  4. Hilfe bei buderus km 200 adapter
64 Beiträge 6 Kommentatoren 6.2k Aufrufe 5 Beobachtet
    @mcm1957
    Ich verwende weder den einen noch den anderen...
    Du meintest vermutlich @Pooldiver
    mcm1957M Online
    mcm1957M Online
    mcm1957
    Ja - sorry
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    P 1 Antwort Letzte Antwort
    • mcm1957M mcm1957
      Ja - sorry
      Pooldiver
      so hebe nun nodejs geupdatet aben denk da hat etwas nicht funktioniert.
      km 200 ist nun auch gelöscht.
      dpkg: error processing archive /var/cache/apt/archives/evcc_0.200.9_armhf.deb (--unpack):
       new evcc package pre-installation script subprocess returned error exit status 1
      Preparing to unpack .../nodejs_20.18.3-1nodesource1_armhf.deb ...
      Detected old npm client, removing...
      Unpacking nodejs (20.18.3-1nodesource1) over (18.17.1-deb-1nodesource1) ...
      Errors were encountered while processing:
      Error: Timeout was reached
      E: Sub-process /usr/bin/dpkg returned an error code (1)
      We tried our best to fix your nodejs. Please run iob diag again to verify.
      *** RESTARTING ioBroker NOW! ***
       Please refresh or restart your browser in a few moments.
      pi@raspberrypi:/opt/iobroker $ type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
      /usr/bin/node
      /usr/bin/npm
      /usr/bin/npx
      P HomoranH 2 Antworten Letzte Antwort
      • P Pooldiver
        /usr/bin/node
        /usr/bin/npm
        /usr/bin/npx
        Pooldiver
        @pooldiver
        beim full update ist auch was schief gelaufen
        Nothing to do - Your installation is using the correct paths.
        Nothing to do - Your version is the recommended one.
        ***You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands. ***
        *** DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation! ***
         *** DO NOT use 'nodejs-update' as part of a regular update process! ***
        /usr/bin/node
        /usr/bin/npm
        /usr/bin/npx
        pi@raspberrypi:/opt/iobroker $ sudo apt update && sudo apt full-upgrade
        OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
        OK:3 https://deb.nodesource.com/node_20.x nodistro InRelease
        Holen:4 https://dl.evcc.io/public/evcc/stable/deb/raspbian bullseye InRelease
        Es wurden 5.127 B in 1 s geholt (6.313 B/s).
        Fehler: Zeitberschreitung wurde erreicht
        Abhngigkeitsbaum wird aufgebaut... Fertig
        Statusinformationen werden eingelesen... Fertig
        Aktualisierung fr 1 Paket verfgbar. Fhren Sie apt list --upgradable aus, um es anzuzeigen.
        Paketaktualisierung (Upgrade) wird berechnet... Fertig
          evcc
        1 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
        1 nicht vollstndig installiert oder entfernt.
        Es mssen noch 0 B von 22,6 MB an Archiven heruntergeladen werden.
        Nach dieser Operation werden 14,5 MB Plattenplatz zustzlich benutzt.
        Mchten Sie fortfahren? [J/n] J
        Changelogs werden gelesen... Fertig
        dpkg: Warnung: Dateilisten-Datei des Paketes python3-pip fehlt; es wird angenommen,
         dass das Paket derzeit keine Dateien installiert hat
        (Lese Datenbank ... 119492 Dateien und Verzeichnisse sind derzeit installiert.)
        Vorbereitung zum Entpacken von .../evcc_0.200.9_armhf.deb ...
        Not copying /root/.evcc/evcc.db to /var/lib/evcc/evcc.db, since there is
        already a database there.
        Either delete one of the databases or run 'touch /root/.evcc/.copiedToEvccUser' to keep both,
        then restart installation.
        Hint: usually the larger one is the one to keep.
        -rw-r--r-- 1 root root 57344  7. Mr 20:22 /root/.evcc/evcc.db
        -rw-r--r-- 1 evcc evcc 36864 31. Okt 2023  /var/lib/evcc/evcc.db
        dpkg: Fehler beim Bearbeiten des Archivs /var/cache/apt/archives/evcc_0.200.9_armhf.deb (--unpack):
         neues evcc-Skript des Paketes pre-installation-Unterprozess gab den Fehlerwert 1 zurck
        Fehler traten auf beim Bearbeiten von:
        • P Pooldiver
          @pooldiver
          /usr/bin/node
          /usr/bin/npm
          /usr/bin/npx
            evcc
          Pooldiver
          pi@raspberrypi:~ $  sudo apt update && sudo apt full-upgrade
          Es wurden 5.127 B in 1 s geholt (6.249 B/s).
           evcc
          • P Pooldiver
             evcc
            @pooldiver sagte in Hilfe bei buderus km 200 adapter:
            Da ist was mit der evcc.db falsch. Und eigentlich darf die auch nicht dem root gehören, weil der keine Anwendungsdaten produziert.
            • P Pooldiver
              /usr/bin/node
              /usr/bin/npm
              /usr/bin/npx
              bitte immer alles zeigen!
              auch die Eingabezeile.
              So weiss niemand was du da gemacht hast
                Pooldiver
                @homoran ich versuch mir zubesser
                sollte ich die ecvv.db flasch löschen
                • P Pooldiver
                  @pooldiver
                  Ja, eine der beiden db löschen. Ich vermute, die aus dem home vom root muss weg.
                  Und dann wirst du in allernächster Zeit dein System komplett neuaufsetzen, diesmal dann in der 64Bit-Lite-Version.
                    @pooldiver
                    Pooldiver
                    habe das system nicht selber auf gebaut.
                    und kenn auch nicht viel das von
                    nun die frage wenn ich eine neue SD karte hole und von null anfange kan man die karten wechslen so wie ne hdd beim pc
                    • P Pooldiver
                      @pooldiver
                      Klar. Sauber runterfahren, Karten tauschen, starten, fertig.
                        @pooldiver
                        Pooldiver
                        wie gross sollte die SD sein
                        Thomas BraunT P 2 Antworten Letzte Antwort
                        • P Pooldiver
                          @pooldiver
                          Kann man nicht generell beantworten. Hängt davon ab, was du da alles an Daten produzierst und wie lange du die vorhältst.
                          Ich hab meinen Raspberry mit einer 128GB SSD ausgestattet. Da habe ich ewig Ruhe.
                          • P Pooldiver
                            Pooldiver
                            @thomas-braun sagte in Hilfe bei buderus km 200 adapter:
                            @pooldiver
                            finde diese nicht in home
                            • P Pooldiver
                              @pooldiver
                              @pooldiver
                              Der root hat auch ein home-Verzeichnis. Auch wenn da natürlich nicht viel drin ist bzw. drin sein sollte, schließlich wird der root ja nicht für die tägliche Arbeit verwendet und kann daher solche Daten gar nicht generieren.
                              sudo rm /root/.evcc/evcc.db
                                @pooldiver
                                Pooldiver
                                gut is gelöscht nun geth der ecvv nicht mehr
                                • P Pooldiver
                                  @pooldiver
                                  Das schaut für mich nach eine 'Chaos'-Installation aus. Offenbar sowohl als Docker wie auch nativ per deb-Paket installiert.
                                  Der Docker-Krempel liegt in /root, das deb-Paket verwendet den user evcc und legt die db in /var/lib/evcc/ ab.
                                  Ich würde immer die native Installation vorziehen...
                                    @pooldiver
                                    Pooldiver
                                    kann ich noch was retten
                                    P Thomas BraunT 2 Antworten Letzte Antwort
                                    • P Pooldiver
                                      Pooldiver
                                      was kan ich tun im moment das ich nicht komplett neu muss instalieren
                                      • P Pooldiver
                                        @pooldiver
                                        Die db ist jetzt gelöscht.
                                        (Ich gebe zu, eine Umbenennung wäre gescheiter gewesen...)
                                        Da dein Debian 11 'Bullseye' ohne hin in Kürze endgültig ausläuft (im Upstream ist es schon länger tot) und Debian 12 'Bookworm' auf einem Raspberry eh neuinstalliert werden muss:
                                        Installier es neu. Und evcc dann diesmal 'ordentlich' als deb/apt-Paket.
                                          @pooldiver
                                          Pooldiver
                                          dumm gelaufen
                                          kann ich den iobroker sichern und wie d das backup immer auf der pi gespeichert wird
