  4. Fehler VIS-2 Widget Inventwo
    5.8k
77 Beiträge 11 Kommentatoren 9.1k Aufrufe 11 Beobachtet
  • LongbowL Online
    LongbowL Online
    Longbow
    schrieb am zuletzt editiert von Longbow
    So es hat endlich geklappt.
    Hier der Text aus dem html, bin gespannt @jkvarel und @OliverIO ob ihr damit was anfangen könnt
    [log] Translate: jqui_widgetTitle
    [log] Translate: jqui_Write state
    [log] Translate: jqui_Close
    [log] Translate: jqui_input
    [log] Translate: jqui_off
    [log] Translate: jqui_on
    [log] Translate: Value
    [log] Ignored bars/tplBarFilter because not used in project
    [log] Ignored bars/tplBarNavigator because not used in project
    [log] Ignored canvas-gauges/tplCGlinearGauge because not used in project
    [log] Ignored canvas-gauges/tplCGradialGauge because not used in project
    [log] Ignored canvas-gauges/tplCGCompas because not used in project
    [log] Ignored canvas-gauges/tplCGflatGauge because not used in project
    [log] Ignored colorpicker/tplRGBSpectrum because not used in project
    [log] Ignored colorpicker/tplSpectrumHomematic because not used in project
    [log] Ignored colorpicker/tplRGBFarbtastic because not used in project
    [log] Ignored colorpicker/tplHUEjscolor because not used in project
    [log] Ignored colorpicker/tplHUEPickerXY because not used in project
    [log] Ignored colorpicker/tplHUEIndicatorXY because not used in project
    [log] Ignored colorpicker/tplHUEPickerCT because not used in project
    [log] Ignored colorpicker/tplHUEIndicatorCT because not used in project
    [log] Ignored colorpicker/tplJscolor because not used in project
    [log] Ignored eventlist/tplEventlist because not used in project
    [log] Ignored eventlist/tplEventlistButton because not used in project
    [log] Ignored history/tplHistoryEventList because not used in project
    [log] Ignored history/tplHistorySparkLIne because not used in project
    [log] Ignored jqplot/tplJqplotGauge because not used in project
    [log] Ignored justgage/tplJustgageJustGage because not used in project
    [log] Ignored justgage/tplJustgageValueColored because not used in project
    [log] Ignored justgage/tplJustgageIndicatorColored because not used in project
    [log] Ignored justgage/tplJustgageValueIndicatorColored because not used in project
    [log] Ignored map/tplOsm because not used in project
    [log] Ignored map/tplGoogleMap because not used in project
    [log] Ignored material/tplMaListDoor because not used in project
    [log] Ignored material/tplMaListWindow because not used in project
    [log] Ignored material/tplMaListShutter because not used in project
    [log] Ignored material/tplMaListTemp because not used in project
    [log] Ignored material/tplMaListHumid because not used in project
    [log] Ignored material/tplMaListLight because not used in project
    [log] Ignored material/tplMaListLightDim because not used in project
    [log] Ignored rgraph/tplRGtermometer because not used in project
    [log] Ignored rgraph/tplRGgauge because not used in project
    [log] Ignored rgraph/tplRLiveChart because not used in project
    [log] Ignored rgraph/tplRBarChart because not used in project
    [log] Ignored swipe/tplCarousel because not used in project
    [log] Ignored trashschedule/tplTrashscheduleHelper because not used in project
    [log] Ignored weather/tplWeatherShowInstance because not used in project
    [log] log test
    [warn] warn test
    [error] error test
    [debug] debug test
    [log] [2025-08-11T14:27:25.073Z] +SUBSCRIBE: 0_userdata.0.Eigene_Datenpunkte.Garage.AutoClose_RemainingSec
    [log] [2025-08-11T14:27:25.076Z] +SUBSCRIBE: 0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor
    Das steht jetzt noch dazu
    [error] [2025-08-11T14:53:17.758Z] ws connection error: CLOSE_ABNORMAL
    [log] [2025-08-11T14:53:17.766Z] Start reconnect 0
    [log] [2025-08-11T14:53:17.846Z] Try to connect
    [log] [2025-08-11T15:08:40.280Z] Start reconnect 0
    [log] [2025-08-11T15:08:40.290Z] Try to connect
    [error] [2025-08-11T15:08:40.395Z] ws connection error: CLOSE_ABNORMAL
    [log] [2025-08-11T15:08:40.397Z] Start reconnect 1
    [log] [2025-08-11T15:08:40.400Z] Reconnect is already running 1
    [error] [2025-08-11T15:08:40.400Z] ws connection error: CLOSE_ABNORMAL
    [log] [2025-08-11T15:08:40.402Z] Reconnect is already running 1
    [log] [2025-08-11T15:08:42.295Z] Try to connect
    [log] [2025-08-11T15:40:06.480Z] Start reconnect 0
    [error] [2025-08-11T15:40:06.937Z] ws connection error: CLOSE_ABNORMAL
    [log] [2025-08-11T15:40:06.938Z] Reconnect is already running 0
    [log] [2025-08-11T16:30:25.704Z] Try to connect
    jkvarelJ 1 Antwort Letzte Antwort
    • LongbowL Longbow
      [log] log test
      [warn] warn test
      [error] error test
      [debug] debug test
      jkvarelJ Online
      jkvarelJ Online
      jkvarel
      @longbow hast du in der gleichen View ein inventwo Widget drin?
      LongbowL 1 Antwort Letzte Antwort
      • jkvarelJ jkvarel
        LongbowL Online
        LongbowL Online
        Longbow
        @jkvarel wie meinst du das ?
        hier die Seite exportiert:
          "name": "test",
          "parentId": null,
          "settings": {
            "style": {},
            "class": "mylog"
          "widgets": {
            "w000406": {
              "tpl": "tplHtml",
              "data": {
                "bindings": [],
                "name": "mylog",
                "comment": null,
                "class": "mylog",
                "filterkey": null,
                "multi-views": null,
                "locked": null,
                "g_fixed": true,
                "html": "<script>\r\n    console.log(\"log test\");\r\n    console.warn(\"warn test\");\r\n    console.error(\"error test\");\r\n    console.debug(\"debug test\");\r\n</script>",
                "refreshInterval": null,
                "g_common": true
              "style": {
                "bindings": [],
                "left": 48,
                "top": 64,
                "width": "711px",
                "height": "331px"
              "widgetSet": "basic"
            "w000407": {
              "tpl": "tplInventwoWidgetUniversal",
              "data": {
                "bindings": [],
                "type": "switch",
                "g_common": true,
                "mode": "singleButton",
                "direction": "row",
                "oid": "nothing_selected",
                "httpType": "send",
                "buttonSize": 110,
                "btnSpacing": 10,
                "countStates": 1,
                "buttonHoldValue": false,
                "dialogWidth": 500,
                "g_attr_group_type_view_in_dialog": true,
                "dialogHeight": 300,
                "dialogPadding": 10,
                "dialogBackground": "rgb(18, 18, 18)",
                "dialogTitleColor": "rgb(255,255,255)",
                "dialogTitleSize": 20,
                "dialogCloseButtonBackground": "rgba(255,255,255,0)",
                "dialogCloseButtonColor": "rgba(255,255,255,1)",
                "dialogCloseButtonSize": 14,
                "dialogBorderRadiusTopLeft": 12,
                "dialogBorderRadiusTopRight": 0,
                "dialogBorderRadiusBottomRight": 12,
                "dialogBorderRadiusBottomLeft": 0,
                "clickThrough": false,
                "g_attr_group_click_feedback": true,
                "feedbackDuration": 0,
                "backgroundFeedback": "rgba(69, 86, 24, 1)",
                "outerShadowColorFeedback": "rgba(0, 0, 0, 1)",
                "contentBlinkInterval": 0,
                "g_attr_group_state_default": true,
                "outerShadowColor": "rgba(0, 0, 0, 1)",
                "colorPickerColorModel": "hex",
                "g_attr_content_color_picker": true,
                "colorPickerWidth": 200,
                "colorPickerHandleSize": 8,
                "colorPickerHandleMargin": 6,
                "colorPickerComponentsSpace": 12,
                "colorPickerDirection": "vertical",
                "colorPickerBorderWidth": 0,
                "colorPickerShowWheel": true,
                "colorPickerShowSaturation": true,
                "colorPickerShowValue": true,
                "textDecoration": "none",
                "g_attr_group_css_text": true,
                "textMarginTop": 0,
                "textMarginBottom": 0,
                "textMarginLeft": 0,
                "textMarginRight": 0,
                "contentType": "icon",
                "g_attr_group_css_content": true,
                "contentMarginTop": 0,
                "contentMarginBottom": 0,
                "contentMarginLeft": 0,
                "contentMarginRight": 0,
                "contentSize": 40,
                "contentRotation": 0,
                "contentMirror": false,
                "flexDirection": "column",
                "g_attr_group_css_alignment": true,
                "alignItems": "space-between",
                "textAlign": "start",
                "contentAlign": "center",
                "backgroundOpacity": 1,
                "g_attr_group_css_transparency": true,
                "contentOpacity": 1,
                "paddingLeft": 10,
                "g_attr_group_css_spacing": true,
                "paddingRight": 10,
                "paddingTop": 10,
                "paddingBottom": 10,
                "borderRadiusTopLeft": 12,
                "g_attr_group_css_border_radius": true,
                "borderRadiusTopRight": 0,
                "borderRadiusBottomRight": 12,
                "borderRadiusBottomLeft": 0,
                "borderSizeTop": 0,
                "g_attr_group_css_border": true,
                "borderSizeBottom": 0,
                "borderSizeLeft": 0,
                "borderSizeRight": 0,
                "borderStyle": "none",
                "outerShadowX": 2,
                "g_attr_group_css_outer_shadow": true,
                "outerShadowY": 2,
                "outerShadowBlur": 2,
                "outerShadowSize": 1,
                "innerShadowX": 0,
                "g_attr_group_css_inner_shadow": true,
                "innerShadowY": 0,
                "innerShadowBlur": 0,
                "innerShadowSize": 0
              "style": {
                "bindings": [],
                "left": 45,
                "top": 389,
                "width": "179px",
                "height": "199px",
                "position": "absolute",
                "overflow": "visible"
              "widgetSet": "vis-2-widgets-inventwo"
            "w000408": {
              "tpl": "tplContainerView",
              "data": {
                "bindings": [],
                "contains_view": "Torsteuerung",
                "g_common": true
              "style": {
                "bindings": [],
                "left": 261,
                "top": 387,
                "width": "312px",
                "height": "270px"
          "activeWidgets": []
        • LongbowL Online
          LongbowL Online
          Longbow
          kann mir jemandes behilflich sein? Bin ich der einzige, der diese Problem hat
          • jkvarelJ Online
            jkvarelJ Online
            jkvarel
            Nicht wirklich ein Fehler da. Die Websocket Fehler werden damit nichts zu tun haben. @Longbow, hattest du schon den Browser Cache geleert? Wäre ein Versuch wert.
            Ansonsten, @OliverIO hast du noch eine Idee?
            OliverIOO 2 Antworten Letzte Antwort
            • jkvarelJ jkvarel
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              @jkvarel
              Ohne Fehlermeldung schwierig.
              Man könnte unter Windows mal noch Safari installieren. Aber dann wäre es wirklich was Browser spezifischisches, was für mich ein wenig strange wär
              Meine Adapter und Widgets
              Links im Profil
              F 1 Antwort Letzte Antwort
              • OliverIOO OliverIO
                @jkvarel
                Filo
                @oliverio,
                sorry,ich hab den ganzen Thread ein bisschen verschlafen, habe auch das gleiche Problem wie Longbow. Wenn ich das Ganze (leere Seite mit dem HTML Widget und Universal Widget) auf Safari im IPad mini öffne, bekomme ich folgende Fehlerausgabe:
                [log] log test
                [warn] warn test
                [error] error test
                [debug] debug test
                [error] Cannot load widget system.adapter.vis-2-widgets-inventwo.0: ReferenceError: Cannot access uninitialized variable.
                [error] Cannot load widget system.adapter.vis-2-widgets-inventwo.0: {}
                vielleicht kann man daraus etwas sehen.
                Filo
                • F Filo
                  @oliverio,
                  [log] log test
                  [warn] warn test
                  [error] error test
                  [debug] debug test
                  Filo
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @filo
                  Das sieht schon besser aus. Evtl gibt das @jkvarel schon genug Hinweise zum suchen.
                  Dürfte aber auch ein Fehler sein, der eigentlich auch auf anderen Plattformen auftaucht.
                  Ich muss mal schauen, ob man die Ausgabe auch noch mit dem callstack erweitern kann.
                  Dann würde man genau sehen, an welcher Stelle der Fehler auftritt.
                  Links im Profil
                  • LongbowL Online
                    LongbowL Online
                    Longbow
                    Hallo in die Runde,
                    ich habe mir ein neues System auf gesetzt, nur die VIS-2 installiert und Inventwo Widgets.
                    Da läuft alles perfekt, geh ich in die Beta Version auch, nur bei dem Adapter darf ich nicht über 0.2.2 gehen, dann habe ich das Problem wieder.
                    Im System, was ich gebrauche, hat ein Down Option des Adapter leider nicht den Erfolg gebracht. Da bin ich am probieren.
                    Im neuen System geht es, alle Mobile Versionen bei uns probiert und es geht.
                    Update, in dem alten System kann ich die VIS 1 nicht löschen als Adapter. Denke das ich alles umziehen muss in den neuen Iobroker oder ?
                    • LongbowL Longbow
                      Hallo in die Runde,
                      Filo
                      @longbow
                      die Version 0.2.2 läuft bei mir auch einwandfrei (auch nach Downgrade von 0.3.5). Bei höheren Versionen habe ich das oben beschriebene Problem.
                      Es gibt bei der Version 0.3.5 ein weiteres Problem mit multiplen Zuständen, dazu habe ich bereits ein Issue auf GitHub eröffnet. Link
                      Filo
                      • LongbowL Online
                        LongbowL Online
                        Longbow
                        Also ich werde nicht drum her rum kommen, alles neu auf zu setzten und dann hoffentlich den Fehler nicht mehr zu haben.
                        Bis jetzt läuft das neue System ohne Fehler bei dem Widget. Bei dem neuen habe ich kein Vis-1 mehr installiert.
                        Ich bin gespannt, was her aus kommt bei dem Fehlercode.
                        • jkvarelJ jkvarel
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          @jkvarel
                          Vergiss bitte nicht den Code zeitnah zu deaktivieren, da ansonsten bei allen die die Widgets installiert haben die komplette browser Konsole umgebogen wird.
                          Das könnte die fehlersuche auch für andere Widgets schwierig machen da die Konsole dann einfach leer ist.
                          Links im Profil
                          • LongbowL Longbow
                            jkvarelJ Online
                            jkvarelJ Online
                            jkvarel
                            @longbow bitte mit v0.3.6 versuchen und die Ausgaben schicken. Dort sollte beistehen, woher der Fehler kommt
                            LongbowL F 4 Antworten Letzte Antwort
                            • jkvarelJ jkvarel
                              LongbowL Online
                              LongbowL Online
                              Longbow
                              @jkvarel Guten Morgen, du ich habe ein neues System auf gesetzt, kein VIS 1 sachen installiert und es geht nun prima. Da lange keine reaktion kam, habe ich das system gelöscht. Sorry. Ich kann somit leider gerade nichts mehr dazu sagen, aber es scheint ein Problem zu sein.
                              • LongbowL Online
                                LongbowL Online
                                Longbow
                                @jkvarel Gibt es was neues, keine Ahnung warum, aber es wurde heute die Neue Verion installiert, jetzt habe ich die gleichen Fehler wieder auf den iOS Geräten. Auch ein Downgrade macht kein Verbesserung mehr, der Fehler bleibt weiterhin. Hast du hier schon mal was machen können.
                                @all sind wir die einizgen, die diese Problem haben.
                                • LongbowL Online
                                  LongbowL Online
                                  Longbow
                                  @jkalver Es muss an das Neu laden des VIS 2 Adapter liegen, wenn ich was update wird der neu geladen der Editor, nur dann ist es mal so, das links euere zur Auswahl steht, mal nicht. Wenn es nicht zur Auswahl steht, dann kommen die Fehlermeldung.
                                  Aber habe heute das bemerkt, auch wenn geladen ist, das der Widget Schieberegler und Checkbox auch Fehler in der Vis machen.
                                  An was liegt das bitte? Das kann ja nicht bei 1-2 Leuten sei? Oder?
                                  • jkvarelJ jkvarel
                                    Filo
                                    schrieb am zuletzt editiert von Filo
                                    @jkvarel
                                    Habe mit der 0.3.6 folgende Fehlermeldungen erhalten (mit Universal Widget, Schieberegler und Schalter auf der Seite), ich hoffe das kommt nichtzu spät:
                                    [error] [2025-10-11T15:21:57.865Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
                                    [error] Socket Error: UNKNOWN @ @http://192.168.2.8:8082/vis-2/assets/index-CMnY6NW2.js:57091:201
                                    [log] [2025-10-11T15:21:57.866Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:57.866Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:57.866Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:57.866Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
                                    [error] [2025-10-11T15:21:57.949Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
                                    [log] [2025-10-11T15:21:57.949Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:57.949Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:57.949Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:57.950Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
                                    [error] [2025-10-11T15:21:58.066Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
                                    [log] [2025-10-11T15:21:58.067Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:58.067Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:58.067Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:58.067Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
                                    [error] [2025-10-11T15:21:58.101Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
                                    [log] [2025-10-11T15:21:58.101Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:58.101Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:58.101Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:58.101Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
                                    [error] [2025-10-11T15:21:58.212Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
                                    [log] [2025-10-11T15:21:58.212Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:58.212Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:58.212Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:58.213Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
                                    [error] [2025-10-11T15:21:58.317Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
                                    [log] [2025-10-11T15:21:58.317Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:58.317Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:58.317Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:58.317Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
                                    [error] [2025-10-11T15:21:58.427Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
                                    [log] [2025-10-11T15:21:58.427Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:58.428Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:58.428Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:58.428Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
                                    [error] [2025-10-11T15:21:58.481Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
                                    [log] [2025-10-11T15:21:58.481Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:58.481Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:58.481Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:58.482Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
                                    [error] [2025-10-11T15:21:58.527Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
                                    [log] [2025-10-11T15:21:58.527Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:58.527Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:58.527Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:58.528Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
                                    [error] [2025-10-11T15:21:58.606Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
                                    [log] [2025-10-11T15:21:58.606Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:58.606Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:58.606Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:58.607Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
                                    [error] [2025-10-11T15:21:58.677Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
                                    [log] [2025-10-11T15:21:58.677Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:58.678Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:58.678Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:58.678Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
                                    [error] [2025-10-11T15:21:58.721Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
                                    [log] [2025-10-11T15:21:58.721Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:58.721Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:58.722Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:58.722Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
                                    [error] [2025-10-11T15:21:58.782Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
                                    [log] [2025-10-11T15:21:58.782Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:58.783Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:58.783Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:58.783Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
                                    [error] [2025-10-11T15:21:58.899Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
                                    [log] [2025-10-11T15:21:58.899Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:58.899Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:58.899Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:58.899Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
                                    [error] [2025-10-11T15:21:58.964Z] ws normal error: error @ @http://192.168.2.8:8082/lib/js/socket.io.js:160:25
                                    [log] [2025-10-11T15:21:58.965Z] Start reconnect 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:58.965Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:58.965Z] Reconnect is already running 0 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:58.965Z] Try to connect @ @http://192.168.2.8:8082/lib/js/socket.io.js:392:21
                                    [error] [2025-10-11T15:21:58.972Z] ws connection error: CLOSED_NO_STATUS @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    [log] [2025-10-11T15:21:58.972Z] Start reconnect 1 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [log] [2025-10-11T15:21:58.972Z] Reconnect is already running 1 @ close@http://192.168.2.8:8082/lib/js/socket.io.js:372:20
                                    [error] [2025-10-11T15:21:58.972Z] ws connection error: CLOSE_ABNORMAL @ @http://192.168.2.8:8082/lib/js/socket.io.js:153:23
                                    Vielleicht diese noch, die steht ganz am Anfang:
                                    [error] Cannot load widget system.adapter.vis-2-widgets-inventwo.0: ReferenceError: Cannot access uninitialized variable. @ @http://192.168.2.8:8082/vis-2/assets/visView-9RsJe6Ux.js:3314:22
                                    [error] Cannot load widget system.adapter.vis-2-widgets-inventwo.0: {} @ @http://192.168.2.8:8082/vis-2/assets/visView-9RsJe6Ux.js:3314:107
                                    Gruß Filo
                                    • jkvarelJ jkvarel
                                      Filo
                                      @jkvarel
                                      so, ich hab nochmals alles durchprobiert: Adapter neu installiert, mit allen möglichen socket Enstellungen rumprobiert, IObroker neu aufgespielt (Docker übrigens), aber nichts hat geholfen. Das Problem besteht nur im Apple Umfeld (Iphone und Ipad)., komisch, das sonst niemand diese Probleme hat ausser uns.
                                      Probleme bei Apple Umgebung:
                                      Universal Widget: wird manchmal angezeigt
                                      Schieberegler: Wird nie angezeigt
                                      Schalter: Wird nie angezeigt
                                      andere Widgets benutze ich nicht.
                                      Fehler tritt nur im Apple Universum auf, (Browser oder Vis App), bei Windows Geräten habe ich ich keine Probleme, alles funktioniert einwandfrei, Android Geräte habe ich keine. Versionen bis 0.2.2 laufen auch einwandfrei.
                                      Gibt es jemand, bei dem die Widgets unter Apple laufen, dann müsste es ja an meinem System liegen. Meine Vis2 ist auf inventwo Widgets aufgebaut und es wäre gar nicht einfach , das Ganze mit anderen Mitteln umzusetzen und wenn, dann doch sehr umständlich..
                                      Filo
                                      skvarelS E 2 Antworten Letzte Antwort
                                      • F Filo
                                        @jkvarel
                                        Filo
                                        skvarelS Offline
                                        skvarelS Offline
                                        skvarel
                                        @filo .. ich sage meinem Sohn Bescheid. Er war in letzter Zeit nicht sehr oft im Forum.
                                        #TeamInventwo
                                        Unsere Adapter:
                                        • F Filo
                                          @jkvarel
                                          Filo
                                          eLichte
                                          @filo
                                          Hi, wollte mich mal hier einklinken.
                                          Ich habe das gleiche Problem nur auf Apple Ipad und Iphone im Safari Browser und auch in der IO-Broker Visu App
                                          Vis 2 Inventwo Widgets 0.3.9
                                          Vis 2 2.13.6
                                          Ich benutze nur das Universal Widget. Meist geht es beim ersten Aufruf und dann nicht mehr.
