  4. Auslesen und Filtern der autobahn.api von bund.dev
    5.1k
30 Beiträge 6 Kommentatoren 4.2k Aufrufe 8 Beobachtet
  • mickymM mickym
    Warte mal - ich glaub mit dem Filter stimmt noch was nicht.
    Ja der Filter muss evaluiert werden - also in der Filterchange Node folgendes ändern:
    payload.warning[$eval($$.filter)].{
        "ID": identifier, "Titel":title,
        "Verzögerung": (delayTimeValue ? delayTimeValue : "0") & " Minuten",
        "Durchschnittsgeschwindigkeit" : averageSpeed,
       "Beginn": description[0] ~> $substringAfter(": "),
       "Ende": description[1] ~> $substringAfter(": "),
       "Beschreibung": description#$i[$i in [3..$count(%.description)]] ~> $join(" ")
    Hier nochmal der ganze Flow:
           "id": "6e802f1553b18149",
           "type": "subflow",
           "name": "JSON or Obj to IOBroker",
           "info": "# Creates an IOBroker tree\n\nThis node creates an IOBroker tree out of an Java-Object or JSON String.\n\nThe object tree will be created under 0_userdata.0\nIn addition to the JSON-String or Java Object as `msg.payload` it is necessary to specify a `msg.top` properity in addition to the msg-Object.\n\nThe object tree will be created under 0_userdata.0\n\nExisting `msg.topic` entries will be deleted.\nAn iobroker-out node has to be appended to this subflow node. It is not part of the subflow itself. No topic should be specified in the iobroker out node.\n\nIs `msg.top` property isn't defined, the `top` property of the subflow-node is used. \n\nIn the properties of the subflow node a new property `keepTopic` has been added. Default is _false_ to keep the current behaviour. If set to _true_ then the originial topic will be placed between the `top` property of the subflow node and the property of the analyzed JSON object.\n\n**Attention:**\nIf msg.top and top is empty, all msg.topics (msg.topic) will be directly prefixed with 0_userdata.0. . \n\n**Update 13.09.2022:**\nSpaces in topics of objects are no longer replaced with underscores in objects. No differences between all data types.\n\n# Erstellt einen Objektbaum im ioBroker\n\nDiese Node erstellt einen Objektbaum im ioBroker aus einem JAVA Objekt bzw. einem JSON String. \n\nDer Baum wird in jedem Fall unter 0_userdata.0 erstellt und zwar unter dem Topic der in` msg.top` mitgegeben wurde. In der `msg.payload` befindet sich dann der JSON String oder das entsprechende Objekt.\n\nExistierende `msg.topic `Einträge werden gelöscht.\nEin entsprechende iobroker-out Node muss an den Flow angehängt werden. Sie ist nicht Bestandteil des Subflows. In dieser iobroker-out Node darf kein Topic angegeben werden. \n\nFalls msg.top nicht definiert wurde, wird der `top`-Wert der Subflow-Node verwendet.\n\nIn den Eigenschaften der Subflow-Node wurde ein neuer Parameter `keepTopic` hinzugefügt. Standardwert ist _false_, um das bisherige Verhalten beizubehalten. Setzt man die Eigenschaft auf _true_, dann wird das originale Topic zwischen der `top` Eigenschaft der Subflow-Node und Eigenschaft des analysierten JSON Objektes eingefügt.\n\n**Achtung:**\nWenn top und msg.top leer ist, werden alle msg.topics (msg.topic) direkt unter dem Präfix 0_userdata.0., angelegt bzw. ausgegeben. \n\n**Update 13.09.2022:**\nLeerzeichen werden in Topics von Objekten nicht mehr durch Unterstriche ersetzt. Es gibt keine Unterschiede mehr zwischen den Datentypen.",
           "category": "",
           "in": [
                   "x": 60,
                   "y": 160,
                   "wires": [
                           "id": "554b8c663bcb46c2"
           "out": [
                   "x": 2620,
                   "y": 280,
                   "wires": [
                           "id": "0962842ebd23e0d7",
                           "port": 0
           "env": [
                   "name": "top",
                   "type": "str",
                   "value": "objRoot"
                   "name": "keepTopic",
                   "type": "bool",
                   "value": "false"
           "meta": {},
           "color": "#E2D96E",
           "icon": "node-red/batch.svg"
           "id": "3e11e8338f694832",
           "type": "split",
           "z": "6e802f1553b18149",
           "name": "split object",
           "splt": "\\n",
           "spltType": "str",
           "arraySplt": 1,
           "arraySpltType": "len",
           "stream": false,
           "addname": "key",
           "x": 1370,
           "y": 160,
           "wires": [
                   "0562a4249c8b856b"
           "id": "0562a4249c8b856b",
           "type": "change",
           "name": "add key to topic",
           "rules": [
                   "t": "set",
                   "p": "stateName",
                   "pt": "msg",
                   "to": "key",
                   "tot": "msg"
                   "t": "change",
                   "p": "key",
                   "pt": "msg",
                   "from": ".",
                   "fromt": "str",
                   "to": "_",
                   "tot": "str"
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "topic  & '.' & key",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1560,
           "y": 160,
           "wires": [
                   "ddc90985bef0fafa"
           "id": "ddc90985bef0fafa",
           "type": "switch",
           "name": "is type?",
           "property": "payload",
           "propertyType": "msg",
           "rules": [
                   "t": "istype",
                   "v": "array",
                   "vt": "array"
                   "t": "istype",
                   "v": "object",
                   "vt": "object"
                   "t": "else"
           "checkall": "true",
           "repair": false,
           "outputs": 3,
           "x": 1740,
           "y": 160,
           "wires": [
                   "bfce19b206660fbe"
                   "3e11e8338f694832"
                   "1a8c03d866b85b12"
           "id": "bfce19b206660fbe",
           "type": "split",
           "name": "split array",
           "splt": "\\n",
           "spltType": "str",
           "arraySplt": 1,
           "stream": false,
           "addname": "",
           "x": 780,
           "y": 280,
           "wires": [
                   "e89927810c6d75ec"
           "id": "e89927810c6d75ec",
           "type": "change",
           "name": "add index to topic",
           "rules": [
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "topic  & '.' & parts.index",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 970,
           "y": 280,
           "wires": [
                   "a4d1a5d04564dc77"
           "id": "f5d52c6a57d08904",
           "type": "change",
           "name": "finalize msg.topic",
           "rules": [
                   "t": "set",
                   "p": "top",
                   "pt": "msg",
                   "to": "'0_userdata.0.' & top",
                   "tot": "jsonata"
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "top & '.' & topic",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 2170,
           "y": 240,
           "wires": [
                   "0962842ebd23e0d7"
           "id": "1a8c03d866b85b12",
           "type": "switch",
           "name": "is msg.top != null",
           "property": "top",
           "rules": [
                   "t": "nnull"
                   "t": "null"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 1950,
           "y": 280,
           "wires": [
                   "f5d52c6a57d08904"
                   "74c895ce724750de"
           "id": "e023fe88445ce43e",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "delete",
                   "p": "topic",
                   "pt": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 350,
           "y": 200,
           "wires": [
                   "3649300b4c233b10"
           "id": "3649300b4c233b10",
           "type": "switch",
           "name": "is type?",
           "rules": [
                   "t": "istype",
                   "v": "json",
                   "vt": "json"
                   "t": "istype",
                   "v": "array",
                   "vt": "array"
                   "t": "istype",
                   "v": "object",
                   "vt": "object"
                   "t": "else"
           "checkall": "true",
           "repair": false,
           "outputs": 4,
           "x": 600,
           "y": 160,
           "wires": [
                   "fc7913a8524badb7"
                   "bfce19b206660fbe"
                   "3e11e8338f694832"
                   "9ac3cc3681e8b6c6"
           "id": "1b8480cd2df7ba3f",
           "type": "comment",
           "name": "Array",
           "info": "",
           "x": 600,
           "y": 280,
           "wires": []
           "id": "b3541807672be040",
           "type": "comment",
           "name": "object",
           "info": "",
           "x": 1340,
           "y": 100,
           "wires": []
           "id": "a4d1a5d04564dc77",
           "type": "switch",
           "name": "is type?",
           "rules": [
                   "t": "istype",
                   "v": "object",
                   "vt": "object"
                   "t": "istype",
                   "v": "array",
                   "vt": "array"
                   "t": "else"
           "checkall": "true",
           "repair": false,
           "outputs": 3,
           "x": 1160,
           "y": 280,
           "wires": [
                   "3e11e8338f694832"
                   "bfce19b206660fbe"
                   "a096a93bb82b7a93"
           "id": "74c895ce724750de",
           "type": "change",
           "rules": [
                   "t": "set",
                   "p": "top",
                   "pt": "msg",
                   "to": "top",
                   "tot": "env"
                   "t": "set",
                   "p": "top",
                   "pt": "msg",
                   "tot": "jsonata"
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 2170,
           "y": 320,
           "wires": [
                   "0962842ebd23e0d7"
           "id": "554b8c663bcb46c2",
           "type": "switch",
           "name": "",
           "property": "keepTopic",
           "propertyType": "env",
           "rules": [
                   "t": "true"
                   "t": "false"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 170,
           "y": 160,
           "wires": [
                   "e30ba9f0483285e4"
                   "e023fe88445ce43e"
           "id": "e30ba9f0483285e4",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "change",
                   "p": "topic",
                   "pt": "msg",
                   "from": "/",
                   "fromt": "str",
                   "to": ".",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 350,
           "y": 120,
           "wires": [
                   "3649300b4c233b10"
           "type": "change",
           "name": "translate invalid chars in topic",
           "rules": [
                   "t": "change",
                   "p": "topic",
                   "pt": "msg",
                   "from": "..",
                   "fromt": "str",
                   "to": ".",
                   "tot": "str"
                   "t": "change",
                   "p": "topic",
                   "pt": "msg",
                   "from": "€",
                   "fromt": "str",
                   "to": "EUR",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 2430,
           "y": 280,
           "wires": [
           "id": "9ac3cc3681e8b6c6",
           "type": "change",
           "name": "set topic, if empty",
           "rules": [
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "topic ? topic : $type(payload)\t",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 950,
           "y": 200,
           "wires": [
                   "a096a93bb82b7a93"
           "id": "fc7913a8524badb7",
           "type": "json",
           "name": "",
           "action": "obj",
           "pretty": false,
           "x": 750,
           "y": 100,
           "wires": [
                   "d9e7bdd4c48a8aa1"
           "id": "d9e7bdd4c48a8aa1",
           "type": "switch",
           "name": "is type?",
           "rules": [
                   "t": "istype",
                   "v": "array",
                   "vt": "array"
                   "t": "istype",
                   "v": "object",
                   "vt": "object"
                   "t": "else"
           "checkall": "true",
           "repair": false,
           "outputs": 3,
           "x": 900,
           "y": 100,
           "wires": [
                   "1520be42bcc2145e"
                   "1520be42bcc2145e"
                   "9ac3cc3681e8b6c6"
           "id": "a096a93bb82b7a93",
           "type": "junction",
           "x": 1380,
           "y": 280,
           "wires": [
                   "1a8c03d866b85b12"
           "id": "1520be42bcc2145e",
           "type": "junction",
           "x": 480,
           "y": 20,
           "wires": [
                   "3649300b4c233b10"
           "id": "3e7ed9c7e1462b09",
           "type": "inject",
           "z": "7e6af0015415146d",
           "name": "AB  & Filter",
           "props": [
                   "p": "autobahn",
                   "v": "A7",
                   "vt": "str"
                   "p": "filter",
                   "v": "(coordinate.lat > 51.0 and coordinate.lat < 54.4) and (coordinate.long > 9.0 and coordinate.long < 10)",
                   "vt": "str"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "x": 180,
           "y": 7160,
           "wires": [
                   "e9f4765fa483a48a"
           "id": "e9f4765fa483a48a",
           "type": "template",
           "name": "",
           "field": "url",
           "fieldType": "msg",
           "format": "handlebars",
           "syntax": "mustache",
           "template": "https://verkehr.autobahn.de/o/autobahn/{{autobahn}}/services/warning",
           "output": "str",
           "x": 320,
           "y": 7160,
           "wires": [
                   "4759ede23832569c",
                   "a73f68ca019bab89"
           "id": "4759ede23832569c",
           "type": "debug",
           "name": "url",
           "active": false,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "true",
           "targetType": "full",
           "statusVal": "",
           "statusType": "auto",
           "x": 510,
           "y": 7100,
           "wires": []
           "id": "a73f68ca019bab89",
           "type": "http request",
           "name": "",
           "method": "GET",
           "ret": "obj",
           "paytoqs": "ignore",
           "url": "",
           "tls": "",
           "persist": false,
           "proxy": "",
           "insecureHTTPParser": false,
           "authType": "",
           "senderr": false,
           "headers": [],
           "x": 490,
           "y": 7160,
           "wires": [
                   "8d7bc4d16a712bc4",
                   "e4e045e2d7b0f1f3"
           "id": "8d7bc4d16a712bc4",
           "type": "debug",
           "name": "JSON",
           "active": false,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "true",
           "statusVal": "",
           "x": 670,
           "y": 7200,
           "wires": []
           "id": "e4e045e2d7b0f1f3",
           "type": "change",
           "name": "Filter",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload.warning[$eval($$.filter)].{\t    \"ID\": identifier, \"Titel\":title,\t    \"Verzögerung\": (delayTimeValue ? delayTimeValue : \"0\") & \" Minuten\",\t    \"Durchschnittsgeschwindigkeit\" : averageSpeed,\t   \"Beginn\": description[0] ~> $substringAfter(\": \"),\t   \"Ende\": description[1] ~> $substringAfter(\": \"),\t   \"Beschreibung\": description#$i[$i in [3..$count(%.description)]] ~> $join(\" \")\t}[]",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 650,
           "y": 7160,
           "wires": [
                   "7b995bd410358394",
                   "ad94c8961362eb3c"
           "id": "7b995bd410358394",
           "type": "change",
           "name": "Anzahl Warnungen",
           "rules": [
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "\"0_userdata.0.Test.Autobahn.\" & autobahn & \".AnzahlWarnungen\"",
                   "tot": "jsonata"
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "$count(payload)",
                   "tot": "jsonata"
                   "t": "set",
                   "p": "top",
                   "pt": "msg",
                   "to": "\"0_userdata.0.Test.Autobahn.\" & autobahn & \".Warnungen\"",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 830,
           "y": 7100,
           "wires": [
                   "abf49b5aa9ca3e7e"
           "id": "abf49b5aa9ca3e7e",
           "type": "ioBroker out",
           "name": "",
           "topic": "",
           "ack": "true",
           "autoCreate": "true",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1040,
           "y": 7100,
           "wires": []
           "id": "ccecbbc4a466efa8",
           "type": "subflow:6e802f1553b18149",
           "name": "",
           "x": 1010,
           "y": 7160,
           "wires": [
                   "a72e0e225946d210"
           "id": "a72e0e225946d210",
           "name": "",
           "topic": "",
           "ack": "true",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1240,
           "y": 7160,
           "wires": []
           "id": "df1966a24326d1f3",
           "type": "debug",
           "name": "Ergebnisse",
           "active": false,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "x": 970,
           "y": 7200,
           "wires": []
           "id": "ad94c8961362eb3c",
           "type": "change",
           "name": "Top Tree",
           "rules": [
                   "t": "set",
                   "p": "top",
                   "pt": "msg",
                   "to": "\"Test.Autobahn.\" & autobahn & \".Warnungen\"",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 800,
           "y": 7160,
           "wires": [
                   "ccecbbc4a466efa8",
                   "df1966a24326d1f3"
    icebearI Online
    icebearI Online
    icebear
    @mickym
    Super Vielen Dank für deine Arbeit, ich werde das testen und berichten.
    • icebearI icebear
      @mickym
      mickymM Offline
      mickymM Offline
      mickym
      @icebear sagte in Auslesen und Filtern der autobahn.api von bund.dev:
      @mickym
      Ja noch einen Filter, als Sicherheitsabfrage, wenn keine Ergebnisse vorhanden sind.
      Sonst stürzt der NodeRed Adapter ab .
      Also diesen Flow bitte verwenden:
             "type": "subflow",
             "category": "",
             "in": [
                     "x": 60,
                     "y": 160,
                     "wires": [
             "out": [
                     "x": 2620,
                     "y": 280,
                     "wires": [
                             "port": 0
             "env": [
                     "name": "top",
                     "type": "str",
                     "value": "objRoot"
                     "type": "bool",
                     "value": "false"
             "meta": {},
             "color": "#E2D96E",
             "type": "split",
             "splt": "\\n",
             "spltType": "str",
             "arraySplt": 1,
             "stream": false,
             "addname": "key",
             "x": 1370,
             "y": 160,
             "wires": [
                     "0562a4249c8b856b"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "stateName",
                     "pt": "msg",
                     "to": "key",
                     "tot": "msg"
                     "t": "change",
                     "p": "key",
                     "pt": "msg",
                     "from": ".",
                     "fromt": "str",
                     "to": "_",
                     "tot": "str"
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 1560,
             "y": 160,
             "wires": [
                     "ddc90985bef0fafa"
             "type": "switch",
             "name": "is type?",
             "rules": [
                     "t": "istype",
                     "v": "array",
                     "vt": "array"
                     "t": "istype",
                     "v": "object",
                     "vt": "object"
                     "t": "else"
             "checkall": "true",
             "repair": false,
             "outputs": 3,
             "x": 1740,
             "y": 160,
             "wires": [
                     "bfce19b206660fbe"
                     "3e11e8338f694832"
                     "1a8c03d866b85b12"
             "type": "split",
             "splt": "\\n",
             "spltType": "str",
             "arraySplt": 1,
             "stream": false,
             "addname": "",
             "x": 780,
             "y": 280,
             "wires": [
                     "e89927810c6d75ec"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 970,
             "y": 280,
             "wires": [
                     "a4d1a5d04564dc77"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "top",
                     "pt": "msg",
                     "tot": "jsonata"
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2170,
             "y": 240,
             "wires": [
                     "0962842ebd23e0d7"
             "type": "switch",
             "property": "top",
             "rules": [
                     "t": "nnull"
                     "t": "null"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 1950,
             "y": 280,
             "wires": [
                     "f5d52c6a57d08904"
                     "74c895ce724750de"
             "type": "change",
             "name": "",
             "rules": [
                     "t": "delete",
                     "p": "topic",
                     "pt": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 350,
             "y": 200,
             "wires": [
                     "3649300b4c233b10"
             "type": "switch",
             "name": "is type?",
             "rules": [
                     "t": "istype",
                     "v": "json",
                     "vt": "json"
                     "t": "istype",
                     "v": "array",
                     "vt": "array"
                     "t": "istype",
                     "v": "object",
                     "vt": "object"
                     "t": "else"
             "checkall": "true",
             "repair": false,
             "outputs": 4,
             "x": 600,
             "y": 160,
             "wires": [
                     "fc7913a8524badb7"
                     "bfce19b206660fbe"
                     "3e11e8338f694832"
                     "9ac3cc3681e8b6c6"
             "type": "comment",
             "name": "Array",
             "info": "",
             "x": 600,
             "y": 280,
             "wires": []
             "type": "comment",
             "name": "object",
             "info": "",
             "x": 1340,
             "y": 100,
             "wires": []
             "type": "switch",
             "name": "is type?",
             "rules": [
                     "t": "istype",
                     "v": "object",
                     "vt": "object"
                     "t": "istype",
                     "v": "array",
                     "vt": "array"
                     "t": "else"
             "checkall": "true",
             "repair": false,
             "outputs": 3,
             "x": 1160,
             "y": 280,
             "wires": [
                     "3e11e8338f694832"
                     "bfce19b206660fbe"
                     "a096a93bb82b7a93"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "top",
                     "pt": "msg",
                     "to": "top",
                     "tot": "env"
                     "t": "set",
                     "p": "top",
                     "pt": "msg",
                     "tot": "jsonata"
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2170,
             "y": 320,
             "wires": [
                     "0962842ebd23e0d7"
             "type": "switch",
             "name": "",
             "rules": [
                     "t": "true"
                     "t": "false"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 170,
             "y": 160,
             "wires": [
                     "e30ba9f0483285e4"
                     "e023fe88445ce43e"
             "type": "change",
             "name": "",
             "rules": [
                     "t": "change",
                     "p": "topic",
                     "pt": "msg",
                     "from": "/",
                     "fromt": "str",
                     "to": ".",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 350,
             "y": 120,
             "wires": [
                     "3649300b4c233b10"
             "type": "change",
             "rules": [
                     "t": "change",
                     "p": "topic",
                     "pt": "msg",
                     "from": "..",
                     "fromt": "str",
                     "to": ".",
                     "tot": "str"
                     "t": "change",
                     "p": "topic",
                     "pt": "msg",
                     "from": "€",
                     "fromt": "str",
                     "to": "EUR",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2430,
             "y": 280,
             "wires": [
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 950,
             "y": 200,
             "wires": [
                     "a096a93bb82b7a93"
             "type": "json",
             "name": "",
             "action": "obj",
             "pretty": false,
             "x": 750,
             "y": 100,
             "wires": [
                     "d9e7bdd4c48a8aa1"
             "type": "switch",
             "name": "is type?",
             "rules": [
                     "t": "istype",
                     "v": "array",
                     "vt": "array"
                     "t": "istype",
                     "v": "object",
                     "vt": "object"
                     "t": "else"
             "checkall": "true",
             "repair": false,
             "outputs": 3,
             "x": 900,
             "y": 100,
             "wires": [
                     "1520be42bcc2145e"
                     "1520be42bcc2145e"
                     "9ac3cc3681e8b6c6"
             "type": "junction",
             "x": 1380,
             "y": 280,
             "wires": [
                     "1a8c03d866b85b12"
             "type": "junction",
             "x": 480,
             "y": 20,
             "wires": [
                     "3649300b4c233b10"
             "type": "inject",
             "props": [
                     "p": "autobahn",
                     "v": "A7",
                     "vt": "str"
                     "p": "filter",
                     "v": "(coordinate.lat > 49.0 and coordinate.lat < 54.4) and (coordinate.long > 6.0 and coordinate.long < 10)",
                     "vt": "str"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "x": 180,
             "y": 7160,
             "wires": [
                     "e9f4765fa483a48a"
             "type": "template",
             "name": "",
             "field": "url",
             "fieldType": "msg",
             "output": "str",
             "x": 320,
             "y": 7160,
             "wires": [
                     "4759ede23832569c",
                     "a73f68ca019bab89"
             "type": "debug",
             "name": "url",
             "active": false,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "true",
             "statusVal": "",
             "x": 510,
             "y": 7100,
             "wires": []
             "name": "",
             "method": "GET",
             "ret": "obj",
             "url": "",
             "tls": "",
             "persist": false,
             "proxy": "",
             "authType": "",
             "senderr": false,
             "headers": [],
             "x": 490,
             "y": 7160,
             "wires": [
                     "8d7bc4d16a712bc4",
                     "e4e045e2d7b0f1f3"
             "type": "debug",
             "name": "JSON",
             "active": false,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "true",
             "statusVal": "",
             "x": 670,
             "y": 7200,
             "wires": []
             "type": "change",
             "name": "Filter",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 650,
             "y": 7160,
             "wires": [
                     "7b995bd410358394",
                     "37f05e634adffcfb"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "tot": "jsonata"
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "jsonata"
                     "t": "set",
                     "p": "top",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 830,
             "y": 7100,
             "wires": [
                     "abf49b5aa9ca3e7e"
             "name": "",
             "topic": "",
             "ack": "true",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 1040,
             "y": 7100,
             "wires": []
             "name": "",
             "x": 1170,
             "y": 7160,
             "wires": [
                     "a72e0e225946d210"
             "name": "",
             "topic": "",
             "ack": "true",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 1400,
             "y": 7160,
             "wires": []
             "type": "debug",
             "active": false,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1150,
             "y": 7200,
             "wires": []
             "type": "change",
             "name": "Top Tree",
             "rules": [
                     "t": "set",
                     "p": "top",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 960,
             "y": 7160,
             "wires": [
                     "ccecbbc4a466efa8",
                     "df1966a24326d1f3"
             "id": "37f05e634adffcfb",
             "type": "switch",
             "name": "",
             "property": "$count(payload)",
             "propertyType": "jsonata",
             "rules": [
                     "t": "gt",
                     "v": "0",
                     "vt": "num"
             "checkall": "true",
             "repair": false,
             "outputs": 1,
             "x": 810,
             "y": 7160,
             "wires": [
                     "ad94c8961362eb3c"
      • G Offline
        gutgut30
        @mickym said in Auslesen und Filtern der autobahn.api von bund.dev:
        :title,
        Funktioniert perfekt. Ich schreibe inzwischen auch einfach das JSON in den Datenpunkt und gebe es in Jarvis als einfache JSON Liste aus. Das reicht mir vollkommen.
        An einer Kleinigkeit habe ich mir aber nun dann doch noch die Zähne ausgebissen und bin mit Google und KI nicht zum Ziel gekommen...
        Ich gehe davon aus, dass der Wert "isBlocked" in der Rückgabe für eine Vollsperrung steht. Wie bekomme ich es hin, dass ich in der Ausgabe bei false den Wert gar nicht habe, bei true aber ein Wert "Vollsperrung" : "ja" kommt?
        Ich hab es replacen können, aber eine Selektion mal "Vollsperrung" und mal nicht mit auszugeben hat mich dann leider überfordert.
        • G gutgut30
          :title,
          mickymM Offline
          mickymM Offline
          mickym
          @gutgut30 sagte in Auslesen und Filtern der autobahn.api von bund.dev:
          $.warning[(coordinate.lat > 51.0 and coordinate.lat < 54.4) and (coordinate.long > 9.0 and coordinate.long < 10)].{
              "Vollsperrung": isBlocked="false" ? undefined : "ja"}[]
          https://try.jsonata.org/yQ2hFUzFf
          Ach hatte ich schon erwähnt, dass JSONATA so genial ist und nur Eigenschaften anzeigt, die definiert sind?
          G 1 Antwort Letzte Antwort
          • mickymM mickym
            gutgut30
            Ich möchte euch herzlich danken - ich habe nun fast das, was ich haben wollte.
            Ich lese 3 Autobahnen aus, filtere auf mein Teistück und kombiniere diese. Anschließend erscheinen die Meldungen auf meiner VIS. Mein Lese-Blockly sieht so aus:
            Das Kombinieren der Meldungen so (und, ja, es geht sicher geschickter...):
            Die JSONata, je nach Autobahn, so (füllen von Verzögerung, Splitten des Titels):
            $.warning[(coordinate.lat > 1.1 and coordinate.lat < 99.999)].{"Autobahn":$substringBefore(title, " |"),"Teilstück":$substringAfter(title, " | "),"Verzögerung": (delayTimeValue ? delayTimeValue : "0") & " Minuten","Vollsperrung": isBlocked="false" ? undefined : "ja"}[]
            Und was ich damit am Ende bezwecken wollte:
            Was ich jetzt noch versuchen werde:
            • das zusammenbauen der Kombination besser bauen
            • nur die Meldungen ausgeben die entweder Verzögerung von mehr als 2 Minuten haben ODER eine Vollsperrung ergeben. Das dürfte eigentlich schon mit JSONata Filtern machbar sein
            • Und, sicher die größte Herausforderung, nur die Meldungen anzeigen, die in die gewünschte Richtung gelten.
              Derzeit bekomme ich ja auch Meldungen auf der Gegenfahrbahn, die brauche ich nicht. Das müsste ja eigentlich möglich sein, es zu filtern durch "gebe nur Meldungen die Koordinate von Nord nach Süd haben".
            icebearI 1 Antwort Letzte Antwort
            • G gutgut30
              icebearI Online
              icebearI Online
              icebear
              schrieb am zuletzt editiert von icebear
              @gutgut30
              wie hast du denn die google maps Karte eingebunden?
              Edit: Hat sich erledigt
              • bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                ich habe auch mal ne Frage zu der api.
                Bei folgender url:
                https://verkehr.autobahn.de/o/autobahn/A7/services/webcam
                bekomme ich nur sowas:
                Lt. api sollte doch aber eine Auflistung folgen:
                Wie gesagt, ich hätte gerne das u.g. json.
                Folgendes Script habe ich zum auslesen mal schnell geschrieben:
                httpGet('https://verkehr.autobahn.de/o/autobahn/A7/services/webcam', { timeout: 1000 }, (error, response) => {
                    if (!error) {
                        console.log(response.statusCode);
                        console.log(response.data);
                    } else {
                        console.error(error);
                Im log kommt dann:
                script.js.Scripte.Sonstige.Autobahn: {"webcam":[]}
                Frage:
                Muss die httpget anders aussehen?
                Die anderen url von der api funktionieren; nur halt nicht die webcam url.
                Danke.
                R 1 Antwort Letzte Antwort
                • bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  Keiner eine Idee ?
                  Danke.
                  • bahnuhrB bahnuhr
                    Bei folgender url:
                        if (!error) {
                        } else {
                    Im log kommt dann:
                    Frage:
                    Ralf 2
                    @bahnuhr sagte in Auslesen und Filtern der autobahn.api von bund.dev:
                    Die Webcams sind bereits seit einigen Jahren nicht mehr für die Öffentlichkeit verfügbar - Datenschutz.
                    Ich finde das auch blöde, früher hatte ich mir immer den Verkehr auf der Rheinbrücke vor der Fahrt angesehen, geht in Deutschland nicht mehr.
                    Gruß Ralf
                    • R Ralf 2
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      @ralf-2
                      Danke für die Info.
                      Dann ist aber auch die api Beschreibung veraltet.
                      Danke.
                      • bahnuhrB bahnuhr
                        @ralf-2
                        Danke für die Info.
                        Ralf 2
                        @bahnuhr
                        Ja, aber vielleicht will man die wieder aktivieren.
                        Die Kameras wurden März 2022 wegen dem Ukrainekrieg abgeschaltet um es den Russen nicht zu leicht zu machen Truppenbewegungen in Deutschland zu erkennen.
                        Gruß Ralf
