  4. Mal wieder zerschossen
    1.0k
    6.1k
iobroker stoppt nicht
17 Beiträge 6 Kommentatoren 2.0k Aufrufe 6 Beobachtet
  • wendy2702W wendy2702
    @chaot
    curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
    ChaotC Offline
    ChaotC Offline
    Chaot
    @wendy2702
    Ach so:
    ```bash
    Script v.2025-03-08
    *** BASE SYSTEM ***
       Static hostname: ioBroker
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Ubuntu 20.04.6 LTS
                Kernel: Linux 6.5.13-5-pve
          Architecture: x86-64
    OS is similar to: debian
    model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     14:31:19 up 21 min,  1 user,  load average: 2.76, 2.58, 3.74
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Ubuntu Release codenamed 'focal' reached its END OF LIFE and needs to be updated to the latest LTS release 'noble' NOW!
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-07-21 14:31:19 CEST
               Universal time: Mon 2025-07-21 12:31:19 UTC
                     RTC time: n/a
                  NTP service: n/a
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    haus
    HOME=/home/haus
    GROUPS=haus iobroker
    iobroker
    [sudo] password for haus:
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev redis
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           6.1G        3.1G        2.1G        1.0M        971M        3.1G
    Swap:          2.0G          0B        2.0G
    Total:         8.2G        3.1G        4.1G
    Active iob-Instances:   35
             6144 M total memory
             3076 M used memory
             3188 M active memory
              708 M inactive memory
             2096 M free memory
                0 M buffer memory
              971 M swap cache
             2048 M total swap
                0 M used swap
             2048 M free swap
    top - 14:31:25 up 21 min,  1 user,  load average: 3.16, 2.68, 3.76
    Tasks:  69 total,   1 running,  68 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 28.8 us,  9.1 sy,  0.0 ni, 59.1 id,  0.0 wa,  0.0 hi,  3.0 si,  0.0 st
    MiB Mem :   6144.0 total,   2096.1 free,   3076.6 used,    971.3 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   3065.8 avail Mem
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * apparmor.service loaded failed failed Load AppArmor profiles
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--110--disk--0 ext4    32G   25G  5.5G  82% /
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs  1.6G  1.6M  1.6G   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs  1.6G     0  1.6G   0% /run/user/1001
    [Mon Jul 21 14:02:20 2025] EXT4-fs (dm-1): mounted filesystem 15679eb9-5ea6-43b8-b91c-29a0ecca7019 ro with ordered data mode. Quota mode: none.
    [Mon Jul 21 14:02:21 2025] EXT4-fs (dm-1): re-mounted 15679eb9-5ea6-43b8-b91c-29a0ecca7019 r/w. Quota mode: none.
    [Mon Jul 21 14:02:22 2025] EXT4-fs (sdb): mounting ext3 file system using the ext4 subsystem
    [Mon Jul 21 14:02:22 2025] EXT4-fs (sdb): mounted filesystem 72a49e33-105a-4582-a31c-1bbff15e30ec r/w with ordered data mode. Quota mode: none.
    [Mon Jul 21 14:02:47 2025] EXT4-fs (loop0): mounted filesystem f7913bd0-bee5-42e9-83c6-edb24bba20bc r/w with ordered data mode. Quota mode: none.
    [Mon Jul 21 14:02:54 2025] EXT4-fs (dm-12): mounted filesystem 32a22a38-9374-43d2-a490-0d49504c12c9 r/w with ordered data mode. Quota mode: none.
    [Mon Jul 21 14:03:10 2025] EXT4-fs (dm-10): mounted filesystem 1c6095f9-366b-4331-a231-4ac8e949c392 r/w with ordered data mode. Quota mode: none.
    [Mon Jul 21 14:03:17 2025] EXT4-fs (dm-6): mounted filesystem be54090e-144d-414f-a0ac-f457653d388a r/w with ordered data mode. Quota mode: none.
    [Mon Jul 21 14:03:46 2025] EXT4-fs (loop1): warning: mounting fs with errors, running e2fsck is recommended
    [Mon Jul 21 14:03:46 2025] EXT4-fs (loop1): mounted filesystem 110cdcbd-660a-4f4d-99bb-0dd7d2fffa88 r/w with ordered data mode. Quota mode: none.
    [Mon Jul 21 14:03:59 2025] EXT4-fs (dm-15): mounted filesystem 32e87d66-9df5-4bc2-99c5-f006705424bb r/w with ordered data mode. Quota mode: none.
    [Mon Jul 21 14:08:51 2025] EXT4-fs (loop1): error count since last fsck: 2
    [Mon Jul 21 14:08:51 2025] EXT4-fs (loop1): initial error at time 1666345607: ext4_check_bdev_write_error:217
    [Mon Jul 21 14:08:51 2025] EXT4-fs (loop1): last error at time 1666426664: ext4_journal_check_start:83
    [Mon Jul 21 14:09:38 2025] EXT4-fs (dm-12): unmounting filesystem 32a22a38-9374-43d2-a490-0d49504c12c9.
    [Mon Jul 21 14:09:41 2025] EXT4-fs (dm-12): mounted filesystem 32a22a38-9374-43d2-a490-0d49504c12c9 r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET                    SOURCE                           FSTYPE     OPTIONS
    /                         /dev/mapper/pve-vm--110--disk--0 ext4       rw,relatime,stripe=16
    |-/proc/cpuinfo           lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/diskstats         lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/loadavg           lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/meminfo           lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/slabinfo          lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/stat              lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/swaps             lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/uptime            lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys/devices/system/cpu lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    3.8G    /var/
    3.2G    /var/log/journal/db91a8d9813048b3b0d9627361bf92a2
    3.2G    /var/log
    431M    /var/lib
    Archived and active journals take up 752.0M in the file system.
    /opt/iobroker/backups:
    267M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.2G    /opt/iobroker/iobroker-data/
    1018M   /opt/iobroker/iobroker-data/history
    888M    /opt/iobroker/iobroker-data/files
    299M    /opt/iobroker/iobroker-data/files/vis
    291M    /opt/iobroker/iobroker-data/files/vis/widgets
    43M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/vis/widgets/vis-2-widgets-jaeger-design/static/js/vendors-node_modules_iobroker_adapter-react-v5_build_index_js.0424abce.chunk.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    21M     /opt/iobroker/iobroker-data/objects.json.migrated
    21M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.3
    /usr/bin/node           v20.19.3
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.32.0
    nodejs:
      Installed: 20.19.3-1nodesource1
      Candidate: 20.19.3-1nodesource1
      Version table:
     *** 20.19.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         10.19.0~dfsg-3ubuntu1.6 500
            500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
            500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
         10.19.0~dfsg-3ubuntu1 500
            500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    Temp directories causing deletion problem: 4
    Some problems detected, please run iob fix
    Errors in npm tree: 0
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Hosts:
    ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 1313)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.1
    javascript:     9.0.7
    nodejs modules from github:     3
    +-- iobroker.icons-open-icon-library-png@0.1.3 invalid: "https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master" from the root project
    | `-- kodi-ws@2.4.4 invalid: "git+https://git@github.com/iobroker-community-adapters/kodi-ws.git" from node_modules/iobroker.kodi
    | +-- samsungtv@0.0.0 invalid: "https://git@github.com/luca-saggese/samsungtv" from node_modules/iobroker.samsung
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : ioBroker                                 - disabled, port: 80, bind: 0.0.0.0, run as: admin
      system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : ioBroker                                 - disabled
      system.adapter.alexa2.0                 : alexa2                : ioBroker                                 - disabled
      system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
    + system.adapter.bosch-ebike.0            : bosch-ebike           : ioBroker                                 -  enabled
      system.adapter.cameras.0                : cameras               : ioBroker                                 - disabled, port: 8200, bind: 127.0.0.1
      system.adapter.cloud.0                  : cloud                 : ioBroker                                 - disabled
      system.adapter.countdown.0              : countdown             : ioBroker                                 - disabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 - disabled
      system.adapter.devices.0                : devices               : ioBroker                                 - disabled
      system.adapter.discovery.0              : discovery             : ioBroker                                 - disabled
    + system.adapter.drag-indicator.0         : drag-indicator        : ioBroker                                 -  enabled
      system.adapter.drops-weather.0          : drops-weather         : ioBroker                                 - disabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
      system.adapter.email.0                  : email                 : ioBroker                                 - disabled
    + system.adapter.ems-esp.0                : ems-esp               : ioBroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
    + system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 -  enabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker                                 -  enabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
    + system.adapter.hoover.0                 : hoover                : ioBroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.8                   : ical                  : ioBroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
    + system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
      system.adapter.kodi.0                   : kodi                  : ioBroker                                 - disabled, port: 9090
      system.adapter.linux-control.0          : linux-control         : ioBroker                                 - disabled
      system.adapter.logparser.0              : logparser             : ioBroker                                 - disabled
      system.adapter.matter.0                 : matter                : ioBroker                                 - disabled
      system.adapter.mpd.0                    : mpd                   : ioBroker                                 - disabled, port: 6600
      system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 - disabled, port: 1500, bind: 0.0.0.0
    + system.adapter.mytime.0                 : mytime                : ioBroker                                 -  enabled
    + system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
    + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
      system.adapter.odl.0                    : odl                   : ioBroker                                 -  enabled
      system.adapter.onvif.0                  : onvif                 : ioBroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
      system.adapter.parcel.0                 : parcel                : ioBroker                                 - disabled
      system.adapter.phantomjs.0              : phantomjs             : ioBroker                                 - disabled
    + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
      system.adapter.proxy.0                  : proxy                 : ioBroker                                 - disabled
    + system.adapter.remeha-home.0            : remeha-home           : ioBroker                                 -  enabled
    + system.adapter.reolink.0                : reolink               : ioBroker                                 -  enabled
      system.adapter.rickshaw.0               : rickshaw              : ioBroker                                 - disabled
      system.adapter.rssfeed.0                : rssfeed               : ioBroker                                 - disabled
      system.adapter.scenes.0                 : scenes                : ioBroker                                 - disabled
      system.adapter.schoolfree.0             : schoolfree            : ioBroker                                 -  enabled
    + system.adapter.smartcontrol.0           : smartcontrol          : ioBroker                                 -  enabled
      system.adapter.socketio.0               : socketio              : ioBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1500, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
    + system.adapter.statistics.0             : statistics            : ioBroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.time-switch.0            : time-switch           : ioBroker                                 - disabled
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
      system.adapter.upnp.0                   : upnp                  : ioBroker                                 - disabled
      system.adapter.uv-protect.0             : uv-protect            : ioBroker                                 - disabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 - disabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBroker                                 - disabled
      system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 - disabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      system.adapter.wallpanel.0              : wallpanel             : ioBroker                                 - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 - disabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
    + system.adapter.wiegand-tcpip.0          : wiegand-tcpip         : ioBroker                                 -  enabled, port: 60000, bind: 0.0.0.0
    + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
    + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'live-default'     │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
    │ 3       │ 'live-latest'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
    Active repo(s): live-latest
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: live-latest
    Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common//../node_modules/iobroker.lgtv/io-package.json: /opt/iobroker/node_modules/iobroker.lgtv/io-package.json: Expected double-quoted property name in JSON at position 10582
    Adapter    "admin"        : 7.7.1    , installed 7.7.1
    Adapter    "alexa-timer-vis": 2.1.1  , installed 2.1.1
    Adapter    "alexa2"       : 3.27.3   , installed 3.26.7 [Updatable]
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.4  [Updatable]
    Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
    Adapter    "bosch-ebike"  : 0.1.12   , installed 0.1.12
    Adapter    "cameras"      : 2.1.2    , installed 2.1.2
    Adapter    "countdown"    : 3.0.0    , installed 3.0.0
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "devices"      : 1.2.7    , installed 1.2.7
    Adapter    "drag-indicator": 2.4.0   , installed 2.4.0
    Adapter    "drops-weather": 1.2.7    , installed 1.2.6  [Updatable]
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "ems-esp"      : 6.0.0    , installed 6.0.0
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
    Adapter    "heatingcontrol": 2.12.15 , installed 2.12.15
    Adapter    "hoover"       : 0.1.4    , installed 0.1.4
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "javascript"   : 9.0.8    , installed 9.0.7  [Updatable]
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "kodi"         : 3.1.0    , installed 3.1.0
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "matter"       : 0.5.1    , installed 0.5.1
    Adapter    "mpd"          : 2.2.0    , installed 2.2.0
    Adapter    "mytime"       : 1.4.4    , installed 1.4.4
    Adapter    "nina"         : 0.0.26   , installed 0.0.26
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "odl"          : 5.0.0    , installed 5.0.0
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "parcel"       : 0.2.10   , installed 0.2.10
    Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "remeha-home"  : 1.0.7    , installed 1.0.7
    Adapter    "reolink"      : 1.2.3    , installed 1.2.2  [Updatable]
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "rssfeed"      : 3.5.2    , installed 3.5.2
    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
    Adapter    "scenes"       : 4.0.3    , installed 4.0.2  [Updatable]
    Adapter    "schoolfree"   : 1.1.10   , installed 1.1.10
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "statistics"   : 4.0.0    , installed 4.0.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
    Adapter    "trashschedule": 4.0.1    , installed 4.0.0  [Updatable]
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "tvprogram"    : 4.0.0    , installed 4.0.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "uv-protect"   : 0.6.7    , installed 0.6.7
    Adapter    "virtualpowermeter": 1.5.0, installed 1.5.0
    Adapter    "vis-2"        : 2.12.12  , installed 2.12.10 [Updatable]
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 2.0.1, installed 1.1.1 [Updatable]
    Adapter    "vis-2-widgets-jaeger-design": 1.4.7, installed 1.4.4 [Updatable]
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-2-widgets-sweethome3d": 0.2.0, installed 0.2.0
    Adapter    "vis-icontwo"  : 1.12.0   , installed 1.12.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
    Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.9    , installed 7.0.9
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wiegand-tcpip": 0.4.7    , installed 0.4.7
    Adapter    "wled"         : 0.7.3    , installed 0.7.3
    Adapter    "ws"           : 3.0.19   , installed 3.0.19
    Objects and States
    Objects:        32962
    States:         32247
    Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu focal-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 15
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      109        90878      186/redis-server 0.
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        91333      96/systemd-resolved
    tcp        0      0 0.0.0.0:1500            0.0.0.0:*               LISTEN      1000       97850      631/io.sonoff.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       93573      199/iobroker.js-con
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          89805      382/master
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          91691      271/smbd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          91048      196/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          88523      1/init
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          91692      271/smbd
    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       128122     1386/io.ws.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       124270     1116/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       94564      399/io.admin.0
    tcp6       0      0 ::1:6379                :::*                    LISTEN      109        90879      186/redis-server 0.
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          89806      382/master
    tcp6       0      0 :::445                  :::*                    LISTEN      0          91689      271/smbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          89733      196/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          88527      1/init
    tcp6       0      0 :::139                  :::*                    LISTEN      0          91690      271/smbd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       119509     1278/io.wled.0
    udp        0      0 192.168.8.50:5353       0.0.0.0:*                           1000       98964      620/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        89714      155/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       124196     915/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       124197     915/io.tuya.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        91332      96/systemd-resolved
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          88524      1/init
    udp        0      0 192.168.8.50:123        0.0.0.0:*                           0          92363      191/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          92361      191/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          92357      191/ntpd
    udp        0      0 192.168.8.255:137       0.0.0.0:*                           0          92408      160/nmbd
    udp        0      0 192.168.8.50:137        0.0.0.0:*                           0          92407      160/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          92395      160/nmbd
    udp        0      0 192.168.8.255:138       0.0.0.0:*                           0          92410      160/nmbd
    udp        0      0 192.168.8.50:138        0.0.0.0:*                           0          92409      160/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          92396      160/nmbd
    udp        0      0 0.0.0.0:42134           0.0.0.0:*                           108        89716      155/avahi-daemon: r
    udp        0      0 0.0.0.0:60001           0.0.0.0:*                           1000       113256     901/io.wiegand-tcpi
    udp6       0      0 :::5353                 :::*                                108        89715      155/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          88530      1/init
    udp6       0      0 fe80::88d5:5eff:fea:123 :::*                                0          92367      191/ntpd
    udp6       0      0 ::1:123                 :::*                                0          92365      191/ntpd
    udp6       0      0 :::123                  :::*                                0          92354      191/ntpd
    udp6       0      0 :::41998                :::*                                108        89717      155/avahi-daemon: r
    2025-07-21 14:08:47.945  - error: host.ioBroker Caught by controller[0]:     at StateRedisClient.getState (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:872:26)
    2025-07-21 14:08:47.945  - error: host.ioBroker Caught by controller[0]:     at AdapterClass._getForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9161:33)
    2025-07-21 14:08:47.946  - error: host.ioBroker Caught by controller[0]:     at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2336:17
    2025-07-21 14:08:49.635  - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-07-21 14:08:49.636  - error: host.ioBroker Caught by controller[0]: Error: DB closed
    2025-07-21 14:08:49.636  - error: host.ioBroker Caught by controller[0]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-07-21 14:08:49.637  - error: host.ioBroker Caught by controller[0]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-07-21 14:08:49.638  - error: host.ioBroker Caught by controller[0]:     at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-07-21 14:08:49.638  - error: host.ioBroker Caught by controller[0]:     at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-07-21 14:08:49.639  - error: host.ioBroker Caught by controller[0]:     at processImmediate (node:internal/timers:485:21)
    2025-07-21 14:08:54.753  - error: birthdays.0 (1164) Cannot check object existence of "birthdays.0.month.01": Connection is closed.
    2025-07-21 14:09:31.900  - error: heatingcontrol.0 (1600) exception in CreateDatapoints [Error: DB closed]
    2025-07-21 14:09:31.923  - error: heatingcontrol.0 (1600) exception in SetDefaults [Error: DB closed]
    2025-07-21 14:09:31.928  - error: heatingcontrol.0 (1600) exception in  main [Error: DB closed]
    2025-07-21 14:09:32.784  - error: influxdb.0 (1611) Error on "subscribeForeignStates": DB closed
    2025-07-21 14:12:06.237  - error: hoover.0 (886) Missing step4 url
    2025-07-21 14:12:06.245  - error: hoover.0 (886) "\r\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\" \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\"><html xmlns=\"http://www.w3.org/1999/xhtml\" style=\"visibility: visible;\" lang=de xml:lang=de><head><meta name=\"viewport\" content=\"initial-scale=1.0\"/><title>Ändern Sie Ihr Kennwort. | SmartHome</title><meta name=\"format-detection\" content=\"telephone=no\" /><link href=\"/sCSS/64.0/sprites/1748341653000/Theme3/de/base/common.css\" rel=\"stylesheet\" type=\"text/css\"/><link href=\"/sCSS/64.0/sprites/1748341653000/Theme3/de/base/elements.css\" rel=\"stylesheet\" type=\"text/css\"/><link href=\"/sCSS/64.0/sprites/1748341653000/Theme3/de/base/extended.css\" rel=\"stylesheet\" type=\"text/css\"/><link href=\"/sCSS/64.0/sprites/1748341653000/Theme3/de/base/ChatterViralInviteSignup.css\" rel=\"stylesheet\" type=\"text/css\"/><link rel=\"stylesheet\" type=\"text/css\" href=\"/css/sfdc_210.css?v=5\" /><style type=\"text/css\">a{color:#0070d2;}body{background-color:#B1BAC1;}#content,.container{background-color:#ffffff;}#header{color:#51606E;}#header,#footer{color:#000000;}.primary,.primary:hover,.primary:focus{background-color:#1797C0;}.primary{color:#FFFFFF;}.primary{border:#1797C0;}.detailRow .message{width:100%;}.requiredInput{width: auto;}div#content .labelCol,div#content .data2Col{min-height: 30px; padding-top:0px; padding-bottom:15px;vertical-align: top;} body .bEditBlock .pbBottomButtons{border-top: 0px;padding-top:0px;margin-top:0px;} .pbSubheader, .mainTitle{display:none;} div.bDescription, div#content .data2Col {font-size: 95%;} .pageTitle{font-weight: bold;}.detailList, .detailList tr{display:block;width:230px;overflow:hidden;}.labelCol, .data2Col{clear:both;}.detailList td{display:block;}#editPage .pbSubsection{padding:0px;}div#content .labelCol, div#content .data2Col{min-height:10px;padding-bottom:0px;}.detailList tr{padding-top:10px;}.pbTitle{display:none;}p{text-align:initial;text-align:start;}body .btn{color:#fff;}input.primary{width:auto;padding:5px;height:auto;}input{border: 1px solid #cccccc; border-radius: 3px; height: 20px; width: 200px; font-size: 14px;}</style><script type=\"text/javascript\"></script><script src=\"/jslibrary/1743001299256/sfdc/main.js\"></script><script src=\"/jslibrary/jslabels/1752874325000/de.js\"></script><script src=\"/jslibrary/1729010880256/sfdc/ChangePassword.js\"></script><script src=\"/jslibrary/1729717492256/sfdc/Setup.js\"></script><script></script></head><body onload=\"this.bodyOnLoad&&bodyOnLoad();\" onunload=\"this.bodyOnUnload&&bodyOnUnload();\"><div id=\"main\"><div id=\"wrapper\"><div id=\"logo_wrapper\" class=\"standard_logo_wrapper mb24\"><div style=\"height: 100%; display: table-cell; vertical-align: bottom;\"><img aria-hidden=\"true\" id=\"logo\" class=\"standard_logo\" src=\"/servlet/servlet.ImageServer?id=0154O0000074vxd&amp;oid=00DU0000000Lkcq&amp;lastMod=1581701911000\" alt=\"SmartHome\" border=\"0\" name=\"logo\">                    <span class=\"zen-assistiveText\">SmartHome</span></div></div><h2 id=\"header\" class=\"mb12\">Ändern Sie Ihr Kennwort.</h2><div id=\"content\"><form  accept-charset=\"UTF-8\" action=\"/_ui/system/security/ChangePassword?setupid=ChangePassword\" autocomplete=\"off\" enctype=\"application/x-www-form-urlencoded\" id=\"editPage\" method=\"post\" name=\"editPage\" onsubmit=\"if (window.ffInAlert) { return false; }\" ><input type=\"hidden\" name=\"_CONFIRMATIONTOKEN\" id=\"_CONFIRMATIONTOKEN\" value=\"VmpFPSxNakF5TlMwd055MHlORlF4TWpveE1qb3dOaTR4T1RoYSxKU3hJTVVIRU5ONlB6UEJFbTY3MDZqdmQ5bU5TTHNTTGpaQmg3RDl0TXFRPSxZelU0T1RnNA==\" /><input type=\"hidden\" name=\"cancelURL\" id=\"cancelURL\" value=\"/setup/secur/RemoteAccessAuthorizationPage.apexp?source=CAAAAZgyDEjRMDAwMDAwMDAwMDAwMDAwAAABAC292TBIIZdwgLpFNr4Q_61rihjaRjwhAXX5Jv7YmClM7C7ZWsOkXtgBET4mh1dXYbkFE__-aVNuGx1YBJNkFMpa3SwchD123C56f8VWIOYaQPAj31TPeY9j0gYf1-2enh6w3s4l0eoE9BazDETkvc4-8T-oi0chdbkbXqhw0Pi6Z0NfQxasXkhI6_-dslWEuyOPzl6Zqaxgx28O5Dw6JXPMehbcmQT87vpTqFrJ_7G0IJSRDLCbm3tO38UT9hxrDM1I72g3zRp0QymtWI_Joi7Hyzqn1rZA6j1GHvekeB49LfB9X4EL8S-m-dYsZeEuHn7RBJyILpPTdxj4ofpnby9E3jnds4l55I36EG7-5a-LCK_FuPJU13EI5s2c53bUY9gytSYp2y5Ku_hR2tCx4XbrOECYBKk952ByCPa8j6JzgHhbGTl2GpUP2ZgszSTQnSe4zB-ylzM7U_efp7adZ3iWL7UtAAwW8WQVduq0LkWiXitiz9WA2Ay4OKZcxQK3S3TMJEiEBwUMgwutFlXt_2nwrht-bIj2FOP4UQFCkmRueXC3iHs9-LXg6Utie5jB8uxE7NNAC0jO6DAAc_doEPGC5IoJKLiivxa17jnUV1-pCwCgHEHFKEfMzcySgx6xg7C8FWoP_LGqzfvKiSJy_1ldmaFZeoze69Nd8jRwHrI_PXMgdvNUTPpx43fcvg-95udV_INZGU-qsuRjE2NRYrNPE1K1brJogTWtsAOy4qU30Vb0o5SXLMOuqmjmTgd8zg==\" /><input type=\"hidden\" name=\"retURL\" id=\"retURL\" value=\"/setup/secur/RemoteAccessAuthorizationPage.apexp?source=CAAAAZgyDEjRMDAwMDAwMDAwMDAwMDAwAAABAC292TBIIZdwgLpFNr4Q_61rihjaRjwhAXX5Jv7YmClM7C7ZWsOkXtgBET4mh1dXYbkFE__-aVNuGx1YBJNkFMpa3SwchD123C56f8VWIOYaQPAj31TPeY9j0gYf1-2enh6w3s4l0eoE9BazDETkvc4-8T-oi0chdbkbXqhw0Pi6Z0NfQxasXkhI6_-dslWEuyOPzl6Zqaxgx28O5Dw6JXPMehbcmQT87vpTqFrJ_7G0IJSRDLCbm3tO38UT9hxrDM1I72g3zRp0QymtWI_Joi7Hyzqn1rZA6j1GHvekeB49LfB9X4EL8S-m-dYsZeEuHn7RBJyILpPTdxj4ofpnby9E3jnds4l55I36EG7-5a-LCK_FuPJU13EI5s2c53bUY9gytSYp2y5Ku_hR2tCx4XbrOECYBKk952ByCPa8j6JzgHhbGTl2GpUP2ZgszSTQnSe4zB-ylzM7U_efp7adZ3iWL7UtAAwW8WQVduq0LkWiXitiz9WA2Ay4OKZcxQK3S3TMJEiEBwUMgwutFlXt_2nwrht-bIj2FOP4UQFCkmRueXC3iHs9-LXg6Utie5jB8uxE7NNAC0jO6DAAc_doEPGC5IoJKLiivxa17jnUV1-pCwCgHEHFKEfMzcySgx6xg7C8FWoP_LGqzfvKiSJy_1ldmaFZeoze69Nd8jRwHrI_PXMgdvNUTPpx43fcvg-95udV_INZGU-qsuRjE2NRYrNPE1K1brJogTWtsAOy4qU30Vb0o5SXLMOuqmjmTgd8zg==\" /><input type=\"hidden\" name=\"save_new_url\" id=\"save_new_url\" value=\"/_ui/system/security/ChangePassword?fromFrontdoor=1&amp;retURL=%2Fsetup%2Fsecur%2FRemoteAccessAuthorizationPage.apexp%3Fsource%3DCAAAAZgyDEjRMDAwMDAwMDAwMDAwMDAwAAABAC292TBIIZdwgLpFNr4Q_61rihjaRjwhAXX5Jv7YmClM7C7ZWsOkXtgBET4mh1dXYbkFE__-aVNuGx1YBJNkFMpa3SwchD123C56f8VWIOYaQPAj31TPeY9j0gYf1-2enh6w3s4l0eoE9BazDETkvc4-8T-oi0chdbkbXqhw0Pi6Z0NfQxasXkhI6_-dslWEuyOPzl6Zqaxgx28O5Dw6JXPMehbcmQT87vpTqFrJ_7G0IJSRDLCbm3tO38UT9hxrDM1I72g3zRp0QymtWI_Joi7Hyzqn1rZA6j1GHvekeB49LfB9X4EL8S-m-dYsZeEuHn7RBJyILpPTdxj4ofpnby9E3jnds4l55I36EG7-5a-LCK_FuPJU13EI5s2c53bUY9gytSYp2y5Ku_hR2tCx4XbrOECYBKk952ByCPa8j6JzgHhbGTl2GpUP2ZgszSTQnSe4zB-ylzM7U_efp7adZ3iWL7UtAAwW8WQVduq0LkWiXitiz9WA2Ay4OKZcxQK3S3TMJEiEBwUMgwutFlXt_2nwrht-bIj2FOP4UQFCkmRueXC3iHs9-LXg6Utie5jB8uxE7NNAC0jO6DAAc_doEPGC5IoJKLiivxa17jnUV1-pCwCgHEHFKEfMzcySgx6xg7C8FWoP_LGqzfvKiSJy_1ldmaFZeoze69Nd8jRwHrI_PXMgdvNUTPpx43fcvg-95udV_INZGU-qsuRjE2NRYrNPE1K1brJogTWtsAOy4qU30Vb0o5SXLMOuqmjmTgd8zg%3D%3D&amp;setupid=ChangePassword\" /><input type=\"hidden\" name=\"setupid\" id=\"setupid\" value=\"ChangePassword\" />\n\n<script>\n    var changePassword;\n\n    Sfdc.onload(function() {\n        changePassword = new Identity.ChangePasswordRequirements({\n            length: 8,\n            letters: false,\n            numbers: true,\n            upper: true,\n            lower: true,\n            special: false,\n            anythreeconditions: false\n        });\n    });\n</script>\n<div class=\"setup change-password\">\n<p class=\"mb16\" id=\"pwdintro\">Geben Sie ein neues Kennwort für <span class=\"important\">bernhard3008@gmail.com</span> ein.<span> </span>\n            Schließen Sie mindestens Folgendes ein:</p>\n        <ul class=\"passwordul mb16\">\n            <li class=\"mb8\">\n        <img src=\"/img/iconCheckDisabled.png\" class=\"passwordicon\" alt=\"Entspricht Anforderungen nicht\" id=\"charcounticon\">\n        <span id=\"charcount\">\n            8 Zeichen</span>\n    </li>\n<li class=\"mb8\">\n        <img src=\"/img/iconCheckDisabled.png\" class=\"passwordicon\" alt=\"Entspricht Anforderungen nicht\" id=\"uppericon\">\n        <span id=\"upper\">\n            1 Großbuchstabe</span>\n    </li>\n<li class=\"mb8\">\n        <img src=\"/img/iconCheckDisabled.png\" class=\"passwordicon\" alt=\"Entspricht Anforderungen nicht\" id=\"lowericon\">\n        <span id=\"lower\">\n            1 Kleinbuchstabe</span>\n    </li>\n<li class=\"mb8\">\n        <img src=\"/img/iconCheckDisabled.png\" class=\"passwordicon\" alt=\"Entspricht Anforderungen nicht\" id=\"numbersicon\">\n        <span id=\"numbers\">\n            1 Zahl</span>\n    </li>\n</ul>\n\n<label for=\"newpassword\" class=\"altLabel\"><span class=\"required\">*</span>&nbsp;Neues Kennwort</label>\n<div class=\"password-wrapper\">\n    <input class=\"password-input input wide mt8 mb16 password\" type=\"password\" name=\"newpassword\" aria-required=\"true\" aria-describedby=\"newpassword-message\" user-scalable=\"no\" id=\"newpassword\" autofocus>\n    <span id=\"newpassword-message\" aria-live=\"polite\" class=\"password-message\"></span>\n</div>\n\n<label for=\"confirmpassword\" class=\"altLabel\"><span class=\"required\">*</span>&nbsp;Neues Kennwort bestätigen</label>\n<div class=\"password-wrapper\">\n    <input class=\"password-input input wide mt8 mb16 password\" type=\"password\" name=\"confirmpassword\" aria-required=\"true\" aria-describedby=\"confirmpassword-message\" user-scalable=\"no\" id=\"confirmpassword\">\n    <span id=\"confirmpassword-message\" aria-live=\"polite\" class=\"password-message\"></span>\n</div>\n\n<div class=\"mb16 mt8 small\">\n    <span class=\"required\">*</span>= erforderlich</div>\n\n\n<input name=\"fromFrontdoor\" id=\"fromFrontdoor\" type=\"hidden\" value=\"1\"/><div class=\"wide\">\n        <!--[if IE 7]>\n        <button id=\"password-button\" class=\"button wide mb16\" name=\"save\" type=\"submit\">\n            Kennwort ändern</button>\n<![endif]-->\n<![if !(IE 7)|!IE]>\n        <button id=\"password-button\" class=\"button wide mb16\" name=\"save\">\n            Kennwort ändern</button>\n<![endif]>\n    </div>\n<p class=\"small\">Kennwort wurde am 15.08.2023, 13:06 zuletzt geändert.</p></div>\n<div id=\"pwcaps\" class=\"mb16\" style=\"display:none\" aria-live=\"assertive\"><img id=\"pwcapsicon\" alt=\"Feststelltaste ist aktiviert.\" width=\"12\" src=\"/img/icon/capslock_blue.png\"/> Feststelltaste ist aktiviert.</div>\n</form></div></div></div><div id=\"footer\">&copy; 2025 Candy Hoover Group Srl. Alle Rechte vorbehalten.</div><script>var p=document.getElementById('footer').parentNode;while(p.nodeName.toLowerCase()==='div'){p.style.height='100%';p=p.parentNode;}</script>\n\n\n<!-- Body events -->\n<script type=\"text/javascript\">function bodyOnLoad(){if (typeof(startSessionTimer)!='undefined') {startSessionTimer(); };if(window.PreferenceBits){window.PreferenceBits.prototype.csrfToken=\"VmpFPSxNakF5TlMwd055MHlORlF4TWpveE1qb3dOaTR5TVRGYSxUczk3U3V5RTdEeDRvVjNEWDRPM3dHTE1WSFp3OFM0Z1M3ZS1EUHdINk00PSxNR1V3WmpRdw==\";};}function bodyOnBeforeUnload(){}function bodyOnFocus(){}function bodyOnUnload(){}</script></body></html>"
    2025-07-21 14:12:56.268  - error: sourceanalytix.0 (1256) Check settings for sonoff.0.Zaehler.SML_Actual_pow ! Known valueAtDeviceReset : (31.784) > known cumulative value (31.738) cannot proceed
    2025-07-21 14:12:56.271  - error: sourceanalytix.0 (1256) Troubleshoot Data sonoff.0.Zaehler.SML_Actual_pow custom Data : {"_id":"sonoff.0.Zaehler.SML_Actual_pow","common":{"role":"value","read":true,"write":false,"type":"number","unit":"kWh","name":"Zaehler SML  Actual_pow","custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","start_day":1302,"start_week":0,"start_month":0,"start_quarter":0,"start_year":0,"alias":"Gesamtstrom","selectedPrice":"ElectricityDay","costs":true,"consumption":true,"meter_values":true,"basicRate":true,"valueAtDeviceReset":31.784,"valueAtDeviceInit":0.764}}},"native":{},"type":"state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1635757558045}
    2025-07-21 14:12:56.273  - error: sourceanalytix.0 (1256) Cannot handle calculations for sonoff.0.Zaehler.SML_Actual_pow, check log messages and adjust settings!
    2025-07-21 14:12:56.276  - error: sourceanalytix.0 (1256) Initialization of sonoff.0.Zaehler.SML_Actual_pow failed, check warn messages !
    2025-07-21 14:13:09.533  - error: heatingcontrol.0 (450) could not read target OID fritzdect.0.DECT_119600122088.tsoll in Schlafzimmer
    2025-07-21 14:13:17.973  - error: reolink.0 (1371) get white led: TypeError: Cannot read properties of undefined (reading 'WhiteLed')
    2025-07-21 14:13:18.295  - warn: reolink.0 (1371) State "reolink.0.setting.EmailNotification" has no existing object, this might lead to an error in future versions
    2025-07-21 14:14:21.254  - error: heatingcontrol.0 (450) Schlafzimmer could not read fritzdect.0.DECT_119600122088.tsoll
    • ChaotC Chaot
      Ich habe keine Ahnung warum der ioBroker mal wieder zerschossen ist.
      Der läuft eigentlich problemlos seit langer Zeit in einem Proxmox Container. Allerdings lässt er sich von Zeit zu Zeit manchmal nicht starten oder stoppen.
      Aktuell ist es so, dass ich keine Adapter updaten kann. In der Konsole kann ich den ioBroker nicht stoppen und der Fixer funktionieret auch nicht.
      haus@ioBroker:~$ iob stop
      Could not send "SIGTERM" to process 199: kill EPERM
      No "killall.sh" script found. Just stop.
      haus@ioBroker:~$ iob status
      Objects type: jsonl
      States  type: redis
      Klar, wenn der nicht gestoppt ist kann der Fixer nicht funktionieren...
      Also zuerst irgendwie stoppen wenn ich das so richtig sehe
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      @chaot
      Hinweis 1, was nichts mit dem eigentlichen Problem zu tun hat:
      Warum hast du json und Redis gemischt. Wenn dann würde ich auch die objects auf Redis umstellen.
      Hinweis2:
      Hast Du evtl. Ports am Router geöffnet?
      Meine Adapter und Widgets
      Links im Profil
      • OliverIOO OliverIO
        @chaot
        Hinweis2:
        ChaotC Offline
        ChaotC Offline
        Chaot
        @oliverio
        Ich hatte mal irgendwann gelesen, dass diese Kombination bei meinem System wohl schneller (besser) wäre. Aber das lässt sich ja beheben.
        Ports am Router sind für den ioBroker alle dicht.
        wendy2702W OliverIOO 2 Antworten Letzte Antwort
        • ChaotC Chaot
          @oliverio
          wendy2702W Offline
          wendy2702W Offline
          @chaot hast du den Proxmox Container mal neu gestartet und damit auch iob?
            ChaotC Offline
            ChaotC Offline
            Chaot
            @wendy2702
            Ja, bereits mehrfach.
            Ich habe auch schon den kompletten Server neu gestartet
            • ChaotC Chaot
              @oliverio
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              @chaot
              Wenn du genug ram hast ist Redis schneller.
              Beide Systeme halten die Daten im ram und Speichern verzögert im Hintergrund. Redis hat das optimiertere Datenformat (binär) auf der Platte und ist in C geschrieben. Jsonl speichert als json und ist in JavaScript geschrieben.
              Daher ist Redis insgesamt besser.
              Gut, das keine offenen Ports, dann schließt sich das aus, das jemand fremdes sich da Scherze erlaubt.
              Probiere evtl. Mal mit der physischen Platte (also nicht im Container) einen Smart Festplatten Test durchzuführen um beginnende Schäden der Platte/ssd auszuschließen. Ergebnisse kannst du durch ChatGPT interpretieren lassen.
              Nachtrag
              Dringend die Platte prüfen
              Hier sind Fehler und Warnungen drin
              Links im Profil
              • ChaotC Chaot
                @wendy2702
                Ach so:
                ```bash
                Script v.2025-03-08
                *** BASE SYSTEM ***
                           Chassis: container
                    Virtualization: lxc
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                CPU threads: 4
                                 RTC time: n/a
                              NTP service: n/a
                          RTC in local TZ: no
                haus
                HOME=/home/haus
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:          2.0G          0B        2.0G
                         6144 M total memory
                         3076 M used memory
                         2096 M free memory
                            0 M buffer memory
                          971 M swap cache
                         2048 M total swap
                            0 M used swap
                         2048 M free swap
                *** FILESYSTEM ***
                /var:
                3.8G    /var/
                3.2G    /var/log
                431M    /var/lib
                USB-Devices by-id:
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: redis
                Hosts:
                admin:          7.7.1
                javascript:     9.0.7
                Adapter State
                + instance is alive
                Objects and States
                Objects:        32962
                States:         32247
                Pending Updates: 15
                @chaot sagte in Mal wieder zerschossen:
                Ganz grundsätzlich würde ich das ganze Spiel auf einer noch unterstützen Basis betreiben.
                Und das Dateisystem scheint was zu haben:
                  ChaotC Offline
                  ChaotC Offline
                  Chaot
                  Das bedeutet:
                  Proxmox Platte rausschmeißen, neu machen (bzw ersetzen) und dann alle container zurück.
                  Dann iobroker auf neuen Container und Backup wieder einspielen.
                  Thomas BraunT OliverIOO 2 Antworten Letzte Antwort
                  • ChaotC Chaot
                    Das bedeutet:
                    @chaot
                    Zum Beispiel.
                    • ChaotC Chaot
                      Das bedeutet:
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      @chaot
                      Erst mal den physischen Status feststellen. Es können auch logische Fehler des Dateisystem sein, die sich reparieren lassen.
                      Wenn die Platte schon ein wenig älter ist, dann ja, ansonsten werden die Probleme nicht besser.
                      Der interessanteste Wert von Smart um den physischen plattenstatus zu bewerten bei ssd ist TBW total bytes written, reallocated sector count und uncorrectable error count
                      Links im Profil
                        @chaot
                        Nachtrag
                        CodierknechtC Online
                        Codierknecht
                        @oliverio sagte in Mal wieder zerschossen:
                        Jedenfalls nicht für ioBroker
                        Hoffentlich auch sonst keine Portfreigaben ❓❓❓
                        HmIP|ZigBee|Tasmota|Unifi
                        Zabbix Certified Specialist
                        • CodierknechtC Codierknecht
                          ChaotC Offline
                          ChaotC Offline
                          Chaot
                          @codierknecht Doch. zwei Ports brauche ich leider offen. Im Netzwerk hängt noch ein Kassensystem.
