  4. Wir Empfehlen: Node.js 20.x :-)
    6.7k
237 Beiträge 49 Kommentatoren 99.5k Aufrufe 46 Beobachtet
  • S shellyrulestheworld
    @thomas-braun OK, immerhin kein Handy Foto 😜
    Nächstes Mal kommt wieder Code 😃
    #212
    @shellyrulestheworld sagte in Wir Empfehlen: Node.js 20.x :-):
    Dann kann ich ja beim nächsten Mal antworten.
      shellyrulestheworld
      #213
      @thomas-braun das Angebot nehme ich an. Irgendwie scheint es jetzt geklappt zu haben, oder?
      ioBroker nodejs fixer 2024-10-10
      You requested to install latest version from nodejs v20 tree.
      Your current setup is:
      /usr/bin/nodejs         v18.20.6
      /usr/bin/node           v18.20.6
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 18.20.6-1nodesource1
        Candidate: 18.20.6-1nodesource1
        Version table:
       *** 18.20.6-1nodesource1 100
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      Nothing to do - Your installation is using the correct paths.
      You are running nodejs v18.20.6. Do you want to install latest version from nodejs v.20 tree?
      Press <y> to continue or any other key to quit
      Trying to fix your installation now. Please be patient.
      rm: cannot remove '/etc/apt/keyrings/nodesource.gpg 2> /dev/null': No such file or directory
      Virtualization: lxc
      Waiting for ioBroker to shut down - Give me a minute...
      Removing dfsg-nodejs
      *** These repos are active on your system:
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:4 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
      Reading package lists... Done
      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      *** These repos are active after the adjustments:
      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
      Get:4 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
      Get:6 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages [10.4 kB]
      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
      Fetched 22.5 kB in 1s (18.6 kB/s)
      Installing nodejs now!
      (Reading database ... 43850 files and directories currently installed.)
      Preparing to unpack .../nodejs_20.18.2-1nodesource1_amd64.deb ...
      Detected old npm client, removing...
      Unpacking nodejs (20.18.2-1nodesource1) over (18.20.6-1nodesource1) ...
      Setting up nodejs (20.18.2-1nodesource1) ...
      Processing triggers for man-db (2.11.2-2) ...
      *** You need to manually restart your container/virtual machine now! ***
      We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
      peter@iobroker:~$
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        Virtualization: lxc
        Package: nodejs
        Pin-Priority: 1001
        peter@iobroker:~$
        #214
        Vermutlich. Container neugestartet?
        Dann nochmal
        iob nodejs-update
        Da sollte dann auch was passendes stehen.
          Dann nochmal
          iob nodejs-update
          shellyrulestheworld
          #215
          @thomas-braun genau. Ich habe den Container neu gestartet. jetzt kommt folgdendes:
          Recommended nodejs-version is: 20.18.2
          Checking your installation now. Please be patient!
          /usr/bin/nodejs         v20.18.2
          /usr/bin/node           v20.18.2
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Installed: 20.18.2-1nodesource1
            Candidate: 20.18.2-1nodesource1
            Version table:
           *** 20.18.2-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
               20.18.1-1nodesource1 1001
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
          Nothing to do - Your version is the recommended one.
          ***You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands. ***
          *** DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation! ***
           *** DO NOT use 'nodejs-update' as part of a regular update process! ***
          peter@iobroker:~$
          Komischerweise steht im IOB folgendes:
          CPU: 14,58 %
          RAM: 28 %
          Betriebszeit: 0h
          Verfügbar: 7.0.6
          Installiert: 7.0.6
          Ereignisse: ⇥40 / ↦13
          Plattform: linux
          Betriebssystem: linux
          Architektur: x64
          CPUs: 4
          Geschwindigkeit: 2799 MHz
          Modell: Intel(R) Celeron(R) N5105 @ 2.00GHz
          RAM: 8 GB
          System-Betriebszeit: 00:00:48
          Node.js: v18.20.6
          time: 1738393951080
          timeOffset: -60
          NPM: 10.8.2
          Adapter-Anzahl: 559
          Datenträgergröße: 13.7 GB
          Freier Festplattenspeicher: 5.3 GB
          Aktive Instanzen: 7
          Pfad: /opt/iobroker/
          Betriebszeit: 00:00:43
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
            peter@iobroker:~$
            CPU: 14,58 %
            RAM: 28 %
            Betriebszeit: 0h
            Verfügbar: 7.0.6
            Installiert: 7.0.6
            Plattform: linux
            Architektur: x64
            CPUs: 4
            RAM: 8 GB
            Node.js: v18.20.6
            time: 1738393951080
            timeOffset: -60
            NPM: 10.8.2
            Adapter-Anzahl: 559
            Aktive Instanzen: 7
            #216
            Alles richtig. ioBroker-GUI neuladen.
              shellyrulestheworld
              #217
              @thomas-braun perfekt. Wie immer: herzlichen Dank für deinen Support :-)
                Maddin77
                #218
                Servus zusammen
                hoffe ich darf hier bissi Fragen
                ich bin ziemlich neu in der Welt
                und IOB möchte gerne das ich Node update, allerdings habe ich ziemlich keine Ahnung davon
                bei mir läuft IOB auf einem Synology NAS als Container
                soll ich im NAS Terminal updaten oder im IOB
                was wäre zu bevorzugen?
                danke schon mal für eure hilfe
                • M Maddin77
                  Servus zusammen
                  #219
                  @maddin77
                  Von welcher Version auf welche neue Version?
                    @maddin77
                    Maddin77
                    #220
                    @thomas-braun sagte in Wir Empfehlen: Node.js 20.x :-):
                    @maddin77
                    im Terminal wird mir das angezeigt
                    /opt/iobroker$ node -v
                    v18.20.3
                    /opt/iobroker$
                    manche Adapter schreiben einfach >20
                    • M Maddin77
                      @maddin77
                      v18.20.3
                      /opt/iobroker$
                      #221
                      @maddin77
                      Dann roll einen aktuellen Container drüber.
                        @maddin77
                        Maddin77
                        #222
                        @maddin77
                        ist das dann mit
                        sudo apt-get install -y nodejs
                        • M Maddin77
                          @maddin77
                          ist das dann mit
                          #223
                          @maddin77
                          Nein. Du nimmst das aktuelle Container-Image und tauschst die Umgebung für den ioBroker aus.
                            @maddin77
                            Maddin77
                            #224
                            o-Gott
                            da bin ich aktuell etwas überfordert damit, sorry
                            Thomas BraunT Samson71S 2 Antworten Letzte Antwort
                            • M Maddin77
                              o-Gott
                              #225
                              @maddin77
                              Gibt Anleitungen dazu.
                              Du musst deine Kiste ja verwalten und pflegen können.
                                Maddin77
                                #226
                                theoretisch wäre das schön, ja
                                aber das meiste macht man selten.
                                ich hoffe immer das Adapter Update im IOB langt.......
                                aber so ein komplett hab ich immer zu viel angst, das danach was nicht mehr geht und ich nicht weiter komme.
                                aber dann werde ich wohl mal lesen und suchen müssen
                                danke
                                • M Maddin77
                                  danke
                                  #227
                                  @maddin77 sagte in Wir Empfehlen: Node.js 20.x :-):
                                  Nein, tut es nicht.
                                  Ja. Irgendwie haste das Ding ja auch drauf bekommen.
                                  • M Maddin77
                                    o-Gott
                                    Samson71S Offline
                                    Samson71S Offline
                                    Samson71
                                    #228
                                    Dann werfe ich mal die ernsthafte Frage in den Raum warum man dann Container/Docker-Umgebungen nutzt anstatt das System nativ mit Debian auf einem Raspi oder Mini-PC zu betreiben.
                                    Markus
                                    Bitte beachten:
                                    • Samson71S Samson71
                                      Maddin77
                                      #229
                                      @samson71 sagte in Wir Empfehlen: Node.js 20.x :-):
                                      weil man von beiden keine Ahnung hat, ein NAS im Haus war für Datensicherung.....
                                      und so ist eins zum anderen gekommen.....
                                      und irgendwie mit etwas Hilfe von Freunden und viel Lesen ist es dann irgendwann letztes jahr gelaufen.
                                      Aber ich frag lieber bevor ich was kaputt mache oder einen umständlichen Weg gehe.
                                      Mehr als zugeben das ich mich nicht gut auskenne, kann ich nun mal nicht.
                                      Werde aber wahrscheinlich nicht der einzigste sein 😖
                                      und ich habe auch keine Lust meine ganzen Daten zu verlieren nur weil ich zu stolz bin zu fragen.
                                      hoffe das ist okay
                                      Samson71S ? 2 Antworten Letzte Antwort
                                      • M Maddin77
                                        hoffe das ist okay
                                        Samson71S Offline
                                        Samson71S Offline
                                        Samson71
                                        #230
                                        Sehr weise ;)
                                        Absolut nicht. Ich bekenne ioBroker selber auf einer Syno unter Docker genutzt zu haben, bin aber davon aber weg weil ich mit Docker prinzipiell irgendwie nicht warm geworden bin.
                                        Das wäre wohl das dümmste was man tun könnte
                                        hoffe das ist okay
                                        Selbstverständlich
                                        Markus
                                        Bitte beachten:
                                        • M Maddin77
                                          hoffe das ist okay
                                          #231
                                          @maddin77
                                          dass du fragst, und sagst, wie dein Wissensstand ist, ist doch super!
                                          Viele markieren hier den Helden, und machen vieles falsch.
                                          Zum upgraden des Dockers ist zuerst das Backup wichtig, hier am besten einmal mit dem Backitup-Adapter den iobroker sichern auf ein anderes Device oder auf dem Nas in einen anderen Ordner.
                                          Dann stoppst du den Container und kopierst das komplette iobroker-Verzeichnis unter /docker zur Sicherheit
                                          Dann erst die aktuelle Docker-Version mit Node 20 (sollte was mit V10 sein) pullen.
                                          Nutzt du Portainer? Welches Nas? synology?
                                          M 2 Antworten Letzte Antwort
