iobroker Absturz
top - 20:29:31 up 27 min, 1 user, load average: 0.42, 0.74, 1.12 Tasks: 193 total, 1 running, 192 sleeping, 0 stopped, 0 zombie %Cpu(s): 3.4 us, 1.2 sy, 0.0 ni, 95.2 id, 0.1 wa, 0.0 hi, 0.1 si, 0.0 st MiB Mem : 3790.9 total, 416.3 free, 2352.6 used, 1097.8 buff/cache MiB Swap: 200.0 total, 84.7 free, 115.3 used. 1438.3 avail Mem -
top - 20:32:23 up 30 min, 1 user, load average: 0.71, 0.76, 1.06 Tasks: 194 total, 3 running, 191 sleeping, 0 stopped, 0 zombie %Cpu(s): 4.2 us, 0.7 sy, 0.0 ni, 94.9 id, 0.0 wa, 0.0 hi, 0.2 si, 0.0 st MiB Mem : 3790.9 total, 408.6 free, 2347.7 used, 1110.4 buff/cache MiB Swap: 200.0 total, 84.8 free, 115.2 used. 1443.2 avail Mem -
Aha, das war mir so nicht klar.
top - 20:37:11 up 35 min, 1 user, load average: 0.12, 0.48, 0.86 Tasks: 194 total, 3 running, 191 sleeping, 0 stopped, 0 zombie %Cpu(s): 4.2 us, 1.2 sy, 0.0 ni, 94.5 id, 0.1 wa, 0.0 hi, 0.1 si, 0.0 st MiB Mem : 3790.9 total, 378.2 free, 2371.7 used, 1116.9 buff/cache MiB Swap: 200.0 total, 85.1 free, 114.8 used. 1419.2 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 890 iobroker 20 0 9474412 392520 38912 R 7.6 10.1 5:54.60 iobroker.js-con 1056 iobroker 20 0 9378436 119260 38912 S 2.7 3.1 1:29.99 io.influxdb.0 1101 iobroker 20 0 9641008 362132 40704 S 2.7 9.3 2:03.87 io.javascript.0 1654 iobroker 20 0 9096716 105024 38656 S 2.0 2.7 1:17.80 io.sonoff.0 1681 iobroker 20 0 9085944 95300 38784 S 1.7 2.5 0:23.08 io.tr-064.0 789 influxdb 20 0 2665996 146712 9684 S 1.0 3.8 0:29.06 influxd 1613 iobroker 20 0 9071608 79240 39168 S 1.0 2.0 0:14.64 io.s7.2 1783 iobroker 20 0 9074016 81808 38912 S 1.0 2.1 0:10.75 io.modbus.0 1257 iobroker 20 0 9079240 90204 38912 S 0.7 2.3 0:16.65 io.hm-rpc.1 17 root 20 0 0 0 0 I 0.3 0.0 0:01.54 rcu_preempt 565 message+ 20 0 8792 3072 2432 S 0.3 0.1 0:00.44 dbus-daemon 632 root 20 0 262564 7808 6528 S 0.3 0.2 0:00.73 NetworkManager 644 root 20 0 17160 4352 3968 S 0.3 0.1 0:00.34 wpa_supplicant 889 grafana 20 0 1598204 75140 41856 S 0.3 1.9 0:08.36 grafana 1280 iobroker 20 0 9082348 90944 38784 S 0.3 2.3 0:17.25 io.hm-rpc.2 1379 iobroker 20 0 9076332 89020 38912 S 0.3 2.3 0:15.40 io.opendtu.0 1513 iobroker 20 0 9071972 79808 39168 S 0.3 2.1 0:14.67 io.s7.0 1536 iobroker 20 0 9071744 80584 39168 S 0.3 2.1 0:14.64 io.s7.1 1805 iobroker 20 0 9059084 87284 43904 R 0.3 2.2 0:09.73 io.pvforecast.0 1857 iobroker 20 0 9052620 76880 38912 S 0.3 2.0 0:06.70 io.time-switch. 1872 iobroker 20 0 9050672 73640 38912 S 0.3 1.9 0:06.36 io.vis-inventwo 3826 root 20 0 0 0 0 I 0.3 0.0 0:00.11 kworker/0:1-mm_percpu_wq 4210 peter 20 0 11756 4992 2816 R 0.3 0.1 0:00.06 top 1 root 20 0 168468 8152 6208 S 0.0 0.2 0:01.91 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.01 kthreadd 3 root 20 0 0 0 0 S 0.0 0.0 0:00.00 pool_workqueue_release 4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-rcu_g 5 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-rcu_p 6 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-slub_ 7 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-netns 9 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/0:0H-events_highpri 11 root 20 0 0 0 0 I 0.0 0.0 0:00.16 kworker/u8:0-ext4-rsv-conversion 12 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-mm_pe 13 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_kthread 14 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_rude_kthread 15 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_trace_kthread 16 root 20 0 0 0 0 S 0.0 0.0 0:00.25 ksoftirqd/0 18 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/0 19 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0 20 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1 21 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/1 22 root 20 0 0 0 0 S 0.0 0.0 0:00.13 ksoftirqd/1 24 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/1:0H-events_highpri 25 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/2 26 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/2 27 root 20 0 0 0 0 S 0.0 0.0 0:00.12 ksoftirqd/2 29 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/2:0H-events_highpri 30 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/3 31 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/3 32 root 20 0 0 0 0 S 0.0 0.0 0:00.11 ksoftirqd/3 34 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/3:0H-events_highpri 35 root 20 0 0 0 0 I 0.0 0.0 0:00.68 kworker/u9:0-writeback 36 root 20 0 0 0 0 I 0.0 0.0 0:00.05 kworker/u10:0-events_unbound 38 root 20 0 0 0 0 I 0.0 0.0 0:00.00 kworker/u12:0-events_unbound 39 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs 40 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-inet_ -
@homoran said in iobroker Absturz:
deutet auf Probleme mit dem I/O
Tut mir leid, dafür fehlt mir das Wissen. Kannst Du mir das bitte erklären?
Danke schon mal...
@pb74 sagte in iobroker Absturz:
@homoran sagte in iobroker Absturz:
die load average betrachtet diverse Parameter zur Systemlast, und der Wert sollte grob gesagt die Anzahl Kerne nicht überschreiten.
Passiert das, staut sich die Abarbeitung was im schlimmsten Fall zur Lähmung des Systems führt.
Es wäre vielleicht sinnvoll auf den entsprechenden Wert unter system.host.xyz zu triggern, beim Erreichen einer Schwelle eine WARN ins log schreiben, damit man später im Log sehen kann was da etwa passiert ist.dazu gehören natürlich die CPU Last, aber auch due Geschwindigkeit von In/Out (Lese/Schreib) Vorgängen.
Da bei dir die CPU nur mäßig ausgelastet ist, die load aber relativ hoch, muss die Ursache nicht in der CPU-Last liegen
top - 20:37:11 up 35 min, 1 user, load average: 0.12, 0.48, 0.86 Tasks: 194 total, 3 running, 191 sleeping, 0 stopped, 0 zombie %Cpu(s): 4.2 us, 1.2 sy, 0.0 ni, 94.5 id, 0.1 wa, 0.0 hi, 0.1 si, 0.0 st MiB Mem : 3790.9 total, 378.2 free, 2371.7 used, 1116.9 buff/cache MiB Swap: 200.0 total, 85.1 free, 114.8 used. 1419.2 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 890 iobroker 20 0 9474412 392520 38912 R 7.6 10.1 5:54.60 iobroker.js-con 1056 iobroker 20 0 9378436 119260 38912 S 2.7 3.1 1:29.99 io.influxdb.0 1101 iobroker 20 0 9641008 362132 40704 S 2.7 9.3 2:03.87 io.javascript.0 1654 iobroker 20 0 9096716 105024 38656 S 2.0 2.7 1:17.80 io.sonoff.0 1681 iobroker 20 0 9085944 95300 38784 S 1.7 2.5 0:23.08 io.tr-064.0 789 influxdb 20 0 2665996 146712 9684 S 1.0 3.8 0:29.06 influxd 1613 iobroker 20 0 9071608 79240 39168 S 1.0 2.0 0:14.64 io.s7.2 1783 iobroker 20 0 9074016 81808 38912 S 1.0 2.1 0:10.75 io.modbus.0 1257 iobroker 20 0 9079240 90204 38912 S 0.7 2.3 0:16.65 io.hm-rpc.1 17 root 20 0 0 0 0 I 0.3 0.0 0:01.54 rcu_preempt 565 message+ 20 0 8792 3072 2432 S 0.3 0.1 0:00.44 dbus-daemon 632 root 20 0 262564 7808 6528 S 0.3 0.2 0:00.73 NetworkManager 644 root 20 0 17160 4352 3968 S 0.3 0.1 0:00.34 wpa_supplicant 889 grafana 20 0 1598204 75140 41856 S 0.3 1.9 0:08.36 grafana 1280 iobroker 20 0 9082348 90944 38784 S 0.3 2.3 0:17.25 io.hm-rpc.2 1379 iobroker 20 0 9076332 89020 38912 S 0.3 2.3 0:15.40 io.opendtu.0 1513 iobroker 20 0 9071972 79808 39168 S 0.3 2.1 0:14.67 io.s7.0 1536 iobroker 20 0 9071744 80584 39168 S 0.3 2.1 0:14.64 io.s7.1 1805 iobroker 20 0 9059084 87284 43904 R 0.3 2.2 0:09.73 io.pvforecast.0 1857 iobroker 20 0 9052620 76880 38912 S 0.3 2.0 0:06.70 io.time-switch. 1872 iobroker 20 0 9050672 73640 38912 S 0.3 1.9 0:06.36 io.vis-inventwo 3826 root 20 0 0 0 0 I 0.3 0.0 0:00.11 kworker/0:1-mm_percpu_wq 4210 peter 20 0 11756 4992 2816 R 0.3 0.1 0:00.06 top 1 root 20 0 168468 8152 6208 S 0.0 0.2 0:01.91 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.01 kthreadd 3 root 20 0 0 0 0 S 0.0 0.0 0:00.00 pool_workqueue_release 4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-rcu_g 5 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-rcu_p 6 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-slub_ 7 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-netns 9 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/0:0H-events_highpri 11 root 20 0 0 0 0 I 0.0 0.0 0:00.16 kworker/u8:0-ext4-rsv-conversion 12 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-mm_pe 13 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_kthread 14 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_rude_kthread 15 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_trace_kthread 16 root 20 0 0 0 0 S 0.0 0.0 0:00.25 ksoftirqd/0 18 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/0 19 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0 20 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1 21 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/1 22 root 20 0 0 0 0 S 0.0 0.0 0:00.13 ksoftirqd/1 24 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/1:0H-events_highpri 25 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/2 26 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/2 27 root 20 0 0 0 0 S 0.0 0.0 0:00.12 ksoftirqd/2 29 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/2:0H-events_highpri 30 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/3 31 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/3 32 root 20 0 0 0 0 S 0.0 0.0 0:00.11 ksoftirqd/3 34 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/3:0H-events_highpri 35 root 20 0 0 0 0 I 0.0 0.0 0:00.68 kworker/u9:0-writeback 36 root 20 0 0 0 0 I 0.0 0.0 0:00.05 kworker/u10:0-events_unbound 38 root 20 0 0 0 0 I 0.0 0.0 0:00.00 kworker/u12:0-events_unbound 39 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs 40 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-inet_@pb74 Danke!
Jetzt hat sich "leider" die load normalisiert und passt zur CPU-Last@pb74 sagte in iobroker Absturz:
daher ist auch der Prozess mit der höchsten Last auch absolut unauffällig
890 iobroker 20 0 9474412 392520 38912 R 7.6 10.1 5:54.60 iobroker.js-conEDIT
der controller belastet zwar nur einen Kern mit 7.6%, braucht aber 10% des Speichers.
Das kann ich jetzt nicht bewerten.
Der zweitgrößte Speicherfresser ist javascript.0 -
Wenn Du keine anderen Vorgaben hast, würde ich das System jetzt erst mal so laufen lassen und demnächst in den Scripten auf Fehlersuche gehen...
Alternative ggf.
htopdas ist
topmit etwas mehr "Schnickschnack" was es aus meiner Sicht lesbarer macht:
Als "Windows Benutzer" ist insbesondere die prozentuale Anzeige oben für die CPU vertrauter,htopist bunt und bei beiden gibt es mitheine Hilfe -
Alternative ggf.
htopdas ist
Als "Windows Benutzer" ist insbesondere die prozentuale Anzeige oben für die CPU vertrauter,htopist bunt und bei beiden gibt es mitheine HilfeGuter Tipp, ich lass es grade mal durchlaufen.
Ich hab heute mal die Variablen entsprechend korrigiert, damit die Warnmeldungen verschwinden.
Hier die derzeitige Ausgabe von top (ich konnte die Ausgabe von htop leider nicht kopieren
)Weiter unten noch der Langtext von iob_diag.
Die dort noch angezeigte Warnung "hm-rega.0(6801)" tritt nun auch nicht mehr auf; der max-Wert wurde entsprechend angepasst.top - 18:49:53 up 22:48, 1 user, load average: 0.15, 0.34, 0.41 Tasks: 192 total, 1 running, 191 sleeping, 0 stopped, 0 zombie %Cpu(s): 5.1 us, 1.3 sy, 0.0 ni, 93.2 id, 0.0 wa, 0.0 hi, 0.4 si, 0.0 st MiB Mem : 3790.9 total, 376.0 free, 2649.7 used, 838.7 buff/cache MiB Swap: 200.0 total, 0.4 free, 199.6 used. 1141.2 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 6672 iobroker 20 0 9708496 370072 14080 S 10.3 9.5 163:48.76 iobroker.js-con 7024 iobroker 20 0 9142568 126288 11392 S 4.3 3.3 48:14.52 io.sonoff.0 6705 iobroker 20 0 9390044 107320 11136 S 3.7 2.8 50:19.08 io.influxdb.0 6732 iobroker 20 0 9639256 352964 16640 S 3.7 9.1 49:20.98 io.javascript.0 7043 iobroker 20 0 9088432 74536 11648 S 1.3 1.9 7:55.73 io.tr-064.0 789 influxdb 20 0 2734792 192696 13236 S 0.7 5.0 15:18.77 influxd 6801 iobroker 20 0 9084128 61792 11136 S 0.7 1.6 2:42.33 io.hm-rega.0 56 root 0 -20 0 0 0 I 0.3 0.0 0:08.71 kworker/0:1H-kblockd 89 root -51 0 0 0 0 S 0.3 0.0 2:14.46 irq/37-mmc0 200 root 20 0 0 0 0 S 0.3 0.0 0:45.18 jbd2/sda2-8 259 root 20 0 115780 47092 46708 S 0.3 1.2 1:50.74 systemd-journal 6782 iobroker 20 0 9355772 71336 11392 S 0.3 1.8 2:24.99 io.backitup.0 6839 iobroker 20 0 9092588 64508 11008 S 0.3 1.7 3:48.31 io.hm-rpc.1 6994 iobroker 20 0 9080908 60140 11392 S 0.3 1.5 4:39.15 io.s7.1 7009 iobroker 20 0 9078792 59536 11136 S 0.3 1.5 4:37.34 io.s7.2 7208 iobroker 20 0 9072548 51920 11008 S 0.3 1.3 1:26.47 io.mytime.0 22100 iobroker 20 0 9351032 72500 12032 S 0.3 1.9 1:00.17 io.telegram.0 47225 root 20 0 0 0 0 D 0.3 0.0 0:03.25 kworker/2:0+events_freezable 47988 peter 20 0 11756 4992 2816 R 0.3 0.1 0:00.28 top 1 root 20 0 168624 6744 4800 S 0.0 0.2 0:03.00 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.10 kthreadd 3 root 20 0 0 0 0 S 0.0 0.0 0:00.00 pool_workqueue_release 4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-rcu_g 5 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-rcu_p 6 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-slub_ 7 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-netns 9 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/0:0H-events_highpri 11 root 20 0 0 0 0 I 0.0 0.0 0:03.92 kworker/u8:0-ext4-rsv-conversion 12 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-mm_pe 13 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_kthread 14 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_rude_kthread 15 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_trace_kthread 16 root 20 0 0 0 0 S 0.0 0.0 0:06.88 ksoftirqd/0 17 root 20 0 0 0 0 I 0.0 0.0 0:37.42 rcu_preempt 18 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/0 19 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0 20 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1 21 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/1 22 root 20 0 0 0 0 S 0.0 0.0 0:02.78 ksoftirqd/1 24 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/1:0H-events_highpri 25 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/2 26 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/2 27 root 20 0 0 0 0 S 0.0 0.0 0:02.58 ksoftirqd/2 29 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/2:0H-events_highpri 30 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/3 31 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/3 32 root 20 0 0 0 0 S 0.0 0.0 0:02.30 ksoftirqd/3 34 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/3:0H-events_highpri 39 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs 40 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-inet_ 42 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kauditd 44 root 20 0 0 0 0 S 0.0 0.0 0:00.08 khungtaskd 45 root 20 0 0 0 0 S 0.0 0.0 0:00.00 oom_reaper 46 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-write 47 root 20 0 0 0 0 S 0.0 0.0 0:06.75 kcompactd0 48 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-kinteScript v.2024-12-09 Raspbian+zigbee diag+masking *** BASE SYSTEM *** Static hostname: iobroker001 Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.6.62+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 18:51:37 up 22:49, 1 user, load average: 0.52, 0.41, 0.43 CPU threads: 4 *** LIFE CYCLE STATUS *** Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained. *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Sat 2025-01-25 18:51:38 CET Universal time: Sat 2025-01-25 17:51:38 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': peter HOME=/home/peter GROUPS=peter adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: tty *** MEMORY *** total used free shared buff/cache available Mem: 4.0G 2.8G 338M 208K 936M 1.2G Swap: 209M 208M 876K Total: 4.2G 3.0G 339M Active iob-Instances: 29 3790 M total memory 2649 M used memory 1489 M active memory 1803 M inactive memory 322 M free memory 77 M buffer memory 814 M swap cache 199 M total swap 199 M used swap 0 M free swap *** top - Table Of Processes *** top - 18:51:38 up 22:49, 1 user, load average: 0.52, 0.41, 0.43 Tasks: 198 total, 2 running, 196 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 11.1 sy, 0.0 ni, 77.8 id, 11.1 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 3790.9 total, 322.1 free, 2649.2 used, 893.2 buff/cache MiB Swap: 200.0 total, 0.8 free, 199.2 used. 1141.7 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 1.6G 0 1.6G 0% /dev tmpfs tmpfs 380M 1.2M 378M 1% /run /dev/sda2 ext4 235G 14G 209G 7% / tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock /dev/sda1 vfat 510M 65M 446M 13% /boot/firmware tmpfs tmpfs 380M 0 380M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Fri Jan 24 20:01:43 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=D8:3A:DD:7F:7D:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=2edada06-02 rootfstype=ext4 fsck.repair=yes rootwait [Fri Jan 24 20:01:51 2025] EXT4-fs (sda2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none. [Fri Jan 24 20:01:52 2025] EXT4-fs (sda2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot/firmware /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 6.1G /var/ 4.0G /var/log/journal/a8a92d47c12b42b58df1e1120bb26229 4.0G /var/log/journal 4.0G /var/log 1.3G /var/lib Archived and active journals take up 3.9G in the file system. /opt/iobroker/backups: 6.0M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.6G /opt/iobroker/iobroker-data/ 1.3G /opt/iobroker/iobroker-data/files 617M /opt/iobroker/iobroker-data/files/javascript.admin 560M /opt/iobroker/iobroker-data/files/javascript.admin/static 558M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 49M /opt/iobroker/iobroker-data/states.jsonl 26M /opt/iobroker/iobroker-data/objects.jsonl 24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map 24M /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map 24M /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' *** NodeJS-Installation *** /usr/bin/nodejs v18.20.6 /usr/bin/node v18.20.6 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.29.4 nodejs: Installed: 18.20.6-1nodesource1 Candidate: 18.20.6-1nodesource1 Version table: *** 18.20.6-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 18.20.5-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.20.4-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.20.3-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.20.2-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.20.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.20.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.19.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.19.0+dfsg-6~deb12u2 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages 18.19.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.2-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.15.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.2-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.13.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.12.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.11.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.10.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.1-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.8.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.7.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.6.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.5.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.4.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.3.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.2.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.1.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.0.0-1nodesource1 600 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: iobroker001 iobroker001 (version: 7.0.6, hostname: iobroker001 , alive, uptime: 78011) Core adapters versions js-controller: 7.0.6 admin: 7.4.10 javascript: 8.8.3 nodejs modules from github: 1 +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e) Adapter State + system.adapter.admin.0 : admin : iobroker001 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : iobroker001 - enabled + system.adapter.discovery.0 : discovery : iobroker001 - enabled + system.adapter.hm-rega.0 : hm-rega : iobroker001 - enabled + system.adapter.hm-rpc.0 : hm-rpc : iobroker001 - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : iobroker001 - enabled, port: 0 + system.adapter.hm-rpc.2 : hm-rpc : iobroker001 - enabled, port: 0 system.adapter.icons-icons8.0 : icons-icons8 : iobroker001 - disabled system.adapter.icons-material-png.0 : icons-material-png : iobroker001 - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker001 - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker001 - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobroker001 - disabled + system.adapter.influxdb.0 : influxdb : iobroker001 - enabled, port: 8086 + system.adapter.javascript.0 : javascript : iobroker001 - enabled + system.adapter.modbus.0 : modbus : iobroker001 - enabled + system.adapter.mytime.0 : mytime : iobroker001 - enabled + system.adapter.opendtu.0 : opendtu : iobroker001 - enabled + system.adapter.pvforecast.0 : pvforecast : iobroker001 - enabled + system.adapter.pvforecast.1 : pvforecast : iobroker001 - enabled + system.adapter.rpi2.0 : rpi2 : iobroker001 - enabled + system.adapter.s7.0 : s7 : iobroker001 - enabled + system.adapter.s7.1 : s7 : iobroker001 - enabled + system.adapter.s7.2 : s7 : iobroker001 - enabled + system.adapter.socketio.0 : socketio : iobroker001 - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobroker001 - enabled, port: 1883, bind: 192.168.1.141 + system.adapter.sourceanalytix.0 : sourceanalytix : iobroker001 - enabled + system.adapter.telegram.0 : telegram : iobroker001 - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.terminal.0 : terminal : iobroker001 - enabled, port: 8090, bind: 0.0.0.0, run as: admin + system.adapter.time-switch.0 : time-switch : iobroker001 - enabled + system.adapter.tr-064.0 : tr-064 : iobroker001 - enabled + system.adapter.vis-2.0 : vis-2 : iobroker001 - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker001 - disabled system.adapter.vis-icontwo.0 : vis-icontwo : iobroker001 - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : iobroker001 - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker001 - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker001 - disabled system.adapter.vis-plumb.0 : vis-plumb : iobroker001 - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker001 - disabled system.adapter.vis.0 : vis : iobroker001 - enabled + system.adapter.web.0 : web : iobroker001 - enabled, port: 8082, bind: 0.0.0.0, run as: admin + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker001 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.0 : hm-rpc : iobroker001 - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : iobroker001 - enabled, port: 0 + system.adapter.hm-rpc.2 : hm-rpc : iobroker001 - enabled, port: 0 + system.adapter.influxdb.0 : influxdb : iobroker001 - enabled, port: 8086 + system.adapter.socketio.0 : socketio : iobroker001 - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobroker001 - enabled, port: 1883, bind: 192.168.1.141 + system.adapter.telegram.0 : telegram : iobroker001 - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.terminal.0 : terminal : iobroker001 - enabled, port: 8090, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : iobroker001 - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌────────────────────────────────────────────────────────────────────────────────────────────── │ (index) │ name │ url │ auto upgrade │ ├────────────────────────────────────────────────────────────────────────────────────────────── │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └────────────────────────────────────────────────────────────────────────────────────────────── Active repo(s): stable Upgrade policy: none Installed ioBroker-Instances Used repository: stable Adapter "admin" : 7.4.10 , installed 7.4.10 Adapter "backitup" : 3.0.31 , installed 3.0.31 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "hm-rega" : 5.1.0 , installed 5.1.0 Adapter "hm-rpc" : 2.0.2 , installed 2.0.2 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "javascript" : 8.8.3 , installed 8.8.3 Controller "js-controller": 7.0.6 , installed 7.0.6 Adapter "modbus" : 6.3.2 , installed 6.3.2 Adapter "mytime" : 1.4.0 , installed 1.4.0 Adapter "opendtu" : 3.1.0 , installed 2.0.0 [Updatable] Adapter "pvforecast" : 4.1.0 , installed 4.1.0 Adapter "rpi2" : 2.3.1 , installed 2.3.1 Adapter "s7" : 1.4.3 , installed 1.4.3 Adapter "signal-cmb" : 0.3.0 , installed 0.3.0 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "sonoff" : 3.1.2 , installed 3.1.2 Adapter "telegram" : 3.9.0 , installed 3.9.0 Adapter "terminal" : 1.0.0 , installed 1.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.9.64 , installed 2.9.64 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-icontwo" : 1.11.0 , installed 1.11.0 Adapter "vis-inventwo" : 3.3.4 , installed 3.3.4 Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "ws" : 2.6.2 , installed 2.6.2 Objects and States Please stand by - This may take a while Objects: 5621 States: 4770 *** OS-Repositories and Updates *** Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease Hit:2 http://deb.debian.org/debian bookworm InRelease Hit:3 https://repos.influxdata.com/debian stable InRelease Hit:4 https://packages.grafana.com/oss/deb stable InRelease Hit:5 http://deb.debian.org/debian-security bookworm-security InRelease Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease Hit:7 http://deb.debian.org/debian bookworm-updates InRelease Reading package lists... Done Pending Updates: 1 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 101269 6672/iobroker.js-co tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 101276 6672/iobroker.js-co tcp 0 0 192.168.1.141:8701 0.0.0.0:* LISTEN 1001 103794 6857/io.hm-rpc.2 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 5640 694/sshd: /usr/sbin tcp 0 0 192.168.1.141:1883 0.0.0.0:* LISTEN 1001 103010 7024/io.sonoff.0 tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 999 6787 789/influxd tcp 0 0 192.168.1.141:2001 0.0.0.0:* LISTEN 1001 104570 6824/io.hm-rpc.0 tcp 0 0 192.168.1.141:2010 0.0.0.0:* LISTEN 1001 104679 6839/io.hm-rpc.1 tcp6 0 0 :::3000 :::* LISTEN 106 6922 889/grafana tcp6 0 0 :::22 :::* LISTEN 0 5642 694/sshd: /usr/sbin tcp6 0 0 :::8084 :::* LISTEN 1001 104037 7103/io.socketio.0 tcp6 0 0 :::8086 :::* LISTEN 999 5746 789/influxd tcp6 0 0 :::8081 :::* LISTEN 1001 102581 6694/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 104198 7193/io.web.0 tcp6 0 0 :::8090 :::* LISTEN 1001 104056 7114/io.terminal.0 udp 0 0 0.0.0.0:59105 0.0.0.0:* 104 4551 562/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 4549 562/avahi-daemon: r udp6 0 0 fe80::9948:b004:76b:546 :::* 0 1865 632/NetworkManager udp6 0 0 :::57898 :::* 104 4552 562/avahi-daemon: r udp6 0 0 :::5353 :::* 104 4550 562/avahi-daemon: r *** Log File - Last 25 Lines *** 2025-01-25 15:31:20.283 - info: javascript.0 (6732) script.js.common.Gerate_Zaehlen_V1: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions 2025-01-25 16:00:00.125 - info: javascript.0 (6732) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 6] | [nächster Tag: 7] | [Aktualisiert: 1] | Aktuelle Tageszeit: früher Abend | Kommende Tageszeit: Abend 2025-01-25 16:00:22.485 - warn: hm-rega.0 (6801) State value to set for "hm-rega.0.10636" has value "10478.884942" greater than max "8800" 2025-01-25 16:30:00.106 - info: javascript.0 (6732) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 6] | [nächster Tag: 8] | [Aktualisiert: 0] | Aktuelle Tageszeit: früher Abend | Kommende Tageszeit: Abend 2025-01-25 16:30:22.508 - warn: hm-rega.0 (6801) State value to set for "hm-rega.0.10636" has value "10479.301609" greater than max "8800" 2025-01-25 17:00:00.104 - info: javascript.0 (6732) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 4] | [nächster Tag: 8] | [Aktualisiert: 2] | Aktuelle Tageszeit: Sonnenuntergang | Kommende Tageszeit: Abenddämmerung 2025-01-25 17:00:22.532 - warn: hm-rega.0 (6801) State value to set for "hm-rega.0.10636" has value "10479.718276" greater than max "8800" 2025-01-25 17:30:00.095 - info: javascript.0 (6732) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 3] | [nächster Tag: 10] | [Aktualisiert: 1] | Aktuelle Tageszeit: Abenddämmerung | Kommende Tageszeit: später Abend 2025-01-25 17:30:22.578 - warn: hm-rega.0 (6801) State value to set for "hm-rega.0.10636" has value "10480.134943" greater than max "8800" 2025-01-25 18:00:00.106 - info: javascript.0 (6732) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 1] | [nächster Tag: 12] | [Aktualisiert: 1] | Aktuelle Tageszeit: Nacht | Kommende Tageszeit: Mitternacht 2025-01-25 18:00:22.621 - warn: hm-rega.0 (6801) State value to set for "hm-rega.0.10636" has value "10480.55161" greater than max "8800" 2025-01-25 18:30:00.101 - info: javascript.0 (6732) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 1] | [nächster Tag: 13] | [Aktualisiert: 0] | Aktuelle Tageszeit: Nacht | Kommende Tageszeit: Mitternacht 2025-01-25 18:30:20.093 - info: admin.0 (6694) failed connection to socket.io from ::ffff:192.168.1.60: Passport was not initialized 2025-01-25 18:30:20.174 - info: admin.0 (6694) failed connection to socket.io from ::ffff:192.168.1.60: Passport was not initialized 2025-01-25 18:30:22.631 - warn: hm-rega.0 (6801) State value to set for "hm-rega.0.10636" has value "10480.968277" greater than max "8800" 2025-01-25 18:30:34.092 - info: admin.0 (6694) ==> Connected system.user.admin from ::ffff:192.168.1.60 2025-01-25 18:31:32.179 - info: javascript.0 (6732) Stopping script script.js.common.Gerate_Zaehlen_V1 2025-01-25 18:31:32.230 - info: javascript.0 (6732) Start JavaScript script.js.common.Gerate_Zaehlen_V1 (Javascript/js) 2025-01-25 18:31:32.300 - info: javascript.0 (6732) script.js.common.Gerate_Zaehlen_V1: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions 2025-01-25 18:34:07.573 - info: admin.0 (6694) ==> Connected system.user.admin from ::ffff:192.168.1.60 2025-01-25 18:35:44.149 - info: admin.0 (6694) <== Disconnect system.user.admin from ::ffff:192.168.1.60 javascript 2025-01-25 18:38:10.320 - info: web.0 (7193) ==> Connected system.user.admin from ::ffff:192.168.1.180 2025-01-25 18:40:35.697 - info: web.0 (7193) <== Disconnect system.user.admin from ::ffff:192.168.1.180 vis.0 2025-01-25 18:52:33.831 - info: web.0 (7193) ==> Connected system.user.admin from ::ffff:192.168.1.180 2025-01-25 18:53:10.078 - info: web.0 (7193) <== Disconnect system.user.admin from ::ffff:192.168.1.180 vis.0 -
Sollte ich eigentlich meinen Swap vergrößern?
top - 19:12:20 up 23:10, 1 user, load average: 0.22, 0.42, 0.62 Tasks: 192 total, 1 running, 191 sleeping, 0 stopped, 0 zombie %Cpu(s): 8.3 us, 2.2 sy, 0.0 ni, 89.1 id, 0.1 wa, 0.0 hi, 0.2 si, 0.0 st MiB Mem : 3790.9 total, 442.0 free, 2595.2 used, 827.2 buff/cache MiB Swap: 200.0 total, 0.6 free, 199.4 used. 1195.7 avail Mem -
top - 19:12:20 up 23:10, 1 user, load average: 0.22, 0.42, 0.62 Tasks: 192 total, 1 running, 191 sleeping, 0 stopped, 0 zombie %Cpu(s): 8.3 us, 2.2 sy, 0.0 ni, 89.1 id, 0.1 wa, 0.0 hi, 0.2 si, 0.0 st MiB Mem : 3790.9 total, 442.0 free, 2595.2 used, 827.2 buff/cache MiB Swap: 200.0 total, 0.6 free, 199.4 used. 1195.7 avail Mem@pb74 sagte in iobroker Absturz:
ich halte das für Blödsinn bei
1195.7 avail Mem
sieht richtig gut aus!
ich war schon euphorisch und wollte sagen "Problem gelöst", aber am Donnerstag 30.01. gegen Abend blieb das System wieder hängen.
Bis dato hatte ich mehrfach auch von Arbeit aus per VPN und SSH die Werte per top kontrolliert, es war alles i.O.
Um 18:54 Uhr wurde das automatische Update des Repositorys gestartet; danach gibt es keine Protokolleinträge mehr.
Am 31.01. finden sich ab ca. 05:30 Uhr wieder Einträge im Protokoll, jede Menge Fehler und Warnmeldungen. Ab ca. 05:35 Uhr gibt es keine Fehler mehr, nur noch zwei Warnungen:
a)
hm-rega.0 (275505) State value to set for "hm-rega.0.10636" has value "10600.135039" greater than max "8800"(der Max-Wert wurde inzwischen angepasst)
b)
javascript.0 (275428) script.js.common.DWD_Radarbild_holen: Fehler bei https://www.dwd.de/DWD/wetter/sat/satwetter/njob_satrad.png : AxiosError: stream has been abortedNun läuft alles wieder als wäre nichts gewesen ....
Hab grade noch das OS und auf Nodejs 20 geupdatet, mal schauen....Habt ihr vielleicht noch einen Ansatzpunkt für mich?
Danke schon mal !
Nach dem Neustart werden im Protokoll folgende Fehler + Warnungen angezeigt:
hm-rega.0 2025-02-01 16:30:16.783 warn State value to set for "hm-rega.0.10636" has value "10619.301721" greater than max "8800" hm-rega.0 2025-02-01 16:24:16.470 warn State value to set for "hm-rega.0.10636" has value "10618.885054" greater than max "8800" hm-rega.0 2025-02-01 16:23:41.027 error CCU 192.168.xxx.xxx unreachable hm-rega.0 2025-02-01 16:23:41.027 error post request error: Aborted due to timeout hm-rega.0 2025-02-01 16:23:41.008 warn "!# alarms.fn!#!# Dieses Homematic-Script gibt eine Liste aller Alarm-Datenpunk" timed out after 90 seconds sourceanalytix.0 2025-02-01 16:23:32.193 warn Cannot handle calculations for 1 of 2 enabled states, check error messages sourceanalytix.0 2025-02-01 16:23:32.182 error Initialization of modbus.0.inputRegisters.32332_Energie_EM1 failed, check warn messages ! sourceanalytix.0 2025-02-01 16:23:32.180 error Cannot handle calculations for modbus.0.inputRegisters.32332_Energie_EM1, check log messages and adjust settings! sourceanalytix.0 2025-02-01 16:23:32.180 error No cost type defined for modbus.0.inputRegisters.32332_Energie_EM1, please Select Type of calculation at state setting vis-2.0 2025-02-01 16:23:10.778 error No license found for vis-2. Please get one on https://iobroker.net !Offensichtlich hat meine "Anpassung" des Objekts hm-reg.0.10636 nichts gebracht, denn nach dem Neustart steht der Max-Wert wieder auf 8800.
Es handelt sich hierbei um den Wert eines Scriptes, das auf meiner CCU3 (IP 192.168.xxx.xxx) läuft und die Betriebsstunden eines Lüfters wiedergibt.
Offensichtlich wird der Max-Wert irgendwie in dem CCU-Script mit "8800" beschrieben...wo das passiert muss ich noch rausfinden.Lässt sich zu den anderen Fehlern eurerseits etwas sagen?
a)
b)
Danke schon mal !
Ich habe ein ähnliches Problem, mein System läuft ab und zu mal Amok, mit einer sehr hohen Auslastung im load average, allerdings habe ich keinerlei Fehlermeldungen. Ich hab mir ein kleines Script für die Konsole geschrieben, um das Problem Zeitlich eingrenzen zu können.
#!/bin/bash # Dateiname loadAverage_v2.sh # setze Dateiberechtigung für Benutzer # sudo chmod u+x loadAverage_v2.sh while true; do uptime >> /home/xxxx/bin/load_average.log sleep 60 doneSeit dem ich das Script rund um die Uhr laufen lasse, ist der Amoklauf des Systems nur einmal aufgetreten, wie immer ohne jegliche Fehlermeldung.
@binarie, danke für Deinen Tipp.
Da ich nicht so der Programmierer bin, könntest Du mir bitte erläutern, was Dein Script macht?
EDIT: Wie lange läuft dieses Script schon bei Dir?
Das schreibt alle 60 Sekunden die Ausgabe von
uptimein eine Text-Datei.Mehr macht es nicht.
Es läuft jetzt vier Tage, das Ergebnis bei hoher Auslastung :
16:34:02 up 2 days, 22:50, 2 users, load average: 4,17, 4,87, 4,15 16:35:02 up 2 days, 22:51, 2 users, load average: 4,30, 4,74, 4,14 16:36:02 up 2 days, 22:52, 2 users, load average: 6,52, 5,19, 4,32 16:37:02 up 2 days, 22:53, 2 users, load average: 7,28, 5,52, 4,48 16:38:02 up 2 days, 22:54, 2 users, load average: 7,16, 5,70, 4,60 16:39:02 up 2 days, 22:55, 2 users, load average: 7,31, 5,90, 4,72 16:40:02 up 2 days, 22:56, 2 users, load average: 6,34, 5,79, 4,75 16:41:02 up 2 days, 22:57, 2 users, load average: 6,07, 5,74, 4,80 16:42:02 up 2 days, 22:58, 2 users, load average: 6,05, 5,71, 4,84 16:43:02 up 2 days, 22:59, 2 users, load average: 5,82, 5,65, 4,86Normale Auslastung:
1:10:04 up 3 days, 3:26, 2 users, load average: 0,21, 0,30, 0,39 21:11:04 up 3 days, 3:27, 2 users, load average: 0,12, 0,26, 0,37 21:12:04 up 3 days, 3:28, 2 users, load average: 0,24, 0,26, 0,36 21:13:04 up 3 days, 3:29, 2 users, load average: 0,09, 0,21, 0,34 21:14:04 up 3 days, 3:30, 2 users, load average: 0,03, 0,17, 0,31 21:15:04 up 3 days, 3:31, 2 users, load average: 0,08, 0,15, 0,29 21:16:04 up 3 days, 3:32, 2 users, load average: 0,03, 0,12, 0,27 21:17:04 up 3 days, 3:33, 2 users, load average: 0,05, 0,11, 0,26 21:18:04 up 3 days, 3:34, 2 users, load average: 0,02, 0,09, 0,24 21:19:04 up 3 days, 3:35, 2 users, load average: 0,00, 0,07, 0,22 21:20:04 up 3 days, 3:36, 2 users, load average: 0,36, 0,14, 0,24 21:21:04 up 3 days, 3:37, 2 users, load average: 0,55, 0,25, 0,27 -
Ich habe mir /home/[mein Benutzername] dieses Script per nano mit dem von Dir angegebenen Dateinamen angelegt und mit
sudo chmod u+x loadAverage_v2.shausführbar gemacht. Im WinSCP konnte ich auch sehen, wie in den Rechten das "x" gesetzt wurde.
Danach habe ich das Script mit
./loadAverage_v2.shgestartet. Es hat mir auch die Datei angelegt und die ersten zwei Werte reingeschrieben.
Danach hab ich putty beendet und nun schreibt das Script nicht weiter.... ich hab bestimmt jede Menge falsch gemacht...das Script soll ja ständig laufen.Ich bitte schon mal um Entschuldigung für die ganzen Anfängerfragen, aber das ist "mein erstes Mal", das ich auf diese Art und Weise unter Linux mit Scripten arbeite.
Vielleicht kann mir jemand weiterhelfen, bevor ich mir noch mein System zerlege...
Dankeschön
