  4. [Gelöst] JS Controller Update läuft auf Fehler
42 Beiträge 7 Kommentatoren 5.6k Aufrufe 4 Beobachtet
  • UHU01U UHU01
    @thomas-braun Nach fix und update hat es jetzt funktioniert den Controller zu aktualisieren. Hier trotzdem mal die Diagnose. Gibt bestimmt noch mehr Baustellen:
    ```bash        Script v.2024-12-09 Raspbian+zigbee diag+masking
    *** BASE SYSTEM ***        Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    OS is similar to: debian
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 32 bit
    Systemuptime and Load:
     19:50:55 up 98 days, 27 min,  1 user,  load average: 1.00, 2.28, 2.29
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-01-26 19:50:55 CET
               Universal time: Sun 2025-01-26 18:50:55 UTC
                     RTC time: n/a
    System clock synchronized: no
                  NTP service: n/a
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.8G        1.9G        1.7G        0.0K        4.3G        5.8G
    Swap:            99M          0B         99M
    Total:          7.9G        1.9G        1.8G
    Active iob-Instances:   21
             7812 M total memory
             1852 M used memory
             2503 M active memory
             3165 M inactive memory
             1682 M free memory
              282 M buffer memory
             3995 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 19:50:55 up 98 days, 27 min,  1 user,  load average: 1.00, 2.28, 2.29
    Tasks: 171 total,   2 running, 169 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 43.1 us, 12.5 sy,  0.0 ni, 43.1 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
    MiB Mem :   7812.3 total,   1681.6 free,   1852.7 used,   4278.0 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   5789.2 avail Mem
    *** FAILED SERVICES ***
      UNIT                              LOAD   ACTIVE SUB    DESCRIPTION
    * hciuart.service                   loaded failed failed Configure Bluetooth Modems con...* motioneye.service                 loaded failed failed motionEye Server
    * run-r1c3b976f44ca47afa9a38b2d6... loaded failed failed /usr/bin/node /opt/iobroker/no...* run-r2fd84954123c4431bb5e8ef8e... loaded failed failed /usr/bin/node /opt/iobroker/no...* run-r47cdd2edbca24604a52480051... loaded failed failed /usr/bin/node /opt/iobroker/no...* run-r5353d92724ff4829a94a27f7e... loaded failed failed /usr/bin/node /opt/iobroker/no...* run-r5c87c1800de54c2597303a4de... loaded failed failed /usr/bin/node /opt/iobroker/no...* run-r65cf2a59af08422b9a795b5c4... loaded failed failed /usr/bin/node /opt/iobroker/no...* run-r8332dc44ede846c98a6a0289e... loaded failed failed /usr/bin/node /opt/iobroker/no...* run-ra8215279992546dbb522455f7... loaded failed failed /usr/bin/node /opt/iobroker/no...* run-rbf9a06f20bc04e48b465c703e... loaded failed failed /usr/bin/node /opt/iobroker/no...* run-rcc2ca0e4a68b4406b298c9efd... loaded failed failed /usr/bin/node /opt/iobroker/no...* run-rd2b14b37168f44019996d3e10... loaded failed failed /usr/bin/node /opt/iobroker/no...* run-re27041a612b249aaba3250f54... loaded failed failed /usr/bin/node /opt/iobroker/no...* run-re284b30398b4433086d319a29... loaded failed failed /usr/bin/node /opt/iobroker/no...* run-re6f2accceb9942b2ba4c6c9c0... loaded failed failed /usr/bin/node /opt/iobroker/no...* run-re779a355b5e44691bd7accc28... loaded failed failed /usr/bin/node /opt/iobroker/no...* run-redf8272a681b4ea1b1c264109... loaded failed failed /usr/bin/node /opt/iobroker/no...
    18 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4      117G   22G   91G  19% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  836K  1.6G   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     782M   24K  782M   1% /run/user/1000
    [Sun Oct 20 20:23:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:0D:0A:F1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=64538962-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sun Oct 20 20:23:32 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Oct 20 20:23:32 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Oct 20 20:23:35 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=asc
    /var:
    5.6G    /var/
    3.8G    /var/log/journal/9e9ac854acef421abae9f158c44125bf
    3.8G    /var/log
    1.6G    /var/cache/apt
    Archived and active journals take up 3.7G in the file system.
    /opt/iobroker/backups:
    23M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    894M    /opt/iobroker/iobroker-data/
    509M    /opt/iobroker/iobroker-data/files
    189M    /opt/iobroker/iobroker-data/sonosCache
    158M    /opt/iobroker/iobroker-data/files/admin.admin
    157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    21M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
    16M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.5e602f04.js.map
    16M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
    15M     /opt/iobroker/iobroker-data/files/vis-2/static/js/118.c8f873ca.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.2-1nodesource1
      Version table:
         20.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
     *** 20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u5 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 365)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.18
    javascript:     8.9.0
    nodejs modules from github:     4
    | `-- kodi-ws@2.4.3 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#c276cfa6576302974904e2ef3fc2b0d9fab8482e)
    +-- iobroker.vis-bars@0.1.4 (git+ssh://git@github.com/ioBroker/ioBroker.vis-bars.git#e6e01bd4dae5ce7a09dbfee91ab06d18c81c43e4)
    +-- iobroker.vis-fancyswitch@1.1.0 (git+ssh://git@github.com/ioBroker/ioBroker.vis-fancyswitch.git#62fe89a9bf646392c6a53e7f91744352409135ae)
    +-- iobroker.vis-keyboard@0.0.2 (git+ssh://git@github.com/ioBroker/ioBroker.vis-keyboard.git#91dd01381baea2e0c77144a2936389b9ce38f1b8)
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8099, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              -  enabled
    + system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
      system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
      system.adapter.deconz.0                 : deconz                : raspberrypi                              - disabled, port: 80
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
      system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              - disabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              - disabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
    + system.adapter.mercedesme.0             : mercedesme            : raspberrypi                              -  enabled
      system.adapter.mihome.0                 : mihome                : raspberrypi                              - disabled, port: 9898, bind: 0.0.0.0
      system.adapter.panasonic-viera.1        : panasonic-viera       : raspberrypi                              - disabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
      system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
    + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              - disabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
    + system.adapter.yeelight-2.0             : yeelight-2            : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name      │ url                                                     │ auto upgrade │
    │ 0       │ 'default' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 1       │ 'gith ub' │ 'https://github.com/TA2k/'                              │ false        │
    Active repo(s): default
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: default
    Adapter    "admin"        : 7.4.18   , installed 7.4.18
    Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "deconz"       : 1.6.4    , installed 1.6.4
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
    Adapter    "fritzdect"    : 2.5.12   , installed 2.5.12
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "iot"          : 3.4.5    , installed 3.4.5
    Adapter    "javascript"   : 8.9.0    , installed 8.9.0
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "kodi"         : 3.1.0    , installed 3.1.0
    Adapter    "lg-thinq"     : 1.0.7    , installed 1.0.7
    Adapter    "mercedesme"   : 0.3.4    , installed 0.3.4
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "panasonic-viera": 2.1.0  , installed 2.1.0
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "shelly"       : 8.5.1    , installed 8.5.1
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "telegram"     : 4.0.0    , installed 4.0.0
    Adapter    "tvprogram"    : 4.0.0    , installed 2.3.1  [Updatable]
    Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
    Adapter    "vis-2"        : 2.11.2   , installed 2.11.1 [Updatable]
    Adapter    "vis-2-widgets-jaeger-design": 1.3.9, installed 1.3.9
    Adapter    "vis-icontwo"  : 1.11.0   , installed 1.10.1 [Updatable]
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "web"          : 6.3.1    , installed 6.3.1
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
    Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
    Objects and States
    Objects:        15013
    States:         12400
    Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 62
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       1877       375/deCONZ
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       15551      375/deCONZ
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15494      581/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       460560542  16045/io.shelly.1
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          456786256  16099/cupsd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       460557907  15561/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       460557912  15561/iobroker.js-c
    tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      0          13998      372/connmand
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          456786255  16099/cupsd
    tcp6       0      0 :::4369                 :::*                    LISTEN      0          3473       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15496      581/sshd: /usr/sbin
    tcp6       0      0 ::1:53                  :::*                    LISTEN      0          14002      372/connmand
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       460562940  16325/io.web.0
    tcp6       0      0 :::8099                 :::*                    LISTEN      1001       460558109  15613/io.admin.0
    tcp6       0      0 :::3389                 :::*                    LISTEN      115        1870       593/xrdp
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          13982      582/xrdp-sesman
    udp        0      0 127.0.0.1:53            0.0.0.0:*                           0          13990      372/connmand
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15602      484/dhcpcd
    udp        0      0 192.168.178.53:5353     0.0.0.0:*                           1001       460559845  16175/io.tr-064.1
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       460556250  15850/io.chromecast
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1739       366/avahi-daemon: r
    udp        0      0 0.0.0.0:54668           0.0.0.0:*                           108        1741       366/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       460559411  15890/io.shelly.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1904       375/deCONZ
    udp        0      0 0.0.0.0:44779           0.0.0.0:*                           0          460585453  372/connmand
    udp6       0      0 ::1:53                  :::*                                0          13994      372/connmand
    udp6       0      0 :::37508                :::*                                108        1742       366/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        1740       366/avahi-daemon: r
    2025-01-26 19:46:53.730  - info: shelly.1 (16045) [MQTT] Device with client id "shellyplus2pm-485519a1f430" connected!
    2025-01-26 19:46:54.829  - info: smartcontrol.0 (16531) Adapter admin configuration successfully validated...
    2025-01-26 19:46:57.419  - info: lg-thinq.0 (16242) Update raw datapoints for 9735209f-656a-1117-8694-d8e35e32800c
    2025-01-26 19:46:57.923  - info: info.0 (16354) cpu Temp res = {"main":72.549,"cores":[],"max":72.549,"socket":[],"chipset":null}
    2025-01-26 19:46:58.081  - info: shelly.1 (16045) [MQTT] Device with client id "shellyplus2pm-fcb467ba2770" connected!
    2025-01-26 19:46:59.219  - info: smartcontrol.0 (16531) Subscribing to all target devices and trigger states. 4 trigger schedules activated...
    2025-01-26 19:46:59.224  - info: lg-thinq.0 (16242) Found MQTT Host
    Copy text starting here:
    ```bash
    ======================= SUMMARY =======================                                                           v.2024-12-09 Raspbian+zigbee diag+masking
       Static hostname: raspberrypi        Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)                                                  Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Installation:           native                                                            Kernel:                 aarch64
    Userland:               32 bit                                                            Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000                                                              Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     62        Pending iob updates:    3
    Nodejs-Installation:
    /usr/bin/nodejs         v20.18.1                                                          /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2                                                            /usr/bin/npx            10.8.2
    Recommended versions are nodejs 20.18.2 and npm 10.8.2                                    nodeJS installation is correct
    MEMORY:
    Mem:            7.8G        1.9G        1.6G        0.0K        4.3G        5.7G
    Swap:            99M          0B         99M
    Total:          7.9G        1.9G        1.7G
    ioBroker Core:          js-controller           7.0.6
                            admin                   7.4.18
    Objects type: jsonl
    States  type: jsonl
    Objects:                15013
    States:                 12400
    Size of iob-Database:
    9.2M    /opt/iobroker/iobroker-data/objects.json.migrated
    9.2M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    7.6M    /opt/iobroker/iobroker-data/states.jsonl
    2.0M    /opt/iobroker/iobroker-data/states.json.migrated
    2.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    === Mark text until here for copying ===
    @uhu01 sagte in JS Controller UUpdate läuft auf Fehler:
    Das dann als NEUinstallation in der 64Bit-Lite-Variante.
    UHU01U 1 Antwort Letzte Antwort
      UHU01U Offline
      UHU01U Offline
      UHU01
      @thomas-braun Gibt es wo eine Schritt für Schritt Anleitung dazu? Google wirft zumindest bei mir mehr Fragen als Antworten auf
      CodierknechtC HomoranH 2 Antworten Letzte Antwort
      • UHU01U UHU01
        CodierknechtC Offline
        Codierknecht
        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
        • UHU01U UHU01
          wozu?
          Installation?
          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht?_=1737919548374
          Backup/Restore?
          backitup Wiki
          • CodierknechtC Codierknecht
            UHU01U Offline
            UHU01U Offline
            UHU01
            schrieb am zuletzt editiert von UHU01
            @codierknecht @Homoran @mcm1957 @Thomas-Braun
            Erstmal danke für die Antworten. Habe ich das richtig verstanden, dass ich den pi komplett neu aufsetzen sollte bzw muss?
            Demzufolge:
            1 Backup iobroker
            2 NEUinstallation gemäß "einfacher geht's nicht" Anleitung
            3 Backup zurückspielen
            CodierknechtC Thomas BraunT HomoranH 3 Antworten Letzte Antwort
            • UHU01U UHU01
              Demzufolge:
              1 Backup iobroker
              Codierknecht
              Solltest Du.
              1. Du bist da mit 'nem OS unterwegs, das sein EOL (EndOfLife) längst überschritten hat.
                Das wird auf absehbare Zeit nicht mehr mit (evtl. kritischen) Updates versorgt.
              2. Das aktuelle OS ist noch ein 32-Bit.
              Dein Fahrplan passt.
              • UHU01U UHU01
                Demzufolge:
                1 Backup iobroker
                Ja.
                • UHU01U UHU01
                  Demzufolge:
                  1 Backup iobroker
                  @uhu01 genau so!
                  Wenn du dann noch eine neue SD Karte nimmst, hast du die alte noch als physikalisches Backup
                    Ja.
                    UHU01U Offline
                    UHU01U Offline
                    UHU01
                    Deine "einfacher gehts nicht" Anleitung ist ja Raspi-spezifisch. Ich habe noch einen HP-ProDesk liegen (Core i5 6500T, 16/256 GB) durch den ich den Raspi bei der Gelegenheit ersetzen wollen würde.
                    Gibt es Tipps welche Softwarevariante (Betriebssystem) sich da anbietet? Windows mit Virtualisierung oder auch direkt Debian drauf?
                    Analog zum jetzigen Pi soll künftig auch nur der IOBroker, Motioneye und ein Phoscon-Stick darauf laufen.
                    Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
                    • UHU01U UHU01
                      @uhu01
                      Debian.
                      Auf Servern aus meiner Sicht grundsätzlich erste Wahl.
                      • UHU01U UHU01
                        Codierknecht
                        Wenn da gleich mehrere Dinge drauf laufen sollen, würde sich Proxmox anbieten.
                        ioBroker als LXC mit Debian 12. Dem Motioneye würde ich auch seinen eigenen LXC gönnen.
                          UHU01U Offline
                          UHU01U Offline
                          UHU01
                          @codierknecht So weit so gut. Der neue Server läuft und der Umzug vom Broker auf Proxmox ist auch halbwegs erledigt. Allerdings ist jetzt meine VIS nicht mehr erreichbar. Weder der Editor, noch die Runtime. Habt ihr eine Idee?
                          HomoranH CodierknechtC 2 Antworten Letzte Antwort
                          • UHU01U UHU01
                            Habt ihr eine Idee?
                            tausende 😂
                            mit mehr Fakten wäre es einfacher .
                            iob diag in der Langfassung wäre ein Anfang
                            • UHU01U UHU01
                              Codierknecht
                              @uhu01
                              Wie @Homoran schon schreibt: Das kann zig Ursachen haben.
                              Mit der Langfassung von
                              iob diag
                              kann man sich ein Bild machen.
                                Habt ihr eine Idee?
                                tausende 😂
                                UHU01U Offline
                                UHU01U Offline
                                UHU01
                                @Codierknecht @Homoran : Brauche tatsächlich die Schritt für Schritt Anleitungen ;) Danke für die Geduld.
                                ```bash
                                Script v.2025-02-02
                                *** BASE SYSTEM ***
                                 Static hostname: IOBroker
                                       Icon name: computer-container
                                         Chassis: container ☐
                                  Virtualization: lxc
                                          Kernel: Linux 6.8.12-8-pve
                                    Architecture: x86-64
                                OS is similar to:
                                model name      : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
                                Docker          : false
                                Virtualization  : lxc
                                Kernel          : x86_64
                                Userland        : 64 bit
                                 18:16:38 up 20:56,  2 users,  load average: 0.10, 0.21, 0.18
                                CPU threads: 4
                                Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                                               Local time: Thu 2025-02-06 18:16:38 CET
                                           Universal time: Thu 2025-02-06 17:16:38 UTC
                                                 RTC time: n/a
                                              NTP service: inactive
                                          RTC in local TZ: no
                                iobroker
                                HOME=/home/iobroker
                                GROUPS=iobroker tty dialout sudo audio video plugdev users
                                iobroker
                                HOME=/home/iobroker
                                A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
                                A root login is not required in most Linux Distributions.
                                Run 'iobroker fix' or use the system tools to create a user.
                                Desktop:
                                Terminal:
                                System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                                *** MEMORY ***
                                Mem:            9.5G        1.9G        5.8G        110K        1.9G        7.7G
                                Swap:           536M          0B        536M
                                Total:           10G        1.9G        6.3G
                                Active iob-Instances:   24
                                         9092 M total memory
                                         1775 M used memory
                                         1672 M active memory
                                         1659 M inactive memory
                                         5533 M free memory
                                            0 M buffer memory
                                         1782 M swap cache
                                          512 M total swap
                                            0 M used swap
                                          512 M free swap
                                top - 18:16:38 up 20:56,  2 users,  load average: 0.10, 0.21, 0.18
                                Tasks:  49 total,   1 running,  48 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :   9092.0 total,   5531.5 free,   1777.7 used,   1783.0 buff/cache
                                MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7314.3 avail Mem
                                * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                                1 loaded units listed.
                                [sudo] password for iobroker:
                                dmesg: read kernel buffer failed: Operation not permitted
                                *** FILESYSTEM ***
                                Filesystem                       Type      Size  Used Avail Use% Mounted on
                                /dev/mapper/pve-vm--100--disk--1 ext4       63G  3.5G   56G   6% /
                                none                             tmpfs     492K  4.0K  488K   1% /dev
                                udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                                tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                                tmpfs                            tmpfs     3.1G  108K  3.1G   1% /run
                                tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                                /      /dev/mapper/pve-vm--100--disk--1 ext4   rw,relatime,stripe=16
                                /var:
                                413M    /var/
                                249M    /var/cache
                                245M    /var/cache/apt
                                170M    /var/cache/apt/archives
                                147M    /var/lib
                                Archived and active journals take up 8.0M in the file system.
                                6.7M    /opt/iobroker/backups/
                                482M    /opt/iobroker/iobroker-data/
                                379M    /opt/iobroker/iobroker-data/files
                                33M     /opt/iobroker/iobroker-data/objects.jsonl
                                22M     /opt/iobroker/iobroker-data/states.jsonl
                                7.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js
                                7.4M    /opt/iobroker/iobroker-data/files/javascript.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.3514cab0.chunk.js.map
                                USB-Devices by-id:
                                No Devices found 'by-id'
                                HINT:
                                Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                /usr/bin/nodejs         v20.18.2
                                /usr/bin/node           v20.18.2
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Installed: 20.18.2-1nodesource1
                                  Version table:
                                 *** 20.18.2-1nodesource1 1001
                                        500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                     18.19.0+dfsg-6~deb12u2 500
                                        500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                     18.19.0+dfsg-6~deb12u1 500
                                        500 http://security.debian.org bookworm-security/main amd64 Packages
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                IOBroker            IOBroker (version: 7.0.6, hostname: IOBroker      , alive, uptime: 75020)
                                admin:          7.4.19
                                javascript:     8.9.1
                                nodejs modules from github:     0
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : IOBroker                                 -  enabled, port: 8099, bind: 0.0.0.0, run as: admin
                                + system.adapter.alexa2.0                 : alexa2                : IOBroker                                 -  enabled
                                  system.adapter.alias-manager.0          : alias-manager         : IOBroker                                 - disabled
                                + system.adapter.backitup.0               : backitup              : IOBroker                                 -  enabled
                                + system.adapter.chromecast.0             : chromecast            : IOBroker                                 -  enabled
                                + system.adapter.cloud.0                  : cloud                 : IOBroker                                 -  enabled
                                + system.adapter.deconz.0                 : deconz                : IOBroker                                 -  enabled, port: 80
                                + system.adapter.discovery.0              : discovery             : IOBroker                                 -  enabled
                                + system.adapter.email.0                  : email                 : IOBroker                                 -  enabled
                                  system.adapter.fb-checkpresence.0       : fb-checkpresence      : IOBroker                                 - disabled
                                  system.adapter.flot.0                   : flot                  : IOBroker                                 - disabled
                                  system.adapter.fritzdect.0              : fritzdect             : IOBroker                                 - disabled
                                + system.adapter.history.0                : history               : IOBroker                                 -  enabled
                                + system.adapter.homeconnect.0            : homeconnect           : IOBroker                                 -  enabled
                                  system.adapter.ical.0                   : ical                  : IOBroker                                 -  enabled
                                  system.adapter.icons-icons8.0           : icons-icons8          : IOBroker                                 - disabled
                                  system.adapter.info.0                   : info                  : IOBroker                                 - disabled
                                + system.adapter.iot.0                    : iot                   : IOBroker                                 -  enabled
                                + system.adapter.javascript.0             : javascript            : IOBroker                                 -  enabled
                                + system.adapter.lg-thinq.0               : lg-thinq              : IOBroker                                 -  enabled
                                  system.adapter.mercedesme.0             : mercedesme            : IOBroker                                 - disabled
                                  system.adapter.mihome.0                 : mihome                : IOBroker                                 - disabled, port: 9898, bind: 192.168.178.53
                                + system.adapter.panasonic-viera.1        : panasonic-viera       : IOBroker                                 -  enabled
                                + system.adapter.ping.0                   : ping                  : IOBroker                                 -  enabled
                                + system.adapter.shelly.0                 : shelly                : IOBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                + system.adapter.shelly.1                 : shelly                : IOBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                + system.adapter.smartcontrol.0           : smartcontrol          : IOBroker                                 -  enabled
                                + system.adapter.sonos.0                  : sonos                 : IOBroker                                 -  enabled
                                + system.adapter.telegram.1               : telegram              : IOBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.tr-064.1                 : tr-064                : IOBroker                                 -  enabled
                                  system.adapter.tvspielfilm.0            : tvspielfilm           : IOBroker                                 - disabled
                                  system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: IOBroker                                 - disabled
                                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IOBroker                                 - disabled
                                  system.adapter.vis-icontwo.0            : vis-icontwo           : IOBroker                                 - disabled
                                  system.adapter.vis-players.0            : vis-players           : IOBroker                                 - disabled
                                  system.adapter.vis-weather.0            : vis-weather           : IOBroker                                 - disabled
                                  system.adapter.vis.0                    : vis                   : IOBroker                                 -  enabled
                                  system.adapter.web.0                    : web                   : IOBroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IOBroker                                 -  enabled
                                + system.adapter.yeelight-2.0             : yeelight-2            : IOBroker                                 -  enabled
                                  system.adapter.zigbee.0                 : zigbee                : IOBroker                                 - disabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                + instance is alive
                                Adapter    "admin"        : 7.4.19   , installed 7.4.19
                                Adapter    "javascript"   : 8.9.1    , installed 8.9.1
                                Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
                                Objects and States
                                Objects:        15014
                                States:         12335
                                Hit:2 http://security.debian.org bookworm-security InRelease
                                Pending Updates: 0
                                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1658763    296/master
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1672265    547/iobroker.js-con
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1672260    547/iobroker.js-con
                                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1658524    1/init
                                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       1683360    2527/io.shelly.1
                                tcp6       0      0 :::8099                 :::*                    LISTEN      1000       1670808    579/io.admin.0
                                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1658764    296/master
                                tcp6       0      0 :::3500                 :::*                    LISTEN      1000       5592335    76372/io.sonos.0
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          1660286    1/init
                                tcp6       0      0 :::111                  :::*                    LISTEN      0          1658526    1/init
                                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1684068    2515/io.shelly.0
                                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1658525    1/init
                                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1680931    1749/io.deconz.0
                                udp        0      0 192.168.178.53:5353     0.0.0.0:*                           1000       1685034    2625/io.tr-064.1
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1679343    1708/io.chromecast.
                                udp6       0      0 :::111                  :::*                                0          1658527    1/init
                                udp6       0      0 :::1900                 :::*                                1000       1680932    1749/io.deconz.0
                                2025-02-06 18:13:59.845  - info: sonos.0 (76372) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v20.18.2, js-controller: 7.0.6
                                2025-02-06 18:13:59.945  - warn: deconz.0 (1749) Could not connect to websocket instance of deConz/Phoscon. Error: connect ECONNREFUSED 192.168.178.53:443
                                2025-02-06 18:14:00.600  - warn: sonos.0 (76372) State "sonos.0.root.192_168_178_60.current_track_number" has no existing object, this might lead to an error in future versions
                                2025-02-06 18:14:00.727  - warn: sonos.0 (76372) State "sonos.0.root.192_168_178_58.current_track_number" has no existing object, this might lead to an error in future versions
                                2025-02-06 18:14:00.733  - warn: sonos.0 (76372) State "sonos.0.root.192_168_178_39.favorites_list_html" has no existing object, this might lead to an error in future versions
                                2025-02-06 18:14:00.734  - warn: sonos.0 (76372) State "sonos.0.root.192_168_178_58.favorites_list_html" has no existing object, this might lead to an error in future versions
                                2025-02-06 18:14:00.774  - warn: sonos.0 (76372) State "sonos.0.root.192_168_178_60.favorites_list_html" has no existing object, this might lead to an error in future versions
                                2025-02-06 18:14:00.827  - warn: sonos.0 (76372) State "sonos.0.root.192_168_178_39.favorites_list_html" has no existing object, this might lead to an error in future versions
                                2025-02-06 18:14:00.828  - warn: sonos.0 (76372) State "sonos.0.root.192_168_178_58.favorites_list_html" has no existing object, this might lead to an error in future versions
                                2025-02-06 18:14:00.829  - warn: sonos.0 (76372) State "sonos.0.root.192_168_178_60.favorites_list_html" has no existing object, this might lead to an error in future versions
                                2025-02-06 18:14:01.365  - warn: sonos.0 (76372) State "sonos.0.root.192_168_178_39.current_track_number" has no existing object, this might lead to an error in future versions
                                2025-02-06 18:14:01.370  - warn: sonos.0 (76372) State "sonos.0.root.192_168_178_39.queue_html" has no existing object, this might lead to an error in future versions
                                2025-02-06 18:14:07.562  - warn: sonos.0 (76372) State "sonos.0.root.192_168_178_39.current_track_number" has no existing object, this might lead to an error in future versions
                                2025-02-06 18:14:07.603  - warn: sonos.0 (76372) State "sonos.0.root.192_168_178_39.queue_html" has no existing object, this might lead to an error in future versions
                                2025-02-06 18:14:20.859  - warn: sonos.0 (76372) State "sonos.0.root.192_168_178_39.current_track_number" has no existing object, this might lead to an error in future versions
                                2025-02-06 18:14:20.862  - warn: sonos.0 (76372) State "sonos.0.root.192_168_178_39.queue_html" has no existing object, this might lead to an error in future versions
                                2025-02-06 18:14:59.946  - warn: deconz.0 (1749) Could not connect to websocket instance of deConz/Phoscon. Error: connect ECONNREFUSED 192.168.178.53:443
                                2025-02-06 18:15:03.010  - info: host.IOBroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 76447
                                2025-02-06 18:15:03.728  - error: tvspielfilm.0 (76447) adapter disabled
                                2025-02-06 18:15:03.772  - warn: tvspielfilm.0 (76447) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                                2025-02-06 18:15:04.286  - error: host.IOBroker instance system.adapter.tvspielfilm.0 having pid 76447 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                                2025-02-06 18:15:59.948  - warn: deconz.0 (1749) Could not connect to websocket instance of deConz/Phoscon. Error: connect ECONNREFUSED 192.168.178.53:443
                                2025-02-06 18:16:38.376  - warn: javascript.0 (2332) script.js.common.Wohnzimmer.Gehweg_per_Taster_und_VIS: Script Wohnzimmer ausgelöst
                                2025-02-06 18:16:38.580  - warn: shelly.0 (2515) [http controlFunction] Unable to perform request - device 192.168.178.79 (shellycolorbulb / shellycolorbulb-98CDAC1F2884 / SHCB-1#98CDAC1F2884#1) is offline
                                2025-02-06 18:16:59.949  - warn: deconz.0 (1749) Could not connect to websocket instance of deConz/Phoscon. Error: connect ECONNREFUSED 192.168.178.53:443
                                iob diag has finished.
                                HomoranH Thomas BraunT Meister MopperM 3 Antworten Letzte Antwort
                                • UHU01U UHU01
                                  ```bash
                                  Script v.2025-02-02
                                  *** BASE SYSTEM ***
                                    Virtualization: lxc
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : 64 bit
                                  CPU threads: 4
                                                   RTC time: n/a
                                            RTC in local TZ: no
                                  iobroker
                                  HOME=/home/iobroker
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:
                                  *** MEMORY ***
                                  Swap:           536M          0B        536M
                                           9092 M total memory
                                           1775 M used memory
                                           5533 M free memory
                                              0 M buffer memory
                                           1782 M swap cache
                                            512 M total swap
                                              0 M used swap
                                            512 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  413M    /var/
                                  249M    /var/cache
                                  245M    /var/cache/apt
                                  147M    /var/lib
                                  USB-Devices by-id:
                                  HINT:
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  admin:          7.4.19
                                  javascript:     8.9.1
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        15014
                                  States:         12335
                                  Pending Updates: 0
                                    Codierknecht
                                    @UHU01
                                    Was @Homoran meint:
                                    iob start web.0
                                      @UHU01
                                      Was @Homoran meint:
                                      iob start web.0
                                      @codierknecht sagte in JS Controller UUpdate läuft auf Fehler:
                                      @UHU01
                                      Was @Homoran meint:
                                      iob start web.0
                                      das kann er doch auch über den Admin machen.
                                      Da kommt er doch drauf
                                        @UHU01
                                        Was @Homoran meint:
                                        iob start web.0
                                        Codierknecht
                                        Ja wenn er doch eh in der Konsole ist ... viele Wege führen nach Rom 😁 😁 😁
                                        • UHU01U UHU01
                                          ```bash
                                          Script v.2025-02-02
                                          *** BASE SYSTEM ***
                                            Virtualization: lxc
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                          CPU threads: 4
                                                           RTC time: n/a
                                                    RTC in local TZ: no
                                          iobroker
                                          HOME=/home/iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Terminal:
                                          *** MEMORY ***
                                          Swap:           536M          0B        536M
                                                   9092 M total memory
                                                   1775 M used memory
                                                   5533 M free memory
                                                      0 M buffer memory
                                                   1782 M swap cache
                                                    512 M total swap
                                                      0 M used swap
                                                    512 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          413M    /var/
                                          249M    /var/cache
                                          245M    /var/cache/apt
                                          147M    /var/lib
                                          USB-Devices by-id:
                                          HINT:
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          admin:          7.4.19
                                          javascript:     8.9.1
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        15014
                                          States:         12335
                                          Pending Updates: 0
                                          Solltest du machen.
                                          Solltest du machen.
                                          Solltest du machen. siehe Punkt 1.
