  4. Alias Umwandlung bei JSON mit "null" bereitet Probleme
    5.1k
javascriptblockly
19 Beiträge 5 Kommentatoren 2.1k Aufrufe 3 Beobachtet
  • H Heinz53
    Hallo allerseits,
    mein ioBroker lief stabil in einem Container auf meiner synology.
    Seit einigen Tagen habe ich nach der Umstellung von zigbee auf zigbee2mqtt Probleme:
    Beim starten des Containers erscheint folgende Fehlermeldung:
    ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
    This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    TypeError: Cannot read properties of undefined (reading 'toString')
    at applyAliasConvenienceConversion (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/aliasProcessing.ts:78:30)
    at Object.formatAliasValue (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2753:17)
    at AdapterClass._processStatesSecondary (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9376:31)
    at processTicksAndRejections (node:internal/process/task_queues:95:5)
    at AdapterClass._getForeignStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9526:29)
    Beim Aufruf der Instanz mit einem alias Datenpunkt friert das System ein, und erstellt folgende Fehlermeldungen:
    host.iobroker
    2025-01-02 18:13:58.435	error	instance system.adapter.admin.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker
    2025-01-02 18:13:58.434	error	Caught by controller[1]: at Admin._getForeignStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9526:29)
    host.iobroker
    2025-01-02 18:13:58.434	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.iobroker
    2025-01-02 18:13:58.434	error	Caught by controller[1]: at Admin._processStatesSecondary (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9376:31)
    host.iobroker
    2025-01-02 18:13:58.434	error	Caught by controller[1]: at Object.formatAliasValue (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2753:17)
    host.iobroker
    2025-01-02 18:13:58.434	error	Caught by controller[1]: at applyAliasConvenienceConversion (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/aliasProcessing.ts:78:30)
    host.iobroker
    2025-01-02 18:13:58.434	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'toString')
    host.iobroker
    2025-01-02 18:13:58.433	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    admin.0
    2025-01-02 18:13:57.822	error	Cannot read properties of undefined (reading 'toString')
    admin.0
    2025-01-02 18:13:57.821	error	TypeError: Cannot read properties of undefined (reading 'toString') at applyAliasConvenienceConversion (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/aliasProcessing.ts:78:30) at Object.formatAliasValue (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2753:17) at Admin._processStatesSecondary (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9376:31) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Admin._getForeignStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9526:29)
    admin.0
    2025-01-02 18:13:57.672	error	unhandled promise rejection: Cannot read properties of undefined (reading 'toString')
    admin.0
    2025-01-02 18:13:57.672	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Die Datenpunkte sind folgendermaßen definiert:
    alias.0.Button.Cube1.action - mit Typ mixed
      "common": {
        "name": "action",
        "desc": "Manuell erzeugt",
        "role": "state",
        "type": "mixed",
        "read": true,
        "write": true,
        "def": "",
        "alias": {
          "id": "mqtt.0.zigbee2mqtt.Cube1",
          "read": "JSON.parse(val).action"
      "type": "state",
      "native": {},
      "_id": "alias.0.Button.Cube1.action",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
      "user": "system.user.admin",
      "ts": 1735832197825
    alias.0.Button.Cube1.alias.0.Button.Cube1.action_from_side - mit Typ String
      "common": {
        "name": "action_from_side",
        "role": "state",
        "type": "string",
        "read": true,
        "write": true,
        "def": "",
        "alias": {
          "read": "JSON.parse(val).action_from_side"
      "type": "state",
      "native": {},
      "_id": "alias.0.Button.Cube1.action_from_side",
      "acl": {
        "object": 1636,
        "state": 1636,
      "ts": 1735834100918
    Meine Systemeinstellungen habe ich mit iobroker diag hier eingefügt:
    The ioBroker diag script is not specifically designed to run in Docker.
    Although it is generally safe to use, use it at your own risk.
    *** iob diag is starting up, please wait ***
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    Press any key to continue
    Script v.2024-10-19
    *** BASE SYSTEM ***
    Hardware Vendor : Synology
    Kernel          : x86_64
    Userland        : 64 bit
    Docker          : v10.0.0
    Virtualization  : docker
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     17:47:39 up 15 days, 21:39,  0 user,  load average: 0.45, 0.39, 0.44
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
    Thu Jan  2 16:47:39 UTC 2025
    Thu Jan  2 17:47:39 CET 2025
    CET +0100
    Etc/UTC
    *** Users and Groups ***
    User that called 'iob diag':
    root
    HOME=/root
    GROUPS=root
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             20G        5.0G        2.3G        336M         14G         15G
    Swap:            14G        1.4G         13G
    Total:           35G        6.4G         15G
    Active iob-Instances: 	1
            19852 M total memory
             4771 M used memory
             8293 M active memory
             7281 M inactive memory
             2151 M free memory
             1065 M buffer memory
            12608 M swap cache
            13959 M total swap
             1297 M used swap
            12662 M free swap
    top - 17:47:39 up 15 days, 21:39,  0 user,  load average: 0.45, 0.39, 0.44
    Tasks:   8 total,   1 running,   7 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  19852.1 total,   2150.2 free,   4772.8 used,  13673.8 buff/cache
    MiB Swap:  13959.9 total,  12662.6 free,   1297.3 used.  15079.3 avail Mem
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem             Type   Size  Used Avail Use% Mounted on
    /dev/mapper/cachedev_0 btrfs   14T  7.4T  6.7T  53% /
    tmpfs                  tmpfs   64M     0   64M   0% /dev
    tmpfs                  tmpfs  9.7G     0  9.7G   0% /sys/fs/cgroup
    shm                    tmpfs   64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev_0 btrfs   14T  7.4T  6.7T  53% /opt/iobroker
    /dev/mapper/cachedev_0 btrfs   14T  7.4T  6.7T  53% /etc/hosts
    tmpfs                  tmpfs  9.7G     0  9.7G   0% /proc/acpi
    tmpfs                  tmpfs  9.7G     0  9.7G   0% /proc/scsi
    tmpfs                  tmpfs  9.7G     0  9.7G   0% /sys/firmware
    Show mounted filesystems:
    TARGET             SOURCE        FSTYPE OPTIONS
    /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/192331e0bdd039fa603c9a2d9aa939e3abd9c6d9cb2905154c13a7371af3a5bb]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=6521,subvol=/@syno/@docker/btrfs/subvolumes/192331e0bdd039fa603c9a2d9aa939e3abd9c6d9cb2905154c13a7371af3a5bb
    |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/iobroker245]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=786,subvol=/@syno/docker
    |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/e01a8487ad4b8b2f86e8c2510e9eb4a8ee872205cc6b01bf942823a07b8d393e/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
    |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/e01a8487ad4b8b2f86e8c2510e9eb4a8ee872205cc6b01bf942823a07b8d393e/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
    `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/e01a8487ad4b8b2f86e8c2510e9eb4a8ee872205cc6b01bf942823a07b8d393e/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
    /var:
    35M	/var/
    33M	/var/lib
    19M	/var/lib/apt/lists
    19M	/var/lib/apt
    13M	/var/lib/dpkg/info
    /opt/iobroker/backups:
    840M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.9G	/opt/iobroker/iobroker-data/
    1.3G	/opt/iobroker/iobroker-data/files
    616M	/opt/iobroker/iobroker-data/files/javascript.admin
    560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    32M	/opt/iobroker/iobroker-data/objects.jsonl
    27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.18.1
    /usr/bin/node 		v20.18.1
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 3017)
    Core adapters versions
    js-controller: 	7.0.3
    admin: 		7.1.5
    javascript: 	8.8.3
    nodejs modules from github: 	1
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled, compact disabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled, compact disabled
      system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
      system.adapter.broadlink2.0             : broadlink2            : iobroker                                 - disabled
      system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled, compact disabled
      system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled, compact disabled
      system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled, compact disabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled, compact disabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled, compact disabled
      system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled, compact disabled
      system.adapter.eventlist.0              : eventlist             : iobroker                                 -  enabled, compact disabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled, compact disabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled, compact disabled
      system.adapter.hm-rega.1                : hm-rega               : iobroker                                 -  enabled, compact disabled
      system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, compact disabled, port: 0
      system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, compact disabled, port: 0
      system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, compact disabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
      system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, compact disabled, port: 8086
      system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
      system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
      system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 - disabled, compact disabled
      system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled, compact disabled
      system.adapter.scenes.0                 : scenes                : iobroker                                 - disabled, compact disabled
      system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
      system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, compact disabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
      system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled, compact disabled
      system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled, compact disabled
      system.adapter.synology.0               : synology              : iobroker                                 - disabled, compact disabled, port: 5000
      system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled, compact disabled
      system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled, compact disabled
      system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled, compact disabled
      system.adapter.trashschedule.0          : trashschedule         : iobroker                                 - disabled, compact disabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
      system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled, compact disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled, compact disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled, compact disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled, compact disabled
      system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled, compact disabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Instances
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.3  [Updatable]
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects: 	14941
    States: 	12189
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.11:36365        0.0.0.0:*               LISTEN      0          361034420  -
    udp        0      0 127.0.0.11:43162        0.0.0.0:*                           0          361034419  -
    2025-01-02 17:31:01.056  - warn: host.iobroker instance system.adapter.sayit.0 terminated due to SIGKILL
    2025-01-02 17:31:01.056  - info: host.iobroker instance system.adapter.sayit.0 terminated with code null ()
    2025-01-02 17:31:01.056  - info: host.iobroker instance system.adapter.vis-inventwo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-01-02 17:31:01.449  - warn: host.iobroker instance system.adapter.telegram.0 terminated due to SIGKILL
    2025-01-02 17:31:01.449  - info: host.iobroker instance system.adapter.telegram.0 terminated with code null ()
    2025-01-02 17:31:01.449  - warn: host.iobroker instance system.adapter.hm-rega.1 terminated due to SIGKILL
    2025-01-02 17:31:01.449  - info: host.iobroker instance system.adapter.hm-rega.1 terminated with code null ()
    2025-01-02 17:31:01.483  - warn: host.iobroker instance system.adapter.sonoff.0 terminated due to SIGKILL
    2025-01-02 17:31:01.484  - info: host.iobroker instance system.adapter.sonoff.0 terminated with code null ()
    2025-01-02 17:31:01.484  - warn: host.iobroker instance system.adapter.echarts.0 terminated due to SIGKILL
    2025-01-02 17:31:01.484  - info: host.iobroker instance system.adapter.echarts.0 terminated with code null ()
    2025-01-02 17:31:01.484  - warn: host.iobroker instance system.adapter.fullybrowser.0 terminated due to SIGKILL
    2025-01-02 17:31:01.485  - info: host.iobroker instance system.adapter.fullybrowser.0 terminated with code null ()
    2025-01-02 17:31:01.529  - info: host.iobroker instance system.adapter.socketio.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-01-02 17:31:01.530  - info: host.iobroker All instances are stopped.
    2025-01-02 17:31:01.530  - warn: host.iobroker instance system.adapter.statistics.0 terminated due to SIGKILL
    2025-01-02 17:31:01.530  - info: host.iobroker instance system.adapter.statistics.0 terminated with code null ()
    2025-01-02 17:31:01.530  - warn: host.iobroker instance system.adapter.text2command.0 terminated due to SIGKILL
    2025-01-02 17:31:01.530  - info: host.iobroker instance system.adapter.text2command.0 terminated with code null ()
    2025-01-02 17:31:01.542  - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGKILL
    2025-01-02 17:31:01.542  - info: host.iobroker instance system.adapter.web.0 terminated with code null ()
    2025-01-02 17:31:01.543  - info: host.iobroker All instances are stopped.
    2025-01-02 17:31:01.703  - info: host.iobroker terminated
    iob diag has finished.
    Press any key for a summary
    Copy text starting here:
    			v.2024-10-19
    model name	: Intel(R) Celeron(R) J4125 CPU @ 2.00GHz
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v10.0.0
    Installation: 		Docker
    Kernel: 		x86_64
    Userland: 		64 bit
    Timezone: 		CET +0100
    User-ID: 		0
    Pending OS-Updates: 	0
    Pending iob updates: 	1
    Nodejs-Installation:
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    Recommended versions are nodejs 20.18.1 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:             20G        5.0G        2.3G        337M         14G         15G
    Swap:            14G        1.4G         13G
    Total:           35G        6.4G         15G
    ioBroker Core: 		js-controller 		7.0.3
    			admin 			7.1.5
    ioBroker Status: 	iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		14941
    States: 		12189
    Size of iob-Database:
    6.1M	/opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    Wie muss die Umwandlung gesetzt werden damit undefinierte Werte nicht zu den Problemen führen?
    Die Änderungen von Datenpunkten werden ebenfalls nicht mehr im Javascript oder Blockly erkannt. Hängt das mit den alias Problemen zusammen? Was kann ich für die weitere Fehleranalyse / -behebung unternehmen?
    Ich hoffe auf eure Unterstützung.
    Heinz
    @heinz53 sagte: Was kann ich für die weitere Fehleranalyse / -behebung unternehmen?
          "read":  "val ? JSON.parse(val).action : 'no Action'"
    • H Offline
      Heinz53
      @paul53 : DANKE! Das ist die Lösung!
      Es war für mich unverständlich dass falsche Werte im alias das ganze System aus dem Tritt bringen.
      Vielleicht hast du noch einen Tipp für mich: Die Steckdosen melden über zigbee2mqtt als string "on" oder off.
      Ich versuche sie als boolean umzuwandeln und erhalte folgende Meldung
      Object alias.0.Steckdose.Strom28.POWER is invalid: Default value has to be type "boolean" but received type "string" This will throw an error up from js-controller version 7.0.0!
        "common": {
          "name": "POWER",
          "role": "state",
          "type": "boolean",
          "read": true,
          "write": true,
          "def": "",
          "alias": {
            "id": {
              "read": "mqtt.0.zigbee2mqtt.Strom28",
              "write": "mqtt.0.zigbee2mqtt.Strom28.set"
            "read": "val == 'on' ? true : val == 'off' ? false : null"
        "type": "state",
        "native": {},
        "_id": "alias.0.Steckdose.Strom28.POWER",
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1735929801444
      Ist die Umsetzung nicht mehr möglich?
      Vielen Dank für deine Unterstützung
      Heinz
      FredFF paul53P 2 Antworten Letzte Antwort
      • H Heinz53
          "common": {
            "name": "POWER",
            "role": "state",
            "type": "boolean",
            "read": true,
            "write": true,
            "def": "",
            "alias": {
              "id": {
          "type": "state",
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636,
          "ts": 1735929801444
        Heinz
        FredFF Online
        FredFF Online
        FredF
        Most Active Forum Testing
        @heinz53
        Ich antworte mal:
        "read": "val == 'on' ? true : false"
        • H Heinz53
            "common": {
              "name": "POWER",
              "role": "state",
              "type": "boolean",
              "read": true,
              "write": true,
              "def": "",
              "alias": {
                "id": {
            "type": "state",
            "native": {},
            "acl": {
              "object": 1636,
              "state": 1636,
            "ts": 1735929801444
          Heinz
          @heinz53 sagte: folgende Meldung
          Wenn auch geschrieben werden soll, muss man beim Schreiben konvertieren, denn ich nehme an, dass "Strom28.set" ebenfalls "on"/"off" erwartet?
                "read": "val == 'on'",
                "write": "val ? 'on' : 'off'"
          • H Offline
            Heinz53
            Danke für eure Tipps. Leider kann ich sie gerade nicht testen weil mein ioBroker in einer Endlosschleife läuft.
            Ich habe ihn gestoppt, neu gestartet und den Container neu erstellt., ioBroker fix ausgeführt, ... Das Ergebnis bleibt gleich:
                at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10961:37)
                at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:383:37)
                at processImmediate (node:internal/timers:483:21)
            Ich kann nicht über den ioBroker auf meine Datenpunkte zugreifen.
            Vermutlich habe ich noch ungültige alias Definitionen.
            Wie kann ich den Zugriff wieder herstellen?
            • H Offline
              Heinz53
              Mein ursprüngliches Problem ist mittlerweile behoben. Der Zugriff auf den ioBroker war nach Start der Admin Instanz über SSH wieder möglich.
              iobroker start admin
              Als Ursache für meine Probleme vermute ich den "Schlafmodus" meiner Zigbee Button beim Versuch des öffnens eines "schlafenden" alias Datenpunktes in den Objekten.
              Dies führte bei mir reproduzierbar zu Problemen der Admin Instanz.
              Nach dem Setzen des Retain bei den Problematischen Geräten traten keine Abbrüche mehr auf.
              "retain": true
              @FredF und @paul53 : Ich habe noch Probleme meine Zigbee Steckdose (mit JSON) zu schalten.
              Bei der Anbindung eines direkten Datenpunktes funktioniert es:
                "common": {
                  "name": "Test_1",
                  "role": "state",
                  "type": "boolean",
                  "read": true,
                  "write": true,
                  "def": false,
                  "alias": {
                    "id": "0_userdata.0.Test.TestOnOff",
                    "read": "val == 'on' ? true : false",
              Bei der Steckdose habe ich noch Probleme. Ich erhalte die Fehlermeldung:
              Invalid write function for "alias.0.Steckdose.Strom28.state": "val ? JSON.stringify{'state' : 'on'} : JSON.stringify{'state' : 'off'}" => Unexpected token '{'
              Ich habe schon viele Varianten erfolglos durchprobiert.
                "common": {
                  "name": "state",
                  "role": "state",
                  "type": "boolean",
                  "read": true,
                  "write": true,
                  "def": "",
                  "alias": {
                    "id": {
                    "read": "JSON.parse(val).state == 'on' ? true : false",
                    "write": "val ? JSON.stringify{'state' : 'on'} : JSON.stringify{'state' : 'off'}"
              Wie geht es richtig?
              • H Heinz53
                "retain": true
                  "common": {
                    "name": "Test_1",
                    "role": "state",
                    "type": "boolean",
                    "read": true,
                    "write": true,
                    "def": false,
                    "alias": {
                  "common": {
                    "name": "state",
                    "role": "state",
                    "type": "boolean",
                    "read": true,
                    "write": true,
                    "def": "",
                    "alias": {
                      "id": {
                @heinz53 sagte: Wie geht es richtig?
                Es fehlenden die runden Klammern.
                      "read": "JSON.parse(val).state == 'on'",
                      "write": "JSON.stringify({state: val ? 'on' : 'off'})"
                Die Rolle sollte "switch" sein. Außerdem bietet sich an, einen eindeutigen, verständlichen Namen zu vergeben.
                • H Offline
                  Heinz53
                  @paul53 said in Alias Umwandlung bei JSON mit "null" bereitet Probleme:
                  @paul53 Nun erhalte ich folgende Fehlermeldung:
                  Object alias.0.Steckdose.Strom28.state is invalid: Default value has to be type "boolean" but received type "string" This will throw an error up from js-controller version 7.0.0!
                  Wenn die Steckdose ausgeschaltet ist wird sie über den alias eingeschaltet.
                  Das Ausschalten über den alias ist nicht möglich.
                    "common": {
                      "name": "Steckdose_Strom28",
                      "role": "switch",
                      "type": "boolean",
                      "read": true,
                      "write": true,
                      "def": "",
                      "alias": {
                        "id": {
                        "read": "JSON.parse(val).state == 'on' ? true : false ",
                  Was kann ich machen?
                  • H Heinz53
                      "common": {
                        "role": "switch",
                        "type": "boolean",
                        "read": true,
                        "write": true,
                        "def": "",
                        "alias": {
                          "id": {
                    @heinz53 sagte: Was kann ich machen?
                    Ändere "def":
                        "def": false,
                    @heinz53 sagte in Alias Umwandlung bei JSON mit "null" bereitet Probleme:
                    ?? Wie sieht der Wert von "mqtt.0.zigbee2mqtt.Strom28" bei ausgeschalteter Steckdose aus?
                    • H Offline
                      Heinz53
                      Die mqtt Daten sind:
                        "common": {
                          "role": "switch",
                          "type": "boolean",
                          "read": true,
                          "write": true,
                          "def": false,
                          "alias": {
                            "id": {
                      Nach der Änderung von "def" erhalte ich keine Fehlermeldung mehr im log.
                      Das Ausschalten ist weiterhin nicht möglich.
                        "common": {
                          "role": "switch",
                          "type": "boolean",
                          "read": true,
                          "write": true,
                          "def": false,
                          "alias": {
                            "id": {
                      • H Offline
                        Heinz53
                        die mqtt Daten:
                        "child_lock": "UNLOCK",
                        "countdown": 0,
                        "current": 0,
                        "energy": 0.03,
                        "indicator_mode": "off/on",
                        "last_seen": "2025-01-08T20:10:18+01:00",
                        "linkquality": 138,
                        "power": 0,
                        "power_outage_memory": "restore",
                        "state": "OFF",
                        "update": {
                        "installed_version": 80,
                        "latest_version": 80,
                        "state": "idle"
                        "update_available": false,
                        "voltage": 225
                        • H Heinz53
                          die mqtt Daten:
                          "countdown": 0,
                          "current": 0,
                          "energy": 0.03,
                          "linkquality": 138,
                          "power": 0,
                          "state": "OFF",
                          "update": {
                          "state": "idle"
                          "voltage": 225
                          @heinz53 sagte: "state": "OFF",
                          ... groß geschrieben! Auch "ON"?
                          • H Offline
                            Heinz53
                            Danke! Das war's. Nun funktioniert es.
                              "common": {
                                "role": "switch",
                                "type": "boolean",
                                "read": true,
                                "write": true,
                                "def": false,
                                "alias": {
                                  "id": {
                                  "read": "JSON.parse(val).state == 'ON'",
                                  "write": "JSON.stringify({state: val ? 'ON' : 'OFF'})"
                            Es funktionieren beim direkten Schalten beide Schreibweisen (Groß oder Kleinschrift)
                            ... und wieder was gelernt ...
                            Danke für die Unterstützung!
                            C 1 Antwort Letzte Antwort
                            • H Heinz53
                                "common": {
                                  "role": "switch",
                                  "type": "boolean",
                                  "read": true,
                                  "write": true,
                                  "def": false,
                                  "alias": {
                                    "id": {
                              c1olli
                              Ich habe ein wenigstens der Überschrift nach ähnliches Problem.
                              Ich bekomme die Daten aus der Victron VRM als json ins MQTT geliefert.
                              Diese wandele ich mit:
                              Math.round(JSON.parse(val).value * 10) / 10
                              im Alias zu Werten um und das funktioniert auch recht gut.
                              Aber wenn die PV nichts mehr einspeist meldet der Datenpunkt :
                              {"value":null}
                              Damit kommt dann der alias nicht klar und meldet folgenden Fehler:
                              Invalid read function for "alias.0.Vic-Erz": "Math.round(JSON.parse(val).value * 10) / 10" => Cannot read properties of null (reading 'value')
                              Weil Null kein Wert ist.
                              So sieht der Datenpunkt dann aus:
                                "common": {
                                  "name": "PV-Pow-Ges",
                                  "role": "value",
                                  "type": "number",
                                  "read": true,
                                  "write": true,
                                  "def": 0,
                                  "alias": {
                                    "read": "Math.round(JSON.parse(val).value * 100) / 100",
                                    "id": "mqtt.0.N.48e7da85dd79.pvinverter.22.Ac.Power"
                                  "unit": "W"
                                "type": "state",
                                "native": {},
                                "_id": "alias.0.PV-Pow-Ges",
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                                "ts": 1736334728344
                              Wie kann ich nun die Fehlermeldung verhindern?
                              Olli
                              • mickymM Online
                                mickymM Online
                                mickym
                                @c1olli sagte in Alias Umwandlung bei JSON mit "null" bereitet Probleme:
                                Probier halt das Gleiche was vorgeschlagen wurde:
                                val ? Math.round(JSON.parse(val).value * 10) / 10 : val
                                • C c1olli
                                  {"value":null}
                                    "common": {
                                      "role": "value",
                                      "type": "number",
                                      "read": true,
                                      "write": true,
                                      "def": 0,
                                      "alias": {
                                      "unit": "W"
                                    "type": "state",
                                    "native": {},
                                    "acl": {
                                      "object": 1636,
                                      "state": 1636,
                                    "ts": 1736334728344
                                  @c1olli sagte: {"value":null}
                                  "JSON.parse(val).value ? Math.round(JSON.parse(val).value * 100) / 100 : 0",
                                  Das JSON wird noch so erzeugt? Es ist nicht der gesamte Wert null?
                                  C 2 Antworten Letzte Antwort
                                    c1olli
                                    schrieb am zuletzt editiert von c1olli
                                    ich habe die Variante von @mickym und auch die von Dir probiert (2 verschiedene Werte) und beides funktioniert erst einmal.
                                    Ob das mit Null funktioniert weiß ich nicht, da die PV erst heute abend auf "null" stellt.
                                    Ich versuche mal beides zu simulieren.
                                    Edit:
                                    In der Simulation hat beides funktioniert. Ich warte also mal ab was passiert.
                                    Olli
                                      c1olli
                                      @mickym
                                      Ich hab die Varianten jetzt laufen lassen und die Variante von @mickym funktioniert.
                                      Bei der anderen Variante kommt dann wieder "null" und die Fehlermeldung,
                                      Danke für die Hilfe.
                                      Olli
