  4. [Aufruf] IKEA-Trådfri Adapter testen
471 Beiträge 49 Kommentatoren 175.9k Aufrufe 5 Beobachtet
  • N Offline
    N Offline
    NemoN
    #282
    @AlCalzone:
    Cool, danke! Muss ich mir mal wieder die App anschauen um rauszufinden, was dieser neue Key ist. `
    zumindest meine Android App (1.3.0) kennt die ID noch nicht:
    public class IPSOObjects {
        public static final String ALEXA_PAIR_STATUS = "9093";
        public static final String AUTH_PATH = "9063";
        public static final String CERTIFICATE_PEM = "9096";
        public static final String CERTIFICATE_PROV = "9092";
        public static final String CLIENT_IDENTITY_PROPOSED = "9090";
        public static final String COGNITO_ID = "9101";
        public static final String COLOR = "5706";
        public static final String COLOR_TEMPERATURE = "5711";
        public static final String COLOR_X = "5709";
        public static final String COLOR_Y = "5710";
        public static final String COMMISSIONING_MODE = "9061";
        public static final String CREATED_AT = "9002";
        public static final String CUM_ACTIVE_POWER = "5805";
        public static final String CURRENT_TIMESTAMP = "9059";
        public static final int DEFAULT_DIMMER_TRANSITION_TIME = 5;
        public static final String DEVICE = "3";
        public static final String DIMMER = "5851";
        public static final int DIMMER_MAX = 254;
        public static final int DIMMER_MIN = 0;
        public static final String END_ACTION = "9043";
        public static final String END_TIME_HR = "9048";
        public static final String END_TIME_MN = "9049";
        public static final String ERROR_TAG = "errorcode";
        public static final String FORCE_CHECK_OTA_UPDATE = "9032";
        public static final String GATEWAY = "15011";
        public static final String GATEWAY_DETAILS = "15012";
        public static final String GATEWAY_ID = "9100";
        public static final String GATEWAY_NAME = "9035";
        public static final int GATEWAY_REBOOT_NOTIFICATION = 1003;
        public static final String GATEWAY_REBOOT_NOTIFICATION_TYPE = "9052";
        public static final String GATEWAY_TIME_SOURCE = "9071";
        public static final String GATEWAY_UPDATE_DETAILS_URL = "9056";
        public static final String GATEWAY_UPDATE_PROGRESS = "9055";
        public static final String GOOGLE_HOME_PAIR_STATUS = "9105";
        public static final String GROUPS = "15004";
        public static final String GROUP_ID = "9038";
        public static final String GROUP_LINK_ARRAY = "9995";
        public static final String GROUP_SETTINGS = "9045";
        public static final String HS_ACCESSORY_LINK = "9018";
        public static final String HS_LINK = "15002";
        public static final String HUE = "5707";
        public static final String IKEA_MOODS = "9068";
        public static final String INSTANCE_ID = "9003";
        public static final String IOT_ENDPOINT = "9103";
        public static final String KEY_PAIR = "9097";
        public static final String LAST_SEEN = "9020";
        public static final String LIGHT = "3311";
        public static final int LIGHTS_OFF_SMART_TASK = 2;
        public static final String LIGHT_SETTING = "15013";
        public static final int LOSS_OF_INTERNET_CONNECTIVITY = 5001;
        public static final String MASTER_TOKEN_TAG = "9036";
        public static final String MAX_MSR_VALUE = "5602";
        public static final String MAX_RNG_VALUE = "5604";
        public static final String MIN_MSR_VALUE = "5601";
        public static final String MIN_RNG_VALUE = "5603";
        public static final String NAME = "9001";
        public static final int NEW_FIRMWARE_AVAILABLE = 1001;
        public static final String NEW_PSK_BY_GW = "9091";
        public static final String NOTIFICATION_EVENT = "9015";
        public static final String NOTIFICATION_NVPAIR = "9017";
        public static final String NOTIFICATION_STATE = "9014";
        public static final int NOT_AT_HOME_SMART_TASK = 1;
        public static final String NTP_SERVER = "9023";
        public static final String ONOFF = "5850";
        public static final String ON_TIME = "5852";
        public static final String OPEN = "1";
        public static final int OPTION_APP_TOKEN = 2051;
        public static final int OTA_CRITICAL = 1;
        public static final int OTA_FORCED = 5;
        public static final int OTA_NORMAL = 0;
        public static final int OTA_REQUIRED = 2;
        public static final String OTA_TYPE = "9066";
        public static final String OTA_UPDATE = "9037";
        public static final String OTA_UPDATE_STATE = "9054";
        public static final String PLUG = "3312";
        public static final String POWER_FACTOR = "5820";
        public static final String PRIVATE_KEY = "9099";
        public static final String PUBLIC_KEY = "9098";
        public static final String REACHABILITY_STATE = "9019";
        public static final String REBOOT = "9030";
        public static final int REBOOT_DEFAULT = -1;
        public static final int REBOOT_FIRMWARE_UPGRADE = 0;
        public static final int REBOOT_FROM_CLIENT = 1;
        public static final int REBOOT_HOMEKIT_RESET = 3;
        public static final int REBOOT_SOFT_RESET = 2;
        public static final String REPEAT_DAYS = "9041";
        public static final String RESET = "9031";
        public static final String RESET_MIN_MAX_MSR = "5605";
        public static final String SATURATION = "5708";
        public static final String SCENE = "15005";
        public static final String SCENE_ACTIVATE_FLAG = "9058";
        public static final String SCENE_ID = "9039";
        public static final String SCENE_INDEX = "9057";
        public static final String SCENE_LINK = "9009";
        public static final String SEND_CERT_TO_GATEWAY = "9094";
        public static final String SEND_COGNITO_ID_TO_GATEWAY = "9095";
        public static final String SEND_GH_COGNITO_ID_TO_GATEWAY = "9104";
        public static final String SENSOR = "3300";
        public static final String SENSOR_TYPE = "5751";
        public static final String SENSOR_VALUE = "5700";
        public static final String SESSION_ID = "9033";
        public static final String SESSION_LENGTH = "9064";
        public static final String SHORTCUT_ICON_REFERENCE_TYPE = "9051";
        public static final String SMART_TASK_ACTION = "9050";
        public static final String SMART_TASK_TEMPLATE = "9016";
        public static final int SMART_TASK_TRIGGERED_EVENT = 1002;
        public static final String SMART_TASK_TYPE = "9040";
        public static final String START_ACTION = "9042";
        public static final String START_TIME_HR = "9046";
        public static final String START_TIME_MN = "9047";
        public static final String SWITCH = "15009";
        public static final String TIME_ARRAY = "9994";
        public static final String TIME_REMAINING_IN_SECONDS = "9024";
        public static final String TRANSITION_TIME = "5712";
        public static final String TRIGGER_TIME_INTERVAL = "9044";
        public static final String TYPE = "5750";
        public static final String UNIT = "5701";
        public static final String UPDATE_ACCEPTED_TIMESTAMP = "9069";
        public static final String UPDATE_FIRMWARE = "9034";
        public static final String USE_CURRENT_LIGHT_SETTINGS = "9070";
        public static final String VERSION = "9029";
        public static final int WAKE_UP_SMART_TASK = 3;
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      #283
      Danke, dann brauch ich auch erst mal nicht suchen!
        AlCalzoneA Offline
        AlCalzone
        #284
        @pxstd:
        Neuste Fehler: `
        Probier mal die Version von GitHub, da sollte die Warnung weg sein.
        • L Offline
          ludino
          #285
          ich denke das ist der gleiche fehler wie schon beschrieben, oder ist das was anders?
            AlCalzoneA Offline
            AlCalzone
            #286
            Das ist der gleiche. Sollte verschwinden, wenn du die Version von Github installierst.
            • L Offline
              ludino
              #287
              muss ich den alten dafür deninstallieren?
                AlCalzoneA Offline
                AlCalzone
                #288
                @ludino:
                muss ich den alten dafür deninstallieren? `
                Nein, der wird aktualisiert. Musst nur anschließend die Instanz neustarten.
                  Arnulf
                  #289
                  gerade wollte ich der Adapter auch testen und bin leider daran gescheitert, dass ich nicht ganz verstanden habe, wie ganau ich die Lampe verbinden muss.
                  Ich habe in der IKEA-APP leider 3 Fragen zu beantworten:
                  Host ==> ok, das wird dann wohl der ioBroker sein
                  Seriennummer ==> hier hört es schon auf. Vom Format ist das eine MAC-Adresse. Aber woher bekomme ich die? Auf der Lampe steht nix und ich glaube nicht, dass ich den Beipackzettel noch habe
                  Securitycode ==> 16-stelliger Code, der mit dem Code im Adaper übereinstimmen muss.
                  Oder habe ich hier was falsch verstanden?
                  Ich fürchte ja, ich habe keine Chance, die mit dem ioBroker zu verbinden. Mit Alexa läuft sie zur Zeit
                    AlCalzoneA Offline
                    AlCalzone
                    #290
                    Du brauchst das Ikea Gateway um den Adapter zu verwenden. Mit den Infos auf dessen Unterseite und den tooltips im konfigurationsdialog (Maus über (i)) solltest du alles ausfüllen können.
                      Arnulf
                      #291
                      Ich hatte die Lampe ohne Gateway mit Alexa einbinden können. Ein Gateway habe ich gar nicht :(
                      • N Offline
                        N Offline
                        NemoN
                        #292
                        @Arnulf:
                        Ich hatte die Lampe ohne Gateway mit Alexa einbinden können. Ein Gateway habe ich gar nicht :( `
                        Vermutlich hast du den Echo Plus?
                        Für den ioBroker Adapter brauchst du zwingend das IKEA Tradfri Gateway (29,00 EUR)
                        Edit: ach hatte ja AlCalzone schon geschrieben :-)
                        • P Offline
                          pxstd
                          #293
                          Ich sorge mich! Seit dem Upgrade auf 1.0.6 höre ich hier kein Gemecker mehr wie:
                          "Patrick! Dein dämliches gebasteltes Flurlicht funktioniert schon wieder nicht!" :)
                          Thanks, AlCalzone!
                            AlCalzoneA Offline
                            AlCalzone
                            #294
                            @pxstd:
                            Ich sorge mich! Seit dem Upgrade auf 1.0.6 höre ich hier kein Gemecker mehr `
                            Yeah! Ich will aber auch nicht ausschließen dass das letzte Gateway Update damit was zu tun hat.
                            Gesendet von unterwegs
                            • P Offline
                              pxstd
                              #295
                              @AlCalzone:
                              @pxstd:
                              Gesendet von unterwegs `
                              Kommando zurück. Schon wieder 2 Adapter Abstürze.
                                AlCalzoneA Offline
                                AlCalzone
                                #296
                                Dann brauche ich wohl wirklich mal nen Traffic Mitschnitt. Du scheinst aktuell der einzige zu sein, kein Schimmer warum.
                                  bastian
                                  #297
                                  ich habe eine Frage im Zusammenhang mit Vis.
                                  Über welches Widget mit welchen Datenpunkten steuert ihr eine Lampe?
                                  Mir war es gestern nur möglich eine Lampe ein und aus zuschalten jedoch nicht zu dimmen.
                                  Bastian
                                    krissi
                                    #298
                                    Ich habe das Problem das die Lampe morgens zwischendurch auf 100% eingeschaltet wird. Ich kann das auch nicht reproduzieren, abends steht die immer auf 18%. Ich schalte nur eine und aus.
                                    ioBroker in VM (unraid) / CCU2 für IP FB-Heizungssteuerung raspi3 / 3x Echo Dot / IKEA Tradfri / zigBee mit Conbee II
                                      AlCalzoneA Offline
                                      AlCalzone
                                      #299
                                      @krissi:
                                      Ich habe das Problem das die Lampe morgens zwischendurch auf 100% eingeschaltet wird. Ich kann das auch nicht reproduzieren, abends steht die immer auf 18%. Ich schalte nur eine und aus. `
                                      Kann mir nicht vorstellen, warum das passieren sollte. Wie steuerst du die an? Skripte? Alexa? Vis? Sonstwas?
                                        krissi
                                        #300
                                        @AlCalzone:
                                        Kann mir nicht vorstellen, warum das passieren sollte. Wie steuerst du die an? Skripte? Alexa? Vis? Sonstwas? `
                                        Das ist ja halt die gute Frage, ich schalte morgens über Blockly ein und aus. Gibt aber auch einen Taster, Alexa und VIS. Ich benutze immer den gleichen Datenpunkt. Das mit den 100% ist auch egal womit ich das schalte. Ich hab mir schon in VIS einen Taster für die 18% erstellt.
                                          AlCalzoneA Offline
                                          AlCalzone
                                          #301
                                          @krissi:
                                          Das ist ja halt die gute Frage, ich schalte morgens über Blockly ein und aus. `
                                          Und dabei passiert das? Schaltest du on/off oder Helligkeit per Blockly? Wenn du eine Helligkeit größer 0 festlegst, geht die Lampe ja auch an, vllt. ist das eine Möglichkeit.
                                          Vielleicht stellt der Cloud-Adapter bei Alexa-Betätigung irgendeinen Quatsch ein.
                                          Alternativ kannst du per Skript mal herausfinden, wo die 100% herkommen (XXXXX durch Lampen-ID ersetzen):
                                          on("tradfri.0.L-XXXXX.lightbulb.brightness", (obj) => {
                                          	log(`Helligkeit auf ${obj.state.val} gesetzt durch ${obj.state.from}`);
