  4. Zigbee Adapter schmeißt warnungen
    1.0k
    6.1k
32 Beiträge 7 Kommentatoren 4.0k Aufrufe 5 Beobachtet
    @autodidakt
    Ist jedenfalls eine bessere Idee als 'irgendwas wild' in die neue Installation zu kopieren.
    AutodidaktA Offline
    AutodidaktA Offline
    Autodidakt
    @thomas-braun Super Sache, Danke für eure Hilfe. Jetzt komm ich wieder ein Stück weiter...
    • AutodidaktA Offline
      AutodidaktA Offline
      Autodidakt
      Und was könnte denn da falsch gelaufen sein?
      node-red.0
      2025-06-25 20:50:44.811	error	Node-RED: Error: Install failed at /opt/iobroker/node_modules/@node-red/registry/lib/installer.js:288:25 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) 25 Jun 20:50:44 - [error] Error: Install failed at /opt/iobroker/node_modules/@node-red/registry/lib/installer.js:288:25 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      node-red.0
      2025-06-25 20:50:44.809	warn	Node-RED: 25 Jun 20:50:44 - [warn] npm warn config production Use `--omit=dev` instead. npm warn deprecated vis@4.21.0: Please consider using https://github.com/visjs npm error code 1 npm error path /opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings npm error command failed npm error command sh -c node-gyp rebuild npm error make: Entering directory '/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build' npm error CXX(target) Release/obj.target/bindings/src/serialport.o npm error make: Leaving directory '/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build' npm error gyp info it worked if it ends with ok npm error gyp info using node-gyp@8.4.1 npm error gyp info using node@20.19.3 | linux | arm64 npm error gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3" npm error gyp info spawn /usr/bin/python3 npm error gyp info spawn args [ npm error gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py', npm error gyp info spawn args 'binding.gyp', npm error gyp info spawn args '-f', npm error gyp info spawn args 'make', npm error gyp info spawn args '-I', npm error gyp info spawn args '/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/config.gypi', npm error gyp info spawn args '-I', npm error gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi', npm error gyp info spawn args '-I', npm error gyp info spawn args '/home/iobroker/.cache/node-gyp/20.19.3/include/node/common.gypi', npm error gyp info spawn args '-Dlibrary=shared_library', npm error gyp info spawn args '-Dvisibility=default', npm error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.3', npm error gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp', npm error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.3/<(target_arch)/node.lib', npm error gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings', npm error gyp info spawn args '-Dnode_engine=v8', npm error gyp info spawn args '--depth=.', npm error gyp info spawn args '--no-parallel', npm error gyp info spawn args '--generator-output', npm error gyp info spawn args 'build', npm error gyp info spawn args '-Goutput_dir=.' npm error gyp info spawn args ] npm error gyp info spawn make npm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ] npm error In file included from ../../../nan/nan.h:178, npm error from ../src/./serialport.h:13, npm error from ../src/serialport.cpp:1: npm error ../../../nan/nan_callbacks.h:55:23: error: ‘AccessorSignature’ is not a member of ‘v8’ npm error 55 | typedef v8::Local<v8::AccessorSignature> Sig; npm error | ^~~~~~~~~~~~~~~~~ npm error ../../../nan/nan_callbacks.h:55:40: error: template argument 1 is invalid npm error 55 | typedef v8::Local<v8::AccessorSignature> Sig; npm error | ^ npm error In file included from ../src/./serialport.h:13, npm error from ../src/serialport.cpp:1: npm error ../../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, Nan::GetterCallback, Nan::SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, Nan::imp::Sig)’: npm error ../../../nan/nan.h:2551:16: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&, Nan::imp::Sig&)’ npm error 2551 | , signature); npm error | ^ npm error In file included from /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-function.h:15, npm error from /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8.h:33, npm error from /home/iobroker/.cache/node-gyp/20.19.3/include/node/node.h:73, npm error from ../../../nan/nan.h:58, npm error from ../src/./serialport.h:13, npm error from ../src/serialport.cpp:1: npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:809:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ npm error 809 | void SetAccessor( npm error | ^~~~~~~~~~~ npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:814:22: note: no known conversion for argument 7 from ‘Nan::imp::Sig’ {aka ‘int’} to ‘v8::SideEffectType’ npm error 814 | SideEffectType getter_side_effect_type = SideEffectType::kHasSideEffect, npm error | ~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:816:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ npm error 816 | void SetAccessor( npm error | ^~~~~~~~~~~ npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:821:22: note: no known conversion for argument 7 from ‘Nan::imp::Sig’ {aka ‘int’} to ‘v8::SideEffectType’ npm error 821 | SideEffectType getter_side_effect_type = SideEffectType::kHasSideEffect, npm error | ~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 78 | uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 135 | uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 175 | uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 215 | uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 271 | uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 316 | uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 366 | uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 412 | uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: At global scope: npm error ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] npm error 433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) { npm error | ^ npm error ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] npm error 452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { npm error | ^ npm error In file included from ../../../nan/nan.h:58, npm error from ../src/./serialport.h:13, npm error from ../src/serialport.cpp:1: npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/node.h:1227:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] npm error 1227 | (node::addon_register_func) (regfunc), \ npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/node.h:1261:3: note: in expansion of macro ‘NODE_MODULE_X’ npm error 1261 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) npm error | ^~~~~~~~~~~~~ npm error ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’ npm error 486 | NODE_MODULE(serialport, init); npm error | ^~~~~~~~~~~ npm error make: *** [bindings.target.mk:109: Release/obj.target/bindings/src/serialport.o] Error 1 npm error gyp ERR! build error npm error gyp ERR! stack Error: `make` failed with exit code: 2 npm error gyp ERR! stack at ChildProcess.onExit (/opt/iobroker/node_modules/node-gyp/lib/build.js:194:23) npm error gyp ERR! stack at ChildProcess.emit (node:events:524:28) npm error gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:293:12) npm error gyp ERR! System Linux 6.1.21-v8+ npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild" npm error gyp ERR! cwd /opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings npm error gyp ERR! node -v v20.19.3 npm error gyp ERR! node-gyp -v v8.4.1 npm error gyp ERR! not ok npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-25T18_50_27_905Z-debug-0.log 25 Jun 20:50:44 - [warn] ------------------------------------------
      node-red.0
      2025-06-25 20:50:44.808	warn	Node-RED: 25 Jun 20:50:44 - [warn] ------------------------------------------
      node-red.0
      2025-06-25 20:50:44.807	warn	Node-RED: 25 Jun 20:50:44 - [warn] Installation of module node-red-contrib-zigbee failed:
      • AutodidaktA Autodidakt
        Hallo und guten Abend.
        Mein Zigbee Adapter V 2.0.5 Gibt bei jedem Start Warnungen aus.
        zigbee.0
        2025-06-25 20:16:20.380	warn	ELEVATED:I02 (1a87) value generated '100' from device ffffb40e060599a0 for 'Battery percent'
        zigbee.0
        2025-06-25 20:16:20.379	warn	ELEVATED:I01 (1a87) message received '{"battery":100}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:20.378	warn	ELEVATED:I02 (1a87) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:16:20.377	warn	ELEVATED:I01 (1a87) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:20.373	warn	ELEVATED:NOVAL (1a83) No value published for device ffffb40e060599a0
        zigbee.0
        2025-06-25 20:16:20.373	warn	ELEVATED:I01 (1a83) message received '{}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:20.371	warn	ELEVATED:I02 (1a83) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:16:20.371	warn	ELEVATED:I01 (1a83) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:20.367	warn	ELEVATED:I02 (1a7b) value generated '0' from device ffffb40e060599a0 for 'Humidity'
        zigbee.0
        2025-06-25 20:16:20.367	warn	ELEVATED:I01 (1a7b) message received '{"humidity":0}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:20.366	warn	ELEVATED:I02 (1a7b) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:16:20.366	warn	ELEVATED:I01 (1a7b) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:20.365	warn	ELEVATED:I02 (1a79) value generated '30.81' from device ffffb40e060599a0 for 'Temperature'
        zigbee.0
        2025-06-25 20:16:20.365	warn	ELEVATED:I01 (1a79) message received '{"temperature":30.81}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:20.363	warn	ELEVATED:I02 (1a79) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:16:20.362	warn	ELEVATED:I01 (1a79) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:20.359	warn	ELEVATED:I01 (1a87) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":211,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:16:20.356	warn	ELEVATED:I01 (1a83) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":16},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":210,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:16:20.347	warn	ELEVATED:I01 (1a7b) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":225,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":209,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:16:20.345	warn	ELEVATED:I01 (1a79) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":3081},"linkquality":225,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":208,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:16:05.388	warn	ELEVATED:I02 (dfee) value generated '100' from device ffffb40e060599a0 for 'Battery percent'
        zigbee.0
        2025-06-25 20:16:05.387	warn	ELEVATED:I01 (dfee) message received '{"battery":100}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:05.385	warn	ELEVATED:I02 (dfee) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:16:05.385	warn	ELEVATED:I01 (dfee) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:05.380	warn	ELEVATED:NOVAL (dfed) No value published for device ffffb40e060599a0
        zigbee.0
        2025-06-25 20:16:05.380	warn	ELEVATED:I01 (dfed) message received '{}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:05.378	warn	ELEVATED:I02 (dfed) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:16:05.377	warn	ELEVATED:I01 (dfed) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:05.369	warn	ELEVATED:I02 (dfe1) value generated '0' from device ffffb40e060599a0 for 'Humidity'
        zigbee.0
        2025-06-25 20:16:05.369	warn	ELEVATED:I01 (dfe1) message received '{"humidity":0}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:05.368	warn	ELEVATED:I02 (dfe1) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:16:05.367	warn	ELEVATED:I01 (dfe1) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:05.366	warn	ELEVATED:I02 (dfdd) value generated '30.81' from device ffffb40e060599a0 for 'Temperature'
        zigbee.0
        2025-06-25 20:16:05.366	warn	ELEVATED:I01 (dfdd) message received '{"temperature":30.81}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:05.365	warn	ELEVATED:I02 (dfdd) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:16:05.364	warn	ELEVATED:I01 (dfdd) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:05.358	warn	ELEVATED:I01 (dfee) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":207,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:16:05.357	warn	ELEVATED:I01 (dfed) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":16},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":206,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:16:05.345	warn	ELEVATED:I01 (dfe1) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":225,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":205,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:16:05.341	warn	ELEVATED:I01 (dfdd) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":3081},"linkquality":225,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":204,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:16:05.293	warn	ELEVATED:I02 (df38) value generated '0' from device ffffb40e060599a0 for 'Humidity'
        zigbee.0
        2025-06-25 20:16:05.292	warn	ELEVATED:I01 (df38) message received '{"humidity":0}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:05.290	warn	ELEVATED:I02 (df38) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:16:05.290	warn	ELEVATED:I01 (df38) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:05.289	warn	ELEVATED:I02 (df2e) value generated '30.81' from device ffffb40e060599a0 for 'Temperature'
        zigbee.0
        2025-06-25 20:16:05.288	warn	ELEVATED:I01 (df2e) message received '{"temperature":30.81}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:05.286	warn	ELEVATED:I02 (df2e) value generated '229' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:16:05.286	warn	ELEVATED:I01 (df2e) message received '{"linkquality":229}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:16:05.176	warn	ELEVATED:I01 (df38) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":225,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":203,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:16:05.166	warn	ELEVATED:I01 (df2e) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":3081},"linkquality":229,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":202,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:15:50.311	warn	ELEVATED:I02 (a50e) value generated '100' from device ffffb40e060599a0 for 'Battery percent'
        zigbee.0
        2025-06-25 20:15:50.311	warn	ELEVATED:I01 (a50e) message received '{"battery":100}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:50.309	warn	ELEVATED:I02 (a50e) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:15:50.308	warn	ELEVATED:I01 (a50e) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:50.305	warn	ELEVATED:NOVAL (a50b) No value published for device ffffb40e060599a0
        zigbee.0
        2025-06-25 20:15:50.305	warn	ELEVATED:I01 (a50b) message received '{}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:50.303	warn	ELEVATED:I02 (a50b) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:15:50.302	warn	ELEVATED:I01 (a50b) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:50.299	warn	ELEVATED:I02 (a4f7) value generated '0' from device ffffb40e060599a0 for 'Humidity'
        zigbee.0
        2025-06-25 20:15:50.298	warn	ELEVATED:I01 (a4f7) message received '{"humidity":0}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:50.297	warn	ELEVATED:I02 (a4f7) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:15:50.296	warn	ELEVATED:I01 (a4f7) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:50.295	warn	ELEVATED:I02 (a4f1) value generated '30.81' from device ffffb40e060599a0 for 'Temperature'
        zigbee.0
        2025-06-25 20:15:50.295	warn	ELEVATED:I01 (a4f1) message received '{"temperature":30.81}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:50.292	warn	ELEVATED:I02 (a4f1) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:15:50.292	warn	ELEVATED:I01 (a4f1) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:50.287	warn	ELEVATED:I01 (a50e) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":201,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:15:50.283	warn	ELEVATED:I01 (a50b) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":16},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":200,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:15:50.263	warn	ELEVATED:I01 (a4f7) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":225,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":199,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:15:50.258	warn	ELEVATED:I01 (a4f1) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":3081},"linkquality":225,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":198,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:15:39.159	warn	ELEVATED:I02 (7990) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:15:39.159	warn	ELEVATED:I01 (7990) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:39.158	warn	ELEVATED:NOCONV (7990) No converter available for '3RSM0147Z' 'ffffb40e060599a0' with cluster 'genBasic' and type 'attributeReport'
        zigbee.0
        2025-06-25 20:15:39.152	warn	ELEVATED:I01 (7990) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"swBuildId":"v1.00.38"},"linkquality":225,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":197,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:15:37.184	warn	ELEVATED:I02 (71c5) value generated '100' from device ffffb40e060599a0 for 'Battery percent'
        zigbee.0
        2025-06-25 20:15:37.183	warn	ELEVATED:I01 (71c5) message received '{"battery":100}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:37.179	warn	ELEVATED:I02 (71c5) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:15:37.178	warn	ELEVATED:I01 (71c5) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:37.172	warn	ELEVATED:NOVAL (71c0) No value published for device ffffb40e060599a0
        zigbee.0
        2025-06-25 20:15:37.171	warn	ELEVATED:I01 (71c0) message received '{}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:37.168	warn	ELEVATED:I02 (71c0) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:15:37.167	warn	ELEVATED:I01 (71c0) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:37.158	warn	ELEVATED:I01 (71c5) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":196,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:15:37.152	warn	ELEVATED:I01 (71c0) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":16},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":195,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:15:36.071	warn	ELEVATED:I02 (6d85) value generated '10' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:15:36.070	warn	ELEVATED:I01 (6d85) message received '{"linkquality":10}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:36.070	warn	ELEVATED:I02 (6d85) value generated 'true' from device ffffb40e060599a0 for 'Available'
        zigbee.0
        2025-06-25 20:15:36.069	warn	ELEVATED:I01 (6d85) message received '{"available":true}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:35.187	warn	ELEVATED:I02 (6a04) value generated '0' from device ffffb40e060599a0 for 'Humidity'
        zigbee.0
        2025-06-25 20:15:35.186	warn	ELEVATED:I01 (6a04) message received '{"humidity":0}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:35.183	warn	ELEVATED:I02 (6a04) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:15:35.182	warn	ELEVATED:I01 (6a04) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:35.179	warn	ELEVATED:I02 (69fc) value generated '30.81' from device ffffb40e060599a0 for 'Temperature'
        zigbee.0
        2025-06-25 20:15:35.179	warn	ELEVATED:I01 (69fc) message received '{"temperature":30.81}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:35.177	warn	ELEVATED:I02 (69fc) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:15:35.176	warn	ELEVATED:I01 (69fc) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:15:35.172	warn	ELEVATED:I01 (6a04) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":225,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":194,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:15:35.164	warn	ELEVATED:I01 (69fc) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":3081},"linkquality":225,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":193,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
        zigbee.0
        2025-06-25 20:15:35.066	warn	ELEVATED:Ida (699a) Device '0xffffb40e060599a0' announced itself
        zigbee.0
        2025-06-25 20:14:54.818	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"dad0c14dc174ef11b4f0cd8c8fcc3fa0","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_dad0c14dc174ef11b4f0cd8c8fcc3fa0-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyACM0","manufacturer":"0658","serialNumber":"E3040A02-4A02-0113-1510-041500BFCC64","pnpId":"usb-0658_0200_E3040A02-4A02-0113-1510-041500BFCC64-if00","vendorId":"0658","productId":"0200"},{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
        zigbee.0
        2025-06-25 20:14:16.430	warn	ELEVATED:I02 (3665) value generated '10' from device ffffb40e060599a0 for 'Link quality'
        zigbee.0
        2025-06-25 20:14:16.429	warn	ELEVATED:I01 (3665) message received '{"linkquality":10}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:14:16.424	warn	ELEVATED:I02 (3664) value generated 'true' from device ffffb40e060599a0 for 'Available'
        zigbee.0
        2025-06-25 20:14:16.423	warn	ELEVATED:I01 (3664) message received '{"available":true}' from device ffffb40e060599a0 type '3RSM0147Z'
        zigbee.0
        2025-06-25 20:14:15.705	info	debug devices set to ["ffffb40e060599a0"]
        zigbee.0
        2025-06-25 20:14:15.666	info	Zigbee started
        zigbee.0
        2025-06-25 20:14:15.663	info	Currently 4 devices are joined:
        zigbee.0
        2025-06-25 20:14:15.663	info	0x8c65a3fffe5256c2 (addr 11312): ZBDongle-E - SONOFF Sonoff Zigbee 3.0 USB Dongle Plus (EFR32MG21) with router firmware (Router)
        zigbee.0
        2025-06-25 20:14:15.660	info	0x70b3d52b600a59f0 (addr 12676): TS011F_plug_3 - Tuya Smart plug (with power monitoring by polling) (Router)
        zigbee.0
        2025-06-25 20:14:15.419	info	0xffffb40e060599a0 (addr 22929): 3RSM0147Z - Third Reality Soil sensor (EndDevice)
        zigbee.0
        2025-06-25 20:14:15.391	info	0x0ceff6fffe5a0306 (addr 30247): SNZB-02D - SONOFF Temperature and humidity sensor with screen (EndDevice)
        zigbee.0
        2025-06-25 20:14:15.315	info	Unable to disable LED, unsupported function.
        zigbee.0
        2025-06-25 20:14:15.313	info	Zigbee-Herdsman started successfully with Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20240710}}
        zigbee.0
        2025-06-25 20:14:14.661	info	Starting Zigbee-Herdsman
        zigbee.0
        2025-06-25 20:14:14.659	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
        zigbee.0
        2025-06-25 20:14:14.606	info	Starting Adapter npm ...
        zigbee.0
        2025-06-25 20:14:14.604	info	--- creating device debug ---
        zigbee.0
        2025-06-25 20:14:14.600	info	delete old Backup files. keep only last 10
        zigbee.0
        2025-06-25 20:14:14.582	info	--> transmitPower : high+
        zigbee.0
        2025-06-25 20:14:14.571	info	init localConfig
        zigbee.0
        2025-06-25 20:14:14.540	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.3, js-controller: 7.0.6
        Hier die Ausgabe von IoB Diag
        ======== Start marking the full check here ===========
        ```bash
        Script v.2025-03-08
        *** BASE SYSTEM ***
           Static hostname: pi4-Master
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         20:19:41 up  8:00,  2 users,  load average: 0.63, 0.76, 0.72
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Wed 2025-06-25 20:19:42 CEST
                   Universal time: Wed 2025-06-25 18:19:42 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.8G        3.4G        374M        0.0K        4.1G        4.3G
        Swap:            99M         63M         36M
        Total:          7.9G        3.4G        410M
        Active iob-Instances:   45
                 7811 M total memory
                 3382 M used memory
                 3803 M active memory
                 3190 M inactive memory
                  374 M free memory
                   76 M buffer memory
                 3977 M swap cache
                   99 M total swap
                   63 M used swap
                   36 M free swap
        top - 20:19:42 up  8:00,  2 users,  load average: 0.63, 0.76, 0.72
        Tasks: 219 total,   2 running, 216 sleeping,   0 stopped,   1 zombie
        %Cpu(s): 15.3 us,  8.3 sy,  0.0 ni, 76.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   7811.3 total,    374.5 free,   3382.3 used,   4054.5 buff/cache
        MiB Swap:    100.0 total,     36.1 free,     63.9 used.   4298.3 avail Mem
        *** FAILED SERVICES ***
          UNIT              LOAD   ACTIVE SUB    DESCRIPTION
        * mosquitto.service loaded failed failed Mosquitto MQTT Broker
        1 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        /dev/root      ext4      220G   34G  178G  16% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
        /dev/sda1      vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
        [Wed Jun 25 12:19:18 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:84:59:3C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=e432a575-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Wed Jun 25 12:19:21 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Wed Jun 25 12:19:21 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Wed Jun 25 12:19:23 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        9.6G    /var/
        4.3G    /var/log
        4.1G    /var/log/journal/eefdb7bad79f4dbab7d9171e992a2beb
        3.4G    /var/lib
        Archived and active journals take up 4.0G in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        2.3G    /opt/iobroker/iobroker-data/
        1.3G    /opt/iobroker/iobroker-data/backup-objects
        775M    /opt/iobroker/iobroker-data/files
        156M    /opt/iobroker/iobroker-data/files/vis-2
        110M    /opt/iobroker/iobroker-data/node-red
        570M    /opt/iobroker/iobroker-data/backup-objects/historyDB_2022_11_16-02_45_10_backupiobroker.tar.gz
        461M    /opt/iobroker/iobroker-data/backup-objects/influxDB_2022_11_16-02_40_53_backupiobroker.tar.gz
        40M     /opt/iobroker/iobroker-data/objects.jsonl
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-0658_0200_E3040A02-4A02-0113-1510-041500BFCC64-if00
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_dad0c14dc174ef11b4f0cd8c8fcc3fa0-if00-port0
        *** ZigBee Settings ***
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyUSB0
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.19.3
        /usr/bin/node           v20.19.3
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.32.0
        nodejs:
          Installed: 20.19.3-1nodesource1
          Candidate: 20.19.3-1nodesource1
          Version table:
         *** 20.19.3-1nodesource1 600
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
             20.19.2-1nodesource1 600
             20.19.1-1nodesource1 600
             20.19.0-1nodesource1 600
             20.18.3-1nodesource1 600
             20.18.2-1nodesource1 600
             20.18.1-1nodesource1 600
             20.18.0-1nodesource1 600
             20.17.0-1nodesource1 600
             20.16.0-1nodesource1 600
             20.15.1-1nodesource1 600
             20.15.0-1nodesource1 600
             20.14.0-1nodesource1 600
             20.13.1-1nodesource1 600
             20.13.0-1nodesource1 600
             20.12.2-1nodesource1 600
             20.12.1-1nodesource1 600
             20.12.0-1nodesource1 600
             20.11.1-1nodesource1 600
             20.11.0-1nodesource1 600
             20.10.0-1nodesource1 600
             20.9.0-1nodesource1 600
             20.8.1-1nodesource1 600
             20.8.0-1nodesource1 600
             20.7.0-1nodesource1 600
             20.6.1-1nodesource1 600
             20.6.0-1nodesource1 600
             20.5.1-1nodesource1 600
             20.5.0-1nodesource1 600
             20.4.0-1nodesource1 600
             20.3.1-1nodesource1 600
             20.3.0-1nodesource1 600
             20.2.0-1nodesource1 600
             20.1.0-1nodesource1 600
             20.0.0-1nodesource1 600
             12.22.12~dfsg-1~deb11u7 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        pi4-Master          pi4-Master (version: 7.0.6, hostname: pi4-Master    , alive, uptime: 24898)
        Core adapters versions
        admin:          7.7.0
        javascript:     8.9.2
        nodejs modules from github:     5
        +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
        +-- iobroker.life360@0.2.21 (git+ssh://git@github.com/MiGoller/ioBroker.life360.git#888e08024c2d93d86aa6eb74f281c574dce86c42)
        +-- iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#0d037c0c9a025b193546f881f747c8f998bfc724)
        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
        +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
        Adapter State
        + system.adapter.admin.0                  : admin                 : pi4-Master                               -  enabled, port: 6969, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : pi4-Master                               -  enabled
        + system.adapter.backitup.0               : backitup              : pi4-Master                               -  enabled
        + system.adapter.ble.0                    : ble                   : pi4-Master                               -  enabled
        + system.adapter.cloud.0                  : cloud                 : pi4-Master                               -  enabled
        + system.adapter.ds18b20.0                : ds18b20               : pi4-Master                               -  enabled
        + system.adapter.epson_ecotank_et_2750.0  : epson_ecotank_et_2750 : pi4-Master                               -  enabled
          system.adapter.feiertage.0              : feiertage             : pi4-Master                               -  enabled
        + system.adapter.fritzbox.0               : fritzbox              : pi4-Master                               -  enabled
          system.adapter.fritzdect.0              : fritzdect             : pi4-Master                               - disabled
        + system.adapter.fullybrowser.0           : fullybrowser          : pi4-Master                               -  enabled
          system.adapter.ham.0                    : ham                   : pi4-Master                               - disabled
        + system.adapter.history.0                : history               : pi4-Master                               -  enabled
        + system.adapter.homeconnect.0            : homeconnect           : pi4-Master                               -  enabled
        + system.adapter.i2c.0                    : i2c                   : pi4-Master                               -  enabled
          system.adapter.ical.0                   : ical                  : pi4-Master                               -  enabled
          system.adapter.ical.1                   : ical                  : pi4-Master                               -  enabled
          system.adapter.ical.2                   : ical                  : pi4-Master                               -  enabled
          system.adapter.ical.3                   : ical                  : pi4-Master                               -  enabled
          system.adapter.ical.4                   : ical                  : pi4-Master                               -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: pi4-Master                               -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : pi4-Master                               -  enabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : pi4-Master                               -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : pi4-Master                               -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : pi4-Master                               -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: pi4-Master                               -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : pi4-Master                               -  enabled
        + system.adapter.influxdb.0               : influxdb              : pi4-Master                               -  enabled, port: 8086
        + system.adapter.iot.0                    : iot                   : pi4-Master                               -  enabled
        + system.adapter.javascript.0             : javascript            : pi4-Master                               -  enabled
        + system.adapter.knx.0                    : knx                   : pi4-Master                               -  enabled, bind: 192.168.178.185
        + system.adapter.lgtv.0                   : lgtv                  : pi4-Master                               -  enabled
          system.adapter.life360.0                : life360               : pi4-Master                               - disabled
        + system.adapter.meross.0                 : meross                : pi4-Master                               -  enabled
          system.adapter.midea.0                  : midea                 : pi4-Master                               - disabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : pi4-Master                               -  enabled, port: 54321
        + system.adapter.modbus.0                 : modbus                : pi4-Master                               -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : pi4-Master                               -  enabled, port: 1879, bind: 0.0.0.0
          system.adapter.mqtt.1                   : mqtt                  : pi4-Master                               - disabled, port: 1783, bind: 0.0.0.0
        + system.adapter.net-tools.0              : net-tools             : pi4-Master                               -  enabled
        + system.adapter.node-red.0               : node-red              : pi4-Master                               -  enabled, port: 1880, bind: 0.0.0.0
        + system.adapter.ping.0                   : ping                  : pi4-Master                               -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : pi4-Master                               -  enabled
          system.adapter.samsung.0                : samsung               : pi4-Master                               - disabled
        + system.adapter.scenes.0                 : scenes                : pi4-Master                               -  enabled
          system.adapter.schoolfree.0             : schoolfree            : pi4-Master                               -  enabled
        + system.adapter.shelly.0                 : shelly                : pi4-Master                               -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.shuttercontrol.0         : shuttercontrol        : pi4-Master                               -  enabled
        + system.adapter.simple-api.0             : simple-api            : pi4-Master                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.sonnen.0                 : sonnen                : pi4-Master                               -  enabled
        + system.adapter.sonoff.0                 : sonoff                : pi4-Master                               -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : pi4-Master                               -  enabled
        + system.adapter.sql.0                    : sql                   : pi4-Master                               -  enabled, port: 3307
        + system.adapter.tankerkoenig.0           : tankerkoenig          : pi4-Master                               -  enabled
        + system.adapter.telegram.0               : telegram              : pi4-Master                               -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.text2command.0           : text2command          : pi4-Master                               - disabled
        + system.adapter.tr-064.0                 : tr-064                : pi4-Master                               -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : pi4-Master                               -  enabled
        + system.adapter.tuya.0                   : tuya                  : pi4-Master                               -  enabled
          system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: pi4-Master                               -  enabled
          system.adapter.vis-2.0                  : vis-2                 : pi4-Master                               - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : pi4-Master                               -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : pi4-Master                               -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : pi4-Master                               -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : pi4-Master                               -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : pi4-Master                               -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : pi4-Master                               -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : pi4-Master                               -  enabled
          system.adapter.vis-metro.0              : vis-metro             : pi4-Master                               -  enabled
          system.adapter.vis-players.0            : vis-players           : pi4-Master                               -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : pi4-Master                               -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : pi4-Master                               -  enabled
          system.adapter.vis.0                    : vis                   : pi4-Master                               -  enabled
        + system.adapter.web.0                    : web                   : pi4-Master                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : pi4-Master                               -  enabled
        + system.adapter.worx.0                   : worx                  : pi4-Master                               -  enabled
        + system.adapter.zigbee.0                 : zigbee                : pi4-Master                               -  enabled, port: /dev/ttyUSB0
        + system.adapter.zwave2.0                 : zwave2                : pi4-Master                               -  enabled
        + instance is alive
        ioBroker-Repositories
        │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "admin"        : 7.6.17   , installed 7.7.0
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 3.2.2    , installed 3.2.2
        Adapter    "ble"          : 0.14.0   , installed 0.14.0
        Adapter    "ds18b20"      : 3.0.1    , installed 3.0.1
        Adapter    "epson_ecotank_et_2750": 1.0.1, installed 1.0.1
        Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
        Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
        Adapter    "fritzdect"    : 2.6.2    , installed 2.6.1  [Updatable]
        Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
        Adapter    "i2c"          : 1.2.1    , installed 1.2.1
        Adapter    "ical"         : 1.16.1   , installed 1.16.1
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "knx"          : 2.0.30   , installed 2.0.30
        Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
        Adapter    "meross"       : 1.17.0   , installed 1.17.0
        Adapter    "midea"        : 0.0.7    , installed 0.1.0
        Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
        Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
        Adapter    "samsung"      : 0.6.1    , installed 0.6.1
        Adapter    "scenes"       : 3.2.3    , installed 4.0.2
        Adapter    "schoolfree"   : 1.1.9    , installed 1.1.9
        Adapter    "shelly"       : 9.5.1    , installed 9.5.1
        Adapter    "shuttercontrol": 2.0.1   , installed 2.0.1
        Adapter    "socketio"     : 6.7.1    , installed 7.0.8
        Adapter    "sonnen"       : 1.18.1   , installed 1.18.1
        Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
        Adapter    "sql"          : 3.0.1    , installed 3.0.1
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
        Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.2.7
        Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "worx"         : 3.2.4    , installed 3.2.4
        Adapter    "ws"           : 2.6.2    , installed 3.0.19
        Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
        Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
        Objects and States
        Objects:        19833
        States:         17847
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://repos.influxdata.com/debian stable InRelease
        Hit:6 https://apt.grafana.com stable InRelease
        Hit:7 https://repos.influxdata.com/debian stretch InRelease
        Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       189723     25382/iobroker.js-c
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       188953     25382/iobroker.js-c
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14559      654/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:1879            0.0.0.0:*               LISTEN      1001       190455     25928/io.mqtt.0
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       190059     25580/node-red
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       195060     26220/io.sonoff.0
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        11677      696/influxd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14562      654/sshd: /usr/sbin
        tcp6       0      0 :::1821                 :::*                    LISTEN      1001       195880     26380/io.ds18b20.0
        tcp6       0      0 :::3030                 :::*                    LISTEN      1001       191039     25693/io.fullybrows
        tcp6       0      0 :::3000                 :::*                    LISTEN      110        15485      808/grafana
        tcp6       0      0 :::6969                 :::*                    LISTEN      1001       189057     25400/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       196567     26747/io.web.0
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       194545     26471/io.simple-api
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        13294      696/influxd
        udp        0      0 192.168.178.185:33436   0.0.0.0:*                           1001       970178     25847/io.knx.0
        udp        0      0 192.168.178.185:37561   0.0.0.0:*                           1001       934363     25847/io.knx.0
        udp        0      0 192.168.178.185:50320   0.0.0.0:*                           1001       851723     25847/io.knx.0
        udp        0      0 192.168.178.185:38034   0.0.0.0:*                           1001       1204940    25847/io.knx.0
        udp        0      0 192.168.178.185:5353    0.0.0.0:*                           1001       195713     26246/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11598      522/avahi-daemon: r
        udp        0      0 192.168.178.185:38188   0.0.0.0:*                           1001       503118     25847/io.knx.0
        udp        0      0 192.168.178.185:42299   0.0.0.0:*                           1001       1199623    25847/io.knx.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       191462     26127/io.shelly.0
        udp        0      0 192.168.178.185:58972   0.0.0.0:*                           1001       934750     25847/io.knx.0
        udp        0      0 192.168.178.185:38501   0.0.0.0:*                           1001       306739     25847/io.knx.0
        udp        0      0 0.0.0.0:55133           0.0.0.0:*                           108        11600      522/avahi-daemon: r
        udp        0      0 192.168.178.185:39140   0.0.0.0:*                           1001       968220     25847/io.knx.0
        udp        0      0 192.168.178.185:47373   0.0.0.0:*                           1001       318632     25847/io.knx.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       196195     26279/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       196196     26279/io.tuya.0
        udp        0      0 192.168.178.185:43684   0.0.0.0:*                           1001       1013029    25847/io.knx.0
        udp        0      0 192.168.178.185:39720   0.0.0.0:*                           1001       931937     25847/io.knx.0
        udp        0      0 192.168.178.185:56110   0.0.0.0:*                           1001       911755     25847/io.knx.0
        udp        0      0 192.168.178.185:60235   0.0.0.0:*                           1001       474397     25847/io.knx.0
        udp        0      0 192.168.178.185:39839   0.0.0.0:*                           1001       999258     25847/io.knx.0
        udp        0      0 192.168.178.185:39989   0.0.0.0:*                           1001       201298     25847/io.knx.0
        udp        0      0 192.168.178.185:56379   0.0.0.0:*                           1001       325796     25847/io.knx.0
        udp        0      0 192.168.178.185:48380   0.0.0.0:*                           1001       194001     25847/io.knx.0
        udp        0      0 192.168.178.185:44379   0.0.0.0:*                           1001       850925     25847/io.knx.0
        udp        0      0 192.168.178.185:60959   0.0.0.0:*                           1001       1009835    25847/io.knx.0
        udp        0      0 192.168.178.185:32847   0.0.0.0:*                           1001       205725     25847/io.knx.0
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       192258     25902/io.mihome-vac
        udp        0      0 192.168.178.185:41156   0.0.0.0:*                           1001       302699     25847/io.knx.0
        udp        0      0 192.168.178.185:41274   0.0.0.0:*                           1001       190969     25580/node-red
        udp6       0      0 :::5353                 :::*                                108        11599      522/avahi-daemon: r
        udp6       0      0 :::41173                :::*                                108        11601      522/avahi-daemon: r
        2025-06-25 20:16:20.378  - warn: zigbee.0 (154603) ELEVATED:I02 (1a87) value generated '225' from device ffffb40e060599a0 for 'Link quality'
        2025-06-25 20:16:20.379  - warn: zigbee.0 (154603) ELEVATED:I01 (1a87) message received '{"battery":100}' from device ffffb40e060599a0 type '3RSM0147Z'
        2025-06-25 20:16:20.380  - warn: zigbee.0 (154603) ELEVATED:I02 (1a87) value generated '100' from device ffffb40e060599a0 for 'Battery percent'
        2025-06-25 20:16:22.969  - info: influxdb.0 (25437) Store 501 buffered influxDB history points
        2025-06-25 20:17:02.120  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connected with secret 1750875422120_3859
        2025-06-25 20:17:02.972  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connection closed: disconnected
        2025-06-25 20:17:46.857  - info: influxdb.0 (25437) Store 501 buffered influxDB history points
        2025-06-25 20:18:01.564  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connected with secret 1750875481564_5212
        2025-06-25 20:18:02.386  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connection closed: disconnected
        2025-06-25 20:18:04.113  - debug: alexa2.0 (25628) Alexa-Remote HTTP2-PUSH: Send Ping
        2025-06-25 20:18:14.284  - debug: shuttercontrol.0 (26159) outsidetemperature changed: knx.0.Melden_Sensor.Wetterstation_Regensensor.Temperatur_Messwert | Value: 32.4°C
        2025-06-25 20:19:01.991  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connected with secret 1750875541990_2988
        2025-06-25 20:19:02.869  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connection closed: disconnected
        2025-06-25 20:19:16.824  - info: influxdb.0 (25437) Store 504 buffered influxDB history points
        2025-06-25 20:19:50.308  - debug: shuttercontrol.0 (26159) Lightsensor changed: knx.0.Melden_Sensor.Wetterstation_Regensensor.Helligjkeit_Süd_Messwert | Value: 10199.04lux
        2025-06-25 20:20:00.007  - debug: shuttercontrol.0 (26159) calculate astrodata ...
        2025-06-25 20:20:00.008  - debug: shuttercontrol.0 (26159) Sun Azimut: 296.6°
        2025-06-25 20:20:00.008  - debug: shuttercontrol.0 (26159) Sun Elevation: 7.9°
        2025-06-25 20:20:02.438  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connected with secret 1750875602437_3871
        2025-06-25 20:20:03.289  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connection closed: disconnected
        2025-06-25 20:20:24.266  - debug: shuttercontrol.0 (26159) outsidetemperature changed: knx.0.Melden_Sensor.Wetterstation_Regensensor.Temperatur_Messwert | Value: 32.3°C
        2025-06-25 20:20:43.970  - info: influxdb.0 (25437) Store 501 buffered influxDB history points
        2025-06-25 20:21:01.886  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connected with secret 1750875661886_7516
        2025-06-25 20:21:02.713  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connection closed: disconnected
        2025-06-25 20:21:04.114  - debug: alexa2.0 (25628) Alexa-Remote HTTP2-PUSH: Send Ping
        Kann mir jemand weiter helfen?
        Mfg
        Tom
        arteckA Offline
        arteckA Offline
        arteck
        @autodidakt
        ELEVATED
        bedeutet dass da irgend zu einem Gerät die Debug infos an sind
        steht hier was - >
        zigbee.0.info.debugmessages
        AutodidaktA 1 Antwort Letzte Antwort
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          @autodidakt sagte in Zigbee Adapter schmeißt warnungen:
          Könnte man evtl sehen, wenn du das direkte Log unter /opt/iobroker/logs
          Posten würdest und nicht den GUI-Hantier.
            AutodidaktA Offline
            AutodidaktA Offline
            Autodidakt
            schrieb am zuletzt editiert von Autodidakt
            2025-06-25 21:25:46.719  - warn: node-red.0 (25486) Node-RED: 25 Jun 21:25:46 - [warn] Installation of module node-red-contrib-zigbee failed:
            2025-06-25 21:25:46.720  - warn: node-red.0 (25486) Node-RED: 25 Jun 21:25:46 - [warn] ------------------------------------------
            25 Jun 21:25:46 - [warn] npm warn config production Use `--omit=dev` instead.
            npm error code 1
            npm error       |                                        ^
            npm error       |                ^
            npm error       |                            ^
            npm error       |                              ^
            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-25T19_25_26_960Z-debug-0.log
            pi@pi4-Master:~ $ tail /home/iobroker/.npm/_logs/2025-06-25T19_25_26_960Z-debug-0.log
            1028 silly unfinished npm timer build:deps 1750879540508
            1029 silly unfinished npm timer build:run:install 1750879540638
            1030 silly unfinished npm timer build:run:install:node_modules/zigbee-herdsman/node_modules/@serialport/bindings 1750879540657
            1031 verbose cwd /opt/iobroker/iobroker-data/node-red
            1032 verbose os Linux 6.1.21-v8+
            1033 verbose node v20.19.3
            1034 verbose npm  v10.8.2
            1035 verbose exit 1
            1036 verbose code 1
            1037 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-25T19_25_26_960Z-debug-0.log
            pi@pi4-Master:~ $
            • arteckA arteck
              @autodidakt
              ELEVATED
              steht hier was - >
              AutodidaktA Offline
              AutodidaktA Offline
              Autodidakt
              @arteck sagte in Zigbee Adapter schmeißt warnungen:
              @autodidakt
              ELEVATED
              steht hier was - >
              Nein, logstufe ist auf Info
                @autodidakt
                ELEVATED
                steht hier was - >
                arteckA Offline
                arteckA Offline
                arteck
                @autodidakt es geht nicht um die logstufe sondern um den eintrag da drin.. aber da wird ehh nix mehr drin stehen..
                • arteckA arteck
                  AutodidaktA Offline
                  AutodidaktA Offline
                  Autodidakt
                  @arteck Ich kann Dir nicht folgen...
                    Brokerti
                    Ich habe ein ähnliches Problem, allerdings steht bei mir nirgends was von Debug und der Käfer ist auch weiß.
                    • B Brokerti
                      AlexHaxe
                      @brokerti said in Zigbee Adapter schmeißt warnungen:
                      Bist Du sicher, dass Du die richtige Kachel angeschaut hast? Vielleicht sind bei Dir auch die Farben anders, wenn Du mit der Maus über dem Käfer "hoverst", was sagt der Tooltip? Er sollte "Enable Debug" anzeigen, wenn Debug ausgeschaltet ist (klingt komisch, ist aber so).
                      gfs. danach den Adapter neu starten, dabei auf Meldungen im Log schauen:
                      2025-06-25 20:14:15.705 info debug devices set to ["xxxxxxxx"]
                      Mit grünem Käfer wird in den eckigen Klammern eine Liste der Debug-Geräte angezeigt. Ohne Debug-Geräte sollte dort [] stehen.
                      • A AlexHaxe
                        Brokerti
                        @alexhaxe korrekt. Es steht dann enabled debug da. wenn ich Debug aktiviere, erhalte ich dennoch Nicht die besagte Debugmeldung!
                        Selbst wenn ich den BWM lösche und Batterien entferne kommen alle 15sec die Log Einträge.
                        Auch wenn ich ihn in der Instanz deaktiviere.
                        Folglich "spukt" sich die Instanz selbst etwas vor.
                        Vorhin habe ich mal auf "reconfigure" geklickt und damit kam dann zumindest die Occupancy Funktion zurück.
                        Angefangen hat das Problem, seit der Ventilator im Zimmer steht :D.
                        • B Brokerti
                          AlexHaxe
                          Das klingt sehr unwahrscheinlich. Ein Batterie-Gerät ohne Batterien sendet nichts. Bist Du Dir sicher, dass Du den richtigen Bewegungsmelder anschaust? Die Hex-Zahlen sehen sich ja immer zum Verwechseln ähnlich.
                          Die Meldung info debug devices set to [] kommt nur beim Hochfahren des Adapters, oder beim Anklicken der Käfer. Wobei die [] durch eine Liste der IDs ersetzt wird, sobald Debug aktiv ist.
                          Ob ein Ventilator mit einem Bewegungsmelder interagiert, bzw. dessen Belegt Status beeinflussen kann, entzieht sich derzeit meiner Kenntnis. Die Debug-Meldungen sind aber unabhängig davon.
                          • A AlexHaxe
                            Brokerti
                            @alexhaxe du hattest recht!
                            Ich hätte schwören können, ich war am richtigen BWM.
                            Nummer verglichen und siehe da, es war ein anderer. Weshalb dieser auf Debug stand, kann ich mir nicht erklären..
                            Somit wünsche ich eine ruhige und kühle Nacht. Vielen Dank! :)
                            • B Brokerti
                              AutodidaktA Offline
                              AutodidaktA Offline
                              Autodidakt
                              Was ist ein BWM?
                                Was ist ein BWM?
                                sigi234S Online
                                sigi234S Online
                                Was ist ein BWM?
                                Bewegungsmelder
                                • AutodidaktA Offline
                                  AutodidaktA Offline
                                  Autodidakt
                                  Kann niemand mit dieser Fehlermeldung etwas anfangen?
                                  2025-06-26T08:09:05.411Z Installieren : node-red-contrib-zigbee 0.21.0
                                  2025-06-26T08:09:05.300Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-zigbee@0.21.0
                                  2025-06-26T08:09:05.697Z [err] npm warn config production Use `--omit=dev` instead.
                                  2025-06-26T08:09:21.023Z [err] npm warn deprecated vis@4.21.0: Please consider using https://github.com/visjs
                                  2025-06-26T08:09:27.263Z [err] npm error code 1
                                  2025-06-26T08:09:27.264Z [err] npm error path /opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
                                  2025-06-26T08:09:27.264Z [err] npm error command failed
                                  2025-06-26T08:09:27.264Z [err] npm error command sh -c node-gyp rebuild
                                  2025-06-26T08:09:27.264Z [err] npm error make: Entering directory '/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
                                  2025-06-26T08:09:27.264Z [err] npm error   CXX(target) Release/obj.target/bindings/src/serialport.o
                                  2025-06-26T08:09:27.264Z [err] npm error make: Leaving directory '/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info it worked if it ends with ok
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info using node-gyp@8.4.1
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info using node@20.19.3 | linux | arm64
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn /usr/bin/python3
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args [
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   'binding.gyp',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-f',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   'make',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-I',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/config.gypi',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '/home/iobroker/.cache/node-gyp/20.19.3/include/node/common.gypi',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Dlibrary=shared_library',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Dvisibility=default',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.3',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.3/<(target_arch)/node.lib',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Dnode_engine=v8',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '--depth=.',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '--no-parallel',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '--generator-output',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   'build',
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Goutput_dir=.'
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args ]
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn make
                                  2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                                  2025-06-26T08:09:27.266Z [err] npm error In file included from ../../../nan/nan.h:178,
                                  2025-06-26T08:09:27.266Z [err] npm error                  from ../src/./serialport.h:13,
                                  2025-06-26T08:09:27.266Z [err] npm error                  from ../src/serialport.cpp:1:
                                  2025-06-26T08:09:27.266Z [err] npm error ../../../nan/nan_callbacks.h:55:23: error: ‘AccessorSignature’ is not a member of ‘v8’
                                  2025-06-26T08:09:27.266Z [err] npm error    55 | typedef v8::Local<v8::AccessorSignature> Sig;
                                  2025-06-26T08:09:27.266Z [err] npm error       |                       ^~~~~~~~~~~~~~~~~
                                  2025-06-26T08:09:27.266Z [err] npm error ../../../nan/nan_callbacks.h:55:40: error: template argument 1 is invalid
                                  2025-06-26T08:09:27.266Z [err] npm error In file included from ../src/./serialport.h:13,
                                  2025-06-26T08:09:27.266Z [err] npm error ../../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, Nan::GetterCallback, Nan::SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, Nan::imp::Sig)’:
                                  2025-06-26T08:09:27.266Z [err] npm error ../../../nan/nan.h:2551:16: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&, Nan::imp::Sig&)’
                                  2025-06-26T08:09:27.266Z [err] npm error  2551 |     , signature);
                                  2025-06-26T08:09:27.266Z [err] npm error In file included from /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-function.h:15,
                                  2025-06-26T08:09:27.266Z [err] npm error                  from /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8.h:33,
                                  2025-06-26T08:09:27.266Z [err] npm error                  from /home/iobroker/.cache/node-gyp/20.19.3/include/node/node.h:73,
                                  2025-06-26T08:09:27.266Z [err] npm error                  from ../../../nan/nan.h:58,
                                  2025-06-26T08:09:27.266Z [err] npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:809:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’
                                  2025-06-26T08:09:27.266Z [err] npm error   809 |   void SetAccessor(
                                  2025-06-26T08:09:27.266Z [err] npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:814:22: note:   no known conversion for argument 7 from ‘Nan::imp::Sig’ {aka ‘int’} to ‘v8::SideEffectType’
                                  2025-06-26T08:09:27.266Z [err] npm error   814 |       SideEffectType getter_side_effect_type = SideEffectType::kHasSideEffect,
                                  2025-06-26T08:09:27.266Z [err] npm error       |       ~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                  2025-06-26T08:09:27.266Z [err] npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:816:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’
                                  2025-06-26T08:09:27.266Z [err] npm error   816 |   void SetAccessor(
                                  2025-06-26T08:09:27.266Z [err] npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:821:22: note:   no known conversion for argument 7 from ‘Nan::imp::Sig’ {aka ‘int’} to ‘v8::SideEffectType’
                                  2025-06-26T08:09:27.266Z [err] npm error   821 |       SideEffectType getter_side_effect_type = SideEffectType::kHasSideEffect,
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  2025-06-26T08:09:27.266Z [err] npm error    78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                                  2025-06-26T08:09:27.266Z [err] npm error       |                                                   ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  2025-06-26T08:09:27.266Z [err] npm error   135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                                  2025-06-26T08:09:27.266Z [err] npm error       |                                                     ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  2025-06-26T08:09:27.266Z [err] npm error   175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  2025-06-26T08:09:27.266Z [err] npm error   215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  2025-06-26T08:09:27.266Z [err] npm error   271 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  2025-06-26T08:09:27.266Z [err] npm error   316 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  2025-06-26T08:09:27.266Z [err] npm error   366 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                                  2025-06-26T08:09:27.266Z [err] npm error       |                                                          ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  2025-06-26T08:09:27.266Z [err] npm error   412 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: At global scope:
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                                  2025-06-26T08:09:27.266Z [err] npm error   433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                                  2025-06-26T08:09:27.266Z [err] npm error   452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                                  2025-06-26T08:09:27.266Z [err] npm error In file included from ../../../nan/nan.h:58,
                                  2025-06-26T08:09:27.266Z [err] npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/node.h:1227:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                  2025-06-26T08:09:27.266Z [err] npm error  1227 |       (node::addon_register_func) (regfunc),                          \
                                  2025-06-26T08:09:27.266Z [err] npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/node.h:1261:3: note: in expansion of macro ‘NODE_MODULE_X’
                                  2025-06-26T08:09:27.266Z [err] npm error  1261 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                  2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
                                  2025-06-26T08:09:27.266Z [err] npm error   486 | NODE_MODULE(serialport, init);
                                  2025-06-26T08:09:27.266Z [err] npm error make: *** [bindings.target.mk:109: Release/obj.target/bindings/src/serialport.o] Error 1
                                  2025-06-26T08:09:27.266Z [err] npm error gyp ERR! build error
                                  2025-06-26T08:09:27.266Z [err] npm error gyp ERR! stack Error: `make` failed with exit code: 2
                                  2025-06-26T08:09:27.266Z [err] npm error gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/node-gyp/lib/build.js:194:23)
                                  2025-06-26T08:09:27.266Z [err] npm error gyp ERR! stack     at ChildProcess.emit (node:events:524:28)
                                  2025-06-26T08:09:27.266Z [err] npm error gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:293:12)
                                  2025-06-26T08:09:27.266Z [err] npm error gyp ERR! System Linux 6.1.21-v8+
                                  2025-06-26T08:09:27.266Z [err] npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                                  2025-06-26T08:09:27.266Z [err] npm error gyp ERR! cwd /opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
                                  2025-06-26T08:09:27.266Z [err] npm error gyp ERR! node -v v20.19.3
                                  2025-06-26T08:09:27.266Z [err] npm error gyp ERR! node-gyp -v v8.4.1
                                  2025-06-26T08:09:27.266Z [err] npm error gyp ERR! not ok
                                  2025-06-26T08:09:27.274Z [err] npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-26T08_09_05_562Z-debug-0.log
                                  2025-06-26T08:09:27.317Z rc=1
                                  • AutodidaktA Autodidakt
                                    doch!
                                    aber du bist falsch hier!
                                    hat nichts mit dem zigbee-Adapter zu tun!
                                      AutodidaktA Offline
                                      Autodidakt
                                      @homoran Achso, wo muss ich denn damit hin?
                                        roter und fetter konnte ich es nicht machen.
                                        es besteht natürlich noch die Möglichkeit dass du da gerade irgendwas ganz snderes tust.
                                        Da du nicht sagst was du tust, wenn diese Meldung auftritt, kann ich dir nicht sagen wohin du genau musst
                                          AutodidaktA Offline
                                          AutodidaktA Offline
                                          Autodidakt
                                          Ich möchte nur installieren.
                                          Ich möchte auf meinem Node red Dashboard einen ein/aus Button für ein zigbee Gerät.
                                          Ich weiß nicht, was ich Dir verheimlicht hätte...
                                          STOP! Node red schreibt, dass dieser Knoten aufgegeben wurde. IoB hat also nichts damit zu tun.
                                          Dank euch.
                                          Mfg
                                          Tom
