  3. Cloud Dienste
  4. Fehlerhafte Status Meldungen in der Alexa App
    6.4k
31 Beiträge 5 Kommentatoren 3.7k Aufrufe 5 Beobachtet
  • Jörg WintersteinJ Jörg Winterstein
    @ofbeqnpolkkl6mby5e13
    025-01-08 08:40:31.050 - info: hmip.1 (462592) Got terminate signal TERMINATE_YOURSELF
    2025-01-08 08:40:31.052 - info: hmip.1 (462592) cleaned everything up...
    2025-01-08 08:40:31.054 - info: hmip.1 (462592) terminating
    2025-01-08 08:40:31.056 - info: hmip.1 (462592) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-01-08 08:40:31.136 - info: host.docker stopInstance system.adapter.hmip.1 send kill signal
    2025-01-08 08:40:31.560 - info: hmip.1 (462592) terminating
    2025-01-08 08:40:31.635 - info: host.docker instance system.adapter.hmip.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-01-08 08:40:35.434 - info: host.docker instance system.adapter.hmip.1 in version "1.26.4" started with pid 462787
    2025-01-08 08:40:37.030 - info: host.docker stopInstance system.adapter.hmip.1 (force=false, process=true)
    2025-01-08 08:40:37.126 - info: host.docker stopInstance system.adapter.hmip.1 send kill signal
    2025-01-08 08:40:37.968 - info: hmip.1 (462787) starting. Version 1.26.4 in /opt/iobroker/node_modules/iobroker.hmip, node: v20.18.1, js-controller: 7.0.6
    2025-01-08 08:40:38.087 - info: hmip.1 (462787) token not yet created
    2025-01-08 08:40:38.128 - info: host.docker stopInstance timeout system.adapter.hmip.1 killing pid 462787
    2025-01-08 08:40:38.191 - warn: host.docker instance system.adapter.hmip.1 terminated due to SIGKILL
    2025-01-08 08:40:38.191 - info: host.docker instance system.adapter.hmip.1 terminated with code null ()
    2025-01-08 08:40:41.827 - info: host.docker instance system.adapter.hmip.1 in version "1.26.4" started with pid 462802
    2025-01-08 08:40:44.182 - info: hmip.1 (462802) starting. Version 1.26.4 in /opt/iobroker/node_modules/iobroker.hmip, node: v20.18.1, js-controller: 7.0.6
    2025-01-08 08:40:44.249 - info: hmip.1 (462802) token not yet created
    2025-01-08 08:40:50.404 - info: hmip.1 (462802) auth step 1
    2025-01-08 08:40:50.469 - info: hmip.1 (462802) auth step 2
    O Abwesend
    O Abwesend
    oFbEQnpoLKKl6mbY5e13
    @jörg-winterstein
    Und du hast die blaue Taste auf dem HAP gedrückt?
    1. SGTIN des HAP eintragen
    2. Admin-PIN eintragen
    3. Token erstellen Button drücken
    4. Blaue Taste des HAP drücken
    Jörg WintersteinJ 2 Antworten Letzte Antwort
    • O oFbEQnpoLKKl6mbY5e13
      @jörg-winterstein
      Jörg WintersteinJ Offline
      Jörg Winterstein
      @ofbeqnpolkkl6mby5e13 Ich habe es mit dem HAP und dem DRAP versucht, beide hängen ja an der Cloud.
      Und nein beide gehen nicht
        @jörg-winterstein
        Jörg Winterstein
        @ofbeqnpolkkl6mby5e13 Der Adapter kreist immer und wartet auf den Tastendruck, aber er nimmt ihn dann nicht an
        O 1 Antwort Letzte Antwort
          O Abwesend
          O Abwesend
          @jörg-winterstein
          Ich weiß natürlich nichts über deine Installation. Können Netzwerkprobleme sein.
          Konzentriere dich auf den HAP und versuche es immer mal wieder.
          Edit:
          Und kontrolliere die Richtigkeit von SGTIN und PIN!
          Jörg WintersteinJ 1 Antwort Letzte Antwort
            @jörg-winterstein
            Edit:
            Jörg Winterstein
            schrieb am zuletzt editiert von Jörg Winterstein
            @ofbeqnpolkkl6mby5e13 ich schließe Netzwerk Probleme aus, da ja ansonsten alles funktioniert. Egal ob als Cloud oder CCU Installation, alle Geräte werden richtig erkannt und funktionieren einwandfrei.
            Eine Frage... muss der HMIP Adapter vor dem erstellen des TOKEN "grün" sein oder erst wenn der TOKEN erstellt wurde?
            Also so wie bei dem MQTT Adapter, oder muss man den HAP vorher einmal reseten?
              O Abwesend
              O Abwesend
              @jörg-winterstein
              Der Adapter wird erst nach erfolgreicher Erstellung des Tokens grün.
              Kontrolliere die SGTIN und PIN auf Richtigkeit. Du hast viel rumprobiert mit HAP und DRAP. Lösche die Instanz komplett und lege eine Neue an. Dann von vorne und verwende nur den HAP für die Verbindung.
                @jörg-winterstein
                Jörg Winterstein
                @ofbeqnpolkkl6mby5e13 sorry hat etwas gedauert, musste erstmal den Raspi neustarten und hatte das Passwort verlegt.
                Geht immer noch nicht
                Eduard77E O 2 Antworten Letzte Antwort
                  Eduard77E Online
                  Eduard77E Online
                  Eduard77
                  @jörg-winterstein
                  Hallo, du kannst dein Admin-PIN im Homematic-App unter "Einstellungen/Benutzerverwaltung/Administrator-PIN" prüfen ob er richtig ist. Wenn nicht kannst du dort ein neues PIN erstellen.
                    O Abwesend
                    O Abwesend
                    @jörg-winterstein
                    Dann kann ich leider nicht weiterhelfen.
                    • Eduard77E Eduard77
                      @jörg-winterstein
                      Jörg Winterstein
                      @edis77 Moin...
                      Die PIN hatte ich extra noch einmal überprüft, die war und ist korrekt,
                      trotzdem bekomme ich keinen Zugriff.
