  4. js-controller updaten
    6.7k
63 Beiträge 8 Kommentatoren 14.1k Aufrufe 7 Beobachtet
    @erich-1 sagte in js-controller updaten:
    OK, was muss ich da dann eingeben?
    Da musst du dich schon einlesen.
    Link zur Anleitung hatte ich dir ja schon gegeben.
    Erich 1
    @thomas-braun Hab jetzt mal einiges versucht:
    ```bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
       Static hostname: debian-iobroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-23-amd64
          Architecture: x86-64
    OS is similar to:
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     21:05:41 up 33 min,  2 users,  load average: 0.93, 0.82, 0.97
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    This system needs to be REBOOTED!
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-03-24 21:05:41 CET
               Universal time: Mon 2025-03-24 20:05:41 UTC
                     RTC time: Mon 2025-03-24 20:05:42
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    erich
    HOME=/home/erich
    GROUPS=erich cdrom floppy sudo audio dip video plugdev netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            3.9G        1.5G        555M        0.0K        1.9G        2.2G
    Swap:           974M        2.0M        972M
    Total:          4.9G        1.5G        1.5G
    Active iob-Instances:   15
             3919 M total memory
             1468 M used memory
              466 M active memory
             2626 M inactive memory
              555 M free memory
               73 M buffer memory
             1822 M swap cache
              974 M total swap
                2 M used swap
              972 M free swap
    top - 21:05:41 up 33 min,  2 users,  load average: 0.93, 0.82, 0.97
    Tasks: 104 total,   2 running, 102 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3919.7 total,    555.2 free,   1468.4 used,   1896.2 buff/cache
    MiB Swap:    975.0 total,    972.5 free,      2.5 used.   2179.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.9G     0  1.9G   0% /dev
    tmpfs          tmpfs     392M  516K  392M   1% /run
    /dev/sda1      ext4       39G  9.4G   27G  26% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
    [Mon Mar 24 20:32:25 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Mar 24 20:32:25 2025] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    834M    /var/
    449M    /var/log
    433M    /var/log/journal/4782ab7b08f9440cb38008c40dbc892b
    223M    /var/cache
    Archived and active journals take up 40.0M in the file system.
    /opt/iobroker/backups:
    2.6G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.7G    /opt/iobroker/iobroker-data/
    855M    /opt/iobroker/iobroker-data/backupDir
    764M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u6 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    debian-iobroker     debian-iobroker (version: 7.0.6, hostname: debian-iobroker, alive, uptime: 692)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.3
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : debian-iobroker                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : debian-iobroker                          -  enabled
      system.adapter.birthdays.0              : birthdays             : debian-iobroker                          -  enabled
    + system.adapter.cloud.0                  : cloud                 : debian-iobroker                          -  enabled
      system.adapter.devices.0                : devices               : debian-iobroker                          - disabled
    + system.adapter.discovery.0              : discovery             : debian-iobroker                          -  enabled
    + system.adapter.email.0                  : email                 : debian-iobroker                          -  enabled
      system.adapter.flot.0                   : flot                  : debian-iobroker                          - disabled
    + system.adapter.fritzdect.0              : fritzdect             : debian-iobroker                          -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : debian-iobroker                          -  enabled
      system.adapter.habpanel.0               : habpanel              : debian-iobroker                          - disabled
      system.adapter.heatingcontrol.0         : heatingcontrol        : debian-iobroker                          - disabled
    + system.adapter.history.0                : history               : debian-iobroker                          -  enabled
    + system.adapter.javascript.0             : javascript            : debian-iobroker                          -  enabled
    + system.adapter.javascript.1             : javascript            : debian-iobroker                          -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : debian-iobroker                          -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : debian-iobroker                          -  enabled
      system.adapter.openweathermap.0         : openweathermap        : debian-iobroker                          -  enabled
    + system.adapter.shelly.0                 : shelly                : debian-iobroker                          -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : debian-iobroker                          -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.tuya.0                   : tuya                  : debian-iobroker                          -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : debian-iobroker                          - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian-iobroker                          - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : debian-iobroker                          -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian-iobroker                          - disabled
      system.adapter.vis.0                    : vis                   : debian-iobroker                          -  enabled
      system.adapter.web.0                    : web                   : debian-iobroker                          - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    │ (index) │   name   │                           url                           │ auto upgrade │
    │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
    │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.3    , installed 7.6.3
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "birthdays"    : 3.1.0    , installed 3.1.0
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
    Adapter    "fullybrowser" : 3.0.13   , installed 3.0.13
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "heatingcontrol": 2.12.14 , installed 2.12.14
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "shelly"       : 8.5.1    , installed 8.5.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Objects and States
    Objects:        3719
    States:         3066
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10984      1/systemd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          37313      10130/sshd: /usr/sb
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       66915      21512/io.mqtt.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       67113      21557/io.sonoff.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       65840      21326/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       65833      21326/iobroker.js-c
    tcp6       0      0 :::111                  :::*                    LISTEN      0          10992      1/systemd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       65966      21344/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          37324      10130/sshd: /usr/sb
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       67053      21542/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12495      342/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          10987      1/systemd
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       67232      21572/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       67233      21572/io.tuya.0
    udp6       0      0 :::111                  :::*                                0          10997      1/systemd
    2025-03-24 20:55:46.062  - error: tuya.0 (21572) Cloud login failed: Incorrect account ID or password
    2025-03-24 20:55:46.062  - error: tuya.0 (21572) Please check your cloud credentials in the adapter configuration!
    2025-03-24 20:55:46.062  - warn: tuya.0 (21572) App cloud connection failed. No sync possible
    2025-03-24 20:57:32.476  - info: admin.0 (21344) ==> Connected system.user.admin from ::ffff:192.168.178.91
    2025-03-24 20:57:56.747  - info: admin.0 (21344) <== Disconnect system.user.admin from ::ffff:192.168.178.91 javascript
    2025-03-24 20:59:08.140  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] connection closed: timeout
    2025-03-24 20:59:08.308  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] connected with secret 1742846348307_1509
    2025-03-24 20:59:08.333  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] subscribes on "ESP_Easy-03 Wetterstation/#" with regex /^ESP_Easy-03_Wetterstation\..*/
    2025-03-24 20:59:08.336  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] subscribes on "ESP_Easy-03 Wetterstation/#"  with regex /^mqtt\.0\.ESP_Easy-03_Wetterstation\..*/
    2025-03-24 20:59:08.536  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] publishOnSubscribe send all known states
    2025-03-24 21:00:17.029  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 21695
    2025-03-24 21:00:18.865  - info: netatmo-crawler.0 (21695) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 7.0.6
    2025-03-24 21:00:18.911  - info: netatmo-crawler.0 (21695) Getting data for stationid:70:ee:50:1b:2f:26
    2025-03-24 21:00:22.311  - info: netatmo-crawler.0 (21695) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2025-03-24 21:00:22.857  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 having pid 21695 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-03-24 21:05:17.015  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 21786
    2025-03-24 21:05:20.937  - info: netatmo-crawler.0 (21786) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 7.0.6
    2025-03-24 21:05:21.131  - info: netatmo-crawler.0 (21786) Getting data for stationid:70:ee:50:1b:2f:26
    2025-03-24 21:05:21.739  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] connection closed: timeout
    2025-03-24 21:05:22.025  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] connected with secret 1742846722025_2942
    2025-03-24 21:05:22.041  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] subscribes on "ESP_Easy-03 Wetterstation/#" with regex /^ESP_Easy-03_Wetterstation\..*/
    2025-03-24 21:05:22.041  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] subscribes on "ESP_Easy-03 Wetterstation/#"  with regex /^mqtt\.0\.ESP_Easy-03_Wetterstation\..*/
    2025-03-24 21:05:22.242  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] publishOnSubscribe send all known states
    2025-03-24 21:05:23.286  - info: netatmo-crawler.0 (21786) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2025-03-24 21:05:23.851  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 having pid 21786 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    • E Erich 1
      ```bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
                 Chassis: vm
          Virtualization: kvm
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                    NTP service: active
                RTC in local TZ: no
      erich
      HOME=/home/erich
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               3919 M total memory
               1468 M used memory
                466 M active memory
                555 M free memory
                 73 M buffer memory
               1822 M swap cache
                974 M total swap
                  2 M used swap
                972 M free swap
      *** FILESYSTEM ***
      /var:
      834M    /var/
      449M    /var/log
      223M    /var/cache
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.3
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        3719
      States:         3066
      Pending Updates: 0
      E 1 Antwort Letzte Antwort
        Erich 1
        @thomas-braun Hab das mal gemacht, der ioBroker läuft wieder, aber die VIS ist nicht erreichbar. Weder über die Instanz im ioBroker und auch nicht über den Fully-Browser ...
        • E Erich 1
          Hab das mal gemacht
          Was gemacht? Dein Betriebssystem ist jetzt auf dem 'Bookworm'-Release (Debian 12)?
            Hab das mal gemacht
            Erich 1
            @thomas-braun Ich hoffe doch. Auch die Adapter des ioBroker sind alle aktualisiert und der js-controler ist auf 7.0.6 - aber die VIS mag nicht mehr.
            • E Erich 1
              Ich hoffe doch.
              Nicht hoffen, nachschauen...
              iob diag
              ist dein Freund.
                Ich hoffe doch.
                iob diag
                ist dein Freund.
                Erich 1
                @thomas-braun Falsch gehofft, bin immer noch auf Version 11 und habe keinen blassen Schimmer, wie ich die Version 12 drauf bringe.
                • E Erich 1
                  @erich-1
                  So:
                  https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
                    @erich-1
                    So:
                    Erich 1
                    @thomas-braun Das sieht für mich erstmal mehr als kompliziert aus, Da wage ich mich auf die Schnelle nicht dran.
                    E Thomas BraunT 2 Antworten Letzte Antwort
                    • E Erich 1
                      Erich 1
                      @erich-1 Die VIS muss doch auch mit dem Bullauge funktionieren. Hat sie ja vorher doch auch getan ...
                      • E Erich 1
                        Dein Debian 11 / Bullseye ist aber ABGEKÜNDIGT.
                        Du MUSST da dran. Dringend.
                          Erich 1
                          @thomas-braun Das ist mir klar, aber erst muss die VIS wieder funktionieren.
                          • E Erich 1
                            @erich-1
                            Nö, zuerst musst du deine Kiste auf Stand bringen.
                              @erich-1
                              Erich 1
                              @thomas-braun Ich fürchte, dass das mit der Anleitung ein paar Nummern zu gross für mich ist. Da setze ich vermutlich das ganze System neu auf, wobei ich mich frage, ob der iobroker mit Linux drunter für mich überhaupt das passende System ist. Wenn man da regelmäßig dran arbeiten muss.
                              • E Erich 1
                                Und mit welchem System hast du keine regelmäßigen Updates?
                                Mit welcher Nummer hast du denn KONKRET ein Problem?
                                  Erich 1
                                  @thomas-braun Beginnend ab da habe ich Verständnisprobleme und danach sowieso...
                                  Wenn in der Liste irgendwas mit bullseye-backports oder bullseye-propsed-updates oder ähnliches auftauchen sollte, dann ist diese Quelle zuvor zu deaktivieren. Ebenso andere manuelle Eingriffe in die Paket-Datenbank. Z.B. ein apt-hold auf das Paket 'udev' ist ja von einigen getätigt worden, diese Sperren müssen aufgehoben werden. Kann man per
                                  apt-mark showhold
                                  prüfen. Die aufgelisteten Pakete dann mit
                                  sudo apt-mark unhold `apt-mark showhold`
                                  wieder frei laufen lassen.
                                  • E Erich 1
                                    apt-mark showhold
                                    Wenn in der Liste irgendwas mit bullseye-backports oder bullseye-propsed-updates auftaucht.
                                    Tut es das denn? Wenn nicht, dann musst du den Part ja auch nicht machen.
                                    Eigentlich kann man die Befehle so in das Terminal hacken. Sofern sie denn überhaupt notwendig sind.
                                    • E Erich 1
                                      Ich wollte einige Adapter updaten und habe dabei festgestellt, dass der installierte js-controller 4.0.24 dermaßen veraltet ist und upgedatet werden muss. Deswegen lassen sich auch einige Adapter nicht updaten.
                                      Die aktuelle Version des js-controller ist derzeit 7.0.6 und mir ist im Moment überhaupt noch nicht klar, wie ich den js-controller am einfachsten update. Alles was ich bisher dazu gelesenhabe, schrecht mich eigentlich etwas ab, das ohne erfahrene Hilfe in Eigenregie durchzuühren.
                                      Kann mir jemand sagen wie ich das am sinnvollsten anstelle und was ich beachten muss? Ein Backup der Installation ist durchgeführt.
                                      Mein ioBroker läuft auf einem Mini-PC unter Proxmox in einer VM
                                      saeft_2003
                                      @erich-1
                                      also ich würde das so machen.
                                      1. Altes proxmox backup wiederherstellen damit VIS wieder läuft.
                                      2. Neue VM/LXC erstellen Debian installieren und danach iobroker.
                                      3. Alte VM/LXC abschalten und neue VM/LXC die gleiche IP Adresse vergeben.
                                      4. iobroker backup einspielen (kann dauern). Danach sollte alles aktuell sein.
                                      proxmox ist dafür eigentlich perfekt...
                                      E HomoranH 2 Antworten Letzte Antwort
                                      • S saeft_2003
                                        @erich-1
                                        Erich 1
                                        @saeft_2003 Die Gedanken hatte ich heute Nacht auch.
                                        Schritt 1 ist vollzogen und es läuft wieder alles normal. Schritt 2 folgt in den nächsten Tagen, wenn ich wieder etwas normalisiert bin ...
                                        • E Erich 1
                                          @erich-1
                                          Und dann halte die Kiste und die Installationen darauf immer aktuell...
