[Gelöst] Kein Zugriff auf Weboberfläche nach Update
Das Update hat nur teilweise geklappt denke ich:
root@raspberrypi:/opt/iobroker# sudo iobroker update
Used repository: default
! /opt/iobroker/node_modules/iobroker.js-controller/node_modules/request/node_modules/hawk/node_modules/boom/lib/index.js:5
const Hoek = require('hoek');
SyntaxError: Use of const in strict mode.
at Module._compile (module.js:439:25)
at Object.Module._extensions..js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Module.require (module.js:364:17)
at require (module.js:380:17)
at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/request/node_modules/hawk/lib/index.js:5:33)
at Module._compile (module.js:456:26)
root@raspberrypi:/opt/iobroker# sudo iobroker upgrade self
Host "raspberrypi" is up to date.</anonymous>beim Log steht nun : >! ```` 2018-02-02 17:45:39.058 - info: cloud.0 system.adapter.admin.0: logging false 2018-02-02 17:45:39.060 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 8 (node.js: Cannot find module) 2018-02-02 17:45:39.062 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled 2018-02-02 17:45:39.064 - info: tankerkoenig.0 system.adapter.admin.0: logging false 2018-02-02 17:45:39.070 - info: javascript.0 system.adapter.admin.0: logging false 2018-02-02 17:45:39.088 - info: web.0 system.adapter.admin.0: logging false >! ```` -
Ich bekomme leider immer noch eine Fehlermeldung im Log:
2018-02-02 19:18:21.667 - info: history.0 starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.histo ry, node: v0.10.22 2018-02-02 19:18:21.960 - info: hm-rpc.0 system.adapter.admin.0: logging false 2018-02-02 19:18:21.968 - info: hm-rpc.1 system.adapter.admin.0: logging false 2018-02-02 19:18:21.971 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 8 (node .js: Cannot find module) 2018-02-02 19:18:21.966 - info: hm-rega.0 system.adapter.admin.0: logging false 2018-02-02 19:18:21.980 - info: fritzbox.0 system.adapter.admin.0: logging false 2018-02-02 19:18:21.977 - info: ical.0 system.adapter.admin.0: logging false 2018-02-02 19:18:21.975 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled 2018-02-02 19:18:22.494 - info: history.0 enabled logging of hm-rega.0.11555 ! -
npm-v
-bash: npm-v: command not found
node -v
v0.10.22
nodejs -v
-bash: nodejs: command not found
error: host.raspberrypi instance system.adapter.admin.0 terminated with code 8 (node.js: Cannot find module)scheint node.js & npm zu fehlen.
Aber das log… ist bestimmt nicht vollständig
Ist das ein PI3 ?
Wenn ja und nur bei PI3 mal das machen: WENN kein PI3, welche HW benutzt du?
apt-get --purge remove node apt-get --purge remove nodejs apt-get autoremove rebootcurl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash - sudo apt-get install -y build-essential python nodejs rebootwenn es danach noch nicht geht :
cd /opt/iobroker sudo ./reinstall.sh -
ja, das Log ist nicht vollständig, hier wiederholt sich aber auch alles, so wie ich es sehe.
Es handelt sich um einen PI2, gibt es dafür andere Befehle?
Hier also mal ein größerer Ausschnitt:
2018-02-02 19:27:46.986 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 8 (node.js: Cannot find module) 2018-02-02 19:27:46.991 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled 2018-02-02 19:27:46.998 - info: javascript.0 system.adapter.admin.0: logging false 2018-02-02 19:28:17.021 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 14074 2018-02-02 19:28:20.075 - info: hm-rpc.0 system.adapter.admin.0: logging false 2018-02-02 19:28:20.078 - info: hm-rega.0 system.adapter.admin.0: logging false 2018-02-02 19:28:20.081 - info: hm-rpc.1 system.adapter.admin.0: logging false 2018-02-02 19:28:20.086 - info: text2command.0 system.adapter.admin.0: logging false 2018-02-02 19:28:20.089 - info: scenes.0 system.adapter.admin.0: logging false 2018-02-02 19:28:20.090 - info: cloud.0 system.adapter.admin.0: logging false 2018-02-02 19:28:20.091 - info: fritzbox.0 system.adapter.admin.0: logging false 2018-02-02 19:28:20.093 - info: history.0 system.adapter.admin.0: logging false 2018-02-02 19:28:20.096 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 8 (node.js: Cannot find module) 2018-02-02 19:28:20.097 - info: web.0 system.adapter.admin.0: logging false 2018-02-02 19:28:20.098 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled 2018-02-02 19:28:20.105 - info: javascript.0 system.adapter.admin.0: logging false 2018-02-02 19:28:50.152 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 14076 2018-02-02 19:28:53.196 - info: hm-rpc.0 system.adapter.admin.0: logging false 2018-02-02 19:28:53.198 - info: hm-rpc.1 system.adapter.admin.0: logging false 2018-02-02 19:28:53.200 - info: hm-rega.0 system.adapter.admin.0: logging false 2018-02-02 19:28:53.204 - info: history.0 system.adapter.admin.0: logging false 2018-02-02 19:28:53.207 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 8 (node.js: Cannot find module) 2018-02-02 19:28:53.208 - info: cloud.0 system.adapter.admin.0: logging false 2018-02-02 19:28:53.210 - info: text2command.0 system.adapter.admin.0: logging false 2018-02-02 19:28:53.212 - info: web.0 system.adapter.admin.0: logging false 2018-02-02 19:28:53.213 - info: scenes.0 system.adapter.admin.0: logging false 2018-02-02 19:28:53.200 - info: fritzbox.0 system.adapter.admin.0: logging false 2018-02-02 19:28:53.210 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled 2018-02-02 19:28:53.220 - info: javascript.0 system.adapter.admin.0: logging false ! -
npm-v
-bash: npm-v: command not found `
Versuche es mal mit einem Leerzeichen nach dem „npm“.node -v
v0.10.22 `
Reichlich alt.Wie hast Du installiert?
Fertiges Image?
Selber installiert (nach welcher Anleitung)?
Gruß,
Eric
Von unterwegs getippert
Oh, das hab ich übersehen :oops:
npm -v
1.3.14
Oh, lange her. Die Installation habe ich nach der Anleitung von der iobroker Seite gemacht.
VIELEN DANK!
Das Update hat tatsächlich geholfen.
curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash - sudo apt-get install -y build-essential python nodejs reboot iobroker startNun hab ich folgende Versionen:
npm 3.10.10 node v6.12.3 nodejs v6.12.3Nun läuft alles und ich habe auch die Weboberfläche wieder.
Ihr seid die Besten :!:
