  3. Off Topic
  4. Erfahrungen mit Zigbee BWM/Präsenzmelder von AliExpress
    5.9k
124 Beiträge 11 Kommentatoren 18.8k Aufrufe 14 Beobachtet
  • BananaJoeB BananaJoe
    @bananajoe mhh, seit heute morgen (Neustart von ioBroker) sehe ich so etwas im Log:
    2025-04-09 09:04:43.266  - warn: zigbee.2 (3247851) ELEVATED:I01 (8c02) Zigbee Event of Type commandDataReport from device 0xa4c13802ff4f35dd, incoming event: {"type":"commandDataReport","data":{"seq":6400,"dpValues":[{"dp":12,"datatype":2,"data":{"type":"Buffer","data":[0,0,5,38]}}]},"linkquality":36,"groupID":0,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":25,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
    2025-04-09 09:04:43.268  - warn: zigbee.2 (3247851) ELEVATED:I01 (8c02) message received '{"linkquality":36}' from device a4c13802ff4f35dd type 'ZG-204ZL'
    2025-04-09 09:04:43.269  - warn: zigbee.2 (3247851) ELEVATED:I02 (8c02) value generated '36' from device a4c13802ff4f35dd for 'Link quality'
    2025-04-09 09:04:43.269  - warn: zigbee.2 (3247851) ELEVATED:I01 (8c02) message received '{"illuminance":1318}' from device a4c13802ff4f35dd type 'ZG-204ZL'
    2025-04-09 09:04:43.269  - warn: zigbee.2 (3247851) ELEVATED:I02 (8c02) value generated '1318' from device a4c13802ff4f35dd for 'Illuminance raw'
    2025-04-09 09:04:43.816  - warn: zigbee.2 (3247851) ELEVATED:I01 (8e28) Zigbee Event of Type attributeReport from device 0xa4c13802ff4f35dd, incoming event: {"type":"attributeReport","data":{"measuredValue":31193},"linkquality":36,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":26,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    2025-04-09 09:04:43.818  - warn: zigbee.2 (3247851) ELEVATED:NOCONV (8e28) No converter available for 'ZG-204ZL' 'a4c13802ff4f35dd' with cluster 'msIlluminanceMeasurement' and type 'attributeReport'
    2025-04-09 09:04:43.818  - warn: zigbee.2 (3247851) ELEVATED:I01 (8e28) message received '{"linkquality":36}' from device a4c13802ff4f35dd type 'ZG-204ZL'
    2025-04-09 09:04:43.818  - warn: zigbee.2 (3247851) ELEVATED:I02 (8e28) value generated '36' from device a4c13802ff4f35dd for 'Link quality'
    Bin aber auch noch auf ZigBee-Adapter v2.0.5
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @bananajoe du musst die ieee des Gerätes ‘noch’ im zigbee.0.info.debug,messages stehen haben. Oder etwas zumindest. Nimm das mal raus dann sind die Meldungen weg
    A.
    • AsgothianA Asgothian
      A.
      BananaJoeB Online
      BananaJoeB Online
      BananaJoe
      @asgothian sagte in Erfahrungen mit Zigbee BWM/Präsenzmelder von AliExpress:
      A.
      stimmt. Nur: Wie ist der da reingekommen?
      • AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @bananajoe sagte in Erfahrungen mit Zigbee BWM/Präsenzmelder von AliExpress:
        A.
        • selber eingetragen ?
        • dumm geklickt (auf den kleinen 'bug' auf der Kachel)
        Mir wäre nicht bekannt das die automatisch irgendwie eingetragen werden. Stand wirklich die komplette IEEE drin ?
        A.
          A.
          haselchenH Offline
          haselchenH Offline
          haselchen
          @bananajoe
          Da bin ich jetzt auch mal gespannt.
          Einen PIR und einen Radar bestellt .
          Irgendwie haben beide Verpackungen die gleiche Bezeichnung 🤔
          Edit :
          Einzig hier scheint es eine Unterscheidung zu geben
            A.
            A.
            BananaJoeB Online
            BananaJoeB Online
            BananaJoe
            Das war es, gestern als ich den per Tablet eingebunden hatte bin da drauf gekommen und hatte mich noch gefragt wofür der jetzt war ...
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              jetzt weisst du es - er aktiviert die by device debug Meldungen. (oder deaktiviert sie, wenn sie aktiv sind) :) (steht so auch in der Doku auf Github)
              A.
              • haselchenH haselchen
                @dieter_p
                Ich hab bei sowas immer Hemmungen 😁
                Wie wo haste das(in der App) gemacht ?
                BananaJoeB Online
                BananaJoeB Online
                BananaJoe
                @haselchen sagte in Erfahrungen mit Zigbee BWM/Präsenzmelder von AliExpress:
                @dieter_p
                Haben sich heute gemeldet: die 2 x Radar wurde versendet (die Meldung kam heute Nacht),
                eben kam der Rücksendeaufkleber für Hermes um 2 wieder zurück zu senden (an Adresse in Deutschland)
                  @dieter_p
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @bananajoe
                  Okay, also keine Kulanz a là "Sie können die jetzigen Geräte behalten".
                  Gut zu wissen, Danke.
                    @bananajoe
                    BananaJoeB Online
                    BananaJoeB Online
                    BananaJoe
                    @bananajoe
                    Wenn ich mir das alles genau ansehe bin ich jetzt gar nicht sicher, ob ich das Geld wiederbekomme oder 2 neue Radar Sensoren ... in meinem Kundenkonto erkenne ich das nicht richtig und die Mails sind verwirrend bzw. die Links darin für zu "nicht gefunden"
                      @bananajoe
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @bananajoe
                      In der Hinsicht hat immer alles gepasst bei mir.
                      Ali schickt eigentlich zu jedem Pups ne Mail.
                      Das wird auch bei Dir richtig laufen.
                      Ich brau mir erstmal nen Kaffee und dann schau ich mal , wie ich das Radar Teil integriere und sinnvoll abbilden kann.
                        @bananajoe
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        Es wird immer besser....
                        Ich hab ihn gerade angelernt.
                        Blöd, dass ich die Zigbee Version genommen habe, so kann ich ihn nicht in der App anlernen und visuell alles einrichten.
                        Aber gut. Hab ich für die Zukunft im Hinterkopf.
                        Viel geiler ist, man braucht keinen einzelnen PIR.
                        Dieser Radarsensor hat beides.
                        Einstellbar in der Kachel.
                        Edit:
                        Tatsächlich sollte man lieber die Wifi Variante bestellen.
                        Über den Zigbee Adapter sehe ich nicht die Möglichkeit, dass so abzubilden , wie in der Hersteller Beschreibung.
                        https://doc.szalarm.com/zg-205Z/en/1.html
                        Ich vermute, dass mit Einbindung in der SmartLifeApp das Ganze dann mit dem Tuya Adapter läuft und da (vermutlich) die benötigten DP erscheinen.
                        So, was ich jetzt in den DP sehe, kriege ich das nicht wunschgemäss abgebildet.
                          Edit:
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          @haselchen wie weit kannst du die presence keep time runterschrauben ?
                          • liv-in-skyL liv-in-sky
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            @liv-in-sky
                            Ich hab an den Einstellungen noch nichts verändert.
                            Irgendwie hatte ich mir das anders vorgestellt.
                            Dachte, dass man z.B. die Entfernung in m oder cm zum Gerät in einem DP sehen kann.
                            Stattdessen, vermute ich auf den ersten Blick, gibt es nur Schlagwörter wie small, large .... in den DP.
                            Ich muss mir das alles nochmal in Ruhe ansehen.
                            Edit:
                            Sehr informativ , auf Platz 3:
                            https://www.heise.de/bestenlisten/testsieger/die-besten-praesenzmelder-mit-radar-im-test-aus-fuer-bewegungsmelder/smlxw21
                            Allerdings....
                            Die Variante mit der Zigbee-Herstellerkennung _TZE200_2aaelwxk funktioniert einwandfrei, während die Alternative _TZE200_kb5noeto nach kurzer Zeit dauerhaft Präsenz meldet und damit in der Praxis unbrauchbar ist.
                            Ich hab natürlich die Version bekommen :man-facepalming:
                              @liv-in-sky
                              Edit:
                              Allerdings....
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              ist bei mir auch so
                              den habe ich auch
                              habe ihn gerade eingerichtet - muss noch mehr testen
                              die alternative hat tatsächlich das problem, das es dauern auf true bleibt :-( dafür reagiert aber motion_state relativ gut
                                ist bei mir auch so
                                den habe ich auch
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                @liv-in-sky
                                Und deswegen hab ich eine Retour angestossen.
                                Der Motion Sensor reagiert erste Sahne.
                                Radar ist tatsächlich "Müll".
                                Muss den jetzt über Hermes zurückschicken.
                                Label wurde mir zugeschickt.
                                Dachte tatsächlich , ich komme drumherum.
                                Bleibt wohl nur eine Stromversorgungslösung.
                                Oder ich finde noch was anderes bei Ali.
                                  @liv-in-sky
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  @haselchen ich habe den auch schon vor 3 wochen bestellt - versuche es immer wieder mal, wenn es solche angebote gibt - bisher war ich nie besonders erfolgreich :-( der hat aber auch unter 10 euro gekostet
                                  der motion-state reagiert alle ca 5 sek neu - ist mir ein klein wenig zu lange - aber ich hatte schon schlechtere.
                                  wenn einer von uns mal ein gutes teil findet, posten wir ja das hier
                                  der kleine bwm, den habe ich auch, ist jedoch zuverlässig und auch leicht einzubinden - war für den preis ganz gut - setze ich als eine art redundanz ein
                                  haselchenH crunchipC 2 Antworten Letzte Antwort
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    @liv-in-sky
                                    Von den PIR Sensoren habe ich jetzt 4.
                                    Und damit die HUE entfernt.
                                    Die jetzt von Ali sind wesentlich umfangreicher, was die Einstellungen und auch was die Bewegungserkennung angeht.
                                    Bei den Radarteilen brauche ich wenigstens einen DP, in dem die aktuell im Raum befindlichen Personen als Zahl stehen.
                                    Pluspunkt wäre wie beim FP2 von Aqara natürlich noch ne Karte.
                                    Ist ne gute Beschäftigung abends nochmal ganz Ali zu durchstöbern :)
                                    liv-in-skyL BananaJoeB 2 Antworten Letzte Antwort
                                      @liv-in-sky
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      bin gespannt, ob und wenn ja wie du das hinbekommst
                                        @liv-in-sky
                                        BananaJoeB Online
                                        BananaJoeB Online
                                        BananaJoe
                                        @haselchen also, es stellte sich heraus das einer der 8 Sensoren in der Tüte dann doch die Radar-Version ist:
                                        Äußerlich war das nicht zu erkennen, die Verpackung war 1:1 die gleiche inklusive gleicher Artikelnummern etc.
                                        Also hatten die mir das wohl doch "richtig" zugesendet.
                                        Aber _TZE200_kb5noeto heißt das man mit dem Ding nichts anfangen kann?
                                          Dieter_P
                                          @bananajoe said in Erfahrungen mit Zigbee BWM/Präsenzmelder von AliExpress:
                                          Warum? Er wird doch voll erkannt und ist im herdsmann als bekannt eingetragen. Sollte also funktionieren.
                                          Diese kryptische Bezeichnung habe ich als interne Referenz der Entwickler verstanden da die Modellbezeichnungen bei Tuya oft kreuz und quer gewürfelt werden und nicht einheitlich je hardware genutzt werden.
                                          AsgothianA 2 Antworten Letzte Antwort
