  4. Test Adapter Garmin
Test Adapter Garmin
196 Beiträge 21 Kommentatoren 53.8k Aufrufe 21 Beobachtet
  • T tombox
    @bommel_030 steht im log wenn der adapter gestartet wird
    bommel_030
    #119
    @tombox
    Der Adapter ruft jetzt seit gestern durchgehend Daten ab. Alle 2h haut er aber das LOG voll.
    2025-02-28 10:33:05.017	error	undefined
    2025-02-28 10:33:05.017	error	HTTPError: Response code 401 (Unauthorized)
    2025-02-28 10:33:05.017	error	https://connect.garmin.com/weight-service/weight/dateRange?startDate=2025-02-22&endDate=2025-02-28
    2025-02-28 10:33:04.870	error	undefined
    2025-02-28 10:33:04.870	error	HTTPError: Response code 401 (Unauthorized)
    2025-02-28 10:33:04.870	error	https://connect.garmin.com/activitylist-service/activities/search/activities?start=0&limit=10
    2025-02-28 10:33:04.717	error	undefined
    2025-02-28 10:33:04.717	error	HTTPError: Response code 401 (Unauthorized)
    2025-02-28 10:33:04.717	error	https://connect.garmin.com/metrics-service/metrics/trainingstatus/aggregated/2025-02-28
    2025-02-28 10:33:04.199	error	undefined
    2025-02-28 10:33:04.198	error	HTTPError: Response code 401 (Unauthorized)
    2025-02-28 10:33:04.198	error	https://connect.garmin.com/userstats-service/wellness/daily/bommel_030?fromDate=2025-02-22
    2025-02-28 10:33:04.032	error	undefined
    2025-02-28 10:33:04.032	error	HTTPError: Response code 401 (Unauthorized)
    2025-02-28 10:33:04.032	error	https://connect.garmin.com/wellness-service/wellness/dailyStress/2025-02-28
    2025-02-28 10:33:03.883	error	undefined
    2025-02-28 10:33:03.883	error	HTTPError: Response code 401 (Unauthorized)
    2025-02-28 10:33:03.883	error	https://connect.garmin.com/wellness-service/wellness/dailySleepData/bommel_030?date=2025-02-28&nonSleepBufferMinutes=60
    2025-02-28 10:33:03.730	error	undefined
    2025-02-28 10:33:03.730	error	HTTPError: Response code 401 (Unauthorized)
    2025-02-28 10:33:03.730	error	https://connect.garmin.com/adhocchallenge-service/adHocChallenge/historical
    2025-02-28 10:33:03.568	error	undefined
    2025-02-28 10:33:03.568	error	HTTPError: Response code 401 (Unauthorized)
    2025-02-28 10:33:03.568	error	https://connect.garmin.com/personalrecord-service/personalrecord/prs/bommel_030
    2025-02-28 10:33:03.380	error	undefined
    2025-02-28 10:33:03.380	error	HTTPError: Response code 401 (Unauthorized)
    2025-02-28 10:33:03.380	error	https://connect.garmin.com/usersummary-service/usersummary/hydration/daily/2025-02-28
    2025-02-28 10:33:03.224	error	undefined
    2025-02-28 10:33:03.224	error	HTTPError: Response code 401 (Unauthorized)
    2025-02-28 10:33:03.224	error	https://connect.garmin.com/metrics-service/metrics/maxmet/daily/2025-02-28/2025-02-28
    2025-02-28 10:33:03.072	error	undefined
    2025-02-28 10:33:03.072	error	HTTPError: Response code 401 (Unauthorized)
    2025-02-28 10:33:03.072	error	https://connect.garmin.com/usersummary-service/usersummary/daily/bommel_030?calendarDate=2025-02-28
    Kann man das noch irgendwie abfangen? Wenn nicht, die Logstufe evtl. auf "Warn" setzen?
    T 2 Antworten Letzte Antwort
    • B bommel_030
      @tombox
      tombox
      #120
      @bommel_030 Wenn das kommt sollten aber keine Daten reinkommen oder
      • T tombox
        bommel_030
        #121
        @tombox
        Nein, bei dem Abruf der den Fehler 401 erzeugt kommen keine Daten. Bei dem darauffolgenden kommen dann wieder Daten.
        • B bommel_030
          @tombox
          tombox
          #122
          @bommel_030 hast du ein größeren log ausschnitt mit refresh token
          • T tombox
            bommel_030
            #123
            @tombox
            Mit refresh vor und nach 401. Reicht das?
            2025-02-28 00:20:30.918 - debug: garmin.0 (2133783) Refresh token
            2025-02-28 00:20:30.919 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:13:16.024Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:13:16.024Z","sameSite":"none"},{"key":"JWT_FGP","value":"a90b9183-b21b-4477-a473-6b4346295d77","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T21:24:18.016Z","lastAccessed":"2025-02-27T23:20:30.918Z"},{"key":"ADRUM_BTa","value":"R:0|g:e5a90d46-5b0e-4249-be6a-ebe67936c980|n:garmin_869629ee-d273-481d-b5a4-f4b0a8c4d5a3","expires":"2025-02-27T23:13:45.000Z","maxAge":30,"domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":true,"creation":"2025-02-27T23:13:14.122Z","lastAccessed":"2025-02-27T23:13:16.024Z"},{"key":"ADRUM_BT1","value":"R:0|i:137465|e:23|t:1740697995888","expires":"2025-02-27T23:13:45.000Z","maxAge":30,"domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":true,"creation":"2025-02-27T23:13:14.122Z","lastAccessed":"2025-02-27T23:13:16.024Z"}]}
            2025-02-28 00:20:30.919 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.ZVboYSNZS-o7BgcCmfggSwzN_8_odrsX97qdCrhEwWTcVjsVjjxhrbKnbMbvGZ2Iu2-JdY4v2YWpxe1ghApY2ag4t84UQcIUmMewqkTnmTeBM_ggSEK6ix3NyiVjpDkbLnoXeOuyYI8mSCEX0jpmHZx76w0yNESfIhh_wTJySjz-mKR7CFdFtVnw97jck4mqU9nRZTvKCka2UhjkuJp_MXPSgQofOdPm0lk9HwacALZVEwxnT2q4HtWq8MZM2NkcV3AMirow8p8Cwx8LPdWJhWXr_cF90Y8zoI_zloCxmFRFhUwZrCGb9FE7WKUAN363-kDEt-63NLYQ8lt7YAFU8w
            2025-02-28 00:20:30.919 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImRlNmRhOTdlLWViNTUtNDgzZi1hMTY1LWIzOTlmY2NjNmUxZSIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD==
            2025-02-28 00:20:31.518 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.g92Uywmjq_hgvI9ZHINo6wtzQz7P_NUW1LkVFL-MbxGk4X0T9wvLm5PmCELi_KCwcaVHoRO3ntyZBlMqXG0sFLB9k_NHgmBtKNuvdoUyl1gj79SIXmN6F0pOBOKbj3kpYVKe_ksNzkLgcC0NilHbOnNi35jJwKw-zfScV1bxePf4ba1U-leVXCl7EOl3cQ2n4kjxqHfAd8js1oFNgA79loGPu1aYD4R-RJwnAs-PtaVdmIpAk2X8u2qXnfWZXSGiMuPZbuQhik1P2Ypkq1X3oO8rpx4craAuupzk97xDOMfOcIggYfWKE9G-qXprp16aBpNYVnyP6oex2JCVJhrC3g\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImZjYThjMDNkLTUwMWQtNGViMS04N2JjLTJhYTI5ZTJmYTRlZCIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"d4eee4a1-3da5-4ab8-a7b3-62c5356b5d74\",\"refresh_token_expires_in\":7199}"
            2025-02-28 00:33:25.684 - debug: garmin.0 (2133783) Refresh token
            2025-02-28 00:33:25.686 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:20:30.921Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:20:30.921Z","sameSite":"none"},{"key":"JWT_FGP","value":"7fe4bd67-6230-4d20-b739-1f2abd78f1bc","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T21:24:18.016Z","lastAccessed":"2025-02-27T23:33:25.685Z"}]}
            2025-02-28 00:33:25.686 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.g92Uywmjq_hgvI9ZHINo6wtzQz7P_NUW1LkVFL-MbxGk4X0T9wvLm5PmCELi_KCwcaVHoRO3ntyZBlMqXG0sFLB9k_NHgmBtKNuvdoUyl1gj79SIXmN6F0pOBOKbj3kpYVKe_ksNzkLgcC0NilHbOnNi35jJwKw-zfScV1bxePf4ba1U-leVXCl7EOl3cQ2n4kjxqHfAd8js1oFNgA79loGPu1aYD4R-RJwnAs-PtaVdmIpAk2X8u2qXnfWZXSGiMuPZbuQhik1P2Ypkq1X3oO8rpx4craAuupzk97xDOMfOcIggYfWKE9G-qXprp16aBpNYVnyP6oex2JCVJhrC3g
            2025-02-28 00:33:25.686 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImZjYThjMDNkLTUwMWQtNGViMS04N2JjLTJhYTI5ZTJmYTRlZCIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD==
            2025-02-28 00:33:26.324 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInRASDsdfsdverzbezbdgvI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.le9xjESzpqCAk8Uvx7ZsIK2NgLJgiyZyxRkUGjUBobqc5pHALzNwg2gLo6QQTEgNWM557mYpkS-wYiwyXbbO1hHjqQar5YlPBOE4xPD5E-ldGw4mSNlVhRVblXCIOJI8egRwVRvn1TurDfhpnC0CO2W9LfmJKlprm2YUMI8cHfX1HIyBeyCgJM6o7oRufuL55R-ZUZ6nNI2ecEt6dfWbnHkrawbVwXig9IbIqyTWOtylKmXUkPXuCnAB-3iYaANGt9UJ1rrX3oaTjrKLinidHdCNUFV8m2y4xAp8cJcZk6nF_dzF6ru4CYjbhTlGGz2aeOZouuuGscyURMgD7CHzPA\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjhiNmJjMzM2LWU3NWItNDY4OC04ZDU2LTJlNWIwZGY3ZDNkNSIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"d396d226-0b4a-4627-a1fa-3975e5f1a6ad\",\"refresh_token_expires_in\":7199}"
            2025-02-28 00:43:13.708 - error: garmin.0 (2133783) https://connect.garmin.com/usersummary-service/usersummary/daily/bommel_030?calendarDate=2025-02-27
            2025-02-28 00:43:13.708 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
            2025-02-28 00:43:13.708 - error: garmin.0 (2133783) undefined
            2025-02-28 00:43:14.088 - error: garmin.0 (2133783) https://connect.garmin.com/metrics-service/metrics/maxmet/daily/2025-02-27/2025-02-27
            2025-02-28 00:43:14.088 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
            2025-02-28 00:43:14.088 - error: garmin.0 (2133783) undefined
            2025-02-28 00:43:14.242 - error: garmin.0 (2133783) https://connect.garmin.com/usersummary-service/usersummary/hydration/daily/2025-02-27
            2025-02-28 00:43:14.242 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
            2025-02-28 00:43:14.242 - error: garmin.0 (2133783) undefined
            2025-02-28 00:43:14.395 - error: garmin.0 (2133783) https://connect.garmin.com/personalrecord-service/personalrecord/prs/bommel_030
            2025-02-28 00:43:14.396 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
            2025-02-28 00:43:14.396 - error: garmin.0 (2133783) undefined
            2025-02-28 00:43:14.543 - error: garmin.0 (2133783) https://connect.garmin.com/adhocchallenge-service/adHocChallenge/historical
            2025-02-28 00:43:14.543 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
            2025-02-28 00:43:14.543 - error: garmin.0 (2133783) undefined
            2025-02-28 00:43:14.690 - error: garmin.0 (2133783) https://connect.garmin.com/wellness-service/wellness/dailySleepData/bommel_030?date=2025-02-27&nonSleepBufferMinutes=60
            2025-02-28 00:43:14.690 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
            2025-02-28 00:43:14.690 - error: garmin.0 (2133783) undefined
            2025-02-28 00:43:14.837 - error: garmin.0 (2133783) https://connect.garmin.com/wellness-service/wellness/dailyStress/2025-02-27
            2025-02-28 00:43:14.838 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
            2025-02-28 00:43:14.838 - error: garmin.0 (2133783) undefined
            2025-02-28 00:43:14.986 - error: garmin.0 (2133783) https://connect.garmin.com/userstats-service/wellness/daily/bommel_030?fromDate=2025-02-21
            2025-02-28 00:43:14.986 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
            2025-02-28 00:43:14.986 - error: garmin.0 (2133783) undefined
            2025-02-28 00:43:15.159 - error: garmin.0 (2133783) https://connect.garmin.com/metrics-service/metrics/trainingstatus/aggregated/2025-02-27
            2025-02-28 00:43:15.160 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
            2025-02-28 00:43:15.160 - error: garmin.0 (2133783) undefined
            2025-02-28 00:43:15.307 - error: garmin.0 (2133783) https://connect.garmin.com/activitylist-service/activities/search/activities?start=0&limit=10
            2025-02-28 00:43:15.308 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
            2025-02-28 00:43:15.308 - error: garmin.0 (2133783) undefined
            2025-02-28 00:43:15.451 - error: garmin.0 (2133783) https://connect.garmin.com/weight-service/weight/dateRange?startDate=2025-02-21&endDate=2025-02-27
            2025-02-28 00:43:15.451 - error: garmin.0 (2133783) HTTPError: Response code 401 (Unauthorized)
            2025-02-28 00:43:15.451 - error: garmin.0 (2133783) undefined
            2025-02-28 00:46:20.452 - debug: garmin.0 (2133783) Refresh token
            2025-02-28 00:46:20.453 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:43:15.309Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:43:15.309Z","sameSite":"none"},{"key":"JWT_FGP","value":"983a4a62-9e24-40ea-89ef-c57b224611fa","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T23:46:20.452Z","lastAccessed":"2025-02-27T23:46:20.452Z"}]}
            2025-02-28 00:46:20.453 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.le9xjESzpqCAk8Uvx7ZsIK2NgLJgiyZyxRkUGjUBobqc5pHALzNwg2gLo6QQTEgNWM557mYpkS-wYiwyXbbO1hHjqQar5YlPBOE4xPD5E-ldGw4mSNlVhRVblXCIOJI8egRwVRvn1TurDfhpnC0CO2W9LfmJKlprm2YUMI8cHfX1HIyBeyCgJM6o7oRufuL55R-ZUZ6nNI2ecEt6dfWbnHkrawbVwXig9IbIqyTWOtylKmXUkPXuCnAB-3iYaANGt9UJ1rrX3oaTjrKLinidHdCNUFV8m2y4xAp8cJcZk6nF_dzF6ru4CYjbhTlGGz2aeOZouuuGscyURMgD7CHzPA
            2025-02-28 00:46:20.453 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjhiNmJjMzM2LWU3NWItNDY4OC04ZDU2LTJlNWIwZGY3ZDNkNSIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD==
            2025-02-28 00:46:21.181 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVdtzbudzbdbtZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.SUozkIOGJaNrqL6Dkk5w7IlD9ACRx8atbYRPUrC4q9hiFzfCGsmUWYNPcDPX43GY64xGrupiXRg-KBdlMrNjZgmVcNV4tsTBiiG8FQLCxj19XWQvNRkx75roWnEzIj_4hJJwJmS53zs8TiqJvQbe141YbV0P2wriJIssruOm9VcvPTpePZvYoi20ocz4DN3s_63QnHW0dL-UcK_RlZS9uyhKTaJ4r-M0_MIiL3zERMNfXa0xmNeAAOnkv-nCB672gJtVR7JN0NXFKaLYrfjsoNdLzhDuCTKZ5crDbnb1m-rf80rD4tPURXLR87KCEjFtGc7a0Av419o1yYLFS9abPg\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjVkYzc0MTY1LTdjODMtNDkwYy1hZGVlLTIzNDkzYjU3YjEzNiIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YMGHSLAHFDD==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"c08f4f2e-08bf-4022-afff-273700e389b7\",\"refresh_token_expires_in\":7199}"
            2025-02-28 00:59:15.219 - debug: garmin.0 (2133783) Refresh token
            • B bommel_030
              @tombox
              tombox
              #124
              @bommel_030 mmh und nach dem zweiten refresh geht es dann wieder?
              • T tombox
                bommel_030
                #125
                @tombox
                Danach geht es wieder. Die nächsten Zeilen vom LOG direkt im Anschluss wenn das was hilft.
                2025-02-28 00:46:20.453 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjhiNmJjMzM2LWU3NWItNDY4OC04ZDU2LTJlNWIwZGY3ZDNkNSIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==
                2025-02-28 00:46:21.181 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.SUozkIOGJaNrqL6Dkk5w7IlD9ACRx8atbYRPUrC4q9hiFzfCGsmUWYNPcDPX43GY64xGrupiXRg-KBdlMrNjZgmVcNV4tsTBiiG8FQLCxj19XWQvNRkx75roWnEzIj_4hJJwJmS53zs8TiqJvQbe141YbV0P2wriJIssruOm9VcvPTpePZvYoi20ocz4DN3s_63QnHW0dL-UcK_RlZS9uyhKTaJ4r-M0_MIiL3zERMNfXa0xmNeAAOnkv-nCB672gJtVR7JN0NXFKaLYrfjsoNdLzhDuCTKZ5crDbnb1m-rf80rD4tPURXLR87KCEjFtGc7a0Av419o1yYLFS9abPg\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjVkYzc0MTY1LTdjODMtNDkwYy1hZGVlLTIzNDkzYjU3YjEzNiIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"c08f4f2e-08bf-4022-afff-273700e389b7\",\"refresh_token_expires_in\":7199}"
                2025-02-28 00:59:15.221 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:46:20.455Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:46:20.455Z","sameSite":"none"},{"key":"JWT_FGP","value":"af387cb9-d3a3-41b3-8c89-a668d7401461","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T23:46:20.452Z","lastAccessed":"2025-02-27T23:59:15.219Z"}]}
                2025-02-28 00:59:15.221 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.SUozkIOGJaNrqL6Dkk5w7IlD9ACRx8atbYRPUrC4q9hiFzfCGsmUWYNPcDPX43GY64xGrupiXRg-KBdlMrNjZgmVcNV4tsTBiiG8FQLCxj19XWQvNRkx75roWnEzIj_4hJJwJmS53zs8TiqJvQbe141YbV0P2wriJIssruOm9VcvPTpePZvYoi20ocz4DN3s_63QnHW0dL-UcK_RlZS9uyhKTaJ4r-M0_MIiL3zERMNfXa0xmNeAAOnkv-nCB672gJtVR7JN0NXFKaLYrfjsoNdLzhDuCTKZ5crDbnb1m-rf80rD4tPURXLR87KCEjFtGc7a0Av419o1yYLFS9abPg
                2025-02-28 00:59:15.221 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6IjVkYzc0MTY1LTdjODMtNDkwYy1hZGVlLTIzNDkzYjU3YjEzNiIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==
                2025-02-28 00:59:16.148 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.CYPtRMD30ZXSlqlMAvw2Dj7z4yKqyUyuWOnbCLz3UYBj64QvREE9N3XXER3OjlZcBUNiKuc5xirbslTnnPS2P-DOX6UAxiE6Ads-Q-L_zgE59z-1GxWV23TUWl2mxwj-I257mwP-1q2ixj95E4C_ge1xQ5Q-JbLNpBIQZponcm2sx-Oirub4vwgGY9gQELLtCsJS1jslnfKgDs5YH53tm5xS8MXC2VP-J3ZIoFNTO3q1xC9No_YDN-98aAE2Ra-2o19oBFCwO7wcldLpf01ldqvWyzX1AFApC-FCrmrNXGTuge9XYVFKi83DWLcNUSgHpzJ5H07rYD2lCTJu5uv2Bw\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImFjNThjNmEyLWJiNjYtNDQ4Yy05ZGUzLTQ5MDEyZTAyODY3YyIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"4b3be690-0ef3-4ddd-b93e-8ea8d391c52d\",\"refresh_token_expires_in\":7199}"
                2025-02-28 01:12:09.985 - debug: garmin.0 (2133783) Refresh token
                2025-02-28 01:12:09.986 - debug: garmin.0 (2133783) {"version":"tough-cookie@4.1.4","storeType":"MemoryCookieStore","rejectPublicSuffixes":true,"enableLooseMode":false,"allowSpecialUseDomain":true,"prefixSecurity":"silent","cookies":[{"key":"__cflb","value":"02DiuJLbVZHipNWxN8wwnxZhF2QbAv3GZNF2Z7HNiarda","expires":"2025-02-28T10:43:10.000Z","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":true,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:59:15.223Z","sameSite":"none"},{"key":"_cfuvid","value":"EYAT1NBLV.idCR.EuHFwKrevqHIrlKtOnk_.D0w9nOU-1740656590441-0.0.1.1-604800000","domain":"connect.garmin.com","path":"/","secure":true,"httpOnly":true,"hostOnly":false,"creation":"2025-02-27T11:43:10.449Z","lastAccessed":"2025-02-27T23:59:15.223Z","sameSite":"none"},{"key":"JWT_FGP","value":"05589760-e24e-46f8-a04f-b85cb72a10e6","domain":"connect.garmin.com","path":"/","secure":true,"hostOnly":false,"creation":"2025-02-27T23:46:20.452Z","lastAccessed":"2025-02-28T00:12:09.985Z"}]}
                2025-02-28 01:12:09.986 - debug: garmin.0 (2133783) eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.CYPtRMD30ZXSlqlMAvw2Dj7z4yKqyUyuWOnbCLz3UYBj64QvREE9N3XXER3OjlZcBUNiKuc5xirbslTnnPS2P-DOX6UAxiE6Ads-Q-L_zgE59z-1GxWV23TUWl2mxwj-I257mwP-1q2ixj95E4C_ge1xQ5Q-JbLNpBIQZponcm2sx-Oirub4vwgGY9gQELLtCsJS1jslnfKgDs5YH53tm5xS8MXC2VP-J3ZIoFNTO3q1xC9No_YDN-98aAE2Ra-2o19oBFCwO7wcldLpf01ldqvWyzX1AFApC-FCrmrNXGTuge9XYVFKi83DWLcNUSgHpzJ5H07rYD2lCTJu5uv2Bw
                2025-02-28 01:12:09.986 - debug: garmin.0 (2133783) eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImFjNThjNmEyLWJiNjYtNDQ4Yy05ZGUzLTQ5MDEyZTAyODY3YyIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==
                2025-02-28 01:12:10.684 - debug: garmin.0 (2133783) "{\"access_token\":\"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6ImRpLW9hdXRoLXNpZ25lci1wcm9kLTIwMjQtcTEifQ.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.TRYFENyJT0pBz4kqnkATNbG5EV-rb_2NJEsemuPlbOeWV89rOoVW0WJ5N1WXuvbCN3HYibS6Lnwg7nqvExbdBSBAH1MbtVNb8xSDlq2HdMjyYhwcC66W-wy0g9ciXCX6P1kyUcwdayD6LMSxJI_SQ9FE6KzUqOpxjX2JGq7myg38QGSXVDjFJpffcfb4Mvg2F4pMeK5uiPyj9K5lWlmMo4rinnWeKuRW7lx9tIaEJ7lqs6hSGNCSw4yXWXKEp3k4wZrX16WyvN6E9djYoYrlvjCxR6y3oQ3CTzUpsbUFc7o2Pp7Lz5j6F7k9Yx8He3gnUDtKQ1QsUiEZAIDqlHYXLw\",\"token_type\":\"bearer\",\"refresh_token\":\"eyJyZWZyZXNoVG9rZW5WYWx1ZSI6ImRmOGRiOTg1LTVjMTktNDQ4Zi05ZGQ1LTEyMGViMzhmZGYzNiIsImdhcm1pbkd1aWQiOiI0MjRmYmU5Ny1hODlkLTQ3ZWItYTFjYi1jYmViN2YwMGViODUifQ==\",\"expires_in\":3599,\"scope\":\"COMMUNITY_COURSE_READ GOLF_API_READ GHS_HID ATP_READ DIVE_API_WRITE GHS_SAMD INSIGHTS_READ DIVE_API_READ DIVE_API_IMAGE_PREVIEW COMMUNITY_COURSE_WRITE CONNECT_WRITE DIVE_SHARED_READ GHS_REGISTRATION DT_CLIENT_ANALYTICS_WRITE GOLF_API_WRITE INSIGHTS_WRITE PRODUCT_SEARCH_READ GOLF_SHARED_READ OMT_CAMPAIGN_READ OMT_SUBSCRIPTION_READ CONNECT_NON_SOCIAL_SHARED_READ CONNECT_READ ATP_WRITE\",\"jti\":\"be8a9cd4-5c9c-49ba-93fe-a91c9bf1b9fe\",\"refresh_token_expires_in\":7199}"
                2025-02-28 01:13:14.544 - debug: garmin.0 (2133783) {"userProfileId":2400759,"totalKilocalories":27,"activeKilocalories":0,"bmrKilocalories":27,"wellnessKilocalories":27,"burnedKilocalories":null,"consumedKilocalories":null,"remainingKilocalories":1500,"totalSteps":null,"netCalorieGoal":1500,"totalDistanceMeters":null,"wellnessDistanceMeters":null,"wellnessActiveKilocalories":0,"netRemainingKilocalories":1500,"userDailySummaryId":2400759,"calendarDate":"2025-02-28","rule":{"typeId":3,"typeKey":"subscribers"},"uuid":"3cc5c04cce824a92bf67d8616a334a6e","dailyStepGoal":14280,"wellnessStartTimeGmt":"2025-02-27T23:00:00.0","wellnessStartTimeLocal":"2025-02-28T00:00:00.0","wellnessEndTimeGmt":"2025-02-27T23:18:00.0","wellnessEndTimeLocal":"2025-02-28T00:18:00.0","durationInMilliseconds":1080000,"wellnessDescription":null,"highlyActiveSeconds":0,"activeSeconds":0,"sedentarySeconds":1080,"sleepingSeconds":0,"includesWellnessData":true,"includesActivityData":false,"includesCalorieConsumedData":false,"privacyProtected":false,"moderateIntensityMinutes":0,"vigorousIntensityMinutes":0,"floorsAscendedInMeters":0,"floorsDescendedInMeters":0,"floorsAscended":0,"floorsDescended":0,"intensityMinutesGoal":150,"userFloorsAscendedGoal":10,"minHeartRate":68,"maxHeartRate":70,"restingHeartRate":67,"lastSevenDaysAvgRestingHeartRate":63,"source":"GARMIN","averageStressLevel":26,"maxStressLevel":28,"stressDuration":720,"restStressDuration":360,"activityStressDuration":null,"uncategorizedStressDuration":null,"totalStressDuration":1080,"lowStressDuration":720,"mediumStressDuration":null,"highStressDuration":null,"stressPercentage":66.67,"restStressPercentage":33.33,"activityStressPercentage":0,"uncategorizedStressPercentage":0,"lowStressPercentage":66.67,"mediumStressPercentage":0,"highStressPercentage":0,"stressQualifier":"UNKNOWN","measurableAwakeDuration":1080,"measurableAsleepDuration":0,"lastSyncTimestampGMT":"2025-02-27T23:18:53.423","minAvgHeartRate":69,"maxAvgHeartRate":70,"bodyBatteryChargedValue":0,"bodyBatteryDrainedValue":0,"bodyBatteryHighestValue":5,"bodyBatteryLowestValue":5,"bodyBatteryMostRecentValue":5,"bodyBatteryDuringSleep":null,"bodyBatteryAtWakeTime":null,"bodyBatteryVersion":2,"abnormalHeartRateAlertsCount":null,"averageSpo2":90,"lowestSpo2":87,"latestSpo2":91,"latestSpo2ReadingTimeGmt":"2025-02-27T23:18:00.0","latestSpo2ReadingTimeLocal":"2025-02-28T00:18:00.0","averageMonitoringEnvironmentAltitude":-4,"restingCaloriesFromActivity":null,"avgWakingRespirationValue":14,"highestRespirationValue":16,"lowestRespirationValue":12,"latestRespirationValue":16,"latestRespirationTimeGMT":"2025-02-27T23:18:00.0","respirationAlgorithmVersion":100}
                2025-02-28 01:13:14.555 - debug: garmin.0 (2133783) Type changed for usersummary.totalSteps from number to mixed
                2025-02-28 01:13:14.561 - debug: garmin.0 (2133783) Type changed for usersummary.totalDistanceMeters from number to mixed
                2025-02-28 01:13:14.566 - debug: garmin.0 (2133783) Type changed for usersummary.wellnessDistanceMeters from number to mixed
                2025-02-28 01:13:14.618 - debug: garmin.0 (2133783) Type changed for usersummary.activityStressDuration from number to mixed
                2025-02-28 01:13:14.622 - debug: garmin.0 (2133783) Type changed for usersummary.uncategorizedStressDuration from mixed to mixed
                2025-02-28 01:13:14.629 - debug: garmin.0 (2133783) Type changed for usersummary.mediumStressDuration from mixed to mixed
                2025-02-28 01:13:14.653 - debug: garmin.0 (2133783) Type changed for usersummary.bodyBatteryDuringSleep from mixed to mixed
                2025-02-28 01:13:14.657 - debug: garmin.0 (2133783) Type changed for usersummary.bodyBatteryAtWakeTime from mixed to mixed
                2025-02-28 01:13:14.671 - debug: garmin.0 (2133783) Type changed for usersummary.restingCaloriesFromActivity from mixed to mixed
                2025-02-28 01:13:14.712 - debug: garmin.0 (2133783) []
                2025-02-28 01:13:14.893 - debug: garmin.0 (2133783) {"userId":2400759,"calendarDate":"2025-02-28","valueInML":null,"goalInML":2800,"dailyAverageinML":null,"lastEntryTimestampLocal":null,"sweatLossInML":null,"activityIntakeInML":null}
                2025-02-28 01:13:14.899 - debug: garmin.0 (2133783) Type changed for hydration.valueInML from mixed to mixed
                2025-02-28 01:13:14.907 - debug: garmin.0 (2133783) Type changed for hydration.sweatLossInML from mixed to mixed
                2025-02-28 01:13:14.911 - debug: garmin.0 (2133783) Type changed for hydration.activityIntakeInML from mixed to mixed
                • B bommel_030
                  @tombox
                  tombox
                  #126
                  @bommel_030 siehst du ein Muster wan es auftritt
                  • B bommel_030
                    @kirbsi
                    Läuft der Adapter bei dir denn durchgehend? Welche Garmin Hardware nutzt du und in welchem Umfang?
                    kirbsi
                    #127
                    @bommel_030 nein leider immer nur wenige Stunden.
                    • T tombox
                      bommel_030
                      #128
                      @tombox
                      Naja, exakt alle 2,5 h kommen die Meldungen.
                      Ob das jetzt zufällig mit dem 30min Abrufintervall zusammenfällt, oder die Anzahl der Abrufe ist kann ich nicht sagen.
                      Sobald ich wieder an nem PC sitze schraube ich das Abrufintervall Mal runter.
                      Es ist auch kein zeitlicher Zusammenhang zu refresh Token und 401 zu sehen. Das was er an Daten abruft scheint damit nichts zu tun zu haben.
                      • B bommel_030
                        @tombox
                        tombox
                        #129
                        @bommel_030 Ja refresh Token funktioniert immer ohne Probleme Vielleicht tmla das interval 15 oder so setzen
                        B 2 Antworten Letzte Antwort
                        • T tombox
                          bommel_030
                          #130
                          @tombox
                          Intervall ist jetzt auf 15min und er holt nach dem Start auch Daten.
                          garmin has an invalid jsonConfig: [{"instancePath":"","schemaPath":"#/then/required","keyword":"required","params":{"missingProperty":"type"},"message":"must have required property 'type'"}]
                          Die Meldung kommt noch beim Start. Ist mir vorher im Log Level Debug scheinbar nicht aufgefallen.
                          • T tombox
                            bommel_030
                            #131
                            @tombox
                            Joar, Fehlerbild bleibt gleich. Jetzt halt nach 2:15 statt nach 2:30. Scheint also nicht an der Anzahl der Abrufe zu liegen.
                            • B bommel_030
                              @tombox
                              tombox
                              #132
                              @bommel_030 Ich denke nach 2h läuft etwas ab muss ich mal schauen was es genau ist
                              • T tombox
                                bommel_030
                                #133
                                @tombox
                                Erstmal nochmals danke. Das erste Mal, dass der Adapter über 24h kontinuierlich Daten abruft!
                                Mir würde es auch erstmal reichen den 401 als Warnung und nicht als Error zu sehen. Dann ist das Log nicht ganz so unübersichtlich.
                                Wenn ich noch irgendwelche Daten bereitstellen soll sag Bescheid.
                                • B bommel_030
                                  @tombox
                                  tombox
                                  #134
                                  @bommel_030 habe das in GitHub version angepasst
                                  • T tombox
                                    bommel_030
                                    #135
                                    @tombox
                                    Hab die 0.2.1 installiert. Er ruft brav im 15 min Takt die Daten ab. Nach der 2h Schallgrenze ruft er die Daten nicht ab, gibt aber auch nichts im LOG aus.
                                    Ab dem nächsten Abrufintervall kommen dann wieder Daten. Also alle 2h setzt ein Intervall quasi aus.
                                    Damit kann ich gut leben.
                                    Mal schauen wie lange er im Dauerbetrieb jetzt mitmacht.
                                    • T tombox
                                      bommel_030
                                      #136
                                      @tombox
                                      Nach 5 Tagen klappt das mit dem Abrufen bzw. Token Erneuerung nicht mehr. Meldung im Log:
                                      2025-03-08 07:33:45.983 - error: garmin.0 (1923) FGP missmatch. Please logout and login in garmin and update FGP in the settings
                                      2025-03-08 07:33:45.984 - error: garmin.0 (1923) Failed to login
                                      Nach erneuter Eingabe der Daten klappt es wieder.
                                      • MassiveAttackM Offline
                                        MassiveAttack
                                        #137
                                        Ich verwende aktuell auch den Adapter, so weit so gut. Finde aber ein paar Werte nicht, zB. den Ausdauerwert.
                                        Zusätzlich gebe ich manuell in der App meine Blutdruckwerte ein, die kann ich aber mit dem Adapter auch nicht finden. Jemand eine Idee?
                                          MassiveAttack
                                          #138
                                          Mich würde auch interessieren, ob und wie ich gesamt-tageswerte von kalorien, schritte, etc auslesen kann. wenn man nur spontane werte nach einer synchronisierung bekommt, macht das doch null sinn.
