  3. Einsteigerfragen
  4. Installation
  5. Zigbee - SONOFF Zigbee 3.0 Dongle startet nicht
10 Beiträge 4 Kommentatoren 682 Aufrufe 4 Beobachtet
    deviobroker
    ich habe eine frische IOBroker Installation ohne etwas zu "restoren". Habe dabei Probleme mit meinem bereis in älteren Versionen laufenden Sonoff Zigbee Dongle (CC2652P). Fehlermeldung:
    error: zigbee.0 (13229) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    Drüber steht folgendes in der Logdatei:
    2024-12-28 10:46:16.267  - debug: zigbee.0 (13378) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-12-28 10:46:16.301  - debug: zigbee.0 (13378) Objects client ready ... initialize now
    2024-12-28 10:46:16.303  - debug: zigbee.0 (13378) Objects create System PubSub Client
    2024-12-28 10:46:16.305  - debug: zigbee.0 (13378) Objects create User PubSub Client
    2024-12-28 10:46:16.328  - debug: zigbee.0 (13378) Objects client initialize lua scripts
    2024-12-28 10:46:16.338  - debug: zigbee.0 (13378) Objects connected to redis: 127.0.0.1:9001
    2024-12-28 10:46:16.343  - silly: zigbee.0 (13378) redis psubscribe cfg.o.system.user.*
    2024-12-28 10:46:16.353  - silly: zigbee.0 (13378) redis psubscribe cfg.o.enum.*
    2024-12-28 10:46:16.357  - silly: zigbee.0 (13378) objectDB connected
    2024-12-28 10:46:16.361  - debug: zigbee.0 (13378) Redis States: Use Redis connection: 127.0.0.1:9000
    2024-12-28 10:46:16.369  - debug: zigbee.0 (13378) States create System PubSub Client
    2024-12-28 10:46:16.371  - debug: zigbee.0 (13378) States create User PubSub Client
    2024-12-28 10:46:16.383  - debug: zigbee.0 (13378) States connected to redis: 127.0.0.1:9000
    2024-12-28 10:46:16.385  - silly: zigbee.0 (13378) statesDB connected
    2024-12-28 10:46:16.414  - debug: zigbee.0 (13378) Plugin sentry Do not initialize Plugin (enabled=false)
    2024-12-28 10:46:16.558  - info: zigbee.0 (13378) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
    2024-12-28 10:46:16.586  - debug: zigbee.0 (13378) Using zigbee-herdsman with settings: {"network":{"panID":6340,"extendedPanID":[173,218,18,209,218,223,208,223],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_fcdb00ac54d9eb118bf8178e6fe9f4d9-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
    2024-12-28 10:46:16.652  - info: zigbee.0 (13378) Starting Zigbee  npm ...
    2024-12-28 10:46:16.683  - silly: zigbee.0 (13378) States system redis pmessage system.adapter.zigbee.0.logLevel/system.adapter.zigbee.0.logLevel:{"val":"silly","ack":true,"ts":1735379176654,"q":0,"from":"system.adapter.zigbee.0","lc":1735377228617}
    Schritte, die ich bereits ausgeführt habe:
    1. Dongle neu geflasht (20240710)
    2. IOBroker frisch, ohne weitere Adapter, installiert.
    3. gecheckt, ob iobroker in der Gruppe dialout ist.
    4. viele verschienede Optionen unter Zigbee Einstellung ausprobiert.
    5. verschiedene USB Ports mit und ohne Verlägerungskabel ausprobiert.
    6. Adapter-Typ auf Silikon Labs umgestellt
    Alles hat nicht geholfen. Erst die Option "forceStartWithInconsistentAdapterConfiguration" hat geholfen und Zigbee adapter startet und ich konnte das erste Gerät anlernen.
    Nun steht dort : "Bitte Aktualisieren Sie den Adapter auf kompatible Firmware ..."
    Was muss ich hier machen?
    • Adaptername: zigbee
    • Link zu Adapterrepository: www.github.com...
    • Adapterversion: 1.10.3
    • js-controller Version: 7.0.6
    • Admin Version: 7.1.5
    • Hardwaresystem: Pi4 Model B Rev 1.1
    • Arbeitsspeicher: ...4GB
    • Festplattenart: SD-Karte
    • Betriebssystem: bookworm
    • Nodejs-Version: v20.18.1
    • NPM-Version: 10.8.2
    • Installationsart: Skript
    • Image, Docker genutzt: Nein
    iob diag Summary: iobDiagSummary.txt
    iob diad Detailed: iobDiagDetailed.txt
    Thomas BraunT haselchenH 2 Antworten Letzte Antwort
    • D deviobroker
      @deviobroker
      Ruf iob diag mal so auf:
      ./iob_diag.sh -de --unmask
      Muss allerdings noch die Testversion von hier:
      https://forum.iobroker.net/topic/59549/iob-diag-skript
      sein. Dann stehen die im Adapter einzutragenden Werte in der Ausgabe drin.
      • D deviobroker
        haselchenH Offline
        haselchenH Offline
        haselchen
        @deviobroker
        Dein Problem wird nach der frischen Installation die PAN ID und ext. PAN ID sein.
        Deswegen wohl der Hinweis mit dem Mismatch.
        Bin am Handy und finde so schnell nicht die Anleitung von @Asgothian
        Vielleicht liest er das hier und hilft aus.
        Edit: Was hast du denn in die Felder im Adapter eingetragen?
        Neue Werte ?
          @deviobroker
          deviobroker
          Hi Thomas,
          anbei die Logdatei von iob_diag.sh
          iob_diag.sh --de --unmask: iob_diag_all.log
          • D deviobroker
            Hi Thomas,
            @deviobroker
            Bitte keine windigen Text-Dateien hier anhängen.
            Ausgabe in CodeTags eingebettet. Dafür sind die da.
            In der Sektion
            *** ZigBee Settings ***
            finden sich aber die richtigen Einstellungen. Musste mal abgleichen, was du im Adapter/in der Instanz eingetragen hast.
              @deviobroker
              In der Sektion
              deviobroker
              In der tat, nach der Anpassung der PAN ID und Port hat es geklappt. Ich konnte mir also weder die PAN ID noch den Port aussuchen, sondern habe die Werte aus dem Skript iob_diag --unmask eingetragen.
              Danke für den Hinweis.
              • haselchenH haselchen
                @deviobroker
                Neue Werte ?
                deviobroker
                @haselchen,
                Falls du die Anleitung findest, würde mich das mal interessieren.
                Sonst hatte ich die Werte "erfunden", das hat aber nicht funktioniert.
                Danke,
                dev
                Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
                • D deviobroker
                  @haselchen,
                  Danke,
                  dev
                  @deviobroker sagte in Zigbee - SONOFF Zigbee 3.0 Dongle startet nicht:
                  Das funktioniert nicht, weil auf dem Stick bereits ein anderes Schloss eingebaut ist und du nun den passenden Schlüssel haben musst.
                  • D deviobroker
                    @haselchen,
                    Danke,
                    dev
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @haselchen,
                    Danke,
                    dev
                    Die Anleitung ist irgendwo im Forum - ist aber durch die gute Arbeit von @Thomas-Braun unnötig geworden. Er hat das diag Skript so angepasst das die gewünschten Informationen im Log stehen. Sobald das 'stabil' wird werde ich die Information in die Dokumentation vom Zigbee-Adapter aufnehmen.
                    Es gibt im Übrigen noch eine andere Option den Fehler zu beheben:
                    • Adapter anhalten
                    • nvbackup.json und shepherd.db löschen (unter \opt\iobroker\iobroker-data\zigbee_X, wobei X die InstanzID ist.)
                    • Adapter starten
                    In diesem Fall müssen alle Geräte neu angelernt werden. Dafür können Kanal, PanID und ExtPanID frei gewählt werden.
                    A.
                    • AsgothianA Asgothian
                      @haselchen,
                      Danke,
                      dev
                      • Adapter anhalten
                      • Adapter starten
                      A.
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @deviobroker
                      • Adapter anhalten
                      • Adapter starten
                      Genau die Anleitung meinte ich
