox Cluster mit ioBroker, Wireguard, HomeAssistant (Testsystem), paperlessNGX, MariaDB, PiHole, Grafana, InfluxDB, 1 x BKW 600 Wp, 2 x BKW 400 Wp, 2 x SolarFlow 800 Pro mit 11,52 kWh Akku und 3,48 kWp, OpenDTU, AhoyDTU, HmIP, Shellys, AVM LAN/WLAN
