  4. Zugriff Iobroker im Internet Explorer funktioniert nicht
22 Beiträge 8 Kommentatoren 3.0k Aufrufe 8 Beobachtet
  • S Smartuser_1
    ```bash
    Script v.2025-02-02
    *** BASE SYSTEM ***
     Static hostname: raspberrypi5
           Icon name: computer
              Kernel: Linux 6.6.74+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     21:08:36 up 15 min,  2 users,  load average: 0.00, 0.00, 0.02
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2025-02-08 21:08:36 CET
               Universal time: Sat 2025-02-08 20:08:36 UTC
                     RTC time: Sat 2025-02-08 20:08:36
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    uld
    HOME=/home/uld
    GROUPS=uld adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.4G        747M        7.3G        7.5M        443M        7.7G
    Swap:           536M          0B        536M
    Total:          9.0G        747M        7.9G
    Active iob-Instances:   7
             8052 M total memory
              712 M used memory
              737 M active memory
              162 M inactive memory
             7007 M free memory
               35 M buffer memory
              387 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 21:08:36 up 15 min,  2 users,  load average: 0.08, 0.02, 0.02
    Tasks: 177 total,   1 running, 176 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8052.2 total,   7007.1 free,    712.7 used,    423.2 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7339.5 avail Mem
    *** FAILED SERVICES ***
      UNIT         LOAD   ACTIVE SUB    DESCRIPTION
    * nmbd.service loaded failed failed Samba NMB Daemon
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                  Type      Size  Used Avail Use% Mounted on
    udev                        devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs                       tmpfs     806M  7.2M  799M   1% /run
    /dev/mmcblk0p2              ext4       59G  5.5G   50G  10% /
    tmpfs                       tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs                       tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1              vfat      510M   55M  456M  11% /boot/firmware
    //wdmycloudmirror/Smarthome cifs      1.8T  573G  1.3T  32% /home/uld/Backup/share
    tmpfs                       tmpfs     806M     0  806M   0% /run/user/1000
    [Sat Feb  8 20:53:20 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:8B:D1:73 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=73e40d05-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Feb  8 20:53:23 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Sat Feb  8 20:53:24 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET                   SOURCE                      FSTYPE OPTIONS
    /                        /dev/mmcblk0p2              ext4   rw,noatime,commit=600
    |-/boot/firmware         /dev/mmcblk0p1              vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/home/uld/Backup/share //wdmycloudmirror/Smarthome cifs   rw,relatime,vers=default,cache=strict,username=uld,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.27,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,reparse=nfs,rsize=262144,wsize=262144,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
    /var:
    1.1G    /var/
    241M    /var/cache
    235M    /var/cache/apt
    185M    /var/lib
    135M    /var/lib/apt/lists
    Archived and active journals take up 92.0M in the file system.
    /opt/iobroker/backups:
    3.5M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    870M    /opt/iobroker/iobroker-data/
    826M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
    16M     /opt/iobroker/iobroker-data/objects.jsonl
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
    8.4M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.2
    /usr/bin/node           v20.18.2
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.2-1nodesource1
      Candidate: 20.18.2-1nodesource1
      Version table:
     *** 20.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi5        raspberrypi5 (version: 7.0.6, hostname: raspberrypi5  , alive, uptime: 903)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.10
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
    + system.adapter.history.0                : history               : raspberrypi5                             -  enabled
      system.adapter.influxdb.0               : influxdb              : raspberrypi5                             - disabled, port: 8086
    + system.adapter.javascript.0             : javascript            : raspberrypi5                             -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi5                             -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi5                             - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.4.10   , installed 7.4.10
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Objects and States
    Objects:        1132
    States:         404
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5667       651/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          935        775/smbd
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      106        845        634/influxd
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          934        775/smbd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2031       635/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2036       635/iobroker.js-con
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5669       651/sshd: /usr/sbin
    tcp6       0      0 :::139                  :::*                    LISTEN      0          933        775/smbd
    tcp6       0      0 :::445                  :::*                    LISTEN      0          932        775/smbd
    tcp6       0      0 :::8086                 :::*                    LISTEN      106        4846       634/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5003       840/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        712        530/avahi-daemon: r
    udp        0      0 0.0.0.0:37566           0.0.0.0:*                           104        714        530/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        713        530/avahi-daemon: r
    udp6       0      0 :::59334                :::*                                104        715        530/avahi-daemon: r
    udp6       0      0 fe80::cef1:bbf1:e04:546 :::*                                0          952        606/NetworkManager
    2025-02-08 20:52:47.882  - warn: discovery.0 (826) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2025-02-08 20:52:48.404  - error: host.raspberrypi5 instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2025-02-08 20:52:48.404  - info: host.raspberrypi5 Restart adapter system.adapter.discovery.0 because enabled
    2025-02-08 20:54:01.465  - info: host.raspberrypi5 instance system.adapter.admin.0 in version "7.4.10" started with pid 840
    2025-02-08 20:54:02.316  - info: admin.0 (840) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.2, js-controller: 7.0.6
    2025-02-08 20:54:02.338  - info: admin.0 (840) requesting all objects
    2025-02-08 20:54:02.695  - info: admin.0 (840) received all objects
    2025-02-08 20:54:02.939  - info: admin.0 (840) Secure socket.io server listening on port 8081
    2025-02-08 20:54:02.940  - info: admin.0 (840) https server listening on port 8081
    2025-02-08 20:54:02.941  - info: admin.0 (840) Use link "https://127.0.0.1:8081" to configure.
    2025-02-08 20:54:04.743  - info: host.raspberrypi5 instance system.adapter.history.0 in version "3.0.1" started with pid 882
    2025-02-08 20:54:05.536  - info: history.0 (882) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.history, node: v20.18.2, js-controller: 7.0.6
    2025-02-08 20:54:09.326  - info: host.raspberrypi5 instance system.adapter.javascript.0 in version "8.8.3" started with pid 906
    2025-02-08 20:54:10.314  - info: javascript.0 (906) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.2, js-controller: 7.0.6
    2025-02-08 20:54:10.472  - info: javascript.0 (906) requesting all states
    2025-02-08 20:54:10.473  - info: javascript.0 (906) requesting all objects
    2025-02-08 20:54:10.678  - info: javascript.0 (906) received all objects
    2025-02-08 20:54:10.721  - info: javascript.0 (906) received all states
    2025-02-08 20:54:12.741  - info: host.raspberrypi5 instance system.adapter.scenes.0 in version "3.2.3" started with pid 921
    2025-02-08 20:54:13.373  - info: scenes.0 (921) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.scenes, node: v20.18.2, js-controller: 7.0.6
    2025-02-08 20:54:16.824  - info: host.raspberrypi5 instance system.adapter.backitup.0 in version "3.0.31" started with pid 936
    2025-02-08 20:54:17.525  - info: backitup.0 (936) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.18.2, js-controller: 7.0.6
    2025-02-08 20:54:17.549  - info: backitup.0 (936) [iobroker] backup will be activated at 02:48 every 7 day(s)
    2025-02-08 20:54:20.789  - info: host.raspberrypi5 instance system.adapter.discovery.0 in version "5.0.0" started with pid 959
    2025-02-08 20:54:21.428  - info: discovery.0 (959) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.18.2, js-controller: 7.0.6
    verstehe nicht, das der komplette Zugriff sonst funktioniert ???
    @smartuser_1 sagte in Zugriff Iobroker im Internet Explorer funktioniert nicht:
    wie bereits geschrieben
    @homoran sagte in Zugriff Iobroker im Internet Explorer funktioniert nicht:
    alles was du getestet hast läuft auf anderen Ebenen als der Zugriff auf den Admin.
    und da stellt sich due Frage ob du das
    berücksichtigt hast
      berücksichtigt hast
      Smartuser_1
      das verstehe ich jetzt leider nicht. Die Seite hat ja mal funktioniert. Ich suche jetzt schon überall in den Einstellungen, ob irgendwelche Firewalls anschlagen o.ä. Die Netzwerkeinstellungen habe ich auch schon zurückgesetzt ... Was könnte ich sonst noch machen?
      • S Smartuser_1
        wie versuchst du "die Seite" aufzurufen?
          Smartuser_1
          über http://192.xxx:8081
          Habe es auch über ein tablet (unabhängig vom PC) versucht. Auch da ging es leider nicht bzw. es kam die Meldung, daß Safari die Seite nicht öffnen kann.
          Apple & Windows PC haben ja nun gar nix miteinander zu tun und die verwendete IP Adresse stimmt.
          Fritzbox habe ich auch schon neu gestartet, der 2. Raspi ist auch wie gewohnt erreichbar
          ? HomoranH 2 Antworten Letzte Antwort
          • S Smartuser_1
            @smartuser_1
            https ist richtig..
            • S Smartuser_1
              und genau das geht nicht.
              Du hast in der Konfiguration SSL, also gesicherte Verbindung, eingestellt.
              dann musst du https://192.... nehmen
                Smartuser_1
                vielen Dank, jetzt bin ich einen Schritt weiter und komme auf das System :-)
                Warum wird dann trotzdem "Nicht sicher" in der Adressleiste angezeigt? Muss da noch eine weitere Einstellung o.ä. gemacht werden?
                Danke & Vg
                MartinPM HomoranH CodierknechtC 4 Antworten Letzte Antwort
                • S Smartuser_1
                  Danke & Vg
                  MartinPM Online
                  MartinPM Online
                  MartinP
                  @smartuser_1 Deinem HTTPS Zertifikat wird nicht vertraut.
                  Die Verbindung selber ist wohl trotzdem sicher.
                  Edit: Habe das Symbol im Screenshot nicht gesehen. Bei dieser Ausprägung weiß ich nicht, ob verschlüsselt wird.
                  • S Smartuser_1
                    Danke & Vg
                    weil du wahrscheinlich kein offizielles (teures) Zertifikat eineröffentlich überprüfbaren CA (Zertifikatsausgabestelle) verwendest
                    • S Smartuser_1
                      Danke & Vg
                      CodierknechtC Offline
                      Codierknecht
                      @smartuser_1
                      by the way: Deine IP's im lokalen Netz musst Du nicht anonymisieren.
                      Die sehen bei uns allen gleich oder zumindest ähnlich aus.
                      HmIP|ZigBee|Tasmota|Unifi
                      Zabbix Certified Specialist
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        Die sind nicht mehr teuer. Sie sind kostenlos
                        https://letsencrypt.org/
                        Die machen das aber nur für Domains im Internet und nicht im LAN
                        Für lokale Webserver macht das überhaupt keinen Sinn.
                        Falls man das dennoch will und auch die Browser Meldung weg haben möchte, muss man sich eine eigene CA aufbauen. Dieses Root Zertifikat muss man dann im Browser importieren bzw. in Windows registrieren.
                        Die Browser bringen einen ganzen Sack voller vorregistrierten Root Zertifikate mit.
                        So kann man die sich anzeigen lassen
                        https://security.stackexchange.com/questions/168271/how-to-view-all-the-certificates-that-are-loaded-in-to-chrome-or-any-browsers-or
                        SSL ist eine Transportverschlüsselung.
                        Wer keine NSA im netz hat, die den Router kontrolliert oder seinen Teenagern misstraut braucht das nicht.
                        Die müssten aber dann ein deep inspection System auf dem Router einrichten, der in jedem Päckchen nach Zugangsdaten, Bankverbindung oder kreditkarteninformationen sucht, so das die dann entsprechen Weiterverwertung werden könnten.
                        Meine Adapter und Widgets
                        Links im Profil
                        HomoranH D 2 Antworten Letzte Antwort
                        • S Smartuser_1
                          Danke & Vg
                          Codierknecht
                          @smartuser_1
                          Wieso willst Du da denn unbedingt über HTTPS zugreifen?
                          Droht da im eigenen Haus eine Man-In-The-Middle-Attacke durch rebellierende Pupertisten?
                          Wenn nicht: Schalte doch einfach SSL ab und greife unverschlüsselt darauf zu.
                          • OliverIOO OliverIO
                            @oliverio sagte in Zugriff Iobroker im Internet Explorer funktioniert nicht:
                            hat aber lange gedauert 😀
                            Hab mit dem Einwurf früher gerechnet
                              darkiop
                              Du kannst LE durchaus für lokales verwenden - mit einem lokalen DNS der die lokale Domain verwaltet.
                              Betreibe das hier auch schon seit vielen Jahren so, weil ich Geräte und Netzübergreifend die Zertifikatsfehler nicht mehr sehen konnte.
                              Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
