  4. Node-Red
  5. Simple Steuerung true/false offen/geschlossen
    6.4k
51 Beiträge 3 Kommentatoren 6.4k Aufrufe 3 Beobachtet
  • mickymM mickym
    @aphofis Was verstehst Du nicht?
    Also die iobroker-Out Node schreibt nur eine payload.
    In der iobroker-In Node spezifizierst Du unter welchem Attribut ein Wert eingelesen wird.
    Die Regeln in einer Change Node werden von oben nach unten abgearbeitet.
    AphofisA Offline
    AphofisA Offline
    Aphofis
    schrieb am zuletzt editiert von Aphofis
    @mickym also so korrekt !?
            "id": "989d9879651c9725",
            "type": "ioBroker in",
            "z": "403774f919fb638c",
            "name": "",
            "attrname": "fenster_wz",
            "topic": "alexa2.0.History.answerText",
            "payloadType": "value",
            "onlyack": "",
            "func": "all",
            "gap": "",
            "fireOnStart": "false",
            "outFormat": "MQTT",
            "x": 140,
            "y": 320,
            "wires": [
                    "0a809a663c37b826"
            "id": "583b02925b31d661",
            "type": "debug",
            "name": "Ausgabe",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "true",
            "targetType": "full",
            "statusVal": "",
            "statusType": "auto",
            "x": 580,
            "y": 300,
            "wires": []
            "id": "0a809a663c37b826",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "change",
                    "p": "fenster_wz",
                    "pt": "msg",
                    "from": "Wohnzimmer Fenster,, wurde,, geöffnet",
                    "fromt": "str",
                    "to": "true",
                    "tot": "bool"
                    "t": "change",
                    "p": "fenster_wz",
                    "pt": "msg",
                    "from": "Wohnzimmerfenster wurde geschlossen",
                    "fromt": "str",
                    "to": "false",
                    "tot": "bool"
                    "t": "move",
                    "p": "fenster_wz",
                    "pt": "msg",
                    "to": "payload",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 390,
            "y": 320,
            "wires": [
                    "583b02925b31d661",
                    "30700a1f1af11019"
            "id": "30700a1f1af11019",
            "type": "ioBroker out",
            "name": "Fenster WZ",
            "topic": "0_userdata.0.GordonX-Home.0.fenster-sensor-wz",
            "ack": "false",
            "autoCreate": "false",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 590,
            "y": 340,
            "wires": []
    Ich denke das hab ich jetzt verstanden
    • AphofisA Aphofis
              "name": "",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "x": 140,
              "y": 320,
              "wires": [
                      "0a809a663c37b826"
              "type": "debug",
              "name": "Ausgabe",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "statusVal": "",
              "x": 580,
              "y": 300,
              "wires": []
              "type": "change",
              "name": "",
              "rules": [
                      "t": "change",
                      "p": "fenster_wz",
                      "pt": "msg",
                      "fromt": "str",
                      "to": "true",
                      "tot": "bool"
                      "t": "change",
                      "p": "fenster_wz",
                      "pt": "msg",
                      "fromt": "str",
                      "to": "false",
                      "tot": "bool"
                      "t": "move",
                      "p": "fenster_wz",
                      "pt": "msg",
                      "to": "payload",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 390,
              "y": 320,
              "wires": [
                      "583b02925b31d661",
                      "30700a1f1af11019"
              "ack": "false",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 590,
              "y": 340,
              "wires": []
      mickymM Offline
      mickymM Offline
      mickym
      @aphofis Ja - so würde es funktionieren, wenn Du mit der iobroker In Node es in eine andere Eigenschaft (also fenster_wz) einliest.
      Aber in der Regel wirst Du ja alles bei payload belassen. - Aber es geht ja darum dass Du das Prinzip mit den Nachrichteneigenschaften verstehst.
      AphofisA 1 Antwort Letzte Antwort
      • mickymM mickym
        AphofisA Offline
        AphofisA Offline
        Aphofis
        @mickym genau und das denke ich habe ich verstanden
        • AphofisA Aphofis
          AphofisA Offline
          AphofisA Offline
          Aphofis
          nur was ich noch nicht verstehe, das die anderen sensoren in der node ein anderes attribute haben aber in deren zustand trotzdem innerhalb der node der wert aus alexa2/0/History/answerText eingetragen wird also fenster sensor wz wurde geschlossen zb normal sollen die ja gar nicht darauf reagieren. hmmm
          mickymM AphofisA 2 Antworten Letzte Antwort
          • AphofisA Aphofis
            mickymM Offline
            mickymM Offline
            mickym
            @aphofis sagte in Simple Steuerung true/false offen/geschlossen:
            Und ich habe diesen Satz überhaupt nicht verstanden - vielleicht kannst Du ihn nochmal anders erklären.
            • mickymM mickym
              mickymM Offline
              mickymM Offline
              mickym
              @mickym Was sind denn andere Sensoren in der Node? und wieso haben die ein anderes Attribut?
              • AphofisA Aphofis
                AphofisA Offline
                AphofisA Offline
                Aphofis
                also ich muss mich erstmal abmelden. muss noch duschen !
                habe heute wieder etwas gelernt.
                Muss nur noch paar schaltpläne welzen muss morgen zwei schiebetüren an GLT, EMA und BMA aufschalten und da muss ich mich noch etwas belesen. Ist zwar simpler kram ist aber von den sensor befestigungen von anlagen typ zu anlagen typ unterschiedlich.
                Danke dir schon mal und man könnte ja morgen weiter machen.
                • AphofisA Aphofis
                  AphofisA Offline
                  AphofisA Offline
                  Aphofis
                  das wären die anderen:
                          "id": "55c6088dfea007c5",
                          "type": "tab",
                          "label": "Flow 2",
                          "disabled": false,
                          "info": "",
                          "env": []
                          "id": "044e4776a918b4dd",
                          "z": "55c6088dfea007c5",
                          "name": "",
                          "attrname": "fenster_kueche",
                          "onlyack": "",
                          "func": "all",
                          "gap": "",
                          "x": 260,
                          "y": 180,
                          "wires": [
                                  "918be1111d3e5712"
                          "id": "918be1111d3e5712",
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "change",
                                  "p": "payload",
                                  "pt": "msg",
                                  "from": "fenster küche wurde geöffnet",
                                  "fromt": "str",
                                  "to": "true",
                                  "tot": "bool"
                                  "t": "change",
                                  "p": "payload",
                                  "pt": "msg",
                                  "from": "fenster küche wurde geschlossen",
                                  "fromt": "str",
                                  "to": "false",
                                  "tot": "bool"
                                  "t": "set",
                                  "p": "fenster_kueche",
                                  "pt": "msg",
                                  "to": "payload",
                                  "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 490,
                          "y": 180,
                          "wires": [
                                  "800e97df64d87e25",
                                  "934bab665a1cb42e"
                          "id": "800e97df64d87e25",
                          "name": "Fenster Küche",
                          "topic": "0_userdata.0.GordonX-Home.0.fenster-sensor-küche",
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 720,
                          "y": 180,
                          "wires": []
                          "id": "7796f218ad150460",
                          "name": "",
                          "attrname": "fenster_buero",
                          "onlyack": "",
                          "func": "all",
                          "gap": "",
                          "x": 260,
                          "y": 320,
                          "wires": [
                                  "3ed9453c15ca6be1"
                          "id": "3ed9453c15ca6be1",
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "change",
                                  "p": "fenster_buero",
                                  "pt": "msg",
                                  "from": "büro fenster wurde geöffnet",
                                  "fromt": "str",
                                  "to": "true",
                                  "tot": "bool"
                                  "t": "change",
                                  "pt": "msg",
                                  "from": "fenster sensor büro wurde geschlossen",
                                  "fromt": "str",
                                  "to": "false",
                                  "tot": "bool"
                                  "t": "set",
                                  "pt": "msg",
                                  "to": "payload",
                                  "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 490,
                          "y": 320,
                          "wires": [
                                  "7a9421922bed7d97"
                          "id": "7a9421922bed7d97",
                          "name": "Fenster Büro",
                          "topic": "0_userdata.0.GordonX-Home.0.fenster-sensor-büro",
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 710,
                          "y": 320,
                          "wires": []
                          "id": "8d71936646378267",
                          "name": "",
                          "attrname": "fenster_schlafz",
                          "onlyack": "",
                          "func": "all",
                          "gap": "",
                          "x": 260,
                          "y": 440,
                          "wires": [
                                  "8ba6d78da7dd412a"
                          "id": "8ba6d78da7dd412a",
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "change",
                                  "p": "fenster_schlafz",
                                  "pt": "msg",
                                  "from": "schlafzimmer fenster wurde geöffnet",
                                  "fromt": "str",
                                  "to": "true",
                                  "tot": "bool"
                                  "t": "change",
                                  "pt": "msg",
                                  "from": "schlafzimmer fenster wurde geschlossen",
                                  "fromt": "str",
                                  "to": "false",
                                  "tot": "bool"
                                  "t": "set",
                                  "pt": "msg",
                                  "to": "payload",
                                  "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 490,
                          "y": 440,
                          "wires": [
                                  "2f90d602bda3575e"
                          "id": "2f90d602bda3575e",
                          "name": "Fenster Schlafz",
                          "topic": "0_userdata.0.GordonX-Home.0.fenster-sensor-schlafz",
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 720,
                          "y": 440,
                          "wires": []
                          "id": "0fb2440f5e5b9be9",
                          "name": "",
                          "attrname": "tuer_wz",
                          "onlyack": "",
                          "func": "all",
                          "gap": "",
                          "x": 260,
                          "y": 580,
                          "wires": [
                                  "b563556596e10823"
                          "id": "b563556596e10823",
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "change",
                                  "p": "tuer_wz",
                                  "pt": "msg",
                                  "from": "tür wohnzimmer wurde geöffnet",
                                  "fromt": "str",
                                  "to": "true",
                                  "tot": "bool"
                                  "t": "change",
                                  "p": "tuer_wz",
                                  "pt": "msg",
                                  "from": "tür wohnzimmer wurde geschlossen",
                                  "fromt": "str",
                                  "to": "false",
                                  "tot": "bool"
                                  "t": "set",
                                  "p": "tuer_wz",
                                  "pt": "msg",
                                  "to": "payload",
                                  "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 490,
                          "y": 580,
                          "wires": [
                                  "de842256f488dd2b"
                          "id": "de842256f488dd2b",
                          "name": "Tür WZ",
                          "topic": "0_userdata.0.GordonX-Home.0.tür-sensor-wz",
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 700,
                          "y": 580,
                          "wires": []
                          "id": "934bab665a1cb42e",
                          "type": "debug",
                          "name": "Ausgabe",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "complete": "true",
                          "statusVal": "",
                          "x": 700,
                          "y": 140,
                          "wires": []
                  • AphofisA Aphofis
                            "type": "tab",
                            "label": "Flow 2",
                            "disabled": false,
                            "info": "",
                            "env": []
                            "name": "",
                            "onlyack": "",
                            "func": "all",
                            "gap": "",
                            "x": 260,
                            "y": 180,
                            "wires": [
                                    "918be1111d3e5712"
                            "type": "change",
                            "name": "",
                            "rules": [
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "fromt": "str",
                                    "to": "true",
                                    "tot": "bool"
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "fromt": "str",
                                    "to": "false",
                                    "tot": "bool"
                                    "t": "set",
                                    "pt": "msg",
                                    "to": "payload",
                                    "tot": "msg"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 490,
                            "y": 180,
                            "wires": [
                                    "800e97df64d87e25",
                                    "934bab665a1cb42e"
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 720,
                            "y": 180,
                            "wires": []
                            "name": "",
                            "onlyack": "",
                            "func": "all",
                            "gap": "",
                            "x": 260,
                            "y": 320,
                            "wires": [
                                    "3ed9453c15ca6be1"
                            "type": "change",
                            "name": "",
                            "rules": [
                                    "t": "change",
                                    "pt": "msg",
                                    "fromt": "str",
                                    "to": "true",
                                    "tot": "bool"
                                    "t": "change",
                                    "pt": "msg",
                                    "fromt": "str",
                                    "to": "false",
                                    "tot": "bool"
                                    "t": "set",
                                    "pt": "msg",
                                    "to": "payload",
                                    "tot": "msg"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 490,
                            "y": 320,
                            "wires": [
                                    "7a9421922bed7d97"
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 710,
                            "y": 320,
                            "wires": []
                            "name": "",
                            "onlyack": "",
                            "func": "all",
                            "gap": "",
                            "x": 260,
                            "y": 440,
                            "wires": [
                                    "8ba6d78da7dd412a"
                            "type": "change",
                            "name": "",
                            "rules": [
                                    "t": "change",
                                    "pt": "msg",
                                    "fromt": "str",
                                    "to": "true",
                                    "tot": "bool"
                                    "t": "change",
                                    "pt": "msg",
                                    "fromt": "str",
                                    "to": "false",
                                    "tot": "bool"
                                    "t": "set",
                                    "pt": "msg",
                                    "to": "payload",
                                    "tot": "msg"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 490,
                            "y": 440,
                            "wires": [
                                    "2f90d602bda3575e"
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 720,
                            "y": 440,
                            "wires": []
                            "name": "",
                            "onlyack": "",
                            "func": "all",
                            "gap": "",
                            "x": 260,
                            "y": 580,
                            "wires": [
                                    "b563556596e10823"
                            "type": "change",
                            "name": "",
                            "rules": [
                                    "t": "change",
                                    "p": "tuer_wz",
                                    "pt": "msg",
                                    "fromt": "str",
                                    "to": "true",
                                    "tot": "bool"
                                    "t": "change",
                                    "p": "tuer_wz",
                                    "pt": "msg",
                                    "fromt": "str",
                                    "to": "false",
                                    "tot": "bool"
                                    "t": "set",
                                    "p": "tuer_wz",
                                    "pt": "msg",
                                    "to": "payload",
                                    "tot": "msg"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 490,
                            "y": 580,
                            "wires": [
                                    "de842256f488dd2b"
                            "name": "Tür WZ",
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 700,
                            "y": 580,
                            "wires": []
                            "type": "debug",
                            "name": "Ausgabe",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "complete": "true",
                            "statusVal": "",
                            "x": 700,
                            "y": 140,
                            "wires": []
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @aphofis Du liest 4 mal den gleichen Datenpunkt aus. Das kann man so machen, man kann das aber auch anders machen.
                    • mickymM mickym
                      AphofisA Offline
                      AphofisA Offline
                      Aphofis
                      @mickym
                      Wäre es so möglich !?
                              "id": "403774f919fb638c",
                              "type": "tab",
                              "label": "Fenster & Tür Sensoren",
                              "disabled": false,
                              "info": "",
                              "env": []
                              "type": "debug",
                              "name": "Ausgabe Fenster Wz",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "complete": "true",
                              "statusVal": "",
                              "x": 740,
                              "y": 320,
                              "wires": []
                              "type": "change",
                              "name": "",
                              "rules": [
                                      "t": "change",
                                      "p": "fenster_wz",
                                      "pt": "msg",
                                      "fromt": "str",
                                      "to": "true",
                                      "tot": "bool"
                                      "t": "change",
                                      "p": "fenster_wz",
                                      "pt": "msg",
                                      "fromt": "str",
                                      "to": "false",
                                      "tot": "bool"
                                      "t": "move",
                                      "p": "fenster_wz",
                                      "pt": "msg",
                                      "to": "payload",
                                      "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 490,
                              "y": 340,
                              "wires": [
                                      "583b02925b31d661",
                                      "30700a1f1af11019"
                              "ack": "false",
                              "stateName": "",
                              "role": "",
                              "payloadType": "",
                              "readonly": "",
                              "stateUnit": "",
                              "stateMin": "",
                              "stateMax": "",
                              "x": 710,
                              "y": 360,
                              "wires": []
                              "id": "a04e704da4f58ac3",
                              "name": "",
                              "onlyack": "",
                              "func": "all",
                              "gap": "",
                              "x": 180,
                              "y": 540,
                              "wires": [
                                      "b13c2d067e849deb",
                                      "dc5cf4f07eb8edc9",
                                      "0de159c4387539cc",
                                      "c8e42d6ae7a6a496",
                                      "0a809a663c37b826"
                              "id": "b13c2d067e849deb",
                              "type": "change",
                              "name": "",
                              "rules": [
                                      "t": "change",
                                      "p": "payload",
                                      "pt": "msg",
                                      "fromt": "str",
                                      "to": "true",
                                      "tot": "bool"
                                      "t": "change",
                                      "p": "payload",
                                      "pt": "msg",
                                      "fromt": "str",
                                      "to": "false",
                                      "tot": "bool"
                                      "t": "set",
                                      "pt": "msg",
                                      "to": "payload",
                                      "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 490,
                              "y": 460,
                              "wires": [
                                      "a7aa1fb5298bd29c",
                                      "55130b9c537c5f05"
                              "id": "a7aa1fb5298bd29c",
                              "ack": "false",
                              "stateName": "",
                              "role": "",
                              "payloadType": "",
                              "readonly": "",
                              "stateUnit": "",
                              "stateMin": "",
                              "stateMax": "",
                              "x": 720,
                              "y": 480,
                              "wires": []
                              "id": "dc5cf4f07eb8edc9",
                              "type": "change",
                              "name": "",
                              "rules": [
                                      "t": "change",
                                      "pt": "msg",
                                      "fromt": "str",
                                      "to": "true",
                                      "tot": "bool"
                                      "t": "change",
                                      "pt": "msg",
                                      "fromt": "str",
                                      "to": "false",
                                      "tot": "bool"
                                      "t": "set",
                                      "pt": "msg",
                                      "to": "payload",
                                      "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 490,
                              "y": 540,
                              "wires": [
                                      "ea407daf57ae3231",
                                      "ba9eec8450b3fd98"
                              "id": "ea407daf57ae3231",
                              "ack": "false",
                              "stateName": "",
                              "role": "",
                              "payloadType": "",
                              "readonly": "",
                              "stateUnit": "",
                              "stateMin": "",
                              "stateMax": "",
                              "x": 710,
                              "y": 580,
                              "wires": []
                              "id": "0de159c4387539cc",
                              "type": "change",
                              "name": "",
                              "rules": [
                                      "t": "change",
                                      "pt": "msg",
                                      "fromt": "str",
                                      "to": "true",
                                      "tot": "bool"
                                      "t": "change",
                                      "pt": "msg",
                                      "fromt": "str",
                                      "to": "false",
                                      "tot": "bool"
                                      "t": "set",
                                      "pt": "msg",
                                      "to": "payload",
                                      "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 490,
                              "y": 660,
                              "wires": [
                                      "0ba5165605c97935",
                                      "bdf36b2de16500eb"
                              "id": "0ba5165605c97935",
                              "ack": "false",
                              "stateName": "",
                              "role": "",
                              "payloadType": "",
                              "readonly": "",
                              "stateUnit": "",
                              "stateMin": "",
                              "stateMax": "",
                              "x": 720,
                              "y": 680,
                              "wires": []
                              "id": "c8e42d6ae7a6a496",
                              "type": "change",
                              "name": "",
                              "rules": [
                                      "t": "change",
                                      "p": "tuer_wz",
                                      "pt": "msg",
                                      "fromt": "str",
                                      "to": "true",
                                      "tot": "bool"
                                      "t": "change",
                                      "p": "tuer_wz",
                                      "pt": "msg",
                                      "fromt": "str",
                                      "to": "false",
                                      "tot": "bool"
                                      "t": "set",
                                      "p": "tuer_wz",
                                      "pt": "msg",
                                      "to": "payload",
                                      "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 490,
                              "y": 780,
                              "wires": [
                                      "7b6776a1a67d1974",
                                      "98a8e0b1bf54230d"
                              "id": "7b6776a1a67d1974",
                              "name": "Tür WZ",
                              "ack": "false",
                              "stateName": "",
                              "role": "",
                              "payloadType": "",
                              "readonly": "",
                              "stateUnit": "",
                              "stateMin": "",
                              "stateMax": "",
                              "x": 700,
                              "y": 780,
                              "wires": []
                              "id": "55130b9c537c5f05",
                              "type": "debug",
                              "name": "Ausgabe Fenster Küche",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "complete": "true",
                              "statusVal": "",
                              "x": 750,
                              "y": 440,
                              "wires": []
                              "id": "ba9eec8450b3fd98",
                              "type": "debug",
                              "name": "Ausgabe Fenster Büro",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "complete": "true",
                              "statusVal": "",
                              "x": 740,
                              "y": 540,
                              "wires": []
                              "id": "bdf36b2de16500eb",
                              "type": "debug",
                              "name": "Ausgabe Fenster Schlafz.",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "complete": "true",
                              "statusVal": "",
                              "x": 750,
                              "y": 640,
                              "wires": []
                              "id": "98a8e0b1bf54230d",
                              "type": "debug",
                              "name": "Ausgabe Tür Wz",
                              "active": true,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "complete": "true",
                              "statusVal": "",
                              "x": 730,
                              "y": 740,
                              "wires": []
                      • AphofisA Aphofis
                        @mickym
                                "type": "tab",
                                "disabled": false,
                                "info": "",
                                "env": []
                                "type": "debug",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "complete": "true",
                                "statusVal": "",
                                "x": 740,
                                "y": 320,
                                "wires": []
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "change",
                                        "p": "fenster_wz",
                                        "pt": "msg",
                                        "fromt": "str",
                                        "to": "true",
                                        "tot": "bool"
                                        "t": "change",
                                        "p": "fenster_wz",
                                        "pt": "msg",
                                        "fromt": "str",
                                        "to": "false",
                                        "tot": "bool"
                                        "t": "move",
                                        "p": "fenster_wz",
                                        "pt": "msg",
                                        "to": "payload",
                                        "tot": "msg"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 490,
                                "y": 340,
                                "wires": [
                                        "583b02925b31d661",
                                        "30700a1f1af11019"
                                "ack": "false",
                                "stateName": "",
                                "role": "",
                                "payloadType": "",
                                "readonly": "",
                                "stateUnit": "",
                                "stateMin": "",
                                "stateMax": "",
                                "x": 710,
                                "y": 360,
                                "wires": []
                                "name": "",
                                "onlyack": "",
                                "func": "all",
                                "gap": "",
                                "x": 180,
                                "y": 540,
                                "wires": [
                                        "b13c2d067e849deb",
                                        "dc5cf4f07eb8edc9",
                                        "0de159c4387539cc",
                                        "c8e42d6ae7a6a496",
                                        "0a809a663c37b826"
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "change",
                                        "p": "payload",
                                        "pt": "msg",
                                        "fromt": "str",
                                        "to": "true",
                                        "tot": "bool"
                                        "t": "change",
                                        "p": "payload",
                                        "pt": "msg",
                                        "fromt": "str",
                                        "to": "false",
                                        "tot": "bool"
                                        "t": "set",
                                        "pt": "msg",
                                        "to": "payload",
                                        "tot": "msg"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 490,
                                "y": 460,
                                "wires": [
                                        "a7aa1fb5298bd29c",
                                        "55130b9c537c5f05"
                                "ack": "false",
                                "stateName": "",
                                "role": "",
                                "payloadType": "",
                                "readonly": "",
                                "stateUnit": "",
                                "stateMin": "",
                                "stateMax": "",
                                "x": 720,
                                "y": 480,
                                "wires": []
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "change",
                                        "pt": "msg",
                                        "fromt": "str",
                                        "to": "true",
                                        "tot": "bool"
                                        "t": "change",
                                        "pt": "msg",
                                        "fromt": "str",
                                        "to": "false",
                                        "tot": "bool"
                                        "t": "set",
                                        "pt": "msg",
                                        "to": "payload",
                                        "tot": "msg"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 490,
                                "y": 540,
                                "wires": [
                                        "ea407daf57ae3231",
                                        "ba9eec8450b3fd98"
                                "ack": "false",
                                "stateName": "",
                                "role": "",
                                "payloadType": "",
                                "readonly": "",
                                "stateUnit": "",
                                "stateMin": "",
                                "stateMax": "",
                                "x": 710,
                                "y": 580,
                                "wires": []
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "change",
                                        "pt": "msg",
                                        "fromt": "str",
                                        "to": "true",
                                        "tot": "bool"
                                        "t": "change",
                                        "pt": "msg",
                                        "fromt": "str",
                                        "to": "false",
                                        "tot": "bool"
                                        "t": "set",
                                        "pt": "msg",
                                        "to": "payload",
                                        "tot": "msg"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 490,
                                "y": 660,
                                "wires": [
                                        "0ba5165605c97935",
                                        "bdf36b2de16500eb"
                                "ack": "false",
                                "stateName": "",
                                "role": "",
                                "payloadType": "",
                                "readonly": "",
                                "stateUnit": "",
                                "stateMin": "",
                                "stateMax": "",
                                "x": 720,
                                "y": 680,
                                "wires": []
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "change",
                                        "p": "tuer_wz",
                                        "pt": "msg",
                                        "fromt": "str",
                                        "to": "true",
                                        "tot": "bool"
                                        "t": "change",
                                        "p": "tuer_wz",
                                        "pt": "msg",
                                        "fromt": "str",
                                        "to": "false",
                                        "tot": "bool"
                                        "t": "set",
                                        "p": "tuer_wz",
                                        "pt": "msg",
                                        "to": "payload",
                                        "tot": "msg"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 490,
                                "y": 780,
                                "wires": [
                                        "7b6776a1a67d1974",
                                        "98a8e0b1bf54230d"
                                "name": "Tür WZ",
                                "ack": "false",
                                "stateName": "",
                                "role": "",
                                "payloadType": "",
                                "readonly": "",
                                "stateUnit": "",
                                "stateMin": "",
                                "stateMax": "",
                                "x": 700,
                                "y": 780,
                                "wires": []
                                "type": "debug",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "complete": "true",
                                "statusVal": "",
                                "x": 750,
                                "y": 440,
                                "wires": []
                                "type": "debug",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "complete": "true",
                                "statusVal": "",
                                "x": 740,
                                "y": 540,
                                "wires": []
                                "type": "debug",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "complete": "true",
                                "statusVal": "",
                                "x": 750,
                                "y": 640,
                                "wires": []
                                "type": "debug",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "complete": "true",
                                "statusVal": "",
                                "x": 730,
                                "y": 740,
                                "wires": []
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @aphofis Im Prinzip schon - aber so halt nicht - schau halt mal in welches Attribut Du den Wert ausliest.
                        Wenn Du das nicht beantworten kannst, dann lass Dir halt wieder das ganze Nachrichtenpbjekt ausgeben.
                        Geh halt Schritt für Schritt vor.
                        Also in welches Attribut liest Du den Wert ein?
                        Außerdem verwirrst Du ja Dein Ziel schau halt was in den Debug Nodes rauskommt.
                        • AphofisA Offline
                          AphofisA Offline
                          Aphofis
                          @mickym Achso Attribute ist ja nur fenster_kueche ne das ja etwas zu wenig.
                          wie mache ich das denn das alle attribute gelesen und weiter gegeben werden
                          Kann man das so machen !? fehlt aber anscheinend etwas attribute wird irgendwo nicht weiter verarbeitet.
                                  "type": "debug",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "complete": "true",
                                  "statusVal": "",
                                  "x": 1120,
                                  "y": 300,
                                  "wires": []
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "change",
                                          "p": "fenster_wz",
                                          "pt": "msg",
                                          "fromt": "str",
                                          "to": "true",
                                          "tot": "bool"
                                          "t": "change",
                                          "p": "fenster_wz",
                                          "pt": "msg",
                                          "fromt": "str",
                                          "to": "false",
                                          "tot": "bool"
                                          "t": "move",
                                          "p": "fenster_wz",
                                          "pt": "msg",
                                          "to": "payload",
                                          "tot": "msg"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 870,
                                  "y": 320,
                                  "wires": [
                                          "583b02925b31d661",
                                          "30700a1f1af11019"
                                  "ack": "false",
                                  "stateName": "",
                                  "role": "",
                                  "payloadType": "",
                                  "readonly": "",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1090,
                                  "y": 340,
                                  "wires": []
                                  "name": "",
                                  "attrname": "payload",
                                  "onlyack": "",
                                  "func": "all",
                                  "gap": "",
                                  "x": 240,
                                  "y": 540,
                                  "wires": [
                                          "45dc365807d87963"
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "change",
                                          "pt": "msg",
                                          "fromt": "str",
                                          "to": "true",
                                          "tot": "bool"
                                          "t": "change",
                                          "pt": "msg",
                                          "fromt": "str",
                                          "to": "false",
                                          "tot": "bool"
                                          "t": "move",
                                          "pt": "msg",
                                          "to": "payload",
                                          "tot": "msg"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 870,
                                  "y": 420,
                                  "wires": [
                                          "a7aa1fb5298bd29c",
                                          "55130b9c537c5f05"
                                  "ack": "false",
                                  "stateName": "",
                                  "role": "",
                                  "payloadType": "",
                                  "readonly": "",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1100,
                                  "y": 440,
                                  "wires": []
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "change",
                                          "pt": "msg",
                                          "fromt": "str",
                                          "to": "true",
                                          "tot": "bool"
                                          "t": "change",
                                          "pt": "msg",
                                          "fromt": "str",
                                          "to": "false",
                                          "tot": "bool"
                                          "t": "move",
                                          "pt": "msg",
                                          "to": "payload",
                                          "tot": "msg"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 870,
                                  "y": 500,
                                  "wires": [
                                          "ea407daf57ae3231",
                                          "ba9eec8450b3fd98"
                                  "ack": "false",
                                  "stateName": "",
                                  "role": "",
                                  "payloadType": "",
                                  "readonly": "",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1090,
                                  "y": 540,
                                  "wires": []
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "change",
                                          "pt": "msg",
                                          "fromt": "str",
                                          "to": "true",
                                          "tot": "bool"
                                          "t": "change",
                                          "pt": "msg",
                                          "fromt": "str",
                                          "to": "false",
                                          "tot": "bool"
                                          "t": "move",
                                          "pt": "msg",
                                          "to": "payload",
                                          "tot": "msg"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 870,
                                  "y": 620,
                                  "wires": [
                                          "0ba5165605c97935",
                                          "bdf36b2de16500eb"
                                  "ack": "false",
                                  "stateName": "",
                                  "role": "",
                                  "payloadType": "",
                                  "readonly": "",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1100,
                                  "y": 640,
                                  "wires": []
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "change",
                                          "p": "tuer_wz",
                                          "pt": "msg",
                                          "fromt": "str",
                                          "to": "true",
                                          "tot": "bool"
                                          "t": "change",
                                          "p": "tuer_wz",
                                          "pt": "msg",
                                          "fromt": "str",
                                          "to": "false",
                                          "tot": "bool"
                                          "t": "move",
                                          "p": "tuer_wz",
                                          "pt": "msg",
                                          "to": "payload",
                                          "tot": "msg"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 870,
                                  "y": 740,
                                  "wires": [
                                          "7b6776a1a67d1974",
                                          "98a8e0b1bf54230d"
                                  "name": "Tür WZ",
                                  "ack": "false",
                                  "stateName": "",
                                  "role": "",
                                  "payloadType": "",
                                  "readonly": "",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1080,
                                  "y": 740,
                                  "wires": []
                                  "type": "debug",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "complete": "true",
                                  "statusVal": "",
                                  "x": 1130,
                                  "y": 400,
                                  "wires": []
                                  "type": "debug",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "complete": "true",
                                  "statusVal": "",
                                  "x": 1120,
                                  "y": 500,
                                  "wires": []
                                  "type": "debug",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "complete": "true",
                                  "statusVal": "",
                                  "x": 1130,
                                  "y": 600,
                                  "wires": []
                                  "type": "debug",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "complete": "true",
                                  "statusVal": "",
                                  "x": 1110,
                                  "y": 700,
                                  "wires": []
                                  "id": "45dc365807d87963",
                                  "type": "switch",
                                  "name": "",
                                  "property": "payload",
                                  "propertyType": "msg",
                                  "rules": [
                                          "t": "eq",
                                          "v": "fenster_wz",
                                          "vt": "str"
                                          "t": "eq",
                                          "v": "fenster_kueche",
                                          "vt": "str"
                                          "t": "eq",
                                          "v": "fenster_buero",
                                          "vt": "str"
                                          "t": "eq",
                                          "v": "fenster_schlafz",
                                          "vt": "str"
                                          "t": "eq",
                                          "v": "tuer_wz",
                                          "vt": "str"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 5,
                                  "x": 490,
                                  "y": 540,
                                  "wires": [
                                          "0a809a663c37b826"
                                          "b13c2d067e849deb"
                                          "dc5cf4f07eb8edc9"
                                          "0de159c4387539cc"
                                          "c8e42d6ae7a6a496"
                          • AphofisA Aphofis
                                    "type": "debug",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "complete": "true",
                                    "statusVal": "",
                                    "x": 1120,
                                    "y": 300,
                                    "wires": []
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "change",
                                            "p": "fenster_wz",
                                            "pt": "msg",
                                            "fromt": "str",
                                            "to": "true",
                                            "tot": "bool"
                                            "t": "change",
                                            "p": "fenster_wz",
                                            "pt": "msg",
                                            "fromt": "str",
                                            "to": "false",
                                            "tot": "bool"
                                            "t": "move",
                                            "p": "fenster_wz",
                                            "pt": "msg",
                                            "to": "payload",
                                            "tot": "msg"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 870,
                                    "y": 320,
                                    "wires": [
                                            "583b02925b31d661",
                                            "30700a1f1af11019"
                                    "ack": "false",
                                    "stateName": "",
                                    "role": "",
                                    "payloadType": "",
                                    "readonly": "",
                                    "stateUnit": "",
                                    "stateMin": "",
                                    "stateMax": "",
                                    "x": 1090,
                                    "y": 340,
                                    "wires": []
                                    "name": "",
                                    "onlyack": "",
                                    "func": "all",
                                    "gap": "",
                                    "x": 240,
                                    "y": 540,
                                    "wires": [
                                            "45dc365807d87963"
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "change",
                                            "pt": "msg",
                                            "fromt": "str",
                                            "to": "true",
                                            "tot": "bool"
                                            "t": "change",
                                            "pt": "msg",
                                            "fromt": "str",
                                            "to": "false",
                                            "tot": "bool"
                                            "t": "move",
                                            "pt": "msg",
                                            "to": "payload",
                                            "tot": "msg"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 870,
                                    "y": 420,
                                    "wires": [
                                            "a7aa1fb5298bd29c",
                                            "55130b9c537c5f05"
                                    "ack": "false",
                                    "stateName": "",
                                    "role": "",
                                    "payloadType": "",
                                    "readonly": "",
                                    "stateUnit": "",
                                    "stateMin": "",
                                    "stateMax": "",
                                    "x": 1100,
                                    "y": 440,
                                    "wires": []
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "change",
                                            "pt": "msg",
                                            "fromt": "str",
                                            "to": "true",
                                            "tot": "bool"
                                            "t": "change",
                                            "pt": "msg",
                                            "fromt": "str",
                                            "to": "false",
                                            "tot": "bool"
                                            "t": "move",
                                            "pt": "msg",
                                            "to": "payload",
                                            "tot": "msg"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 870,
                                    "y": 500,
                                    "wires": [
                                            "ea407daf57ae3231",
                                            "ba9eec8450b3fd98"
                                    "ack": "false",
                                    "stateName": "",
                                    "role": "",
                                    "payloadType": "",
                                    "readonly": "",
                                    "stateUnit": "",
                                    "stateMin": "",
                                    "stateMax": "",
                                    "x": 1090,
                                    "y": 540,
                                    "wires": []
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "change",
                                            "pt": "msg",
                                            "fromt": "str",
                                            "to": "true",
                                            "tot": "bool"
                                            "t": "change",
                                            "pt": "msg",
                                            "fromt": "str",
                                            "to": "false",
                                            "tot": "bool"
                                            "t": "move",
                                            "pt": "msg",
                                            "to": "payload",
                                            "tot": "msg"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 870,
                                    "y": 620,
                                    "wires": [
                                            "0ba5165605c97935",
                                            "bdf36b2de16500eb"
                                    "ack": "false",
                                    "stateName": "",
                                    "role": "",
                                    "payloadType": "",
                                    "readonly": "",
                                    "stateUnit": "",
                                    "stateMin": "",
                                    "stateMax": "",
                                    "x": 1100,
                                    "y": 640,
                                    "wires": []
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "change",
                                            "p": "tuer_wz",
                                            "pt": "msg",
                                            "fromt": "str",
                                            "to": "true",
                                            "tot": "bool"
                                            "t": "change",
                                            "p": "tuer_wz",
                                            "pt": "msg",
                                            "fromt": "str",
                                            "to": "false",
                                            "tot": "bool"
                                            "t": "move",
                                            "p": "tuer_wz",
                                            "pt": "msg",
                                            "to": "payload",
                                            "tot": "msg"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 870,
                                    "y": 740,
                                    "wires": [
                                            "7b6776a1a67d1974",
                                            "98a8e0b1bf54230d"
                                    "name": "Tür WZ",
                                    "ack": "false",
                                    "stateName": "",
                                    "role": "",
                                    "payloadType": "",
                                    "readonly": "",
                                    "stateUnit": "",
                                    "stateMin": "",
                                    "stateMax": "",
                                    "x": 1080,
                                    "y": 740,
                                    "wires": []
                                    "type": "debug",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "complete": "true",
                                    "statusVal": "",
                                    "x": 1130,
                                    "y": 400,
                                    "wires": []
                                    "type": "debug",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "complete": "true",
                                    "statusVal": "",
                                    "x": 1120,
                                    "y": 500,
                                    "wires": []
                                    "type": "debug",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "complete": "true",
                                    "statusVal": "",
                                    "x": 1130,
                                    "y": 600,
                                    "wires": []
                                    "type": "debug",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "complete": "true",
                                    "statusVal": "",
                                    "x": 1110,
                                    "y": 700,
                                    "wires": []
                                    "type": "switch",
                                    "name": "",
                                    "rules": [
                                            "t": "eq",
                                            "v": "fenster_wz",
                                            "vt": "str"
                                            "t": "eq",
                                            "vt": "str"
                                            "t": "eq",
                                            "vt": "str"
                                            "t": "eq",
                                            "vt": "str"
                                            "t": "eq",
                                            "v": "tuer_wz",
                                            "vt": "str"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 5,
                                    "x": 490,
                                    "y": 540,
                                    "wires": [
                                            "0a809a663c37b826"
                                            "b13c2d067e849deb"
                                            "dc5cf4f07eb8edc9"
                                            "0de159c4387539cc"
                                            "c8e42d6ae7a6a496"
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @aphofis Wenn Du alles bei payload belassen hättest, dann hättest Du doch vorerst kein Problem - allerdings schau Dir halt mal an, was in den Debugnodes rauskommt - ich glaube nicht, dass da nur true/false rauskommt.
                            • mickymM mickym
                              AphofisA Offline
                              AphofisA Offline
                              Aphofis
                              @mickym Irgendwie klappt das nicht!
                              alle geräte sollen ja nur true/false melden und nicht alle auf alles reagieren und Fenster Bad ist ein Sonoff Gerät das muss auf 0/1 reagieren
                                      "type": "tab",
                                      "disabled": false,
                                      "info": "",
                                      "env": []
                                      "type": "debug",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "complete": "true",
                                      "statusVal": "",
                                      "x": 820,
                                      "y": 200,
                                      "wires": []
                                      "type": "change",
                                      "name": "",
                                      "rules": [
                                              "t": "change",
                                              "p": "fenster_wz",
                                              "pt": "msg",
                                              "fromt": "str",
                                              "to": "true",
                                              "tot": "bool"
                                              "t": "change",
                                              "p": "fenster_wz",
                                              "pt": "msg",
                                              "fromt": "str",
                                              "to": "false",
                                              "tot": "bool"
                                              "t": "move",
                                              "p": "fenster_wz",
                                              "pt": "msg",
                                              "to": "payload",
                                              "tot": "msg"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 570,
                                      "y": 220,
                                      "wires": [
                                              "583b02925b31d661",
                                              "30700a1f1af11019"
                                      "ack": "false",
                                      "stateName": "",
                                      "role": "",
                                      "payloadType": "",
                                      "readonly": "",
                                      "stateUnit": "",
                                      "stateMin": "",
                                      "stateMax": "",
                                      "x": 790,
                                      "y": 240,
                                      "wires": []
                                      "name": "",
                                      "onlyack": "",
                                      "func": "all",
                                      "gap": "",
                                      "x": 200,
                                      "y": 440,
                                      "wires": [
                                              "e14f45b233f41bf6",
                                              "0a809a663c37b826",
                                              "b13c2d067e849deb",
                                              "dc5cf4f07eb8edc9",
                                              "0de159c4387539cc",
                                              "c8e42d6ae7a6a496",
                                              "5c4c4ecbf153b3de"
                                      "type": "change",
                                      "name": "",
                                      "rules": [
                                              "t": "change",
                                              "pt": "msg",
                                              "fromt": "str",
                                              "to": "true",
                                              "tot": "bool"
                                              "t": "change",
                                              "pt": "msg",
                                              "fromt": "str",
                                              "to": "false",
                                              "tot": "bool"
                                              "t": "move",
                                              "pt": "msg",
                                              "to": "payload",
                                              "tot": "msg"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 570,
                                      "y": 340,
                                      "wires": [
                                              "a7aa1fb5298bd29c",
                                              "55130b9c537c5f05"
                                      "ack": "false",
                                      "stateName": "",
                                      "role": "",
                                      "payloadType": "",
                                      "readonly": "",
                                      "stateUnit": "",
                                      "stateMin": "",
                                      "stateMax": "",
                                      "x": 800,
                                      "y": 340,
                                      "wires": []
                                      "type": "change",
                                      "name": "",
                                      "rules": [
                                              "t": "change",
                                              "pt": "msg",
                                              "fromt": "str",
                                              "to": "true",
                                              "tot": "bool"
                                              "t": "change",
                                              "pt": "msg",
                                              "fromt": "str",
                                              "to": "false",
                                              "tot": "bool"
                                              "t": "move",
                                              "pt": "msg",
                                              "to": "payload",
                                              "tot": "msg"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 570,
                                      "y": 400,
                                      "wires": [
                                              "ea407daf57ae3231",
                                              "ba9eec8450b3fd98"
                                      "ack": "false",
                                      "stateName": "",
                                      "role": "",
                                      "payloadType": "",
                                      "readonly": "",
                                      "stateUnit": "",
                                      "stateMin": "",
                                      "stateMax": "",
                                      "x": 790,
                                      "y": 440,
                                      "wires": []
                                      "type": "change",
                                      "name": "",
                                      "rules": [
                                              "t": "change",
                                              "pt": "msg",
                                              "fromt": "str",
                                              "to": "true",
                                              "tot": "bool"
                                              "t": "change",
                                              "pt": "msg",
                                              "fromt": "str",
                                              "to": "false",
                                              "tot": "bool"
                                              "t": "move",
                                              "pt": "msg",
                                              "to": "payload",
                                              "tot": "msg"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 570,
                                      "y": 520,
                                      "wires": [
                                              "0ba5165605c97935",
                                              "bdf36b2de16500eb"
                                      "ack": "false",
                                      "stateName": "",
                                      "role": "",
                                      "payloadType": "",
                                      "readonly": "",
                                      "stateUnit": "",
                                      "stateMin": "",
                                      "stateMax": "",
                                      "x": 800,
                                      "y": 540,
                                      "wires": []
                                      "type": "change",
                                      "name": "",
                                      "rules": [
                                              "t": "change",
                                              "p": "tuer_wz",
                                              "pt": "msg",
                                              "fromt": "str",
                                              "to": "true",
                                              "tot": "bool"
                                              "t": "change",
                                              "p": "tuer_wz",
                                              "pt": "msg",
                                              "fromt": "str",
                                              "to": "false",
                                              "tot": "bool"
                                              "t": "move",
                                              "p": "tuer_wz",
                                              "pt": "msg",
                                              "to": "payload",
                                              "tot": "msg"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 570,
                                      "y": 640,
                                      "wires": [
                                              "7b6776a1a67d1974",
                                              "98a8e0b1bf54230d"
                                      "name": "Tür WZ",
                                      "ack": "false",
                                      "stateName": "",
                                      "role": "",
                                      "payloadType": "",
                                      "readonly": "",
                                      "stateUnit": "",
                                      "stateMin": "",
                                      "stateMax": "",
                                      "x": 780,
                                      "y": 640,
                                      "wires": []
                                      "type": "debug",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "complete": "true",
                                      "statusVal": "",
                                      "x": 830,
                                      "y": 300,
                                      "wires": []
                                      "type": "debug",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "complete": "true",
                                      "statusVal": "",
                                      "x": 820,
                                      "y": 400,
                                      "wires": []
                                      "type": "debug",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "complete": "true",
                                      "statusVal": "",
                                      "x": 830,
                                      "y": 500,
                                      "wires": []
                                      "type": "debug",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "complete": "true",
                                      "statusVal": "",
                                      "x": 810,
                                      "y": 600,
                                      "wires": []
                                      "id": "5c4c4ecbf153b3de",
                                      "type": "change",
                                      "name": "",
                                      "rules": [
                                              "t": "change",
                                              "p": "fenster_bad",
                                              "pt": "msg",
                                              "from": "fenster Bad wurde geöffnet",
                                              "fromt": "str",
                                              "to": "1",
                                              "tot": "str"
                                              "t": "change",
                                              "p": "fenster_bad",
                                              "pt": "msg",
                                              "from": "fenster Bad wurde geschlossen",
                                              "fromt": "str",
                                              "to": "0",
                                              "tot": "str"
                                              "t": "move",
                                              "p": "fenster_bad",
                                              "pt": "msg",
                                              "to": "payload",
                                              "tot": "msg"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 570,
                                      "y": 720,
                                      "wires": [
                                              "f94f4d4e2195fd4e",
                                              "5f208caa0596d609"
                                      "id": "f94f4d4e2195fd4e",
                                      "name": "Fenster Bad",
                                      "topic": "ham.0.Fenster-Bad.Contact-Sensor.Contact-Sensor-State",
                                      "ack": "false",
                                      "stateName": "",
                                      "role": "",
                                      "payloadType": "",
                                      "readonly": "",
                                      "stateUnit": "",
                                      "stateMin": "",
                                      "stateMax": "",
                                      "x": 790,
                                      "y": 740,
                                      "wires": []
                                      "id": "5f208caa0596d609",
                                      "type": "debug",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "complete": "true",
                                      "statusVal": "",
                                      "x": 810,
                                      "y": 700,
                                      "wires": []
                                      "id": "e14f45b233f41bf6",
                                      "type": "debug",
                                      "name": "debug 4",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "complete": "false",
                                      "statusVal": "",
                                      "x": 540,
                                      "y": 160,
                                      "wires": []
                              • AphofisA Aphofis
                                        "type": "tab",
                                        "disabled": false,
                                        "info": "",
                                        "env": []
                                        "type": "debug",
                                        "active": true,
                                        "tosidebar": true,
                                        "console": false,
                                        "tostatus": false,
                                        "complete": "true",
                                        "statusVal": "",
                                        "x": 820,
                                        "y": 200,
                                        "wires": []
                                        "type": "change",
                                        "name": "",
                                        "rules": [
                                                "t": "change",
                                                "p": "fenster_wz",
                                                "pt": "msg",
                                                "fromt": "str",
                                                "to": "true",
                                                "tot": "bool"
                                                "t": "change",
                                                "p": "fenster_wz",
                                                "pt": "msg",
                                                "fromt": "str",
                                                "to": "false",
                                                "tot": "bool"
                                                "t": "move",
                                                "p": "fenster_wz",
                                                "pt": "msg",
                                                "to": "payload",
                                                "tot": "msg"
                                        "action": "",
                                        "property": "",
                                        "from": "",
                                        "to": "",
                                        "reg": false,
                                        "x": 570,
                                        "y": 220,
                                        "wires": [
                                                "583b02925b31d661",
                                                "30700a1f1af11019"
                                        "ack": "false",
                                        "stateName": "",
                                        "role": "",
                                        "payloadType": "",
                                        "readonly": "",
                                        "stateUnit": "",
                                        "stateMin": "",
                                        "stateMax": "",
                                        "x": 790,
                                        "y": 240,
                                        "wires": []
                                        "name": "",
                                        "onlyack": "",
                                        "func": "all",
                                        "gap": "",
                                        "x": 200,
                                        "y": 440,
                                        "wires": [
                                                "e14f45b233f41bf6",
                                                "0a809a663c37b826",
                                                "b13c2d067e849deb",
                                                "dc5cf4f07eb8edc9",
                                                "0de159c4387539cc",
                                                "c8e42d6ae7a6a496",
                                                "5c4c4ecbf153b3de"
                                        "type": "change",
                                        "name": "",
                                        "rules": [
                                                "t": "change",
                                                "pt": "msg",
                                                "fromt": "str",
                                                "to": "true",
                                                "tot": "bool"
                                                "t": "change",
                                                "pt": "msg",
                                                "fromt": "str",
                                                "to": "false",
                                                "tot": "bool"
                                                "t": "move",
                                                "pt": "msg",
                                                "to": "payload",
                                                "tot": "msg"
                                        "action": "",
                                        "property": "",
                                        "from": "",
                                        "to": "",
                                        "reg": false,
                                        "x": 570,
                                        "y": 340,
                                        "wires": [
                                                "a7aa1fb5298bd29c",
                                                "55130b9c537c5f05"
                                        "ack": "false",
                                        "stateName": "",
                                        "role": "",
                                        "payloadType": "",
                                        "readonly": "",
                                        "stateUnit": "",
                                        "stateMin": "",
                                        "stateMax": "",
                                        "x": 800,
                                        "y": 340,
                                        "wires": []
                                        "type": "change",
                                        "name": "",
                                        "rules": [
                                                "t": "change",
                                                "pt": "msg",
                                                "fromt": "str",
                                                "to": "true",
                                                "tot": "bool"
                                                "t": "change",
                                                "pt": "msg",
                                                "fromt": "str",
                                                "to": "false",
                                                "tot": "bool"
                                                "t": "move",
                                                "pt": "msg",
                                                "to": "payload",
                                                "tot": "msg"
                                        "action": "",
                                        "property": "",
                                        "from": "",
                                        "to": "",
                                        "reg": false,
                                        "x": 570,
                                        "y": 400,
                                        "wires": [
                                                "ea407daf57ae3231",
                                                "ba9eec8450b3fd98"
                                        "ack": "false",
                                        "stateName": "",
                                        "role": "",
                                        "payloadType": "",
                                        "readonly": "",
                                        "stateUnit": "",
                                        "stateMin": "",
                                        "stateMax": "",
                                        "x": 790,
                                        "y": 440,
                                        "wires": []
                                        "type": "change",
                                        "name": "",
                                        "rules": [
                                                "t": "change",
                                                "pt": "msg",
                                                "fromt": "str",
                                                "to": "true",
                                                "tot": "bool"
                                                "t": "change",
                                                "pt": "msg",
                                                "fromt": "str",
                                                "to": "false",
                                                "tot": "bool"
                                                "t": "move",
                                                "pt": "msg",
                                                "to": "payload",
                                                "tot": "msg"
                                        "action": "",
                                        "property": "",
                                        "from": "",
                                        "to": "",
                                        "reg": false,
                                        "x": 570,
                                        "y": 520,
                                        "wires": [
                                                "0ba5165605c97935",
                                                "bdf36b2de16500eb"
                                        "ack": "false",
                                        "stateName": "",
                                        "role": "",
                                        "payloadType": "",
                                        "readonly": "",
                                        "stateUnit": "",
                                        "stateMin": "",
                                        "stateMax": "",
                                        "x": 800,
                                        "y": 540,
                                        "wires": []
                                        "type": "change",
                                        "name": "",
                                        "rules": [
                                                "t": "change",
                                                "p": "tuer_wz",
                                                "pt": "msg",
                                                "fromt": "str",
                                                "to": "true",
                                                "tot": "bool"
                                                "t": "change",
                                                "p": "tuer_wz",
                                                "pt": "msg",
                                                "fromt": "str",
                                                "to": "false",
                                                "tot": "bool"
                                                "t": "move",
                                                "p": "tuer_wz",
                                                "pt": "msg",
                                                "to": "payload",
                                                "tot": "msg"
                                        "action": "",
                                        "property": "",
                                        "from": "",
                                        "to": "",
                                        "reg": false,
                                        "x": 570,
                                        "y": 640,
                                        "wires": [
                                                "7b6776a1a67d1974",
                                                "98a8e0b1bf54230d"
                                        "name": "Tür WZ",
                                        "ack": "false",
                                        "stateName": "",
                                        "role": "",
                                        "payloadType": "",
                                        "readonly": "",
                                        "stateUnit": "",
                                        "stateMin": "",
                                        "stateMax": "",
                                        "x": 780,
                                        "y": 640,
                                        "wires": []
                                        "type": "debug",
                                        "active": true,
                                        "tosidebar": true,
                                        "console": false,
                                        "tostatus": false,
                                        "complete": "true",
                                        "statusVal": "",
                                        "x": 830,
                                        "y": 300,
                                        "wires": []
                                        "type": "debug",
                                        "active": true,
                                        "tosidebar": true,
                                        "console": false,
                                        "tostatus": false,
                                        "complete": "true",
                                        "statusVal": "",
                                        "x": 820,
                                        "y": 400,
                                        "wires": []
                                        "type": "debug",
                                        "active": true,
                                        "tosidebar": true,
                                        "console": false,
                                        "tostatus": false,
                                        "complete": "true",
                                        "statusVal": "",
                                        "x": 830,
                                        "y": 500,
                                        "wires": []
                                        "type": "debug",
                                        "active": true,
                                        "tosidebar": true,
                                        "console": false,
                                        "tostatus": false,
                                        "complete": "true",
                                        "statusVal": "",
                                        "x": 810,
                                        "y": 600,
                                        "wires": []
                                        "type": "change",
                                        "name": "",
                                        "rules": [
                                                "t": "change",
                                                "p": "fenster_bad",
                                                "pt": "msg",
                                                "fromt": "str",
                                                "to": "1",
                                                "tot": "str"
                                                "t": "change",
                                                "p": "fenster_bad",
                                                "pt": "msg",
                                                "fromt": "str",
                                                "to": "0",
                                                "tot": "str"
                                                "t": "move",
                                                "p": "fenster_bad",
                                                "pt": "msg",
                                                "to": "payload",
                                                "tot": "msg"
                                        "action": "",
                                        "property": "",
                                        "from": "",
                                        "to": "",
                                        "reg": false,
                                        "x": 570,
                                        "y": 720,
                                        "wires": [
                                                "f94f4d4e2195fd4e",
                                                "5f208caa0596d609"
                                        "ack": "false",
                                        "stateName": "",
                                        "role": "",
                                        "payloadType": "",
                                        "readonly": "",
                                        "stateUnit": "",
                                        "stateMin": "",
                                        "stateMax": "",
                                        "x": 790,
                                        "y": 740,
                                        "wires": []
                                        "type": "debug",
                                        "active": true,
                                        "tosidebar": true,
                                        "console": false,
                                        "tostatus": false,
                                        "complete": "true",
                                        "statusVal": "",
                                        "x": 810,
                                        "y": 700,
                                        "wires": []
                                        "type": "debug",
                                        "name": "debug 4",
                                        "active": true,
                                        "tosidebar": true,
                                        "console": false,
                                        "tostatus": false,
                                        "statusVal": "",
                                        "x": 540,
                                        "y": 160,
                                        "wires": []
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @aphofis ja wenn nicht jede Node auf alles reagieren soll, dann darfst du die Nachrichten nicht einfach vervielfältigen, sondern musst diese über Bedingungen an verschiedene Ausgänge einer Switch Node schicken
                                • mickymM mickym
                                  AphofisA Offline
                                  AphofisA Offline
                                  Aphofis
                                  @mickym Wie erstelle ich denn diese bedingungen !?
                                  • AphofisA Aphofis
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @aphofis Na wie ich geschrieben habe. Mit einer switch Node. Oben steht die Eigenschaft, die Du überprüfen willst und dann definierst Du die Regeln - welcher Ausgang genommen wird.
                                    • AphofisA Offline
                                      AphofisA Offline
                                      Aphofis
                                      @mickym Ich tausche die Tuya Sensoren einfach gegen Sonoff Fenster Kontakte die reagieren in wenigen ms und sind zuverlässig. Es ist mir einfach zu kompliziert über eine alexa routine zu arbeiten.
                                      es sind einfach zu viele störfaktoren in der Geschichte.
                                      • AphofisA Aphofis
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @aphofis Ja mach wie Du denkst. Es geht nicht nur um das Ergebnis, sondern dass Du was gelernt hättest. Aber ich denke wir lassen das in Zukunft. Es gibt ja noch eine Menge anderer Leute, die Dir ggf. helfen können.
                                        Also viel Glück und Erfolg.
                                        • mickymM mickym
                                          AphofisA Offline
                                          AphofisA Offline
                                          Aphofis
                                          @mickym
                                          Ich verstehe manche dinge nicht!
                                          Ich würde es gerne umsetzen doch ich verliere manchmal den Faden um so komplexer es wird.
                                          Hat jetzt nix mit dieser steuerung zu Tun! Es hat nur keinen sinn eine Steuerung weiter zu bilden, wenn die aktoren nicht korrekt reagieren und macht dann auch keinen spaß. Hatte mir einen Fenster Tür Kontakt von Sonoff gekauft und die reagieren sehr schnell. man kann die schaltung damit weiter führen.
