  4. Wir empfehlen: Node.js 22.x
    6.8k
370 Beiträge 53 Kommentatoren 92.7k Aufrufe 53 Beobachtet
  • L lessthanmore
    @thomas-braun Es war gar nicht der Adapter, sondern zigbee2mqtt selbst. Sorry.
    Sollte jetzt passen :-)
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.14.8-2-pve
        Architecture: x86-64
    OS is similar to:
    model name	: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     12:08:39 up 1 min,  1 user,  load average: 0.55, 0.61, 0.56
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-08-13 12:08:39 CEST
               Universal time: Wed 2025-08-13 10:08:39 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    michael
    HOME=/home/michael
    GROUPS=michael sudo users iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/michael
    GROUPS=iobroker tty dialout audio video plugdev redis
    *** DISPLAY-SERVER SETUP ***
    Display-Server: 	false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session: 		tty
    *** MEMORY ***
    Mem:            8.6G        1.1G        7.1G        1.6M        335M        7.5G
    Swap:           536M          0B        536M
    Total:          9.1G        1.1G        7.7G
    Active iob-Instances: 	13
             8192 M total memory
             1080 M used memory
             1230 M active memory
              101 M inactive memory
             6792 M free memory
                0 M buffer memory
              319 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    top - 12:08:39 up 1 min,  1 user,  load average: 0.55, 0.61, 0.56
    Tasks:  47 total,   1 running,  46 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8192.0 total,   6791.5 free,   1081.9 used,    319.9 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7110.1 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--1 ext4       25G  4.9G   19G  21% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    /dev/mapper/pve-root             ext4       67G  3.9G   60G   7% /dev/ttyACM0
    udev                             devtmpfs   32G     0   32G   0% /dev/tty
    tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
    tmpfs                            tmpfs      13G  152K   13G   1% /run
    tmpfs                            tmpfs      32G  1.4M   32G   1% /tmp
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     6.3G  8.0K  6.3G   1% /run/user/1001
    Show mounted filesystems:
    TARGET         SOURCE                                                 FSTYPE OPTIONS
    /              /dev/mapper/pve-vm--100--disk--1                       ext4   rw,relatime,stripe=16
    `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
    /var:
    418M	/var/
    214M	/var/lib
    130M	/var/cache
    126M	/var/cache/apt
    89M	/var/lib/apt
    Archived and active journals take up 24M in the file system.
    /opt/iobroker/backups:
    1.8M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    92M	/opt/iobroker/iobroker-data/
    56M	/opt/iobroker/iobroker-data/files
    38M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    6.8M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-0fd47d.a444afaa.chunk.js
    5.3M	/opt/iobroker/iobroker-data/objects.jsonl
    3.9M	/opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.92169c09.chunk.js
    3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
    3.7M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-Drg0QIRU.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2432650-if00
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v22.18.0
    /usr/bin/node 		v22.18.0
    /usr/bin/npm 		10.9.3
    /usr/bin/npx 		10.9.3
    /usr/bin/corepack 	0.33.0
    nodejs:
      Installed: 22.18.0-1nodesource1
      Candidate: 22.18.0-1nodesource1
      Version table:
     *** 22.18.0-1nodesource1 600
         22.17.1-1nodesource1 600
         22.17.0-1nodesource1 600
         22.16.0-1nodesource1 600
         22.15.1-1nodesource1 600
         22.15.0-1nodesource1 600
         22.14.0-1nodesource1 600
         22.13.1-1nodesource1 600
         22.13.0-1nodesource1 600
         22.12.0-1nodesource1 600
         22.11.0-1nodesource1 600
         22.10.0-1nodesource1 600
         22.9.0-1nodesource1 600
         22.8.0-1nodesource1 600
         22.7.0-1nodesource1 600
         22.6.0-1nodesource1 600
         22.5.1-1nodesource1 600
         22.5.0-1nodesource1 600
         22.4.1-1nodesource1 600
         22.4.0-1nodesource1 600
         22.3.0-1nodesource1 600
         22.2.0-1nodesource1 600
         22.1.0-1nodesource1 600
         22.0.0-1nodesource1 600
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    Hosts:
    iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 61)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		7.6.17
    javascript: 	8.9.2
    nodejs modules from github: 	1
    +-- iobroker.husqvarna-automower@0.6.0-beta.12 (git+ssh://git@github.com/ice987987/ioBroker.husqvarna-automower.git#e43328543d35c4555a4a3f3e595dd16417978d85)
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
    + system.adapter.husqvarna-automower.0    : husqvarna-automower   : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "lovelace"     : 4.1.15   , installed 4.1.15
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "openknx"      : 0.9.0    , installed 0.9.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
    Objects and States
    Objects: 	18944
    States: 	7107
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://security.debian.org trixie-security InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:44527         0.0.0.0:*               LISTEN      1000       2961001    535/io.yahka.0
    tcp        0      0 127.0.0.1:45247         0.0.0.0:*               LISTEN      1000       2961005    535/io.yahka.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      107        2954068    320/mosquitto
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2949013    1/init
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          2954254    288/master
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      105        2951043    146/redis-server 12
    tcp        0      0 127.0.0.1:40947         0.0.0.0:*               LISTEN      1000       2961009    535/io.yahka.0
    tcp6       0      0 ::1:6379                :::*                    LISTEN      105        2951044    146/redis-server 12
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          2954255    288/master
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       2951844    565/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2951332    338/io.admin.0
    tcp6       0      0 :::8091                 :::*                    LISTEN      1000       2955216    520/io.lovelace.0
    tcp6       0      0 :::35035                :::*                    LISTEN      1000       2951772    535/io.yahka.0
    tcp6       0      0 :::1883                 :::*                    LISTEN      107        2954069    320/mosquitto
    tcp6       0      0 :::33309                :::*                    LISTEN      1000       2951776    535/io.yahka.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          2949015    1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          2953518    1/init
    tcp6       0      0 :::41839                :::*                    LISTEN      1000       2951774    535/io.yahka.0
    udp        0      0 0.0.0.0:60413           0.0.0.0:*                           106        2950882    131/avahi-daemon: r
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2949014    1/init
    udp        0      0 0.0.0.0:34687           0.0.0.0:*                           1000       2955115    475/io.openknx.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        2950880    131/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          2949016    1/init
    udp6       0      0 :::5353                 :::*                                106        2950881    131/avahi-daemon: r
    udp6       0      0 :::41093                :::*                                106        2950883    131/avahi-daemon: r
    @lessthanmore
    Das haste aber jetzt auch nicht per iob nodejs-update gemacht, oder?
    Das müsste nämlich dann eigentlich anders aussehen.
    L 1 Antwort Letzte Antwort
    • A Online
      A Online
      ag
      Hallo.
      Habe jetzt mein Multihostsystem auch auf Nodejs22.
      1 Host (RPI5) und 2 Slaves (RPI4/RPI3)
      Der CanBus Adapter wollte erst nicht, Erst nach deinstallation und neubau lief der dann auch.
      Danke an Alle für die Tips und Tricks hier.
      ag
      Operating System: Debian GNU/Linux 12 architecture: arm64 Pi5 8GB
      /usr/bin/nodejs v20.18.0 /usr/bin/node 20.18.1 /usr/bin/npm 10.8.2
      js-controller 7.0.6 admin 7.4.10
        @lessthanmore
        lessthanmore
        @thomas-braun Doch, das habe ich.
        Wie müsste es denn aussehen bzw. wie kann ich es korrigieren?
        • L lessthanmore
          @lessthanmore sagte in Wir empfehlen: Node.js 22.x:
          Kannste so lassen. Ist nicht ganz verkehrt. nodejs-update sollte eigentlich das Paket nodejs mit ganz hoher Priority (1001) führen. Bei dir ist es 'nur' mit 600 eingestellt. Macht aber nix, ist immer noch höhere Prio als der Standard (500).
          Das könnte allerdings auch der Grund sein, warum das bei dir so komisch reagiert, Prio 1001 knallt diese Versionen ohne Rücksicht auf Verluste auf jedenfall rein, 600 ist nicht ganz so aggressiv.
            @mutanten sagte in Wir empfehlen: Node.js 22.x:
            Ich hoffe du kannst mir helfen.
            Nein, kann ich nicht.
            Das liegt an der von dir verwendeten 32Bit-Version.
            Installier das ganze Ding komplett neu als reines 64Bit-System.
            Dann würde auch der aktuelle Kernel geladen und nicht der von Raspberry 11 noch.
            In-line-Upgrades funktionieren von 11 auf 12 NICHT!
            Mutanten
            Alles klar, dann werde ich das versuchen.
            Danke und Gruß, Michael
            E3DC S10 Pro, 19,5kWh, 22,2kWp
            MyPV Thor9s & ELWA-E
            ioBroker mit Vis auf Raspberry Pi 4
              @BigMike71
              Eins fällt mir noch ein...
              Schau mal nach den Rechten an /home/iobroker
              ls -la /home
              BigMike71
              @thomas-braun said in Wir empfehlen: Node.js 22.x:
              ls -la /home
              mike@Pi5:~ $ ls -la /home
              total 36
              drwxr-xr-x  5 root root  4096 Sep  9  2024 .
              drwxr-xr-x 18 root root  4096 Jul  4  2024 ..
              drwxr-xr-x  2 root root 20480 Apr 18 17:25 backup
              drwxr-xr-x  4 mike ****  4096 Jul 15 18:04 iobroker
              drwx------ 12 mike **** 4096 Aug 13 11:48 mike
              mike@Pi5:~ $
              so siehts aus.
              hast du zufällig auch ein bash script für den iob fix, der macht auch nix mehr, früher gings...
              • B BigMike71
                ls -la /home
                total 36
                mike@Pi5:~ $
                so siehts aus.
                #66
                @bigmike71
                Haste die **** da selber reingeschrieben oder ist das so?
                Da sind eh die Rechte verbogen. /home/iobroker muss natürlich auch dem iobroker gehörten und NICHT dem mike.
                • B BigMike71
                  ls -la /home
                  total 36
                  mike@Pi5:~ $
                  so siehts aus.
                  #67
                  @bigmike71 sagte in Wir empfehlen: Node.js 22.x:
                  früher gings...
                  Bevor du dir die Rechte zerballert hast...
                  sudo chown -R iobroker:iobroker /home/iobroker
                  Das Verzeichnis
                  darf es da auch nicht geben. Oder hast du einen user namens 'backup', der irgendwas tut?
                  Aber dann hätte der die falschen Rechte, der Kram würde dann nicht root gehören. Der hat ein eigenes Home unter /root
                  Also komplett alles irgendwie durcheinandergeschossen.
                    früher gings...
                    Das Verzeichnis
                    BigMike71
                    #68
                    kann ich mir damit was kaputt machen? gibt es einen weg notfalls zurück?
                    keine ahnung warum die rechte so sind, hatte eine normale installation seinerzeit gemacht über ssh
                    • B BigMike71
                      #69
                      Das IST doch schon alles kaputt gefummelt. Mit dem Befehl stellst du das wieder richtig, sodass auch der Befehle wie iob diag und iob nodejs-update wieder funktionieren können. Grund bei dir ist: Die Skripte können nicht heruntergeladen werden, weil der user 'iobroker' in sein eigenes Zuhause nicht reinkommt, weil da jemand an der Tür das Schloss getauscht hat.
                      Und irgendwann danach hast DU die Rechte zerballert. Der user 'iobroker' wird natürlich erstmal mit den richtigen Rechten angelegt.
                        bean
                        #70
                        Das Update des Containers von Buanet auf 11 Latest hat einwandfrei funktioniert - leider kann der eCharts-Adapter keine Bilder mehr versenden und der Eusec Adapter lässt sich nicht starten - entsprechende Issues sind schon eröffnet und warten auf Behandlung.
                        Also wieder zurück auf v10/Node 20, ich muss noch warten...
                        • P Offline
                          Pitpilot
                          #71
                          Der Siemens Simatic S7 Adapter macht leider einen Fehler mit Node.js 22.x und ich musste zurück auf 20 updaten.
                          Also Vorsicht wenn ihr eine Produktiv System am Laufen habt !!
                          Kennt das Problem schon jemand?
                          host.raspberrypi
                          2025-08-14 12:15:14.244	error	instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          host.raspberrypi
                          2025-08-14 12:15:14.244	error	Caught by controller[0]: Node.js v22.18.0
                          host.raspberrypi
                          2025-08-14 12:15:14.244	error	Caught by controller[0]: }
                          host.raspberrypi
                          2025-08-14 12:15:14.243	error	Caught by controller[0]: ]
                          host.raspberrypi
                          2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-arm64/node_snap7.node'
                          host.raspberrypi
                          2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node',
                          host.raspberrypi
                          2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node',
                          host.raspberrypi
                          2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node',
                          host.raspberrypi
                          2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/compiled/22.18.0/linux/arm64/node_snap7.node',
                          host.raspberrypi
                          2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node',
                          host.raspberrypi
                          2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Release/node_snap7.node',
                          host.raspberrypi
                          2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node',
                          host.raspberrypi
                          2025-08-14 12:15:14.243	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node',
                          host.raspberrypi
                          2025-08-14 12:15:14.242	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node',
                          host.raspberrypi
                          2025-08-14 12:15:14.242	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node',
                          host.raspberrypi
                          2025-08-14 12:15:14.242	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node',
                          host.raspberrypi
                          2025-08-14 12:15:14.242	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/node_snap7.node',
                          host.raspberrypi
                          2025-08-14 12:15:14.242	error	Caught by controller[0]: tries: [
                          host.raspberrypi
                          2025-08-14 12:15:14.242	error	Caught by controller[0]: at require (node:internal/modules/helpers:135:16) {
                          host.raspberrypi
                          2025-08-14 12:15:14.242	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1445:12)
                          host.raspberrypi
                          2025-08-14 12:15:14.241	error	Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
                          host.raspberrypi
                          2025-08-14 12:15:14.241	error	Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                          host.raspberrypi
                          2025-08-14 12:15:14.241	error	Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1246:12)
                          host.raspberrypi
                          2025-08-14 12:15:14.241	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1423:32)
                          host.raspberrypi
                          2025-08-14 12:15:14.241	error	Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1820:10)
                          host.raspberrypi
                          2025-08-14 12:15:14.241	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1688:14)
                          host.raspberrypi
                          2025-08-14 12:15:14.241	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
                          host.raspberrypi
                          2025-08-14 12:15:14.241	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
                          host.raspberrypi
                          2025-08-14 12:15:14.241	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-arm64/node_snap7.node
                          host.raspberrypi
                          2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node
                          host.raspberrypi
                          2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node
                          host.raspberrypi
                          2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node
                          host.raspberrypi
                          2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/compiled/22.18.0/linux/arm64/node_snap7.node
                          host.raspberrypi
                          2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node
                          host.raspberrypi
                          2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Release/node_snap7.node
                          host.raspberrypi
                          2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node
                          host.raspberrypi
                          2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node
                          host.raspberrypi
                          2025-08-14 12:15:14.240	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node
                          host.raspberrypi
                          2025-08-14 12:15:14.239	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node
                          host.raspberrypi
                          2025-08-14 12:15:14.239	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node
                          host.raspberrypi
                          2025-08-14 12:15:14.239	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/node_snap7.node
                          host.raspberrypi
                          2025-08-14 12:15:14.239	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                          host.raspberrypi
                          2025-08-14 12:15:14.239	error	Caught by controller[0]: ^
                          host.raspberrypi
                          2025-08-14 12:15:14.239	error	Caught by controller[0]: throw err;
                          host.raspberrypi
                          2025-08-14 12:15:14.238	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
                          host.raspberrypi
                          2025-08-14 12:15:12.134	info	instance system.adapter.s7.0 in version "1.4.3" started with pid 6217
                          host.raspberrypi
                          2025-08-14 12:15:11.490	info	iobroker npm-rebuild: exit 1
                          host.raspberrypi
                          2025-08-14 12:15:10.456	error	iobroker npm-rebuild: Rebuilding native modules failed
                          vis.0
                          2025-08-14 12:15:05.035	info	Terminated (NO_ERROR): Without reason
                          vis.0
                          2025-08-14 12:15:03.976	info	starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.18.0, js-controller: 7.0.6
                          host.raspberrypi
                          2025-08-14 12:14:52.609	info	iobroker npm-rebuild: Rebuilding native modules ...
                          host.raspberrypi
                          2025-08-14 12:14:50.956	info	iobroker rebuild
                          host.raspberrypi
                          2025-08-14 12:14:50.955	warn	adapter "s7" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                          host.raspberrypi
                          2025-08-14 12:14:50.955	info	system.adapter.s7.0 will be rebuilt
                          host.raspberrypi
                          2025-08-14 12:14:50.955	info	Adapter system.adapter.s7.0 needs rebuild and will be restarted afterwards.
                          host.raspberrypi
                          2025-08-14 12:14:50.955	error	instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          host.raspberrypi
                          2025-08-14 12:14:50.955	error	Caught by controller[0]: Node.js v22.18.0
                          host.raspberrypi
                          2025-08-14 12:14:50.955	error	Caught by controller[0]: }
                          host.raspberrypi
                          2025-08-14 12:14:50.954	error	Caught by controller[0]: ]
                          MOD-EDIT:Code in code-tags gesetzt!
                          • P Pitpilot
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            vis.0
                            vis.0
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            #72
                            @pitpilot sagte in Wir empfehlen: Node.js 22.x:
                            Auch hier muss ein rebuild erfolgen. Da das aber augenscheinlich über den internen Vorgang nicht funktioniert, deinstallier den Adapter mal komplett und installier den dann nochmal frisch von Neu.
                            mcm1957M P 2 Antworten Letzte Antwort
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              #73
                              Eine REINSTALLATION sollte m.E. reichen.
                              Bei einer Deinstallation werden alle ioBroker infos / states etc gelöscht. Bei einer Reinstallation wird nur der Adaptercode (also alles was via npm kommt) deinstalliert und neu installiert. Die Config u States bleiben erhalten.
                              Bin nur am Handy u kann daher nicht genauer checken. Reinstallation sollte in etwa mit
                              iob update myadapter@1.2.3
                              gehen. Sorry wenn sytax fehlerhaft.
                              Support Repositoryverwaltung.
                              LESEN - gute Forenbeitrage
                                BigMike71
                                #74
                                ok, vielen dank, nun geht auch wieder diag und co :) 👍
                                • B bean
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  #75
                                  @bean said in Wir empfehlen: Node.js 22.x:
                                  Würde mit Erwartungen bei eusec zurüchhaltend sein Brobat hat seit Oktober 2024 keine Aktion mehr auf Github gesetzt ...
                                  • P Offline
                                    Pitpilot
                                    #76
                                    @thomas-braun Ich habe 4 Siemens Instanzen installiert. Die Adapter De-und Reinstallation auf meinem Clone System hat zumindest über die GUI auch nichts verändert. Hat mir jemand Konsolen Befehle?
                                    • mcm1957M mcm1957
                                      #77
                                      @mcm1957 sagte in Wir empfehlen: Node.js 22.x:
                                      Müsste dann
                                      iob upgrade myadapter@1.2.3 sein.
                                      wobei glaube ich auch bei einem de/re-Install die config stehen bleibt. Müsste ich mal ausprobieren.
                                      HomoranH mcm1957M 2 Antworten Letzte Antwort
                                        Müsste dann
                                        #78
                                        @thomas-braun sagte in Wir empfehlen: Node.js 22.x:
                                        aber auf keinen Fall die in den Objekten eingestellten Historisierungs- und andere Optionen
                                        • B BigMike71
                                          #79
                                          Logisch, der user kommt ja nun auch wieder in sein Zuhause rein. :-)
