  4. IoBroker mit Warema WMS Web Control
127 Beiträge 26 Kommentatoren 50.5k Aufrufe 18 Beobachtet
  • Marc BergM Offline
    Marc BergM Offline
    Marc Berg
    #113
    @marco-santarelli sagte in IoBroker mit Warema WMS Web Control:
    Hello, is the maintaner of warema-wms-venetian-blinds on NPM reading this thread? While I know I can see it and reverse-engineer it from the node_modules folder, Is it possible for this person to put the code on GitHub, so that we can collaborate on it?
    I have Warema blinds and a weather station at home, as well as the WMS stick and a webcontrol pro, and I became fairly proficient with WMS Studio, so I can help test the integrations and provide bugfixes!
    Hi Marco, did you get any response? I am also interested in further development.
    Marco SantarelliM 1 Antwort Letzte Antwort
    • Marc BergM Marc Berg
      Marco SantarelliM Offline
      Marco Santarelli
      #114
      @marc-berg No response, i reverse-engineered the code from the npm package and modified it myself. You can see how I use it at https://github.com/santam85/addon-warema-wms/tree/main
      • Marco SantarelliM Marco Santarelli
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        #115
        @marco-santarelli
        Yes, that's how I did it too. A fork of your repo and some customisations for my devices. I'm happy with that now.
        https://github.com/Marc-Berg/wms2mqtt
        P 1 Antwort Letzte Antwort
          tweefo
          #116
          Had been using Tombox' adapter working with the Webcontrol pro for a while. However it suddenly stopped working some time ago. Does someone still have it running with pro?
            @marco-santarelli
            PatrickR
            #117
            @marc-berg
            Entschuldige bitte mein Anfängerfrage
            Dein "wms2mqtt" auf Github, sollte dies auch auf HA laufen?
            Ich frage, weil ich die Fehlermeldung beim hinzufügen erhalte, dass es kein gültiges Repository wäre,
            was ggf. an der fehlenden "repository.json" liegt.
            Danke schon mal
            Patrick
            • P PatrickR
              @marc-berg
              Danke schon mal
              Patrick
              Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              #118
              @patrickr sagte in IoBroker mit Warema WMS Web Control:
              Mein Ziel war es, das Image um meine zusätzlichen Gerätetypen zu erweitern und unter einer Docker Umgebung laufen zu lassen. Deshalb habe ich alle HA-Funktionalitäten entfernt, um den Code schlank zu halten.
              Wenn dir die Geräte reichen, die @Marco-Santarelli drin hat, solltest du sein Image nehmen.
                PatrickR
                schrieb am zuletzt editiert von PatrickR
                #119
                @marc-berg
                Danke für Deine schnelle RM.
                Ich hab auch 63, 2A, daher bin ich auf Dein Resp gestossen.
                Hab gerade erst die Chat-Funktion gefunden (what a shame)
                Ich chatte Dich mal an, vermutlich interessiert meine Frage die wenigsten da HA.
                Patrick
                • P PatrickR
                  @marc-berg
                  Patrick
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  #120
                  Um ganz ehrlich zu sein: Mich interessiert HA auch nicht. Deshalb kann ich diesbezüglich auch keinen Support leisten.
                  Wenn du dir selbst was zusammenstricken möchtest, dann musst du neben der index.js auch die Module unter addon-warema-wms/warema-bridge/srv/warema-wms-venetian-blinds anpassen, denn diese übernehmen die eigentliche Kommunikation mit dem WMS Netzwerk. Wegen der von mir entfernen HA-Funktionalität kannst du die Dateien aber nicht 1:1 ersetzen.
                    PatrickR
                    #121
                    @marc-berg Vielen Dank
                    • P PatrickR
                      PatrickR
                      #122
                      @Marc-Berg
                      Hallo Marc,
                      ich mußte bzgl. Wetterstation Pro
                      bei mir im wms-util.js noch einen Wert ändern.
                      Das wäre bei Dir
                      wms2mqtt/warema-bridge/srv/warema-wms-venetian-blinds/wms-util.js
                      Zeile 272
                      params.temp = parseInt(payload.substr(18, 2), 16) / 2 - 35;
                      Ich muß 40 abziehen, um die korrekten Werte zu erhalten.
                      Vergleich mit WMS Stick und WMS studio pro.
                      Patrick
                      PS: Sieh bitte auch meinen Kommentar zum " Squash deduplication #6"
                      Und vielen Dank für das "Implement comprehensive weather data deduplication"
                      • P PatrickR
                        @Marc-Berg
                        Hallo Marc,
                        Das wäre bei Dir
                        Zeile 272
                        Patrick
                        Marc BergM Offline
                        Marc BergM Offline
                        Marc Berg
                        #123
                        Das wäre bei Dir
                        Zeile 272
                        Da hast du Recht, das passt nicht. Habe ich aber auch nur aus der original Library übernommen. Ich verwende die Temperatur der Wetterstation nicht, da bei starker Sonneneinstrahlung gern mal Mondwerte ankommen. Auch in der Warema App wird die Temperatur nicht direkt angezeigt, dem Hersteller ist wohl auch klar, dass man darauf nichts geben kann. Passe ich aber trotzdem bei Gelegenheit mal an.
                        Ich dachte erst, es sei ein Fehler im Code, aber die Wetterstation sendet wirklich ständig doppelt und dreifach. Wahrscheinlich kann ich noch viel mehr Duplikate rausfiltern, auch das schaue ich mir nochmal an.
                          Das wäre bei Dir
                          Zeile 272
                          PatrickR
                          #124
                          @marc-berg sagte in IoBroker mit Warema WMS Web Control:
                          Wo noch ein allgemeines Problem liegt, ist bei den Jalousien, der maximale Winkel welcher wie in meinem Fall auf 80° steht.
                          Und bei der Umrechnung in % muss ich genau diesen maximal Wert als 100% hernehmen, ansonsten verwende ich einen falschen Wert.
                          So ging es mir anfänglich.
                          Da dieser Maximalwert für jeden Actuator unterschiedlich sein kann,
                          gibt es für unterschiedliche Werte auch unterschiedliche Winkelwerte die 100% bedeuten.
                          Man müßte eigentlich für jeden Actuator den maxWert als Berechnungsbasis ablegen und diesen in der Konfiguration übergeben (alles machbar aber mit Aufwand).
                          Was anderes noch.
                          Es gibt bestimmt eine Botschaft um im WMS-Mesh-System die Geräte auf "Abwesend" zu setzen.
                          Ist Dir da etwas bekannt?
                          Danke.
                          Patrick
                          • P PatrickR
                            Was anderes noch.
                            Danke.
                            Patrick
                            Marc BergM Offline
                            Marc BergM Offline
                            Marc Berg
                            #125
                            Da ich keine Jalousien von Warema besitze, kann ich das nicht nachstellen.
                            Nein, keine Ahnung.
                              Nein, keine Ahnung.
                              PatrickR
                              #126
                              @marc-berg
                              ich hab noch für mich eine Anpassung bzgl. Polling gemacht.
                              Wenn ein neues Weather broadcast empfangen wird, wird der
                              der Intervall-Zähler für "Weather polling function" retriggert.
                              ///////////// index.js : Info
                              //Neu: Info
                              let weatherInterval;
                              //Neu: Info
                              function retriggerWeatherPolling() {
                              if (weatherInterval) {
                              clearInterval(weatherInterval);
                              weatherInterval = setInterval(pollWeatherData, pollingInterval);
                              log.fkt_log_info('046:Restarted weather data polling every ' + pollingInterval + ' ms');
                              //Änderung : Info
                              // Start weather polling with configurable interval
                              log.fkt_log_info('045:Started weather data polling every ' + pollingInterval + ' ms');
                              //Neu: Info
                              //function callback(err, msg)
                              /////case 'wms-vb-rcv-weather-broadcast':
                              ///////if (!cachedWeather || cachedWeather.hash !== weatherHash || (currentTime - cachedWeather.timestamp) > minTimeDiff) {
                              /////////if (typeof client !== 'undefined' && client.connected) {
                              retriggerWeatherPolling();
                              Patrick
                              • P PatrickR
                                @marc-berg
                                //Neu: Info
                                //Neu: Info
                                //Änderung : Info
                                //Neu: Info
                                Patrick
                                PatrickR
                                #127
                                @Marc-Berg
                                Noch eine Änderung des "weatherBroadcast" für meinen batteriebetrieben Temperatursensor "65".
                                       case '7080':
                                            msgType = 'weatherBroadcast';
                                            params.unknown_1 = payload.substr(0, 2);
                                            params.wind = parseInt(payload.substr(2, 2), 16) / 2;                  // 2025-06-28 PatrickR68 added / 2
                                            params.lumen = payload.substr(4, 2) === '00' ? parseInt(payload.substr(12, 2), 16) * 2 : parseInt(payload.substr(4, 2), 16) * parseInt(payload.substr(12, 2), 16) * 2;
                                            params.unknown_2 = payload.substr(6, 6);
                                            params.batt = parseInt(payload.substr(14, 2), 16) / 2;                // 2025-08-24 PatrickR68 0.99.111 Battery in V
                                            params.rain = payload.substr(16, 2) === 'C8';
                                            params.temp = parseInt(payload.substr(18, 2), 16) / 2 - 40;           // 2025-07-02 PatrickR68 changed 35->40 (range -40..87,5)
                                            params.temp_in = parseInt(payload.substr(20, 2), 16) / 2 - 40;        // 2025-08-24 PatrickR68 0.99.111 indoor °C
                                            params.unknown_4 = payload.substr(22,4);
                                            params.humidity = parseInt(payload.substr(26, 2), 16) / 2;            // 2025-08-24 PatrickR68 0.99.111 Humidity in %
                                            params.unknown_5 = payload.substr(28,34);
                                            params.temp_target_in = parseInt(payload.substr(62, 2), 16) / 2 - 40; // 2025-08-24 PatrickR68 0.99.111 indoor target °C
                                            params.unknown_6 = payload.substr(64,2);                              // 2025-08-24 PatrickR68 0.99.111
                                            break;
