  4. js-controller updaten
    6.7k
63 Beiträge 8 Kommentatoren 14.1k Aufrufe 7 Beobachtet
    @erich-1 sagte in js-controller updaten:
    um überhaupt auf die Debian-Installation zu kommen.
    da bist du doch schon drauf!
    hast ja das iob diag da gestartet
    Erich 1
    @homoran said in js-controller updaten:
    OK, was muss ich da dann eingeben?
    • E Erich 1
      Da musst du dich schon einlesen.
      Link zur Anleitung hatte ich dir ja schon gegeben.
      E 1 Antwort Letzte Antwort
        Erich 1
        @thomas-braun Hab jetzt mal einiges versucht:
        ```bash
        Script v.2025-02-23
        *** BASE SYSTEM ***
           Static hostname: debian-iobroker
                 Icon name: computer-vm
                   Chassis: vm
            Virtualization: kvm
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.10.0-23-amd64
              Architecture: x86-64
        OS is similar to:
        model name      : Common KVM processor
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         21:05:41 up 33 min,  2 users,  load average: 0.93, 0.82, 0.97
        CPU threads: 2
        *** LIFE CYCLE STATUS ***
        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
        This system needs to be REBOOTED!
        *** TIME AND TIMEZONES ***
                       Local time: Mon 2025-03-24 21:05:41 CET
                   Universal time: Mon 2025-03-24 20:05:41 UTC
                         RTC time: Mon 2025-03-24 20:05:42
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        erich
        HOME=/home/erich
        GROUPS=erich cdrom floppy sudo audio dip video plugdev netdev iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            3.9G        1.5G        555M        0.0K        1.9G        2.2G
        Swap:           974M        2.0M        972M
        Total:          4.9G        1.5G        1.5G
        Active iob-Instances:   15
                 3919 M total memory
                 1468 M used memory
                  466 M active memory
                 2626 M inactive memory
                  555 M free memory
                   73 M buffer memory
                 1822 M swap cache
                  974 M total swap
                    2 M used swap
                  972 M free swap
        top - 21:05:41 up 33 min,  2 users,  load average: 0.93, 0.82, 0.97
        Tasks: 104 total,   2 running, 102 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3919.7 total,    555.2 free,   1468.4 used,   1896.2 buff/cache
        MiB Swap:    975.0 total,    972.5 free,      2.5 used.   2179.4 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  1.9G     0  1.9G   0% /dev
        tmpfs          tmpfs     392M  516K  392M   1% /run
        /dev/sda1      ext4       39G  9.4G   27G  26% /
        tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
        [Mon Mar 24 20:32:25 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
        [Mon Mar 24 20:32:25 2025] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
        Show mounted filesystems:
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        834M    /var/
        449M    /var/log
        433M    /var/log/journal/4782ab7b08f9440cb38008c40dbc892b
        223M    /var/cache
        Archived and active journals take up 40.0M in the file system.
        /opt/iobroker/backups:
        2.6G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.7G    /opt/iobroker/iobroker-data/
        855M    /opt/iobroker/iobroker-data/backupDir
        764M    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        24M     /opt/iobroker/iobroker-data/objects.jsonl
        8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
        8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
        8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
        USB-Devices by-id:
        No Devices found 'by-id'
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        /usr/bin/corepack       0.18.0
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
             12.22.12~dfsg-1~deb11u6 500
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        debian-iobroker     debian-iobroker (version: 7.0.6, hostname: debian-iobroker, alive, uptime: 692)
        Core adapters versions
        js-controller:  7.0.6
        admin:          7.6.3
        javascript:     8.8.3
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : debian-iobroker                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : debian-iobroker                          -  enabled
          system.adapter.birthdays.0              : birthdays             : debian-iobroker                          -  enabled
        + system.adapter.cloud.0                  : cloud                 : debian-iobroker                          -  enabled
          system.adapter.devices.0                : devices               : debian-iobroker                          - disabled
        + system.adapter.discovery.0              : discovery             : debian-iobroker                          -  enabled
        + system.adapter.email.0                  : email                 : debian-iobroker                          -  enabled
          system.adapter.flot.0                   : flot                  : debian-iobroker                          - disabled
        + system.adapter.fritzdect.0              : fritzdect             : debian-iobroker                          -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : debian-iobroker                          -  enabled
          system.adapter.habpanel.0               : habpanel              : debian-iobroker                          - disabled
          system.adapter.heatingcontrol.0         : heatingcontrol        : debian-iobroker                          - disabled
        + system.adapter.history.0                : history               : debian-iobroker                          -  enabled
        + system.adapter.javascript.0             : javascript            : debian-iobroker                          -  enabled
        + system.adapter.javascript.1             : javascript            : debian-iobroker                          -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : debian-iobroker                          -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : debian-iobroker                          -  enabled
          system.adapter.openweathermap.0         : openweathermap        : debian-iobroker                          -  enabled
        + system.adapter.shelly.0                 : shelly                : debian-iobroker                          -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : debian-iobroker                          -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.tuya.0                   : tuya                  : debian-iobroker                          -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : debian-iobroker                          - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian-iobroker                          - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : debian-iobroker                          -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian-iobroker                          - disabled
          system.adapter.vis.0                    : vis                   : debian-iobroker                          -  enabled
          system.adapter.web.0                    : web                   : debian-iobroker                          - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        │ (index) │   name   │                           url                           │ auto upgrade │
        │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
        │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "admin"        : 7.6.3    , installed 7.6.3
        Adapter    "backitup"     : 3.0.31   , installed 3.0.31
        Adapter    "birthdays"    : 3.1.0    , installed 3.1.0
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
        Adapter    "fullybrowser" : 3.0.13   , installed 3.0.13
        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
        Adapter    "heatingcontrol": 2.12.14 , installed 2.12.14
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
        Adapter    "shelly"       : 8.5.1    , installed 8.5.1
        Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Objects and States
        Objects:        3719
        States:         3066
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10984      1/systemd
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          37313      10130/sshd: /usr/sb
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       66915      21512/io.mqtt.0
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       67113      21557/io.sonoff.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       65840      21326/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       65833      21326/iobroker.js-c
        tcp6       0      0 :::111                  :::*                    LISTEN      0          10992      1/systemd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       65966      21344/io.admin.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          37324      10130/sshd: /usr/sb
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       67053      21542/io.shelly.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12495      342/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          10987      1/systemd
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       67232      21572/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       67233      21572/io.tuya.0
        udp6       0      0 :::111                  :::*                                0          10997      1/systemd
        2025-03-24 20:55:46.062  - error: tuya.0 (21572) Cloud login failed: Incorrect account ID or password
        2025-03-24 20:55:46.062  - error: tuya.0 (21572) Please check your cloud credentials in the adapter configuration!
        2025-03-24 20:55:46.062  - warn: tuya.0 (21572) App cloud connection failed. No sync possible
        2025-03-24 20:57:32.476  - info: admin.0 (21344) ==> Connected system.user.admin from ::ffff:192.168.178.91
        2025-03-24 20:57:56.747  - info: admin.0 (21344) <== Disconnect system.user.admin from ::ffff:192.168.178.91 javascript
        2025-03-24 20:59:08.140  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] connection closed: timeout
        2025-03-24 20:59:08.308  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] connected with secret 1742846348307_1509
        2025-03-24 20:59:08.333  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] subscribes on "ESP_Easy-03 Wetterstation/#" with regex /^ESP_Easy-03_Wetterstation\..*/
        2025-03-24 20:59:08.336  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] subscribes on "ESP_Easy-03 Wetterstation/#"  with regex /^mqtt\.0\.ESP_Easy-03_Wetterstation\..*/
        2025-03-24 20:59:08.536  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] publishOnSubscribe send all known states
        2025-03-24 21:00:17.029  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 21695
        2025-03-24 21:00:18.865  - info: netatmo-crawler.0 (21695) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 7.0.6
        2025-03-24 21:00:18.911  - info: netatmo-crawler.0 (21695) Getting data for stationid:70:ee:50:1b:2f:26
        2025-03-24 21:00:22.311  - info: netatmo-crawler.0 (21695) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
        2025-03-24 21:00:22.857  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 having pid 21695 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-03-24 21:05:17.015  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 21786
        2025-03-24 21:05:20.937  - info: netatmo-crawler.0 (21786) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 7.0.6
        2025-03-24 21:05:21.131  - info: netatmo-crawler.0 (21786) Getting data for stationid:70:ee:50:1b:2f:26
        2025-03-24 21:05:21.739  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] connection closed: timeout
        2025-03-24 21:05:22.025  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] connected with secret 1742846722025_2942
        2025-03-24 21:05:22.041  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] subscribes on "ESP_Easy-03 Wetterstation/#" with regex /^ESP_Easy-03_Wetterstation\..*/
        2025-03-24 21:05:22.041  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] subscribes on "ESP_Easy-03 Wetterstation/#"  with regex /^mqtt\.0\.ESP_Easy-03_Wetterstation\..*/
        2025-03-24 21:05:22.242  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] publishOnSubscribe send all known states
        2025-03-24 21:05:23.286  - info: netatmo-crawler.0 (21786) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
        2025-03-24 21:05:23.851  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 having pid 21786 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        • E Erich 1
          ```bash
          Script v.2025-02-23
          *** BASE SYSTEM ***
                     Chassis: vm
              Virtualization: kvm
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 2
                        NTP service: active
                    RTC in local TZ: no
          erich
          HOME=/home/erich
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
                   3919 M total memory
                   1468 M used memory
                    466 M active memory
                    555 M free memory
                     73 M buffer memory
                   1822 M swap cache
                    974 M total swap
                      2 M used swap
                    972 M free swap
          *** FILESYSTEM ***
          /var:
          834M    /var/
          449M    /var/log
          223M    /var/cache
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.6.3
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        3719
          States:         3066
          Pending Updates: 0
            Erich 1
            @thomas-braun Hab das mal gemacht, der ioBroker läuft wieder, aber die VIS ist nicht erreichbar. Weder über die Instanz im ioBroker und auch nicht über den Fully-Browser ...
            • E Erich 1
              Hab das mal gemacht
              Was gemacht? Dein Betriebssystem ist jetzt auf dem 'Bookworm'-Release (Debian 12)?
                Hab das mal gemacht
                Erich 1
                @thomas-braun Ich hoffe doch. Auch die Adapter des ioBroker sind alle aktualisiert und der js-controler ist auf 7.0.6 - aber die VIS mag nicht mehr.
                • E Erich 1
                  Ich hoffe doch.
                  Nicht hoffen, nachschauen...
                  iob diag
                  ist dein Freund.
                    Ich hoffe doch.
                    iob diag
                    ist dein Freund.
                    Erich 1
                    @thomas-braun Falsch gehofft, bin immer noch auf Version 11 und habe keinen blassen Schimmer, wie ich die Version 12 drauf bringe.
                    • E Erich 1
                      @erich-1
                      So:
                      https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
                        @erich-1
                        So:
                        Erich 1
                        @thomas-braun Das sieht für mich erstmal mehr als kompliziert aus, Da wage ich mich auf die Schnelle nicht dran.
                        E Thomas BraunT 2 Antworten Letzte Antwort
                        • E Erich 1
                          Erich 1
                          @erich-1 Die VIS muss doch auch mit dem Bullauge funktionieren. Hat sie ja vorher doch auch getan ...
                          • E Erich 1
                            Dein Debian 11 / Bullseye ist aber ABGEKÜNDIGT.
                            Du MUSST da dran. Dringend.
                              Erich 1
                              @thomas-braun Das ist mir klar, aber erst muss die VIS wieder funktionieren.
                              • E Erich 1
                                @erich-1
                                Nö, zuerst musst du deine Kiste auf Stand bringen.
                                  @erich-1
                                  Erich 1
                                  @thomas-braun Ich fürchte, dass das mit der Anleitung ein paar Nummern zu gross für mich ist. Da setze ich vermutlich das ganze System neu auf, wobei ich mich frage, ob der iobroker mit Linux drunter für mich überhaupt das passende System ist. Wenn man da regelmäßig dran arbeiten muss.
                                  • E Erich 1
                                    Und mit welchem System hast du keine regelmäßigen Updates?
                                    Mit welcher Nummer hast du denn KONKRET ein Problem?
                                      Erich 1
                                      @thomas-braun Beginnend ab da habe ich Verständnisprobleme und danach sowieso...
                                      Wenn in der Liste irgendwas mit bullseye-backports oder bullseye-propsed-updates oder ähnliches auftauchen sollte, dann ist diese Quelle zuvor zu deaktivieren. Ebenso andere manuelle Eingriffe in die Paket-Datenbank. Z.B. ein apt-hold auf das Paket 'udev' ist ja von einigen getätigt worden, diese Sperren müssen aufgehoben werden. Kann man per
                                      apt-mark showhold
                                      prüfen. Die aufgelisteten Pakete dann mit
                                      sudo apt-mark unhold `apt-mark showhold`
                                      wieder frei laufen lassen.
                                      • E Erich 1
                                        apt-mark showhold
                                        Wenn in der Liste irgendwas mit bullseye-backports oder bullseye-propsed-updates auftaucht.
                                        Tut es das denn? Wenn nicht, dann musst du den Part ja auch nicht machen.
                                        Eigentlich kann man die Befehle so in das Terminal hacken. Sofern sie denn überhaupt notwendig sind.
                                        • E Erich 1
                                          Ich wollte einige Adapter updaten und habe dabei festgestellt, dass der installierte js-controller 4.0.24 dermaßen veraltet ist und upgedatet werden muss. Deswegen lassen sich auch einige Adapter nicht updaten.
                                          Die aktuelle Version des js-controller ist derzeit 7.0.6 und mir ist im Moment überhaupt noch nicht klar, wie ich den js-controller am einfachsten update. Alles was ich bisher dazu gelesenhabe, schrecht mich eigentlich etwas ab, das ohne erfahrene Hilfe in Eigenregie durchzuühren.
                                          Kann mir jemand sagen wie ich das am sinnvollsten anstelle und was ich beachten muss? Ein Backup der Installation ist durchgeführt.
                                          Mein ioBroker läuft auf einem Mini-PC unter Proxmox in einer VM
                                          saeft_2003
                                          @erich-1
                                          also ich würde das so machen.
                                          1. Altes proxmox backup wiederherstellen damit VIS wieder läuft.
                                          2. Neue VM/LXC erstellen Debian installieren und danach iobroker.
                                          3. Alte VM/LXC abschalten und neue VM/LXC die gleiche IP Adresse vergeben.
                                          4. iobroker backup einspielen (kann dauern). Danach sollte alles aktuell sein.
                                          proxmox ist dafür eigentlich perfekt...
                                          E HomoranH 2 Antworten Letzte Antwort
