  4. Test Adapter Philips-TV v0.2.x
    6.7k
philipsphilips tv
550 Beiträge 84 Kommentatoren 185.7k Aufrufe 48 Beobachtet
  • L Lucky_ESA
    @domi920
    Nein es ist kein Android System
    Kenne jetzt nicht alle Einstellungen vom Adapter aber musst du dann nicht jointspace statt android auswählen?
    Gruß//Lucky
    Domi920D Offline
    Domi920D Offline
    Domi920
    #541
    @lucky_esa sagte in Test Adapter Philips-TV v0.2.x:
    @domi920
    Gruß//Lucky
    Dann kann man kein Pairing Starten im Adapter und dadurch auch keine Verbindung herstellen.
    Der TV zeigt dann erst einen Pin an wenn man das Pairing einmal macht.
    Außerdem funktioniert dann gar nichts mehr:
    philips-tv.0
    2024-08-27 13:43:19.144	error	Could not poll API: {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"date":"Tue, 27 Aug 2024 11:43:18 GMT","connection":"close","content-type":"text/html; charset=utf-8","cache-control":"no-cache","access-control-allow-origin":"*","content-length":"72"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.162.1.101:1925","port":"1925","hostname":"192.162.1.101","hash":null,"search":null,"query":null,"pathname":"/6/audio/volume","path":"/6/audio/volume","href":"http://192.162.1.101:1925/6/audio/volume"},"method":"GET","headers":{}}}
    philips-tv.0
    2024-08-27 13:43:14.137	error	Could not poll API: {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"date":"Tue, 27 Aug 2024 11:43:13 GMT","connection":"close","content-type":"text/html; charset=utf-8","cache-control":"no-cache","access-control-allow-origin":"*","content-length":"72"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.162.1.101:1925","port":"1925","hostname":"192.162.1.101","hash":null,"search":null,"query":null,"pathname":"/6/audio/volume","path":"/6/audio/volume","href":"http://192.162.1.101:1925/6/audio/volume"},"method":"GET","headers":{}}}
    philips-tv.0
    2024-08-27 13:43:09.132	error	Could not poll API: {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"date":"Tue, 27 Aug 2024 11:43:08 GMT","connection":"close","content-type":"text/html; charset=utf-8","cache-control":"no-cache","access-control-allow-origin":"*","content-length":"72"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.162.1.101:1925","port":"1925","hostname":"192.162.1.101","hash":null,"search":null,"query":null,"pathname":"/6/audio/volume","path":"/6/audio/volume","href":"http://192.162.1.101:1925/6/audio/volume"},"method":"GET","headers":{}}}
    philips-tv.0
    2024-08-27 13:43:06.192	error	Could not send key "VolumeDown": {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"date":"Tue, 27 Aug 2024 11:43:05 GMT","connection":"close","content-type":"text/html; charset=utf-8","cache-control":"no-cache","access-control-allow-origin":"*","content-length":"72"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.162.1.101:1925","port":"1925","hostname":"192.162.1.101","hash":null,"search":null,"query":null,"pathname":"/6/input/key","path":"/6/input/key","href":"http://192.162.1.101:1925/6/input/key"},"method":"POST","headers":{"content-length":20}}}
    philips-tv.0
    2024-08-27 13:43:06.187	debug	Sending key "VolumeDown"
    philips-tv.0
    2024-08-27 13:43:06.187	debug	state change philips-tv.0.keys.volumeDown: true
    philips-tv.0
    2024-08-27 13:43:04.601	error	Could not send key "YellowColour": {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"date":"Tue, 27 Aug 2024 11:43:03 GMT","connection":"close","content-type":"text/html; charset=utf-8","cache-control":"no-cache","access-control-allow-origin":"*","content-length":"72"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.162.1.101:1925","port":"1925","hostname":"192.162.1.101","hash":null,"search":null,"query":null,"pathname":"/6/input/key","path":"/6/input/key","href":"http://192.162.1.101:1925/6/input/key"},"method":"POST","headers":{"content-length":22}}}
    philips-tv.0
    2024-08-27 13:43:04.597	debug	Sending key "YellowColour"
    philips-tv.0
    2024-08-27 13:43:04.597	debug	state change philips-tv.0.keys.yellowColour: true
    philips-tv.0
    2024-08-27 13:43:04.124	error	Could not poll API: {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"date":"Tue, 27 Aug 2024 11:43:03 GMT","connection":"close","content-type":"text/html; charset=utf-8","cache-control":"no-cache","access-control-allow-origin":"*","content-length":"72"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.162.1.101:1925","port":"1925","hostname":"192.162.1.101","hash":null,"search":null,"query":null,"pathname":"/6/audio/volume","path":"/6/audio/volume","href":"http://192.162.1.101:1925/6/audio/volume"},"method":"GET","headers":{}}}
    philips-tv.0
    2024-08-27 13:43:03.304	error	Could not send key "VolumeUp": {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"date":"Tue, 27 Aug 2024 11:43:02 GMT","connection":"close","content-type":"text/html; charset=utf-8","cache-control":"no-cache","access-control-allow-origin":"*","content-length":"72"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.162.1.101:1925","port":"1925","hostname":"192.162.1.101","hash":null,"search":null,"query":null,"pathname":"/6/input/key","path":"/6/input/key","href":"http://192.162.1.101:1925/6/input/key"},"method":"POST","headers":{"content-length":18}}}
    philips-tv.0
    2024-08-27 13:43:03.301	debug	Sending key "VolumeUp"
    philips-tv.0
    2024-08-27 13:43:03.300	debug	state change philips-tv.0.keys.volumeUp: true
    philips-tv.0
    2024-08-27 13:43:00.877	error	Could not send key "VolumeUp": {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"date":"Tue, 27 Aug 2024 11:42:59 GMT","connection":"close","content-type":"text/html; charset=utf-8","cache-control":"no-cache","access-control-allow-origin":"*","content-length":"72"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.162.1.101:1925","port":"1925","hostname":"192.162.1.101","hash":null,"search":null,"query":null,"pathname":"/6/input/key","path":"/6/input/key","href":"http://192.162.1.101:1925/6/input/key"},"method":"POST","headers":{"content-length":18}}}
    philips-tv.0
    2024-08-27 13:43:00.873	debug	Sending key "VolumeUp"
    philips-tv.0
    2024-08-27 13:43:00.873	debug	state change philips-tv.0.keys.volumeUp: true
    philips-tv.0
    2024-08-27 13:42:59.119	error	Could not poll API: {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"date":"Tue, 27 Aug 2024 11:42:58 GMT","connection":"close","content-type":"text/html; charset=utf-8","cache-control":"no-cache","access-control-allow-origin":"*","content-length":"72"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.162.1.101:1925","port":"1925","hostname":"192.162.1.101","hash":null,"search":null,"query":null,"pathname":"/6/audio/volume","path":"/6/audio/volume","href":"http://192.162.1.101:1925/6/audio/volume"},"method":"GET","headers":{}}}
    philips-tv.0
    2024-08-27 13:42:54.072	error	Could not poll API: {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"date":"Tue, 27 Aug 2024 11:42:53 GMT","connection":"close","content-type":"text/html; charset=utf-8","cache-control":"no-cache","access-control-allow-origin":"*","content-length":"72"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.162.1.101:1925","port":"1925","hostname":"192.162.1.101","hash":null,"search":null,"query":null,"pathname":"/6/audio/volume","path":"/6/audio/volume","href":"http://192.162.1.101:1925/6/audio/volume"},"method":"GET","headers":{}}}
    philips-tv.0
    2024-08-27 13:42:49.065	error	Could not poll API: {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"date":"Tue, 27 Aug 2024 11:42:48 GMT","connection":"close","content-type":"text/html; charset=utf-8","cache-control":"no-cache","access-control-allow-origin":"*","content-length":"72"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.162.1.101:1925","port":"1925","hostname":"192.162.1.101","hash":null,"search":null,"query":null,"pathname":"/6/audio/volume","path":"/6/audio/volume","href":"http://192.162.1.101:1925/6/audio/volume"},"method":"GET","headers":{}}}
    philips-tv.0
    2024-08-27 13:42:44.055	error	Could not poll API: {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"date":"Tue, 27 Aug 2024 11:42:43 GMT","connection":"close","content-type":"text/html; charset=utf-8","cache-control":"no-cache","access-control-allow-origin":"*","content-length":"72"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.162.1.101:1925","port":"1925","hostname":"192.162.1.101","hash":null,"search":null,"query":null,"pathname":"/6/audio/volume","path":"/6/audio/volume","href":"http://192.162.1.101:1925/6/audio/volume"},"method":"GET","headers":{}}}
    philips-tv.0
    2024-08-27 13:42:39.034	info	Starting with ip "192.162.1.101" (API v6 - Jointspace)
    philips-tv.0
    2024-08-27 13:42:39.024	info	starting. Version 0.5.4 (non-npm: AlCalzone/ioBroker.philips-tv) in /opt/iobroker/node_modules/iobroker.philips-tv, node: v20.16.0, js-controller: 6.0.9
    philips-tv.0
    2024-08-27 13:42:38.832	debug	States connected to redis: 127.0.0.1:9000
    philips-tv.0
    2024-08-27 13:42:38.769	debug	States create User PubSub Client
    philips-tv.0
    2024-08-27 13:42:38.768	debug	States create System PubSub Client
    philips-tv.0
    2024-08-27 13:42:38.756	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    philips-tv.0
    2024-08-27 13:42:38.735	debug	Objects connected to redis: 127.0.0.1:9001
    philips-tv.0
    2024-08-27 13:42:38.731	debug	Objects client initialize lua scripts
    philips-tv.0
    2024-08-27 13:42:38.697	debug	Objects create User PubSub Client
    philips-tv.0
    2024-08-27 13:42:38.696	debug	Objects create System PubSub Client
    philips-tv.0
    2024-08-27 13:42:38.695	debug	Objects client ready ... initialize now
    philips-tv.0
    2024-08-27 13:42:38.674	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    L 1 Antwort Letzte Antwort
    • Domi920D Domi920
      @domi920
      Gruß//Lucky
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      philips-tv.0
      Lucky_ESA
      #542
      @domi920 Dann musst du wohl ein Issues auf Github erstellen. Habe leider keine weitere Idee.
      • E Offline
        el_malto
        #543
        Gibt es eine Auflistung, welche Funktionen der Adapter kann?
        Hintergrund: Ich habe schon einen Enigma2 Receiver in ioBroker angebunden der über HDMI den TV Steuert. Wäre schön zu wissen ob ich mit diesen Adapter noch mehr Funktionen am TV nutzen kann.
        • W Offline
          W Offline
          wobbix
          #544
          Moin,
          Ich wollte mal ganz höfflich fragen, ob an dem Adapter noch wegen could not poll API gearbeitet wird?
          LG Wobbix
          • W wobbix
            Moin,
            LG Wobbix
            Lucky_ESA
            #545
            @wobbix sagte in Test Adapter Philips-TV v0.2.x:
            Moin,
            LG Wobbix
            Hier wirst du wohl erst Glück haben wenn der Ferneseher vom Entwickler kaputt geht und er einen neuen kaufen muss. Wenn du Zeit hast und dein ioBroker auf eine Linux Maschine läuft könnte ich versuchen zu helfen.
            W 1 Antwort Letzte Antwort
            • L Lucky_ESA
              Moin,
              LG Wobbix
              W Offline
              W Offline
              wobbix
              #546
              @lucky_esa
              Hallo.
              Ja mein IOBroker läft aufr einem Raspberry Pi.
              Ich würde schon versuchen mir da Zeit zu nehmen.
              LG Wobbix
              • WszeneW Offline
                WszeneW Offline
                Wszene
                #547
                Ich habe jetzt den Adapter auch mal installiert
                Ich muss sagen Danke der funktioniert toll
                Ich habe nur eine Frage
                In den EInstellungen kann ich ja die Mac-Adresse eintragen um den TV zu wecken
                Nur wie funktioniert das?
                Wenn der TV im Standby ist ist er für den Adapter nicht zu erreichen und damit kann ich den TV auch nicht anschalten
                Danke im Voraus
                Marcel
                Meine Hard- & Software:
                • CC2652P Zigbee Stick
                • Lichtschalter mit Tasmota
                • IKEA TRÅDFRI Glühbirnen
                • Aqara Sensoren
                • WszeneW Wszene
                  Danke im Voraus
                  Marcel
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  #548
                  @wszene Es wird dann probiert über WOL das Gerät einzuschalten, dafür musst du z. B. wenn du eine Fritz!Box hast dies für das Gerät dort explizit aktivieren. Und ja die MAC Adresse vom genutzten Interface (siehe Netzwerkeinstellungen im TV selbst) im Adapter eintragen.
                  Videotutorials & mehr
                  WszeneW 1 Antwort Letzte Antwort
                  • foxriver76F foxriver76
                    WszeneW Offline
                    WszeneW Offline
                    Wszene
                    #549
                    @foxriver76 sagte in Test Adapter Philips-TV v0.2.x:
                    ich habe jetzt mal WOL aktiviert (klappt auch vom Router) also der TV ist dann im Adapter online
                    Aber was muss ich machen das es auch der Adapter macht?
                    • Aqara Sensoren
                    • integer63I integer63
                      @AlCalzone:
                      Schade, ein paar Posts drüber war es ohne die /5 angegeben. Ich hatte gehofft, dass man daran direkt die API-Version erkennen kann, ohne zu raten. `
                      Jetzt war ich doch fast ein bisschen verunsichert, aber bei mir bekomme ich eine Fehlermeldung, wenn ich die /5 weglasse
                      und hier mit /5
                      AphofisA Offline
                      AphofisA Offline
                      Aphofis
                      schrieb am zuletzt editiert von Aphofis
                      #550
                      Bei mir läuft die verbindung und kann alle funktionen auch in VIS einbinden!
