  4. Test Adapter telegram-menu v.1.6.x
    6.4k
1.9k Beiträge 65 Kommentatoren 987.9k Aufrufe 63 Beobachtet
  • A adarof
    @michael-roling Gern!
    In der Tat steht da ein Error im Log - der zeigt sicher schnell zum Ziel?
    (Äh, wie geht das denn Hübscher als im CodeBlock?)
    telegram-menu.0
    2025-07-08 16:40:14.252	debug	Telegram response : "["{\"error\":{\"XXX\":{\"code\":\"ETELEGRAM\",\"message\":\"ETELEGRAM: 400 Bad Request: message text is empty\"}}}"]"
    telegram-menu.0
    2025-07-08 16:40:14.228	error	There is a problem! Text to send is empty or undefined, please check your configuration.
    telegram-menu.0
    2025-07-08 16:40:14.228	debug	Send to: { user: Henning , chatId :XXX, text: , instance: telegram.0 , userListWithChatID: [{"name":"Henning","chatID":"XXX"}] , parseMode: undefined }
    telegram-menu.0
    2025-07-08 16:40:14.228	debug	No Entry found
    telegram-menu.0
    2025-07-08 16:40:14.227	debug	Groups with searched User: ["TMenu"]
    telegram-menu.0
    2025-07-08 16:40:14.227	debug	Nav : {"StartSide":{"nav":[["Temperaturen","Fensterstatus","Alarme"],["Cmd","Rolladen"]],"text":"chooseAction","parse_mode":false},"Rolladen":{"nav":[["Wohnzimmer","Kueche"],["AZ","DG"],["Zurück"]],"text":"chooseAction","parse_mode":false},"Zurück ":{"nav":[["menu:back"],[""]],"text":"chooseAction","parse_mode":false},"Wohnzimmer":{"nav":[["WZ-Blendschutz","WZ-Osten-Runter"],[""]],"text":"chooseAction","parse_mode":false},"Kueche":{"nav":[["Kueche-Blendschutz","Kueche-Hoch"],[""]],"text":"chooseAction","parse_mode":false},"AZ":{"nav":[["AZRunter","AZHoch"],["AZBlendschutz"]],"text":"chooseAction","parse_mode":false},"Cmd":{"nav":[["WireGuard Restart","Gartenwasser"],[""]],"text":"chooseAction","parse_mode":false},"Gartenwasser":{"nav":[["GartenwasserLang","GartenwasserKurz"],["GartenwasserHochbeet","GartenwasserAus"]],"text":"chooseAction","parse_mode":false},"AZBlendschutz":{"switch":[{"id":"matter.0.controller.3977668824984073934.WindowCovering-1.SET","value":"30","toggle":false,"confirm":"true","returnText":"Blendschutz im AZ gesetzt {novalue}","ack":false,"parse_mode":false}]},"AZHoch":{"switch":[{"id":"matter.0.controller.3977668824984073934.WindowCovering-1.SET","value":"100","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false},{"id":"hm-rpc.1.OEQ0984288.1.LEVEL","value":"100","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"AZRunter":{"switch":[{"id":"hm-rpc.1.OEQ0984288.1.LEVEL","value":"0","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false},{"id":"matter.0.controller.3977668824984073934.WindowCovering-1.SET","value":"0","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"WZ-Blendschutz":{"switch":[{"id":"hm-rpc.1.LEQ1030787.1.LEVEL","value":"70","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"WZ-Osten-Runter":{"switch":[{"id":"hm-rpc.2.00111D8998C5D1.3.LEVEL","value":"0","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"Kueche-Blendschutz":{"switch":[{"id":"hm-rpc.1.NEQ0056118.1.LEVEL","value":"60","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"Kueche-Hoch":{"switch":[{"id":"hm-rpc.1.NEQ0056118.1.LEVEL","value":"100","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false},{"id":"hm-rpc.1.PEQ0007016.1.LEVEL","value":"100","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"Temperaturen":{"switch":[{"id":"javascript.0.scriptEnabled.Telegram.Menu-Temperaturabfrage","value":"true","toggle":false,"confirm":"false","returnText":"ok","ack":false,"parse_mode":true}]},"WireGuard Restart":{"switch":[{"id":"javascript.0.scriptEnabled.Telegram.RestartWG0","value":"true","toggle":false,"confirm":"true","returnText":"Called.","ack":false,"parse_mode":false}]},"GartenwasserAus":{"switch":[{"id":"hm-rpc.1.OEQ1129419.8.PRESS_SHORT","value":"true","toggle":false,"confirm":"true","returnText":"Ok","ack":false,"parse_mode":false}]},"GartenwasserKurz":{"switch":[{"id":"hm-rpc.1.OEQ1129419.7.PRESS_SHORT","value":"true","toggle":false,"confirm":"true","returnText":"Ok","ack":false,"parse_mode":false}]},"GartenwasserLang":{"switch":[{"id":"hm-rpc.1.OEQ1129419.7.PRESS_LONG","value":"true","toggle":false,"confirm":"true","returnText":"Ok","ack":false,"parse_mode":false}]},"GartenwasserHochbeet":{"switch":[{"id":"hm-rpc.1.OEQ1129419.8.PRESS_LONG","value":"true","toggle":false,"confirm":"true","returnText":"Ok","ack":false,"parse_mode":false}]},"Fensterstatus":{"getData":[{"id":"javascript.0.localHausGeschlossenOffeneElementePlain","text":"\\n","newline":"true","parse_mode":"true"}]},"Alarme":{"getData":[{"id":"hm-rega.0.26947","text":"Aktuelle Alarme: ","newline":"true","parse_mode":"false"}]}}
    telegram-menu.0
    2025-07-08 16:40:14.226	debug	Menu : TMenu
    telegram-menu.0
    2025-07-08 16:40:11.951	debug	Telegram response : "["{\"XXX\":153169}"]"
    telegram-menu.0
    2025-07-08 16:40:11.880	debug	Groups with searched User: ["TMenu"]
    telegram-menu.0
    2025-07-08 16:40:11.879	debug	Menu found
    telegram-menu.0
    2025-07-08 16:40:11.878	debug	Return text : chooseAction
    telegram-menu.0
    2025-07-08 16:40:11.877	debug	Send to: { user: Henning , chatId :XXX, text: chooseAction , instance: telegram.0 , userListWithChatID: [{"name":"Henning","chatID":"XXX"}] , parseMode: false }
    telegram-menu.0
    2025-07-08 16:40:11.876	debug	Return text : chooseAction
    telegram-menu.0
    2025-07-08 16:40:11.876	debug	Menu to Send: [["Wohnzimmer","Kueche"],["AZ","DG"],["Zurück"]]
    telegram-menu.0
    2025-07-08 16:40:11.874	debug	Nav : {"StartSide":{"nav":[["Temperaturen","Fensterstatus","Alarme"],["Cmd","Rolladen"]],"text":"chooseAction","parse_mode":false},"Rolladen":{"nav":[["Wohnzimmer","Kueche"],["AZ","DG"],["Zurück"]],"text":"chooseAction","parse_mode":false},"Zurück ":{"nav":[["menu:back"],[""]],"text":"chooseAction","parse_mode":false},"Wohnzimmer":{"nav":[["WZ-Blendschutz","WZ-Osten-Runter"],[""]],"text":"chooseAction","parse_mode":false},"Kueche":{"nav":[["Kueche-Blendschutz","Kueche-Hoch"],[""]],"text":"chooseAction","parse_mode":false},"AZ":{"nav":[["AZRunter","AZHoch"],["AZBlendschutz"]],"text":"chooseAction","parse_mode":false},"Cmd":{"nav":[["WireGuard Restart","Gartenwasser"],[""]],"text":"chooseAction","parse_mode":false},"Gartenwasser":{"nav":[["GartenwasserLang","GartenwasserKurz"],["GartenwasserHochbeet","GartenwasserAus"]],"text":"chooseAction","parse_mode":false},"AZBlendschutz":{"switch":[{"id":"matter.0.controller.3977668824984073934.WindowCovering-1.SET","value":"30","toggle":false,"confirm":"true","returnText":"Blendschutz im AZ gesetzt {novalue}","ack":false,"parse_mode":false}]},"AZHoch":{"switch":[{"id":"matter.0.controller.3977668824984073934.WindowCovering-1.SET","value":"100","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false},{"id":"hm-rpc.1.OEQ0984288.1.LEVEL","value":"100","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"AZRunter":{"switch":[{"id":"hm-rpc.1.OEQ0984288.1.LEVEL","value":"0","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false},{"id":"matter.0.controller.3977668824984073934.WindowCovering-1.SET","value":"0","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"WZ-Blendschutz":{"switch":[{"id":"hm-rpc.1.LEQ1030787.1.LEVEL","value":"70","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"WZ-Osten-Runter":{"switch":[{"id":"hm-rpc.2.00111D8998C5D1.3.LEVEL","value":"0","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"Kueche-Blendschutz":{"switch":[{"id":"hm-rpc.1.NEQ0056118.1.LEVEL","value":"60","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"Kueche-Hoch":{"switch":[{"id":"hm-rpc.1.NEQ0056118.1.LEVEL","value":"100","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false},{"id":"hm-rpc.1.PEQ0007016.1.LEVEL","value":"100","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"Temperaturen":{"switch":[{"id":"javascript.0.scriptEnabled.Telegram.Menu-Temperaturabfrage","value":"true","toggle":false,"confirm":"false","returnText":"ok","ack":false,"parse_mode":true}]},"WireGuard Restart":{"switch":[{"id":"javascript.0.scriptEnabled.Telegram.RestartWG0","value":"true","toggle":false,"confirm":"true","returnText":"Called.","ack":false,"parse_mode":false}]},"GartenwasserAus":{"switch":[{"id":"hm-rpc.1.OEQ1129419.8.PRESS_SHORT","value":"true","toggle":false,"confirm":"true","returnText":"Ok","ack":false,"parse_mode":false}]},"GartenwasserKurz":{"switch":[{"id":"hm-rpc.1.OEQ1129419.7.PRESS_SHORT","value":"true","toggle":false,"confirm":"true","returnText":"Ok","ack":false,"parse_mode":false}]},"GartenwasserLang":{"switch":[{"id":"hm-rpc.1.OEQ1129419.7.PRESS_LONG","value":"true","toggle":false,"confirm":"true","returnText":"Ok","ack":false,"parse_mode":false}]},"GartenwasserHochbeet":{"switch":[{"id":"hm-rpc.1.OEQ1129419.8.PRESS_LONG","value":"true","toggle":false,"confirm":"true","returnText":"Ok","ack":false,"parse_mode":false}]},"Fensterstatus":{"getData":[{"id":"javascript.0.localHausGeschlossenOffeneElementePlain","text":"\\n","newline":"true","parse_mode":"true"}]},"Alarme":{"getData":[{"id":"hm-rega.0.26947","text":"Aktuelle Alarme: ","newline":"true","parse_mode":"false"}]}}
    telegram-menu.0
    2025-07-08 16:40:11.873	debug	Menu : TMenu
    telegram-menu.0
    2025-07-08 16:39:25.157	debug	Telegram response : "["{\"XXX\":153167}"]"
    telegram-menu.0
    2025-07-08 16:39:25.118	debug	Return text : chooseAction
    telegram-menu.0
    2025-07-08 16:39:25.117	debug	Send to: { user: Henning , chatId :XXX, text: chooseAction , instance: telegram.0 , userListWithChatID: [{"name":"Henning","chatID":"XXX"}] , parseMode: false }
    telegram-menu.0
    2025-07-08 16:39:25.117	debug	User list: [{"name":"Henning","chatID":"XX"}]
    telegram-menu.0
    2025-07-08 16:39:25.116	debug	Startside: StartSide
    telegram-menu.0
    2025-07-08 16:39:25.115	debug	MenuList: ["TMenu"]
    telegram-menu.0
    2025-07-08 16:39:25.115	debug	Checkbox: {"sendMenuAfterRestart":true,"resKey":true,"oneTiKey":true,"checkboxNoValueFound":true}
    telegram-menu.0
    2025-07-08 16:39:25.115	debug	Gen. Actions: {"StartSide":{"nav":[["Temperaturen","Fensterstatus","Alarme"],["Cmd","Rolladen"]],"text":"chooseAction","parse_mode":false},"Rolladen":{"nav":[["Wohnzimmer","Kueche"],["AZ","DG"],["Zurück"]],"text":"chooseAction","parse_mode":false},"Zurück ":{"nav":[["menu:back"],[""]],"text":"chooseAction","parse_mode":false},"Wohnzimmer":{"nav":[["WZ-Blendschutz","WZ-Osten-Runter"],[""]],"text":"chooseAction","parse_mode":false},"Kueche":{"nav":[["Kueche-Blendschutz","Kueche-Hoch"],[""]],"text":"chooseAction","parse_mode":false},"AZ":{"nav":[["AZRunter","AZHoch"],["AZBlendschutz"]],"text":"chooseAction","parse_mode":false},"Cmd":{"nav":[["WireGuard Restart","Gartenwasser"],[""]],"text":"chooseAction","parse_mode":false},"Gartenwasser":{"nav":[["GartenwasserLang","GartenwasserKurz"],["GartenwasserHochbeet","GartenwasserAus"]],"text":"chooseAction","parse_mode":false},"AZBlendschutz":{"switch":[{"id":"matter.0.controller.3977668824984073934.WindowCovering-1.SET","value":"30","toggle":false,"confirm":"true","returnText":"Blendschutz im AZ gesetzt {novalue}","ack":false,"parse_mode":false}]},"AZHoch":{"switch":[{"id":"matter.0.controller.3977668824984073934.WindowCovering-1.SET","value":"100","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false},{"id":"hm-rpc.1.OEQ0984288.1.LEVEL","value":"100","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"AZRunter":{"switch":[{"id":"hm-rpc.1.OEQ0984288.1.LEVEL","value":"0","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false},{"id":"matter.0.controller.3977668824984073934.WindowCovering-1.SET","value":"0","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"WZ-Blendschutz":{"switch":[{"id":"hm-rpc.1.LEQ1030787.1.LEVEL","value":"70","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"WZ-Osten-Runter":{"switch":[{"id":"hm-rpc.2.00111D8998C5D1.3.LEVEL","value":"0","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"Kueche-Blendschutz":{"switch":[{"id":"hm-rpc.1.NEQ0056118.1.LEVEL","value":"60","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"Kueche-Hoch":{"switch":[{"id":"hm-rpc.1.NEQ0056118.1.LEVEL","value":"100","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false},{"id":"hm-rpc.1.PEQ0007016.1.LEVEL","value":"100","toggle":false,"confirm":"true","returnText":"ok","ack":false,"parse_mode":false}]},"Temperaturen":{"switch":[{"id":"javascript.0.scriptEnabled.Telegram.Menu-Temperaturabfrage","value":"true","toggle":false,"confirm":"false","returnText":"ok","ack":false,"parse_mode":true}]},"WireGuard Restart":{"switch":[{"id":"javascript.0.scriptEnabled.Telegram.RestartWG0","value":"true","toggle":false,"confirm":"true","returnText":"Called.","ack":false,"parse_mode":false}]},"GartenwasserAus":{"switch":[{"id":"hm-rpc.1.OEQ1129419.8.PRESS_SHORT","value":"true","toggle":false,"confirm":"true","returnText":"Ok","ack":false,"parse_mode":false}]},"GartenwasserKurz":{"switch":[{"id":"hm-rpc.1.OEQ1129419.7.PRESS_SHORT","value":"true","toggle":false,"confirm":"true","returnText":"Ok","ack":false,"parse_mode":false}]},"GartenwasserLang":{"switch":[{"id":"hm-rpc.1.OEQ1129419.7.PRESS_LONG","value":"true","toggle":false,"confirm":"true","returnText":"Ok","ack":false,"parse_mode":false}]},"GartenwasserHochbeet":{"switch":[{"id":"hm-rpc.1.OEQ1129419.8.PRESS_LONG","value":"true","toggle":false,"confirm":"true","returnText":"Ok","ack":false,"parse_mode":false}]},"Fensterstatus":{"getData":[{"id":"javascript.0.localHausGeschlossenOffeneElementePlain","text":"\\n","newline":"true","parse_mode":"true"}]},"Alarme":{"getData":[{"id":"hm-rega.0.26947","text":"Aktuelle Alarme: ","newline":"true","parse_mode":"false"}]}}
    telegram-menu.0
    2025-07-08 16:39:25.115	debug	Array Buttons: [{"call":"StartSide","text":"chooseAction","parse_mode":false,"nav":[["Temperaturen","Fensterstatus","Alarme"],["Cmd","Rolladen"]]},{"call":"Rolladen","text":"chooseAction","parse_mode":false,"nav":[["Wohnzimmer","Kueche"],["AZ","DG"],["Zurück"]]},{"call":"Zurück ","text":"chooseAction","parse_mode":false,"nav":[["menu:back"],[""]]},{"call":"Wohnzimmer","text":"chooseAction","parse_mode":false,"nav":[["WZ-Blendschutz","WZ-Osten-Runter"],[""]]},{"call":"Kueche","text":"chooseAction","parse_mode":false,"nav":[["Kueche-Blendschutz","Kueche-Hoch"],[""]]},{"call":"AZ","text":"chooseAction","parse_mode":false,"nav":[["AZRunter","AZHoch"],["AZBlendschutz"]]},{"call":"Cmd","text":"chooseAction","parse_mode":false,"nav":[["WireGuard Restart","Gartenwasser"],[""]]},{"call":"Gartenwasser","text":"chooseAction","parse_mode":false,"nav":[["GartenwasserLang","GartenwasserKurz"],["GartenwasserHochbeet","GartenwasserAus"]]}]
    telegram-menu.0
    2025-07-08 16:39:25.115	debug	Menu: TMenu
    telegram-menu.0
    2025-07-08 16:39:25.059	info	Telegram was found
    telegram-menu.0
    2025-07-08 16:39:25.054	debug	Telegram Info Connection: {"val":true,"ack":true,"ts":1751943847689,"q":0,"from":"system.adapter.telegram.0","user":"system.user.admin","lc":1751943847689}
    telegram-menu.0
    2025-07-08 16:39:24.945	info	starting. Version 2.4.4 in /opt/iobroker/node_modules/iobroker.telegram-menu, node: v20.19.3, js-controller: 7.0.7
    Michael RolingM Offline
    Michael Roling
    schrieb am zuletzt editiert von Michael Roling
    #1758
    @adarof Schaue mir das an,
    Schau mal nach ob du irgendwo bei Zurück ein Leerzeichen dabei hast. Was kommt im Log wenn du den Zurück Btn drückst?
    Ich werde da mal einen Fix für bauen, aber du weisst dann schon mal wie du den Fehler beheben kannst
    • Michael RolingM Michael Roling
      adarof
      schrieb am zuletzt editiert von adarof
      #1759
      @michael-roling Danke. Ja in der Tat war das das Problem - schwer zu erkennen, aber (wie das nun mal so ist) im Nachhinein logisch.
      Ich hätte erwartet (und wäre vielleicht selber auch noch etwas Richtung Ziel gekommen), dass ich "Eintrag nicht gefunden!" im Telegram als Antwort sehe in diesem Fall sehe - weil das hab ich hier an:
      !!! DANKE !!!
      Michael RolingM 1 Antwort Letzte Antwort
      • A adarof
        !!! DANKE !!!
        Michael Roling
        #1760
        @adarof Vielleicht einmal aus und wieder an machen, evtl ist da auch ein Bug drin und der Wert ist nicht gesetzt
          adarof
          #1761
          @michael-roling Denke eher Bug - Hatte ich schon direkt nach der Installation angeschaltet weil es mir sinnvoll erschien.
          Gerade nochmal neu gestartet: Auch bei einem Klick auf "DG" (das Submenue hab ich ja noch nicht, wie Du oben siehst) bekomme ich diese Meldung nicht.
          Schau mal in Ruhe - ich bin erstmal sehr sehr glücklich, hab ich mir doch vorher mit JavaScripten + text2command-Adapter ziemlich einen abgebrochen.
          Gruss - Henning
          • A adarof
            Gruss - Henning
            Michael Roling
            #1762
            @adarof Also auch da kann ich nur sagen das es bei mir funktioniert, passe mal den Text an und schau ob das eine Änderung bringt
              adarof
              #1763
              @michael-roling Ja, schonwieder richtig - nun bekomm ich die passende Meldung bei "DG":
              (2 !! zusätzlich)
              Okay, das war Insiderwissen und Du weisst, was zu tun ist ;-)
              Gruss - Henning
              • A adarof
                (2 !! zusätzlich)
                Gruss - Henning
                Michael Roling
                #1764
                @adarof top. Ich habe da schon was angepasst.
                System 9S 1 Antwort Letzte Antwort
                  System 9S Offline
                  System 9S Offline
                  System 9
                  #1765
                  Guten Morgen,
                  woran kann das liegen, das ich die Menüs nicht aktivieren kann ?
                  • System 9S System 9
                    Guten Morgen,
                    Michael Roling
                    #1766
                    @system-9 Hast du eine Telegram Instanz eingestellt.
                      System 9S Offline
                      System 9S Offline
                      System 9
                      #1767
                      @michael-roling ja benutzer kann ich auch auswählen und aktivieren
                        Michael Roling
                        #1768
                        @system-9 Kannst du mal ein Screenshot schicken, von dem was nicht geht
                          System 9S Offline
                          System 9S Offline
                          System 9
                          #1769
                          @michael-roling
                          Diesen Haken kann ich nicht aktiv setzen
                            @michael-roling
                            Michael Roling
                            #1770
                            @system-9 das ist dann ein Bug. Aber hast du schon mal probiert den User abzuwählen dann das Menu aktiv setzen und dann wieder den User?
                              System 9S Offline
                              System 9S Offline
                              System 9
                              #1771
                              @michael-roling leider auch ohne Erfolg
                                Michael Roling
                                #1772
                                @system-9 Schaue ich mir jetzt am Wochenende an. Habe mir dazu gestern schon ein Ticket erstellt
                                  mcreuter
                                  #1773
                                  @michael-roling Bei mir auch, einmal abgewählt kann man ihn nur noch über die json / Backup wieder an bekommen.
                                  • M mcreuter
                                    Michael Roling
                                    #1774
                                    @mcreuter @System-9 Bin gerade dabei das Release 3.0.3 zu erstellen, darin ist der Bug behoben
                                      System 9S Offline
                                      System 9S Offline
                                      System 9
                                      #1775
                                      @michael-roling funktioniert perfekt, danke
                                      • TbsJahT Offline
                                        TbsJahT Offline
                                        TbsJah
                                        #1776
                                        Wie kann ich denn bei einem Trigger den Wert eines DP schreiben bestehend aus statischen Text und gedrückten Button?
                                        Hier die Eingabe
                                        14681869-026f-4799-86dc-8eb2db8cc521-image.png 6b5e9e54-183b-4640-a514-12263967ed77-image.png
                                        Hier der Trigger --> && soll idealerweise der Wert vom dynSwitch sein
                                        Ich weiß && ist falsch
                                          Kami
                                          #1777
                                          @tbsjah
                                          Ich denke das sollte {value} sein statt &&, aber ich habe auch grad ein problem damit
