  3. Entwicklung
  4. Adapter debugging mit VSCode remote ssh
    apollon77A
23 Beiträge 4 Kommentatoren 3.2k Aufrufe 4 Beobachtet
  • AsgothianA Asgothian
    @oliverio sagte in Adapter debugging mit VSCode remote ssh:
    Was für Fehler?
    Schau mal hinterm Spoiler nach. Da ist der versuch mit 'npm run dev-server watch' hinterlegt.
    │   dev-server was sucessfully set up in                                    │
    │   /usr/local/iobroker/node_modules/iobroker.zigbee/.dev-server/default.   │
    │   You may now execute one of the following commands                       │
    │   dev-server run default                                                  │
    │   dev-server watch default                                                │
    │   dev-server debug default                                                │
    │   to use dev-server.                                                      │
    SilverSkin:iobroker.zigbee ae$ npm run dev-server watch default
    > iobroker.zigbee@2.0.3 dev-server
    Using profile name "default"
    Using adapter name "zigbee"
    Install local iobroker.zigbee
    /usr/local/iobroker/node_modules/iobroker.zigbee> npm pack
    Packed to iobroker.zigbee-2.0.3.tgz
    /usr/local/iobroker/node_modules/iobroker.zigbee/.dev-server/default> npm install "/usr/local/iobroker/node_modules/iobroker.zigbee/iobroker.zigbee-2.0.3.tgz"
    up to date, audited 476 packages in 3s
    65 packages are looking for funding
     run `npm fund` for details
    20 vulnerabilities (16 moderate, 4 high)
    To address issues that do not require attention, run:
     npm audit fix
    To address all issues (including breaking changes), run:
     npm audit fix --force
    Run `npm audit` for details.
    /usr/local/iobroker/node_modules/iobroker.zigbee/.dev-server/default> node --inspect=127.0.0.1:9228 --preserve-symlinks --preserve-symlinks-main node_modules/iobroker.js-controller/controller.js
    Waiting for js-controller to start...
    Waiting for port 26426 to be available...
    Debugger listening on ws://127.0.0.1:9228/27431210-2c1a-42a8-9516-d2d9a3f25005
    For help, see: https://nodejs.org/en/docs/inspector
    2025-03-08 21:33:01.399  - info: host.dev-zigbee-SilverSkin.fritz.box iobroker.js-controller version 7.0.6 js-controller starting
    2025-03-08 21:33:01.403  - info: host.dev-zigbee-SilverSkin.fritz.box Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2025-03-08 21:33:01.404  - info: host.dev-zigbee-SilverSkin.fritz.box hostname: dev-zigbee-SilverSkin.fritz.box, node: v20.18.0
    2025-03-08 21:33:01.404  - info: host.dev-zigbee-SilverSkin.fritz.box ip addresses: fe80::cce:e916:61d6:e801 192.168.2.24 fda3:8957:951:5a48:cff:e3e2:1d24:7878 fe80::8d3:dff:fe34:229f fe80::8d3:dff:fe34:229f fe80::6aaf:9d19:7309:5d38 fe80::2a63:bea8:80a0:2a24 fe80::ce81:b1c:bd2c:69e fe80::30e:4cdf:b190:2efc fe80::d4f5:2bde:790a:bb5f fe80::9df5:d7c1:8805:529c fe80::9c28:fd69:aea3:fa16 fe80::798b:4c4c:e4ae:912d fe80::21af:f4d6:cb8b:db29 fe80::9253:21b8:d4c6:ff1a fe80::b027:38d8:8ea3:49e7 fe80::f227:4e89:8745:6833 fe80::fefe:8625:4e38:2b23
    2025-03-08 21:33:01.408  - debug: host.dev-zigbee-SilverSkin.fritz.box-Server Data File: /usr/local/iobroker/node_modules/iobroker.zigbee/.dev-server/default/iobroker-data/objects.jsonl
    2025-03-08 21:33:01.430  - debug: host.dev-zigbee-SilverSkin.fritz.box-Server  Redis inMem-objects listening on port 9001
    2025-03-08 21:33:01.431  - debug: host.dev-zigbee-SilverSkin.fritz.box Redis Objects: Use Redis connection: 127.0.0.1:26426
    2025-03-08 21:33:01.443  - debug: host.dev-zigbee-SilverSkin.fritz.box Objects client ready ... initialize now
    2025-03-08 21:33:01.444  - debug: host.dev-zigbee-SilverSkin.fritz.box Objects create System PubSub Client
    2025-03-08 21:33:01.454  - debug: host.dev-zigbee-SilverSkin.fritz.box Objects client initialize lua scripts
    2025-03-08 21:33:01.462  - debug: host.dev-zigbee-SilverSkin.fritz.box Objects connected to redis: 127.0.0.1:26426
    2025-03-08 21:33:01.469  - debug: host.dev-zigbee-SilverSkin.fritz.box-Server Data File: /usr/local/iobroker/node_modules/iobroker.zigbee/.dev-server/default/iobroker-data/states.jsonl
    2025-03-08 21:33:01.473  - debug: host.dev-zigbee-SilverSkin.fritz.box-Server  Redis inMem-states listening on port 9000
    2025-03-08 21:33:01.473  - debug: host.dev-zigbee-SilverSkin.fritz.box Redis States: Use Redis connection: 127.0.0.1:24426
    2025-03-08 21:33:01.478  - debug: host.dev-zigbee-SilverSkin.fritz.box States create System PubSub Client
    2025-03-08 21:33:01.482  - debug: host.dev-zigbee-SilverSkin.fritz.box States connected to redis: 127.0.0.1:24426
    2025-03-08 21:33:01.489  - info: host.dev-zigbee-SilverSkin.fritz.box connected to Objects and States
    2025-03-08 21:33:01.490  - debug: host.dev-zigbee-SilverSkin.fritz.box Could not read notifications.json: /usr/local/iobroker/node_modules/iobroker.zigbee/.dev-server/default/iobroker-data/notifications.json: ENOENT: no such file or directory, open '/usr/local/iobroker/node_modules/iobroker.zigbee/.dev-server/default/iobroker-data/notifications.json'
    2025-03-08 21:33:01.549  - info: host.dev-zigbee-SilverSkin.fritz.box Node.js version has changed from unknown to 20.18.0
    2025-03-08 21:33:01.559  - info: host.dev-zigbee-SilverSkin.fritz.box added notifications configuration of host
    2025-03-08 21:33:01.579  - debug: host.dev-zigbee-SilverSkin.fritz.box Plugin sentry Do not initialize Plugin (enabled=false)
    2025-03-08 21:33:01.588  - info: host.dev-zigbee-SilverSkin.fritz.box 4 instances found
    2025-03-08 21:33:01.588  - debug: host.dev-zigbee-SilverSkin.fritz.box check instance "system.adapter.admin.0" for host "dev-zigbee-SilverSkin.fritz.box"
    2025-03-08 21:33:01.590  - debug: host.dev-zigbee-SilverSkin.fritz.box check instance "system.adapter.backitup.0" for host "dev-zigbee-SilverSkin.fritz.box"
    2025-03-08 21:33:01.591  - debug: host.dev-zigbee-SilverSkin.fritz.box check instance "system.adapter.zigbee.0" for host "dev-zigbee-SilverSkin.fritz.box"
    2025-03-08 21:33:01.591  - debug: host.dev-zigbee-SilverSkin.fritz.box check instance "system.adapter.discovery.0" for host "dev-zigbee-SilverSkin.fritz.box"
    2025-03-08 21:33:01.591  - info: host.dev-zigbee-SilverSkin.fritz.box starting 3 instances
    2025-03-08 21:33:01.611  - debug: host.dev-zigbee-SilverSkin.fritz.box added notifications configuration of system.adapter.admin.0
    2025-03-08 21:33:01.611  - debug: host.dev-zigbee-SilverSkin.fritz.box startInstance admin.0 loglevel=info, compact=false
    2025-03-08 21:33:01.616  - info: host.dev-zigbee-SilverSkin.fritz.box instance system.adapter.admin.0 in version "7.6.1" started with pid 98880
    Port 26426 is available...
    Waiting for port 24426 to be available...
    Port 24426 is available...
    Running inside /usr/local/iobroker/node_modules/iobroker.zigbee/.dev-server/default
    Waiting for port 20426 to be available...
    ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    2025-03-08 21:33:02.894  - debug: host.dev-zigbee-SilverSkin.fritz.box Incoming Host message getRepository
    2025-03-08 21:33:02.896  - info: host.dev-zigbee-SilverSkin.fritz.box Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
    2025-03-08 21:33:03.062  - debug: host.dev-zigbee-SilverSkin.fritz.box Incoming Host message getHostInfo
    2025-03-08 21:33:03.175  - debug: host.dev-zigbee-SilverSkin.fritz.box Incoming Host message getHostInfo
    2025-03-08 21:33:03.282  - debug: host.dev-zigbee-SilverSkin.fritz.box Incoming Host message getRepository
    2025-03-08 21:33:03.282  - debug: host.dev-zigbee-SilverSkin.fritz.box Repository update already running, registered instance "system.adapter.admin.0"
    Port 20426 is available...
    Starting React build
    Waiting for first successful React build...
    /usr/local/iobroker/node_modules/iobroker.zigbee> npm run watch:parcel
    > iobroker.zigbee@2.0.3 watch:parcel
    > parcel admin/src/index.tsx -d admin/build --hmr-port 1235
    sh: parcel: command not found
    dev-server watch [profile]
    Run ioBroker dev-server and start the adapter in "watch" mode. The adapter will automatically
    restart when its source code changes. You may attach a debugger to the running adapter.
    Options:
         --version     Show version number                                                    [boolean]
     -t, --temp        Temporary directory where the dev-server data will be located
        [string] [default: ".dev-server"]
         --help        Show help                                                              [boolean]
     -n, --noStart     Do not start the adapter itself, only watch for changes and sync them. [boolean]
     -x, --noInstall   Do not build and install the adapter before starting.                  [boolean]
     -w, --doNotWatch  Do not watch the given files or directories for changes (provide paths relative
                       to the adapter base directory.                                          [string]
    Error: Exited with 127
       at ChildProcess.<anonymous> (/usr/local/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/dev-server/dist/index.js:1495:44)
       at ChildProcess.emit (node:events:531:35)
       at ChildProcess._handle.onexit (node:internal/child_process:294:12)
    SilverSkin:iobroker.zigbee ae$ 2025-03-08 21:33:04.114  - info: host.dev-zigbee-SilverSkin.fritz.box received SIGINT
    2025-03-08 21:33:04.115  - debug: host.dev-zigbee-SilverSkin.fritz.box stop isStopping=0 isDaemon=false allInstancesStopped=false
    2025-03-08 21:33:04.115  - info: host.dev-zigbee-SilverSkin.fritz.box stopInstance system.adapter.admin.0 (force=false, process=true)
    2025-03-08 21:33:04.115  - info: host.dev-zigbee-SilverSkin.fritz.box stopInstance system.adapter.backitup.0 (force=false, process=false)
    2025-03-08 21:33:04.116  - info: host.dev-zigbee-SilverSkin.fritz.box stopInstance system.adapter.zigbee.0 (force=false, process=false)
    2025-03-08 21:33:04.116  - info: host.dev-zigbee-SilverSkin.fritz.box stopInstance system.adapter.discovery.0 (force=false, process=false)
    2025-03-08 21:33:04.411  - info: host.dev-zigbee-SilverSkin.fritz.box stopInstance system.adapter.admin.0 send kill signal
    The operation couldn’t be completed. Unable to locate a Java Runtime.
    Please visit http://www.java.com for information on installing Java.
    /bin/sh: yum: command not found
    No supported packet manager found
    Cannot detect dpkg: /bin/sh: dpkg: command not found
    2025-03-08 21:33:05.184  - debug: host.dev-zigbee-SilverSkin.fritz.box Automatic adapter upgrades are disabled for the current repository
    2025-03-08 21:33:05.411  - info: host.dev-zigbee-SilverSkin.fritz.box stopInstance timeout system.adapter.admin.0 killing pid 98880
    2025-03-08 21:33:05.426  - debug: host.dev-zigbee-SilverSkin.fritz.box-Server States 127.0.0.1:55148 Redis Socket error: Error: write EPIPE
       at WriteWrap.onWriteComplete [as oncomplete] (node:internal/stream_base_commons:95:16)
    2025-03-08 21:33:05.427  - debug: host.dev-zigbee-SilverSkin.fritz.box-Server Objects 127.0.0.1:55146 Redis Socket error: Error: write EPIPE
    ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
    2025-03-08 21:33:05.432  - warn: host.dev-zigbee-SilverSkin.fritz.box instance system.adapter.admin.0 terminated due to SIGKILL
    2025-03-08 21:33:05.433  - info: host.dev-zigbee-SilverSkin.fritz.box instance system.adapter.admin.0 terminated with code null ()
    2025-03-08 21:33:05.433  - info: host.dev-zigbee-SilverSkin.fritz.box All instances are stopped.
    2025-03-08 21:33:05.477  - debug: host.dev-zigbee-SilverSkin.fritz.box Plugin sentry destroyed
    2025-03-08 21:33:05.563  - info: host.dev-zigbee-SilverSkin.fritz.box terminated
    T
    T
    ticaki
    @asgothian
    em... dev-server watch sonst nix. steht doch drüber in dem rahmen
    Spenden
    • T ticaki
      @asgothian
      AsgothianA
      AsgothianA
      Asgothian
      @ticaki das geht garnicht - auf dem Mac sollte der dev-server via 'dev-dependency' installiert werden. Nicht global. Deswegen ist mit 'dev-server' nix zu holen. da gibts:
      dev-server watch
      bash: dev-server: command not found
        dev-server watch
        T
        T
        ticaki
        @asgothian
        ah ok bei mir hats auf einem mac auch nicht geklappt, deshalb bin ich remote auf einer vm - da gabs ne video anleitung für :D
        Spenden
        • T ticaki
          @asgothian
          AsgothianA
          AsgothianA
          Asgothian
          Hmm.. ich hab auf dem PI wo mein Produktiv System läuft (zum testen) mal den dev-server als dev-dependency installiert, so wie das auf Github beschrieben ist.
          Die Ausgaben sind aber ähnlich
          │   /opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default.   │
          stormy@stormbroker:/opt/iobroker/node_modules/iobroker.zigbee $ dev-server
          stormy@stormbroker:/opt/iobroker/node_modules/iobroker.zigbee $ npm run dev-server watch default
          /opt/iobroker/node_modules/iobroker.zigbee> npm pack
          /opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default> npm install "/opt/iobroker/node_modules/iobroker.zigbee/iobroker.zigbee-2.0.3.tgz"
          up to date, audited 475 packages in 2s
            npm audit fix
          /opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default> node --inspect=127.0.0.1:9228 --preserve-symlinks --preserve-symlinks-main node_modules/iobroker.js-controller/controller.js
          Debugger listening on ws://127.0.0.1:9228/8d9ad1ff-b7b6-42d7-a5ca-e48002dafd53
          2025-03-08 21:47:13.303  - info: host.dev-zigbee-stormbroker iobroker.js-controller version 7.0.6 js-controller starting
          2025-03-08 21:47:13.306  - info: host.dev-zigbee-stormbroker Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
          2025-03-08 21:47:13.307  - info: host.dev-zigbee-stormbroker hostname: dev-zigbee-stormbroker, node: v20.18.2
          2025-03-08 21:47:13.308  - info: host.dev-zigbee-stormbroker ip addresses: 192.168.2.222 192.168.2.43 fda3:8957:951:5a48:55fd:7999:b19e:8ea fe80::a937:f532:3c5b:b02
          2025-03-08 21:47:13.312  - debug: host.dev-zigbee-stormbroker-Server Data File: /opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default/iobroker-data/objects.jsonl
          2025-03-08 21:47:13.331  - debug: host.dev-zigbee-stormbroker-Server  Redis inMem-objects listening on port 9001
          2025-03-08 21:47:13.332  - debug: host.dev-zigbee-stormbroker Redis Objects: Use Redis connection: 127.0.0.1:26426
          2025-03-08 21:47:13.343  - debug: host.dev-zigbee-stormbroker Objects client ready ... initialize now
          2025-03-08 21:47:13.386  - debug: host.dev-zigbee-stormbroker Objects create System PubSub Client
          2025-03-08 21:47:13.397  - debug: host.dev-zigbee-stormbroker Objects client initialize lua scripts
          2025-03-08 21:47:13.404  - debug: host.dev-zigbee-stormbroker Objects connected to redis: 127.0.0.1:26426
          2025-03-08 21:47:13.456  - debug: host.dev-zigbee-stormbroker-Server Data File: /opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default/iobroker-data/states.jsonl
          2025-03-08 21:47:13.459  - debug: host.dev-zigbee-stormbroker-Server  Redis inMem-states listening on port 9000
          2025-03-08 21:47:13.460  - debug: host.dev-zigbee-stormbroker Redis States: Use Redis connection: 127.0.0.1:24426
          2025-03-08 21:47:13.506  - debug: host.dev-zigbee-stormbroker States create System PubSub Client
          2025-03-08 21:47:13.551  - debug: host.dev-zigbee-stormbroker States connected to redis: 127.0.0.1:24426
          2025-03-08 21:47:13.563  - info: host.dev-zigbee-stormbroker connected to Objects and States
          2025-03-08 21:47:13.564  - debug: host.dev-zigbee-stormbroker Could not read notifications.json: /opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default/iobroker-data/notifications.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default/iobroker-data/notifications.json'
          2025-03-08 21:47:13.579  - info: host.dev-zigbee-stormbroker Node.js version has changed from unknown to 20.18.2
          2025-03-08 21:47:13.591  - info: host.dev-zigbee-stormbroker added notifications configuration of host
          2025-03-08 21:47:13.592  - info: host.dev-zigbee-stormbroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
          2025-03-08 21:47:13.648  - debug: host.dev-zigbee-stormbroker Plugin sentry Do not initialize Plugin (enabled=false)
          2025-03-08 21:47:13.700  - info: host.dev-zigbee-stormbroker 3 instances found
          2025-03-08 21:47:13.700  - debug: host.dev-zigbee-stormbroker check instance "system.adapter.admin.0" for host "dev-zigbee-stormbroker"
          2025-03-08 21:47:13.702  - debug: host.dev-zigbee-stormbroker check instance "system.adapter.backitup.0" for host "dev-zigbee-stormbroker"
          2025-03-08 21:47:13.703  - debug: host.dev-zigbee-stormbroker check instance "system.adapter.zigbee.0" for host "dev-zigbee-stormbroker"
          2025-03-08 21:47:13.703  - info: host.dev-zigbee-stormbroker starting 2 instances
          Running inside /opt/iobroker/node_modules/iobroker.zigbee/.dev-server/default
          2025-03-08 21:47:13.768  - debug: host.dev-zigbee-stormbroker added notifications configuration of system.adapter.admin.0
          2025-03-08 21:47:13.768  - debug: host.dev-zigbee-stormbroker startInstance admin.0 loglevel=info, compact=false
          2025-03-08 21:47:13.773  - info: host.dev-zigbee-stormbroker instance system.adapter.admin.0 in version "7.6.1" started with pid 2430157
          2025-03-08 21:47:14.761  - debug: host.dev-zigbee-stormbroker Incoming Host message getRepository
          2025-03-08 21:47:14.764  - info: host.dev-zigbee-stormbroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
          2025-03-08 21:47:14.861  - debug: host.dev-zigbee-stormbroker Incoming Host message getHostInfo
          2025-03-08 21:47:14.985  - debug: host.dev-zigbee-stormbroker Incoming Host message getHostInfo
          2025-03-08 21:47:15.017  - debug: host.dev-zigbee-stormbroker Incoming Host message getRepository
          2025-03-08 21:47:15.017  - debug: host.dev-zigbee-stormbroker Repository update already running, registered instance "system.adapter.admin.0"
          /opt/iobroker/node_modules/iobroker.zigbee> npm run watch:parcel
          sh: 1: parcel: not found
          Options:
              at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/dev-server/dist/index.js:1495:44)
              at ChildProcess.emit (node:events:530:35)
              at ChildProcess._handle.onexit (node:internal/child_process:293:12)
            @mcm1957 sagte in Adapter debugging mit VSCode remote ssh:
            Also wenn du den Adapetr direkt am MAC starten kannst, dann versuch doch noch mal den dev-server und lass uns wissen welche Fehlermeldungen du bekommst...
            bin gerade dabei - nebenbei - discord ist der allgemeine iobroker discord ? da bin ich auch drauf. Telegram hab ich leider keins.
            Wenn ja können wir die Diskussion nach da verlegen :)
            mcm1957M
            mcm1957M
            mcm1957
            @asgothian said in Adapter debugging mit VSCode remote ssh:
            Hmm - ich benutze nur Telegramm. Keine Ahnung was der ganz normale Telegramm Discord ist :-) Ich weiß nur dass Telegramm und Discor gegenseitig via Bot synchronisiert werden :-)
            Genrell sind in Telegramm / Discord mehr Entwickler - insbesondere auch core - unterwegs.
            Support Repositoryverwaltung.
            LESEN - gute Forenbeitrage
            • mcm1957M mcm1957
              mcm1957M
              mcm1957M
              mcm1957
              @mcm1957
              Uff - du hast da ja noch Schikanen drinnen :-)
              Ich glaub mit React verträgt dich der dev-sever nicht. Aber zum ganzen Komplex react build kann fast nur Bluefox was sagen.
              Was ich raten würde (zumidnest mal zum testen)
              -) Adapter bauen (npm run build)
              -) dev-server run
              Damit sollte mal der dev-sver laufen und admin auf Port 80xx erreichbar sein.
              -) Adaptercode in vsCode starten:
              Adapterverzeichnis in vsCode öffnen
              Launch "Launch normal" verwenden.
              Launch.json sieht bei mir so aus:
                  // Verwendet IntelliSense zum Ermitteln möglicher Attribute.
                  // Zeigen Sie auf vorhandene Attribute, um die zugehörigen Beschreibungen anzuzeigen.
                  // Weitere Informationen finden Sie unter https://go.microsoft.com/fwlink/?linkid=830387
                  "version": "0.2.0",
                  "configurations": [
                          "name": "Launch normal",
                          "program": "${workspaceFolder}/build/main.js",
                          "args": ["--instance", "0", "--force", "--logs", "--debug"],
                          "request": "launch",
                          "stopOnEntry": true,
                          "console": "internalConsole",
                          "outputCapture": "std",
                          "skipFiles": [
                              "<node_internals>/**"
                          "type": "node"
                          "name": "Attach by Process ID",
                          "processId": "${command:PickProcess}",
                          "request": "attach",
                          "skipFiles": [
                          "type": "node"
              Program Zeile je nach TS / JS und ggF main,js Namen halt anpassen
              • mcm1957M mcm1957
                @mcm1957
                -) dev-server run
                    "version": "0.2.0",
                    "configurations": [
                            "skipFiles": [
                            "type": "node"
                            "skipFiles": [
                            "type": "node"
                mcm1957M
                mcm1957M
                mcm1957
                Damit wird mal der Bauvorgang rausgehalten und React sollte da mal in Bezug auf Bau keine Probleme bereiten. (Ob npm run build geht ist dann eine Sache unabhängig vom dev-server)
                • mcm1957M mcm1957
                  mcm1957M
                  mcm1957M
                  mcm1957
                  @mcm1957
                  Aber wie schon ticaki geschrieben hat, @Apollon77 entwickelt m.W. nach auch auf einem mac. Und Matter hat da sicher alle möglichen Spezialitäten zu bieten. :-).
                  Du erreichst ihn auch am besten auf Telegramm / Discord (auchunter @Apollon77)
                  • mcm1957M mcm1957
                    @mcm1957
                    AsgothianA
                    AsgothianA
                    Asgothian
                    @mcm1957 Ich hab da mal ein Hallo auf dem Discord rein geschrieben. Kannst du schauen ob das die richtige Stelle ist ?
                    T mcm1957M 2 Antworten Letzte Antwort
                      T
                      T
                      ticaki
                      @asgothian
                      Ja ist der richtige
                      Spenden
                        mcm1957M
                        mcm1957M
                        mcm1957
                        @asgothian
                        Wenn du dort pk.nalon bist dann ists angekommen :-)
                          ich hab bisher die gesamte Adapterentwicklung ohne einen verbundenen Debugger gemacht, da ich den Zigbee-Adapter nicht in einem Container laufen lassen kann (MacOS erlaubt keine USB Port Weiterleitung). Ich hab vor 5 Jahren mal versuche mit dem devcontainer gemacht - ohne das dabei etwas sinnvolles heraus gekommen ist.
                          Bisher bin ich damit auch gut durchgekommen - jetzt hab ich das Problem das ich nach einem Speicherleck im Zigbee Adapter suchen muss. Da würde ich gerne den Debugger nutzen um mir zu bestimmten Zeiten mal anzuschauen was da so an Objekten und Objektgrössen herum liegt.
                          Nur weiss ich nicht wie. Ich hab den ioBroker auf einem Mac laufen, und kann da per remoteSSH oder direkt auf dem System mit VSCode drauf gehen. Nur weiss ich nicht wie ich den Adapter da im Debugger gestartet bekomme. Einen klaren Hinweis dazu hat mir das Netz leider auch nicht gegeben - ich komm Immer wieder auf die gleichen Artikel - docker benutzen, devContainer nutzen. Das klappt mit dem Zigbee-Adapter nicht. Auch der Versuch das ganze mit dem dev-server zu machen hat nicht geklappt - ich habe den Zigbee- Adapter mit dem Dev-Server nicht gestartet bekommen und das dann wieder aufgegeben.
                          Über sachdienliche Hinweise wäre ich dankbar.
                          A.
                          OliverIOO
                          OliverIOO
                          OliverIO
                          @asgothian
                          Rufe ich glaube ich habe es auf Discord schon geschrieben.
                          Das Parcel Zeug muss weg, das sind wahrscheinlich Reste vom dev containe
                          Wenn du für den Adapter keinen Build aus, dann entferne diese Seite aus dem Package.json
                          Läuft den der Adapter generell auf Mac?
                          wenn nicht, wird es auf Mac natürlich schwierig, wenn er nicht an die Hardware rankommt
                          Meine Adapter und Widgets
                          Links im Profil
                          • OliverIOO OliverIO
                            @asgothian
                            AsgothianA
                            AsgothianA
                            Asgothian
                            Allen erst einmal Vielen Dank für die Hilfe. Wir haben die Diskussion auf Discord verlegt. Ist wenn ich das recht verstanden habe einfacher.
                            A.
                            84.0k
