  4. Neuer Adapter ioBroker.evcc
277 Beiträge 44 Kommentatoren 71.6k Aufrufe 41 Beobachtet
  • arteckA arteck
    Leute wie währe es mit einem LOG ... ?? adapter auf debug und posten
    bei mir wird alles aktualisiert ..
    VAgemarV Offline
    VAgemarV Offline
    VAgemar
    #105
    @arteck Hier mein Log
    2025-01-24 11:48:57.784 - info: host.iobroker stopInstance system.adapter.evcc.0 (force=false, process=true)
    2025-01-24 11:48:57.799 - info: evcc.0 (10591) Got terminate signal TERMINATE_YOURSELF
    2025-01-24 11:48:57.804 - info: evcc.0 (10591) terminating
    2025-01-24 11:48:57.807 - info: evcc.0 (10591) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-01-24 11:48:57.835 - info: host.iobroker stopInstance system.adapter.evcc.0 send kill signal
    2025-01-24 11:48:58.311 - info: evcc.0 (10591) terminating
    2025-01-24 11:48:58.417 - info: host.iobroker instance system.adapter.evcc.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-01-24 11:48:58.466 - silly: parser.0 (30905) Objects system redis pmessage system.config/cfg.o.system.config:{"_id":"system.config","type":"config","common":{"name":{"en":"System configuration","de":"Systemkonfiguration","ru":"Конфигурация системы","pt":"Configuração do sistema","nl":"Systeem configuratie","fr":"Configuration du système","it":"Configurazione di sistema","es":"Configuración del sistema","pl":"Konfiguracja systemu","zh-cn":"系统配置"},"city":"Wiesbaden","country":"Germany","longitude":8.1821016,"latitude":50.0682379,"language":"de","tempUnit":"°C","currency":"€","dontDelete":true,"dateFormat":"DD.MM.YYYY","isFloatComma":true,"licenseConfirmed":true,"defaultHistory":"history.0","expertMode":false,"defaultLogLevel":"info","activeRepo":["stable"],"diag":"extended","tabs":["tab-intro","tab-info","tab-adapters","tab-instances","tab-objects","tab-log","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0"],"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":true},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-backitup-0","visible":true},{"name":"tab-info","visible":true},{"name":"tab-javascript","visible":true},{"name":"tab-vis-inventwo-0","visible":true},{"name":"tab-ring","visible":true}],"defaultNewAcl":{"object":1636,"state":1636,"file":1632,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"firstDayOfWeek":"monday"},"native":{"secret":"46ab018746eb811f0209dcc32bcb9bf1abe49b90e0b2f1a3"},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1737715738448}
    2025-01-24 11:49:02.466 - info: host.iobroker instance system.adapter.evcc.0 in version "0.1.1" started with pid 10800
    2025-01-24 11:49:04.699 - debug: evcc.0 (10800) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2025-01-24 11:49:04.743 - debug: evcc.0 (10800) Objects client ready ... initialize now
    2025-01-24 11:49:04.746 - debug: evcc.0 (10800) Objects create System PubSub Client
    2025-01-24 11:49:04.747 - debug: evcc.0 (10800) Objects create User PubSub Client
    2025-01-24 11:49:04.809 - debug: evcc.0 (10800) Objects client initialize lua scripts
    2025-01-24 11:49:04.818 - debug: evcc.0 (10800) Objects connected to redis: 127.0.0.1:9001
    2025-01-24 11:49:04.854 - debug: evcc.0 (10800) Redis States: Use Redis connection: 127.0.0.1:9000
    2025-01-24 11:49:04.873 - debug: evcc.0 (10800) States create System PubSub Client
    2025-01-24 11:49:04.875 - debug: evcc.0 (10800) States create User PubSub Client
    2025-01-24 11:49:04.908 - debug: evcc.0 (10800) States connected to redis: 127.0.0.1:9000
    2025-01-24 11:49:05.145 - info: evcc.0 (10800) starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.evcc, node: v18.20.5, js-controller: 7.0.3
    2025-01-24 11:49:05.172 - debug: evcc.0 (10800) Final Ip:iobroker:7070
    2025-01-24 11:49:05.175 - debug: evcc.0 (10800) call: http://iobroker:7070/api/state
    2025-01-24 11:49:05.207 - debug: evcc.0 (10800) config ip: iobroker
    2025-01-24 11:49:05.208 - debug: evcc.0 (10800) config polltime: 100
    2025-01-24 11:49:05.256 - debug: evcc.0 (10800) Get-Data from evcc:{"result":{"auth":{},"aux":[],"battery":[{"power":-35,"energy":2405.91,"capacity":0,"soc":1,"controllable":true}],"batteryCapacity":1,"batteryDischargeControl":false,"batteryEnergy":2405.91,"batteryGridChargeActive":false,"batteryMode":"unknown","batteryPower":-35,"batterySoc":1,"bufferSoc":90,"bufferStartSoc":92,"currency":"EUR","eebus":false,"ext":[],"fatal":null,"greenShareHome":0.225,"greenShareLoadpoints":0,"grid":{"power":731,"energy":3932.03,"currents":[1.76,1.46,2.06]},"gridConfigured":true,"hems":{},"homePower":898,"influx":{"url":"","database":"","org":"","user":"","insecure":false},"interval":30,"loadpoints":[{"batteryBoost":false,"chargeCurrent":0,"chargeCurrents":[0,0,0],"chargeDuration":0,"chargePower":0,"chargeTotalImport":0,"chargedEnergy":0,"chargerFeatureHeating":false,"chargerFeatureIntegratedDevice":false,"chargerIcon":null,"chargerPhases1p3p":true,"chargerPhysicalPhases":null,"chargerStatusReason":"unknown","charging":false,"connected":false,"connectedDuration":2147483647,"disableDelay":180,"disableThreshold":0,"effectiveLimitSoc":100,"effectiveMaxCurrent":16,"effectiveMinCurrent":6,"effectivePlanId":0,"effectivePlanSoc":0,"effectivePlanTime":null,"effectivePriority":0,"enableDelay":120,"enableThreshold":0,"enabled":false,"limitEnergy":0,"limitSoc":0,"maxCurrent":16,"minCurrent":6,"mode":"pv","phaseAction":"inactive","phaseRemaining":0,"phasesActive":3,"phasesConfigured":0,"phasesEnabled":0,"planActive":false,"planEnergy":0,"planOverrun":0,"planProjectedEnd":null,"planProjectedStart":null,"planTime":null,"priority":0,"pvAction":"inactive","pvRemaining":0,"sessionCo2PerKWh":null,"sessionEnergy":0,"sessionPrice":null,"sessionPricePerKWh":null,"sessionSolarPercentage":0,"smartCostActive":false,"smartCostNextStart":null,"title":"Carport","vehicleClimaterActive":null,"vehicleDetectionActive":false,"vehicleLimitSoc":0,"vehicleName":"","vehicleOdometer":0,"vehicleRange":0,"vehicleSoc":0,"vehicleWelcomeActive":false}],"messaging":true,"modbusproxy":null,"mqtt":{"broker":"","topic":"evcc"},"network":{"schema":"http","host":"evcc.local","port":7070},"prioritySoc":80,"pv":[{"power":202,"energy":6157.39}],"pvEnergy":6157.39,"pvPower":202,"residualPower":100,"siteTitle":"Sterntaler","smartCostType":"pricestatic","sponsor":{"name":"VAgemar","expiresAt":"2026-11-13T07:00:00Z"},"statistics":{"30d":{"avgCo2":0,"avgPrice":0,"chargedKWh":0,"solarPercentage":0},"365d":{"avgCo2":0,"avgPrice":0,"chargedKWh":0,"solarPercentage":0},"thisYear":{"avgCo2":0,"avgPrice":0,"chargedKWh":0,"solarPercentage":0},"total":{"avgCo2":0,"avgPrice":0.07999999999999986,"chargedKWh":33.92345573820841,"solarPercentage":100.00000000000001}},"tariffFeedIn":0.19,"tariffGrid":0.409,"tariffPriceHome":0.36,"tariffPriceLoadpoints":0.409,"vehicles":{},"version":"0.133.0"}}
    2025-01-24 11:49:05.259 - debug: evcc.0 (10800) Ladepunkt mit index loadpoint.1 gefunden...
    2025-01-24 11:49:05.259 - info: evcc.0 (10800) Lege neuen Ladepunkt an mit Index: 1
    MOD-EDIT: BITTE CODETAGS BENUTZEN!!!
    • Merlin123M Merlin123
      @arteck Ups. Sorry..
      Hier man bei mir:
      evcc.0
      2025-01-24 10:01:47.501	debug	Vehicle mit index db:2 gefunden...
      evcc.0
      2025-01-24 10:01:47.466	debug	Vehicle mit index db:1 gefunden...
      evcc.0
      2025-01-24 10:01:47.465	debug	Ladepunkt mit index loadpoint.1 gefunden...
      evcc.0
      2025-01-24 10:01:47.465	debug	Get-Data from evcc:{"result":{"auth":{},"aux":[],"battery":[],"batteryDischargeControl":false,"batteryGridChargeActive":false,"batteryMode":"unknown","bufferSoc":0,"bufferStartSoc":0,"currency":"EUR","eebus":false,"ext":[],"fatal":null,"greenShareHome":0.337,"greenShareLoadpoints":0,"grid":{"power":278,"energy":20101.277000000002,"powers":[151,5,124],"currents":[2.1,1.3,1.9000000000000001]},"gridConfigured":true,"hems":{},"homePower":419,"influx":{"url":"","database":"","org":"","user":"","insecure":false},"interval":10,"loadpoints":[{"batteryBoost":false,"chargeCurrent":0,"chargeCurrents":[0,0,0],"chargeDuration":16670,"chargePower":0,"chargeRemainingDuration":0,"chargeRemainingEnergy":0,"chargeTotalImport":6497.547,"chargedEnergy":48318,"chargerFeatureHeating":false,"chargerFeatureIntegratedDevice":false,"chargerIcon":null,"chargerPhases1p3p":true,"chargerPhysicalPhases":null,"chargerStatusReason":"unknown","charging":false,"connected":false,"connectedDuration":51860,"disableDelay":300,"disableThreshold":200,"effectiveLimitSoc":100,"effectiveMaxCurrent":16,"effectiveMinCurrent":6,"effectivePlanId":0,"effectivePlanSoc":0,"effectivePlanTime":null,"effectivePriority":0,"enableDelay":60,"enableThreshold":0,"enabled":false,"limitEnergy":0,"limitSoc":0,"maxCurrent":16,"minCurrent":6,"mode":"pv","phaseAction":"inactive","phaseRemaining":0,"phasesActive":3,"phasesConfigured":0,"phasesEnabled":3,"planActive":false,"planEnergy":0,"planOverrun":0,"planProjectedEnd":null,"planProjectedStart":null,"planTime":null,"priority":0,"pvAction":"inactive","pvRemaining":0,"sessionCo2PerKWh":175.999,"sessionEnergy":48318,"sessionPrice":12.859,"sessionPricePerKWh":0.266,"sessionSolarPercentage":0,"smartCostActive":true,"smartCostLimit":0.322,"smartCostNextStart":null,"title":"Hof","vehicleClimaterActive":null,"vehicleDetectionActive":false,"vehicleLimitSoc":0,"vehicleName":"","vehicleOdometer":0,"vehicleRange":0,"vehicleSoc":0,"vehicleWelcomeActive":false}],"messaging":true,"modbusproxy":[{"Port":5200,"ReadOnly":"","ID":0,"SubDevice":0,"URI":"192.168.0.191:1502","Device":"","Comset":"","Baudrate":0,"UDP":false,"RTU":null}],"mqtt":{"broker":"","topic":"evcc"},"network":{"schema":"http","host":"evcc.local","port":7070},"prioritySoc":0,"pv":[{"power":141,"energy":40477.616}],"pvEnergy":40477.616,"pvPower":141,"residualPower":0,"siteTitle":"Völkers Home","smartCostType":"priceforecast","sponsor":{"name":"Horgul123","expiresAt":"2026-05-25T08:05:39Z"},"statistics":{"30d":{"avgCo2":206.87025292202992,"avgPrice":0.2999112449359893,"chargedKWh":510.56900000000223,"solarPercentage":0.579682850130254},"365d":{"avgCo2":147.9071869776837,"avgPrice":0.2112740572536854,"chargedKWh":4443.607329636601,"solarPercentage":19.913539536435394},"thisYear":{"avgCo2":206.87025292202992,"avgPrice":0.3038918162204524,"chargedKWh":447.6030000000019,"solarPercentage":0.6612290201543638},"total":{"avgCo2":156.65264782022217,"avgPrice":0.2014120544476205,"chargedKWh":6154.749174771228,"solarPercentage":25.83035819467612}},"tariffCo2":141,"tariffCo2Home":93.551,"tariffCo2Loadpoints":141,"tariffFeedIn":0.139,"tariffGrid":0.309,"tariffPriceHome":0.252,"tariffPriceLoadpoints":0.309,"vehicles":{"db:1":{"title":"Olis Enyaq","icon":"car","capacity":77,"repeatingPlans":[]},"db:2":{"title":"hannahs_2008","icon":"car","capacity":46,"features":["Offline","Retryable"],"repeatingPlans":[]}},"version":"0.133.0"}}
      evcc.0
      2025-01-24 10:01:47.462	debug	call: http://192.168.1.33:7070/api/state
      evcc.0
      2025-01-24 10:01:42.509	debug	Vehicle mit index db:2 gefunden...
      evcc.0
      2025-01-24 10:01:42.467	debug	Vehicle mit index db:1 gefunden...
      evcc.0
      2025-01-24 10:01:42.467	debug	Ladepunkt mit index loadpoint.1 gefunden...
      evcc.0
      2025-01-24 10:01:42.466	debug	Get-Data from evcc:{"result":{"auth":{},"aux":[],"battery":[],"batteryDischargeControl":false,"batteryGridChargeActive":false,"batteryMode":"unknown","bufferSoc":0,"bufferStartSoc":0,"currency":"EUR","eebus":false,"ext":[],"fatal":null,"greenShareHome":0.337,"greenShareLoadpoints":0,"grid":{"power":278,"energy":20101.277000000002,"powers":[151,5,124],"currents":[2.1,1.3,1.9000000000000001]},"gridConfigured":true,"hems":{},"homePower":419,"influx":{"url":"","database":"","org":"","user":"","insecure":false},"interval":10,"loadpoints":[{"batteryBoost":false,"chargeCurrent":0,"chargeCurrents":[0,0,0],"chargeDuration":16670,"chargePower":0,"chargeRemainingDuration":0,"chargeRemainingEnergy":0,"chargeTotalImport":6497.547,"chargedEnergy":48318,"chargerFeatureHeating":false,"chargerFeatureIntegratedDevice":false,"chargerIcon":null,"chargerPhases1p3p":true,"chargerPhysicalPhases":null,"chargerStatusReason":"unknown","charging":false,"connected":false,"connectedDuration":51860,"disableDelay":300,"disableThreshold":200,"effectiveLimitSoc":100,"effectiveMaxCurrent":16,"effectiveMinCurrent":6,"effectivePlanId":0,"effectivePlanSoc":0,"effectivePlanTime":null,"effectivePriority":0,"enableDelay":60,"enableThreshold":0,"enabled":false,"limitEnergy":0,"limitSoc":0,"maxCurrent":16,"minCurrent":6,"mode":"pv","phaseAction":"inactive","phaseRemaining":0,"phasesActive":3,"phasesConfigured":0,"phasesEnabled":3,"planActive":false,"planEnergy":0,"planOverrun":0,"planProjectedEnd":null,"planProjectedStart":null,"planTime":null,"priority":0,"pvAction":"inactive","pvRemaining":0,"sessionCo2PerKWh":175.999,"sessionEnergy":48318,"sessionPrice":12.859,"sessionPricePerKWh":0.266,"sessionSolarPercentage":0,"smartCostActive":true,"smartCostLimit":0.322,"smartCostNextStart":null,"title":"Hof","vehicleClimaterActive":null,"vehicleDetectionActive":false,"vehicleLimitSoc":0,"vehicleName":"","vehicleOdometer":0,"vehicleRange":0,"vehicleSoc":0,"vehicleWelcomeActive":false}],"messaging":true,"modbusproxy":[{"Port":5200,"ReadOnly":"","ID":0,"SubDevice":0,"URI":"192.168.0.191:1502","Device":"","Comset":"","Baudrate":0,"UDP":false,"RTU":null}],"mqtt":{"broker":"","topic":"evcc"},"network":{"schema":"http","host":"evcc.local","port":7070},"prioritySoc":0,"pv":[{"power":141,"energy":40477.616}],"pvEnergy":40477.616,"pvPower":141,"residualPower":0,"siteTitle":"Völkers Home","smartCostType":"priceforecast","sponsor":{"name":"Horgul123","expiresAt":"2026-05-25T08:05:39Z"},"statistics":{"30d":{"avgCo2":206.87025292202992,"avgPrice":0.2999112449359893,"chargedKWh":510.56900000000223,"solarPercentage":0.579682850130254},"365d":{"avgCo2":147.9071869776837,"avgPrice":0.2112740572536854,"chargedKWh":4443.607329636601,"solarPercentage":19.913539536435394},"thisYear":{"avgCo2":206.87025292202992,"avgPrice":0.3038918162204524,"chargedKWh":447.6030000000019,"solarPercentage":0.6612290201543638},"total":{"avgCo2":156.65264782022217,"avgPrice":0.2014120544476205,"chargedKWh":6154.749174771228,"solarPercentage":25.83035819467612}},"tariffCo2":141,"tariffCo2Home":93.551,"tariffCo2Loadpoints":141,"tariffFeedIn":0.139,"tariffGrid":0.309,"tariffPriceHome":0.252,"tariffPriceLoadpoints":0.309,"vehicles":{"db:1":{"title":"Olis Enyaq","icon":"car","capacity":77,"repeatingPlans":[]},"db:2":{"title":"hannahs_2008","icon":"car","capacity":46,"features":["Offline","Retryable"],"repeatingPlans":[]}},"version":"0.133.0"}}
      evcc.0
      2025-01-24 10:01:42.462	debug	call: http://192.168.1.33:7070/api/state
      evcc.0
      2025-01-24 10:01:37.502	debug	Vehicle mit index db:2 gefunden...
      evcc.0
      2025-01-24 10:01:37.466	debug	Vehicle mit index db:1 gefunden...
      evcc.0
      2025-01-24 10:01:37.465	debug	Ladepunkt mit index loadpoint.1 gefunden...
      evcc.0
      2025-01-24 10:01:37.465	debug	Get-Data from evcc:{"result":{"auth":{},"aux":[],"battery":[],"batteryDischargeControl":false,"batteryGridChargeActive":false,"batteryMode":"unknown","bufferSoc":0,"bufferStartSoc":0,"currency":"EUR","eebus":false,"ext":[],"fatal":null,"greenShareHome":0.319,"greenShareLoadpoints":0,"grid":{"power":307,"energy":20101.277000000002,"powers":[153,7,140],"currents":[2.1,1.3,1.9000000000000001]},"gridConfigured":true,"hems":{},"homePower":451,"influx":{"url":"","database":"","org":"","user":"","insecure":false},"interval":10,"loadpoints":[{"batteryBoost":false,"chargeCurrent":0,"chargeCurrents":[0,0,0],"chargeDuration":16670,"chargePower":0,"chargeRemainingDuration":0,"chargeRemainingEnergy":0,"chargeTotalImport":6497.547,"chargedEnergy":48318,"chargerFeatureHeating":false,"chargerFeatureIntegratedDevice":false,"chargerIcon":null,"chargerPhases1p3p":true,"chargerPhysicalPhases":null,"chargerStatusReason":"unknown","charging":false,"connected":false,"connectedDuration":51860,"disableDelay":300,"disableThreshold":200,"effectiveLimitSoc":100,"effectiveMaxCurrent":16,"effectiveMinCurrent":6,"effectivePlanId":0,"effectivePlanSoc":0,"effectivePlanTime":null,"effectivePriority":0,"enableDelay":60,"enableThreshold":0,"enabled":false,"limitEnergy":0,"limitSoc":0,"maxCurrent":16,"minCurrent":6,"mode":"pv","phaseAction":"inactive","phaseRemaining":0,"phasesActive":3,"phasesConfigured":0,"phasesEnabled":3,"planActive":false,"planEnergy":0,"planOverrun":0,"planProjectedEnd":null,"planProjectedStart":null,"planTime":null,"priority":0,"pvAction":"inactive","pvRemaining":0,"sessionCo2PerKWh":175.999,"sessionEnergy":48318,"sessionPrice":12.859,"sessionPricePerKWh":0.266,"sessionSolarPercentage":0,"smartCostActive":true,"smartCostLimit":0.322,"smartCostNextStart":null,"title":"Hof","vehicleClimaterActive":null,"vehicleDetectionActive":false,"vehicleLimitSoc":0,"vehicleName":"","vehicleOdometer":0,"vehicleRange":0,"vehicleSoc":0,"vehicleWelcomeActive":false}],"messaging":true,"modbusproxy":[{"Port":5200,"ReadOnly":"","ID":0,"SubDevice":0,"URI":"192.168.0.191:1502","Device":"","Comset":"","Baudrate":0,"UDP":false,"RTU":null}],"mqtt":{"broker":"","topic":"evcc"},"network":{"schema":"http","host":"evcc.local","port":7070},"prioritySoc":0,"pv":[{"power":144,"energy":40477.616}],"pvEnergy":40477.616,"pvPower":144,"residualPower":0,"siteTitle":"Völkers Home","smartCostType":"priceforecast","sponsor":{"name":"Horgul123","expiresAt":"2026-05-25T08:05:39Z"},"statistics":{"30d":{"avgCo2":206.87025292202992,"avgPrice":0.2999112449359893,"chargedKWh":510.56900000000223,"solarPercentage":0.579682850130254},"365d":{"avgCo2":147.9071869776837,"avgPrice":0.2112740572536854,"chargedKWh":4443.607329636601,"solarPercentage":19.913539536435394},"thisYear":{"avgCo2":206.87025292202992,"avgPrice":0.3038918162204524,"chargedKWh":447.6030000000019,"solarPercentage":0.6612290201543638},"total":{"avgCo2":156.65264782022217,"avgPrice":0.2014120544476205,"chargedKWh":6154.749174771228,"solarPercentage":25.83035819467612}},"tariffCo2":141,"tariffCo2Home":95.98,"tariffCo2Loadpoints":141,"tariffFeedIn":0.139,"tariffGrid":0.309,"tariffPriceHome":0.254,"tariffPriceLoadpoints":0.309,"vehicles":{"db:1":{"title":"Olis Enyaq","icon":"car","capacity":77,"repeatingPlans":[]},"db:2":{"title":"hannahs_2008","icon":"car","capacity":46,"features":["Offline","Retryable"],"repeatingPlans":[]}},"version":"0.133.0"}}
      evcc.0
      2025-01-24 10:01:37.461	debug	call: http://192.168.1.33:7070/api/state
      evcc.0
      2025-01-24 10:01:32.525	debug	Vehicle mit index db:2 gefunden...
      evcc.0
      2025-01-24 10:01:32.464	debug	Vehicle mit index db:1 gefunden...
      evcc.0
      2025-01-24 10:01:32.464	debug	Ladepunkt mit index loadpoint.1 gefunden...
      evcc.0
      2025-01-24 10:01:32.464	debug	Get-Data from evcc:{"result":{"auth":{},"aux":[],"battery":[],"batteryDischargeControl":false,"batteryGridChargeActive":false,"batteryMode":"unknown","bufferSoc":0,"bufferStartSoc":0,"currency":"EUR","eebus":false,"ext":[],"fatal":null,"greenShareHome":0.319,"greenShareLoadpoints":0,"grid":{"power":307,"energy":20101.277000000002,"powers":[153,7,140],"currents":[2.1,1.3,1.9000000000000001]},"gridConfigured":true,"hems":{},"homePower":451,"influx":{"url":"","database":"","org":"","user":"","insecure":false},"interval":10,"loadpoints":[{"batteryBoost":false,"chargeCurrent":0,"chargeCurrents":[0,0,0],"chargeDuration":16670,"chargePower":0,"chargeRemainingDuration":0,"chargeRemainingEnergy":0,"chargeTotalImport":6497.547,"chargedEnergy":48318,"chargerFeatureHeating":false,"chargerFeatureIntegratedDevice":false,"chargerIcon":null,"chargerPhases1p3p":true,"chargerPhysicalPhases":null,"chargerStatusReason":"unknown","charging":false,"connected":false,"connectedDuration":51860,"disableDelay":300,"disableThreshold":200,"effectiveLimitSoc":100,"effectiveMaxCurrent":16,"effectiveMinCurrent":6,"effectivePlanId":0,"effectivePlanSoc":0,"effectivePlanTime":null,"effectivePriority":0,"enableDelay":60,"enableThreshold":0,"enabled":false,"limitEnergy":0,"limitSoc":0,"maxCurrent":16,"minCurrent":6,"mode":"pv","phaseAction":"inactive","phaseRemaining":0,"phasesActive":3,"phasesConfigured":0,"phasesEnabled":3,"planActive":false,"planEnergy":0,"planOverrun":0,"planProjectedEnd":null,"planProjectedStart":null,"planTime":null,"priority":0,"pvAction":"inactive","pvRemaining":0,"sessionCo2PerKWh":175.999,"sessionEnergy":48318,"sessionPrice":12.859,"sessionPricePerKWh":0.266,"sessionSolarPercentage":0,"smartCostActive":true,"smartCostLimit":0.322,"smartCostNextStart":null,"title":"Hof","vehicleClimaterActive":null,"vehicleDetectionActive":false,"vehicleLimitSoc":0,"vehicleName":"","vehicleOdometer":0,"vehicleRange":0,"vehicleSoc":0,"vehicleWelcomeActive":false}],"messaging":true,"modbusproxy":[{"Port":5200,"ReadOnly":"","ID":0,"SubDevice":0,"URI":"192.168.0.191:1502","Device":"","Comset":"","Baudrate":0,"UDP":false,"RTU":null}],"mqtt":{"broker":"","topic":"evcc"},"network":{"schema":"http","host":"evcc.local","port":7070},"prioritySoc":0,"pv":[{"power":144,"energy":40477.616}],"pvEnergy":40477.616,"pvPower":144,"residualPower":0,"siteTitle":"Völkers Home","smartCostType":"priceforecast","sponsor":{"name":"Horgul123","expiresAt":"2026-05-25T08:05:39Z"},"statistics":{"30d":{"avgCo2":206.87025292202992,"avgPrice":0.2999112449359893,"chargedKWh":510.56900000000223,"solarPercentage":0.579682850130254},"365d":{"avgCo2":147.9071869776837,"avgPrice":0.2112740572536854,"chargedKWh":4443.607329636601,"solarPercentage":19.913539536435394},"thisYear":{"avgCo2":206.87025292202992,"avgPrice":0.3038918162204524,"chargedKWh":447.6030000000019,"solarPercentage":0.6612290201543638},"total":{"avgCo2":156.65264782022217,"avgPrice":0.2014120544476205,"chargedKWh":6154.749174771228,"solarPercentage":25.83035819467612}},"tariffCo2":141,"tariffCo2Home":95.98,"tariffCo2Loadpoints":141,"tariffFeedIn":0.139,"tariffGrid":0.309,"tariffPriceHome":0.254,"tariffPriceLoadpoints":0.309,"vehicles":{"db:1":{"title":"Olis Enyaq","icon":"car","capacity":77,"repeatingPlans":[]},"db:2":{"title":"hannahs_2008","icon":"car","capacity":46,"features":["Offline","Retryable"],"repeatingPlans":[]}},"version":"0.133.0"}}
      evcc.0
      2025-01-24 10:01:32.460	debug	call: http://192.168.1.33:7070/api/state
      evcc.0
      2025-01-24 10:01:27.506	debug	Vehicle mit index db:2 gefunden...
      evcc.0
      2025-01-24 10:01:27.465	debug	Vehicle mit index db:1 gefunden...
      evcc.0
      2025-01-24 10:01:27.465	debug	Ladepunkt mit index loadpoint.1 gefunden...
      evcc.0
      2025-01-24 10:01:27.464	debug	Get-Data from evcc:{"result":{"auth":{},"aux":[],"battery":[],"batteryDischargeControl":false,"batteryGridChargeActive":false,"batteryMode":"unknown","bufferSoc":0,"bufferStartSoc":0,"currency":"EUR","eebus":false,"ext":[],"fatal":null,"greenShareHome":0.304,"greenShareLoadpoints":0,"grid":{"power":311,"energy":20101.277000000002,"powers":[168,9,133],"currents":[2.1,1.3,1.9000000000000001]},"gridConfigured":true,"hems":{},"homePower":447,"influx":{"url":"","database":"","org":"","user":"","insecure":false},"interval":10,"loadpoints":[{"batteryBoost":false,"chargeCurrent":0,"chargeCurrents":[0,0,0],"chargeDuration":16670,"chargePower":0,"chargeRemainingDuration":0,"chargeRemainingEnergy":0,"chargeTotalImport":6497.547,"chargedEnergy":48318,"chargerFeatureHeating":false,"chargerFeatureIntegratedDevice":false,"chargerIcon":null,"chargerPhases1p3p":true,"chargerPhysicalPhases":null,"chargerStatusReason":"unknown","charging":false,"connected":false,"connectedDuration":51860,"disableDelay":300,"disableThreshold":200,"effectiveLimitSoc":100,"effectiveMaxCurrent":16,"effectiveMinCurrent":6,"effectivePlanId":0,"effectivePlanSoc":0,"effectivePlanTime":null,"effectivePriority":0,"enableDelay":60,"enableThreshold":0,"enabled":false,"limitEnergy":0,"limitSoc":0,"maxCurrent":16,"minCurrent":6,"mode":"pv","phaseAction":"inactive","phaseRemaining":0,"phasesActive":3,"phasesConfigured":0,"phasesEnabled":3,"planActive":false,"planEnergy":0,"planOverrun":0,"planProjectedEnd":null,"planProjectedStart":null,"planTime":null,"priority":0,"pvAction":"inactive","pvRemaining":0,"sessionCo2PerKWh":175.999,"sessionEnergy":48318,"sessionPrice":12.859,"sessionPricePerKWh":0.266,"sessionSolarPercentage":0,"smartCostActive":true,"smartCostLimit":0.322,"smartCostNextStart":null,"title":"Hof","vehicleClimaterActive":null,"vehicleDetectionActive":false,"vehicleLimitSoc":0,"vehicleName":"","vehicleOdometer":0,"vehicleRange":0,"vehicleSoc":0,"vehicleWelcomeActive":false}],"messaging":true,"modbusproxy":[{"Port":5200,"ReadOnly":"","ID":0,"SubDevice":0,"URI":"192.168.0.191:1502","Device":"","Comset":"","Baudrate":0,"UDP":false,"RTU":null}],"mqtt":{"broker":"","topic":"evcc"},"network":{"schema":"http","host":"evcc.local","port":7070},"prioritySoc":0,"pv":[{"power":136,"energy":40477.616}],"pvEnergy":40477.616,"pvPower":136,"residualPower":0,"siteTitle":"Völkers Home","smartCostType":"priceforecast","sponsor":{"name":"Horgul123","expiresAt":"2026-05-25T08:05:39Z"},"statistics":{"30d":{"avgCo2":206.87025292202992,"avgPrice":0.2999112449359893,"chargedKWh":510.56900000000223,"solarPercentage":0.579682850130254},"365d":{"avgCo2":147.9071869776837,"avgPrice":0.2112740572536854,"chargedKWh":4443.607329636601,"solarPercentage":19.913539536435394},"thisYear":{"avgCo2":206.87025292202992,"avgPrice":0.3038918162204524,"chargedKWh":447.6030000000019,"solarPercentage":0.6612290201543638},"total":{"avgCo2":156.65264782022217,"avgPrice":0.2014120544476205,"chargedKWh":6154.749174771228,"solarPercentage":25.83035819467612}},"tariffCo2":141,"tariffCo2Home":98.101,"tariffCo2Loadpoints":141,"tariffFeedIn":0.139,"tariffGrid":0.309,"tariffPriceHome":0.257,"tariffPriceLoadpoints":0.309,"vehicles":{"db:1":{"title":"Olis Enyaq","icon":"car","capacity":77,"repeatingPlans":[]},"db:2":{"title":"hannahs_2008","icon":"car","capacity":46,"features":["Offline","Retryable"],"repeatingPlans":[]}},"version":"0.133.0"}}
      evcc.0
      2025-01-24 10:01:27.460	debug	call: http://192.168.1.33:7070/api/state
      arteckA Offline
      arteckA Offline
      arteck
      #106
      @merlin123
        "result": {
          "auth": {},
          "aux": [],
          "battery": [],
          "batteryDischargeControl": false,
          "batteryGridChargeActive": false,
          "batteryMode": "unknown",
          "bufferSoc": 0,
          "bufferStartSoc": 0,
          "currency": "EUR",
          "eebus": false,
          "ext": [],
          "fatal": null,
          "greenShareHome": 0.304,
          "greenShareLoadpoints": 0,
          "grid": {
            "power": 311,
            "energy": 20101.277000000002,
            "powers": [
              168,
              9,
              133
            "currents": [
              2.1,
              1.3,
              1.9000000000000001
          "gridConfigured": true,
          "hems": {},
          "homePower": 447,
          "influx": {
            "url": "",
            "database": "",
            "org": "",
            "user": "",
            "insecure": false
          "interval": 10,
          "loadpoints": [
              "batteryBoost": false,
              "chargeCurrent": 0,
              "chargeCurrents": [
                0,
                0,
              "chargeDuration": 16670,
              "chargePower": 0,
              "chargeRemainingDuration": 0,
              "chargeRemainingEnergy": 0,
              "chargeTotalImport": 6497.547,
              "chargedEnergy": 48318,
              "chargerFeatureHeating": false,
              "chargerFeatureIntegratedDevice": false,
              "chargerIcon": null,
              "chargerPhases1p3p": true,
              "chargerPhysicalPhases": null,
              "chargerStatusReason": "unknown",
              "charging": false,
              "connected": false,
              "connectedDuration": 51860,
              "disableDelay": 300,
              "disableThreshold": 200,
              "effectiveLimitSoc": 100,
              "effectiveMaxCurrent": 16,
              "effectiveMinCurrent": 6,
              "effectivePlanId": 0,
              "effectivePlanSoc": 0,
              "effectivePlanTime": null,
              "effectivePriority": 0,
              "enableDelay": 60,
              "enableThreshold": 0,
              "enabled": false,
              "limitEnergy": 0,
              "limitSoc": 0,
              "maxCurrent": 16,
              "minCurrent": 6,
              "mode": "pv",
              "phaseAction": "inactive",
              "phaseRemaining": 0,
              "phasesActive": 3,
              "phasesConfigured": 0,
              "phasesEnabled": 3,
              "planActive": false,
              "planEnergy": 0,
              "planOverrun": 0,
              "planProjectedEnd": null,
              "planProjectedStart": null,
              "planTime": null,
              "priority": 0,
              "pvAction": "inactive",
              "pvRemaining": 0,
              "sessionCo2PerKWh": 175.999,
              "sessionEnergy": 48318,
              "sessionPrice": 12.859,
              "sessionPricePerKWh": 0.266,
              "sessionSolarPercentage": 0,
              "smartCostActive": true,
              "smartCostLimit": 0.322,
              "smartCostNextStart": null,
              "title": "Hof",
              "vehicleClimaterActive": null,
              "vehicleDetectionActive": false,
              "vehicleLimitSoc": 0,
              "vehicleName": "",
              "vehicleOdometer": 0,
              "vehicleRange": 0,
              "vehicleSoc": 0,
              "vehicleWelcomeActive": false
          "messaging": true,
          "modbusproxy": [
              "Port": 5200,
              "ReadOnly": "",
              "ID": 0,
              "SubDevice": 0,
              "URI": "192.168.0.191:1502",
              "Device": "",
              "Comset": "",
              "Baudrate": 0,
              "UDP": false,
              "RTU": null
          "mqtt": {
            "broker": "",
            "topic": "evcc"
          "network": {
            "schema": "http",
            "host": "evcc.local",
            "port": 7070
          "prioritySoc": 0,
          "pv": [
              "power": 136,
              "energy": 40477.616
          "pvEnergy": 40477.616,
          "pvPower": 136,
          "residualPower": 0,
          "siteTitle": "Völkers Home",
          "smartCostType": "priceforecast",
          "sponsor": {
            "name": "Horgul123",
            "expiresAt": "2026-05-25T08:05:39Z"
          "statistics": {
            "30d": {
              "avgCo2": 206.87025292202992,
              "avgPrice": 0.2999112449359893,
              "chargedKWh": 510.56900000000223,
              "solarPercentage": 0.579682850130254
            "365d": {
              "avgCo2": 147.9071869776837,
              "avgPrice": 0.2112740572536854,
              "chargedKWh": 4443.607329636601,
              "solarPercentage": 19.913539536435394
            "thisYear": {
              "avgPrice": 0.3038918162204524,
              "chargedKWh": 447.6030000000019,
              "solarPercentage": 0.6612290201543638
            "total": {
              "avgCo2": 156.65264782022217,
              "avgPrice": 0.2014120544476205,
              "chargedKWh": 6154.749174771228,
              "solarPercentage": 25.83035819467612
          "tariffCo2": 141,
          "tariffCo2Home": 98.101,
          "tariffCo2Loadpoints": 141,
          "tariffFeedIn": 0.139,
          "tariffGrid": 0.309,
          "tariffPriceHome": 0.257,
          "tariffPriceLoadpoints": 0.309,
          "vehicles": {
            "db:1": {
              "title": "Olis Enyaq",
              "icon": "car",
              "capacity": 77,
              "repeatingPlans": []
            "db:2": {
              "title": "hannahs_2008",
              "icon": "car",
              "capacity": 46,
              "features": [
                "Offline",
                "Retryable"
          "version": "0.133.0"
      die daten sind da..
      "grid": {
          "power": 311,
          "powers": [
            168,
            9,
            133
          "currents": [
            2.1,
            1.3,
            1.9000000000000001
      und werden alle 5 min aktualisiert..
      Merlin123M wolfi913W 2 Antworten Letzte Antwort
      • arteckA arteck
        @merlin123
          "result": {
            "auth": {},
            "aux": [],
            "battery": [],
            "bufferSoc": 0,
            "currency": "EUR",
            "eebus": false,
            "ext": [],
            "fatal": null,
            "grid": {
              "power": 311,
              "powers": [
                168,
                9,
                133
              "currents": [
                2.1,
                1.3,
                1.9000000000000001
            "hems": {},
            "homePower": 447,
            "influx": {
              "url": "",
              "database": "",
              "org": "",
              "user": "",
              "insecure": false
            "interval": 10,
            "loadpoints": [
                "chargeCurrent": 0,
                "chargeCurrents": [
                  0,
                  0,
                "chargePower": 0,
                "charging": false,
                "connected": false,
                "enableDelay": 60,
                "enabled": false,
                "limitEnergy": 0,
                "limitSoc": 0,
                "maxCurrent": 16,
                "minCurrent": 6,
                "mode": "pv",
                "phasesActive": 3,
                "phasesEnabled": 3,
                "planEnergy": 0,
                "planOverrun": 0,
                "planTime": null,
                "priority": 0,
                "pvRemaining": 0,
                "title": "Hof",
                "vehicleName": "",
                "vehicleRange": 0,
                "vehicleSoc": 0,
            "messaging": true,
            "modbusproxy": [
                "Port": 5200,
                "ReadOnly": "",
                "ID": 0,
                "SubDevice": 0,
                "Device": "",
                "Comset": "",
                "Baudrate": 0,
                "UDP": false,
                "RTU": null
            "mqtt": {
              "broker": "",
              "topic": "evcc"
            "network": {
              "schema": "http",
              "port": 7070
            "prioritySoc": 0,
            "pv": [
                "power": 136,
                "energy": 40477.616
            "pvPower": 136,
            "residualPower": 0,
            "sponsor": {
            "statistics": {
              "30d": {
              "365d": {
              "thisYear": {
              "total": {
            "tariffCo2": 141,
            "vehicles": {
              "db:1": {
                "icon": "car",
                "capacity": 77,
              "db:2": {
                "icon": "car",
                "capacity": 46,
                "features": [
                  "Offline",
                  "Retryable"
        die daten sind da..
        "grid": {
            "power": 311,
            "powers": [
              168,
              9,
              133
            "currents": [
              2.1,
              1.3,
              1.9000000000000001
        Merlin123M Offline
        Merlin123M Offline
        Merlin123
        #107
        @arteck Sie werden eben nicht aktualisiert. Das ist ja das Problem.
        Grid wird aktualisiert:
        Beta-Tester
        • arteckA arteck
          @merlin123
            "result": {
              "auth": {},
              "aux": [],
              "battery": [],
              "bufferSoc": 0,
              "currency": "EUR",
              "eebus": false,
              "ext": [],
              "fatal": null,
              "grid": {
                "power": 311,
                "powers": [
                  168,
                  9,
                  133
                "currents": [
                  2.1,
                  1.3,
                  1.9000000000000001
              "hems": {},
              "homePower": 447,
              "influx": {
                "url": "",
                "database": "",
                "org": "",
                "user": "",
                "insecure": false
              "interval": 10,
              "loadpoints": [
                  "chargeCurrent": 0,
                  "chargeCurrents": [
                    0,
                    0,
                  "chargePower": 0,
                  "charging": false,
                  "connected": false,
                  "enableDelay": 60,
                  "enabled": false,
                  "limitEnergy": 0,
                  "limitSoc": 0,
                  "maxCurrent": 16,
                  "minCurrent": 6,
                  "mode": "pv",
                  "phasesActive": 3,
                  "phasesEnabled": 3,
                  "planEnergy": 0,
                  "planOverrun": 0,
                  "planTime": null,
                  "priority": 0,
                  "pvRemaining": 0,
                  "title": "Hof",
                  "vehicleName": "",
                  "vehicleRange": 0,
                  "vehicleSoc": 0,
              "messaging": true,
              "modbusproxy": [
                  "Port": 5200,
                  "ReadOnly": "",
                  "ID": 0,
                  "SubDevice": 0,
                  "Device": "",
                  "Comset": "",
                  "Baudrate": 0,
                  "UDP": false,
                  "RTU": null
              "mqtt": {
                "broker": "",
                "topic": "evcc"
              "network": {
                "schema": "http",
                "port": 7070
              "prioritySoc": 0,
              "pv": [
                  "power": 136,
                  "energy": 40477.616
              "pvPower": 136,
              "residualPower": 0,
              "sponsor": {
              "statistics": {
                "30d": {
                "365d": {
                "thisYear": {
                "total": {
              "tariffCo2": 141,
              "vehicles": {
                "db:1": {
                  "icon": "car",
                  "capacity": 77,
                "db:2": {
                  "icon": "car",
                  "capacity": 46,
                  "features": [
                    "Offline",
                    "Retryable"
          die daten sind da..
          "grid": {
              "power": 311,
              "powers": [
                168,
                9,
                133
              "currents": [
                2.1,
                1.3,
                1.9000000000000001
          wolfi913W Online
          wolfi913W Online
          wolfi913
          #108
          @arteck
          Das Problem liegt vermutlich eher daran, dass der Adapter den (vermutlich geänderten Aufbau des JSON) nicht mehr automatisch in Datenpunkte zerlegt.
          Habe mal auf Verdacht eine zweite Instanz aufgemacht.
          Bei evcc.0 waren die DP so:
          Die Instanz evcc.1 (neu) dann so:
          Da werden die DP gar nicht mehr erzeugt und daher auch die Bestandsdatenpunkte nicht mehr aktualisiert.
          Aus dem grid-DP kann man die Werte aber problemlos rauslesen, wenn benötigt.
          Per MQTT würden die unter evcc/site/grid geliefert:
          • wolfi913W wolfi913
            @arteck
            austrogaucho
            #109
            @arteck
            Zigbee-switch aus EVCC schalten
            hab im iobroker mehrere zigbee-switches u.a. für die Waschmaschine usw. eingebunden und möchte diese nun über EVCC schalten.
            Ich kann zu dem Thema auf EVCC-io weder unter discussions noch in den issues etwas dazu finden.
            Ich muss wohl eine loadpoint anlegen, damit ich die Datenpunkte dann auch im iobroker habe - nur wie muss ich den im EVCC parametrieren?
            • A austrogaucho
              @arteck
              Merlin123M Offline
              Merlin123M Offline
              Merlin123
              #110
              @austrogaucho Da solltest Du dann besser im EVCC Forum fragen......
              Grundsätzlich kannst Du das aber auch über Scripte in iobroker steuern
              Beta-Tester
              • A austrogaucho
                @arteck
                wolfi913W Online
                wolfi913W Online
                wolfi913
                #111
                @austrogaucho
                Keine Ahnung ob’s funktioniert, aber mal als Ansatz:
                https://github.com/evcc-io/evcc/discussions/3880#discussioncomment-4940416
                • arteckA Offline
                  arteckA Offline
                  arteck
                  #112
                  so hab da mal ne anpassung gemacht...
                  evcc hat die Strukur geändert .. bewusst oder unbewusst (wird sich zeigen)
                  der Adapter hat jetzt in den Einstellungen
                  bekommen..
                  für alle die eine Ordnerstruktur bevorzugen..
                  dann wird der Status Ordner so gebildet
                  untendrunter sind dann natürlich die alten Objekte.. wobei hier auch evcc nicht alles liefert..
                  am besten mal den Status Ordner löschen dann wird der nochmal richtig angelegt....
                  GIT Install https://github.com/arteck/ioBroker.evcc
                  sollte es ok sein .. mach ich ein PR
                  wolfi913W Merlin123M 3 Antworten Letzte Antwort
                  • arteckA arteck
                    bekommen..
                    wolfi913W Online
                    wolfi913W Online
                    wolfi913
                    #113
                    @arteck
                    Hab's bei mir mal getestet.
                    Läuft ohne Fehler 👍
                    • arteckA arteck
                      bekommen..
                      Merlin123M Offline
                      Merlin123M Offline
                      Merlin123
                      #114
                      @arteck sagte in Neuer Adapter ioBroker.evcc:
                      Bin irgendwie zu doof... Instanz gestoppt, Status Ordner gelöscht, Via Git und Deiner URL installiert, Instanz gestartet.
                      Macht wieder nen Statusordner, aber ohne die Unterordner....
                      Im Log kam:
                      evcc.0
                      2025-02-04 18:13:45.006	warn	State "evcc.0.status.version" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:45.005	warn	State "evcc.0.status.tariffPriceLoadpoints" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:45.005	warn	State "evcc.0.status.tariffPriceHome" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:45.005	warn	State "evcc.0.status.tariffGrid" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:45.005	warn	State "evcc.0.status.tariffFeedIn" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:45.002	warn	State "evcc.0.status.tariffCo2Loadpoints" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:45.001	warn	State "evcc.0.status.tariffCo2Home" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:45.000	warn	State "evcc.0.status.tariffCo2" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:45.000	warn	State "evcc.0.status.statistics" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:45.000	warn	State "evcc.0.status.sponsor" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:45.000	warn	State "evcc.0.status.smartCostType" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:45.000	warn	State "evcc.0.status.siteTitle" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.999	warn	State "evcc.0.status.residualPower" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.999	warn	State "evcc.0.status.pvPower" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.999	warn	State "evcc.0.status.pvEnergy" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.995	warn	State "evcc.0.status.pv" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.995	warn	State "evcc.0.status.prioritySoc" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.995	warn	State "evcc.0.status.network" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.994	warn	State "evcc.0.status.mqtt" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.994	warn	State "evcc.0.status.modbusproxy" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.994	warn	State "evcc.0.status.messaging" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.994	warn	State "evcc.0.status.interval" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.994	warn	State "evcc.0.status.influx" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.993	warn	State "evcc.0.status.homePower" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.993	warn	State "evcc.0.status.gridConfigured" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.993	warn	State "evcc.0.status.grid" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.993	warn	State "evcc.0.status.greenShareLoadpoints" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.992	warn	State "evcc.0.status.greenShareHome" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.992	warn	State "evcc.0.status.fatal" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.992	warn	State "evcc.0.status.eebus" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.991	warn	State "evcc.0.status.currency" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.991	warn	State "evcc.0.status.bufferStartSoc" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.986	warn	State "evcc.0.status.bufferSoc" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.986	warn	State "evcc.0.status.batteryMode" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.985	warn	State "evcc.0.status.batteryGridChargeActive" has no existing object, this might lead to an error in future versions
                      evcc.0
                      2025-02-04 18:13:44.985	warn	State "evcc.0.status.batteryDischargeControl" has no existing object, this might lead to an error in future versions
                      Beta-Tester
                      wolfi913W 1 Antwort Letzte Antwort
                        Im Log kam:
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        evcc.0
                        wolfi913W Online
                        wolfi913W Online
                        wolfi913
                        #115
                        @merlin123
                        Hast Du nach dem Git-Install einen Upload gemacht?
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          #116
                          ich hab gerade nochmal 2 korrekturen nachgeschoben .. bitte aktualisieren..da wurden zu viele Ordner angelegt
                          also am besten den Status nochmal löschen
                          da ist noch ein Fehler seh ich gerade
                          • arteckA arteck
                            wolfi913W Online
                            wolfi913W Online
                            wolfi913
                            #117
                            @arteck
                            Wollte ich gerade noch schreiben das ziemlich viele Log-Einträge kommen. Hast Du aber selber schon gesehen.
                            • arteckA Offline
                              arteckA Offline
                              arteck
                              #118
                              so jetzt
                              • arteckA arteck
                                so jetzt
                                wolfi913W Online
                                wolfi913W Online
                                wolfi913
                                schrieb am zuletzt editiert von wolfi913
                                #119
                                @arteck
                                Ist leider immer noch ziemlich viel im Log los.
                                  @arteck
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #120
                                  @wolfi913 sagte in Neuer Adapter ioBroker.evcc:
                                  @arteck
                                  ja du musst den evcc.1.status ordner löschen
                                  • Merlin123M Offline
                                    Merlin123M Offline
                                    Merlin123
                                    #121
                                    @wolfi913 Jup. Eben nochmal probiert, bleibt ohne Ordner:
                                    Beta-Tester
                                    arteckA wolfi913W 2 Antworten Letzte Antwort
                                    • arteckA arteck
                                      @arteck
                                      wolfi913W Online
                                      wolfi913W Online
                                      wolfi913
                                      #122
                                      Hatte ich vergessen :man-facepalming:
                                      Beim Start ein paar warnings aber dann alles ruhig. 👍
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #123
                                        @merlin123 hast du auch in den Einstellungen die checkbox gesetzt ?
                                          wolfi913W Online
                                          wolfi913W Online
                                          wolfi913
                                          #124
                                          @merlin123 sagte in Neuer Adapter ioBroker.evcc:
                                          Hast Du den Haken gesetzt?
                                          Merlin123M 1 Antwort Letzte Antwort
