  4. Ikea Dimmer RODRET E2201
    6.3k
70 Beiträge 18 Kommentatoren 20.3k Aufrufe 17 Beobachtet
    @asgothian
    v1.10.3
    Jetzt habe ich mal eine Serie mit reconfigure durchgeführt und auch das device mal stromlos gemacht und wieder mit Strom versorgt.
    Vielleicht kannst du im log eine Ursache erkennen, warum Schaltvorgänge in den Objekten nicht auftauchen.
    zigbee.0	2024-10-24 15:56:09.219	info	-> Configuring 0xd44867fffe1471c5 RODRET Dimmer
    zigbee.0	2024-10-24 15:56:09.223	warn	DeviceConfigure: 0xd44867fffe1471c5 RODRET Dimmer Failed to configure. When device works is all fine when not wake up the device and check again
    zigbee.0	2024-10-24 15:56:36.156	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100MSJ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100MSJ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyUSB0","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"}]
    zigbee.0	2024-10-24 15:56:42.749	info	-> Configuring 0xd44867fffe1471c5 RODRET Dimmer
    zigbee.0	2024-10-24 15:56:42.755	warn	DeviceConfigure: 0xd44867fffe1471c5 RODRET Dimmer Failed to configure. When device works is all fine when not wake up the device and check again
    zigbee.0	2024-10-24 15:57:27.420	info	Device '0xd44867fffe1471c5' announced itself
    zigbee.0	2024-10-24 15:57:28.439	warn	ELEVATED publishToState: message received '{"available":true}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 15:57:28.441	warn	ELEVATED publishToState: value generated 'true' from device d44867fffe1471c5 for 'Available'
    zigbee.0	2024-10-24 15:57:28.442	warn	ELEVATED publishToState: message received '{"linkquality":10}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 15:57:28.443	warn	ELEVATED publishToState: value generated '10' from device d44867fffe1471c5 for 'Link quality'
    zigbee.0	2024-10-24 15:58:06.619	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100MSJ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100MSJ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyUSB0","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"}]
    zigbee.0	2024-10-24 15:58:17.139	info	-> Configuring 0xd44867fffe1471c5 RODRET Dimmer
    zigbee.0	2024-10-24 15:58:17.143	warn	DeviceConfigure: 0xd44867fffe1471c5 RODRET Dimmer Failed to configure. When device works is all fine when not wake up the device and check again
    zigbee.0	2024-10-24 15:58:33.771	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100MSJ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100MSJ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyUSB0","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"}]
    zigbee.0	2024-10-24 15:58:50.792	warn	ELEVATED publishToState: message received '{"linkquality":45}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 15:58:50.793	warn	ELEVATED publishToState: value generated '45' from device d44867fffe1471c5 for 'Link quality'
    zigbee.0	2024-10-24 15:58:51.662	info	-> Configuring 0xd44867fffe1471c5 RODRET Dimmer
    zigbee.0	2024-10-24 15:58:51.664	warn	DeviceConfigure: 0xd44867fffe1471c5 RODRET Dimmer Failed to configure. When device works is all fine when not wake up the device and check again
    zigbee.0	2024-10-24 15:58:53.733	warn	ELEVATED publishToState: message received '{"linkquality":48}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 15:58:53.733	warn	ELEVATED publishToState: value generated '48' from device d44867fffe1471c5 for 'Link quality'
    zigbee.0	2024-10-24 15:58:56.729	warn	ELEVATED publishToState: message received '{"linkquality":45}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 15:58:56.730	warn	ELEVATED publishToState: value generated '45' from device d44867fffe1471c5 for 'Link quality'
    zigbee.0	2024-10-24 15:58:59.723	warn	ELEVATED publishToState: message received '{"linkquality":45}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 15:58:59.724	warn	ELEVATED publishToState: value generated '45' from device d44867fffe1471c5 for 'Link quality'
    zigbee.0	2024-10-24 15:59:02.729	warn	ELEVATED publishToState: message received '{"linkquality":45}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 15:59:02.730	warn	ELEVATED publishToState: value generated '45' from device d44867fffe1471c5 for 'Link quality'
    zigbee.0	2024-10-24 16:04:36.163	info	Device '0xd44867fffe1471c5' announced itself
    zigbee.0	2024-10-24 16:04:37.172	warn	ELEVATED publishToState: message received '{"available":true}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 16:04:37.173	warn	ELEVATED publishToState: value generated 'true' from device d44867fffe1471c5 for 'Available'
    zigbee.0	2024-10-24 16:04:37.173	warn	ELEVATED publishToState: message received '{"linkquality":10}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 16:04:37.173	warn	ELEVATED publishToState: value generated '10' from device d44867fffe1471c5 for 'Link quality'
    zigbee.0	2024-10-24 16:05:13.972	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100MSJ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100MSJ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyUSB0","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"}]
    zigbee.0	2024-10-24 16:07:44.230	warn	ELEVATED publishToState: message received '{"linkquality":45}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 16:07:44.231	warn	ELEVATED publishToState: value generated '45' from device d44867fffe1471c5 for 'Link quality'
    zigbee.0	2024-10-24 16:07:47.211	warn	ELEVATED publishToState: message received '{"linkquality":45}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 16:07:47.211	warn	ELEVATED publishToState: value generated '45' from device d44867fffe1471c5 for 'Link quality'
    zigbee.0	2024-10-24 16:07:50.209	warn	ELEVATED publishToState: message received '{"linkquality":45}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 16:07:50.209	warn	ELEVATED publishToState: value generated '45' from device d44867fffe1471c5 for 'Link quality'
    zigbee.0	2024-10-24 16:07:53.209	warn	ELEVATED publishToState: message received '{"linkquality":45}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 16:07:53.209	warn	ELEVATED publishToState: value generated '45' from device d44867fffe1471c5 for 'Link quality'
    zigbee.0	2024-10-24 16:07:56.197	warn	ELEVATED publishToState: message received '{"linkquality":48}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 16:07:56.197	warn	ELEVATED publishToState: value generated '48' from device d44867fffe1471c5 for 'Link quality'
    zigbee.0	2024-10-24 16:11:21.605	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100MSJ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100MSJ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyUSB0","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"}]
    zigbee.0	2024-10-24 16:11:35.085	info	-> Configuring 0xd44867fffe1471c5 RODRET Dimmer
    zigbee.0	2024-10-24 16:11:35.090	warn	DeviceConfigure: 0xd44867fffe1471c5 RODRET Dimmer Failed to configure. When device works is all fine when not wake up the device and check again
    zigbee.0	2024-10-24 16:11:53.017	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100MSJ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100MSJ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyUSB0","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"}]
    zigbee.0	2024-10-24 16:12:00.253	info	-> Configuring 0xd44867fffe1471c5 RODRET Dimmer
    zigbee.0	2024-10-24 16:12:00.255	warn	DeviceConfigure: 0xd44867fffe1471c5 RODRET Dimmer Failed to configure. When device works is all fine when not wake up the device and check again
    zigbee.0	2024-10-24 16:12:26.452	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100MSJ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100MSJ","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyUSB0","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"}]
    zigbee.0	2024-10-24 16:12:38.301	info	-> Configuring 0xd44867fffe1471c5 RODRET Dimmer
    zigbee.0	2024-10-24 16:12:38.306	warn	DeviceConfigure: 0xd44867fffe1471c5 RODRET Dimmer Failed to configure. When device works is all fine when not wake up the device and check again
    zigbee.0	2024-10-24 16:13:03.836	info	Device '0xd44867fffe1471c5' announced itself
    zigbee.0	2024-10-24 16:13:04.843	warn	ELEVATED publishToState: message received '{"available":true}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 16:13:04.844	warn	ELEVATED publishToState: value generated 'true' from device d44867fffe1471c5 for 'Available'
    zigbee.0	2024-10-24 16:13:04.844	warn	ELEVATED publishToState: message received '{"linkquality":10}' from device d44867fffe1471c5 type 'E2201'
    zigbee.0	2024-10-24 16:13:04.844	warn	ELEVATED publishToState: value generated '10' from device d44867fffe1471c5 for 'Link quality'
    Es wird auch der Ladestand der Batterie nicht aktualisiert (die 100 habe ich manuell reingeschrieben).
    Meister MopperM Online
    Meister Mopper
    Mittlerweile habe ich den Rodret schaltbar integrieren können. Die Lösung habe ich zufällig im Forum gefunden:
    Der Rodret lässt sich mit v1.10.3 zwar integrieren aber nicht schalten.
    • Ich habe kurz die v1.10.2 installiert, den Schalter eingebunden und getestet => funktioniert.
    • Anschließend wieder die stable v1.10.3 installiert => funktioniert auch.
    Proxmox und HA ...
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @meister-mopper sagte in Ikea Dimmer RODRET E2201:
      Das muss mit der Konfiguration des Devices zu tun haben - da gab es mehrere Anpassungen, allerdings kann ich die nicht ohne weiteres verfolgen, da ich keine dieser Devices habe.
      Frage: hat jemand es geschafft den RODRET unter 1.10.13 zu konfigurieren ?
      Ich bräuchte da jemanden der bereit ist das für mich zu testen oder jemanden der mir 2 Geräte zum Testen zur Verfügung stellen kann. Ich schick sie am Ende auch gerne zurück. Leider ist ein Besuch bei Ikea um welche zu bekommen für mich aktuell nicht möglich.
      A.
      Meister MopperM 2 Antworten Letzte Antwort
      • AsgothianA Asgothian
        A.
        Meister Mopper
        @asgothian
        Das teste ich gleich, ich habe noch einen hier rumliegen.
        Proxmox und HA ...
          A.
          Meister Mopper
          schrieb am zuletzt editiert von Meister Mopper
          @asgothian
          v1.10.13
          Einbinden des Schalters funktioniert
          Infos:
          Switch on funktioniert:
          zigbee.0	2024-11-24 17:12:59.467	warn	ELEVATED publishToState: value generated 'true' from device d44867fffe1471c5 for 'on'
          zigbee.0	2024-11-24 17:12:59.467	warn	ELEVATED publishToState: message received '{"action":"on"}' from device d44867fffe1471c5 type 'E2201'
          zigbee.0	2024-11-24 17:12:59.464	debug	Publish {"action":"on"} to "d44867fffe1471c5"
          zigbee.0	2024-11-24 17:12:59.463	warn	ELEVATED publishToState: value generated '45' from device d44867fffe1471c5 for 'Link quality'
          zigbee.0	2024-11-24 17:12:59.462	warn	ELEVATED publishToState: message received '{"linkquality":45}' from device d44867fffe1471c5 type 'E2201'
          zigbee.0	2024-11-24 17:12:59.449	warn	ELEVATED: Zigbee Event of Type commandOn from device "0xd44867fffe1471c5", incoming event: {"type":"commandOn","device":"0xd44867fffe1471c5","endpoint":1,"data":{},"linkquality":45,"groupID":0,"cluster":"genOnOff"}
          switch off funktioniert nicht:
          Edit:
          Komischerweise wurde Minuten später eine switch off reaktion gesendet:
          Seitdem gibt es keine Reaktion mehr nach switch off.
          Proxmox und HA ...
            @asgothian
            v1.10.13
            Infos:
            Edit:
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @meister-mopper Bitte versuch den Schalter per Screenshot 2024-11-24 at 17.26.48.png neu zu konfigurieren und zeig die Meldungen im Log die das bringt.
            Nur das das Gerät auftaucht heisst nicht das die Integration und Konfiguration erfolgreich war.
            A.
            p.s. ich bin im Discord - wenn du zeit hast da noch weiter zu testen. Geht einfacher als über das Forum
            • Meister MopperM Online
              Meister Mopper
              Wir haben das mal durchexerziert.
              Offenbar gibt es Timing-Probleme mit den Rodret E2201. Diese werden üblicherweise direkt mit Lampen gepaired und verhalten sich speziell.
              Es sieht so aus, als ob der batteriebetriebene Schalter zu schnell abschaltet und keine Anfragen vom Adapter empfängt.
              Das führt dazu, dass beim Anlernen das Interview nicht vollständig durchgeführt wird.
              Sobald der Schalter bei den Geräten erscheint, kann man eine Rekonfiguration anschieben, indem man einen Tasterimpuls am Schalter auslöst und anschließend sofort das Symbol anklickt
              und im nächsten Fenster bestätigt.
              Es kann sein, dass dieser Vorgang bis zum Erfolg spielerisch wiederholt werden muss.
              Ergänzung:
              Wer sehen will, ob die Konfiguration erfolgreich war, kann dies über den Debug-Modus des Adapters tun, wird aber ob der Informationsflut im log nicht glücklich.
              Eine bessere Möglichkeit ist ein selektives debug-log nur für das Gerät.
              Hierzu ist die ID des Geräts, z. B. (ist jetzt hier eine andere, exemplarische ID)
              unter Info einzutragen, z. B. (ist jetzt hier auch eine andere, exemplarische ID)
              Ab sofort werden im log die Debug-Werte nur dieses Geräts zusätzlich ausgegeben.
              Proxmox und HA ...
                Ergänzung:
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                Ein Dokument welches beschreibt was für Meldungen kommen und was sie bedeuten ist (aktuell nur auf englisch) hier verfügbar.
                Eine Deutsche Version wird auch noch kommen.
                A.
                • Horst BöttcherH Offline
                  Horst Böttcher
                  wollte mal fragen ob jemand schon eine lösung gefunden hat
                  da bei mir die geräte auf einmal nicht mehr gehen
                  ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
                  • Horst BöttcherH Horst Böttcher
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @horst-böttcher Klar doch. Update auf 2.x (siehe hier)
                    A.
                    Horst BöttcherH 1 Antwort Letzte Antwort
                      A.
                      Horst Böttcher
                      @asgothian nee hat nix gebracht .-(
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @horst-böttcher Hast du die Dimmer erfolgreich über den Adapter neu konfiguriert ?
                          Horst Böttcher
                          @asgothian sagte in Ikea Dimmer RODRET E2201:
                          ja ich hab ihn neu anglernt egal was ich tuh es kommt keine reation auf den bouttons ist komisch denn ich habe andere die gehen noch und ich kann auch was damit schalten :-(
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @horst-böttcher Neu anlernen und Konfigurieren ist deutlich nicht das gleiche. Ist der auf der Info-Kachel als Konfiguriert angezeigt ?
                            A.
                              A.
                              Horst Böttcher
                              @asgothian hab jetzt das ganze system neu aufgesätzt jetzt geht es
                              • J Offline
                                jobe451
                                @asgothian Nö, bringt nix. Ich hab 2.0.2 installiert und versuche es seit einem halben Tag. Hab den Schalter schon zig Mal angelernt, wieder gelöscht und zwischendurch versucht zu rekonfigurieren mit wachhalten und ohne. Ich habe noch 5 Rekonfigurierungsveruche übrig, was auch immer das bedeutet. Wahrscheinlich landen die Schalter aber vorher in der Tonne.
                                • J jobe451
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @jobe451 sagte in Ikea Dimmer RODRET E2201:
                                  Wechsel mal bitte auf die aktuelle Github Version - damit bekommst du eine 2.0.5 RC5 (auch wenn sie als 2.0.4 identifiziert). Es wurde im Bereich des Configure nochmal einiges getan.
                                  Das mit den Rekonfigurierungsversuchen hat mit einer Funktion zu tun die insbesondere dann aktiv ist wenn ein Gerät wegen zeitüberschreitung nicht konfiguriert wird. In diesem Fall wird erneut versucht es zu Konfigurieren wenn es eine Nachricht gesandt hat - dann ist es ja wach.
                                  A
                                  • J Offline
                                    jobe451
                                    Das hat leider nicht geholfen. In der Zwischenzeit scheint 2.0.5 draussen zu sein. Den habe ich installiert und der E2201 wird zwar verbunden, aber Tastenklicks verursachen keine Signale.
                                    Dasselbe Problem habe ich auch mit IKEA E2001/E2002. Ich hatte mir vor einigen Monaten welche gekauft und verbunden und die gehen heute noch. Wenn ich aber neue E2001/E2002 verbinden will, dann habe ich dasselbe Symptom wie mit dem E2201. Beide verhalten sich gleich.
                                    Interessanterweise, während dem Joinen, gibt es ganz viele Nachrichten von den Typen available, link_quality, msg_from_zigbee (commandQueryNextImageRequest). Aber sobald das Device angezeigt wird, geht nichts mehr. So sieht das während dem joinen aus:
                                      Sirnef
                                      hatte auch das Problen, das der Dimmer sich anlernen last, aber dann keine Tasten-Aktion beim ioBroker ankommt.
                                      Ich konnte das folgendemaßen lösen:
                                      1. Im ZigBee Adapter die Kopplung starten
                                      2. Am E2201 Dimmer das Pairung neu starten. Durch 4 mal Drücken der Verbindungstaste. Rote LED blinkt.
                                      3. Den Dimmer wach halten. Durch schnelles (ca alle 0.5 sek) fortlaufendes Drücken einer Funktionstaste, zB "On".
                                      4. Wenn die rote LED ausgeht ist der Dimmer verbunden.
                                      Ich hab so zwei Dimmer bei mir zum Laufen bekommen.
                                      Sirnef
                                      • S Sirnef
                                        Sirnef
                                        Horst Böttcher
                                        @sirnef komisch mal geht es und mal nicht
                                        anlernen kein problem Tastendruck wird trozdem nicht erkannt
                                        ich hab 2 da geht es und 2 da geht es nicht
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          @horst-böttcher sagte in Ikea Dimmer RODRET E2201:
                                          Wie unterscheiden sich die 4 ?
                                          • Firmware ?
                                          • Position ?
                                          • Weitere interna ?
                                          A.
                                          Haifeif 0H 1 Antwort Letzte Antwort
