  3. Einsteigerfragen
  4. Automatisierung
  5. [gelöst] Log-Einträge nach Umzug doppelt vorhanden
    1.0k
Geplant Angeheftet Gesperrt Verschoben Automatisierung
12 Beiträge 3 Kommentatoren 1.4k Aufrufe 2 Beobachtet
  • Siggi0904S Offline
    Siggi0904S Offline
    Siggi0904
    Hier auch noch der Output von iob diag in Lang
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-33-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
    OS is similar to:
    model name      : QEMU Virtual CPU version 2.5+
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     18:35:10 up 9 days,  2:00,  2 users,  load average: 0.05, 0.09, 0.08
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-04-21 18:35:10 CEST
               Universal time: Mon 2025-04-21 16:35:10 UTC
                     RTC time: Mon 2025-04-21 16:35:10
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    mario
    HOME=/home/mario
    GROUPS=mario cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.3G        3.0G        906M        520K        4.7G        5.3G
    Swap:           1.0G        536K        1.0G
    Total:          9.3G        3.0G        1.9G
    Active iob-Instances:   29
             7941 M total memory
             2872 M used memory
              756 M active memory
             5833 M inactive memory
              864 M free memory
              346 M buffer memory
             4172 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    top - 18:35:10 up 9 days,  2:00,  2 users,  load average: 0.05, 0.09, 0.08
    Tasks: 126 total,   1 running, 125 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7941.2 total,    863.2 free,   2873.6 used,   4519.0 buff/cache
    MiB Swap:    975.0 total,    974.5 free,      0.5 used.   5067.5 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     795M  520K  794M   1% /run
    /dev/sda1      ext4       48G  5.7G   40G  13% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     795M     0  795M   0% /run/user/1000
    [Sat Apr 12 16:34:42 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Apr 12 16:34:42 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    463M    /var/
    248M    /var/cache
    241M    /var/cache/apt
    175M    /var/lib
    165M    /var/cache/apt/archives
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    12M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1015M   /opt/iobroker/iobroker-data/
    854M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    34M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
    11M     /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.0
    /usr/bin/node           v20.19.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.0-1nodesource1
      Candidate: 20.19.0-1nodesource1
      Version table:
     *** 20.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 783228)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.3
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
    + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobroker                                 -  enabled
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
    + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 8083
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3307
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.3    , installed 7.6.3
    Adapter    "alarm"        : 3.6.8    , installed 3.6.8
    Adapter    "alexa-timer-vis": 2.0.8  , installed 2.0.8
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "awtrix-light" : 1.4.1    , installed 1.4.1
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "deconz"       : 1.6.4    , installed 1.6.4
    Adapter    "email"        : 2.0.3    , installed 2.0.3
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "heatingcontrol": 2.12.14 , installed 2.12.14
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 9.2.0    , installed 9.2.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Objects and States
    Objects:        10833
    States:         8896
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.64:2010     0.0.0.0:*               LISTEN      1001       956695     71926/io.hm-rpc.0
    tcp        0      0 192.168.178.64:2001     0.0.0.0:*               LISTEN      1001       955877     71909/io.hm-rpc.1
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       63839      14657/io.sonoff.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12174      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15585      507/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       58574      12686/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       58569      12686/iobroker.js-c
    tcp6       0      0 :::111                  :::*                    LISTEN      0          12176      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15596      507/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       64657      14817/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       58673      12715/io.admin.0
    udp        0      0 0.0.0.0:54816           0.0.0.0:*                           1001       68840      15381/io.javascript
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       63851      14668/io.shelly.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       173491     22040/io.deconz.0
    udp        0      0 0.0.0.0:35968           0.0.0.0:*                           1001       3268751    15381/io.javascript
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13996      372/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12175      1/init
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       66404      15198/io.mihome-vac
    udp        0      0 192.168.178.64:5353     0.0.0.0:*                           1001       64601      14758/io.tr-064.0
    udp6       0      0 :::1900                 :::*                                1001       173494     22040/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       173493     22040/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       173492     22040/io.deconz.0
    udp6       0      0 :::111                  :::*                                0          12177      1/init
    2025-04-21 18:30:00.017  - info: javascript.0 (15381) script.js.Skripte.Wohnzimmer.Luftqualität: Daten des Alexa-Luftqualitätsmonitors aktualisiert.
    2025-04-21 18:30:00.020  - info: javascript.0 (15381) script.js.Skripte.Wohnzimmer.Luftqualität: Daten des Alexa-Luftqualitätsmonitors aktualisiert.
    2025-04-21 18:30:00.027  - info: javascript.0 (15381) script.js.Skripte.Wohnung.VerbrauchTasmota: Tasmota Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 6
    2025-04-21 18:30:00.043  - info: javascript.0 (15381) script.js.Skripte.Wohnung.VerbrauchShelly: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 1
    2025-04-21 18:30:00.072  - info: javascript.0 (15381) script.js.Skripte.Außen.AstroDaten: Astro: Gültige Zeiten: [aktueller Tag: 7] | [nächster Tag: 7] | [Aktualisiert: 0] | Aktuelle Tageszeit: Mittag | Kommende Tageszeit: früher Abend
    2025-04-21 18:30:00.147  - warn: alexa2.0 (568128) Smart Home device request blocked for ...entfernt....p_wg_f730P
    2025-04-21 18:30:00.931  - info: ical.0 (630427) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.19.0, js-controller: 7.0.6
    2025-04-21 18:30:01.511  - info: ical.0 (630427) processing URL: Müllkalender https://....entfernt....
    2025-04-21 18:30:01.556  - info: ical.0 (630427) processing URL: Urlaub ....entfernt....269fb571a/basic.ics
    2025-04-21 18:30:01.585  - info: ical.0 (630427) processing URL: Schichtplan-Roland https://calendar.google.com/calendar/ical/...entfernt...2/basic.ics
    2025-04-21 18:30:04.019  - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.3" started with pid 630445
    2025-04-21 18:30:04.830  - info: daswetter.0 (630445) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.0, js-controller: 7.0.6
    2025-04-21 18:30:06.596  - info: daswetter.0 (630445) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-04-21 18:30:06.636  - info: ical.0 (630427) Terminated (NO_ERROR): Without reason
    2025-04-21 18:30:07.101  - info: daswetter.0 (630445) cleaned everything up...
    2025-04-21 18:30:07.109  - info: host.iobroker instance system.adapter.daswetter.0 having pid 630445 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-04-21 18:30:07.149  - info: host.iobroker instance system.adapter.ical.0 having pid 630427 terminated with code 0 (NO_ERROR)
    2025-04-21 18:30:08.027  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 630462
    2025-04-21 18:30:08.882  - info: dwd.0 (630462) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.0, js-controller: 7.0.6
    2025-04-21 18:30:09.143  - info: dwd.0 (630462) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-04-21 18:30:09.654  - info: host.iobroker instance system.adapter.dwd.0 having pid 630462 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-04-21 18:35:06.009  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 630820
    2025-04-21 18:35:06.856  - info: dwd.0 (630820) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.0, js-controller: 7.0.6
    2025-04-21 18:35:07.127  - info: dwd.0 (630820) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-04-21 18:35:07.640  - info: host.iobroker instance system.adapter.dwd.0 having pid 630820 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    MOD-EDIT: private Daten entfernt!
    • Siggi0904S Siggi0904
      nach dem Ausfall meines NUC habe ich IOBroker über den Backup-Restore wiederhergestellt
      und alles läuft auch super.
      Bei der Neueinrichtung der VM unter Proxmox habe ich dem System 2 Kerne und 8GB Ram gegönnt.
      Das kann der neue Beelink ja nun leisten. Vorher hatte ich 1 Kern bei 4GB RAM
      Das Restore über den Backitup-Adapter hat auch super funktioniert und es rennt alles wieder.
      Nun aber das Problem, ich habe alle Einträge im LOG doppelt vorhanden, was die Hardware angeht.
      Zum System:
      Admin: 7.6.3
      JS-Controller: 7.0.6
      Javascript-Adapter: 8.8.3
      Repo: Stable
      OS: Debian 12, alles aktuell
      Wie kann ich das beheben? Warum wird alles doppelt angezeigt und scheinbar auch doppelt ausgeführt?
      LOG-Auszüge von heute:
      2025-04-21 18:00:00.021 - info: javascript.0 (15381) script.js.Skripte.Wohnzimmer.Luftqualität: Daten des Alexa-Luftqualitätsmonitors aktualisiert.
      2025-04-21 18:00:00.023 - info: javascript.0 (15381) script.js.Skripte.Wohnzimmer.Luftqualität: Daten des Alexa-Luftqualitätsmonitors aktualisiert.
      2025-04-21 17:48:48.533 - info: javascript.0 (15381) script.js.Skripte.Wohnung.AnwesenheitTaster: Taster-Anwesenheit wurde kurz betätigt
      2025-04-21 17:48:48.533 - info: javascript.0 (15381) script.js.Skripte.Wohnung.AnwesenheitTaster: Taster Anwesenheit kurz betätigt, Du bist Anwesend, schönen Tag.Klappriges Bittermärchen
      2025-04-21 17:48:48.533 - info: javascript.0 (15381) script.js.Skripte.Wohnung.AnwesenheitTaster: Taster Anwesenheit kurz betätigt, Du bist Anwesend, schönen Tag.Schauriger Ekelklopper
      2025-04-21 17:49:12.653 - info: javascript.0 (15381) script.js.Skripte.Wohnung.Eingangstür_offen: Wohnungstür wurde bewegt
      2025-04-21 17:49:12.654 - info: javascript.0 (15381) script.js.Skripte.Wohnung.Eingangstür_offen: Wohnungstür wurde bewegt
      2025-04-21 17:49:13.614 - info: javascript.0 (15381) script.js.Skripte.Flur.PersonKommt: Bewegung auf dem Flur erkannt
      2025-04-21 17:49:19.862 - info: javascript.0 (15381) script.js.Skripte.Wohnung.Eingangstür_offen: Wohnungstür wurde bewegt
      2025-04-21 17:49:19.862 - info: javascript.0 (15381) script.js.Skripte.Wohnung.Eingangstür_offen: Wohnungstür wieder geschlossen
      2025-04-21 17:50:06.008 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 628507
      2025-04-21 17:50:06.824 - info: dwd.0 (628507) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.0, js-controller: 7.0.6
      2025-04-21 17:50:07.145 - info: dwd.0 (628507) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-04-21 17:50:07.659 - info: host.iobroker instance system.adapter.dwd.0 having pid 628507 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-04-21 17:52:13.854 - info: javascript.0 (15381) script.js.Skripte.Flur.PersonKommt: Bewegung auf dem Flur erkannt
      2025-04-21 17:52:45.669 - info: javascript.0 (15381) script.js.Skripte.Flur.PersonKommt: Bewegung auf dem Flur erkannt
      2025-04-21 17:52:45.670 - info: javascript.0 (15381) script.js.Skripte.Flur.PersonKommt: Mario, es kommt jemand die Treppe hoch. Du kannst schon einmal die Tür öffnen.
      2025-04-21 17:52:52.421 - info: javascript.0 (15381) script.js.Skripte.Wohnung.Eingangstür_offen: Wohnungstür wurde bewegt
      2025-04-21 17:52:52.422 - info: javascript.0 (15381) script.js.Skripte.Wohnung.Eingangstür_offen: Wohnungstür wurde bewegt
      2025-04-21 17:52:53.008 - info: host.iobroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 628624
      2025-04-21 17:52:53.873 - info: openweathermap.0 (628624) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.19.0, js-controller: 7.0.6
      2025-04-21 17:52:56.805 - info: javascript.0 (15381) script.js.Skripte.Wohnung.Eingangstür_offen: Wohnungstür wurde bewegt
      2025-04-21 17:52:56.805 - info: javascript.0 (15381) script.js.Skripte.Wohnung.Eingangstür_offen: Wohnungstür wieder geschlossen
      HomoranH Offline
      HomoranH Offline
      @siggi0904 sagte in Log-Einträge nach Umzug doppelt vorhanden:
      was meinst du damit?
      Das stammt von einem Skript
      Siggi0904S 1 Antwort Letzte Antwort
        Siggi0904S Offline
        Siggi0904S Offline
        Siggi0904
        naja, irgendwie werden alle Scripte, die aufgrund eines Tasters, HMIP etc. kommen doppelt angezeigt.
        Ja, das kommt von einem Script, wie du auc im Log siehst, wird das gleich ein paar 100erstel später nochmal ausgeführt. Gleiches beim Script:
        wendy2702W HomoranH 2 Antworten Letzte Antwort
          wendy2702W Offline
          wendy2702W Offline
          @siggi0904 was triggert denn dein Skript?
          • wendy2702W wendy2702
            Siggi0904S Offline
            Siggi0904S Offline
            Siggi0904
            @wendy2702 beim ersten script ein Taster. bei der Luftqualität ein Blockly mit Cron:
              <block type="comment" id="Uo8V0{:s:8nOJxIuEvw=" x="113" y="113">
                <field name="COMMENT">Alexa Luftqualitätsmonitor updaten</field>
                <next>
                  <block type="schedule" id="]W|DEXl(RwWEZ*+2Y=/3">
                    <field name="SCHEDULE">{"time":{"start":"00:00","end":"23:59","mode":"minutes","interval":15},"period":{"days":1}}</field>
                    <statement name="STATEMENT">
                      <block type="comment" id="PB^%imT.@!r$JTct(^g`">
                        <field name="COMMENT">Daten neu einlesen</field>
                        <next>
                          <block type="toggle" id="ud~++Vw/;41!9,BD%@/d">
                            <field name="OID">alexa2.0.Smart-Home-Devices.771e6d85-a93c-48de-9a0a-21783668fe6a.#query</field>
                            <next>
                              <block type="comment" id="^-q,|pRBjF]1nFj!SAxZ">
                                <field name="COMMENT">Log schreiben</field>
                                <next>
                                  <block type="debug" id="/S1+)X9,uAe:]YVVxS=+">
                                    <field name="Severity">info</field>
                                    <value name="TEXT">
                                      <shadow type="text" id="f!ffcmbF4BbA9W-i92wH">
                                        <field name="TEXT">Daten des Alexa-Luftqualitätsmonitors aktualisiert.</field>
                                      </shadow>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </xml>
              HomoranH Offline
              HomoranH Offline
              @siggi0904 dann wird wahrscheinlich nicht das log gedoppelt, sondern das Skript.
              Bitte die Ursache suchen, nicht das Ergebnis ;-)
                Siggi0904S Offline
                Siggi0904S Offline
                Siggi0904
                @homoran es hat ja vor dem Neu aufstetzen alles funktioniert und ich habe an den Scripten nichts geändert.
                • wendy2702W Offline
                  wendy2702W Offline
                  Ist Ruhe wenn du das Script beendest?
                  Sonst würde ich den Server mal neu starten.
                  Siggi0904S 2 Antworten Letzte Antwort
                    Siggi0904S Offline
                    Siggi0904S Offline
                    Siggi0904
                    @wendy2702 ja, als gerade das Script gestoppt habe, kan es um 19:00 Uhr nicht wieder.
                      Siggi0904S Offline
                      Siggi0904S Offline
                      Siggi0904
                      @wendy2702 Ich hab mal die VM neu gestartet. Hoffentlich bessert sich es.
                        Siggi0904S Offline
                        Siggi0904
                        Sieht bisher gut aus.
                        Hab die o.g. Scripte mal ausgelöst und den Cron abgewartet.
                        Dieser wird aktuell auch nur einmal ausgeführt.
                        Woher kommt sowas, dass das doppelt ausgeführt wird?
