  4. Wir empfehlen: Node.js 22.x
    6.8k
370 Beiträge 53 Kommentatoren 92.7k Aufrufe 53 Beobachtet
  • L lessthanmore
    @thomas-braun Es war gar nicht der Adapter, sondern zigbee2mqtt selbst. Sorry.
    Sollte jetzt passen :-)
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.14.8-2-pve
        Architecture: x86-64
    OS is similar to:
    model name	: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     12:08:39 up 1 min,  1 user,  load average: 0.55, 0.61, 0.56
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-08-13 12:08:39 CEST
               Universal time: Wed 2025-08-13 10:08:39 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    michael
    HOME=/home/michael
    GROUPS=michael sudo users iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/michael
    GROUPS=iobroker tty dialout audio video plugdev redis
    *** DISPLAY-SERVER SETUP ***
    Display-Server: 	false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session: 		tty
    *** MEMORY ***
    Mem:            8.6G        1.1G        7.1G        1.6M        335M        7.5G
    Swap:           536M          0B        536M
    Total:          9.1G        1.1G        7.7G
    Active iob-Instances: 	13
             8192 M total memory
             1080 M used memory
             1230 M active memory
              101 M inactive memory
             6792 M free memory
                0 M buffer memory
              319 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    top - 12:08:39 up 1 min,  1 user,  load average: 0.55, 0.61, 0.56
    Tasks:  47 total,   1 running,  46 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8192.0 total,   6791.5 free,   1081.9 used,    319.9 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7110.1 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--1 ext4       25G  4.9G   19G  21% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    /dev/mapper/pve-root             ext4       67G  3.9G   60G   7% /dev/ttyACM0
    udev                             devtmpfs   32G     0   32G   0% /dev/tty
    tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
    tmpfs                            tmpfs      13G  152K   13G   1% /run
    tmpfs                            tmpfs      32G  1.4M   32G   1% /tmp
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     6.3G  8.0K  6.3G   1% /run/user/1001
    Show mounted filesystems:
    TARGET         SOURCE                                                 FSTYPE OPTIONS
    /              /dev/mapper/pve-vm--100--disk--1                       ext4   rw,relatime,stripe=16
    `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
    /var:
    418M	/var/
    214M	/var/lib
    130M	/var/cache
    126M	/var/cache/apt
    89M	/var/lib/apt
    Archived and active journals take up 24M in the file system.
    /opt/iobroker/backups:
    1.8M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    92M	/opt/iobroker/iobroker-data/
    56M	/opt/iobroker/iobroker-data/files
    38M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    6.8M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-0fd47d.a444afaa.chunk.js
    5.3M	/opt/iobroker/iobroker-data/objects.jsonl
    3.9M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.92169c09.chunk.js
    3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
    3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-Drg0QIRU.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2432650-if00
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v22.18.0
    /usr/bin/node 		v22.18.0
    /usr/bin/npm 		10.9.3
    /usr/bin/npx 		10.9.3
    /usr/bin/corepack 	0.33.0
    nodejs:
      Installed: 22.18.0-1nodesource1
      Candidate: 22.18.0-1nodesource1
      Version table:
     *** 22.18.0-1nodesource1 600
         22.17.1-1nodesource1 600
         22.17.0-1nodesource1 600
         22.16.0-1nodesource1 600
         22.15.1-1nodesource1 600
         22.15.0-1nodesource1 600
         22.14.0-1nodesource1 600
         22.13.1-1nodesource1 600
         22.13.0-1nodesource1 600
         22.12.0-1nodesource1 600
         22.11.0-1nodesource1 600
         22.10.0-1nodesource1 600
         22.9.0-1nodesource1 600
         22.8.0-1nodesource1 600
         22.7.0-1nodesource1 600
         22.6.0-1nodesource1 600
         22.5.1-1nodesource1 600
         22.5.0-1nodesource1 600
         22.4.1-1nodesource1 600
         22.4.0-1nodesource1 600
         22.3.0-1nodesource1 600
         22.2.0-1nodesource1 600
         22.1.0-1nodesource1 600
         22.0.0-1nodesource1 600
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    Hosts:
    iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 61)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		7.6.17
    javascript: 	8.9.2
    nodejs modules from github: 	1
    +-- iobroker.husqvarna-automower@0.6.0-beta.12 (git+ssh://git@github.com/ice987987/ioBroker.husqvarna-automower.git#e43328543d35c4555a4a3f3e595dd16417978d85)
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
    + system.adapter.husqvarna-automower.0    : husqvarna-automower   : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "lovelace"     : 4.1.15   , installed 4.1.15
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "openknx"      : 0.9.0    , installed 0.9.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
    Objects and States
    Objects: 	18944
    States: 	7107
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://security.debian.org trixie-security InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:44527         0.0.0.0:*               LISTEN      1000       2961001    535/io.yahka.0
    tcp        0      0 127.0.0.1:45247         0.0.0.0:*               LISTEN      1000       2961005    535/io.yahka.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        2954068    320/mosquitto
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2949013    1/init
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          2954254    288/master
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      105        2951043    146/redis-server 12
    tcp        0      0 127.0.0.1:40947         0.0.0.0:*               LISTEN      1000       2961009    535/io.yahka.0
    tcp6       0      0 ::1:6379                :::*                    LISTEN      105        2951044    146/redis-server 12
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          2954255    288/master
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       2951844    565/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2951332    338/io.admin.0
    tcp6       0      0 :::8091                 :::*                    LISTEN      1000       2955216    520/io.lovelace.0
    tcp6       0      0 :::35035                :::*                    LISTEN      1000       2951772    535/io.yahka.0
    tcp6       0      0 :::1883                 :::*                    LISTEN      107        2954069    320/mosquitto
    tcp6       0      0 :::33309                :::*                    LISTEN      1000       2951776    535/io.yahka.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          2949015    1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          2953518    1/init
    tcp6       0      0 :::41839                :::*                    LISTEN      1000       2951774    535/io.yahka.0
    udp        0      0 0.0.0.0:60413           0.0.0.0:*                           106        2950882    131/avahi-daemon: r
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2949014    1/init
    udp        0      0 0.0.0.0:34687           0.0.0.0:*                           1000       2955115    475/io.openknx.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        2950880    131/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          2949016    1/init
    udp6       0      0 :::5353                 :::*                                106        2950881    131/avahi-daemon: r
    udp6       0      0 :::41093                :::*                                106        2950883    131/avahi-daemon: r
    #84
    @lessthanmore
    Magst du mal den Inhalt deiner /etc/apt/preferences.d/nodejs.pref zeigen?
    Sollte eigentlich so aussehen:
    echad@chet:~ $ cat /etc/apt/preferences.d/nodejs.pref
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    echad@chet:~ $
    L 1 Antwort Letzte Antwort
      @lessthanmore
      Package: nodejs
      Pin-Priority: 1001
      echad@chet:~ $
      lessthanmore
      #85
      @thomas-braun said in Wir empfehlen: Node.js 22.x:
      Klar, gerne:
      michael@iobroker:~$ cat /etc/apt/preferences.d/nodejs.pref
      Package: nodejs
      Pin-Priority: 1001
      michael@iobroker:~$
      • L lessthanmore
        Klar, gerne:
        Package: nodejs
        Pin-Priority: 1001
        michael@iobroker:~$
        #86
        @lessthanmore
        Komisch. Da ist er PIN 1001 eigentlich.
        sudo apt update
        apt policy nodejs
        liefert bei dir?
          @lessthanmore
          sudo apt update
          apt policy nodejs
          liefert bei dir?
          lessthanmore
          #87
          michael@iobroker:~$ sudo apt update
          Hit:1 https://deb.nodesource.com/node_22.x nodistro InRelease
          Hit:2 http://deb.debian.org/debian trixie InRelease
          Get:3 http://security.debian.org trixie-security InRelease [43.4 kB]
          Get:4 http://deb.debian.org/debian trixie-updates InRelease [47.1 kB]
          Get:5 http://security.debian.org trixie-security/main amd64 Packages [8,780 B]
          Get:6 http://security.debian.org trixie-security/main Translation-en [9,164 B]
          Fetched 108 kB in 0s (276 kB/s)
          1 package can be upgraded. Run 'apt list --upgradable' to see it.
          Warning: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
          michael@iobroker:~$ apt policy nodejs
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          michael@iobroker:~$
          • L lessthanmore
            nodejs:
              Version table:
                 20.19.2+dfsg-1 500
            michael@iobroker:~$
            #88
            @lessthanmore
            Gibt es da noch andere Dateien?
            ls -l /etc/apt/preferences.d/
              @lessthanmore
              lessthanmore
              schrieb am zuletzt editiert von lessthanmore
              #89
              michael@iobroker:~$ ls -l /etc/apt/preferences.d/
              total 12
              -rw-r--r-- 1 root root 65 May  9 22:16 nodejs
              -rw-r--r-- 1 root root 66 Aug 12 11:45 nodejs.pref
              -rw-r--r-- 1 root root 65 May  9 22:16 nsolid
              michael@iobroker:~$
              1 und 3 können weg oder?
              Package: nodejs
              Pin-Priority: 600
              Package: nodejs
              Pin-Priority: 1001
              Package: nsolid
              Pin-Priority: 600
              • L lessthanmore
                total 12
                michael@iobroker:~$
                Package: nodejs
                Pin-Priority: 600
                Package: nodejs
                Pin-Priority: 1001
                Package: nsolid
                Pin-Priority: 600
                #90
                @lessthanmore sagte in Wir empfehlen: Node.js 22.x:
                Richtig. Der erste Treffer zieht.
                  lessthanmore
                  #91
                  @thomas-braun Nach reboot.
                  total 4
                  All packages are up to date.
                  nodejs:
                    Version table:
                   *** 22.18.0-1nodesource1 1001
                       22.17.1-1nodesource1 1001
                       22.17.0-1nodesource1 1001
                       22.16.0-1nodesource1 1001
                       22.15.1-1nodesource1 1001
                       22.15.0-1nodesource1 1001
                       22.14.0-1nodesource1 1001
                       22.13.1-1nodesource1 1001
                       22.13.0-1nodesource1 1001
                       22.12.0-1nodesource1 1001
                       22.11.0-1nodesource1 1001
                       22.10.0-1nodesource1 1001
                       22.9.0-1nodesource1 1001
                       22.8.0-1nodesource1 1001
                       22.7.0-1nodesource1 1001
                       22.6.0-1nodesource1 1001
                       22.5.1-1nodesource1 1001
                       22.5.0-1nodesource1 1001
                       22.4.1-1nodesource1 1001
                       22.4.0-1nodesource1 1001
                       22.3.0-1nodesource1 1001
                       22.2.0-1nodesource1 1001
                       22.1.0-1nodesource1 1001
                       22.0.0-1nodesource1 1001
                       20.19.2+dfsg-1 500
                  michael@iobroker:~$
                  • L lessthanmore
                    total 4
                    nodejs:
                      Version table:
                         20.19.2+dfsg-1 500
                    michael@iobroker:~$
                    #92
                    Nein, jetzt zieht die nodejs.pref
                      lessthanmore
                      #93
                      @thomas-braun Was wäre/ ist denn richtig?
                      • L lessthanmore
                        #94
                        @lessthanmore
                        Die 1001, weil damit auch Downgrades ohne weitere Klimmzüge möglich sind.
                          @lessthanmore
                          lessthanmore
                          #95
                          @thomas-braun Ich steh auf dem Schlauch.
                          Soll ich die nodejs nochmal anlegen mit pin 1001?
                          • L lessthanmore
                            #96
                            @lessthanmore
                            Nein, alles gut. Jetzt passt es.
                              @lessthanmore
                              lessthanmore
                              #97
                              @thomas-braun Lieben Dank!
                              • L lessthanmore
                                #98
                                @lessthanmore
                                Ich danke dir, das packe ich gleich in einen Fix für 'nodejs-update'.
                                • haselchenH haselchen
                                  @apollon77
                                  Werden die Entwickler von euch informiert ihre Adapter anzupassen?
                                  Oder läuft das so:
                                  Ihr empfehlt -> wir merken das was nicht funktioniert -> erstellen ein Issue -> wenns gut läuft arbeitet der Entwickler es ab ?
                                  #99
                                  @haselchen Also idealerweise sollte derjeniger der das Problem bemerkt ein Issue mit Logs und Infos erstellen. Es macht wenig sinn hier Stille Post zu spielen. Auch weil in dem Fall Node.js 22 schon seit über einem Jahr existiert ... Interessant das noch nicht alles gefunden wurde
                                    @lessthanmore
                                    Da gilt auch:
                                    Da müssen Komponenten neugebaut werden. Mal deinstallieren und wieder drauf, dann sollte das automatisch passieren.
                                    #100
                                    @thomas-braun Sehr interessant ... an sich sollte der Controller genau solche dinge erkennen und selbst versuchen ein Rebuild anzustossen
                                    • B BigMike71
                                      mike@Pi5:~ $ iob diag
                                      mike@Pi5:~ $ iob status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      mike@Pi5:~ $
                                      mike@Pi5:~ $ iob version
                                      7.0.7
                                      mike@Pi5:~ $
                                      mike@Pi5:~ $
                                      #101
                                      @bigmike71 Am besten bei solchen Effekten einmal "iob fix" machen
                                      • apollon77A apollon77
                                        #102
                                        @apollon77 sagte in Wir empfehlen: Node.js 22.x:
                                        Macht er ja auch, kommt aber nicht zum Ziel:
                                        host.raspberrypi 2025-08-14 12:15:10.456	error	iobroker npm-rebuild: Rebuilding native modules failed
                                        host.raspberrypi 2025-08-14 12:15:11.490	info	iobroker npm-rebuild: exit 1
                                        • mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          #103
                                          @haselchen said in Wir empfehlen: Node.js 22.x:
                                          @apollon77
                                          Oder läuft das so:
                                          Ja
                                          Schau bitte doch bitte mal bei den Adaptern rein.
                                          Beispiel: EUSEC
                                          https://github.com/bropat/ioBroker.eusec/issues/443
                                          https://github.com/bropat/ioBroker.eusec/issues/481
                                          Bezüglich der Testtiefe stell die Frage bitte an den jeweiligen Entwickler. Überraschend kommen node Updates für Entwickler jedenfalls nicht.
                                          ALLE Adapter die in den Repositories gelistet sind bekommen rechtzeitig solche Erinnerungsissues.
                                          Für Adapter die nur via Github installierbar sind gilt natürlich dass von solchen Adapter prinzipiell abgeraten wird und dass Benutzer solcher Adapter dies selbt abklären / nachfragen sollten.
                                          Support Repositoryverwaltung.
                                          LESEN - gute Forenbeitrage
