  3. Off Topic
  4. Proxmox
  5. gelöst: Host: Probleme mit unzureichendem Speicherplatz ...
    2.7k
    4.8k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
21 Beiträge 5 Kommentatoren 3.4k Aufrufe 5 Beobachtet
  • K kiste01
    @thomas-braun mach ich sofort
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-26-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
    OS is similar to:
    model name      : QEMU Virtual CPU version 2.5+
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     18:02:14 up 31 days,  4:02,  3 users,  load average: 0.51, 0.37, 0.66
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2024-12-19 18:02:14 CET
               Universal time: Thu 2024-12-19 17:02:14 UTC
                     RTC time: Thu 2024-12-19 17:02:14
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev redis
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:             16G        4.2G        9.6G        598K        3.4G         12G
    Swap:           1.0G          0B        1.0G
    Total:           17G        4.2G         10G
    Active iob-Instances:   53
            15992 M total memory
             3997 M used memory
             1244 M active memory
             5015 M inactive memory
             9121 M free memory
              224 M buffer memory
             2979 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    top - 18:02:14 up 31 days,  4:02,  3 users,  load average: 0.51, 0.37, 0.66
    Tasks: 164 total,   1 running, 163 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  15992.7 total,   9121.4 free,   3997.0 used,   3204.4 buff/cache
    MiB Swap:    975.0 total,    975.0 free,      0.0 used.  11995.7 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  7.8G     0  7.8G   0% /dev
    tmpfs          tmpfs     1.6G  580K  1.6G   1% /run
    /dev/sda1      ext4       15G   14G  518M  97% /
    tmpfs          tmpfs     7.9G  4.0K  7.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
    [Mon Nov 18 14:00:00 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Nov 18 14:00:00 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    2.0G    /var/
    1.5G    /var/log/journal/f78de3547b0149a78c6e67d9bf816f18
    1.5G    /var/log
    353M    /var/cache
    Archived and active journals take up 31.2M in the file system.
    /opt/iobroker/backups:
    1.5M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.9G    /opt/iobroker/iobroker-data/
    1.6G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    78M     /opt/iobroker/iobroker-data/objects.jsonl
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    29M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-SHA_CUL868-if00
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Hosts:
    iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 1295)
    Core adapters versions
    js-controller:  7.0.3
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     6
    +-- iobroker.energiefluss-erweitert@0.4.1 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#2e63ad165a0c0147f01955b024a2ca002299ad65)
    +-- iobroker.fronius-solarweb@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.fronius-solarweb.git#ca2f1a4972992cbd0d14bb25f5f7546219dd5b9e)
    +-- iobroker.info@2.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.info.git#863fada0c02d8c0f718022943bb783f40514f059)
    +-- iobroker.scheppach-roboticmower@0.0.1 (git+ssh://git@github.com/TA2k/ioBroker.scheppach-roboticmower.git#b7a5aa58bca3c366b03249e8488ae6d7c4342ffd)
    +-- iobroker.shelly@8.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.shelly.git#1a3ed2bb255be15db71595e10040f2527210f635)
    +-- iobroker.solaredge-modbus@0.0.25 (git+ssh://git@github.com/joergspoerl/ioBroker.solaredge-modbus.git#a17300b3182465292a476c4e0fbaa96c9706e14d)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.airconwithme.0           : airconwithme          : iobroker                                 - disabled, compact disabled
      system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled, compact disabled
    + system.adapter.alexa2.1                 : alexa2                : iobroker                                 -  enabled, compact disabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled, compact disabled
    + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled, compact disabled
      system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 - disabled, compact disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled, compact disabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled, compact disabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled, compact disabled
    + system.adapter.device-reminder.1        : device-reminder       : iobroker                                 -  enabled, compact disabled
    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled, compact disabled
    + system.adapter.deyeidc.1                : deyeidc               : iobroker                                 -  enabled, compact disabled, port: 8899
    + system.adapter.discovery.0              : discovery             : iobroker                                 - disabled, compact disabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled, compact disabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 - disabled, compact disabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled, compact disabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled, compact disabled
      system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobroker                                 - disabled, compact disabled
      system.adapter.evcc.0                   : evcc                  : iobroker                                 - disabled, compact disabled, port: 7070
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled, compact disabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled, compact disabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 - disabled, compact disabled
      system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled, compact disabled
    + system.adapter.go-e.0                   : go-e                  : iobroker                                 -  enabled, compact disabled
    + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, compact disabled, port: 8123
    + system.adapter.history.0                : history               : iobroker                                 -  enabled, compact disabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled, compact disabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, compact disabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled, compact disabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled, compact disabled
      system.adapter.iqontrol.0               : iqontrol              : iobroker                                 - disabled, compact disabled
      system.adapter.iwg-vpn.0                : iwg-vpn               : iobroker                                 - disabled, compact disabled
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled, compact disabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
    + system.adapter.kisshome-research.0      : kisshome-research     : iobroker                                 -  enabled, compact disabled
    + system.adapter.mercedesme.0             : mercedesme            : iobroker                                 -  enabled, compact disabled
    + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled, compact disabled
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, compact disabled, port: 54321
      system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
    + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled, compact disabled
      system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, compact disabled, port: 1886, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 - disabled, compact disabled
    + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled, compact disabled
      system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, compact disabled, port: 80, 7575, 8000, 8080, 8081, 8899
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 - disabled, compact disabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, compact disabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled, compact disabled
    + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled, compact disabled
    + system.adapter.scheduler.0              : scheduler             : iobroker                                 -  enabled, compact disabled
      system.adapter.scheppach-roboticmower.0 : scheppach-roboticmower: iobroker                                 - disabled, compact disabled
      system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled, compact disabled
      system.adapter.schoolfree.1             : schoolfree            : iobroker                                 -  enabled, compact disabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1886, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled, compact disabled
      system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 - disabled, compact disabled
    + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled, compact disabled
      system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, compact disabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.solaredge-modbus.0       : solaredge-modbus      : iobroker                                 - disabled, compact disabled, port: 502
      system.adapter.solaredge.0              : solaredge             : iobroker                                 -  enabled, compact disabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1887, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled, compact disabled
      system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker                                 - disabled, compact disabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled, compact disabled
      system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled, compact disabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tesla-motors.0           : tesla-motors          : iobroker                                 -  enabled, compact disabled
      system.adapter.text2command.0           : text2command          : iobroker                                 - disabled, compact disabled
    + system.adapter.tibberlink.0             : tibberlink            : iobroker                                 -  enabled, compact disabled
      system.adapter.tibberlink.1             : tibberlink            : iobroker                                 - disabled, compact disabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled, compact disabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled, compact disabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled, compact disabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled, compact disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled, compact disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled, compact disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled, compact disabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled, compact disabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.welcome.0                : welcome               : iobroker                                 -  enabled, compact disabled, port: 80, bind: 0.0.0.0, run as: admin
    + system.adapter.wireless-mbus.0          : wireless-mbus         : iobroker                                 -  enabled, compact disabled
      system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled, compact disabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, compact disabled, port: tcp://192.168.178.188:6638
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name                   │ url                                                     │ auto upgrade │
    │ 0       │ 'Beta (latest)'        │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
    │ 1       │ 'Stable (default)'     │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
    │ 2       │ 'default.ursprünglich' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 3       │ 'latest.ursprünglich'  │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Instances
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "airconwithme" : 0.0.4    , installed 0.0.4
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "awtrix-light" : 1.4.1    , installed 1.4.1
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "deyeidc"      : 0.1.1    , installed 0.1.1
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
    Adapter    "evcc"         : 0.1.1    , installed 0.1.1
    Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "go-e"         : 1.0.41   , installed 1.0.41
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "iwg-vpn"      : 3.0.0    , installed 3.0.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.3    , installed 7.0.3
    Adapter    "kisshome-research": 1.2.5, installed 1.2.5
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
    Adapter    "reolink"      : 1.1.2    , installed 1.1.2
    Adapter    "scheduler"    : 1.4.1    , installed 1.4.1
    Adapter    "schoolfree"   : 1.1.6    , installed 1.1.6
    Adapter    "shelly"       : 8.2.1    , installed 8.4.0
    Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
    Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "telegram-menu": 2.1.3    , installed 2.1.3
    Adapter    "tesla-motors" : 1.3.2    , installed 1.4.5
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tibberlink"   : 3.5.4    , installed 3.5.4
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.10.8
    Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.3.5
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "welcome"      : 1.0.2    , installed 1.0.2
    Adapter    "wireless-mbus": 0.9.4    , installed 0.9.4
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        72662
    States:         56413
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       78415875   993130/io.shelly.1
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       78412777   993137/io.sonoff.0
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       78409630   992629/iobroker.js-
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12100      1/systemd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14041      543/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      104        14030      510/redis-server 12
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       78411365   992647/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       78418952   994076/io.web.0
    tcp6       0      0 ::1:6379                :::*                    LISTEN      104        14031      510/redis-server 12
    tcp6       0      0 :::111                  :::*                    LISTEN      0          13700      1/systemd
    tcp6       0      0 :::80                   :::*                    LISTEN      1001       78418079   994136/io.welcome.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14043      543/sshd: /usr/sbin
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       78414190   993266/io.mihome-va
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       78415877   993119/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       78415922   993179/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       78415923   993179/io.tuya.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13966      475/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          417        1/systemd
    udp6       0      0 :::111                  :::*                                0          12101      1/systemd
    2024-12-19 17:55:12.403  - info: modbus.2 (993030) Disconnected from slave 192.168.178.44
    2024-12-19 17:56:12.405  - info: modbus.2 (993030) Connected to slave 192.168.178.44
    2024-12-19 17:58:42.539  - info: mercedesme.0 (993438) Lost WebSocket connection. Reconnect WebSocket
    2024-12-19 18:00:00.008  - info: go-e.0 (999210) Scheduled restart.
    2024-12-19 18:00:00.011  - info: go-e.0 (999210) terminating
    2024-12-19 18:00:00.011  - info: go-e.0 (999210) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2024-12-19 18:00:00.511  - info: go-e.0 (999210) terminating
    2024-12-19 18:00:00.653  - info: host.iobroker instance system.adapter.go-e.0 scheduled normal terminated and will be restarted on schedule.
    2024-12-19 18:00:00.653  - info: host.iobroker Restart adapter system.adapter.go-e.0 because enabled
    2024-12-19 18:00:02.192  - info: host.iobroker instance system.adapter.go-e.0 in version "1.0.41" started with pid 1005844
    2024-12-19 18:00:05.093  - warn: trashschedule.0 (994008) no events matches type "Wertstofftonne / gelber Sack" with match "Abfuhrtermin Wertstofftonne / gelber Sack (GELB)"
    2024-12-19 18:00:05.333  - info: go-e.0 (1005844) starting. Version 1.0.41 in /opt/iobroker/node_modules/iobroker.go-e, node: v20.18.1, js-controller: 7.0.3
    2024-12-19 18:00:05.384  - info: go-e.0 (1005844) Adapter is staring in Version setByGitHubActions
    2024-12-19 18:00:05.385  - info: go-e.0 (1005844) Server: 192.168.178.171
    2024-12-19 18:00:05.385  - info: go-e.0 (1005844) Intervall: 60
    2024-12-19 18:00:05.385  - info: go-e.0 (1005844) Calculation Method: iob
    2024-12-19 18:00:05.386  - info: go-e.0 (1005844) Set value V2 false of id fup
    2024-12-19 18:00:32.017  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 1006159
    2024-12-19 18:00:34.745  - info: dwd.0 (1006159) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.3
    2024-12-19 18:00:35.183  - info: dwd.0 (1006159) State value to set for "dwd.0.warning1.begin" has to be type "string" but received type "number"
    2024-12-19 18:00:35.184  - info: dwd.0 (1006159) State value to set for "dwd.0.warning1.end" has to be type "string" but received type "number"
    2024-12-19 18:00:35.194  - info: dwd.0 (1006159) State value to set for "dwd.0.warning2.begin" has to be type "string" but received type "number"
    2024-12-19 18:00:35.195  - info: dwd.0 (1006159) State value to set for "dwd.0.warning2.end" has to be type "string" but received type "number"
    2024-12-19 18:00:35.206  - info: dwd.0 (1006159) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-12-19 18:00:35.721  - info: host.iobroker instance system.adapter.dwd.0 having pid 1006159 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    iob diag has finished.
    @kiste01
    Ja, sda1 ist (fast) voll.
    Entweder machst du im ioBroker Platz oder du musst im Host-System der VM mehr Platz einräumen.
      @kiste01
      kiste01
      Ok. Es ist noch nicht so lange her, da hatte ich das System extra neu aufgesetzt und dachte alle Stellschrauben deutlich erhöht zu haben.
      Ist das der Punkt in proxmox?
      Thomas BraunT R 2 Antworten Letzte Antwort
      • K kiste01
        @kiste01 sagte in Fehler Host: Probleme mit unzureichendem Speicherplatz ...:
        Dann solltest du mal hinterfragen, was denn da so heftig viel Platz einnimmt.
        Kann man u. a. per
        sudo ncdu /
        machen.
        • K kiste01
          reutli
          @kiste01
          und nach der Analyse, was Dir die Platte "zumüllt":
          Hardware → Hard Disk → Disk Aktion → Resize
          iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
          *Wer freundlich ist, dem wird freundlich geholfen *
            Kann man u. a. per
            sudo ncdu /
            machen.
            kiste01
            Du meinst so was in etwa?
            pi@iobroker:~$ du -h -a /var/log | sort -hr | head -n 20
            du: cannot read directory '/var/log/private': Permission denied
            du: cannot read directory '/var/log/redis': Permission denied
            1.5G    /var/log
            121M    /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001.journal
            101M    /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-0000000000014765-00061ed627ea6251.journal
            99M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-000000000032250b-000620918fa918f7.journal
            98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-00000000002604b4-00062032f7da632c.journal
            98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-00000000001fec6d-00062032e20da8b0.journal
            98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-000000000019d425-00062032cb9cb472.journal
            98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-000000000013bbe0-00062032b71061c0.journal
            98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-00000000000da39a-00062032a26fbce3.journal
            98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-0000000000078b53-000620328e069c1e.journal
            97M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-00000000002c1d00-000620330e737063.journal
            93M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-00000000003c2af7-000622e1a3054ded.journal
            75M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-000000000041d75d-000625466f7bd335.journal
            65M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@000622cbcddff43a-72f9757d9babbe30.journal~
            17M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-0000000000000938-0006196a726470ea.journal
            14M     /var/log/installer/cdebconf/templates.dat
            Dann könnte ich in dem Ordner /var/log/journal/ einiges löschen
            • K kiste01
              1.5G    /var/log
              NICHT einfach stumpf irgendwas löschen!
              Und du solltest das per
              ncdu machen, da siehst du eher die dicken Brummer. Dein journal ist nämlich nicht ungewöhnlich groß.
                kiste01
                ah. Habs gefunden. Musste ich installieren.
                --- /home/pi ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
                  135.9 MiB [#############################################################] /.npm
                   62.9 MiB [############################                                 ] /.cache
                   12.0 KiB [                                                             ]  .bash_history
                   12.0 KiB [                                                             ] /.iobroker
                    8.0 KiB [                                                             ] /.config
                    4.0 KiB [                                                             ]  .bashrc
                    4.0 KiB [                                                             ]  .profile
                    4.0 KiB [                                                             ]  .bash_logout
                    4.0 KiB [                                                             ]  .rediscli_history
                    4.0 KiB [                                                             ]  .npmrc
                    0.0   B [                                                             ]  .sudo_as_admin_successful
                 /home/pi/.npm/_cacache/content-v2 -----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
                  126.9 MiB [#############################################################] /sha512
                Davon hab ich überhaupt keine Ahnung, was ich da machen könnte. Da bin ich ehrlich
                • K kiste01
                      4.0 KiB [                                                             ]  .bashrc
                      4.0 KiB [                                                             ]  .npmrc
                  kiste01
                  falsche Ebene
                      4.6 GiB [#############################################################] /opt
                  .   3.9 GiB [####################################################         ] /usr
                      2.5 GiB [#################################                            ] /home
                  .   2.0 GiB [##########################                                   ] /var
                    328.3 MiB [####                                                         ] /boot
                  .   4.1 MiB [                                                             ] /etc
                  . 556.0 KiB [                                                             ] /run
                  . 172.0 KiB [                                                             ] /tmp
                  !  16.0 KiB [                                                             ] /lost+found
                      8.0 KiB [                                                             ] /media
                      4.0 KiB [                                                             ] /dev
                  e   4.0 KiB [                                                             ] /srv
                  !   4.0 KiB [                                                             ] /root
                  e   4.0 KiB [                                                             ] /mnt
                  .   0.0   B [                                                             ] /proc
                  .   0.0   B [                                                             ] /sys
                  @   0.0   B [                                                             ]  initrd.img.old
                  @   0.0   B [                                                             ]  vmlinuz.old
                  @   0.0   B [                                                             ]  vmlinuz
                  @   0.0   B [                                                             ]  lib64
                  @   0.0   B [                                                             ]  sbin
                  @   0.0   B [                                                             ]  lib
                  @   0.0   B [                                                             ]  bin
                   2.7 GiB [#############################################################] /node_modules
                      1.8 GiB [########################################                     ] /iobroker-data
                    kiste01
                    @reutli
                    Muss ich nach dem risize noch was machen? Neustart VM und Proxmox hab ich gemacht. Es werden jetzt 36G angezeigt, aber es bleibt bei den ursprünglichen15G
                    pi@iobroker:~$ df -h
                    Filesystem      Size  Used Avail Use% Mounted on
                    udev            7.8G     0  7.8G   0% /dev
                    tmpfs           1.6G  576K  1.6G   1% /run
                    /dev/sda1        15G   14G  482M  97% /
                    R Thomas BraunT 2 Antworten Letzte Antwort
                    • K kiste01
                      @reutli
                      reutli
                      @kiste01
                      Keine Ahnung bei mir war nach dem risize immer alles in Butter.
                      Wahrscheinlich musst Du die vorhandene root Partition mit 'gparted' oder anderem Tool vergrößern?
                      Da müssen aber Linux Spezis wie @Thomas-Braun ran...
                      • K kiste01
                        @reutli
                        Ja, der 'von außen' nun zur Verfügung gestellte zusätzliche Platz muss jetzt auch 'im Inneren der VM' zugeteilt werden.
                        Bei nativen Systemen starte ich dazu extern GParted oder sonst ein Live-Linux und vergrößere die Partition dann darüber. Bei VMs hab ich aber keine Aktien.
                          @thomas-braun sagte in Fehler Host: Probleme mit unzureichendem Speicherplatz ...:
                          läuft genauso.
                          gparted live Image in der PVE Zur Verfügung stellen.
                          Diese dann als boot festlegen und proxmox neu starten
                          Partition snpassen
                          Boot zurückstellen
                          Neustart
                          fertig
                          • R Offline
                            reutli
                            @homoran sagte in Fehler Host: Probleme mit unzureichendem Speicherplatz ...:
                            läuft genauso.
                            Hier (https://pve.proxmox.com/wiki/Resize_disks) auch genau beschrieben und zu gparted gibt es auch genug im Netz
                            • R reutli
                              läuft genauso.
                              kiste01
                              @reutli
                              Ich hab die größe der Partition vergrößert.
                              Falls jemand ein step-by-step Anleitung braucht: https://youtu.be/-BjkHOxUqYc?si=911Sz85lnDcGq943
                              Ich musste die UID (ca. bei 13:00) nicht umstellen
                              R Meister MopperM 2 Antworten Letzte Antwort
                              • K kiste01
                                @reutli
                                reutli
                                schrieb am zuletzt editiert von reutli
                                @kiste01
                                Sehr gut. Dann stell' bitte den thread auf gelöst (Titel editieren und "gelöst" hinzufügen).
                                • K kiste01
                                  @reutli
                                  Meister MopperM Offline
                                  Meister Mopper
                                  @kiste01 sagte in gelöst: Host: Probleme mit unzureichendem Speicherplatz ...:
                                  @reutli
                                  Das ist keine gute Anleitung! Als root mit sudo arbeiten und eine VM in der Proxmox GUI mit stop beenden ist ein NOGO.
                                  Zudem ist das Ändern der UUID nicht erforderlich.
                                  Also für Lesende: Bitte nicht SO machen!
                                  Proxmox und HA - dank KI/AI endlich "blocklyfrei"
