  4. E-INK Display OpenEPaperLink - Displayanzeige mit Batterie
    6.3k
1.0k Beiträge 49 Kommentatoren 443.3k Aufrufe 52 Beobachtet
  • EisbaeeerE Eisbaeeer
    Geht es anderen auch so, dass nach Update von Pupeteer das Blockly nicht mehr funktioniert?
    Hatte jetzt nicht weiter verfolgt, ob das Problem schon behoben ist.
    Meldung:
    javascript.0	11:18:11.773	error	at Object.<anonymous> (script.js.common.EPaper.Tag1:42:24)
    sendTo('puppeteer.0', 'screenshot', {
        url: urlOfVISView,
        path: imageSaveToFilenameWithPath,
        width: viewWidth,
        height: viewHeight,
        quality: jpgQuality,
        waitOption: {
            waitForSelector: waitForSelector,
            waitForTimeout: 20000
        fullPage: false,
        clip: {
            x: cutoutX,
            y: cutoutY,
            width: cutoutWidth,
            height: cutoutHeight
    }, obj => {
        if (obj.error) {
            console.warn("Fehler beim Aufruf der View: " + urlOfVISView + " => " + obj.error.message);
        } else {
            const http = require('http');
            const https = require('https');
            const { URL } = require('url');
            const boundary = '--------------------------' + Date.now().toString(16);
            const CRLF = '\r\n';
            // Payload-Erstellung
            const payload = Buffer.concat([
                Buffer.from(`--${boundary}${CRLF}Content-Disposition: form-data; name="dither"${CRLF}${CRLF}0${CRLF}`),
                Buffer.from(`--${boundary}${CRLF}Content-Disposition: form-data; name="mac"${CRLF}${CRLF}${ePaperMAC}${CRLF}`),
                Buffer.from(`--${boundary}${CRLF}Content-Disposition: form-data; name="image"; filename="screenshot.jpg"${CRLF}Content-Type: image/jpeg${CRLF}${CRLF}`),
                Buffer.from(obj.result, 'binary'),
                Buffer.from(`${CRLF}--${boundary}--${CRLF}`)
            // URL Parsing
            const url = new URL(imageUploadURL);
            const options = {
                hostname: url.hostname,
                port: url.port || (url.protocol === 'https:' ? 443 : 80),
                path: url.pathname + (url.search || ''),
                method: 'POST',
                headers: {
                    'Content-Type': 'multipart/form-data; boundary=' + boundary,
                    'Content-Length': payload.length
            // Protokollwahl
            const protocol = url.protocol === 'https:' ? https : http;
            // HTTP Request
            const req = protocol.request(options, function(res) {
                console.log('ImageUploadStatusCode:', res.statusCode);
                res.on('data', function(chunk) {
                    console.log('Response:', chunk.toString());
            req.on('error', function(e) {
                console.error('Fehler beim Hochladen:', e.message);
            req.write(payload);
            req.end();
    Beowolf
    #871
    @eisbaeeer
    Hatte ich doch auch geschrieben. Ich habe seit einem "komplett" Update auch nur noch Probleme mit Puppeteer und dem Skript..
    haselchenH EisbaeeerE 2 Antworten Letzte Antwort
    • B Beowolf
      @eisbaeeer
      haselchenH Offline
      haselchenH Offline
      haselchen
      #872
      @beowolf
      Puh, da gibt es auf Github glaube ich ne Anleitung wie man das über den Google Kalender realisiert.
      Ich habs 1 mal gemacht und seitdem läuft es.
      Mehr als zufriedenstellend.
      Ich versuche mal die Anleitung zu finden....
      Edit:
      https://github.com/OpenEPaperLink/OpenEPaperLink/wiki/Google-Apps-Scripts
      https://github.com/OpenEPaperLink/OpenEPaperLink/wiki/ICS-calendar
      • haselchenH haselchen
        @beowolf
        Edit:
        Beowolf
        schrieb am zuletzt editiert von Beowolf
        #873
        @haselchen
        Die Anleitung kenne ich.
        Bei den grossen Displays sieht dann die Terminansicht so aus.
        Das hilft mir leider nicht weiter.
        Auf den kleinen sieht der selbe Link so aus.
        • B Beowolf
          @haselchen
          haselchenH Offline
          haselchenH Offline
          haselchen
          #874
          @beowolf
          Bei den großen Displays kann ich nicht mitreden.
          Hab die kleinen Rechteckigen.
          Dachte die Konfig wäre anpassbar.
          • B Beowolf
            @eisbaeeer
            EisbaeeerE Offline
            EisbaeeerE Offline
            Eisbaeeer
            #875
            @beowolf
            Ich versuche gerade das Java-Script zu fixen. Es liegt nicht an Puppeteer, das Bild wird erstellt. Beim Javascript hat sich bei Update was geändert. Der erste Fehler ist mal weg. Ich weiß nur noch nicht, ob das so passt. Jetzt läuft das Script aber in ein Timeout beim hochladen. Da stimmt also noch etwas nicht.
                url: urlOfVISView,
                width: viewWidth,
                height: viewHeight,
                waitOption: {
                fullPage: false,
                clip: {
                    x: cutoutX,
                    y: cutoutY,
                    width: cutoutWidth,
            }, obj => {
                if (obj.error) {
                } else {
                        Buffer.from(Object.values(`--${boundary}${CRLF}Content-Disposition: form-data; name="dither"${CRLF}${CRLF}0${CRLF}`)),
                        Buffer.from(Object.values(`--${boundary}${CRLF}Content-Disposition: form-data; name="mac"${CRLF}${CRLF}${ePaperMAC}${CRLF}`)),
                        Buffer.from(Object.values(`--${boundary}${CRLF}Content-Disposition: form-data; name="image"; filename="screenshot.jpg"${CRLF}Content-Type: image/jpeg${CRLF}${CRLF}`)),
                        Buffer.from(Object.values(obj.result, 'binary')),
                        Buffer.from(Object.values(`${CRLF}--${boundary}--${CRLF}`))
                    console.log(payload);
                    // URL Parsing
                    const options = {
                        method: 'POST',
                        headers: {
                    // Protokollwahl
                    // HTTP Request
                    req.write(payload);
                    req.end();
            Kein support per PM. Bitte im Forum Fragen stellen!
              Beowolf
              #876
              Das das mit Javascript zusammen hängt hatte ich auch schon gedacht. Die Bildchen werden ja schließlich immer sehr schnell erstellt.
                Beowolf
                #877
                War ein Fehler.
                • BananaJoeB BananaJoe
                  @beowolf sagte in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
                  Ich bin ein wenig Ratlos und weiß nicht wo ich anfangen soll.
                  Hier mal grob in Schritten zusammengefasst:
                  Schritt 1: Eigene VIS für die ePaper Tags
                  Im VIS Editor hatte ich ein neues Projekt erstellt - hier openepaper genannt:
                  In dem Projekt habe ich dann jeweils eine Seite für jedes Tag angelegt. Hier zum Beispiel für den Briefkasten, ein 2,9" Tag:
                  Wie man sieht habe ich unter Tools für diese View eine Auflösung von 296x128 Pixel eingestellt. Das habe ich gemacht weil er mir dann den roten Rahmen um diesen Bereich malt und ich weiß wo/wie ich die Elemente platzieren muss.
                  Man kann auch beliebige Elemente außerhalb des roten Rahmens platzieren, die sind dann aber später halt nicht zu sehen. Hier habe ich das für einen Informationstext genutzt und ich parke auch nicht genutzte Elemente die ich aber vielleicht noch mal brauche so. Hier ist also das Batteriesymbol und die Prozentanzeige in Zahl und als Balken zu sehen.
                  Die 2,9" Tags könnten 3 Farben: Rot (#FF0000), Schwarz (#000000) und Weiß (#FFFFFF), also am besten die Elemente in dieser Mini-View in diesen 3 Farben halten.
                  Diese Seite hat später eine URL die man sich ja auch über die Play-Schaltfläche oben rechts ansehen kann (Runtime in einem neuen Fenster aufmachen). Bei mir ist die URL die folgende
                  http://192.168.1.8:8082/vis/index.html?openepaper#Briefkasten
                  Drückt auf den Play Button und kopiert euch die URL einfach dort heraus wenn wir diese dann brauchen.
                  Schritt 2: Puppeteer installieren wenn noch nicht geschehen
                  Installiert den Adapter Puppenspieler
                  und stellt sicher das dieser dann auch eine laufende Instanz hat:
                  Sollte der Adapter nicht auf Grün springen (weil ihr das ganze z.B. auf einem Raspberry Pi laufen habt) so beachtet bitte diesen Issue hier, da wird beschrieben wie Ihr den dann trotzdem zum laufen bekommt: https://github.com/foxriver76/ioBroker.puppeteer/issues/13
                  Schritt 3: Blockly-Skript das die VIS-View an das ePaper Tag sendet
                  Ich beschreibe das hier für Blockly, wer das nicht nutzt kann sich ja den passenden Code herauskopieren.
                  Das ganze habe ich mir auch nicht alleine ausgedacht sondern ist die Sammlung aus den anderen Artikel hier (und wahrscheinlich anderen aus dem Forum hier).
                  Das Aufrufen von Puppeteer habe ich in eine eigene Funktion gepackt. Es holt den Screenshot und sendet diesen auch gleich an das ePaper-Tag.
                  Erstellt am besten ein neues Blockly-Skript und importiert diese Vorlage:
                  <block xmlns="https://developers.google.com/blockly/xml" type="procedures_defcustomnoreturn" id="od4:#LN4MMPOX5Cuwv0G" x="63" y="-187">
                    <mutation statements="false">
                      <arg name="imageSaveToFilenameWithPath" varid="#6wGK,7)K9MvKS1Y^m7w"></arg>
                      <arg name="urlOfVISView" varid="/34/q/S9,6lBaN0B^0p+"></arg>
                      <arg name="viewWidth" varid="VtK5T):T+/?(:RTltehP"></arg>
                      <arg name="viewHeight" varid="d%Y)z(!gms*2[:-Q?srZ"></arg>
                      <arg name="cutoutX" varid="yI1;;SNF[v//PXeFn75c"></arg>
                      <arg name="cutoutY" varid="ixza1C+:$RS#_aO(+mTw"></arg>
                      <arg name="cutoutWidth" varid="JHgH!or}TSYU@4ok~:dD"></arg>
                      <arg name="cutoutHeight" varid="pui*x3;[n/WA5nodRtex"></arg>
                      <arg name="jpgQuality" varid="{l]%ubA0HMv*]m|`-bQ#"></arg>
                      <arg name="waitForSelector" varid="^}k9.{.g,!Q=P%/G;/%p"></arg>
                      <arg name="imageUploadURL" varid="O}nZ-9?%oQZ/=~9D;8MW"></arg>
                      <arg name="ePaperMAC" varid="$iC+L#(86gFYKS_:{d3%"></arg>
                    </mutation>
                    <field name="NAME">ScreenshotVISandUpload2OpenEPaperLink</field>
                    <field name="SCRIPT">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</field>
                  </block>
                  Das ergibt diese JavaScript-Funktion:
                  mit folgenden Quelltext:
                      url: urlOfVISView,                      /* URL der Webseite aus welcher der Screenshot erstellt werden soll */
                      path: imageSaveToFilenameWithPath,      /* Dateiname und Pfad für lokales Speichern des Bildes */
                      width: viewWidth,                       /* Breite des virtuellen Browserfensters */
                      height: viewHeight,                     /* Höhe des virtuellen Browserfensters */
                      quality: jpgQuality,                    /* Qualität des JPG, sollte immer 100 sein */
                      waitOption: {
                          waitForSelector: waitForSelector,   /* Wartet for dem Screenshot bis dieses Objekt sichtbar ist */
                          waitForTimeout: 10000               /* Timeout, solange wird auf das Objekt gewartet */
                      fullPage: false,                        /* True würde die ganze Seite Snapshoten und die clip-Anweisungen ignorieren */
                      clip: {
                          x: cutoutX,                         /* Koordinate X an der der Ausschnitt beginnen soll */
                          y: cutoutY,                         /* Koordinate Y an der der Ausschnitt beginnen soll */
                          width: cutoutWidth,                 /* Breite des Ausschnittes */
                          height: cutoutHeight                /* Höhe des Ausschnittes */
                  }, obj => {
                        if (obj.error) {
                        } else {
                            /* in obj.result sind die Binärdaten des Bildes */
                          var request = require('request');
                          var options = {
                              url: imageUploadURL,
                              method: 'POST',
                              formData: {
                                  "dither": "0",
                                  "mac": ePaperMAC,
                                  "image": obj.result },
                          /* und die URL aufrufen: */
                          request(options,function (error, response, body){
                              //log("Login-Antwort: " + JSON.stringify(response));
                              //console.warn("ImageUpload: " + JSON.stringify(response));
                              console.log("Image:" + imageSaveToFilenameWithPath + " => ImageUploadStatusCode: " + response.statusCode);
                              if(parseInt(body.error_code)==0) {
                                  // nix
                                  } else {
                                  // wieder nix
                  Nun findet Ihr unten unter Funktionen diese neue mit dem sperrigen Namen ScreenshotVISandUpload2OpenEPaperLink:
                  Hui Tiffy, ganz schön viele Parameter! Keine Angst, die gehen wir gleich durch.
                  Als nächstes Sammeln wir zwei der notwendigen Parameter und speichern diese in Variablen die ihr selbst neu erstellen müsst:
                  Ist die URL eures OpenEPaper AccessPoints, also die IP-Adresse über welche Ihr die Weboberfläche des AccessPoints erreicht. daran hängt Ihr ein /imguplad an. Vollständig also so:
                  http://192.168.2.131/imgupload
                  Die Adresse 192.168.2.131 müsst ihr natürlich an eure anpassen.
                  ist die MAC des ePaper-Tags welches den Inhalt erhalten soll. Die MAC findet Ihr auf der Weboberfläche des Tags. Aus dem Dialog wenn man es anklickt kann man diese oben links markieren und kopieren:
                  Denn Rest habe ich hier bei mir direkt eingetragen, AP und Tag habe ich Variablen gespeichert weil ich diese so schnell ändern kann ohne das ganze Skript durchgehen zu müssen.
                  Unter die beiden Variablen setzen wir nun den JavaScript Block und befüllen die Parameter:
                  Die Parameter im Detail:
                  Ist der Dateiname und Pfad wohin er den Screenshot speichert. Das muss also ein Ort sein wohin der Benutzer iobroker schreiben darf. /tmp/ sollte immer gehen. Eigentlich brauchen wir die Datei gar nicht, aber Puppeteer will die nun mal speichern. Andere hatten hier in den Beispielen gar keinen Pfad angegeben, das klappt bei mir nicht, dann versucht er das Bild im Ordner von Puppeteer zu speichern was nicht erlaubt ist.
                  Gebt hier also Pfad mit Dateinamen an, die Endung muss .jpg sein:
                  /tmp/briefkasten-test.jpg
                  Ist die URL zu eurer View - am besten oben aus der Adressleiste kopieren und hier einfügen
                  Puppeteer ruft die Seite auf wie ein Webbrowser das machen würde. Die Angabe ist wie groß das Browserfenster ist. Hier also 800x600 Pixel. Beachtet das die Felder Blau sind - das ist der Zahlenblock aus dem Mathematik-Menü
                  Das ist die Größe des Ausschnitts gefolgt von der Qualität.
                  Die ersten beiden 0 sind die Koordinaten welche die Ecke oben links beschreiben.
                  296 ist die Breite (nach rechts), 128 die Höhe (nach unten). Das ist der Bildausschnitt den er dann speichert.
                  Die Qualität sollte immer 100 sein damit das Bild besser aussieht.
                  Dieser Eintrag lässt Puppeteer auf dieses View-Widget warten und erst dann den Screenshot auslösen. So ist sichergestellt das die Seite fertig geladen ist, er aber auch nicht unnötig lange wartet bis er weiter macht. Diese Widget-Id könnt Ihr auf 2 Arten bekommen:
                  Ihr geht in den VIS-Editor auf die betreffen View und lasst euch die Liste mit den Widgets anzeigen:
                  Nehmt im Zweifel das Widget mit der höchsten Nummer. Oder das was auf jeden Fall zu sehen sein muss.
                  Die andere Methode ist das Ihr euch den Quelltext der Webseite mit der View anzeigen lasst (die nach Play erscheint) und dort die #w00.... Einträge durchgeht. Im Quelltext könnt Ihr ja auch suchen und so im Zweifel prüfen ob das Widget dabei ist.
                  Sind unsere beiden Varibalen mit der URL und der MAC.
                  Wenn Ihr das Skript speichert und ausführt - und es keine Fehler gibt - sollte er einmalig das Bild auf den ePaper Tag schieben.
                  Unten und im Log sollte eine Info-Meldung erscheinen wenn er das Bild am AccessPoint abgeliefert hat.
                  Schritt 4:
                  Wenn das funktioniert könnt Ihr das Skript erweitern so das er immer sendet wenn sich in eurer VIS etwas geändert hat.
                  Beachtet das der AP das Bild immer annehmen wird. Er sendet es aber nur neu an den ePaper Tag wenn das Bild sich auch verändert hat.
                  Edit 22.01.2022: Typos + Satzbau
                  WebrangerW Offline
                  WebrangerW Offline
                  Webranger
                  #878
                  @bananajoe
                  Läuft das Puppeteer script eigentlich noch?
                  Bei mir kommt folgender fehler:
                  javascript.0	21:47:14.718	warn	script.js.common.TestScripte.epaperTEST_1: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                  javascript.0	21:47:14.721	error	at Object.<anonymous> (script.js.common.TestScripte.epaperTEST_1:42:13)
                  Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
                  • WebrangerW Webranger
                    @bananajoe
                    Beowolf
                    #879
                    @webranger sagte in E-INK Display OpenEPaperLink - Displayanzeige mit Batterie:
                    @bananajoe
                    Na ja, das mit dem httpGet ist aber schon etwas älter.
                    Nimm dieses hier.
                    https://forum.iobroker.net/topic/66380/e-ink-display-openepaperlink-displayanzeige-mit-batterie/753?_=1737702534630
                    Das funktioniert. Es gibt aber im Moment wohl kleine Probleme mit Javascript.
                    Siehe
                    https://forum.iobroker.net/topic/66380/e-ink-display-openepaperlink-displayanzeige-mit-batterie/875?_=1737702534633
                    • H Offline
                      holgerwolf
                      #880
                      Mal was ganz anderes. Ich habe hier ein ST-GR 29000 Display was sich alle paar Stunden (1 mal in 24 Stunden, unregelmäßige Zeit) verabschiedet.
                      Standort kann es nicht sein. Nimm ich kurz die Batterien raus läuft es auch wieder.
                      Der Inhalt wird mit einem JSON beschickt.
                      Ist das einfach kaputt oder noch ne andere Idee?
                      H 1 Antwort Letzte Antwort
                      • E eMd
                        Ich bedanke mich bei euch allen und vorallem bei @BananaJoe !
                        Ich weiß nicht warum, aber es geht nun, habe in der zwischenzeit gefühlt 1000 Sachen geändert und mit einmal geht es.
                        Keine Ahnung wo da der Fehler lag...
                        MfG
                        eMd
                        WebrangerW Offline
                        WebrangerW Offline
                        Webranger
                        #881
                        @emd said in E-INK Display OpenEPaperLink - Displayanzeige mit Batterie:
                        MfG
                        eMd
                        Läuft dein script noch? Ich habe auch das Bild im /tmp/ Ordner vom iobroker und einen Code 200 aber irgendwie zeigt er mir im AP Temp nichts an.
                        Log vom AP bleibt leider leer
                        @all Kann ich das Bild nicht auch irgendwo speichern wo sich der Tag das abholen kann?
                          Beowolf
                          #882
                          Bin mir nicht sicher ob das zur Fehlersuche beiträgt, aber wenn ich in VIS etwas ändere, erscheinen die von mir beschriebenen Fehlermeldungen.
                          Wenn ich den Javaskript und den Puppeteer Adapter NACH den Änderungen neu starte, kommen die Meldungen so wie es schein nicht mehr.
                          • B Beowolf
                            BananaJoeB Offline
                            BananaJoeB Offline
                            BananaJoe
                            #883
                            @beowolf Eventuell hängt es mit dem Widget auf das das Skript wartet zusammen? Sollte es das nach einer Änderung nicht mehr geben, wäre das ein Grund.
                              Beowolf
                              #884
                              Ich bin jetzt aber auch dazu übergegangen, das ich die TAGs die nur einfache Werte von z.B. HM-Heizungsventilen anzeigen, mit diesem Blockly zu versorgen.
                                <variables>
                                  <variable id="e.-?J1RG(1E03apliOsd">url</variable>
                                  <variable id="eMqV!m8?ZCdqN2].w`xb">TagMini1</variable>
                                  <variable id="*)}|9mHpKcV3YN}|a_t5">jsonMini1</variable>
                                </variables>
                                <block type="procedures_defcustomreturn" id="Q)=N/g,e;;C$aa#GZ/g6" x="738" y="388">
                                    <arg name="url" varid="e.-?J1RG(1E03apliOsd"></arg>
                                  </mutation>
                                  <field name="NAME">encodeURL</field>
                                  <field name="SCRIPT">dXJsID0gZW5jb2RlVVJJQ29tcG9uZW50KHVybCk7DQpyZXR1cm4gdXJsOw==</field>
                                </block>
                                <block type="on_ext" id="P$af/8byEUS#qCA]5B-P" x="738" y="413">
                                  <mutation xmlns="http://www.w3.org/1999/xhtml" items="4"></mutation>
                                  <value name="OID0">
                                    <shadow type="field_oid" id="qKgG$O[{3RUIQEMyX@84">
                                      <field name="oid">hm-rpc.0.NEQ1405541.4.ACTUAL_TEMPERATURE</field>
                                    </shadow>
                                  </value>
                                  <value name="OID1">
                                    <shadow type="field_oid" id="1=$zeB_8NZ{``1IKhA@;">
                                      <field name="oid">hm-rpc.0.NEQ1405541.4.SET_TEMPERATURE</field>
                                    </shadow>
                                  </value>
                                  <value name="OID2">
                                    <shadow type="field_oid" id="3xv_){1%Z-Px_oc=|ee]">
                                      <field name="oid">hm-rpc.0.NEQ1405541.4.VALVE_STATE</field>
                                    </shadow>
                                  </value>
                                  <value name="OID3">
                                    <shadow type="field_oid" id="1%z%;+tP3g0pYuG^87_*">
                                      <field name="oid">hm-rpc.0.NEQ1405541.4.BATTERY_STATE</field>
                                    </shadow>
                                  </value>
                                  <statement name="STATEMENT">
                                    <block type="variables_set" id="}kvQ}B#.rViPjfKc-HTi">
                                      <field name="VAR" id="eMqV!m8?ZCdqN2].w`xb">TagMini1</field>
                                      <value name="VALUE">
                                        <block type="text" id="AS0{YNAIOlM%S|LO,c(?">
                                          <field name="TEXT">00007E1BDCCFB291</field>
                                        </block>
                                      </value>
                                      <next>
                                        <block type="variables_set" id="k02GjbFfyHgTN`gcO-Da">
                                          <field name="VAR" id="*)}|9mHpKcV3YN}|a_t5">jsonMini1</field>
                                            <block type="procedures_callcustomreturn" id="m+$OB%}5|)Pwa;Sp_8Xz">
                                              <mutation name="encodeURL">
                                                <arg name="url"></arg>
                                              </mutation>
                                              <value name="ARG0">
                                                <block type="text_join" id="%7M,-4ru#q{/k6KDWMHm">
                                                  <mutation items="11"></mutation>
                                                  <value name="ADD0">
                                                    <block type="text" id="KG:U*zHU9}`ZAfY=W0tK">
                                                      <field name="TEXT">[    {"text": [10,10,"Hauswirtschaftsraum","fonts/bahnschrift30",2]},</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                    <block type="text" id="J8kE(`F|;UG(UnXYIXH/">
                                                      <field name="TEXT">{"line": [10,35,374,35,1]},</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                    <block type="text" id="n|(:Q;;@|/rl*,,eDMQ0">
                                                      <field name="TEXT">{"text": [10,50,"Aktuelle Temperatur:","fonts/bahnschrift20",1]},     {"text": [240,50,"</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD3">
                                                    <block type="get_value" id="Ivop[TTx6k8izC(a}Lh$">
                                                      <field name="OID">hm-rpc.0.NEQ1405541.4.ACTUAL_TEMPERATURE</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD4">
                                                    <block type="text" id=".;[edg]Q8Y}~9~$]`WGh">
                                                      <field name="TEXT">°C","fonts/bahnschrift20",2]},     {"text": [10,80,"Eingestellte Temperatur:","fonts/bahnschrift20",1]},   {"text": [240,80,"</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD5">
                                                    <block type="get_value" id="!vH6u](8OPQ3|j4+-R0`">
                                                      <field name="OID">hm-rpc.0.NEQ1405541.4.SET_TEMPERATURE</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD6">
                                                    <block type="text" id="10FFF9ZLy|n:h)tY)c|m">
                                                      <field name="TEXT">°C","fonts/bahnschrift20",2]},     {"text": [10,110,"Aktuelle Ventilstellung:","fonts/bahnschrift20",1]},   {"text": [240,110,"</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD7">
                                                    <block type="get_value" id="N~fNY_bADcQ(?eeOcd70">
                                                      <field name="OID">hm-rpc.0.NEQ1405541.4.VALVE_STATE</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD8">
                                                    <block type="text" id="#7e9sI0@iu:c/+?Dr@Z.">
                                                      <field name="TEXT"> %","fonts/bahnschrift20",2]},     {"text": [10,140,"Batteriespannung:","fonts/bahnschrift20",1]},   {"text": [240,140,"</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD9">
                                                    <block type="get_value" id="M=3Q06RUua?Te,a?1Ui;">
                                                      <field name="OID">hm-rpc.0.NEQ1405541.4.BATTERY_STATE</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD10">
                                                    <block type="text" id="8Mjb{3)XGWhzToz{:.]t">
                                                      <field name="TEXT"> V","fonts/bahnschrift20",2]}  ]</field>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <next>
                                            <block type="http_post" id="AoQ+~mSdktWzhHgxGz#C">
                                              <field name="TIMEOUT">15</field>
                                              <field name="TYPE">text</field>
                                              <value name="URL">
                                                <shadow type="text" id="qh|GfefbC0op9nMhC4nk">
                                                  <field name="TEXT">http://192.168.49.186/jsonupload</field>
                                                </shadow>
                                              </value>
                                              <value name="DATA">
                                                <block type="text_join" id="YiM(/:1NU2PK@ysCbT8$">
                                                  <mutation items="4"></mutation>
                                                  <value name="ADD0">
                                                    <block type="text" id="sY#__Tq@9.DrJShh~Ant">
                                                      <field name="TEXT">mac=</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                    <block type="variables_get" id="^ag2u;YyTY9!dP{tJ|}c">
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                    <block type="text" id="k:I$k7w),ZmO9hEwr:$W">
                                                      <field name="TEXT">&amp;json=</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD3">
                                                    <block type="variables_get" id="MEQ/.CHU]v1WHbuc@`Ly">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                </block>
                              </xml>
                              Das läuft deutlich einfacher.
                              Alle anderen TAGs, z.B. die TAGs die den Inhalt von Terminkalendern anzeigen sollen, versorge ich mit dem "Puppeteer-Skript".
                              Es scheint, das das etwas Ruhe in dieser ganzen "Screenshot-Abfragerei" gebracht hat.
                              Wenn jemand eine Idee hat, wie ich das was vom ical Adapter zur Verfügung gestellt wird, sauber auf den größeren TAG darstellen kann, immer her damit. Bitte nicht den Google-Ansatz. Da ist die Anzeige auf größeren TAGs ganz anderes als wenn man das zu einem kleinen TAGs sendet.
                              WebrangerW 1 Antwort Letzte Antwort
                              • B Beowolf
                                  <variables>
                                  </variables>
                                    </mutation>
                                  </block>
                                    <value name="OID0">
                                      </shadow>
                                    </value>
                                    <value name="OID1">
                                      </shadow>
                                    </value>
                                    <value name="OID2">
                                      </shadow>
                                    </value>
                                    <value name="OID3">
                                      </shadow>
                                    </value>
                                          </block>
                                        </value>
                                        <next>
                                                </mutation>
                                                <value name="ARG0">
                                                    <value name="ADD0">
                                                      </block>
                                                    </value>
                                                    <value name="ADD1">
                                                      </block>
                                                    </value>
                                                    <value name="ADD2">
                                                      </block>
                                                    </value>
                                                    <value name="ADD3">
                                                      </block>
                                                    </value>
                                                    <value name="ADD4">
                                                      </block>
                                                    </value>
                                                    <value name="ADD5">
                                                      </block>
                                                    </value>
                                                    <value name="ADD6">
                                                      </block>
                                                    </value>
                                                    <value name="ADD7">
                                                      </block>
                                                    </value>
                                                    <value name="ADD8">
                                                      </block>
                                                    </value>
                                                    <value name="ADD9">
                                                      </block>
                                                    </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                                <value name="URL">
                                                  </shadow>
                                                </value>
                                                <value name="DATA">
                                                    <value name="ADD0">
                                                      </block>
                                                    </value>
                                                    <value name="ADD1">
                                                      </block>
                                                    </value>
                                                    <value name="ADD2">
                                                      </block>
                                                    </value>
                                                    <value name="ADD3">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                </xml>
                                WebrangerW Offline
                                WebrangerW Offline
                                Webranger
                                #885
                                Ich hab jetzt mal einen anderen Ansatz verfolgt und mit hilfe von ChatGPT ein script erstellt welches mir mit Puppeteer einen Screenshoot erstellt und dann per ftp auf eine diskstation schiebt die eh bei mir im Keller steht. Dort kann sich nun openEPaper Link das Bild abholen und macht dieses auch.
                                const puppeteer = require("puppeteer");
                                const ftp = require("basic-ftp");
                                // Funktion für die Hauptlogik
                                async function captureAndUpload() {
                                    const client = new ftp.Client();
                                    client.ftp.verbose = true;
                                    try {
                                        // Browser starten
                                        const browser = await puppeteer.launch();
                                        const page = await browser.newPage();
                                        // Seite laden und warten, bis sie vollständig geladen ist
                                        await page.goto("http://192.168.178.80:8082/vis/index.html?xxxxxxxxxx", { waitUntil: "networkidle0" });
                                        console.log("Seite vollständig geladen.");
                                        // Screenshot erstellen
                                        const clipRegion = { x: 0, y: 0, width: 296, height: 128 };
                                        const screenshotPath = "/tmp/screenshot.jpg";
                                        await page.screenshot({
                                            path: screenshotPath,
                                            type: "jpeg",
                                            quality: 100,
                                            clip: clipRegion
                                        console.log("Screenshot gespeichert:", screenshotPath);
                                        await browser.close();
                                        // FTP-Verbindung herstellen
                                        await client.access({
                                            host: "192.168.xxx.xx",
                                            user: "xxxxxxx",
                                            password: "xxxxxxx",
                                            secure: false
                                        console.log("Mit FTP-Server verbunden");
                                        // Datei hochladen
                                        await client.uploadFrom(screenshotPath, "/web/screenshot.jpg");
                                        console.log("Screenshot erfolgreich hochgeladen!");
                                    } catch (err) {
                                        console.error("Fehler:", err.message);
                                    } finally {
                                        client.close();
                                // Scheduler: alle 60 Minuten ausführen
                                schedule("*/60 * * * *", async () => {
                                    console.log("Starte Screenshot- und Uploadprozess...");
                                    await captureAndUpload();
                                Jetzt ist es aber so das das Bild korekt erstellt wird und auch abgeholt wird.
                                Im tmp Ordner wird es richtig angezeigt und dann auf dem Tag dann nicht mehr.
                                Was könnte das sein bzw wo dran liegt das?
                                      try {
                                          // Browser starten
                                              type: "jpeg",
                                              quality: 100,
                                              clip: clipRegion
                                              user: "xxxxxxx",
                                              secure: false
                                          // Datei hochladen
                                      } catch (err) {
                                      } finally {
                                          client.close();
                                  sameOne
                                  #886
                                  @webranger Deine Auflösung ist auf 296 x 128 gesetzt jedoch hat das genutzte Display eine Auflösung von 384 x 184
                                  • S sameOne
                                    WebrangerW Offline
                                    WebrangerW Offline
                                    Webranger
                                    #887
                                    @atc sagte in E-INK Display OpenEPaperLink - Displayanzeige mit Batterie:
                                    384
                                    Danke! So einfach kann es sein. Habe tätsächlich gedacht weil kleiner ist muss doch erst recht angezeigt werden.
                                    Damit kann ich jetzt arbeiten und funktioniert
                                    • H holgerwolf
                                      holgerwolf
                                      #888
                                      @holgerwolf Ich gebe mir mal selbst Antwort:
                                      Anderes Display, gleicher Inhalt und Standort läuft seit einigen Tagen durch
                                      Also hat das Display wohl ne Macke :-(
                                      • Basti97B Offline
                                        Basti97B Offline
                                        Basti97
                                        #889
                                        Welche Hardware brauche ich dazu eigentlich das Thema klingt sehr interessant. :)
                                        Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
                                        • Basti97B Basti97
                                          Beowolf
                                          #890
                                          @basti97 sagte in E-INK Display OpenEPaperLink - Displayanzeige mit Batterie:
                                          Alle Infos findest du hier:
                                          https://forum.iobroker.net/topic/66380/e-ink-display-openepaperlink-displayanzeige-mit-batterie?_=1738047117472
                                          Basti97B 1 Antwort Letzte Antwort
