  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Z-Wave Adapter über GPIO in Docker [gelöst]
    2.8k
    4.9k
    4.1k
16 Beiträge 4 Kommentatoren 1.5k Aufrufe 4 Beobachtet
  • Alexander GrebeA Alexander Grebe
    Hallo @arteck,
    vielen Dank für Deine Antwort. Hier die lang Version des Diag outpus:
    Script v.2024-10-19
    *** BASE SYSTEM ***
    cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
    Hardware Vendor :
    Kernel          : aarch64
    Userland        : 64 bit
    Docker          : v10.0.0
    Virtualization  : docker
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     20:10:36 up 1 day,  2:22,  0 user,  load average: 0.99, 0.56, 0.27
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
    *** TIME AND TIMEZONES ***
    Mon Jan 13 19:10:36 UTC 2025
    Mon Jan 13 20:10:36 CET 2025
    CET +0100
    Etc/UTC
    *** Users and Groups ***
    User that called 'iob diag':
    root
    HOME=/root
    GROUPS=root
    iobroker
    HOME=/opt/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            8.5G        4.6G        361M        594M        4.3G        3.9G
    Swap:           209M        3.1M        206M
    Total:          8.7G        4.6G        568M
    Active iob-Instances:   13
             8064 M total memory
             4365 M used memory
             4151 M active memory
             2699 M inactive memory
              343 M free memory
              537 M buffer memory
             3601 M swap cache
              199 M total swap
                3 M used swap
              196 M free swap
    top - 20:10:36 up 1 day,  2:22,  0 user,  load average: 0.99, 0.56, 0.27
    Tasks:  20 total,   2 running,  18 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8064.1 total,    342.9 free,   4366.1 used,   4138.1 buff/cache
    MiB Swap:    200.0 total,    197.0 free,      3.0 used.   3698.0 avail Mem
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem     Type     Size  Used Avail Use% Mounted on
    overlay        overlay  117G   50G   62G  45% /
    tmpfs          tmpfs     64M     0   64M   0% /dev
    shm            tmpfs     64M     0   64M   0% /dev/shm
    /dev/sda1      ext4     916G  244G  626G  29% /opt/iobroker
    /dev/mmcblk0p2 ext4     117G   50G   62G  45% /etc/hosts
    [Sun Jan 12 17:48:24 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:0C:B0:BC vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 root=PARTUUID=70620f12-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Sun Jan 12 17:48:24 2025] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
    [Sun Jan 12 17:48:26 2025] EXT4-fs (mmcblk0p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
    [Sun Jan 12 17:48:28 2025] EXT4-fs (sda1): mounted filesystem 15cc1906-deb3-4e08-8f9a-37a60069a399 r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE        FSTYPE OPTIONS
    /opt/iobroker    /dev/sda1[/iobroker]        ext4   rw,relatime
    /etc/resolv.conf /dev/mmcblk0p2[/var/lib/docker/containers/4fe2373fcf6172ff6353a82acf5e180813ceb6baa748f50e1c375fd6c2ebf5a2/resolv.conf] ext4   rw,noatime
    /etc/hostname    /dev/mmcblk0p2[/var/lib/docker/containers/4fe2373fcf6172ff6353a82acf5e180813ceb6baa748f50e1c375fd6c2ebf5a2/hostname]    ext4   rw,noatime
    /etc/hosts       /dev/mmcblk0p2[/var/lib/docker/containers/4fe2373fcf6172ff6353a82acf5e180813ceb6baa748f50e1c375fd6c2ebf5a2/hosts]       ext4   rw,noatime
    /var:
    35M     /var/
    33M     /var/lib
    19M     /var/lib/apt/lists
    19M     /var/lib/apt
    14M     /var/lib/dpkg
    /opt/iobroker/backups:
    19M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    933M    /opt/iobroker/iobroker-data/
    859M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    20M     /opt/iobroker/iobroker-data/objects.jsonl
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
    8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
    USB-Devices by-id:
    No Devices found 'by-id'
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspyDocker         raspyDocker (version: 7.0.6, hostname: raspyDocker   , alive, uptime: 94847)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.10
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspyDocker                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.backitup.0               : backitup              : raspyDocker                              -  enabled
    + system.adapter.denon.0                  : Denon AVR-X1400H      : raspyDocker                              -  enabled
    + system.adapter.discovery.0              : discovery             : raspyDocker                              -  enabled
      system.adapter.dwd.0                    : dwd                   : raspyDocker                              -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspyDocker                              -  enabled
    + system.adapter.harmony.0                : harmony               : raspyDocker                              -  enabled
    + system.adapter.jarvis.0                 : jarvis                : raspyDocker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.javascript.0             : javascript            : raspyDocker                              -  enabled
    + system.adapter.philips-air.0            : philips-air           : raspyDocker                              -  enabled
      system.adapter.ping.0                   : ping                  : raspyDocker                              - disabled
      system.adapter.tesla-motors.0           : tesla-motors          : raspyDocker                              - disabled
      system.adapter.tr-064.0                 : tr-064                : raspyDocker                              - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspyDocker                              - disabled
    + system.adapter.web.0                    : web                   : raspyDocker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : raspyDocker                              -  enabled, port: /dev/ttyACM0
    + system.adapter.zwave2.0                 : zwave2                : raspyDocker                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.4.10   , installed 7.4.10
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "philips-air"  : 1.1.0    , installed 1.1.0
    Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
    Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
    Objects and States
    Objects:        19048
    States:         5965
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 47
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          364133     -
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       16382      153/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       19459      153/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5939       -
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       19801      384/io.jarvis.0
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          9326       -
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          9325       -
    tcp        0      0 0.0.0.0:9443            0.0.0.0:*               LISTEN      0          10092      -
    tcp        0      0 0.0.0.0:2283            0.0.0.0:*               LISTEN      0          11216      -
    tcp        0      0 0.0.0.0:8010            0.0.0.0:*               LISTEN      0          11656      -
    tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      0          10077      -
    tcp6       0      0 :::61991                :::*                    LISTEN      1000       17343      297/io.harmony.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5941       -
    tcp6       0      0 :::139                  :::*                    LISTEN      0          9324       -
    tcp6       0      0 :::445                  :::*                    LISTEN      0          9323       -
    tcp6       0      0 :::9443                 :::*                    LISTEN      0          10098      -
    tcp6       0      0 :::2283                 :::*                    LISTEN      0          13347      -
    tcp6       0      0 :::8010                 :::*                    LISTEN      0          12513      -
    tcp6       0      0 :::8000                 :::*                    LISTEN      0          12510      -
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          364132     -
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       19088      369/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       19541      187/io.admin.0
    udp        0      0 172.21.255.255:137      0.0.0.0:*                           0          19163      -
    udp        0      0 172.21.0.1:137          0.0.0.0:*                           0          19162      -
    udp        0      0 172.19.255.255:137      0.0.0.0:*                           0          19159      -
    udp        0      0 172.19.0.1:137          0.0.0.0:*                           0          19158      -
    udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          19155      -
    udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          19154      -
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          9292       -
    udp        0      0 192.168.178.106:137     0.0.0.0:*                           0          9291       -
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          9276       -
    udp        0      0 172.21.255.255:138      0.0.0.0:*                           0          19165      -
    udp        0      0 172.21.0.1:138          0.0.0.0:*                           0          19164      -
    udp        0      0 172.19.255.255:138      0.0.0.0:*                           0          19161      -
    udp        0      0 172.19.0.1:138          0.0.0.0:*                           0          19160      -
    udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          19157      -
    udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          19156      -
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          9294       -
    udp        0      0 192.168.178.106:138     0.0.0.0:*                           0          9293       -
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          9277       -
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       17344      297/io.harmony.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6791       -
    udp        0      0 0.0.0.0:46863           0.0.0.0:*                           104        6793       -
    udp        0      0 0.0.0.0:43655           0.0.0.0:*                           1000       1440003    80831/io.philips-ai
    udp6       0      0 fe80::f2f3:2da6:af2:546 :::*                                0          7107       -
    udp6       0      0 :::5353                 :::*                                104        6792       -
    udp6       0      0 :::55922                :::*                                104        6794       -
    2025-01-13 20:10:35.512  - info: zwave2.0 (82051) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.zwave2, node: v20.18.1, js-controller: 7.0.6
    2025-01-13 20:10:41.249  - error: zwave2.0 (82051) Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200)
        at Driver.sendMessage (/opt/iobroker/node_modules/zwave-js/src/lib/driver/Driver.ts:4360:23)
        at ZWaveController.identify (/opt/iobroker/node_modules/zwave-js/src/lib/controller/Controller.ts:915:33)
        at Driver.initializeControllerAndNodes (/opt/iobroker/node_modules/zwave-js/src/lib/driver/Driver.ts:1365:26)
        at Immediate.<anonymous> (/opt/iobroker/node_modules/zwave-js/src/lib/driver/Driver.ts:1171:16) (ZW0100)
    2025-01-13 20:10:41.249  - error: zwave2.0 (82051) Restarting the adapter in a second...
    2025-01-13 20:10:42.251  - info: zwave2.0 (82051) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2025-01-13 20:10:42.760  - info: zwave2.0 (82051) Shutting down driver...
    2025-01-13 20:10:42.796  - info: host.raspyDocker instance system.adapter.zwave2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2025-01-13 20:10:42.797  - info: host.raspyDocker Restart adapter system.adapter.zwave2.0 because enabled
    2025-01-13 20:10:44.019  - info: host.raspyDocker instance system.adapter.zwave2.0 in version "3.1.0" started with pid 82331
    2025-01-13 20:10:45.514  - info: zwave2.0 (82331) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.zwave2, node: v20.18.1, js-controller: 7.0.6
    2025-01-13 20:10:51.245  - error: zwave2.0 (82331) Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200)
    2025-01-13 20:10:51.245  - error: zwave2.0 (82331) Restarting the adapter in a second...
    2025-01-13 20:10:52.247  - info: zwave2.0 (82331) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2025-01-13 20:10:52.756  - info: zwave2.0 (82331) Shutting down driver...
    2025-01-13 20:10:52.805  - info: host.raspyDocker instance system.adapter.zwave2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2025-01-13 20:10:52.806  - info: host.raspyDocker Restart adapter system.adapter.zwave2.0 because enabled
    2025-01-13 20:10:54.026  - info: host.raspyDocker instance system.adapter.zwave2.0 in version "3.1.0" started with pid 82444
    2025-01-13 20:10:55.641  - info: zwave2.0 (82444) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.zwave2, node: v20.18.1, js-controller: 7.0.6
    BTW, in den hier angegebenen Ordnern sind weder LOG noch CACHE Dateien zu finden.
    Kannst Du daraus etwas erkennen?
    arteckA Offline
    arteckA Offline
    arteck
    @alexander-grebe sagte in Z-Wave Adapter über GPIO in Docker:
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
    HINT:
    /dev/ttyACM0
    das bitte korrigieren ...
    die ports sind falsch wie es aussieht.. link die mal über by-id
    Alexander GrebeA 1 Antwort Letzte Antwort
    • arteckA arteck
      USB-Devices by-id:
      HINT:
      /dev/ttyACM0
      Alexander GrebeA Offline
      Alexander Grebe
      schrieb am zuletzt editiert von Alexander Grebe
      Hallo @arteck,
      vielen Dank! Das habe ich auch im log gesehen, dem aber bisher wenig Beachtung geschenkt, da das USB Zigbee device ja (mittlerweile) wunderbar läuft. Das Problem ist der Z-Wave Adapter (ZMEERAZ2), der als Aufsteckmodul auf dem gpio steckt.
      /dev/ttyACM0 ist ziemlich sicher der Zigbee Conbee am USB und /dev/ttyS0 das Z-Wave Aufsteckmodul.
      Ich werde das in den nächsten Tagen trotzdem umstellen (muss aber erstmal googeln, wie ich das auf "by-id" umstelle ;-) ).
        Hallo @arteck,
        Alexander Grebe
        Hallo @arteck,
        Hallo @arteck,
        ich muss gestehen, dass ich keine wirklich gute Info gefunden habe, wie ich unter Docker auf "by-id" umstellen kann. Mein Versuch das einfach genau wie mit /dev/ttyACM0 zu machen, hat leider nicht geklappt und der Container startet nicht mehr mit folgender Fehlermeldung:
        -------------------------     2025-01-15 20:25:06      -------------------------
        -----              Welcome to your ioBroker Docker container!              -----
        -----                    Startupscript is now running!                     -----
        -----                          Please be patient!                          -----
        -----                          System Information                          -----
        -----                    arch:                aarch64                      -----
        -----                    hostname:            raspyDocker                  -----
        -----                          Version Information                         -----
        -----                    image:               v10.0.0                      -----
        -----                    build:               20250114.234327              -----
        -----                    node:                v20.18.1                     -----
        -----                    npm:                 10.8.2                       -----
        -----                        Environment Variables                         -----
        -----                    PACKAGES:            nano                         -----
        -----                    SETGID:              993                          -----
        -----                    SETUID:              1000                         -----
        -----                    USBDEVICES:          /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2452326-if00 -----
        -----                   Step 1 of 5: Preparing Container                   -----
        PACKAGES is set. Installing the following additional Linux packages: nano
        nano is already installed.
        SETUID and/ or SETGID are set to custom values.
        Changing UID to "1000" and GID to "993"... usermod: no changes
        Done.
        -----             Step 2 of 5: Detecting ioBroker Installation             -----
        Existing installation of ioBroker detected in "/opt/iobroker".
        -----             Step 3 of 5: Checking ioBroker Installation              -----
        (Re)setting permissions (This might take a while! Please be patient!)... Done.
        Checking database connection... Done.
        Hostname in ioBroker matches the hostname of this container.
        No action required.
        -----                Step 4 of 5: Applying Special Settings                -----
        Some adapters have special requirements/ settings which can be activated by the use of environment variables.
        For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs/).
        USBDEVICES is set.
        Looks like the device "/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2452326-if00" does not exist.
        Did you mount it correctly by using the "--device" option?
        For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs/#mounting-usb-devices).
        This Script will exit now.
        Ich habe folgendes gemacht:
        alex@raspyDocker:/dev/serial/by-id $ ls -la
        total 0
        drwxr-xr-x 2 root root 60 Jan 15 20:20 .
        drwxr-xr-x 4 root root 80 Jan 15 20:20 ..
        lrwxrwxrwx 1 root root 13 Jan 15 20:20 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2452326-if00 -> ../../ttyACM0
        Der Z-Wave Adapter taucht da nicht auf.
        Hat jemand noch einen Hinweis, wie ich auf "by-id" im Docker umstellen kann?
          Hallo @arteck,
          Hallo @arteck,
          Done.
          No action required.
          USBDEVICES is set.
          total 0
          Marc BergM Offline
          Marc BergM Offline
          Marc Berg
          Das ist grundsätzlich richtig so und läuft bei mir auch mit einem Conbee2. Kann mir nur vorstellen, dass ein Schreibfehler oder Leerzeichen zu viel drin ist. Das kann man aus den Screenshots nicht erkennen, da das Ende abgeschnitten wurde.
          EDIT: zeige mal auf dem Host das Ergebnis von
          docker inspect <CONTAINERNAME> --format='{{json .HostConfig.Devices}}'
          • Marc BergM Marc Berg
            Alexander Grebe
            Hallo @marc-berg,
            ich habe nochmal alles auf zusätzliche Blanks und auf Schreibfehler geprüft, aber nichts gefunden.
            alex@raspyDocker:/dev/serial/by-id $ sudo docker inspect iobroker --format='{{json  .HostConfig.Devices}}'
            [{"PathOnHost":"/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2452326-if00","PathInContainer":"/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2452326-if00","CgroupPermissions":"rwm"}]
            Kannst Du damit etwas erkennen?
              Hallo @marc-berg,
              Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              Nein, keine Idee. Das sollte aus meiner Sicht so funktionieren. Den Conbee Stick mappe ich in den Container zwar mit einem kurzen Pfad, um nicht das lange Monster zu haben. Das sollte aber keinen Unterschied machen.
              "Devices": [
                      "PathOnHost": "/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2664821-if00",
                      "PathInContainer": "/dev/ttyACM0",
                      "CgroupPermissions": "rwm"
              Einen Signalduino mappe ich so, mit vollem Pfad auch im Container:
              "Devices": [
                      "PathOnHost": "/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0",
                      "PathInContainer": "/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0",
              und einen Warema Stick so:
              "Devices": [
                      "PathOnHost": "/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AV0K3AQZ-if00-port0",
                      "PathInContainer": "/dev/ttyUSB0",
              Geht alles seit Jahren problemlos. :man-shrugging:
                "Devices": [
                "Devices": [
                "Devices": [
                Alexander Grebe
                Hallo @marc-berg,
                Dein Kommentar " Den Conbee Stick mappe ich in den Container zwar mit einem kurzen Pfad, um nicht das lange Monster zu haben. Das sollte aber keinen Unterschied machen." hat mich stutzig gemacht und ich habe doch mal den Namen bei mir gekürzt. Im Container mappe ich jetzt auf /dev/serial/by-id/ConBee2. Und siehe da: plötzlich klappt es ;-). Scheinbar mach der Monster-Name doch einen Unterschied... Vielen Dank!!!
                Damit ist dann auch die Warning im iob diag log weg: "Your zigbee.0 COM-Port is matching 'by-id'. Very good!"
                ```bash
                Script v.2024-10-19
                *** BASE SYSTEM ***
                Hardware Vendor :
                Kernel          : aarch64
                Userland        : 64 bit
                Docker          : v10.0.0
                Kernel          : aarch64
                Userland        : 64 bit
                 19:31:48 up  1:23,  0 user,  load average: 0.15, 0.47, 0.69
                CPU threads: 4
                Fri Jan 17 18:31:48 UTC 2025
                Fri Jan 17 19:31:48 CET 2025
                CET +0100
                Etc/UTC
                root
                HOME=/root
                GROUPS=root
                iobroker
                HOME=/opt/iobroker
                Desktop:
                Terminal:
                *** MEMORY ***
                Mem:            8.5G        3.5G        413M        109M        4.8G        5.0G
                Swap:           209M          0B        209M
                Total:          8.7G        3.5G        623M
                Active iob-Instances:   12
                         8064 M total memory
                         3312 M used memory
                         4163 M active memory
                         2643 M inactive memory
                          393 M free memory
                          567 M buffer memory
                         4047 M swap cache
                          199 M total swap
                            0 M used swap
                          199 M free swap
                top - 19:31:48 up  1:23,  0 user,  load average: 0.15, 0.47, 0.69
                Tasks:  19 total,   1 running,  18 sleeping,   0 stopped,   0 zombie
                MiB Mem :   8064.1 total,    391.3 free,   3314.2 used,   4615.0 buff/cache
                MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4750.0 avail Mem
                *** FILESYSTEM ***
                overlay        overlay  117G   52G   60G  47% /
                /dev/mmcblk0p2 ext4     117G   52G   60G  47% /etc/hosts
                [Fri Jan 17 18:07:56 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:0C:B0:BC vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 root=PARTUUID=70620f12-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                [Fri Jan 17 18:07:56 2025] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
                [Fri Jan 17 18:07:58 2025] EXT4-fs (mmcblk0p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
                [Fri Jan 17 18:08:00 2025] EXT4-fs (sda1): mounted filesystem 15cc1906-deb3-4e08-8f9a-37a60069a399 r/w with ordered data mode. Quota mode: none.
                /etc/resolv.conf /dev/mmcblk0p2[/var/lib/docker/containers/e3753f09abe321ec2ef9218ea361cde0bcaa5e5534afba5bc741be51583e915e/resolv.conf] ext4   rw,noatime
                /etc/hostname    /dev/mmcblk0p2[/var/lib/docker/containers/e3753f09abe321ec2ef9218ea361cde0bcaa5e5534afba5bc741be51583e915e/hostname]    ext4   rw,noatime
                /etc/hosts       /dev/mmcblk0p2[/var/lib/docker/containers/e3753f09abe321ec2ef9218ea361cde0bcaa5e5534afba5bc741be51583e915e/hosts]       ext4   rw,noatime
                /var:
                16M     /var/
                14M     /var/lib/dpkg
                14M     /var/lib
                13M     /var/lib/dpkg/info
                1.9M    /var/cache
                939M    /opt/iobroker/iobroker-data/
                27M     /opt/iobroker/iobroker-data/objects.jsonl
                USB-Devices by-id:
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                raspyDocker         raspyDocker (version: 7.0.6, hostname: raspyDocker   , alive, uptime: 4322)
                admin:          7.4.10
                javascript:     8.8.3
                Adapter State
                  system.adapter.philips-air.0            : philips-air           : raspyDocker                              - disabled
                + system.adapter.zigbee.0                 : zigbee                : raspyDocker                              -  enabled, port: /dev/serial/by-id/ConBee2
                + instance is alive
                Objects and States
                Objects:        19039
                States:         5947
                Pending Updates: 0
                tcp        0      0 0.0.0.0:8010            0.0.0.0:*               LISTEN      0          14840      -
                tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      0          12631      -
                tcp        0      0 0.0.0.0:2283            0.0.0.0:*               LISTEN      0          11774      -
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          5920       -
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       43027      340/iobroker.js-con
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       43022      340/iobroker.js-con
                tcp        0      0 0.0.0.0:9443            0.0.0.0:*               LISTEN      0          11712      -
                tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          10354      -
                tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       43326      574/io.jarvis.0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9266       -
                tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          10353      -
                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       41393      362/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       42401      559/io.web.0
                tcp6       0      0 :::8010                 :::*                    LISTEN      0          12815      -
                tcp6       0      0 :::8000                 :::*                    LISTEN      0          13561      -
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          5919       -
                tcp6       0      0 :::2283                 :::*                    LISTEN      0          11779      -
                tcp6       0      0 :::9443                 :::*                    LISTEN      0          14657      -
                tcp6       0      0 :::61991                :::*                    LISTEN      1000       40507      472/io.harmony.0
                tcp6       0      0 :::139                  :::*                    LISTEN      0          10352      -
                tcp6       0      0 :::22                   :::*                    LISTEN      0          9268       -
                tcp6       0      0 :::445                  :::*                    LISTEN      0          10351      -
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7264       -
                udp        0      0 0.0.0.0:49236           0.0.0.0:*                           104        7266       -
                udp        0      0 172.21.255.255:137      0.0.0.0:*                           0          19995      -
                udp        0      0 172.21.0.1:137          0.0.0.0:*                           0          19994      -
                udp        0      0 172.19.255.255:137      0.0.0.0:*                           0          19991      -
                udp        0      0 172.19.0.1:137          0.0.0.0:*                           0          19990      -
                udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          19987      -
                udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          19986      -
                udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          10294      -
                udp        0      0 192.168.178.106:137     0.0.0.0:*                           0          10293      -
                udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          10278      -
                udp        0      0 172.21.255.255:138      0.0.0.0:*                           0          19997      -
                udp        0      0 172.21.0.1:138          0.0.0.0:*                           0          19996      -
                udp        0      0 172.19.255.255:138      0.0.0.0:*                           0          19993      -
                udp        0      0 172.19.0.1:138          0.0.0.0:*                           0          19992      -
                udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          19989      -
                udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          19988      -
                udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          10296      -
                udp        0      0 192.168.178.106:138     0.0.0.0:*                           0          10295      -
                udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          10279      -
                udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       40508      472/io.harmony.0
                udp6       0      0 :::5353                 :::*                                104        7265       -
                udp6       0      0 :::34720                :::*                                104        7267       -
                udp6       0      0 fe80::f2f3:2da6:af2:546 :::*                                0          6130       -
                2025-01-17 19:31:54.256  - info: zwave2.0 (10948) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.zwave2, node: v20.18.1, js-controller: 7.0.6
                2025-01-17 19:31:59.968  - error: zwave2.0 (10948) Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200)
                2025-01-17 19:31:59.968  - error: zwave2.0 (10948) Restarting the adapter in a second...
                2025-01-17 19:32:00.969  - info: zwave2.0 (10948) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2025-01-17 19:32:01.474  - info: zwave2.0 (10948) Shutting down driver...
                2025-01-17 19:32:01.511  - info: host.raspyDocker instance system.adapter.zwave2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2025-01-17 19:32:01.511  - info: host.raspyDocker Restart adapter system.adapter.zwave2.0 because enabled
                2025-01-17 19:32:02.735  - info: host.raspyDocker instance system.adapter.zwave2.0 in version "3.1.0" started with pid 11073
                2025-01-17 19:32:04.167  - info: zwave2.0 (11073) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.zwave2, node: v20.18.1, js-controller: 7.0.6
                2025-01-17 19:32:10.014  - error: zwave2.0 (11073) Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200)
                2025-01-17 19:32:10.015  - error: zwave2.0 (11073) Restarting the adapter in a second...
                2025-01-17 19:32:11.016  - info: zwave2.0 (11073) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2025-01-17 19:32:11.523  - info: zwave2.0 (11073) Shutting down driver...
                2025-01-17 19:32:11.560  - info: host.raspyDocker instance system.adapter.zwave2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2025-01-17 19:32:11.560  - info: host.raspyDocker Restart adapter system.adapter.zwave2.0 because enabled
                2025-01-17 19:32:12.817  - info: host.raspyDocker instance system.adapter.zwave2.0 in version "3.1.0" started with pid 11411
                2025-01-17 19:32:14.464  - info: zwave2.0 (11411) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.zwave2, node: v20.18.1, js-controller: 7.0.6
                Leider ändert das aber nichts an meinem Ursprungs-Problem: Der Zigbee Stick ging ja die ganze Zeit. Das Problem ist und bleibt das Z-Wave Modul auf dem GPIO port.
                Fangen wir nochmal vorne an... Das ist ein Bild von meinem Aufbau (USB-C und Netzwerkkabel habe ich für das Bild abgesteckt. Die Z-Wave Karte habe ich mit einer Verlängerung etwas hoch gesetzt, damit die nicht direkt auf dem CPU Lüfter liegt. Ist noch etwas provisorisch, ich möchte das aber ersteinmal zum Laufen bringen):
                Wenn ich den Raspi mit dem Strom verbinde, leuchtet die LED auf dem Z-Wave Modul kurz auf. Also Strom bekommt das Z-Wave Modul scheinbar ;-).
                Kennt jemand einen Weg auf dem Host System zu prüfen, ob der Z-Wave Adapter sich grundsätzlich ansprechen lässt?
                  Hallo @marc-berg,
                  ```bash
                  Script v.2024-10-19
                  *** BASE SYSTEM ***
                  Hardware Vendor :
                  Kernel          : aarch64
                  Userland        : 64 bit
                  Docker          : v10.0.0
                  Kernel          : aarch64
                  Userland        : 64 bit
                  CPU threads: 4
                  CET +0100
                  Etc/UTC
                  root
                  HOME=/root
                  GROUPS=root
                  iobroker
                  HOME=/opt/iobroker
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Swap:           209M          0B        209M
                           8064 M total memory
                           3312 M used memory
                            393 M free memory
                            567 M buffer memory
                           4047 M swap cache
                            199 M total swap
                              0 M used swap
                            199 M free swap
                  *** FILESYSTEM ***
                  /var:
                  16M     /var/
                  14M     /var/lib/dpkg
                  14M     /var/lib
                  1.9M    /var/cache
                  USB-Devices by-id:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  admin:          7.4.10
                  javascript:     8.8.3
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        19039
                  States:         5947
                  Pending Updates: 0
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  @PackElend hast du eine Idee?
                  Alexander GrebeA PackElendP 2 Antworten Letzte Antwort
                    Alexander Grebe
                    Hallo allerseits,
                    ich habe heute noch einen großen Schritt vorwärts gemacht. Details schreibe ich morgen zusammen, falls irgendwann jemand in ein ähnliches Problem läuft: In short: Das Device war eben doch nicht /dev/ttyS0 (wie auf meinem alten Raspi), sondern /dev/ttyAMA0.
                      PackElendP Offline
                      PackElendP Offline
                      PackElend
                      @marc-berg said in Z-Wave Adapter über GPIO in Docker:
                      muss passen, hatte ewig gesucht aber nichts brauchbares gefunden, das mir einfach mal sagt, ob, und evtl. welche Hardware an einen GPIO sitzt.
                      Daher bin ich zuerst mit Z-Way Server unterwegs gewesen, da er ein wenig mehr erzählt aber da z-wave.me keine brauchbaren Docker berreitstellt, habe ich sein gelasen.
                      https://github.com/Z-Wave-Me/docker-z-way/issues
                      • PackElendP PackElend
                        Alexander Grebe
                        Vielen Dank nochmals, @packelend, @Marc-Berg , @arteck . Mit Eurer Hilfe habe ich das Problem zwischenzeitlich lösen können. War eigentlich nur eine Kleinigkeit: Beim Raspberry5 ist der serielle Port, auf dem das Z-Wave Modul sitzt, /dev/ttyAMA0. (Bei meinem alten, mittlerweile defekten Raspi 3 war das ziemlich sicher /dev/ttyS0.
                        Für alle, die vielleicht später ein ähnliches Problem haben:
                        1. Sicherstellen, dass das Serielle Interface auch eingeschaltet ist: sudo raspi-config
                        2. In Portrainer /dev/ttyAMA0 als Gerät in den iobroker einbinden, sieht bei mir dann so aus:
                        3. Das Gerät in der Umgebungsvariable USBDEVICES ergänzen. (Ich bin mir nicht sicher, ob das wirklich nötig ist, aber geschadet hat es jedenfalls nicht):
                        4. In den Instanzeinstellungen des zwave2.0 Adapters /dev/ttyAMA0 als Schnittstelle auswählen:
                        (BTW, by-id scheint bei deinem Serillem Gerät nicht zu existieren...)
                        PackElendP 1 Antwort Letzte Antwort
                          PackElendP Offline
                          PackElendP Offline
                          PackElend
                          @alexander-grebe
                          ich habe des Container über Kommandozeile gestartet: https://forum.iobroker.net/topic/78964/gelöst-docker-ohne-compose-mit-usb-passthrough/7
                            @alexander-grebe
                            Alexander Grebe
                            Deleted post
