  4. mihome vacuum - login failed
    6.1k
loginmihomevacuum
51 Beiträge 9 Kommentatoren 5.7k Aufrufe 11 Beobachtet
  • D dirkhe
    @thomas-braun bitte noch mal neu von github holen, ich hatte da noch ein bug drin. hatte das ja alles neu geschrieben....
    @dirkhe
    Nope. Get devices geht noch nicht.
    2025-07-24 19:59:42.943  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c68956882748fffffffffffffffffffffffffffffffff
    2025-07-24 19:59:42.943  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
    2025-07-24 19:59:52.947  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827499ffffffffffffffffffffffffffffffff
    2025-07-24 19:59:52.947  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
    2025-07-24 20:00:02.950  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c6895688274a3ffffffffffffffffffffffffffffffff
    2025-07-24 20:00:02.951  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
    2025-07-24 20:00:07.909  - debug: mihome-vacuum.0 (1462) discover__{}
    2025-07-24 20:00:12.954  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c6895688274adffffffffffffffffffffffffffffffff
    2025-07-24 20:00:12.955  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
    2025-07-24 20:00:22.329  - debug: mihome-vacuum.0 (1462) get params for stock Vacuum
    2025-07-24 20:00:22.330  - debug: mihome-vacuum.0 (1462) Message= {"id":142,"method":"get_status"}
    2025-07-24 20:00:22.339  - debug: mihome-vacuum.0 (1462) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":1051,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":142}
    2025-07-24 20:00:22.340  - debug: mihome-vacuum.0 (1462) setGetStatus {"msg_ver":8,"msg_seq":1051,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
    2025-07-24 20:00:22.342  - debug: mihome-vacuum.0 (1462) Message= {"id":143,"method":"get_network_info"}
    2025-07-24 20:00:22.350  - debug: mihome-vacuum.0 (1462) MIIO RECIVE: {"result":"unknown_method","id":143}
    2025-07-24 20:00:22.351  - debug: mihome-vacuum.0 (1462) Message= {"id":144,"method":"get_sound_volume"}
    2025-07-24 20:00:22.361  - debug: mihome-vacuum.0 (1462) MIIO RECIVE: {"result":[90],"id":144}
    2025-07-24 20:00:24.956  - debug: mihome-vacuum.0 (1462) Helo message Timeout
      @dirkhe
      dirkhe
      @thomas-braun gib mal bitte die passenden Logzeilen, die sind in dem Auschnitt nicht drin
      Thomas BraunT Eduard77E 4 Antworten Letzte Antwort
      • D dirkhe
        @dirkhe
        Da ist auch nicht mehr. get devices geklickt um 20:40:23.105
        2025-07-24 20:40:08.922  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e09ffffffffffffffffffffffffffffffff
        2025-07-24 20:40:08.922  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
        2025-07-24 20:40:18.926  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e13ffffffffffffffffffffffffffffffff
        2025-07-24 20:40:18.927  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
        2025-07-24 20:40:23.105  - debug: mihome-vacuum.0 (1462) discover__{}
        2025-07-24 20:40:28.930  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e1dffffffffffffffffffffffffffffffff
        2025-07-24 20:40:28.931  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
        2025-07-24 20:40:38.934  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e27ffffffffffffffffffffffffffffffff
        2025-07-24 20:40:38.935  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
        • D dirkhe
          @dirkhe
          Ah! Nochmal neugestartet, jetzt funktioniert es!
          • D dirkhe
            @dirkhe
            Hi!
            Die Version aus 'latest' funktioniert nicht:
            2025-07-25 11:52:30.448  - info: mihome-vacuum.0 (59185) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v24.4.1, js-controller: 7.0.7
            2025-07-25 11:53:41.089  - debug: mihome-vacuum.0 (59185) CloudApi-Login gestartet…
            2025-07-25 11:53:41.090  - debug: mihome-vacuum.0 (59185) CloudApi-CloudApi-Step 1: Getting sign token
            2025-07-25 11:53:41.229  - debug: mihome-vacuum.0 (59185) CloudApi-Step 2: Authenticating user
            2025-07-25 11:53:41.327  - error: mihome-vacuum.0 (59185) CloudApi-Login failed, because no captcha resolving possible
            2025-07-25 11:53:41.328  - info: mihome-vacuum.0 (59185) discover Login failed, because no captcha resolving possible
              @dirkhe
              Hi!
              dirkhe
              @thomas-braun tja, sieht so aus, als wenn jetzt ganz viele Anfragen über diesen Weg gekommen sind, so dass der Server da jetzt die captcha Frage stellt. Ich fürchte, da können wir jetzt nichts machen, zumindest habe ich keine Idee mehr
              • D dirkhe
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                @dirkhe sagte in mihome vacuum - login failed:
                Danke für die Info.
                Vielleicht kann ja jemand helfen?
                @apollon77
                @mcm1957
                Ich meine hier schon mal gelesen zu haben, dass jemand captcha im Adapter schon umgesetzt hatte.
                Weiß aber nicht mehr wo und wer.
                mfg
                Dieter
                Danke.
                • bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  zur Info:
                  @apollon77 hat im issue geantwortet.
                  Anbei:
                  Danke.
                  • bahnuhrB bahnuhr
                    Danke für die Info.
                    @apollon77
                    @mcm1957
                    mfg
                    Dieter
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    @bahnuhr sagte in mihome vacuum - login failed:
                    Jetzt weiß ich es wieder.
                    War beim bmw Adapter.
                    Vielleicht geht ja sowas hier auch.
                    Danke.
                    • bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      im issue wurde vermerkt, dass wohl oauth2 angesagt ist.
                      Jetzt muss dies "nur" noch umgesetzt werden.
                      Anbei nochmal link zum issue (wer nachlesen möchte).
                      https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/1063
                      Danke.
                      • bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        Rückinfo von mir:
                        Nach Neustart von iob und dann halt auch der Adapter kommt im log:
                        mihome-vacuum.0
                        2025-08-01 16:23:39.601	info	IOT disabled, delete state
                        mihome-vacuum.0
                        2025-08-01 16:23:39.521	info	starting. Version 5.2.0 (non-npm: iobroker-community-adapters/ioBroker.mihome-vacuum) in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v20.19.4, js-controller: 7.0.6
                        Folglich; der Adapter wird nicht mehr grün und funktioniert bei mir nun gar nicht mehr.
                        Danke.
                        • D dirkhe
                          Eduard77E Offline
                          Eduard77E Offline
                          Eduard77
                          @dirkhe
                          nun hat jetzt auch micht erwischt.
                          Ich habe 2 Instanzen.
                          Die Instanz 1 mit Roborock S5 funktioniert noch.
                          Bei der 2. mit Roborock Q8 habe ich gerade festgestellt, dass die Karte seit letzter Woche nicht mehr aktualiesiert wird.
                          Nach dem ich die Roborock Q8 Instanz neu gestartet habe, bekomme ich folgendes im LOG.
                          mihome-vacuum.1 2025-08-06 14:12:04.767	info	Got terminate signal TERMINATE_YOURSELF
                          mihome-vacuum.1 2025-08-06 14:11:52.128	info	discover Login failed
                          mihome-vacuum.1 2025-08-06 14:11:38.127	info	discover Login failed
                          mihome-vacuum.1 2025-08-06 14:10:51.788	info	discover Login failed
                          mihome-vacuum.1 2025-08-06 14:10:17.767	info	discover Login failed
                          mihome-vacuum.1 2025-08-06 14:09:27.868	info	create state for carpet_mode
                          mihome-vacuum.1 2025-08-06 14:09:27.093	info	create states for dust collecting
                          mihome-vacuum.1 2025-08-06 14:09:27.091	info	create states for dock status
                          mihome-vacuum.1 2025-08-06 14:09:27.048	info	create states for mop mode
                          mihome-vacuum.1 2025-08-06 14:09:27.035	info	change states from State control.fan_power mihome-vacuum.1.rooms.161001076339.roomFanPower
                          mihome-vacuum.1 2025-08-06 14:09:27.035	info	change states from State control.fan_power mihome-vacuum.1.rooms.161001076338.roomFanPower
                          mihome-vacuum.1 2025-08-06 14:09:27.034	info	change states from State control.fan_power mihome-vacuum.1.rooms.161001022185.roomFanPower
                          mihome-vacuum.1 2025-08-06 14:09:27.034	info	change states from State control.fan_power mihome-vacuum.1.rooms.161001003117.roomFanPower
                          mihome-vacuum.1 2025-08-06 14:09:27.015	info	create states for water box mode
                          mihome-vacuum.1 2025-08-06 14:09:27.012	info	create states for water box
                          mihome-vacuum.1 2025-08-06 14:09:27.011	info	change states from State control.fan_power
                          mihome-vacuum.1 2025-08-06 14:09:27.010	info	create states for mop
                          mihome-vacuum.1 2025-08-06 14:09:26.818	warn	Login failed
                          mihome-vacuum.1 2025-08-06 14:09:24.934	info	settest next timer: not available
                          mihome-vacuum.1 2025-08-06 14:09:24.369	info	select standard vacuum protocol....
                          mihome-vacuum.1 2025-08-06 14:09:24.245	info	IOT disabled, delete state
                          mihome-vacuum.1 2025-08-06 14:09:24.180	info	starting. Version 5.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v20.19.4, js-controller: 7.0.6
                          mihome-vacuum.1 2025-08-06 14:09:19.302	info	terminating
                          mihome-vacuum.1 2025-08-06 14:09:18.801	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          mihome-vacuum.1 2025-08-06 14:09:18.801	info	terminating
                          mihome-vacuum.1 2025-08-06 14:09:18.801	error	Socket Close
                          Interessanter weise, obwohl die instanz Login Fehler anzeigt, kann ich den Q8 steuern/starten.
                          Eduard
                            dirkhe
                            @eduard77 solange du den token hast, ist alles gut. Nur die karte geht halt nicht
                            • D dirkhe
                              schneidy76
                              @dirkhe Von mir als Hinweis:
                              Man kann sich den Token mit dem Tool aus git holen.
                              Bei mir, Windows 11, gab es hier aber richtig Probleme mit dem Tool.
                              Es wird von Windows als "potentiell gefährlich" eingestuft. Dies bedeutet, einmal gestartet, dann -trotz Erlaubnis nicht ausgeführt und gelöscht. Danach kann man es nicht mehr so einfach downloaden.
                              Ich habe es vor! dem Ausführen dann hinbekommen, die Datei als "sicher" zu kennzeichnen.
                              In Folge lies es sich ausführen. Mit den Daten konnte ich nun auch den Roboter wieder über ioBroker steuern...
                              VG Torsten
                              Raspberry Matic (RP3), LIVE PV Monitoring mit Smartmeter, Poolsteuerung mit NodeRed, KNX Ausbau (ersetzt stückweise HM & klassische Installation), ioBroker Multihost (RP4 &RP2), Visu mit VIS
                              • bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                @dirkhe
                                hat auf git
                                mitgeteilt, dass er den Umbau auf oauto2 nicht vornehmen wird.
                                Schade auch, damit ist der super Adapter nur mit dem Tool (token holen) lauffähig.
                                Die Karte wird zukünftig nicht mehr funktionieren.
                                Äußerst schade.
                                Danke.
                                • mcm1957M Offline
                                  mcm1957M Offline
                                  mcm1957
                                  Dazu wäre allerdings zu ergänzen, dass auch @Apollon77 festgehalten hat dass hier eine Umstellung auf oauth2 nicht sinnvoll gehen wird, da kein bekanntes Verfahren existiert mit dem das Captcha handling implementiert werden kann. Es macht lt. Apollon77 derzeit keinen Sinn hier Aufwand für oath2 zu setzen. Und persönlich glaube ich, dass Apollon77 ein wenig Erfahrung angesammelt hat :-)
                                  Insofern führt dies zwar zum selben Ergebnis aber die zukünftigen Einschränkungen sind nach derzeitigem Wissensstan nicht auf Unwillen von @Dirkhe zurückzuführen wie es im Vorposting möglicherweise durchklingen könnte.
                                  Abgesehen davon steht es jedermann/frau frei einen PR beizusteuern falls jemand eine Lösung hat.
                                  Support Repositoryverwaltung.
                                  LESEN - gute Forenbeitrage
