  4. Backup wiederherstellen auf js-controller 4.0
    6.7k
32 Beiträge 3 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • X xT1GeRx
    @Thomas-Braun
    Das ist eine frische instalation. Keine Ahnung wieso das so ist. Jedoch hat es mit dem Befehl geklappt.
    Hier mal alles war er ausgespuckt hat:
    Script v.2025-03-08
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.12.25+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     17:10:53 up 39 min,  1 user,  load average: 0.24, 0.08, 0.02
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-06-09 17:10:54 CEST
               Universal time: Mon 2025-06-09 15:10:54 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    admin
    HOME=/home/admin
    GROUPS=admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.0G        523M        3.2G        6.2M        313M        3.5G
    Swap:           536M          0B        536M
    Total:          4.5G        523M        3.8G
    Active iob-Instances:   4
             3791 M total memory
              499 M used memory
              527 M active memory
               85 M inactive memory
             3065 M free memory
               31 M buffer memory
              267 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 17:10:54 up 39 min,  1 user,  load average: 0.24, 0.08, 0.02
    Tasks: 169 total,   1 running, 168 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3791.4 total,   3064.0 free,    501.0 used,    298.9 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3290.5 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  5.9M  374M   2% /run
    /dev/mmcblk0p2 ext4      117G  3.2G  108G   3% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Mon Jun  9 16:30:57 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0        cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm283        5.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:B9:D2:87 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  consol        e=ttyS0,115200 console=tty1 root=PARTUUID=ed3ceec2-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Jun  9 16:30:58 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with o        rdered data mode. Quota mode: none.
    [Mon Jun  9 16:31:00 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode:        none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=m
    /var:
    889M    /var/
    213M    /var/cache
    208M    /var/cache/apt
    164M    /var/lib
    135M    /var/lib/apt/lists
    Archived and active journals take up 4.7M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    71M     /opt/iobroker/iobroker-data/
    63M     /opt/iobroker/iobroker-data/files
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
    5.5M    /opt/iobroker/iobroker-data/objects.jsonl
    3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-CyIqcfMJ.js
    3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
    3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-IIKn7Ixx.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3476-if00
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.2
    /usr/bin/node           v20.19.2
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.2-1nodesource1
      Candidate: 20.19.2-1nodesource1
      Version table:
     *** 20.19.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 2390)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.17
    javascript:     "javascript" not found
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  e        nabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  e        nabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  e        nabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "backitup"     : 3.2.2    , installed 3.2.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Objects and States
    Objects:        149
    States:         108
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 48
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program        name
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5553       599/sshd: /        usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2794       590/iobroke        r.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2789       590/iobroke        r.js-con
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5555       599/sshd: /        usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5650       706/io.admi        n.0
    udp        0      0 0.0.0.0:51753           0.0.0.0:*                           104        2729       458/avahi-d        aemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2727       458/avahi-d        aemon: r
    udp6       0      0 fe80::76d4:1422:ca5:546 :::*                                0          2786       536/Network        Manager
    udp6       0      0 :::41991                :::*                                104        2730       458/avahi-d        aemon: r
    udp6       0      0 :::5353                 :::*                                104        2728       458/avahi-d        aemon: r
    2025-06-09 16:30:00.495  - warn: admin.0 (670) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2025-06-09 16:30:01.058  - error: host.iobroker instance system.adapter.admin.0 terminated with code 7 (ADAPTER_A        LREADY_RUNNING)
    2025-06-09 16:30:01.059  - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
    2025-06-09 16:30:02.534  - error: backitup.0 (681) backitup.0 already running
    2025-06-09 16:30:02.538  - warn: backitup.0 (681) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2025-06-09 16:30:03.083  - error: host.iobroker instance system.adapter.backitup.0 terminated with code 7 (ADAPTE        R_ALREADY_RUNNING)
    2025-06-09 16:30:03.084  - info: host.iobroker Restart adapter system.adapter.backitup.0 because enabled
    2025-06-09 16:30:04.520  - info: host.iobroker instance system.adapter.discovery.0 in version "5.0.0" started wit        h pid 692
    2025-06-09 16:30:06.510  - error: discovery.0 (692) discovery.0 already running
    2025-06-09 16:30:06.514  - warn: discovery.0 (692) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2025-06-09 16:30:07.059  - error: host.iobroker instance system.adapter.discovery.0 terminated with code 7 (ADAPT        ER_ALREADY_RUNNING)
    2025-06-09 16:30:07.060  - info: host.iobroker Restart adapter system.adapter.discovery.0 because enabled
    2025-06-09 16:31:44.550  - info: host.iobroker instance system.adapter.admin.0 in version "7.6.17" started with p        id 706
    2025-06-09 16:31:46.585  - info: host.iobroker instance system.adapter.backitup.0 in version "3.2.2" started with        pid 713
    2025-06-09 16:31:47.885  - info: admin.0 (706) starting. Version 7.6.17 in /opt/iobroker/node_modules/iobroker.ad        min, node: v20.19.2, js-controller: 7.0.6
    2025-06-09 16:31:47.976  - info: admin.0 (706) requesting all objects
    2025-06-09 16:31:48.950  - info: admin.0 (706) received all objects
    2025-06-09 16:31:49.539  - info: backitup.0 (713) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.        backitup, node: v20.19.2, js-controller: 7.0.6
    2025-06-09 16:31:49.595  - info: admin.0 (706) socket.io server listening on port 8081
    2025-06-09 16:31:49.600  - info: admin.0 (706) http server listening on port 8081
    2025-06-09 16:31:49.600  - info: admin.0 (706) Use link "http://127.0.0.1:8081" to configure.
    2025-06-09 16:31:49.758  - info: backitup.0 (713) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2025-06-09 16:31:50.529  - info: host.iobroker instance system.adapter.discovery.0 in version "5.0.0" started wit        h pid 749
    2025-06-09 16:31:53.441  - info: discovery.0 (749) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker        .discovery, node: v20.19.2, js-controller: 7.0.6
    2025-06-09 17:02:33.535  - info: admin.0 (706) ==> Connected system.user.admin from ::ffff:192.168.178.40
    iob diag has finished.
    @xt1gerx sagte in Backup wiederherstellen auf js-controller 4.0:
    wir brauchen es aber von der alten!
    • X Offline
      X Offline
      xT1GeRx
      @Thomas-Braun
      Zu der alten hab ich nichts mehr. Wie gesagt. Nach dem Updaten ging nichts mehr. Auch kein ssh, kein Zugriff ansich.
      Wie ist deine Persönliche Meinung. Lohnt sich der Aufwand oder soll ich es einfach neu aufsetzten? Ich möchte euch hier nicht eurer Zeit berauben.
      • X xT1GeRx
        @Thomas-Braun
        Script v.2025-03-08
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        admin
        HOME=/home/admin
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           536M          0B        536M
                 3791 M total memory
                  499 M used memory
                  527 M active memory
                 3065 M free memory
                   31 M buffer memory
                  267 M swap cache
                  511 M total swap
                    0 M used swap
                  511 M free swap
        *** FILESYSTEM ***
        /var:
        889M    /var/
        213M    /var/cache
        208M    /var/cache/apt
        164M    /var/lib
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.6.17
        Adapter State
        + instance is alive
        Objects and States
        Objects:        149
        States:         108
        Pending Updates: 48
        @xt1gerx
        Dann versuch jetzt mal die Backupdatei aus der cloud in /opt/iobroker/backups abzulegen und per
        iobroker restore <backup name or path>
        das wiederherzustellen. Ausgaben vollständig zeigen.
        • X Offline
          X Offline
          xT1GeRx
          @Thomas-Braun
          admin@iobroker:~ $ iobroker restore iobroker_2025_06_07-23_23_27_backupiobroker
          host.iobroker Restore legacy backup.
          The current version of js-controller differs from the version in the backup.
          The js-controller version of the backup can not be restored automatically.
          To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@4.0.23 --omit=dev" insid                     e your ioBroker directory
          If you really want to restore the backup with the current installed js-controller, execute the restore command wit                     h the --force flag
          • X xT1GeRx
            @Thomas-Braun
            @xt1gerx
            Da ist die Anleitung ja gleich mit dabei. Konkret also wohl dann:
            cd /opt/iobroker/
            • X Offline
              X Offline
              xT1GeRx
              @Thomas-Braun
              Es hat mal soweit alles funktioniert. Ich komme jedoch nicht auf die ioBroker Seite. Weder mit dem Port 8081 noch mit 8082. Habe mal einen check gemacht und das kam raus. Ein paar Instanzen fehlen, ist jedoch nicht so wild.
              admin@iobroker:~ $ iobroker status
              Objects type: jsonl
              States  type: jsonl
              admin@iobroker:~ $ iobroker list instances
                system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bi                        nd: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                system.adapter.birthdays.0              : birthdays             : iobroker                                 - disabled
                system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
                system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
                system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
                system.adapter.hmip.0                   : hmip                  : iobroker                                 - disabled
                system.adapter.hue.0                    : hue                   : iobroker                                 - disabled, port: 443
                system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
                system.adapter.pollenflug.0             : pollenflug            : iobroker                                 - disabled
                system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
                system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
                system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bi                        nd: 0.0.0.0, run as: admin
                system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled
              + instance is alive
              • X xT1GeRx
                @Thomas-Braun
                Objects type: jsonl
                States  type: jsonl
                + instance is alive
                @xt1gerx
                iob start admin
                • X xT1GeRx
                  @Thomas-Braun
                  Objects type: jsonl
                  States  type: jsonl
                  + instance is alive
                  Geduld!
                  so ein Restore dauert!
                  je nach Gardware auch mal eine Stunde.
                  bis das fertig ist solltest du nicht eingreifen
                  • X Offline
                    X Offline
                    xT1GeRx
                    Alles klar. Ich warte dann mal bis 20 Uhr ab und melde mich dann nochmals. Vielen Dank @Thomas-Braun
                    Danke auch @Homoran
                    • X xT1GeRx
                      Danke auch @Homoran
                      was sagt denn iob logs --watch
                      das müsste mittlerweile eigentlich fertig sein.
                      • X Offline
                        X Offline
                        xT1GeRx
                        @homoran ich habe mal die warnings rausgesucht. Die Liste ist aktuell über 1000 Zeilen Lang.
                        2025-06-09 17:56:41.710  - error: admin.0 (2990) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
                        2025-06-09 17:56:42.746  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user resarts it.
                        2025-06-09 17:57:31.161  - warn: host.iobroker startInstance cannot find adapter "javascript@6.0.3". Try to install it... 1 attempt
                        2025-06-09 18:00:28.860  - error: admin.0 (3429) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
                        2025-06-09 18:00:29.853  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user rest        arts it.
                        2025-06-09 18:11:13.453  - error: admin.0 (4020) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
                        2025-06-09 18:11:13.455  - info: admin.0 (4020) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2025-06-09 18:11:13.768  - info: admin.0 (4020) Request actual repository...
                        2025-06-09 18:11:14.024  - warn: admin.0 (4020) Cannot check node.js/npm version
                        2025-06-09 18:11:14.048  - info: admin.0 (4020) terminating http server on port 8081
                        2025-06-09 18:11:14.533  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user rest        arts it.
                        2025-06-09 18:27:24.227  - error: admin.0 (4479) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
                        2025-06-09 18:27:24.230  - info: admin.0 (4479) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2025-06-09 18:27:24.501  - info: admin.0 (4479) Request actual repository...
                        2025-06-09 18:27:24.778  - warn: admin.0 (4479) Cannot check node.js/npm version
                        2025-06-09 18:27:25.039  - info: admin.0 (4479) terminating http server on port 8081
                        2025-06-09 18:27:25.449  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                        2025-06-09 18:27:25.514  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user rest        arts it.
                        2025-06-09 18:27:25.514  - info: host.iobroker Do not restart adapter system.adapter.admin.0 because desired by instance
                        2025-06-09 18:27:26.456  - info: backitup.0 (4506) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.19.2, js-controller: 4.0.23
                        2025-06-09 18:27:26.557  - info: backitup.0 (4506) [iobroker] backup was activated at 02:30 every 1 day(s)
                        Wie es aussieht gibt es ein Problem mit dem Admin Web Zugang oder?
                        • X xT1GeRx
                          uninteressant!
                          es geht um die gerade aktuellen Meldungen!
                          die geposteten sind ja "uralt"
                          • X xT1GeRx
                            @xt1gerx
                            Ist das Backup jetzt drin?
                            Dann musst du jetzt den Rest in die Gegenwart holen.
                            Inkl. des js-controllers@7 dann.
                            X 1 Antwort Letzte Antwort
                            • X Offline
                              X Offline
                              xT1GeRx
                              @Thomas-Braun
                              aktuell die letzten. Kann auch die komplette Liste einfügen?
                              2025-06-09 18:27:24.286  - info: host.iobroker instance system.adapter.backitup.0 started with pid 4506
                              2025-06-09 18:27:25.514  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                @xt1gerx
                                X Offline
                                X Offline
                                xT1GeRx
                                @thomas-braun ich würde sagen das das backup geladen ist. Verstehe ich das richtig, dass ich zuerst alles updaten soll bevor der Webzugang wieder geht? Wenn ja, hättest du mir eine sichere anleitung, bevor ich wieder was versaue?
                                • X xT1GeRx
                                  @xt1gerx
                                  Dann lass uns doch mal sehen, wo du da nun stehst.
                                  iob diag
                                  anschauen.
                                    @xt1gerx
                                    iob diag
                                    anschauen.
                                    X Offline
                                    X Offline
                                    xT1GeRx
                                    @thomas-braun alles war rauskam
                                    ```bash
                                    Script v.2025-03-08
                                    *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                     19:01:35 up  2:30,  1 user,  load average: 0.37, 0.08, 0.03
                                    CPU threads: 4
                                    Current issues:
                                                   Local time: Mon 2025-06-09 19:01:35 CEST
                                               Universal time: Mon 2025-06-09 17:01:35 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    admin
                                    HOME=/home/admin
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            4.0G        385M        1.8G        6.2M        1.9G        3.6G
                                    Swap:           536M          0B        536M
                                    Total:          4.5G        385M        2.3G
                                    Active iob-Instances:   2
                                             3791 M total memory
                                              367 M used memory
                                              406 M active memory
                                             1464 M inactive memory
                                             1712 M free memory
                                               99 M buffer memory
                                             1693 M swap cache
                                              511 M total swap
                                                0 M used swap
                                              511 M free swap
                                    top - 19:01:36 up  2:30,  1 user,  load average: 0.37, 0.08, 0.03
                                    Tasks: 165 total,   1 running, 164 sleeping,   0 stopped,   0 zombie
                                    %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                    MiB Mem :   3791.4 total,   1712.3 free,    367.5 used,   1793.1 buff/cache
                                    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3423.9 avail Mem
                                    *** FILESYSTEM ***
                                    /dev/mmcblk0p2 ext4      117G  4.1G  107G   4% /
                                    [Mon Jun  9 16:30:57 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm28        35.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:B9:D2:87 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  c        onsole=ttyS0,115200 console=tty1 root=PARTUUID=ed3ceec2-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Mon Jun  9 16:30:58 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                                    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    889M    /var/
                                    213M    /var/cache
                                    208M    /var/cache/apt
                                    164M    /var/lib
                                    11M     /opt/iobroker/backups/
                                    198M    /opt/iobroker/iobroker-data/
                                    169M    /opt/iobroker/iobroker-data/files
                                    48M     /opt/iobroker/iobroker-data/files/javascript.admin
                                    26M     /opt/iobroker/iobroker-data/objects.jsonl
                                    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
                                    6.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
                                    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                                    USB-Devices by-id:
                                    *** ZigBee Settings ***
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    iobroker            iobroker (version: 4.0.23, hostname: iobroker      , alive, uptime: 2058)
                                    admin:          6.3.5
                                    javascript:     6.0.3
                                    Adapter State
                                      system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    + instance is alive
                                    Adapter    "admin"        : 7.6.17   , installed 6.3.5  [Updatable]
                                    Adapter    "backitup"     : 3.2.2    , installed 2.5.12 [Updatable]
                                    Adapter    "birthdays"    : 4.0.0    , installed 2.2.0  [Updatable]
                                    Adapter    "daswetter"    : 3.2.3    , installed 3.1.7  [Updatable]
                                    Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
                                    Adapter    "dwd"          : 2.8.5    , installed 2.8.3  [Updatable]
                                    Adapter    "fullybrowser" : 3.1.1    , installed 2.1.2  [Updatable]
                                    Adapter    "hmip"         : 1.27.0   , installed 1.20.0 [Updatable]
                                    Adapter    "hue"          : 3.16.1   , installed 3.7.1  [Updatable]
                                    Adapter    "javascript"   : 8.9.2    , installed 6.0.3  [Updatable]
                                    Controller "js-controller": 7.0.6    , installed 4.0.23 [Updatable]
                                    Adapter    "pollenflug"   : 2.0.0    , installed 1.0.6  [Updatable]
                                    Adapter    "pushover"     : 4.1.0    , installed 3.0.3  [Updatable]
                                    Adapter    "rpi2"         : 2.4.0    , installed 1.3.2  [Updatable]
                                    Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
                                    Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
                                    Adapter    "vis"          : 1.5.6    , installed 1.4.16 [Updatable]
                                    Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
                                    Adapter    "vis-icontwo"  : 1.11.0   , installed 0.90.0 [Updatable]
                                    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.1  [Updatable]
                                    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
                                    Adapter    "web"          : 7.0.8    , installed 4.3.0  [Updatable]
                                    Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
                                    Adapter    "zigbee"       : 2.0.5    , installed 1.8.10 [Updatable]
                                    Objects and States
                                    Objects:        8811
                                    States:         7998
                                    Pending Updates: 48
                                    2025-06-09 18:27:17.755  - info: host.iobroker hostname: iobroker, node: v20.19.2
                                    2025-06-09 18:27:17.757  - info: host.iobroker ip addresses: 192.168.178.37 2003:d0:6700:2e00:d638:5401:7be0:ba73 fe80::76d4:1422:ca5b:b545
                                    2025-06-09 18:27:19.448  - info: host.iobroker connected to Objects and States
                                    2025-06-09 18:27:19.500  - info: host.iobroker added notifications configuration of host
                                    2025-06-09 18:27:20.179  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
                                    2025-06-09 18:27:20.181  - info: host.iobroker 22 instances found
                                    2025-06-09 18:27:20.218  - info: host.iobroker starting 2 instances
                                    2025-06-09 18:27:20.313  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
                                    2025-06-09 18:27:20.328  - info: host.iobroker instance system.adapter.admin.0 started with pid 4479
                                    2025-06-09 18:27:20.340  - info: host.iobroker Some obsolete host states deleted.
                                    2025-06-09 18:27:22.763  - info: admin.0 (4479) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v20.19.2, js-controller: 4.0.23
                                    2025-06-09 18:27:22.809  - info: admin.0 (4479) requesting all states
                                    2025-06-09 18:27:22.810  - info: admin.0 (4479) requesting all objects
                                    2025-06-09 18:27:24.173  - info: admin.0 (4479) received all objects
                                    2025-06-09 18:27:25.514  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user res        tarts it.
                                    • X xT1GeRx
                                      ```bash
                                      Script v.2025-03-08
                                      *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                      OS is similar to:
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                      CPU threads: 4
                                      Current issues:
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      admin
                                      HOME=/home/admin
                                      iobroker
                                      HOME=/home/iobroker
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:           536M          0B        536M
                                               3791 M total memory
                                                367 M used memory
                                                406 M active memory
                                               1712 M free memory
                                                 99 M buffer memory
                                               1693 M swap cache
                                                511 M total swap
                                                  0 M used swap
                                                511 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      889M    /var/
                                      213M    /var/cache
                                      208M    /var/cache/apt
                                      164M    /var/lib
                                      USB-Devices by-id:
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      admin:          6.3.5
                                      javascript:     6.0.3
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        8811
                                      States:         7998
                                      Pending Updates: 48
                                      @xt1gerx
                                      Also alles updatebar.
                                      Mit dem System selber anfangen:
                                      iob stop
                                      sudo apt update && sudo apt full-upgrade
                                      sudo reboot
                                      Dann den ioBroker in Angriff nehmen:
                                      iob update
                                      iob upgrade all
                                      Das wird vermutlich nicht ohne Fehlermeldungen durchlaufen. Aber egal.
                                      Dann
                                      iob stop
                                      iob upgrade self
                                      iob start
                                      iob update
                                      iob upgrade all
                                      versuchen. Wenn das nicht in einem Rutsch den js-controller@7 auf die Kiste spült, dann versuchen wir es mit Schriten über js-controller@5 und @6.
                                        @xt1gerx
                                        iob stop
                                        sudo reboot
                                        iob update
                                        iob upgrade all
                                        Dann
                                        iob stop
                                        iob upgrade self
                                        iob start
                                        iob update
                                        iob upgrade all
                                        X Offline
                                        X Offline
                                        xT1GeRx
                                        @thomas-braun Hat alles geklappt. Js auf 7 und node v20. Alle Updates ohne Fehlermeldung. Komme überall drauf und alles ist vorhanden wie davor.
                                        VIELEN VIELEN DANK für deine Hilfe und Zeit @thomas-braun 🎉
                                        • X xT1GeRx
                                          @xt1gerx
                                          Gut gut.
                                          Dann zeig mal zum Abschluß nochmal ein
                                          iob diag
                                          Für die Zukunft: Lass das System nicht mehr versumpfen.
                                          Man muss nicht eine Version x.0 am ersten Tag installieren, aber eine x.1 sollte man dann schon beizeiten mitnehmen.
