  5. [gelöst] exec-Baustein will nicht ausführen
    6.4k
40 Beiträge 5 Kommentatoren 3.9k Aufrufe 4 Beobachtet
    @meister-mopper
    Trag da mal
    ssh thomas@pihole6 /bin/bash << EOF
    sudo systemctl restart pihole-FTL.service
    EOF
    ein.
    Meister MopperM Online
    Meister Mopper
    @thomas-braun sagte in exec-Baustein will nicht ausführen:
    @meister-mopper
    Trag da mal
    EOF
    ein.
    Funktioniert leider nicht. Habe es gerade gecheckt:
    thomas@pihole6:~$ systemctl status pihole-FTL.service
    ● pihole-FTL.service - Pi-hole FTL
         Loaded: loaded (/etc/systemd/system/pihole-FTL.service; enabled; preset: enabled)
         Active: active (running) since Tue 2025-07-22 16:57:46 CEST; 31min ago
        Process: 9946 ExecStartPre=/opt/pihole/pihole-FTL-prestart.sh (code=exited, status=0/SUCCESS)
       Main PID: 9960 (pihole-FTL)
          Tasks: 16 (limit: 38112)
         Memory: 33.2M
            CPU: 35.554s
         CGroup: /system.slice/pihole-FTL.service
                 └─9960 /usr/bin/pihole-FTL -f
    Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.762 CEST [9960M] INFO: FTL user: pihole
    Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.762 CEST [9960M] INFO: Compiled for linux/amd64 (compiled>
    Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.767 CEST [9960M] INFO: Wrote config file:
    Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.767 CEST [9960M] INFO:  - 155 total entries
    Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.767 CEST [9960M] INFO:  - 141 entries are default
    Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.767 CEST [9960M] INFO:  - 14 entries are modified
    Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.767 CEST [9960M] INFO:  - 0 entries are forced through en>
    Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.769 CEST [9960M] INFO: Parsed config file /etc/pihole/pih>
    Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.769 CEST [9960M] INFO: PID file does not exist or not rea>
    Jul 22 16:57:48 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.769 CEST [9960M] INFO: No other running FTL process found.
    lines 1-21/21 (END)
    Die Uhrzeit ist vom letzten restart.
    Proxmox und HA ...
    Thomas BraunT OliverIOO 2 Antworten Letzte Antwort
      @meister-mopper
      Trag da mal
      EOF
      ein.
           Memory: 33.2M
              CPU: 35.554s
      lines 1-21/21 (END)
      @meister-mopper
      Von hier:
      https://stackoverflow.com/questions/4412238/what-is-the-cleanest-way-to-ssh-and-run-multiple-commands-in-bash
      Erst als Skript anlegen.
      #!/bin/bash
      Dann dieses Skript in die secure shell kippen.
      ssh thomas@pihole6 'bash -s' < /pfad/zum/skript.sh
        @oliverio sagte in exec-Baustein will nicht ausführen:
        so kann man sich als iobroker anmelden:
        Der host pihole6 kennt aber doch keinen user iobroker, dort gibt es nur den user thomas, oder begehe ich da einen Denkfehler?
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @meister-mopper
        der befehl in blockly-exec wird als user iobroker auf deinem lokalen system ausgeführt.
        das gilt für jeden befehl. oft wurden von den leuten schon für ihren user dinge verändert, was für den user iobroker nicht gilt.
        bspw wenn user iobroker kein ssh kann/darf, der hauptbenutzer ist in der admingruppe, iobroker evtl nicht
        Nachtrag:
        sudo funktioniert erstmal so ja nicht, da du automatisiert kein passwort eingeben kannst. wenn dann musst du auf dem entfernten system dem user thomas die sudoers berechtigung geben und den befehl in die datei /etc/sudoer eintragen, so das er den befehl ohne passwort ausführen darf
        bitte den artikel sorgfältig lesen
        https://wiki.ubuntuusers.de/sudo/Konfiguration/
        eine falsche bearbeitung der datei (immer das tool visudo verwenden)
        kann zur nichtbenutzbarkeit des systems führen.
        beispiele kann man auf einem iobroker system hier sehen
        /etc/sudoers.d/iobroker
        Meine Adapter und Widgets
        Links im Profil
        • OliverIOO OliverIO
          @meister-mopper
          Nachtrag:
          Stimmt, hatte ich jetzt gar nicht dran gedacht. Möglich, dass der user 'iobroker' kein ssh aufstoßen darf.
            @meister-mopper
            Trag da mal
            EOF
            ein.
                 Memory: 33.2M
                    CPU: 35.554s
            lines 1-21/21 (END)
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @meister-mopper
            ich würde bei der fehlersuche stufenweise vorgehen
            1. lokaler user iobroker darf ssh
            2. verbindung zum anderen rechner funktioniert
            3. user darf auf entferntem rechner sudo befehle ausführen
            4. erst jetzt: entfernter user darf den systemctl befehl
            gern auch mal mit anderen befehlen wie bspw echo "abc" probieren um extra fehlerquellen erst einmal auszuschließen
            Links im Profil
              @meister-mopper
              Nachtrag:
              Nachtrag:
              Wenn des (wie ich vermute) um RaspberryOS geht braucht es das so auch nicht. Da kann jeder aus der Gruppe 'sudo' alles ohne Einschränkung ausführen. Nicht die beste Voreinstellung, ist aber da erstmal so.
                Nachtrag:
                Meister Mopper
                Nachtrag:
                Nein, hier besteht dieses Problem bei virtualisierten Maschinen in Proxmox.
                Proxmox und HA ...
                  Nachtrag:
                  @meister-mopper sagte in exec-Baustein will nicht ausführen:
                  Dann musst du dich zunächst mit den Rechten der einzelnen user auf den jeweiligen Kisten auseinandersetzen.
                    Nachtrag:
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @meister-mopper
                    hast du den ein Ergebnis bei der Ausführung von ssh als nutzer iobroker?
                    die folgenden befehle auf deiner shell mit deinem hauptbenutzer der reihe nach ausführen (also jede zeile einzeln)
                    sudo -u iobroker bash
                    ssh thomas@pihole6 sudo systemctl restart pihole-FTL.service
                    oder
                    ssh thomas@pihole6 systemctl restart pihole-FTL.service
                    Links im Profil
                      @meister-mopper
                      Meister Mopper
                      schrieb am zuletzt editiert von Meister Mopper
                      @oliverio
                      @Thomas-Braun
                      ssh kann der user iobroker schonmal, dann muss ich nur noch das login mit ssh-key einrichten.
                      thomas@iobroker:~$ sudo -u iobroker ssh thomas@pihole6
                      The authenticity of host 'pihole6 (192.168.1.21)' can't be established.
                      ED25519 key fingerprint is SHA256:n+ueMb2fbs2S6jZFGTbCgMgD2Uj0BFD4AT+TNIoGFbc.
                      This key is not known by any other names.
                      Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
                      Warning: Permanently added 'pihole6' (ED25519) to the list of known hosts.
                      thomas@pihole6's password:
                      Linux pihole6 6.8.12-12-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-12 (2025-07-14T13:20Z) x86_64
                      permitted by applicable law.
                      Last login: Tue Jul 22 17:53:16 2025 from 192.168.178.10
                      thomas@pihole6:~$
                      Ich probiere mal ...
                      Proxmox und HA ...
                        @oliverio
                        @Thomas-Braun
                        thomas@pihole6:~$
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @meister-mopper
                        wenn du als iobroker angemeldet bis
                        den keygen durchgeführt hast
                        kannst du mit dem befehl
                        ssh-copy-id
                        sehr einfach den pub key auf deinen entfernten rechner übertragen
                        https://wiki.ubuntuusers.de/SSH/#Public-Key-Authentifizierung
                        Links im Profil
                          @meister-mopper
                          ssh-copy-id
                          Meister Mopper
                          @oliverio
                          Erste Maßnahme:
                          thomas@iobroker:/home/iobroker$ sudo -u iobroker ssh-keygen -t rsa
                          Generating public/private rsa key pair.
                          Enter file in which to save the key (/home/iobroker/.ssh/id_rsa):
                          Enter passphrase (empty for no passphrase):
                          Enter same passphrase again:
                          Your identification has been saved in /home/iobroker/.ssh/id_rsa
                          Your public key has been saved in /home/iobroker/.ssh/id_rsa.pub
                          The key fingerprint is:
                          SHA256:Wl7sPLw9frJgzqC8L9i6Q1xN/Q8qA49etraNxLrhn1Q iobroker@iobroker
                          The key's randomart image is:
                          +---[RSA 3072]----+
                          |       o   .     |
                          |      o ..  o    |
                          |   . . +S E. o   |
                          |    o .=**.   .  |
                          |   . +oo*+B      |
                          |    oo+*oO =o .  |
                          |    o+BB*.=.+=   |
                          +----[SHA256]-----+
                          Zweite Maßnahme:
                          thomas@iobroker:/home/iobroker$ sudo -u iobroker ls -lah .ssh
                          insgesamt 24K
                          drwx------ 2 iobroker iobroker 4,0K 22. Jul 18:09 .
                          drwxr-xr-x 7 iobroker iobroker 4,0K 22. Jul 17:59 ..
                          -rw------- 1 iobroker iobroker 2,6K 22. Jul 18:09 id_rsa
                          -rw-r--r-- 1 iobroker iobroker  571 22. Jul 18:09 id_rsa.pub
                          -rw------- 1 iobroker iobroker  978 22. Jul 17:59 known_hosts
                          -rw-r--r-- 1 iobroker iobroker  142 22. Jul 17:59 known_hosts.old
                          Dritte Maßnahme (eigentlich auch logisch):
                          thomas@iobroker:/home/iobroker$ sudo -u iobroker cat ~/.ssh/id_rsa.pub | ssh thomas@pihole6 'cat >> .ssh/authorized_keys
                          cat: /home/thomas/.ssh/id_rsa.pub: Keine Berechtigung
                          Proxmox und HA ...
                            @oliverio
                            Erste Maßnahme:
                            +---[RSA 3072]----+
                            |       o   .     |
                            |      o ..  o    |
                            |   . . +S E. o   |
                            |    o .=**.   .  |
                            |   . +oo*+B      |
                            |    oo+*oO =o .  |
                            |    o+BB*.=.+=   |
                            +----[SHA256]-----+
                            Zweite Maßnahme:
                            insgesamt 24K
                            Meister Mopper
                            Muss ich jetzt doch auf dem Zielsystem einen user iobroker einrichten?
                            Proxmox und HA ...
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              nein
                              gibt es das .ssh verzeichnis für den user thomas auf dem entfernten rechner
                              /home/thomas/.ssh/
                              Links im Profil
                                nein
                                /home/thomas/.ssh/
                                Meister Mopper
                                nein
                                /home/thomas/.ssh/
                                Ja
                                thomas@pihole6:~$ ls -lah ~/.ssh
                                insgesamt 14K
                                drwxr-xr-x 2 thomas thomas    3 21. Jul 10:54 .
                                drwx------ 5 thomas thomas   14 22. Jul 17:58 ..
                                -rw-r--r-- 1 thomas thomas 1,2K 21. Jul 10:54 authorized_keys
                                Proxmox und HA ...
                                  nein
                                  /home/thomas/.ssh/
                                  Ja
                                  insgesamt 14K
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  @meister-mopper
                                  probiere mal diesen befehl
                                  cat id_rsa.pub | ssh user@server 'cat>> ~/.ssh/authorized_keys'
                                  hm sieht eigentlich gleich aus. ich dachte die anführungsstriche fehlen
                                  probier mal auf dem entfernten system als user thomas sowas
                                  touch ~/ssh/test.txt
                                  wenn das auch fehlschlägt, hat user thomas auf dem system noch ein berechtigungsproblem für den ordner .ssh oder die datei authoreized keys
                                  Links im Profil
                                    @meister-mopper
                                    Meister Mopper
                                    @meister-mopper
                                    Wo muss ich da als welcher user stehen?
                                    Proxmox und HA ...
                                      @meister-mopper
                                      OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      @meister-mopper
                                      wie gesagt du machst das immer integriert
                                      ich mach immer vorab so
                                      sudo -u iobroker
                                      cat ~/.ssh/id_rsa.pub | ssh thomas@pihole6 'cat>> ~/.ssh/authorized_keys'
                                      dann steht am prompt auch
                                      sowas
                                      iobroker@iobroker
                                      Links im Profil
                                        @meister-mopper
                                        sudo -u iobroker
                                        sowas
                                        iobroker@iobroker
                                        Meister Mopper
                                        @meister-mopper
                                        sudo -u iobroker
                                        sowas
                                        iobroker@iobroker
                                        Hier kommt aber sowas :man-shrugging:
                                        usage: sudo -h | -K | -k | -V
                                        usage: sudo -v [-ABkNnS] [-g group] [-h host] [-p prompt] [-u user]
                                        usage: sudo -l [-ABkNnS] [-g group] [-h host] [-p prompt] [-U user] [-u user] [command [arg ...]]
                                        usage: sudo [-ABbEHkNnPS] [-r role] [-t type] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory]
                                                    [-T timeout] [-u user] [VAR=value] [-i | -s] [command [arg ...]]
                                        usage: sudo -e [-ABkNnS] [-r role] [-t type] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory]
                                                    [-T timeout] [-u user] file ...
                                        Proxmox und HA ...
                                          @meister-mopper
                                          sudo -u iobroker
                                          sowas
                                          iobroker@iobroker
                                          OliverIOO Offline
                                          OliverIOO Offline
                                          OliverIO
                                          @meister-mopper sagte in [exec-Baustein will nicht ausführen]
                                          sorry da fehlte bash
                                          Links im Profil
