  4. Test DreameHome: 3D-Visualisierung und Alexa-Steuerung
    6.8k
123 Beiträge 16 Kommentatoren 16.5k Aufrufe 16 Beobachtet
  • wawyoW wawyo
    Changelog
    Version 0.9.0 (2025-03-21)
    New Features:
    • Alexa Command Recognition: The system now recognizes various cleaning commands and supports multiple languages (English and German). It processes different cleaning modes, room names, and suction/mopping levels.
      • Example Alexa command (English): "Alexa, vacuum the living room twice on high."
        Beispiel Alexa-Befehl (Deutsch): "Alexa, sauge das Wohnzimmer zweimal auf hoch."
    • Room Recognition: The system identifies specific rooms in a command and applies the requested cleaning mode. It can handle multiple rooms in a single command.
      • Example Alexa command (English): "Alexa, clean the kitchen and the bathroom."
        Beispiel Alexa-Befehl (Deutsch): "Alexa, reinige die Küche und das Badezimmer."
    • Cleaning Modes: New cleaning modes are available based on the provided AlexacleanModes, such as Vacuum (5122), Mopping (5121), and Mop after Vacuum (5123).
      • Example Alexa command (English): "Alexa, mop after vacuuming the bathroom."
        Beispiel Alexa-Befehl (Deutsch): "Alexa, wische nach dem Saugen im Badezimmer."
    • Suction and Mopping Levels: The system now recognizes different suction and mopping levels based on the provided levels and synonyms, allowing detailed cleaning requests.
      • Example Alexa command (English): "Alexa, vacuum the living room on strong and mop it on wet."
        Beispiel Alexa-Befehl (Deutsch): "Alexa, sauge das Wohnzimmer auf stark und wische es nass."
    • Cancellation of Cleaning: The system recognizes cancellation commands from the AlexacancelKeywords list and allows users to stop ongoing cleaning sessions.
      • Example Alexa command (English): "Alexa, cancel cleaning."
        Beispiel Alexa-Befehl (Deutsch): "Alexa, abbreche die Reinigung."
    Improvements:
    • Room-Specific Cleaning: Commands can now be given for specific rooms, and the robot will clean accordingly. If no room is specified, it will prompt the user to clarify.
      • Example Alexa command (English): "Alexa, clean the living room."
        Beispiel Alexa-Befehl (Deutsch): "Alexa, reinige das Wohnzimmer."
      • Response (English): "Please specify the cleaning mode for the living room."
        Antwort (Deutsch): "Bitte gib den Reinigungsmodus für das Wohnzimmer an."
    • Error Handling: The system now handles missing cleaning mode, suction level, or water level in commands by prompting for the missing information.
      • Example response (English): "Please specify the cleaning mode for the kitchen. You forgot to define the clean mode, suction level, or water level."
        Beispielantwort (Deutsch): "Bitte gib den Reinigungsmodus für die Küche an. Du hast den Reinigungsmodus, das Sauglevel oder den Wasserlevel vergessen zu definieren."
    Bug Fixes:
    • Command Ambiguity: Fixed an issue where commands for multiple rooms were misinterpreted or ignored when no cleaning mode was specified.
      • Example Alexa command (English): "Alexa, clean the kitchen and the bathroom without specifying the mode."
        Beispiel Alexa-Befehl (Deutsch): "Alexa, reinige die Küche und das Badezimmer, ohne den Modus anzugeben."
      • Response (English): "Please specify the cleaning mode for the kitchen and the bathroom."
        Antwort (Deutsch): "Bitte gib den Reinigungsmodus für die Küche und das Badezimmer an."
    Other Changes:
    • Enhanced Voice Feedback: The system now provides more detailed and helpful feedback via Alexa, especially when a command is incomplete or unclear.
      • Example feedback (English): "Cleaning mode: 5122 (Sweeping), Rooms: Living Room, Kitchen."
        Beispielfeedback (Deutsch): "Reinigungsmodus: 5122 (Staubsaugen), Räume: Wohnzimmer, Küche."
    wawyoW Offline
    wawyoW Offline
    wawyo
    Version 0.1.0
    Release-Datum: 30.03.2025
    Neuigkeiten:
    • Erweiterte Flexibilität bei der Reinigungssteuerung:
      Der Adapter ermöglicht es jetzt, für jedes Zimmer individuell festzulegen, ob der Dreame-Saugroboter nur saugt, wischt oder eine Kombination aus beiden ausführt. Dies geht über die standardmäßigen Einschränkungen des Dreame-Roboters hinaus, der normalerweise nur einen Reinigungsmodus für alle Räume akzeptiert.
    • Unterstützung für alternative Zimmer- und Reinigungsbezeichner:
      Die Zimmernamen und Reinigungsarten sind jetzt flexibler. Begriffe wie "Wohnzimmer wischen nass" oder "Stube wischen intensiv" werden automatisch als gleichwertig behandelt, sodass du verschiedene Begriffe verwenden kannst, um den gleichen Reinigungsmodus zu aktivieren.
    • Automatische Zuordnung von Räumen und Befehlen:
      Der Adapter übersetzt alternative Bezeichner für Räume (z. B. "Wohnzimmer", "Stube", "salon") in die akzeptierten Standardbezeichner, was eine nahtlose und benutzerfreundliche Steuerung ermöglicht. Ebenso werden verschiedene Formulierungen für das Saugen oder Wischen (z. B. "staubsaugen" oder "sweeping") korrekt erkannt und dem richtigen Reinigungsmodus zugeordnet.
    Beispiele für neue Befehle:
    • "Wohnzimmer wischen Nass" = "Stube wischen Intensiv"
    • "Schlafzimmer staubsaugen Kraftvoll" = "Hauptschlafzimmer saugen Intensiv" = "masterzimmer saugen Stark"
    • "Küche saugen und wischen Nass und Ultra" = "Kochnische saugen und wischen Durchnässt und Voll"
    Verbesserungen:
    • Vermeidung von doppelten oder widersprüchlichen Befehlen:
      Das System prüft automatisch, ob für ein und dasselbe Zimmer widersprüchliche Reinigungsmodi oder wiederholte Befehle innerhalb eines kurzen Zeitraums gesendet wurden, um unerwünschte Doppelaktionen zu vermeiden.
    • Bessere Steuerung bei aktiven Reinigungsprozessen:
      Sollte ein Reinigungsprozess bereits laufen, erkennt der Adapter dies und fragt den Benutzer, ob der laufende Prozess gestoppt und ein neuer gestartet werden soll. Dies sorgt für eine flüssige Benutzererfahrung und verhindert gleichzeitige Reinigungsvorgänge.
    Szenario 1: Mehrere Räume mit gemischten Modi und Wiederholungen
    • Befehl: „Wohnzimmer saugen hoch und Küche saugen mittel und Küche wischen niedrig 2 mal“
    • Erklärung:
      • „Wohnzimmer saugen hoch“: Der Roboter startet im Wohnzimmer mit dem Saugmodus auf hoher Stufe.
      • „Küche saugen mittel“: In der Küche wird der Saugmodus auf mittlerer Stufe eingestellt.
      • „Küche wischen niedrig 2 mal“: In der Küche wird der Wischmodus auf niedriger Stufe eingestellt, und der Wischvorgang wird zweimal wiederholt.
      Aktion: Der Roboter wird zuerst das Wohnzimmer reinigen (Saugen hoch), dann die Küche (Saugen mittel), und danach den Wischmodus auf niedrig in der Küche zweimal ausführen.
    Szenario 2: Zwei Räume mit einem Modus (nur Saugen oder Wischen)
    • Befehl: „Flur saugen hoch und Bad wischen intensiv“
    • Erklärung:
      • „Flur saugen hoch“: Der Roboter wird im Flur mit dem höchsten Saugmodus arbeiten.
      • „Bad wischen intensiv“: Das Bad wird mit dem höchsten Wischmodus (Intensiv) gewischt.
      Aktion: Der Roboter startet mit dem Saugen im Flur auf hoher Stufe und geht danach ins Bad, um dort intensiv zu wischen.
    Szenario 3: Benutzerabbruch bei fehlenden Modi
    • Befehl: „Wohnzimmer saugen und Küche wischen“
    • Erklärung:
      • Der Befehl fehlt für das „Saugen“ im Küchenbereich, was eine unvollständige Anweisung darstellt.
      Aktion: Da in der Küche der Saugmodus nicht angegeben wurde und eine Lücke im Befehl erkannt wird, fordert Alexa den Benutzer auf, den fehlenden Modus zu korrigieren.
      Antwort von Alexa: „Für folgende Räume fehlen Angaben: Wohnzimmer: Sauglevel und Küche: Wischlevel. Bitte definiere die fehlenden Werte.“
    Szenario 4: Unterschiedliche Reinigungsmodi mit Raum- und Modus-Synonymen
    • Befehl: „Stube saugen intensiv und Küche wischen nach saugen niedrig und kraftvoll und Bad wischen intensiv“
    • Erklärung:
      • Der Benutzer verwendet das Synonym „Stube“ anstelle von „Wohnzimmer“. Da Dreamehome diese Flexibilität unterstützt, wird „Stube“ als „Wohnzimmer“ erkannt und der Modus „Saugen intensiv“ wird zugeordnet.
      • Die Küche wird mit „Saugen niedrig danach Wischen stark“ und das Bad mit „Wischen intensiv“ gereinigt.
      Aktion: Der Roboter wird die folgenden Schritte ausführen:
      • Stube (Wohnzimmer) saugen intensiv
      • Küche wischen niedrig nach saugen stark
      • Bad wischen intensiv
    Szenario 5: Wiederholte Reinigung eines Raumes
    • Befehl: „Wohnzimmer saugen hoch 3 mal und Bad wischen intensiv 2 mal“
    • Erklärung:
      • Der Roboter soll das Wohnzimmer dreimal mit dem Saugmodus „hoch“ und das Bad zweimal mit dem Wischmodus „intensiv“ reinigen.
      Aktion: Der Roboter startet die Reinigung im Wohnzimmer mit hohem Saugmodus und wiederholt den Vorgang dreimal. Danach geht er ins Bad, um zweimal mit dem intensiven Wischmodus zu reinigen.
    Szenario 6: Beenden der Reinigung, wenn ein Abbruchbefehl gegeben wird
    • Befehl: „"reinigung abbrechen", "reinigung stoppen", "stop reinigung", "roboter aus", "reinigung bitte abbrechen", "reinigung beenden", "reinigung unterbrechen", "reinigung anhalten", "saugvorgang stoppen", "staubsauger aus", "roboter abschalten", "staubsaugen beenden", "putzen stoppen", "staubsaugen stoppen", "staubsaugen deaktivieren", "bodenreinigung stoppen", "staubsauger ausschalten", "sauger aus", "roboter deaktivieren", "dreame stoppen", "dreame aus", "dreame reinigen beenden"“
    • Erklärung:
      • Ein Benutzer kann jederzeit den Befehl „Stopp Reinigung“ geben, um den laufenden Vorgang zu beenden.
      Aktion: Wenn der Befehl zum Stoppen der Reinigung kommt, wird der Roboter sofort gestoppt und zur Ladestation zurückgeschickt. Falls der Roboter gerade aktiv reinigt, wird der Vorgang abgebrochen.
      Antwort von Alexa: „Die Reinigung wurde gestoppt und der Roboter fährt zur Ladestation.“
    • wawyoW wawyo
      Version 0.1.0
      Neuigkeiten:
      Verbesserungen:
      • Erklärung:
      • Erklärung:
      • Erklärung:
      • Erklärung:
      • Erklärung:
      • Erklärung:
      mcm1957M Offline
      mcm1957M Offline
      mcm1957
      @wawyo
      DANKE dass du an einem Adapter für ioBroker arbeitest.
      Bitte ergänze deinen Adapter um die standardmäßig vom adapter creator auch angelegten Github based tests aus. Minimales Testing sollten auch Dapetr haben die (zunächst) nur via Github zum Testen angeboten werden.
      Beim ersten Blick in dein repo fällt auf:
      • github based tests (workflow test-and-release) fehlt
      • README Changelog bitte in die übliche Form bringen (schau bei anderen Adaptern rein) damit das Release Scritp dir die Arbeit des erstellens einer sauberen Release abnehmen kann
      Wenn der Adapter für User testbar / verwendbar ist, veranlass dann bitte ein Review und eine Aufnehme in die Repositories.
      https://github.com/ioBroker/ioBroker.repositories?tab=readme-ov-file#requirements-for-adapter-to-get-added-to-the-latest-repository
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      wawyoW 1 Antwort Letzte Antwort
      • mcm1957M mcm1957
        @wawyo
        wawyoW Offline
        wawyoW Offline
        wawyo
        schrieb am zuletzt editiert von wawyo
        Update 0.1.2 (06.04.2025)
        Neue Funktionen und Verbesserungen:
        • Komponentensteuerung und Statusmeldungen:
          -Unterstützung für die Steuerung und Statusprüfung der folgenden Komponenten hinzugefügt:
          • Hauptbürste, Seitenbürste, Filter, Wischbezug, Silberionen, Reinigungsmittel, Reinwassertank, Schmutzwassertank
        • Rücksetzen einzelner oder aller Komponenten möglich.
        • Statusberichte für Komponenten wie verbleibende Zeit (z. B. verbleibende Wischpad-Zeit, verbleibende Hauptbürsten-Zeit)
        • Flexible Befehlserkennung:
          • Befehle wie Entleeren (Leeren, Automatisches Entleeren, Behälter reinigen usw.) und Wischmoppreinigung (Waschen, Automatisches Waschen, Wischmopp reinigen usw.) werden jetzt erkannt und lösen die entsprechenden Aktionen aus.
          • Unterstützung für das Zurücksetzen einzelner oder aller Komponenten mit Befehlen wie „Hauptbürste zurücksetzen“, „Alle zurücksetzen“ usw.
          • Komponentenspezifische Statusabfragen über flexible Synonyme wie „Hauptbürstenstatus prüfen“ oder „Wischpad prüfen“.
        • Verbesserte Befehlsflexibilität:
          • Dynamische Befehlsanalyse: Der Befehlsparser erkennt jetzt verschiedene Synonyme für Roboterbefehle (Roboter, Staubsauger, Dreame usw.), Entleeren (Leeren, automatisches Entleeren usw.), Waschen (Waschen, Wischmoppreinigung usw.) und Zurücksetzen von Komponenten (Hauptbürste zurücksetzen, Alles zurücksetzen usw.).
          • Sprachspezifische Synonyme: Befehle werden dynamisch basierend auf der Sprache (EN/DE) zugeordnet, wodurch eine präzise Erkennung unabhängig von der Formulierung gewährleistet wird.
        🇺🇸 Example Scenarios (Voice Commands)
        To make your voice command work, always say a word like 'robot', 'dreame', 'vacuum', 'vacuum cleaner'
        Scenario 1: General Status Check
        "Alexa, check robot status."
        📌 The system will provide a complete status report of your Dreame robot, including:
        • Battery level
        • Current room (if cleaning)
        • Status and remaining life of components like the mop pad, main brush, side brush, filter, water tanks, detergent, silver ion unit, and sensors
        Scenario 2: Clean the Mop
        "Alexa, clean the mop."
        📌 The robot will return to the station and start the mop cleaning process. This ensures that the mop pad is rinsed and ready for further cleaning.
        Scenario 3: Reset a Single Component
        "Alexa, reset filter."
        📌 The system detects that you're referring to the filter and resets its usage timer. This is useful after you've cleaned or replaced it.
        Scenario 4: Empty the Dustbin
        "Alexa, empty the dustbin."
        📌 The robot will go to the station and start the auto-empty process, removing dust and debris from the bin automatically.
        Scenario 5: Reset All Components
        "Alexa, reset all components."
        📌 This command will reset the usage time of all components (brushes, filter, mop pad, detergent, silver ion, sensors, etc.) at once נperfect after a full service or replacement.
        🇩🇪 Beispiel-Szenarien (Sprachbefehle)
        Damit dein Sprachbefehl funktioniert, sag immer ein Wort wie 'roboter', 'dreame', 'staubsauger', 'saugroboter'
        Szenario 1: Allgemeiner Statusbericht
        „Alexa, Roboterstatus prüfen.“
        📌 Das System gibt einen vollständigen Statusbericht deines Dreame Saugroboters aus, inklusive:
        • Batteriestand
        • Aktueller Raum (falls Reinigung läuft)
        • Zustand und verbleibende Lebensdauer aller Komponenten wie Mopp-Pad, Hauptbürste, Seitenbürste, Filter, Wassertanks, Reinigungsmittel, Silberioneneinheit und Sensoren
        Szenario 2: Mopp reinigen
        „Alexa, Roboter Mopp reinigen.“
        📌 Der Roboter kehrt zur Station zurück und startet die Mopp-Reinigung. Das Mopp-Pad wird dabei gespült und für die nächste Reinigung vorbereitet.
        Szenario 3: Einzelne Komponente zurücksetzen
        „Alexa, Roboter Filter zurücksetzen.“
        📌 Das System erkennt, dass du den Filter meinst, und setzt die Nutzungsanzeige zurück – ideal nach einer Reinigung oder einem Austausch.
        Szenario 4: Staubbehälter entleeren
        „Alexa, Roboter Staubbehälter leeren.“
        📌 Der Roboter fährt zur Station und startet den Auto-Entleerungsvorgang. Der Staubbehälter wird automatisch geleert.
        Szenario 5: Alle Komponenten zurücksetzen
        „Alexa, Roboter alle komponenten zurücksetzen.“
        📌 Mit diesem Befehl setzt das System die Nutzungszeit aller Komponenten (Bürsten, Filter, Mopp-Pad, Reinigungsmittel, Silberionen, Sensoren usw.) gleichzeitig zurück – ideal nach einer Wartung oder einem Kompletttausch.
        • wawyoW wawyo
          • Battery level
          • Batteriestand
          wawyoW Offline
          wawyoW Offline
          wawyo
          Ich habe auf das Feedback der Closed-Beta-Tester reagiert und wichtige Probleme behoben.
          1. Die Reinigung startet jetzt wie gewünscht per Alexa-Sprachbefehl. Befehle wie "saugen", "wischen" oder "moppen" funktionieren nun zuverlässig – auch für bestimmte Räume oder mit unterschiedlichen Reinigungsmodi in verschiedenen Räumen.
          2. Das Zurücksetzen der Komponenten per Sprachbefehl funktioniert jetzt ebenfalls. Alle Komponenten wie Filter, Bürsten, Sensoren usw. lassen sich per Alexa zurücksetzen. Alexa gibt dabei eine klare Rückmeldung, ob etwas zurückgesetzt wurde oder ob ein Reset nötig ist.
          Danach habe ich mich mit der gesamten Steuerlogik beschäftigt. Auch hier funktioniert jetzt alles wie gewünscht
          – inklusive Sprachrückmeldungen von Alexa.
          Jetzt habe ich mit der Entwicklung einer komplett neuen interaktiven Karte für Dreamehome begonnen. Sie wird unabhängig von der Originalkarte sein und bietet deutlich mehr Funktionen:
          – Anzeige aller Räume, Teppiche und virtuellen Grenzen
          – Darstellung des Reinigungspfads in Echtzeit
          – Steuerung direkt über Buttons und Slider auf der Karte
          – Animationen und Effekte für aktive Räume
          – Volle Kontrolle, nicht nur Anzeige
          Der Code ist noch nicht veröffentlicht, aber ich arbeite daran.
          Ein kurzes Video zur Vorschau – damit ihr sehen könnt, wie weit ich schon bin. Es ist jetzt schon deutlich weiter als die originale Kartenfunktion.
          https://youtube.com/shorts/eH6rYprOAOA
          Dreamehome Map – Neue Karte in Arbeit
          Noch nicht veröffentlicht – aber schon viel weiter als die Original-Version.
          • wawyoW wawyo
            wawyoW Offline
            wawyoW Offline
            wawyo
            0.1.4 ist Online ;)
            interaktive Karte
            Hauptfunktionen:
            1. Datenvorbereitung:
              • Lädt die Roboter-Positionshistorie
              • Ermittelt den Adapter-Pfad für die Zustandsspeicherung
              • Verarbeitet die Positionsdaten in ein geeignetes Format
            2. Kartenerstellung:
              • Erstellt ein HTML-Dokument
              • Zeichnet die Karte basierend auf den Roboter-Kartendaten (Räume, Wände, Türen, Ladestation)
              • Implementiert eine 3D-ansicht mit Rotations- und Zoomfunktionen
            3. Interaktive Features:
              • Echtzeit-Positionsverfolgung des Roboters
              • Auswahl von Räumen und Teppichen durch Klick (Die Auswahl funktioniert bereits, der Befehl zur Reinigung wird in der nächsten Version verfügbar sein).
              • Anzeige von Reinigungsfortschritt und Raumdaten
              • Spektakuläre Animationsmodi ("Map Spectacle")
              • Statusanimationen für die Ladestation
            4. Benutzeroberfläche:
              • Modernes Menüsystem mit Animationen
              • Einstellungen für Kartenrotation, Perspektive und Zoom
              • Anzeige von Roboterstatus und Reinigungsdaten
            Technische Details:
            • Die Karte wird als HTML-Canvas mit SVG-Elementen gerendert
            • Verwendet WebSocket für Echtzeit-Updates der Roboterposition
            • Implementiert eine ausgeklügelte 3D-Transformation mit CSS
            Datenfluss:
            1. Roboterpositionsdaten werden vom Adapter abgerufen
            2. Die Karte wird skaliert und transformiert, um in den Canvas zu passen
            3. Interaktionen werden über Farbcodierung und Klickerkennung verarbeitet
            4. Statusupdates werden über WebSocket empfangen und visualisiert
            Besondere Highlights:
            • Die Ladestation zeigt unterschiedliche Animationen für verschiedene Status (Laden, Fehler, Reinigen etc. | 23 Animationen)
            • Räume ändern Farbe basierend auf Reinigungsfortschritt
            • Die "Map Spectacle"-Animation erzeugt dramatische Kamerafahrten um die Karte
            • Das Menüsystem hat automatisches Timeout
            Diese Methode erstellt im Wesentlichen eine komplette, interaktive Visualisierung der Roboterumgebung mit vielen Details und Animationen, die in Echtzeit auf Roboterstatusänderungen reagiert.
            Um die Karte anzuzeigen, erstelle ein HTML-Widget in der Größe 1024x1024 oder nach Bedarf und packe den folgenden Code hinein: {dreamehome.0.XXXXXX.vis.vishtml1}
            Dabei ist XXXXXX die Nummer deines Roboters.
            • wawyoW wawyo
              0.1.4 ist Online ;)
              interaktive Karte
              Hauptfunktionen:
              Technische Details:
              Datenfluss:
              wawyoW Offline
              wawyoW Offline
              wawyo
              Bald ;)
              Main Menu
              Clean Menu
              Settings menu
              Map
              • wawyoW wawyo
                Bald ;)
                Main Menu
                Clean Menu
                Settings menu
                Map
                wawyoW Offline
                wawyoW Offline
                wawyo
                „You go!“
                Unter GitHub ist noch kein Update – und das hat seinen Grund.
                Was schon funktioniert? Lasst euch überraschen!
                Genau deshalb habe ich es noch nicht hochgeladen.
                Manches muss reifen, manches soll wirken – und manches verdient einfach einen großen Auftritt.
                Bleibt dran! ;)
                ⬇️ Download main.js
                Gefixt wird nur, was kommuniziert wird.
                Edit!
                Zur Performance und zum Ressourcenverbrauch:
                Mich interessiert vor allem der Ressourcenverbrauch, da in der Grafik viele Manipulationen stattfinden. Ich habe daher fast alles entfernt, was unnötig Leistung zieht.
                Unter VIS läuft es bei mir sehr flüssig, und auch im ioBroker liegt die Speicherauslastung während der „Reinigung“ bei maximal 128 MB.
                Ich kann aber nur für mein Setup sprechen:
                Ich nutze einen Raspberry Pi 5 mit 16 GB RAM, und das angebundene Tablet ist von mittlerer Qualität.
                Die Performance kann je nach System natürlich unterschiedlich ausfallen.
                • wawyoW wawyo
                  „You go!“
                  Bleibt dran! ;)
                  ⬇️ Download main.js
                  Edit!
                  wawyoW Offline
                  wawyoW Offline
                  wawyo
                  V 0.1.5 Online
                  Neue Funktionen
                  Dynamische VIS-Objekte & Kartenerstellung
                  Integration dynamischer Visualisierungsobjekte für eine flexible und anpassbare Anzeige.
                  Aktions-Dropdown-Menü
                  Neue Steuerungsoptionen verfügbar: Pause, Reinigen, Laden, Stopp.
                  Allgemeines Reinigungsmenü (derzeit deaktiviert)
                  Vorbereitete Funktion zur Einleitung einer Komplettreinigung über ein zentrales Steuerungsmenü.
                  Neue Funktions-Buttons in der Kartenansicht
                  Hinzugefügte Aktionen: Tastensperre, Roboter entleeren, Mopp waschen, Start, Pause, Reinigen, Laden, Auswahl reinigen.
                  Ein- und ausblendbare Reinigungs- & Verlaufspfade
                  Aktueller Reinigungsverlauf und Historie können individuell ein- oder ausgeblendet werden.
                  Radialmenü pro Raum
                  Jeder Raum verfügt nun über ein eigenes Radialmenü zur individuellen Konfiguration: Saugkraft, Wasserstand, Wiederholen, Reinigungsmodus, Route.
                  Animierte Symbole für aktive Reinigung
                  Räume, die aktuell gereinigt werden, werden mit animierten Symbolen hervorgehoben.
                  Realistische Robotersymbole
                  Standardsymbole wurden durch detaillierte und realistische Roboterdarstellungen ersetzt.
                  Verbesserungen
                  Effizienterer Code
                  Optimierte Algorithmen reduzieren den Speicher- und CPU-Verbrauch erheblich.
                  Speichern & Wiederherstellen der 3D-Kartenrotation
                  Aktuelle Kameraposition, -rotation sowie ausgewählte Räume und Teppiche werden gespeichert und nach einem Neustart des Adapters oder Neuladen der Seite korrekt wiederhergestellt.
                  Verbesserter Reinigungsstatus
                  • Probleme beim Laden des Reinigungsstatus wurden behoben, sodass die Historie nun korrekt mit Daten gefüllt wird.
                  • Der Fortschritt laufender Reinigungsaufträge wird jetzt korrekt und in Echtzeit angezeigt.
                  Neue Logik zum Starten der Reinigung
                  Es gibt jetzt drei Möglichkeiten, eine Reinigung zu starten:
                  1. Komplettreinigung per Kartenklick
                    Auf Reinigen in der Karte klicken: Allgemeine Reinigungseinstellungen aus der App werden übernommen und die Reinigung startet sofort.
                  2. Gezielte Raumreinigung
                    • Einzelne Räume per Klick auswählen (blinken grün).
                    • Dann Auswahl reinigen drücken – nur die ausgewählten Räume werden gereinigt.
                    • Raumspezifische Einstellungen (Saugkraft, Wasserstand, Wiederholen, Reinigungsmodus, Route) können über das Zahnrad-Symbol im jeweiligen Raumlabel angepasst werden.
                  3. Auswahl reinigen ohne Auswahl
                    Wird Auswahl reinigen gedrückt, ohne zuvor Räume ausgewählt zu haben, werden alle Räume gemäß der individuellen Einstellungen in den Raumlabels gereinigt.
                  Viel Spaß ;)
                  Exzellenz erkennt man leise.
                  • wawyoW wawyo
                    V 0.1.5 Online
                    Neue Funktionen
                    Radialmenü pro Raum
                    Verbesserungen
                    Effizienterer Code
                    Viel Spaß ;)
                    wawyoW Offline
                    wawyoW Offline
                    wawyo
                    Ich setze noch eine drauf – läuft.
                    Der Farbwert eines Elements wird basierend auf einem Prozentwert (0-100%) in der HSL-Skala berechnet, wobei der Farbton von rot (0°) bis blau (240°) reicht. ;)
                    • wawyoW wawyo
                      Max_yeah
                      @wawyo Hi, ich habe deinen Adapter erst neulich gefunden, davor hab ich den Dreame Adapter genutzt. Der unterschied ist ja gigantisch. Endlich sehe ich alle werte für mein Model. Tolle Arbeit!
                      Eine Frage habe ich allerdings, ich möchte die Werte auch mit Tastenfunktionen auf meinem NSPanel nutzen. Wie kann ich Custom Start Befehle ausführen, zb. Reinige Wohnzimmer nur Saugen.
                      Gibt es dafür eine Möglichkeit? Der Adapter parst ja auch die Alexa eingaben.
                      • M Max_yeah
                        wawyoW Offline
                        wawyoW Offline
                        wawyo
                        @max_yeah vielen Dank für dein tolles Feedback – freut mich sehr, dass der Adapter für dein Modell so gut funktioniert! 😊
                        Deinen Wunsch nach Custom-Startbefehlen (z. B. „Reinige Wohnzimmer nur Saugen“) nehme ich gerne für die nächste Version auf – das ist definitiv sinnvoll, gerade für NSPanel-Nutzer.
                        Aktuell ist Version v0.1.7 nur über GitHub verfügbar, nicht über npm. Du kannst sie also direkt von dort installieren, falls du die neuesten Funktionen testen möchtest.
                        • wawyoW wawyo
                          Aktuelle Test Version 2.0.1
                          Veröffentlichungsdatum 10.04.2026
                          Github Link https://github.com/spayrosam/ioBroker.dreamehome
                          NPM version Number of Installations Downloads Test and Release
                          📋 Inhaltsverzeichnis
                          • [Features]
                          • [Unterstützte Modelle]
                          • [Installation]
                          • [Konfiguration]
                          • [Sprachsteuerung]
                          • [VIS-Widgets]
                          • [Lernsystem]
                          • [Wasserverbrauchs-Tracking]
                          • [Fehlerbehebung]
                          ✨ Features
                          🔌 Cloud-Integration
                          • Vollständige Anbindung an die Dreame-Cloud
                          • Automatisches Token-Management mit Refresh
                          • MQTT-Echtzeitkommunikation mit dem Roboter
                          🗺️ Interaktive Karten (VIS)
                          • 3D-Kartenansicht mit Rotation, Zoom und Perspektive
                          • Klickbare Räume und Teppiche zur Auswahl
                          • Live-Roboter-Position mit Animation
                          • Reinigungspfad mit farbiger Raumzuordnung
                          • Anzeige von Wänden, Türen und Möbeln
                          • Reinigungs-Historie als Overlay mit Pfad-Vorschau
                          • Komponenten-Status (Bürsten, Filter, etc.) mit Fortschrittsbalken
                          🎤 Sprachsteuerung
                          • Alexa-Integration: Natürliche Sprachbefehle
                          • Telegram-Support: Steuerung per Chat
                          • Mehrsprachig (Deutsch/Englisch)
                          🧠 Lernendes System
                          • Analysiert Reinigungsmuster pro Raum
                          • Lernt bevorzugte Einstellungen (Saugstufe, Wassermenge)
                          • Kann fehlende Sprachbefehle automatisch ergänzen
                          • Gibt Empfehlungen mit Konfidenz-Werten
                          💧 Wasserverbrauchs-Tracking
                          • Für Modelle mit Wassertank und Waschstation
                          • Berechnet Verbrauch pro m² (ml/m²)
                          • Lernt aus historischen Daten (KI-gestützt)
                          • Separate Verfolgung von Reinigungsmittel (Detergent)
                          • Warnungen bei niedrigem Füllstand
                          🧹 Umfassende Steuerung
                          • Start/Pause/Stop/Charging
                          • Raumweise Reinigung mit individuellen Einstellungen
                          • Teppichreinigung mit Intensitätsstufen
                          • Esstisch-Zonen (automatische Erkennung)
                          • Auto-Empty und Mop-Washing
                          • Komponenten-Reset (Bürsten, Filter, Sensoren)
                          📊 Status & Monitoring
                          • Alle Roboter-Status (Saugstufe, Wassermenge, Fehler)
                          • Verschleißteile mit Restlebensdauer
                          • Reinigungsverlauf mit Statistiken
                          • Ressourcen-Monitoring (Speicher, Event-Loop)
                          🤖 Unterstützte Modelle
                          Der Adapter unterstützt nahezu alle Dreame-Staubsaugerroboter mit Cloud-Anbindung:
                          Serie Modelle Besonderheiten
                          Matrix / X-Serie Matrix 10 Ultra/Pro, X30 Ultra, X40 Ultra 5.0L Tank, Mop-Typen A/B/C
                          L-Serie L20 Ultra, L30 Ultra, L10s Ultra/Pro 4.5L / 4.0L Tank
                          Z-Serie Z10, Z20, Z30 Pro 5.0L Tank
                          W-Serie W10, W20, W30 4.0L Tank
                          F-Serie F9, F10 3.0L Tank
                          D-Serie D9, D10, D20 2.0L - 2.5L Tank
                          Bei nicht gelisteten Modellen wird automatisch die Tankkapazität erkannt oder ein Standardwert verwendet.
                          📦 Installation
                          Voraussetzungen
                          • Node.js 20 oder höher (mit --expose-gc empfohlen)
                          • ioBroker js-controller 5.0 oder höher
                          • Canvas-Bibliothek für die Kartendarstellung
                          Installation über GitHub (Adapter ist nicht im offiziellen npm-Repository verfügbar)
                          Methode 1: Über die ioBroker-Admin-Oberfläche
                          1. Öffne die ioBroker-Admin-Oberfläche
                          2. Gehe zu "Adapter" → "Eigene Adapter"
                          3. Füge folgende GitHub-URL hinzu: https://github.com/spayrosam/ioBroker.dreamehome
                          4. Klicke auf "Installieren"
                          Wichtig: Canvas-Bibliothek
                          Die Canvas-Bibliothek wird für die Kartendarstellung benötigt. Überprüfe die Installation mit:
                          cd /opt/iobroker
                          npm list canvas
                          Falls nicht installiert:
                          cd /opt/iobroker
                          npm install canvas
                          ⚙️ Konfiguration
                          Grundeinstellungen
                          Feld Beschreibung
                          Benutzername Dein Dreame-Account (E-Mail)
                          Passwort Dein Dreame-Passwort
                          Geräteindex Bei mehreren Robotern: 0 = erstes Gerät
                          Auto-Fallback Automatisch auf erstes Gerät wechseln
                          Erweiterte Einstellungen
                          Feld Beschreibung Standard
                          Aktualisierungsintervall Wie oft Daten abgerufen werden 60 Sekunden
                          Speicher-Limit Maximaler Heap-Speicher 150 MB
                          Event-Loop-Limit Max. Event-Loop-Verzögerung 50 ms
                          GC aktivieren Garbage Collection true
                          Memory Cleaner Automatische Speicherbereinigung true
                          Cleaner-Schwelle Ab wann bereinigt wird 300 MB
                          Cleaner-Intervall Wie oft geprüft wird 30 Sekunden
                          🎤 Sprachsteuerung
                          Alexa-Integration
                          Der Adapter erkennt automatisch, ob der Alexa-Adapter installiert ist. Du kannst natürliche Sprachbefehle mit Alexa verwenden.
                          Wichtig: Befehle für Komponenten-Status, Reset, Auto-Empty und Mop-Washing MÜSSEN ein Robot-Keyword wie "roboter", "saugroboter" oder "dreame" enthalten. Raumreinigungsbefehle funktionieren mit oder ohne Robot-Keyword.
                          Robot-Keywords (müssen in bestimmten Befehlen enthalten sein)
                          Deutsche Keywords
                          roboter, dreame, staubsauger, saugroboter, putzroboter, staubi, saug-bot, reinigungsroboter
                          Grundlegende Befehle
                          Was du zu Alexa sagen musst
                          "Alexa, starte den Roboter"
                          "Alexa, starte die Reinigung"
                          "Alexa, stoppe den Roboter"
                          "Alexa, stoppe die Reinigung"
                          "Alexa, pausiere den Roboter"
                          "Alexa, pausiere"
                          "Alexa, Roboter zur Ladestation"
                          "Alexa, zur Ladestation"
                          Raumreinigung
                          "Alexa, saug die Küche"
                          "Alexa, wisch das Bad"
                          "Alexa, saug das Wohnzimmer zweimal"
                          "Alexa, saug die Küche leise"
                          "Alexa, saug die Küche standard"
                          "Alexa, saug die Küche stark"
                          "Alexa, saug die Küche turbo"
                          "Alexa, wisch das Bad niedrig"
                          "Alexa, wisch das Bad mittel"
                          "Alexa, wisch das Bad hoch"
                          Kombinierte Raum-Befehle
                          "Alexa, saug die Küche zweimal und wisch das Bad"
                          "Alexa, saug die Küche leise und wisch das Bad hoch"
                          "Alexa, saug die Küche dreimal und wisch das Bad zweimal"
                          Auto-Empty (MUSS Robot-Keyword enthalten)
                          "Alexa, Roboter leeren"
                          "Alexa, Saugroboter entleeren"
                          "Alexa, Dreame leeren"
                          "Alexa, Staubsauger leeren"
                          Mop-Washing (MUSS Robot-Keyword enthalten)
                          "Alexa, Roboter waschen"
                          "Alexa, Saugroboter Mopp waschen"
                          "Alexa, Dreame waschen"
                          "Alexa, Roboter Mopp reinigen"
                          Komponenten-Status (MUSS Robot-Keyword enthalten)
                          "Alexa, Roboter Status"
                          "Alexa, Roboter prüfen"
                          "Alexa, Roboter wie ist der Filter"
                          "Alexa, Roboter prüfe Filter"
                          "Alexa, Roboter wie ist die Hauptbürste"
                          "Alexa, Roboter prüfe Seitenbürste"
                          "Alexa, Roboter wie ist das Wischpad"
                          "Alexa, Roboter prüfe Sensor"
                          "Alexa, Roboter wie ist das Reinigungsmittel"
                          "Alexa, Roboter prüfe Wassertank"
                          Komponenten zurücksetzen (MUSS Robot-Keyword enthalten)
                          "Alexa, Roboter alles zurücksetzen"
                          "Alexa, Roboter alle Komponenten zurücksetzen"
                          "Alexa, Roboter Filter zurücksetzen"
                          "Alexa, Roboter Hauptbürste zurücksetzen"
                          "Alexa, Roboter Seitenbürste zurücksetzen"
                          "Alexa, Roboter Wischpad zurücksetzen"
                          Abbruch-Befehle
                          "Alexa, Reinigung abbrechen"
                          "Alexa, stoppe Reinigung"
                          Teppichreinigung
                          "Alexa, reinige den Teppich im Wohnzimmer"
                          "Alexa, reinige den Teppich im Schlafzimmer"
                          "Alexa, Teppich im Wohnzimmer leicht"
                          "Alexa, Teppich im Wohnzimmer mittel"
                          "Alexa, Teppich im Wohnzimmer stark"
                          Esstisch-Reinigung
                          "Alexa, reinige den Esstisch"
                          "Alexa, reinige den Esstisch im Wohnzimmer"
                          "Alexa, saug unter dem Esstisch"
                          "Alexa, wisch um den Esstisch"
                          "Alexa, reinige Esstisch schnell"
                          "Alexa, reinige Esstisch standard"
                          "Alexa, reinige Esstisch gründlich"
                          Hilfemenü
                          "Alexa, Hilfe für den Roboter"
                          "Alexa, Roboter Hilfe"
                          "Alexa, Hilfe für den Staubsauger"
                          Das Hilfemenü führt dich dann durch:
                          • 1 Staubbehälter leeren
                          • 2 Mopp waschen
                          • 3 Komponentenstatus prüfen
                          • 4 Komponenten zurücksetzen
                          • 5 Raumreinigung
                          • 6 Teppichreinigung
                          • 7 Esstisch-Reinigung
                          • 8 Synonym-Beispiele und Sprachbefehle
                          Telegram-Integration
                          Der Adapter unterstützt auch die Steuerung über Telegram. Sende Nachrichten wie:
                          Befehl
                          starte den Roboter
                          Roboter Status
                          Roboter leeren
                          Roboter waschen
                          🖼️ VIS-Widgets
                          Der Adapter generiert eine interaktive Karte für das VIS. Zugriff über:
                          dreamehome.0.[DEIN-DID].vis.vishtml0
                          Features der Karte
                          🎮 Steuerungsmenü (rechts)
                          • Start/Pause/Stop/Charge
                          • Reinigungsmodus-Auswahl (Saugen/Wischen/Beides)
                          • Individuelle Raumeinstellungen
                          🔧 Ansichtsmenü
                          • 3D-Rotation (X/Y/Z)
                          • Zoom und Perspektive
                          • Hintergrundfarbe
                          • Ein-/Ausblenden von Pfaden und Labels
                          📊 Status-Infos (oben links)
                          • Aktueller Raum mit Reinigungsfortschritt
                          • Batteriestand
                          🖱️ Interaktion
                          • Klick auf Räume: Auswahl für gezielte Reinigung
                          • Klick auf Teppiche: Gezielte Teppichreinigung
                          • Klick auf Einstellungs-Icon: Individuelle Raum-Einstellungen
                          📜 Reinigungsverlauf-System
                          Der Adapter enthält ein umfassendes Reinigungsverlauf-System mit:
                          • Listenansicht aller vergangenen Reinigungen mit Datum, Fläche, Dauer und Status
                          • Detailansicht mit vollständigen Statistiken, Raumreihenfolge und individuellen Einstellungen
                          • Hinderniserkennung für über 30 Typen (Schuhe, Kabel, Haustiere, Möbelbeine, usw.)
                          • Blockierte Räume Visualisierung mit 45°-Schraffurmuster und farbcodierten Gründen
                          • Datumsauswahl mit Kalender zur einfachen Navigation (Heute, Gestern, 7T, 30T)
                          • Pfaddarstellung mit raumbasierten Farben und Segmenterkennung
                          • Metadaten & Statistiken inklusive Bewegungsaktionen, KI-Modell und Hinderniszähler
                          • Vollständige Deutsch/Englisch Sprachunterstützung
                          Klicke auf die Verlaufsschaltfläche (Uhrensymbol) auf der Karte, um zu beginnen.
                          🧠 Lernsystem
                          Der Adapter lernt aus deinen Reinigungen und wird mit der Zeit intelligenter.
                          Wie es funktioniert
                          1. Datenerfassung: Jede Reinigung wird analysiert (Raum, Saugstufe, Wassermenge, Erfolg)
                          2. Mustererkennung: Das System erkennt Vorlieben pro Raum
                          3. Empfehlungen: Bei fehlenden Angaben in Sprachbefehlen werden gelernte Werte vorgeschlagen
                          Lernbefehle
                          "Alexa, was hast du gelernt?"
                          "Alexa, zeige Lernstatistiken"
                          "Alexa, Empfehlung für die Küche"
                          "Alexa, lösche Lernhistorie"
                          "Alexa, welche Räume gelernt?"
                          Konfigurierbare Parameter
                          Parameter Beschreibung Standard
                          MinCoverageForLearn Min. Abdeckung zum Lernen 80%
                          MinCleaningsForConfidence Min. Reinigungen für hohe Konfidenz 3
                          AutoCompleteMinConfidence Min. Konfidenz für Auto-Vervollständigung 60%
                          EnableTimeContext Tageszeit berücksichtigen true
                          Das Tracking funktioniert automatisch für Modelle mit:
                          • Wassertank in der Basisstation
                          • Automatischer Mop-Waschfunktion
                          Wie es funktioniert
                          1. Modellerkennung: Automatische Erkennung der Tankkapazität
                          2. Verbrauchsmessung: Berechnet ml/m² während der Reinigung
                          3. Lernende KI: Passt den Verbrauch an deine Gegebenheiten an
                          4. Reinigungsmittel: Separates Tracking für Detergent
                          Verfügbare States
                          State Beschreibung
                          water.Current Aktueller Wasserstand (ml)
                          water.PureWaterTank Wasserstand in Prozent
                          water.CurrentMlPerSqm Aktueller Verbrauch (ml/m²)
                          water.LearningStats Lernstatistiken
                          water.RoomConsumption Verbrauch pro Raum
                          detergent.CurrentMl Reinigungsmittel (ml)
                          detergent.EstimatedRefillDate Voraussichtliches Nachfüll-Datum
                          🔍 Fehlerbehebung
                          Häufige Probleme
                          1. Verbindung zur Cloud schlägt fehl
                          Login error response: "invalid_grant"
                          Lösung:
                          • Überprüfe Benutzername und Passwort
                          • Eventuell ist die Zwei-Faktor-Authentifizierung aktiviert
                          2. Karte wird nicht generiert
                          Error: Cannot find module 'canvas'
                          Lösung: Canvas-Bibliothek manuell installieren:
                          cd /opt/iobroker
                          npm install canvas
                          3. Hoher Speicherverbrauch
                          Lösung:
                          • Aktiviere den Memory Cleaner in den Einstellungen
                          • Starte Node.js mit --expose-gc
                          • Reduziere das Aktualisierungsintervall
                          4. Alexa erkennt keine Befehle
                          Lösung:
                          • Stelle sicher, dass der Alexa-Adapter installiert ist
                          • Prüfe ob alexa2.0.History.summary existiert
                          • Bei Komponenten-Status/Reset: MUSS ein Robot-Keyword enthalten sein (z.B. "roboter", "saugroboter")
                          • Sage "Alexa, Hilfe für den Roboter" für Beispiele
                          Logging aktivieren
                          Setze den State dreamehome.0.settings.showlog auf true, um detaillierte Logs zu erhalten.
                          📝 Changelog
                          [2.0.1] - 2026-04-10
                          Added
                          • Obstacle filter panel with draggable UI (EN/DE)
                          Changed
                          • Initial history load: 50 → 25 entries
                          Fixed
                          • Map generation now correctly handles empty or invalid walls_info structures
                          [2.0.0] - 2026-04-08
                          • Complete code rewrite | Komplett überarbeitete Codebasis
                          • New 3D map widget with interactive elements | Neues 3D-Karten-Widget mit interaktiven Elementen
                          • Learning system for personalized cleaning | Lernendes System für personalisierte Reinigung
                          • Water tracking with AI | Wasserverbrauchs-Tracking mit KI
                          • Support for Matrix models (mop types A/B/C) | Unterstützung für Matrix-Modelle (Mop-Typen A/B/C)
                          • Cleaning history system with obstacle detection, blocked rooms visualization, and date picker | Reinigungsverlauf-System mit Hinderniserkennung, blockierten Räumen und Datumsauswahl
                          • Improved voice control with synonym recognition | Verbesserte Sprachsteuerung mit Synonym-Erkennung
                          • Telegram integration | Telegram-Integration
                          • Resource monitoring with automatic restart | Ressourcen-Monitoring mit automatischem Restart
                          mcm1957M Offline
                          mcm1957M Offline
                          mcm1957
                          @wawyo
                          Wenn dein Adapter bei User funktiomiert - und so sieht es ja aus - lass ihn doch bitte in die Repositories aufnehmen.
                          DANKE für deine Arbeit!
                          Für alle potenziellen User die sich NICHT als Tester sehen und den Adapter z.B. nur auf einem Testsystem ausprobieten wollen noch der nachfolgende Hinweis:
                          Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten.
                          Dieser Hinweis betrifft natürli h NICHT das Testen einer neuen Release.
                          • mcm1957M mcm1957
                            @wawyo
                            wawyoW Offline
                            wawyoW Offline
                            wawyo
                            @mcm1957 danke für das Feedback und das Interesse an einer Aufnahme in die Repositories!
                            Ich möchte zunächst noch genügend Rückmeldungen zur Kompatibilität mit verschiedenen Roboter-Modellen sammeln, bevor ich ihn offiziell einreiche. Ziel ist, dass er wirklich stabil und vollständig funktioniert.
                            Ein Punkt zur Performance:
                            Wie bei allen Saugroboter-Adaptern verursacht die Kartenverarbeitung (Map) bei Aktivierung höheren Ressourcenverbrauch – das ist systembedingt.
                            Daher habe ich ein eigenes Modul integriert, das:
                            1. Ressourcenverbrauch überwacht,
                            2. ggf. Speicher automatisch bereinigt,
                            3. und dir zeigt, wo genau die Auslastung entsteht, um gezielt optimieren zu können.
                            Hinweis zu den VIS Map-Einstellungen:
                            Einige Funktionen dort sind derzeit bewusst noch deaktiviert. Ich werde sie erst freischalten, wenn ausreichend Rückmeldungen und Tests von euch vorliegen – damit alles zuverlässig läuft.
                            Ich selbst nutze den Adapter bereits im Alltag – und er tut, was er soll. 😊
                            Danke für euer Feedback – je mehr Rückmeldungen, desto besser kann ich den Adapter weiterentwickeln!
                            wawyoW mcm1957M 2 Antworten Letzte Antwort
                            • wawyoW wawyo
                              wawyoW Offline
                              wawyoW Offline
                              wawyo
                              @all noch ein technischer Hinweis zur Wasserverbrauchsanzeige in meinem Adapter:
                              Da Geräte wie der Dreame L20 Ultra (4,5 L Tank) keine echten Wasserverbrauchsdaten liefern, basiert die Anzeige in meinem Adapter nicht auf festen Werten oder Schätzungen, sondern auf einem selbstlernenden System.
                              Ich habe eine einfache, integrierte KI entwickelt, die:
                              bei jeder Reinigung Daten wie Fläche, Modus und Dauer sammelt
                              daraus Muster erkennt
                              und nach ca. 5 Reinigungen beginnt, den Verbrauch anhand realer Nutzung zu berechnen
                              Ziel ist keine perfekte Wissenschaft, sondern eine praxisnahe Einschätzung, die sich an das reale Verhalten des Roboters anpasst – und besser wird, je öfter er läuft.
                              Das System ist fest im Adapter integriert, läuft vollständig lokal, benötigt keine Cloud, und verbessert sich mit jeder Nutzung automatisch.
                                muckel
                                @wawyo
                                super Idee dieser Adapter. Danke!
                                Ich habe zwei Dream-Sauger. Einer wird aber nur erkannt.
                                Der LS10 Pro steht in der App als Erster und wird erkannt.
                                Der L40S Pro Ultra wird nicht erkannt.
                                Kann ICH da etwas machen, dass beide Sauger erkannt werden?
                                Lg. Erich
                                • wawyoW wawyo
                                  mcm1957M Offline
                                  mcm1957M Offline
                                  mcm1957
                                  @wawyo said in Test DreameHome: 3D-Visualisierung und Alexa-Steuerung:
                                  Ohne irgendwie drängen zu wollen - die Entscheidung wann ein Adapter in Repo soll trifft natürlich der Dev. -- nur zur Sicherheit:
                                  Es gibt wie wahrscheinlich bekannt ist ein LATEST / BETA und ein STABLE Repository. Wenn der Adapter prinzipiell funktioniert (und das tut er wenn ich es hier so lese) dann spricht zunächst mal nichts dagegen ihn ins BETA (LATEST) Repository aufnehmen zu lassen. Dort kann er dann in Ruhe von Testern erprobt werden ohne GitHub Installationen zu benutzen von denen prinzipiell abgeraten wird. Und es ist auch kein Problem, wenn ein Adapter im Beta Repo mal Fehler aufweist - dazu gibts ja des Beta Test Repository um diese im Zuge eines breiteren Einsatzes zu finden :-)
                                  mcm1957
                                  P.S.: Das notwendige Review für eine Aufnahme ins Latest dauert wahrscheinlich mindestens 1 bis 2 Wochen da leider immer zu wenig Zeit vorhanden ist. Aber wie gsagt - im Kern DEINE Entscheidung und DANKE für deine Arbeit.
                                  Peter V.P 1 Antwort Letzte Antwort
                                  • mcm1957M mcm1957
                                    mcm1957
                                    Peter V.P Offline
                                    Peter V.P Offline
                                    Peter V.
                                    schrieb am zuletzt editiert von Peter V.
                                    @wawyo
                                    Habe den Adapter auch entdeckt, und er funktioniert auch fast perfekt.
                                    Dreame X50 Ultra Complete
                                    Die Mops werden nicht in der Karte angezeigt (in den Datenpunkten sind sie vorhanden),
                                    Reinigungsmittel habe ich in den Datenpunkten nicht finden können, wird daher auch als "NAN%" in der Map angezeigt.
                                    Git Issue bereits eröffnet.
                                    Im Gegensatz zu der Anleitung habe ich den Link in der Vis auf
                                    {dreamehome.0.XXXXXX.vis.vishtml0}
                                    (eine 0 statt 1 am Ende)
                                    Aber ein super Plugin, vorallem die Kartendarstellung.
                                    • Peter V.P Peter V.
                                      @wawyo
                                      wawyoW Offline
                                      wawyoW Offline
                                      wawyo
                                      Hallo @muckel
                                      danke für das Feedback!
                                      Derzeit ist es leider nur möglich, einen Roboter zu binden, aber ich plane, in Zukunft mehrere Roboter zu integrieren, sodass du auch beide Geräte gleichzeitig verwenden kannst.
                                      Danke für deine Geduld und dein Verständnis!
                                      Hallo @mcm1957,
                                      danke für den Hinweis und deine Geduld! Du hast völlig recht, dass es in der Beta-Phase keine Probleme gibt, Fehler zu finden und zu beheben.
                                      Tatsächlich ist der Adapter in der jetzigen Form schon stabil und tut, was er soll. Ich wollte nur sicherstellen, dass er wirklich mit allen Geräten und Szenarien reibungslos funktioniert, bevor er offiziell eingereicht wird.
                                      Ich denke, die Aufnahme ins Beta-Repository wäre ein guter Schritt, um ihn weiter zu testen und zu verfeinern, ohne dass zu viele Nutzer direkt betroffen sind. Der Vorschlag, das Ganze dort zu erproben, klingt sinnvoll.
                                      Ich werde das Ganze dann entsprechend einplanen und die nächsten Schritte in die Wege leiten.
                                      Danke auch für das Verständnis und deine Unterstützung!
                                      Hallo @Peter V.,
                                      danke für dein Feedback und die ausführliche Beschreibung!
                                      Es freut mich zu hören, dass der Adapter bei dir fast perfekt funktioniert. 😊
                                      Nach der Überprüfung unter Issue 21 konnte ich feststellen, dass die Datenpunkte für MopPad und Detergent beim Dreame X50 offenbar nicht verfügbar sind, was auch in der App angezeigt wird. Diese Werte werden für das X50-Modell aktuell leider nicht bereitgestellt.
                                      Hier ist der relevante Log:
                                      info: dreamehome.0 (2225745) https://eu.iot.dreame.tech:13267/dreame-user-iot/iotstatus/props response:{"code":0,"success":true,"data":[{"key":"18.2"}],"msg":".."}
                                      info: dreamehome.0 (2225745) https://eu.iot.dreame.tech:13267/dreame-user-iot/iotstatus/props response:{"code":0,"success":true,"data":[{"key":"19.1"}],"msg":".."}
                                      info: dreamehome.0 (2225745) https://eu.iot.dreame.tech:13267/dreame-user-iot/iotstatus/props response:{"code":0,"success":true,"data":[{"key":"19.2"}],"msg":".."}
                                      info: dreamehome.0 (2225745) https://eu.iot.dreame.tech:13267/dreame-user-iot/iotstatus/props response:{"code":0,"success":true,"data":[{"key":"20.1"}],"msg":".."}
                                      info: dreamehome.0 (2225745) https://eu.iot.dreame.tech:13267/dreame-user-iot/iotstatus/props response:{"code":0,"success":true,"data":[{"key":"20.2"}],"msg":".."}
                                      Wie man sehen kann, gibt die API bei den meisten Anfragen nur den "key" zurück (z. B. 18.1, 19.1), aber ohne den zugehörigen "value"-Wert, der für die Anzeige der Daten notwendig ist.
                                      Falls Dreame in Zukunft diese Daten für das X50-Modell nicht bereitstellt, werde ich das Feature nachträglich hinzufügen, ähnlich wie es beim Wasser-Tracking funktioniert.
                                      Vielen Dank für dein Verständnis und deine Geduld! ;)
                                      M Peter V.P 2 Antworten Letzte Antwort
                                      • wawyoW wawyo
                                        Hallo @muckel
                                        Hallo @mcm1957,
                                        Hallo @Peter V.,
                                        muckel
                                        @wawyo
                                        Danke für deine schnelle Antwort.
                                        Wäre es als Zwischenschritt möglich eine 2. Instanz zu installieren und in den Instanzen den jeweiligen Sauger anzubinden?
                                        Liebe Grüße Erich
                                        • wawyoW wawyo
                                          Hallo @muckel
                                          Hallo @mcm1957,
                                          Hallo @Peter V.,
                                          Peter V.P Offline
                                          Peter V.P Offline
                                          Peter V.
                                          @wawyo
                                          Super, danke für deine Mühe.
                                          Habe mal bei Dreame das als Feature-Request gemeldet.
                                          Frage noch dazu, in VIS-2 (Visualisierung Next Generation) kann ich die Map einbinden, aber so richtig funktioniert das nicht.
                                          In VIS funktiniert es.
                                          Da ich haupsächlich Jarvis als VIS einsetze, habe ich jetzt per Iframe das VIS HTML eingebunden.
                                          Gibt es eine Möglichkeit, das direkt als HTML auszulesen, also unabhängig von VIS, VIS-2, Jarvis?
                                          Oder habe ich da einen Denkfehler?
