  4. Wir empfehlen: Node.js 22.x
    6.8k
370 Beiträge 53 Kommentatoren 92.7k Aufrufe 53 Beobachtet
  • S Supernils
    Hallo, ist es normal, dass ein Minor Update von Node.js nicht funktioniert?
    Auch über apt passiert nichts.
    pi@raspberrypi4-iobroker:~ $ sudo apt update
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists... Done
    All packages are up to date.
    W: http://archive.raspberrypi.org/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    pi@raspberrypi4-iobroker:~ $ sudo apt upgrade
    Calculating upgrade... Done
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    #106
    @Supernils
    32Bit-Version?
    apt policy nodejs
    sagt?
      @Supernils
      32Bit-Version?
      apt policy nodejs
      sagt?
      Supernils
      #107
      pi@raspberrypi4-iobroker:~ $ apt policy nodejs
      nodejs:
        Installed: 22.15.0-1nodesource1
        Candidate: 22.15.0-1nodesource1
        Version table:
       *** 22.15.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main armhf Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main ar        mhf Packages
      • S Supernils
        nodejs:
          Version table:
        #108
        @supernils
        Ja, 32Bit.
        Steig da AB und installier da von GRUND AUF NEU ein 64Bit-System.
          @supernils
          Ja, 32Bit.
          Supernils
          #109
          @thomas-braun @thomas-braun Die 64bit Vorraussetzung für ein Node.js Update war mir nicht bewusst. Eine 64bit Neuinstallation ist derzeit aus Zeitgründen nicht möglich. Gibt es eine Alternative?
          • S Supernils
            #110
            @supernils sagte in Wir empfehlen: Node.js 22.x:
            Nein.
            Es ist ja auch keine Voraussetzung. Die 22.15.0-1nodesource1 gibt es ja. Es werden nur im Moment für 32Bit keine aktuelleren Versionen von nodesource gebaut. Warum weiß ich nicht, aber die 64Bit-Versionen kommen relativ zeitnah rein.
            Gibt aber auch noch weitere Gründe dafür, im Jahre 2025 nicht mehr auf 32Bit herumzurutschen.
              babl
              #111
              Node JS Update auf 22.18.0 und NPM 10.9.3 erfolgreich, bisher keine Auffälligkeiten zu beobachten. Danke euch
                Ich habe es mal auf meinem Testsystem installiert.
                thomas@ioTest:~$ nodejs -v
                v22.18.0
                thomas@ioTest:~$ npm -v
                10.9.3
                Es ist ein Proxmox LXC. Mit iob nodejs-update funktionierte es nicht.
                Auch
                iob stop
                iob fix
                iob nodejs-update
                brachte keinen Erfolg.
                Dann allerdings konnte ich mit iob nodejs-update 22 upgraden.
                ostseereiterO Offline
                ostseereiter
                #112
                @meister-mopper sagte in Wir empfehlen: Node.js 22.x:
                Bei mir unter Proxmox hat auch der Befehl iob nodejs-update 22 nichts gebracht es kommt stattdessen diese Meldung.
                For security reasons ioBroker should not be run or administrated as root.***
                By default only a user that is member of iobroker group can execute ioBroker commands.
                Please read the Documentation on how to set up such a user, if not done yet.
                Only in very special cases you can run iobroker commands by adding the --allow-root option at the end of the command line.
                Please note that this option may be disabled in the future, so please change your setup accordingly now.
                aber man kann sich ja nicht mit einen anderen Benutzer anmelden. Wenn ich versuche mich über Putty einzuloggen komme ich weder per Root noch per Benutzer rein.
                Meldung:
                Access denied
                Gruß OSR
                Plattform
                • ostseereiterO ostseereiter
                  Meldung:
                  Access denied
                  #113
                  @ostseereiter sagte in Wir empfehlen: Node.js 22.x:
                  warum nicht?
                  hast du keinen user angelegt?
                  oder meinst du mit
                  dass du in der PVE unterwegs bist?
                  ostseereiterO 1 Antwort Letzte Antwort
                    warum nicht?
                    oder meinst du mit
                    ostseereiter
                    #114
                    wenn ich es unter Proxmox versuche dann kommt ja die Meldung mit root.
                    wenn ich dann versuche extern also mit Putty bekomme ich überhaupt kein Zugang zum IoB. Einen Benutzer habe ich direkt angelegt im Iobroker.Screenshot (50).png
                    Man kann sich ja auch in Proxmox direkt nur mit root anmelden weil es ja automatisch geht,da hat man keine Chance sich auszuloggen.
                    Gruß OSR
                    Plattform
                      #115
                      bitte die Fragen beantworten!
                      @homoran sagte in Wir empfehlen: Node.js 22.x:
                      oder meinst du mit
                      der Screenshot hilft mir keinen Deut weiter!
                      wo bist du unterwegs?
                      "unter Proxmox" sagt gar nichts aus
                        #116
                        @ostseereiter
                        https://www.iobroker.net/#de/documentation/install/proxmox.md
                        Punkt 3 - LXC einrichten
                        Da wird ein User angelegt und mit diesem user kann man dann auch ohne root im Container die entsprechenden iob-Befehle verwenden.
                          @ostseereiter
                          ostseereiter
                          #117
                          Ich habe Iobroker per Script instaliert ging alles von selbst. musste nichts weiter installieren. also deshalb auch kein User angelegt. Der LNX Container war nach der Installation fertig.Die ganzen Update mache ich in der Proxmox Umgebung dann auch den Container in der Konsole. Updaten usw. funktioniert auch aber eben nicht node-js weil er einen User möchte.
                          Gruß OSR
                          Plattform
                          • Thomas BraunT Online
                            #118
                            NEIN, der Container ist eben NICHT fertig, solange du die Anleitung nicht vollständig befolgst und user anlegst.
                            Der Container ist nur eine Rohmasse, die muss noch weiter geknetet werden.
                              ostseereiter
                              #119
                              Ich verstehe schon worauf die hinaus willst bloß die ganzen Schritte wie dort beschrieben wurden brauchte ich ja nicht machen als das Script durchgelaufen war war Iobroker fertig installiert. ohne irgendwelche Eingaben und zusätzlichen Befehle.
                              Gruß OSR
                              Plattform
                                #120
                                @ostseereiter
                                Was willst du mir denn jetzt sagen?
                                Du hast es nicht vollständig eingerichtet und wunderst dich jetzt, warum das Ganze dann halt nicht funktioniert?
                                Der ioBroker ist (wie im Grunde auch alle anderen Dienste) darauf ausgelegt, das es user mit entsprechenden Rechten gibt. Der Schreiber der Anleitung wird sich schon was dabei gedacht haben, diesen Part niederzuschreiben.
                                Die Anlage eines users ist nicht optional, sondern unerlässlich für den richtigen Betrieb des ioBrokers.
                                  @ostseereiter
                                  ostseereiter
                                  #121
                                  @thomas-braun habe jetzt ein User angelegt und komme mit diesen per Putty rauf. dann wollen wir mal sehen ob das update funktioniert und wie immer wieder was dazu gelernt.
                                  Gruß OSR
                                  Plattform
                                  • ostseereiterO Offline
                                    ostseereiter
                                    #122
                                    Alles gut gelaufen neuste Version ist installiert.
                                    Gruß OSR
                                    Plattform
                                    • mcm1957M mcm1957
                                      @pitpilot
                                      Hast du eh den ADAPTER deinstaöliert undneu installiert und nicht nur die Instanz(en) gelöscht und neu angelegt?
                                      Pitpilot
                                      #123
                                      @mcm1957 Ok ich habe den Siemens Adapter in der GUI gelöscht und die 4 Instanzen neu angelegt und konfiguriert. Wie geht ein Adapter reinstall richtig?
                                        @pitpilot sagte in Wir empfehlen: Node.js 22.x:
                                        warn adapter "s7" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                        Auch hier muss ein rebuild erfolgen. Da das aber augenscheinlich über den internen Vorgang nicht funktioniert, deinstallier den Adapter mal komplett und installier den dann nochmal frisch von Neu.
                                        Pitpilot
                                        schrieb am zuletzt editiert von Pitpilot
                                        #124
                                        @thomas-braun Wie geht das manuelle Deinstallieren und Reinstallieren eines Adapters?
                                        Einfach drüber installieren mit install?
                                        iobroker add adapterName
                                        iobroker install adapterName
                                        iobroker upload adapterName
                                        iobroker setup
                                        iobroker setup custom
                                        iobroker del adapterName
                                        iobroker del adapterName.instance
                                        • P Pitpilot
                                          iobroker setup
                                          #125
                                          @pitpilot
                                          iob upgrade Adapter@Version --debug
                                          P 1 Antwort Letzte Antwort
