  4. Hilfe bei buderus km 200 adapter
64 Beiträge 6 Kommentatoren 6.2k Aufrufe 5 Beobachtet
  • P Pooldiver
    @asgothian 2 versuch
    ems-esp.1
    	2025-03-10 14:19:13.774	error	error reading km200 gateway information (wrong ip address) - stop km200 read
    ems-esp.1
    	2025-03-10 14:19:13.756	info	no database instance selected for recordings
    ems-esp.1
    	2025-03-10 14:19:13.754	error	API version V2 identified. V2 is not supported anymore
    ems-esp.1
    	2025-03-10 14:19:13.667	info	starting. Version 1.21.0 in /opt/iobroker/node_modules/iobroker.ems-esp, node: v18.17.1, js-controller: 7.0.6
    host.raspberrypi
    	2025-03-10 14:19:10.975	info	instance system.adapter.ems-esp.1 in version "1.21.0" started with pid 10181
    host.raspberrypi
    	2025-03-10 14:19:06.735	info	instance system.adapter.ems-esp.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.raspberrypi
    	2025-03-10 14:19:06.290	info	Do not restart adapter system.adapter.km200.0 because desired by instance
    host.raspberrypi
    	2025-03-10 14:19:06.290	info	instance system.adapter.km200.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    host.raspberrypi
    	2025-03-10 14:19:06.217	info	stopInstance system.adapter.ems-esp.1 send kill signal
    ems-esp.1
    	2025-03-10 14:19:06.175	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    ems-esp.1
    	2025-03-10 14:19:06.173	info	terminating
    ems-esp.1
    	2025-03-10 14:19:06.170	info	Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi
    	2025-03-10 14:19:06.164	info	stopInstance system.adapter.ems-esp.1 (force=false, process=true)
    km200.0
    	2025-03-10 14:19:06.040	info	Adapter km200 initialization finished with 0 states.
    km200.0
    	2025-03-10 14:19:06.024	info	Slow Interval=6 hours, Slow-List:
    km200.0
    	2025-03-10 14:19:06.024	info	Fast Interval=2 min, Fast-List:
    km200.0
    	2025-03-10 14:19:06.023	info	Interval=30 min, Norm-list:
    km200.0
    	2025-03-10 14:19:06.021	info	KM200 found 0 states, get their values now.
    km200.0
    	2025-03-10 14:19:06.020	info	Services found: 41
    km200.0
    	2025-03-10 14:19:06.019	warn	Did not get any Services from KLM200!: {}
    km200.0
    	2025-03-10 14:19:05.997	warn	Skip service data of /system
    km200.0
    	2025-03-10 14:19:05.850	warn	Skip service data of /solarCircuits
    km200.0
    	2025-03-10 14:19:05.716	info	Terminated (ADAPTER_REQUESTED_TERMINATION): km200 Initialization Error:TypeError: Cannot read properties of undefined (reading '_subscribeForeignStates') at subscribeStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:6660:17) at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:830:111 at new Promise (<anonymous>) at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:830:20 at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:311:77
    km200.0
    	2025-03-10 14:19:05.704	warn	Skip service data of /recordings
    km200.0
    	2025-03-10 14:19:05.559	warn	Skip service data of /notifications
    km200.0
    	2025-03-10 14:19:05.411	warn	Skip service data of /heatSources
    km200.0
    	2025-03-10 14:19:05.264	warn	Skip service data of /heatingCircuits
    km200.0
    	2025-03-10 14:19:05.118	warn	Skip service data of /gateway
    km200.0
    	2025-03-10 14:19:04.969	warn	Skip service data of /dhwCircuits
    km200.0
    	2025-03-10 14:19:04.819	info	km200.0 address: http://http://192.168.1.75
    km200.0
    	2025-03-10 14:19:04.815	warn	Adapter will exit in latest 1 sec with code km200 Initialization Error:TypeError: Cannot read properties of undefined (reading '_subscribeForeignStates') at subscribeStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:6660:17) at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:830:111 at new Promise (<anonymous>) at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:830:20 at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:311:77!
    km200.0
    	2025-03-10 14:19:04.813	info	Adapter disconnected and stopped with dostop(km200 Initialization Error:TypeError: Cannot read properties of undefined (reading '_subscribeForeignStates') at subscribeStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:6660:17) at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:830:111 at new Promise (<anonymous>) at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:830:20 at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:311:77) and callback(false)
    km200.0
    	2025-03-10 14:19:04.812	error	km200 Initialization Error:TypeError: Cannot read properties of undefined (reading '_subscribeForeignStates') at subscribeStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:6660:17) at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:830:111 at new Promise (<anonymous>) at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:830:20 at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:311:77
    km200.0
    	2025-03-10 14:19:04.705	info	starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.km200, node: v18.17.1, js-controller: 7.0.6
    host.raspberrypi
    	2025-03-10 14:19:02.250	info	instance system.adapter.km200.0 in version "2.0.3" started with pid 10166
    @pooldiver sagte in Hilfe bei buderus km 200 adapter:
    node: v18.17.1
    Beobachtung am Rande:
    Deine nodejs-Version ist abgesoffen. Bring das auf nodejs@20.
    iob nodejs-update 20
    Vermutlich ist da aber auch noch mehr ranzig.
      node: v18.17.1
      MartinPM Online
      MartinPM Online
      MartinP
      @thomas-braun In Github steht außerdem....
      https://github.com/iobroker-community-adapters/ioBroker.km200
      This adapter is DEPRECATED and will not be developed any further
      Da reitet man ein totes Pferd ... (Seit Jul 2023)
      • MartinPM MartinP
        @martinp sagte in Hilfe bei buderus km 200 adapter:
        Nicht nur eins.
        Vermutlich liegt das tote Pferd im buster-Stall.
          Nicht nur eins.
          MartinPM Online
          MartinPM Online
          MartinP
          @thomas-braun Charakteristisch ist, dass @Pooldiver bei iobroker selber anscheinend im Beta Repository unterwegs ist ... aber da ein ziemlich abgehangene Version fährt ...
          Aktuell:
          EDIT - 7.4.21 ist doch nicht besonders alt:
          • MartinPM MartinP
            Aktuell:
            @martinp
            Ergibt aber dennoch keinen Sinn. Denn was soll man da testen, wenn es schon längst aktuellere Versionen gibt?
              @martinp
              mcm1957M Online
              mcm1957M Online
              mcm1957
              @Pooldiver
              Der Adapter .ioBroker.km200 ist DEPRECTED und ARCHIVED.
              Aus dem README des km200:
              Currently there is no further development for this adapter planned. Please migrate to ioBroker.ems-esp adapter which is maintained. If you miss any features at ioBroker.ems-esp open an issue at that repository (https://github.com/tp1de/ioBroker.ems-esp/issues).
              IoBroker.km200 will stay available for some time, but keep in mind, that it will not be adapted to node 20 and upcoming js-controller v5.
              Also vergiss und lösch den km200 Adapter und benutz den ems-esp der der dafür vorgesehne Nachfolger ist.
              Offizieller Support Thread ist da:
              https://forum.iobroker.net/topic/45862/neuer-adapter-ems-esp-für-bosch-heizungen
              Support Repositoryverwaltung.
              LESEN - gute Forenbeitrage
              • mcm1957M mcm1957
                @Pooldiver
                @mcm1957
                Ich verwende weder den einen noch den anderen...
                Du meintest vermutlich @Pooldiver
                  @mcm1957
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  Ja - sorry
                  P 1 Antwort Letzte Antwort
                  • mcm1957M mcm1957
                    Ja - sorry
                    Pooldiver
                    so hebe nun nodejs geupdatet aben denk da hat etwas nicht funktioniert.
                    km 200 ist nun auch gelöscht.
                    dpkg: error processing archive /var/cache/apt/archives/evcc_0.200.9_armhf.deb (--unpack):
                     new evcc package pre-installation script subprocess returned error exit status 1
                    Preparing to unpack .../nodejs_20.18.3-1nodesource1_armhf.deb ...
                    Detected old npm client, removing...
                    Unpacking nodejs (20.18.3-1nodesource1) over (18.17.1-deb-1nodesource1) ...
                    Errors were encountered while processing:
                    Error: Timeout was reached
                    E: Sub-process /usr/bin/dpkg returned an error code (1)
                    We tried our best to fix your nodejs. Please run iob diag again to verify.
                    *** RESTARTING ioBroker NOW! ***
                     Please refresh or restart your browser in a few moments.
                    pi@raspberrypi:/opt/iobroker $ type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
                    /usr/bin/node
                    /usr/bin/npm
                    /usr/bin/npx
                    P HomoranH 2 Antworten Letzte Antwort
                    • P Pooldiver
                      /usr/bin/node
                      /usr/bin/npm
                      /usr/bin/npx
                      Pooldiver
                      @pooldiver
                      beim full update ist auch was schief gelaufen
                      Nothing to do - Your installation is using the correct paths.
                      Nothing to do - Your version is the recommended one.
                      ***You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands. ***
                      *** DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation! ***
                       *** DO NOT use 'nodejs-update' as part of a regular update process! ***
                      /usr/bin/node
                      /usr/bin/npm
                      /usr/bin/npx
                      pi@raspberrypi:/opt/iobroker $ sudo apt update && sudo apt full-upgrade
                      OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                      OK:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Holen:4 https://dl.evcc.io/public/evcc/stable/deb/raspbian bullseye InRelease
                      Es wurden 5.127 B in 1 s geholt (6.313 B/s).
                      Fehler: Zeitberschreitung wurde erreicht
                      Abhngigkeitsbaum wird aufgebaut... Fertig
                      Statusinformationen werden eingelesen... Fertig
                      Aktualisierung fr 1 Paket verfgbar. Fhren Sie apt list --upgradable aus, um es anzuzeigen.
                      Paketaktualisierung (Upgrade) wird berechnet... Fertig
                        evcc
                      1 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                      1 nicht vollstndig installiert oder entfernt.
                      Es mssen noch 0 B von 22,6 MB an Archiven heruntergeladen werden.
                      Nach dieser Operation werden 14,5 MB Plattenplatz zustzlich benutzt.
                      Mchten Sie fortfahren? [J/n] J
                      Changelogs werden gelesen... Fertig
                      dpkg: Warnung: Dateilisten-Datei des Paketes python3-pip fehlt; es wird angenommen,
                       dass das Paket derzeit keine Dateien installiert hat
                      (Lese Datenbank ... 119492 Dateien und Verzeichnisse sind derzeit installiert.)
                      Vorbereitung zum Entpacken von .../evcc_0.200.9_armhf.deb ...
                      Not copying /root/.evcc/evcc.db to /var/lib/evcc/evcc.db, since there is
                      already a database there.
                      Either delete one of the databases or run 'touch /root/.evcc/.copiedToEvccUser' to keep both,
                      then restart installation.
                      Hint: usually the larger one is the one to keep.
                      -rw-r--r-- 1 root root 57344  7. Mr 20:22 /root/.evcc/evcc.db
                      -rw-r--r-- 1 evcc evcc 36864 31. Okt 2023  /var/lib/evcc/evcc.db
                      dpkg: Fehler beim Bearbeiten des Archivs /var/cache/apt/archives/evcc_0.200.9_armhf.deb (--unpack):
                       neues evcc-Skript des Paketes pre-installation-Unterprozess gab den Fehlerwert 1 zurck
                      Fehler traten auf beim Bearbeiten von:
                      • P Pooldiver
                        @pooldiver
                        /usr/bin/node
                        /usr/bin/npm
                        /usr/bin/npx
                          evcc
                        Pooldiver
                        pi@raspberrypi:~ $  sudo apt update && sudo apt full-upgrade
                        Es wurden 5.127 B in 1 s geholt (6.249 B/s).
                         evcc
                        • P Pooldiver
                           evcc
                          Da ist was mit der evcc.db falsch. Und eigentlich darf die auch nicht dem root gehören, weil der keine Anwendungsdaten produziert.
                          • P Pooldiver
                            /usr/bin/node
                            /usr/bin/npm
                            /usr/bin/npx
                            bitte immer alles zeigen!
                            auch die Eingabezeile.
                            So weiss niemand was du da gemacht hast
                              Pooldiver
                              @homoran ich versuch mir zubesser
                              sollte ich die ecvv.db flasch löschen
                              • P Pooldiver
                                @pooldiver
                                Ja, eine der beiden db löschen. Ich vermute, die aus dem home vom root muss weg.
                                Und dann wirst du in allernächster Zeit dein System komplett neuaufsetzen, diesmal dann in der 64Bit-Lite-Version.
                                  @pooldiver
                                  Pooldiver
                                  habe das system nicht selber auf gebaut.
                                  und kenn auch nicht viel das von
                                  nun die frage wenn ich eine neue SD karte hole und von null anfange kan man die karten wechslen so wie ne hdd beim pc
                                  • P Pooldiver
                                    @pooldiver
                                    Klar. Sauber runterfahren, Karten tauschen, starten, fertig.
                                      @pooldiver
                                      Pooldiver
                                      wie gross sollte die SD sein
                                      Thomas BraunT P 2 Antworten Letzte Antwort
                                      • P Pooldiver
                                        @pooldiver
                                        Kann man nicht generell beantworten. Hängt davon ab, was du da alles an Daten produzierst und wie lange du die vorhältst.
                                        Ich hab meinen Raspberry mit einer 128GB SSD ausgestattet. Da habe ich ewig Ruhe.
                                        • P Pooldiver
                                          Pooldiver
                                          @thomas-braun sagte in Hilfe bei buderus km 200 adapter:
                                          @pooldiver
                                          finde diese nicht in home
