tap-adapters bleibt leer und zeigt Fehlermeldung
@wendy2702 sagte in tap-adapters bleibt leer und zeigt Fehlermeldung:
iob upload all
Das hat leider auch nichts gebracht. Die Adapter werden weiterhin nicht angezeigt. Hier noch einmal das aktuelle iob diag
Script v.2025-03-08 *** BASE SYSTEM *** Static hostname: RasPi5Master Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.12.25+rpt-rpi-2712 Architecture: arm64 OS is similar to: Model : Raspberry Pi 5 Model B Rev 1.0 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 20:39:39 up 32 min, 2 users, load average: 1.07, 1.21, 0.78 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'bookworm'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Sun 2025-06-29 20:39:39 CEST Universal time: Sun 2025-06-29 18:39:39 UTC RTC time: Sun 2025-06-29 18:39:39 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: tty *** MEMORY *** total used free shared buff/cache available Mem: 8.5G 2.4G 2.8G 5.7M 3.3G 6.0G Swap: 209M 0B 209M Total: 8.7G 2.4G 3.0G Active iob-Instances: 30 8063 M total memory 2329 M used memory 2367 M active memory 2523 M inactive memory 2708 M free memory 162 M buffer memory 2957 M swap cache 199 M total swap 0 M used swap 199 M free swap *** top - Table Of Processes *** top - 20:39:39 up 32 min, 2 users, load average: 1.07, 1.21, 0.78 Tasks: 213 total, 1 running, 212 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 50.0 sy, 0.0 ni, 50.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 8063.7 total, 2708.5 free, 2329.1 used, 3119.4 buff/cache MiB Swap: 200.0 total, 200.0 free, 0.0 used. 5734.5 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.9G 0 3.9G 0% /dev tmpfs tmpfs 807M 5.4M 801M 1% /run /dev/mmcblk0p2 ext4 29G 9.1G 19G 34% / tmpfs tmpfs 4.0G 0 4.0G 0% /dev/shm tmpfs tmpfs 5.0M 48K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 510M 66M 445M 13% /boot/firmware tmpfs tmpfs 807M 0 807M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Sun Jun 29 20:06:40 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:1C:A4:7A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 console=ttyAMA10,115200 console=tty1 root=PARTUUID=5f91f746-02 rootfstype=ext4 fsck.repair=yes rootwait [Sun Jun 29 20:06:43 2025] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none. [Sun Jun 29 20:06:45 2025] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 2.0G /var/ 1.1G /var/log/journal/64cb121356244e8f8e25e60fb6d9faec 1.1G /var/log/journal 1.1G /var/log 390M /var/cache Archived and active journals take up 1.0G in the file system. /opt/iobroker/backups: 55M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 967M /opt/iobroker/iobroker-data/ 912M /opt/iobroker/iobroker-data/files 617M /opt/iobroker/iobroker-data/files/javascript.admin 560M /opt/iobroker/iobroker-data/files/javascript.admin/static 558M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 24M /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map 24M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map 22M /opt/iobroker/iobroker-data/objects.jsonl USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0 *** ZigBee Settings *** Your zigbee.0 COM-Port is matching 'by-id'. Very good! Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' *** NodeJS-Installation *** /usr/bin/nodejs v20.19.3 /usr/bin/node v20.19.3 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.32.0 nodejs: Installed: 20.19.3-1nodesource1 Candidate: 20.19.3-1nodesource1 Version table: *** 20.19.3-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 20.19.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.3-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 18.19.0+dfsg-6~deb12u2 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: RasPi4Slave RasPi4Slave (version: 7.0.6, hostname: RasPi4Slave , alive, uptime: 1937) RasPi5Master RasPi5Master (version: 7.0.6, hostname: RasPi5Master , alive, uptime: 151) Core adapters versions js-controller: 7.0.6 admin: 7.6.3 javascript: 8.8.3 nodejs modules from github: 0 Adapter State + system.adapter.admin.0 : admin : RasPi5Master - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : RasPi5Master - enabled + system.adapter.backitup.1 : backitup : RasPi5Master - enabled system.adapter.devices.0 : devices : RasPi5Master - enabled + system.adapter.discovery.0 : discovery : RasPi5Master - enabled system.adapter.dwd.0 : dwd : RasPi4Slave - enabled system.adapter.flot.0 : flot : RasPi5Master - enabled + system.adapter.hm-rega.1 : hm-rega : RasPi5Master - enabled + system.adapter.hm-rpc.2 : hm-rpc : RasPi5Master - enabled, port: 0 + system.adapter.hm-rpc.3 : hm-rpc : RasPi5Master - enabled, port: 0 system.adapter.hmip.0 : hmip : RasPi5Master - disabled system.adapter.ical.0 : ical : RasPi4Slave - enabled + system.adapter.influxdb.0 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.influxdb.2 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.javascript.0 : javascript : RasPi5Master - enabled system.adapter.luftdaten.0 : luftdaten : RasPi4Slave - enabled system.adapter.luftdaten.1 : luftdaten : RasPi4Slave - enabled system.adapter.luftdaten.2 : luftdaten : RasPi4Slave - enabled + system.adapter.modbus.0 : modbus : RasPi5Master - enabled + system.adapter.mqtt.0 : mqtt : RasPi5Master - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.nut.0 : nut : RasPi5Master - enabled system.adapter.odl.0 : odl : RasPi4Slave - enabled system.adapter.openweathermap.0 : openweathermap : RasPi4Slave - enabled + system.adapter.owfs.0 : owfs : RasPi4Slave - enabled, port: 4304 + system.adapter.ping.0 : ping : RasPi5Master - enabled + system.adapter.pvforecast.0 : pvforecast : RasPi4Slave - enabled + system.adapter.rpi2.0 : rpi2 : RasPi5Master - enabled + system.adapter.rpi2.1 : rpi2 : RasPi4Slave - enabled + system.adapter.scenes.0 : scenes : RasPi5Master - enabled + system.adapter.shelly.0 : shelly : RasPi5Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.smartmeter.0 : smartmeter : RasPi4Slave - enabled + system.adapter.sonos.0 : sonos : RasPi5Master - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : RasPi4Slave - enabled + system.adapter.telegram.0 : telegram : RasPi5Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.tr-064.0 : tr-064 : RasPi5Master - enabled system.adapter.vis-colorpicker.0 : vis-colorpicker : RasPi5Master - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : RasPi5Master - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : RasPi5Master - enabled system.adapter.vis-material.0 : vis-material : RasPi5Master - enabled system.adapter.vis-materialdesign.0 : vis-materialdesign : RasPi5Master - enabled system.adapter.vis-players.0 : vis-players : RasPi5Master - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : RasPi5Master - enabled system.adapter.vis.0 : vis : RasPi5Master - enabled + system.adapter.web.0 : web : RasPi5Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : RasPi5Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : RasPi5Master - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.2 : hm-rpc : RasPi5Master - enabled, port: 0 + system.adapter.hm-rpc.3 : hm-rpc : RasPi5Master - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.influxdb.2 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : RasPi5Master - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.owfs.0 : owfs : RasPi4Slave - enabled, port: 4304 + system.adapter.shelly.0 : shelly : RasPi5Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : RasPi5Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : RasPi5Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : RasPi5Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters Used repository: stable Objects and States Please stand by - This may take a while Objects: 11278 States: 8992 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease Hit:4 https://repos.influxdata.com/debian stable InRelease Hit:5 http://deb.debian.org/debian bookworm-updates InRelease Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease Hit:7 https://apt.grafana.com stable InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 192.168.2.230:2001 0.0.0.0:* LISTEN 1001 47178 4634/io.hm-rpc.3 tcp 0 0 192.168.2.230:2010 0.0.0.0:* LISTEN 1001 47105 4605/io.hm-rpc.2 tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 44996 4695/io.shelly.0 tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 107 5542 849/mosquitto tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 6489 853/sshd: /usr/sbin tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 40272 4316/iobroker.js-co tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 40267 4316/iobroker.js-co tcp6 0 0 :::3500 :::* LISTEN 1001 46038 4710/io.sonos.0 tcp6 0 0 :::8082 :::* LISTEN 1001 46969 4789/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 44394 4334/io.admin.0 tcp6 0 0 :::8086 :::* LISTEN 999 6911 918/influxd tcp6 0 0 :::3000 :::* LISTEN 106 6958 980/grafana tcp6 0 0 :::1883 :::* LISTEN 107 5543 849/mosquitto tcp6 0 0 :::22 :::* LISTEN 0 6491 853/sshd: /usr/sbin udp 0 0 0.0.0.0:58922 0.0.0.0:* 104 5473 713/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 5471 713/avahi-daemon: r udp6 0 0 fe80::c111:b556:327:546 :::* 0 4052 818/NetworkManager udp6 0 0 :::33369 :::* 104 5474 713/avahi-daemon: r udp6 0 0 :::5353 :::* 104 5472 713/avahi-daemon: r *** Log File - Last 25 Lines *** 2025-06-29 20:38:56.462 - info: shelly.0 (4695) [MQTT] Device with client id "shellyplusplugs-b0b21c19e6d0" connected! 2025-06-29 20:38:56.547 - info: web.0 (4789) ==> Connected system.user.admin from ::ffff:192.168.2.74 2025-06-29 20:38:56.670 - info: tr-064.0 (4649) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 20:38:56.724 - info: shelly.0 (4695) [MQTT] Device with client id "shellyplug-s-4022D881C855" connected! 2025-06-29 20:38:57.484 - info: shelly.0 (4695) [MQTT] Device with client id "shellyplug-s-795742" connected! 2025-06-29 20:38:58.566 - info: shelly.0 (4695) [MQTT] Device with client id "shellyplusplugs-b0b21c18eaa4" connected! 2025-06-29 20:39:00.087 - warn: zigbee.0 (4726) DeviceAvailability:Failed to ping 0x00158d00045845e9 500.47 2025-06-29 20:39:00.105 - info: shelly.0 (4695) [MQTT] Device with client id "shellyplug-s-9DCC68" connected! 2025-06-29 20:39:02.240 - info: shelly.0 (4695) [MQTT] Device with client id "shellyplug-s-041B6E" connected! 2025-06-29 20:39:03.462 - info: shelly.0 (4695) [MQTT] Device with client id "shellyplug-s-F1AEC2" connected! 2025-06-29 20:39:03.524 - info: shelly.0 (4695) [MQTT] Device with client id "shellyplug-s-7A34A5" connected! 2025-06-29 20:39:03.647 - info: shelly.0 (4695) [MQTT] Device with client id "shellyswitch25-483FDA8D1664" connected! 2025-06-29 20:39:03.774 - warn: zigbee.0 (4726) DeviceAvailability:Failed to ping 0x7cb03eaa0a0c739e Plug 01 2025-06-29 20:39:04.599 - info: shelly.0 (4695) [MQTT] Device with client id "shellyplusplugs-64b7080d0540" connected! 2025-06-29 20:39:08.269 - info: tr-064.0 (4649) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 20:39:10.813 - warn: zigbee.0 (4726) DeviceAvailability:Failed to ping 0x00158d000568bb1b 371000002 2025-06-29 20:39:12.452 - info: shelly.0 (4695) [MQTT] Device with client id "shellyplusplugs-b0b21c1ab42c" connected! 2025-06-29 20:39:15.384 - info: admin.0 (4334) <== Disconnect system.user.admin from ::ffff:192.168.2.74 admin 2025-06-29 20:39:15.797 - info: admin.0 (4334) ==> Connected system.user.admin from ::ffff:192.168.2.74 2025-06-29 20:39:19.754 - info: tr-064.0 (4649) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 20:39:21.103 - warn: zigbee.0 (4726) DeviceAvailability:Failed to ping 0x00178801042e1ed8 LTP008 2025-06-29 20:39:30.912 - warn: zigbee.0 (4726) DeviceAvailability:Failed to ping 0x00158d00045850c7 500.47 2025-06-29 20:39:31.419 - info: tr-064.0 (4649) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 20:39:42.880 - info: tr-064.0 (4649) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 20:39:54.304 - info: tr-064.0 (4649) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}@lollo_c welcher Browser? Anderen getestet?
Cache geleert?
Irgendeinen Ad Blocker oder so im Broswer aktiv?
Funktioniert es in einem Inkognito tab?
Was kommt in der Browser Konsole F12 beim Aufruf der Seite?
Ist der Master oder Slave ausgewählt?
Cache geleert?
cd /opt/iobroker npm i --dry-run -
cd /opt/iobroker npm i --dry-runpi@RasPi5Master:~ $ cd /opt/ioBroker -bash: cd: /opt/ioBroker: Datei oder Verzeichnis nicht gefunden -
pi@RasPi5Master:~ $ cd /opt/ioBroker -bash: cd: /opt/ioBroker: Datei oder Verzeichnis nicht gefundenHab es oben korrigiert. Autokorrektur auf dem Handy hat zugeschlagen.
pi@RasPi5Master:/opt/iobroker $ npm i --dry-run add fsevents 2.3.3 added 1 package in 2s 241 packages are looking for funding run `npm fund` for details -
@thomas-braun sagte in tap-adapters bleibt leer und zeigt Fehlermeldung:
npm ls
pi@RasPi5Master:/opt/iobroker $ npm ls iobroker.inst@3.0.0 /opt/iobroker ├── iobroker.admin@7.6.3 ├── iobroker.backitup@3.0.31 ├── iobroker.devices@1.1.5 ├── iobroker.discovery@5.0.0 ├── iobroker.flot@1.12.0 ├── iobroker.hm-rega@5.1.0 ├── iobroker.hm-rpc@2.0.2 ├── iobroker.hmip@1.27.0 ├── iobroker.influxdb@4.0.2 ├── iobroker.javascript@8.8.3 ├── iobroker.js-controller@7.0.6 ├── iobroker.modbus@6.3.2 ├── iobroker.mqtt@6.1.2 ├── iobroker.nut@1.6.0 ├── iobroker.openweathermap@1.1.2 ├── iobroker.ping@1.6.2 ├── iobroker.rpi2@2.4.0 ├── iobroker.scenes@3.2.3 ├── iobroker.shelly@8.5.1 ├── iobroker.simple-api@2.8.0 ├── iobroker.smartmeter@3.4.0 ├── iobroker.socketio@6.7.1 ├── iobroker.sonos@3.0.0 ├── iobroker.telegram@4.1.0 ├── iobroker.tr-064@4.3.0 ├── iobroker.vis-colorpicker@2.0.3 ├── iobroker.vis-inventwo@3.3.4 ├── iobroker.vis-jqui-mfd@1.1.1 ├── iobroker.vis-material@0.2.0 ├── iobroker.vis-materialdesign@0.5.9 ├── iobroker.vis-players@0.1.6 ├── iobroker.vis-timeandweather@1.2.2 ├── iobroker.vis@1.5.6 ├── iobroker.web@7.0.8 ├── iobroker.ws@2.6.2 └── iobroker.zigbee@1.10.14 -
Cache geleert?
welcher Browser? Chrome
Anderen getestet? Ja, Firefox
Cache geleert?Ja
Irgendeinen Ad Blocker oder so im Broswer aktiv? Nein
Funktioniert es in einem Inkognito tab? Nein
Was kommt in der Browser Konsole F12 beim Aufruf der Seite? Jede Menge Fehler in der Art "bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.flot" common.adminUI={"config":"none"}"
Ist der Master oder Slave ausgewählt? Bei beiden nichts zu sehenIch denke auch nicht, das es vom Browser kommt, da auch in der iob diag schon keine Auflistung der Adapter angezeigt wird. (Beim Slave : ja; beim Master: nein)
Cache geleert?Ja
Cache geleert?Ja
@lollo_c wenn du einen Beitrag editierst, dann markiere das bitte entsprechend.
Glaube es macht Sinn wenn du den Inhalt der Browser Konsole mal vollständig zeigst.
@wendy2702
Ich habe den Inhalt der Konsole kopiert. Ich hoffe, das reicht, wenn nIcht? Was soll ich tun?bootstrap-DF1rNJUh.js:1899 iobroker.admin@7.0.25 bootstrap-DF1rNJUh.js:17 [2025-06-29T18:56:22.502Z] Try to connect bootstrap-DF1rNJUh.js:17 Stored version: , new version: 7.6.3 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.flot" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.hm-rega" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.tr-064" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.devices" common.adminUI={"config":"none","tab":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.scenes" common.adminUI={"config":"none","tab":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.owfs" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.smartmeter" common.adminUI={"config":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.vis-inventwo" common.adminUI={"config":"materialize","tab":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.vis-players" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.vis-jqui-mfd" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.vis-materialdesign" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Double links: "vis.0" and "vis.0 pro" bootstrap-DF1rNJUh.js:17 Double links: "flot.0" and "flot.0 cloud" bootstrap-DF1rNJUh.js:17 Double links: "luftdaten.1 map" and "luftdaten.0 map" bootstrap-DF1rNJUh.js:17 Double links: "luftdaten.2 map" and "luftdaten.0 map" bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Translate: Link bootstrap-DF1rNJUh.js:17 Translate: time bootstrap-DF1rNJUh.js:17 Translate: timeOffset bootstrap-DF1rNJUh.js:17 Translate: _nodeCurrent bootstrap-DF1rNJUh.js:17 Translate: _nodeNewest bootstrap-DF1rNJUh.js:17 Translate: _nodeNewestNext bootstrap-DF1rNJUh.js:17 Translate: _npmCurrent bootstrap-DF1rNJUh.js:17 Translate: _npmNewest bootstrap-DF1rNJUh.js:17 Translate: _npmNewestNext bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.flot" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.hm-rega" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.tr-064" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.devices" common.adminUI={"config":"none","tab":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.scenes" common.adminUI={"config":"none","tab":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.owfs" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.smartmeter" common.adminUI={"config":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.vis-inventwo" common.adminUI={"config":"materialize","tab":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.vis-players" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.vis-jqui-mfd" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.adapter.vis-materialdesign" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.flot" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.hm-rega" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.tr-064" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.devices" common.adminUI={"config":"none","tab":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.scenes" common.adminUI={"config":"none","tab":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.smartmeter" common.adminUI={"config":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-inventwo" common.adminUI={"config":"materialize","tab":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-players" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-jqui-mfd" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-materialdesign" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] getAdapters bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.flot" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.hm-rega" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.tr-064" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.devices" common.adminUI={"config":"none","tab":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.scenes" common.adminUI={"config":"none","tab":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.smartmeter" common.adminUI={"config":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-inventwo" common.adminUI={"config":"materialize","tab":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-players" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-jqui-mfd" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-materialdesign" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] getAdaptersInfo bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Cannot get adapters info: TypeError: Cannot create property 'rating' on string '<' (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Double links: "vis.0" and "vis.0 pro" bootstrap-DF1rNJUh.js:17 Double links: "flot.0" and "flot.0 cloud" bootstrap-DF1rNJUh.js:17 Double links: "luftdaten.1 map" and "luftdaten.0 map" bootstrap-DF1rNJUh.js:17 Double links: "luftdaten.2 map" and "luftdaten.0 map" bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.flot" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.hm-rega" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.tr-064" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.devices" common.adminUI={"config":"none","tab":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.scenes" common.adminUI={"config":"none","tab":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.smartmeter" common.adminUI={"config":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-inventwo" common.adminUI={"config":"materialize","tab":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-players" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-jqui-mfd" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-materialdesign" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] getAdapters bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.flot" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.hm-rega" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.tr-064" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.devices" common.adminUI={"config":"none","tab":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.scenes" common.adminUI={"config":"none","tab":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.smartmeter" common.adminUI={"config":"html"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-inventwo" common.adminUI={"config":"materialize","tab":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-players" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-jqui-mfd" common.adminUI={"config":"none"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 Please add to "system.host.RasPi5Master.adapter.vis-materialdesign" common.adminUI={"config":"materialize"} (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] getAdaptersInfo bootstrap-DF1rNJUh.js:17 Cannot get adapters info: TypeError: Cannot create property 'rating' on string '<' (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 bootstrap-DF1rNJUh.js:17 [ADAPTERS] Cannot compare "" and "7.0.6" (anonym) @ bootstrap-DF1rNJUh.js:17 -
@wendy2702
@lollo_c gab mal ähnliche Probleme bei denen dann die Installation einer weiteren Admin Instanz geholfen.
Kannst ja mal testen und dich dann über den Port verbinden.
iob add admin@wendy2702
Okay, da werde ich mich mal einlesen. Muss für Heute aber Schluss machen. Morgen geht es weiter.
Bisher vielen Dank für die Unterstützung. -
@wendy2702
Bisher vielen Dank für die Unterstützung.@lollo_c
Ich glaub nicht dass da admin selbst oder der browser mitspielt. Da gibts ein Problem mit der Installation selbst.wenn iob diag keine Adapter listet stimmt was in der Installation selbst nicht.
EDiT
vermutung defeketes package.json gelöscht da ja npm ls funktioniert hat -
@lollo_c
EDiT
vermutung defeketes package.json gelöscht da ja npm ls funktioniert hat@mcm1957
Guten Morgen,
die package.json ist vorhanden. Ihr Inhalt ist:{"name":"iobroker.inst","version":"3.0.0","private":true,"description":"Automate your Life","engines":{"node":">=16.0.0"},"dependencies":{"iobroker.admin":"7.6.3","iobroker.backitup":"3.0.31","iobroker.devices":"1.1.5","iobroker.discovery":"5.0.0","iobroker.flot":"1.12.0","iobroker.hm-rega":"5.1.0","iobroker.hm-rpc":"2.0.2","iobroker.hmip":"1.27.0","iobroker.influxdb":"4.0.2","iobroker.javascript":"8.8.3","iobroker.js-controller":"7.0.6","iobroker.modbus":"6.3.2","iobroker.mqtt":"6.1.2","iobroker.nut":"1.6.0","iobroker.openweathermap":"1.1.2","iobroker.ping":"1.6.2","iobroker.rpi2":"2.4.0","iobroker.scenes":"3.2.3","iobroker.shelly":"8.5.1","iobroker.simple-api":"2.8.0","iobroker.smartmeter":"3.4.0","iobroker.socketio":"6.7.1","iobroker.sonos":"3.0.0","iobroker.telegram":"4.1.0","iobroker.tr-064":"4.3.0","iobroker.vis":"1.5.6","iobroker.vis-colorpicker":"2.0.3","iobroker.vis-inventwo":"3.3.4","iobroker.vis-jqui-mfd":"1.1.1","iobroker.vis-material":"0.2.0","iobroker.vis-materialdesign":"0.5.9","iobroker.vis-players":"0.1.6","iobroker.vis-timeandweather":"1.2.2","iobroker.web":"7.0.8","iobroker.ws":"2.6.2","iobroker.zigbee":"1.10.14"},"overrides":{"@iobroker/adapter-core":"^3.2.1"}} -
@lollo_c
EDiT
Hallo Zusammen,
seit einiger Zeit kann ich den Adapter-Tab nicht mehr öffnen. Die Seite bleibt leer und ich bekomme folgende Fehlermeldung:Cannot get adapters info: TypeError: Cannot create property 'rating' on string '<'Mein System besteht aus einem Master = Raspi5 und einem Slave = Raspi4.
In der iob-diag kann ich sehen, dass die Adapter auf dem Slave angezeigt werden, auf dem Master aber nicht.Die Frage ist nun: Warum und was kann ich tun?
Hier der iob-diag vom Master:
Script v.2025-03-08 *** BASE SYSTEM *** Static hostname: RasPi5Master Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.12.25+rpt-rpi-2712 Architecture: arm64 OS is similar to: Model : Raspberry Pi 5 Model B Rev 1.0 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 10:23:28 up 41 days, 16:01, 2 users, load average: 0.45, 0.57, 0.61 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'bookworm'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Sun 2025-06-29 10:23:28 CEST Universal time: Sun 2025-06-29 08:23:28 UTC RTC time: Sun 2025-06-29 08:23:28 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: tty *** MEMORY *** total used free shared buff/cache available Mem: 8.4G 2.5G 2.9G 5.7M 3.2G 6.0G Swap: 209M 0B 209M Total: 8.7G 2.5G 3.1G Active iob-Instances: 30 8051 M total memory 2358 M used memory 2313 M active memory 2515 M inactive memory 2789 M free memory 192 M buffer memory 2813 M swap cache 199 M total swap 0 M used swap 199 M free swap *** top - Table Of Processes *** top - 10:23:28 up 41 days, 16:01, 2 users, load average: 0.45, 0.57, 0.61 Tasks: 198 total, 1 running, 197 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 8051.8 total, 2788.9 free, 2358.9 used, 3006.3 buff/cache MiB Swap: 200.0 total, 200.0 free, 0.0 used. 5692.9 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.9G 0 3.9G 0% /dev tmpfs tmpfs 806M 5.4M 800M 1% /run /dev/mmcblk0p2 ext4 29G 9.1G 19G 34% / tmpfs tmpfs 4.0G 0 4.0G 0% /dev/shm tmpfs tmpfs 5.0M 48K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 510M 66M 445M 13% /boot/firmware tmpfs tmpfs 806M 0 806M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 2.0G /var/ 1.1G /var/log/journal/64cb121356244e8f8e25e60fb6d9faec 1.1G /var/log/journal 1.1G /var/log 390M /var/cache Archived and active journals take up 1.0G in the file system. /opt/iobroker/backups: 55M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 960M /opt/iobroker/iobroker-data/ 912M /opt/iobroker/iobroker-data/files 617M /opt/iobroker/iobroker-data/files/javascript.admin 560M /opt/iobroker/iobroker-data/files/javascript.admin/static 558M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 24M /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map 24M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map 15M /opt/iobroker/iobroker-data/objects.jsonl USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0 *** ZigBee Settings *** Your zigbee.0 COM-Port is matching 'by-id'. Very good! Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' *** NodeJS-Installation *** /usr/bin/nodejs v20.19.3 /usr/bin/node v20.19.3 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.32.0 nodejs: Installed: 20.19.3-1nodesource1 Candidate: 20.19.3-1nodesource1 Version table: *** 20.19.3-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 20.19.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.3-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 18.19.0+dfsg-6~deb12u2 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: RasPi4Slave RasPi4Slave (version: 7.0.6, hostname: RasPi4Slave , alive, uptime: 3601616) RasPi5Master RasPi5Master (version: 7.0.6, hostname: RasPi5Master , alive, uptime: 511) Core adapters versions js-controller: 7.0.6 admin: 7.6.3 javascript: 8.8.3 nodejs modules from github: 0 Adapter State + system.adapter.admin.0 : admin : RasPi5Master - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : RasPi5Master - enabled + system.adapter.backitup.1 : backitup : RasPi5Master - enabled system.adapter.devices.0 : devices : RasPi5Master - enabled + system.adapter.discovery.0 : discovery : RasPi5Master - enabled system.adapter.dwd.0 : dwd : RasPi4Slave - enabled system.adapter.flot.0 : flot : RasPi5Master - enabled + system.adapter.hm-rega.1 : hm-rega : RasPi5Master - enabled + system.adapter.hm-rpc.2 : hm-rpc : RasPi5Master - enabled, port: 0 + system.adapter.hm-rpc.3 : hm-rpc : RasPi5Master - enabled, port: 0 system.adapter.hmip.0 : hmip : RasPi5Master - disabled system.adapter.ical.0 : ical : RasPi4Slave - enabled + system.adapter.influxdb.0 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.influxdb.2 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.javascript.0 : javascript : RasPi5Master - enabled system.adapter.luftdaten.0 : luftdaten : RasPi4Slave - enabled system.adapter.luftdaten.1 : luftdaten : RasPi4Slave - enabled system.adapter.luftdaten.2 : luftdaten : RasPi4Slave - enabled + system.adapter.modbus.0 : modbus : RasPi5Master - enabled + system.adapter.mqtt.0 : mqtt : RasPi5Master - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.nut.0 : nut : RasPi5Master - enabled system.adapter.odl.0 : odl : RasPi4Slave - enabled system.adapter.openweathermap.0 : openweathermap : RasPi4Slave - enabled + system.adapter.owfs.0 : owfs : RasPi4Slave - enabled, port: 4304 + system.adapter.ping.0 : ping : RasPi5Master - enabled + system.adapter.pvforecast.0 : pvforecast : RasPi4Slave - enabled + system.adapter.rpi2.0 : rpi2 : RasPi5Master - enabled + system.adapter.rpi2.1 : rpi2 : RasPi4Slave - enabled + system.adapter.scenes.0 : scenes : RasPi5Master - enabled + system.adapter.shelly.0 : shelly : RasPi5Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.smartmeter.0 : smartmeter : RasPi4Slave - enabled + system.adapter.sonos.0 : sonos : RasPi5Master - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : RasPi4Slave - enabled + system.adapter.telegram.0 : telegram : RasPi5Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.tr-064.0 : tr-064 : RasPi5Master - enabled system.adapter.vis-colorpicker.0 : vis-colorpicker : RasPi5Master - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : RasPi5Master - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : RasPi5Master - enabled system.adapter.vis-material.0 : vis-material : RasPi5Master - enabled system.adapter.vis-materialdesign.0 : vis-materialdesign : RasPi5Master - enabled system.adapter.vis-players.0 : vis-players : RasPi5Master - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : RasPi5Master - enabled system.adapter.vis.0 : vis : RasPi5Master - enabled + system.adapter.web.0 : web : RasPi5Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : RasPi5Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : RasPi5Master - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.2 : hm-rpc : RasPi5Master - enabled, port: 0 + system.adapter.hm-rpc.3 : hm-rpc : RasPi5Master - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.influxdb.2 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : RasPi5Master - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.owfs.0 : owfs : RasPi4Slave - enabled, port: 4304 + system.adapter.shelly.0 : shelly : RasPi5Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : RasPi5Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : RasPi5Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : RasPi5Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters Used repository: stable Objects and States Please stand by - This may take a while Objects: 11278 States: 8992 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease Hit:4 https://repos.influxdata.com/debian stable InRelease Hit:5 http://deb.debian.org/debian bookworm-updates InRelease Hit:6 https://apt.grafana.com stable InRelease Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 6582 840/sshd: /usr/sbin tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 42335995 2463068/iobroker.js tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 42336000 2463068/iobroker.js tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 107 5716 835/mosquitto tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 42339935 2463447/io.shelly.0 tcp 0 0 192.168.2.230:2010 0.0.0.0:* LISTEN 1001 42337166 2463371/io.hm-rpc.2 tcp 0 0 192.168.2.230:2001 0.0.0.0:* LISTEN 1001 42338902 2463386/io.hm-rpc.3 tcp6 0 0 :::22 :::* LISTEN 0 6584 840/sshd: /usr/sbin tcp6 0 0 :::1883 :::* LISTEN 107 5717 835/mosquitto tcp6 0 0 :::3000 :::* LISTEN 106 42317856 2440337/grafana tcp6 0 0 :::3500 :::* LISTEN 1001 42339952 2463462/io.sonos.0 tcp6 0 0 :::8086 :::* LISTEN 999 8301 903/influxd tcp6 0 0 :::8081 :::* LISTEN 1001 42335080 2463089/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 42340117 2463543/io.web.0 udp 0 0 0.0.0.0:40313 0.0.0.0:* 104 4063 720/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 4061 720/avahi-daemon: r udp6 0 0 fe80::c111:b556:327:546 :::* 0 7299 797/NetworkManager udp6 0 0 :::37557 :::* 104 4064 720/avahi-daemon: r udp6 0 0 :::5353 :::* 104 4062 720/avahi-daemon: r *** Log File - Last 25 Lines *** 2025-06-29 10:19:17.685 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:19:29.121 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:19:40.561 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:19:52.028 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:20:03.496 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:20:15.063 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:20:26.588 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:20:37.914 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:20:49.302 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:21:00.853 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:21:12.127 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:21:23.627 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:21:35.095 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:21:46.496 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:21:57.930 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:22:09.375 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:22:20.910 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:22:32.335 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:22:43.765 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:22:55.263 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:23:06.873 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:23:18.185 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:23:29.545 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:23:41.203 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2025-06-29 10:23:52.802 - info: tr-064.0 (2463402) forEachConfiguredDevice: in GetSpecificHostEntry 5(UL-Galaxy-A6/10:8E:E0:71:F7:AE) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}und der vom Slave:
Script v.2025-03-08 *** BASE SYSTEM *** Static hostname: RasPi4Slave Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.12.25+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 10:20:06 up 41 days, 22:20, 2 users, load average: 0.24, 0.19, 0.18 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'bookworm'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Sun 2025-06-29 10:20:06 CEST Universal time: Sun 2025-06-29 08:20:06 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: tty *** MEMORY *** total used free shared buff/cache available Mem: 4.0G 744M 1.5G 1.2M 1.8G 3.2G Swap: 209M 0B 209M Total: 4.2G 744M 1.7G Active iob-Instances: 30 3791 M total memory 710 M used memory 728 M active memory 1379 M inactive memory 1455 M free memory 195 M buffer memory 1506 M swap cache 199 M total swap 0 M used swap 199 M free swap *** top - Table Of Processes *** top - 10:20:07 up 41 days, 22:20, 2 users, load average: 0.24, 0.19, 0.18 Tasks: 177 total, 1 running, 176 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 3791.4 total, 1455.6 free, 710.4 used, 1702.2 buff/cache MiB Swap: 200.0 total, 200.0 free, 0.0 used. 3081.0 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 1.6G 0 1.6G 0% /dev tmpfs tmpfs 380M 1.2M 378M 1% /run /dev/mmcblk0p2 ext4 29G 4.6G 23G 17% / tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 510M 66M 445M 13% /boot/firmware tmpfs tmpfs 380M 0 380M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Sun May 18 11:59:30 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=D8:3A:DD:E0:CE:1F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=7436914b-02 rootfstype=ext4 fsck.repair=yes rootwait [Sun May 18 11:59:31 2025] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none. [Sun May 18 11:59:32 2025] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 1000M /var/ 352M /var/log/journal/67e5e2254bad4b69bd3c66f52d0f2074 352M /var/log/journal 352M /var/log 265M /var/cache Archived and active journals take up 351.5M in the file system. /opt/iobroker/backups: 2.9M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 55M /opt/iobroker/iobroker-data/ 35M /opt/iobroker/iobroker-data/backup-objects 15M /opt/iobroker/iobroker-data/files 13M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js 13M /opt/iobroker/iobroker-data/files/admin.admin/custom/static The five largest files in iobroker-data are: 6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map 5.7M /opt/iobroker/iobroker-data/objects.jsonl 2.8M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js 1.6M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map 1.5M /opt/iobroker/iobroker-data/backup-objects/2024-04-09_19-44_objects.jsonl.gz USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DK0EJEOL-if00-port0 HINT: Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0 Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' *** NodeJS-Installation *** /usr/bin/nodejs v20.19.3 /usr/bin/node v20.19.3 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.32.0 nodejs: Installed: 20.19.3-1nodesource1 Candidate: 20.19.3-1nodesource1 Version table: *** 20.19.3-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 20.19.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.3-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 18.19.0+dfsg-6~deb12u2 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. At least one iobroker host is running. Objects type: jsonl States type: jsonl Hosts: RasPi4Slave RasPi4Slave (version: 7.0.6, hostname: RasPi4Slave , alive, uptime: 3601421) RasPi5Master RasPi5Master (version: 7.0.6, hostname: RasPi5Master , alive, uptime: 316) Core adapters versions js-controller: 7.0.6 admin: 7.6.3 javascript: "javascript" not found nodejs modules from github: 0 Adapter State + system.adapter.admin.0 : admin : RasPi5Master - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : RasPi5Master - enabled + system.adapter.backitup.1 : backitup : RasPi5Master - enabled system.adapter.devices.0 : devices : RasPi5Master - enabled + system.adapter.discovery.0 : discovery : RasPi5Master - enabled system.adapter.dwd.0 : dwd : RasPi4Slave - enabled system.adapter.flot.0 : flot : RasPi5Master - enabled + system.adapter.hm-rega.1 : hm-rega : RasPi5Master - enabled + system.adapter.hm-rpc.2 : hm-rpc : RasPi5Master - enabled, port: 0 + system.adapter.hm-rpc.3 : hm-rpc : RasPi5Master - enabled, port: 0 system.adapter.hmip.0 : hmip : RasPi5Master - disabled system.adapter.ical.0 : ical : RasPi4Slave - enabled + system.adapter.influxdb.0 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.influxdb.2 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.javascript.0 : javascript : RasPi5Master - enabled system.adapter.luftdaten.0 : luftdaten : RasPi4Slave - enabled system.adapter.luftdaten.1 : luftdaten : RasPi4Slave - enabled system.adapter.luftdaten.2 : luftdaten : RasPi4Slave - enabled + system.adapter.modbus.0 : modbus : RasPi5Master - enabled + system.adapter.mqtt.0 : mqtt : RasPi5Master - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.nut.0 : nut : RasPi5Master - enabled system.adapter.odl.0 : odl : RasPi4Slave - enabled system.adapter.openweathermap.0 : openweathermap : RasPi4Slave - enabled + system.adapter.owfs.0 : owfs : RasPi4Slave - enabled, port: 4304 + system.adapter.ping.0 : ping : RasPi5Master - enabled + system.adapter.pvforecast.0 : pvforecast : RasPi4Slave - enabled + system.adapter.rpi2.0 : rpi2 : RasPi5Master - enabled + system.adapter.rpi2.1 : rpi2 : RasPi4Slave - enabled + system.adapter.scenes.0 : scenes : RasPi5Master - enabled + system.adapter.shelly.0 : shelly : RasPi5Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.smartmeter.0 : smartmeter : RasPi4Slave - enabled + system.adapter.sonos.0 : sonos : RasPi5Master - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : RasPi4Slave - enabled + system.adapter.telegram.0 : telegram : RasPi5Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.tr-064.0 : tr-064 : RasPi5Master - enabled system.adapter.vis-colorpicker.0 : vis-colorpicker : RasPi5Master - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : RasPi5Master - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : RasPi5Master - enabled system.adapter.vis-material.0 : vis-material : RasPi5Master - enabled system.adapter.vis-materialdesign.0 : vis-materialdesign : RasPi5Master - enabled system.adapter.vis-players.0 : vis-players : RasPi5Master - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : RasPi5Master - enabled system.adapter.vis.0 : vis : RasPi5Master - enabled + system.adapter.web.0 : web : RasPi5Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : RasPi5Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : RasPi5Master - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.2 : hm-rpc : RasPi5Master - enabled, port: 0 + system.adapter.hm-rpc.3 : hm-rpc : RasPi5Master - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.influxdb.2 : influxdb : RasPi5Master - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : RasPi5Master - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.owfs.0 : owfs : RasPi4Slave - enabled, port: 4304 + system.adapter.shelly.0 : shelly : RasPi5Master - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : RasPi5Master - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : RasPi5Master - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : RasPi5Master - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_00d4b1faa612ec11879723c7bd930c07-if00-port0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters Used repository: stable Adapter "admin" : 7.6.17 , installed 7.6.3 [Updatable] Adapter "backitup" : 3.2.2 , installed 3.0.31 [Updatable] Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "ical" : 1.16.1 , installed 1.16.1 Controller "js-controller": 7.0.6 , installed 7.0.6 Adapter "luftdaten" : 4.0.0 , installed 4.0.0 Adapter "odl" : 5.0.0 , installed 4.0.2 [Updatable] Adapter "openweathermap": 1.1.2 , installed 1.1.2 Adapter "owfs" : 0.7.0 , installed 0.7.0 Adapter "pvforecast" : 4.1.0 , installed 4.1.0 Adapter "rpi2" : 2.4.0 , installed 2.4.0 Adapter "smartmeter" : 3.4.0 , installed 3.4.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Objects and States Please stand by - This may take a while Objects: 11278 States: 9002 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease Hit:4 http://deb.debian.org/debian bookworm-updates InRelease Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:2121 0.0.0.0:* LISTEN 106 6598 670/owhttpd tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 2743 728/sshd: /usr/sbin tcp6 0 0 :::22 :::* LISTEN 0 2745 728/sshd: /usr/sbin tcp6 0 0 :::4304 :::* LISTEN 0 2499 1/systemd udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 2616 582/avahi-daemon: r udp 0 0 0.0.0.0:47541 0.0.0.0:* 104 2618 582/avahi-daemon: r udp6 0 0 :::5353 :::* 104 2617 582/avahi-daemon: r udp6 0 0 :::59884 :::* 104 2619 582/avahi-daemon: r udp6 0 0 fe80::a459:307d:e59:546 :::* 0 6707 665/NetworkManager *** Log File - Last 25 Lines *** 2025-06-29 10:14:49.669 - error: smartmeter.0 (61102) Objects database error: connect ECONNREFUSED 192.168.2.230:9001 2025-06-29 10:14:49.675 - error: host.RasPi4Slave Objects database error: connect ECONNREFUSED 192.168.2.230:9001 2025-06-29 10:14:49.676 - error: pvforecast.0 (61206) Objects database error: connect ECONNREFUSED 192.168.2.230:9001 2025-06-29 10:14:49.674 - error: tankerkoenig.0 (61221) Objects database error: connect ECONNREFUSED 192.168.2.230:9001 2025-06-29 10:14:49.674 - error: rpi2.1 (64416) Objects database error: connect ECONNREFUSED 192.168.2.230:9001 2025-06-29 10:14:49.679 - error: owfs.0 (61003) Objects database error: connect ECONNREFUSED 192.168.2.230:9001 2025-06-29 10:14:54.673 - info: smartmeter.0 (61102) Objects database successfully reconnected 2025-06-29 10:14:54.679 - info: host.RasPi4Slave Objects database successfully reconnected 2025-06-29 10:14:54.684 - info: pvforecast.0 (61206) Objects database successfully reconnected 2025-06-29 10:14:54.696 - info: tankerkoenig.0 (61221) Objects database successfully reconnected 2025-06-29 10:14:54.698 - info: rpi2.1 (64416) Objects database successfully reconnected 2025-06-29 10:14:54.702 - info: owfs.0 (61003) Objects database successfully reconnected 2025-06-29 10:15:00.039 - info: host.RasPi4Slave instance system.adapter.dwd.0 in version "2.8.5" started with pid 1307871 2025-06-29 10:15:04.148 - info: dwd.0 (1307871) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.3, js-controller: 7.0.6 2025-06-29 10:15:04.793 - info: dwd.0 (1307871) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2025-06-29 10:15:05.718 - info: host.RasPi4Slave instance system.adapter.dwd.0 having pid 1307871 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2025-06-29 10:16:43.068 - info: smartmeter.0 (61102) Received 66 values, 2 updated 2025-06-29 10:20:00.034 - info: host.RasPi4Slave instance system.adapter.dwd.0 in version "2.8.5" started with pid 1308803 2025-06-29 10:20:02.360 - info: dwd.0 (1308803) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.3, js-controller: 7.0.6 2025-06-29 10:20:02.918 - info: dwd.0 (1308803) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2025-06-29 10:20:03.449 - info: host.RasPi4Slave instance system.adapter.dwd.0 having pid 1308803 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2025-06-29 10:20:10.028 - info: host.RasPi4Slave instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 1309065 2025-06-29 10:20:12.788 - info: openweathermap.0 (1309065) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.19.3, js-controller: 7.0.6 2025-06-29 10:20:44.255 - info: openweathermap.0 (1309065) Terminated (NO_ERROR): Without reason 2025-06-29 10:20:44.829 - info: host.RasPi4Slave instance system.adapter.openweathermap.0 having pid 1309065 terminated with code 0 (NO_ERROR)Vielen Dank im voraus für Eure Unterstützung
Mfg
Wilfried -
@lollo_c wenn du ein aktuelles Backup hast, dann baue das System komplett neu auf - ist vielleicht effizienter und schneller.
Ro75.
Abrr VORSOCHT
Hab jetzt dein System nicht im Kopf. Wenn möglich installier auf be NEUE SD Karte od. SSD. Da dein System keibe Adapter anzeigt würd ich bis zum Gegenbeweis nicht drauf vertraun dass die Adapteringos im Backup landen.
Abrr VORSOCHT
@mcm1957
ich habe noch ein Image der Karte vom Januar, bei dem es lt. iob diag noch die Adapter angezeigt hat. Frage: Kann ich das einlegen und dann aktualisieren? Und wie verhält es sich dann mit dem Slave, der ja zwischenzeitlich auf einem neuen Stand ist? ... und kann ich dann ein aktuelles Backitup über die dann vorhandenen "alten" Daten einfach drüberziehen?
