Shelly Instanz CoAp steigt seit inst. vom neuen Node.js aus
@arminrey du sollst auf den Schraubenschlüssel klicken, dadurch erfolgt ein rebuild des Adapters
PS
bei Fehler bitte das Log zeigen -
So, musste wieder auf node20 um, da der Shelly 9 nicht akzeptiert wurde.
Leider nein
shelly.0 2025-02-13 14:05:52.131 info terminating shelly.0 2025-02-13 14:05:51.629 warn Terminated (UNCAUGHT_EXCEPTION): Without reason shelly.0 2025-02-13 14:05:51.629 info terminating shelly.0 2025-02-13 14:05:51.616 error Error ERROR writeFile-Meta id=shelly.0: UNKNOWN: unknown error, open 'C:\ioBroker\iobroker-data\files\shelly.0\_data.json' shelly.0 2025-02-13 14:05:51.616 error ReplyError: Error ERROR writeFile-Meta id=shelly.0: UNKNOWN: unknown error, open 'C:\ioBroker\iobroker-data\files\shelly.0\_data.json' at parseError (C:\ioBroker\node_modules\redis-parser\lib\parser.js:179:12) at parseType (C:\ioBroker\node_modules\redis-parser\lib\parser.js:302:14) shelly.0 2025-02-13 14:05:51.614 error unhandled promise rejection: Error ERROR writeFile-Meta id=shelly.0: UNKNOWN: unknown error, open 'C:\ioBroker\iobroker-data\files\shelly.0\_data.json' shelly.0 2025-02-13 14:05:51.613 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). shelly.0 2025-02-13 14:03:39.594 info [CoAP] Device 192.168.1.130 (shellyplug-s / shellyplug-s-4022D889B232 / SHPLG-S#4022D889B232#1) connected! Polltime set to 10 sec. shelly.0 2025-02-13 14:03:38.209 info [CoAP] Device 192.168.1.167 (shellyem / shellyem-485519D6C5DA / SHEM#485519D6C5DA#1) connected! Polltime set to 10 sec. shelly.0 2025-02-13 14:03:37.922 info [CoAP] Device 192.168.1.132 (shelly1 / shelly1-C45BBE764758 / SHSW-1#C45BBE764758#1) connected! Polltime set to 10 sec. shelly.0 2025-02-13 14:03:37.865 info [CoAP] Device 192.168.1.162 (shellyplug-s / shellyplug-s-4022D88943F7 / SHPLG-S#4022D88943F7#1) connected! Polltime set to 10 sec. shelly.0 2025-02-13 14:03:37.687 info [CoAP] Device 192.168.1.168 (shelly1pm / shelly1pm-8CAAB55FD700 / SHSW-PM#8CAAB55FD700#1) connected! Polltime set to 10 sec.MOD-EDIT: Code in code-tags gesetzt!
Leider nein
@arminrey kein Mensch sagte etwas davon, dass du v9 installieren solltest und es fehlt auch das Installationslog dazu
lediglich auf den Schraubenschlüssel solltest du drücken und das LOG bei Fehler zeigen
und solange deine Instanz Fehler wirft ist logisch das der Ram nicht runter gehtggf stell die Instanz auf debug und zeig den Startvorgang aus dem Log
@arminrey Ich hab den Adapter nie unter Windows getestet. Aber die Zeile hier ist schon komisch:
2025-02-13 15:00:48.318 - [33mwarn[39m: host.ADMINIS-ROKLDQE-Server Objects 127.0.0.1:56580 Error from InMemDB: Error: ERROR writeFile-Meta id=shelly.0: UNKNOWN: unknown error, open 'C:\ioBroker\iobroker-data\files\shelly.0\_data.json'Stimmen da eventuell Ordnerrechte nicht?
@crunchip sagte in Shelly Instanz CoAp steigt seit inst. vom neuen Node.js aus:
bedeutet immer als Text in code-tags!
siehe auch:
https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge/1 -
@haus-automatisierung sagte in Shelly Instanz CoAp steigt seit inst. vom neuen Node.js aus:
Wenn ichs richtig gelesen habe, hat er ja 2 Instanzen, jedoch nur bei Instanz. 0 dieses Problem
Edit
Grad das log per Handy überflogen, da stimmt ja auch etwas nicht2025-02-13 15:04:15.400 - [31merror[39m: shelly.1 (16624) [MQTT] (Shelly?) device unknown, configuration for client with id "Gaszaehler" (Gaszaehler / Gaszaehler / undefined) does not exist! Maybe this device is not supported in this adapter version. 2025-02-13 15:04:15.400 - [31merror[39m: shelly.1 (16624) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details) 2025-02-13 15:04:15.411 - [32minfo[39m: shelly.1 (16624) [MQTT] Client Close: (Gaszaehler / Gaszaehler / undefined) (false) -
Edit
Grad das log per Handy überflogen, da stimmt ja auch etwas nicht2025-02-13 15:04:15.400 - [31merror[39m: shelly.1 (16624) [MQTT] (Shelly?) device unknown, configuration for client with id "Gaszaehler" (Gaszaehler / Gaszaehler / undefined) does not exist! Maybe this device is not supported in this adapter version. 2025-02-13 15:04:15.400 - [31merror[39m: shelly.1 (16624) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details) 2025-02-13 15:04:15.411 - [32minfo[39m: shelly.1 (16624) [MQTT] Client Close: (Gaszaehler / Gaszaehler / undefined) (false)@crunchip sagte in Shelly Instanz CoAp steigt seit inst. vom neuen Node.js aus:
Das ist aber egal und hat mit dem Fehler nix zu tun. Da wurde nur (mal wieder) die Doku nicht gelesen.
Gas hab ich raus, war mein Fehler.
Jetzt habe ich bei einem anderen NUC ein altes BackUp 31.12.24 drauf und nur mal den Shelly.0 gestartet. Da passiert das Gleiche. Bin mir aber sicher, dass das damals nicht war. Somit meine Vermutung, dass das an einem ShellyUpdate liegen kann? Nur mal so als User der sich freut, wenn alles läuft....
@arminrey Und die andere Frage zu den Rechten des Ordners? Zeig mal die Instanz-Einstellungen
Die Frage von voher, der "Schraubenschlüssel", wurde nichts angezeigt. Wenn man aber auf Version einstellen geht, dann kommen Fehlermeldungen, die Ihr vermutlich wolltet.
Aber das muss ich in Ruhe probieren, da blick ich nicht mehr durch..... komisch dass das vorher immer gegangen ist.
Bin von PI4 irgendwann auf P5, der hat dann auch gekotzt und nun auf NUC wo alles ohne dass die CPU auf 100% geht, läuft. Im Schnitt bei 20%.Hier der Prozess:
$ iobroker upgrade shelly@8.5.1 --debug
Update shelly from @8.5.0 to @8.5.1
host.ADMINIS-ROKLDQE Adapter "system.adapter.shelly.1" is stopped.
NPM version: 10.8.2
Installing iobroker.shelly@8.5.1... (System call)
diskusage@1.2.0 install > node-gyp rebuild
gyp info it worked if it ends with ok
gyp info using node-gyp@10.1.0 gyp info using node@20.18.3 | win32 | x64
gyp info find Python using Python version 3.13.1 found at "C:\Python313\python.exe"
gyp ERR! find VS gyp ERR! find VS msvs_version not set from command line or npm config gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt gyp ERR! find VS could not use PowerShell to find Visual Studio 2017 or newer, try re-running with '--loglevel silly' for more details. gyp ERR! find VS
gyp ERR! find VS Failure details: undefined gyp ERR! find VS checking VS2022 (17.12.35410.144) found at: gyp ERR! find VS "C:\Program Files\Microsoft Visual Studio\2022\Preview" gyp ERR! find VS - found "Visual Studio C++ core features" gyp ERR! find VS - missing any VC++ toolset gyp ERR! find VS checking VS2022 (17.11.35327.3) found at: gyp ERR! find VS "C:\Program Files\Microsoft Visual Studio\2022\Community" gyp ERR! find VS - found "Visual Studio C++ core features" gyp ERR! find VS - missing any VC++ toolset gyp ERR! find VS checking VS2019 (16.11.35731.53) found at: gyp ERR! find VS "C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools" gyp ERR! find VS - found "Visual Studio C++ core features" gyp ERR! find VS - found VC++ toolset: v142 gyp ERR! find VS - missing any Windows SDK gyp ERR! find VS could not find a version of Visual Studio 2017 or newer to use gyp ERR! find VS could not use PowerShell to find Visual Studio 2017 or newer, try re-running with '--loglevel silly' for more details. gyp ERR! find VS gyp ERR! find VS Failure details: undefined gyp ERR! find VS unsupported version "16.11.35731.53" found at "C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools" gyp ERR! find VS unsupported version "17.12.35410.144" found at "C:\Program Files\Microsoft Visual Studio\2022\Preview" gyp ERR! find VS unsupported version "17.11.35327.3" found at "C:\Program Files\Microsoft Visual Studio\2022\Community" gyp ERR! find VS could not find a version of Visual Studio 2017 or newer to use gyp ERR! find VS not looking for VS2015 as it is only supported up to Node.js 18 gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8 gyp ERR! find VS gyp ERR! find VS ************************************************************** gyp ERR! find VS You need to install the latest version of Visual Studio gyp ERR! find VS including the "Desktop development with C++" workload. gyp ERR! find VS For more information consult the documentation at: gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows gyp ERR! find VS ************************************************************** gyp ERR! find VS
gyp ERR! configure error gyp ERR! stack Error: Could not find any Visual Studio installation to use gyp ERR! stack at VisualStudioFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:116:11) gyp ERR! stack at VisualStudioFinder.findVisualStudio (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:72:17) gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:95:5) gyp ERR! stack at async createBuildDir (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:95:26) gyp ERR! stack at async run (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js:81:18) gyp ERR! System Windows_NT 10.0.22631 gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild" gyp ERR! cwd C:\ioBroker\node_modules\diskusage gyp ERR! node -v v20.18.3 gyp ERR! node-gyp -v v10.1.0 gyp ERR! not ok
unix-dgram@2.0.6 install > node-gyp rebuild
gyp ERR! find VS gyp ERR! find VS msvs_version not set from command line or npm config gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt gyp ERR! find VS could not use PowerShell to find Visual Studio 2017 or newer, try re-running with '--loglevel silly' for more details. gyp ERR! find VS gyp ERR! find VS Failure details: undefined gyp ERR! find VS checking VS2022 (17.12.35410.144) found at:
changed 1 package, and audited 1687 packages in 16s
305 packages are looking for funding run
npm fundfor details44 vulnerabilities (4 low, 27 moderate, 11 high, 2 critical)
To address issues that do not require attention, run: npm audit fix To address all issues possible (including breaking changes), run: npm audit fix --force Some issues need review, and may require choosing a different dependency. Run
npm auditfor details.Updating objects from io-package.json for adapter "shelly" with version "8.5.1"
Update "system.adapter.shelly.0"
Update "system.adapter.shelly.1"
upload [16] shelly.admin C:/ioBroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
upload [15] shelly.admin C:/ioBroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
upload [14] shelly.admin C:/ioBroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
upload [13] shelly.admin C:/ioBroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
upload [12] shelly.admin C:/ioBroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
upload [11] shelly.admin C:/ioBroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
upload [10] shelly.admin C:/ioBroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
upload [5] shelly.admin C:/ioBroker/node_modules/iobroker.shelly/admin/img/mqttGen1.png img/mqttGen1.png image/png
upload [4] shelly.admin C:/ioBroker/node_modules/iobroker.shelly/admin/img/mqttGen2.png img/mqttGen2.png image/png
upload [3] shelly.admin C:/ioBroker/node_modules/iobroker.shelly/admin/img/restrictedLoginGen1.png img/restrictedLoginGen1.png image/png
upload [2] shelly.admin C:/ioBroker/node_modules/iobroker.shelly/admin/img/restrictedLoginGen2.png img/restrictedLoginGen2.png image/png
upload [1] shelly.admin C:/ioBroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
upload [0] shelly.admin C:/ioBroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
host.ADMINIS-ROKLDQE Adapter "system.adapter.shelly.1" is started
Process exited with code 0
@arminrey sagte in Shelly Instanz CoAp steigt seit inst. vom neuen Node.js aus:
Dann geh doch mal ein paar Versionen zurück und teste
bzw@arminrey sagte in Shelly Instanz CoAp steigt seit inst. vom neuen Node.js aus:
was ist/war da für eine Version installiert und welche nodejs ist da drauf?
@crunchip
Mit dem TestNUC bin ich beim Shelly bis zu 3 Versionen runter gegangen. Bei Node bis zu 15 und dann stufenweise rauf.Ich schätze das hat was mit Visual und Pyton zu tun, nur da steige ich aus.
Ich liebe den iob wegen scripte und einfache Einbindung in KNX was bei HA mit dem yaml schon eine nervige Sache ist.
@crunchip
macht ja keinen Sinn, zumal gewisse Abhängigkeiten vorhanden sind und du oben schon den Hinweis bekommen hattest, ungerade nodejs Versionen sind tabu.
siehe z.b. v7.0.0
https://github.com/iobroker-community-adapters/ioBroker.shelly/releases@arminrey sagte in Shelly Instanz CoAp steigt seit inst. vom neuen Node.js aus:
Ich liebe den iob wegen scripte und einfache Einbindung in KNX was bei HA mit dem yaml schon eine nervige Sache ist.warum dann nicht einfach ein Linux nutzen?
siehe z.b. v7.0.0
So den TestNUC iob, visual und Python deinstalliert. Neu gestartet und iob neu inst.
Shelly installiert und ohne Fehlermeldungen zum laufen gebracht und läuft stabil.Werde das, wenn ich mal Zeit habe beim LiveNuC versuchen. Erst mal nur die Shelly Adapter löschen und dann neu aufsetzten.
... ich berichte
... ich berichte
Kein Change, das Problem direkt zu eliminieren. Trotzdem Dank an den Beteiligten, die versucht haben, mir zu helfen.
Ich schätze von BackUp und Restore von P4 auf P5 und dann noch auf NUC ist irgendwas schief gelaufen.
Habe den Shelly-Adapter gelöscht und wieder neu installiert und nachträglich die HistoryDB wieder aufgespielt um die alten Daten zu haben. Läuft jetzt seit 2 Tagen problemlos. Die Einstellungen der Objekte musste neu erstellt werden.
Ich hoffe, dass es nun läuft.
ByTheWay hatte ich damals für einen Fixer für PC gesucht. Lt. Google gibts den nur für Linux. Stimmt aber nicht, wenn man die Inst von W aktiviert und IOB installiert ist, läuft ein Fixer. (oder ich hatte es überlesen :man-shrugging: )
Gruß und Danke
