  3. Off Topic
  4. Proxmox
  5. gelöst: Host: Probleme mit unzureichendem Speicherplatz ...
    2.7k
    4.7k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
21 Beiträge 5 Kommentatoren 3.4k Aufrufe 5 Beobachtet
    @kiste01
    In der Langfassung könnte man die jetzige Zuteilung sehen...
    kiste01
    @thomas-braun mach ich sofort
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-26-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
    OS is similar to:
    model name      : QEMU Virtual CPU version 2.5+
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     18:02:14 up 31 days,  4:02,  3 users,  load average: 0.51, 0.37, 0.66
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2024-12-19 18:02:14 CET
               Universal time: Thu 2024-12-19 17:02:14 UTC
                     RTC time: Thu 2024-12-19 17:02:14
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev redis
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:             16G        4.2G        9.6G        598K        3.4G         12G
    Swap:           1.0G          0B        1.0G
    Total:           17G        4.2G         10G
    Active iob-Instances:   53
            15992 M total memory
             3997 M used memory
             1244 M active memory
             5015 M inactive memory
             9121 M free memory
              224 M buffer memory
             2979 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    top - 18:02:14 up 31 days,  4:02,  3 users,  load average: 0.51, 0.37, 0.66
    Tasks: 164 total,   1 running, 163 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  15992.7 total,   9121.4 free,   3997.0 used,   3204.4 buff/cache
    MiB Swap:    975.0 total,    975.0 free,      0.0 used.  11995.7 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  7.8G     0  7.8G   0% /dev
    tmpfs          tmpfs     1.6G  580K  1.6G   1% /run
    /dev/sda1      ext4       15G   14G  518M  97% /
    tmpfs          tmpfs     7.9G  4.0K  7.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
    [Mon Nov 18 14:00:00 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Nov 18 14:00:00 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    2.0G    /var/
    1.5G    /var/log/journal/f78de3547b0149a78c6e67d9bf816f18
    1.5G    /var/log
    353M    /var/cache
    Archived and active journals take up 31.2M in the file system.
    /opt/iobroker/backups:
    1.5M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.9G    /opt/iobroker/iobroker-data/
    1.6G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    78M     /opt/iobroker/iobroker-data/objects.jsonl
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    29M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-SHA_CUL868-if00
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Hosts:
    iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 1295)
    Core adapters versions
    js-controller:  7.0.3
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     6
    +-- iobroker.energiefluss-erweitert@0.4.1 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#2e63ad165a0c0147f01955b024a2ca002299ad65)
    +-- iobroker.fronius-solarweb@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.fronius-solarweb.git#ca2f1a4972992cbd0d14bb25f5f7546219dd5b9e)
    +-- iobroker.info@2.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.info.git#863fada0c02d8c0f718022943bb783f40514f059)
    +-- iobroker.scheppach-roboticmower@0.0.1 (git+ssh://git@github.com/TA2k/ioBroker.scheppach-roboticmower.git#b7a5aa58bca3c366b03249e8488ae6d7c4342ffd)
    +-- iobroker.shelly@8.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.shelly.git#1a3ed2bb255be15db71595e10040f2527210f635)
    +-- iobroker.solaredge-modbus@0.0.25 (git+ssh://git@github.com/joergspoerl/ioBroker.solaredge-modbus.git#a17300b3182465292a476c4e0fbaa96c9706e14d)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.airconwithme.0           : airconwithme          : iobroker                                 - disabled, compact disabled
      system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled, compact disabled
    + system.adapter.alexa2.1                 : alexa2                : iobroker                                 -  enabled, compact disabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled, compact disabled
    + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled, compact disabled
      system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 - disabled, compact disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled, compact disabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled, compact disabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled, compact disabled
    + system.adapter.device-reminder.1        : device-reminder       : iobroker                                 -  enabled, compact disabled
    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled, compact disabled
    + system.adapter.deyeidc.1                : deyeidc               : iobroker                                 -  enabled, compact disabled, port: 8899
    + system.adapter.discovery.0              : discovery             : iobroker                                 - disabled, compact disabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled, compact disabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 - disabled, compact disabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled, compact disabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled, compact disabled
      system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobroker                                 - disabled, compact disabled
      system.adapter.evcc.0                   : evcc                  : iobroker                                 - disabled, compact disabled, port: 7070
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled, compact disabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled, compact disabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 - disabled, compact disabled
      system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled, compact disabled
    + system.adapter.go-e.0                   : go-e                  : iobroker                                 -  enabled, compact disabled
    + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, compact disabled, port: 8123
    + system.adapter.history.0                : history               : iobroker                                 -  enabled, compact disabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled, compact disabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, compact disabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled, compact disabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled, compact disabled
      system.adapter.iqontrol.0               : iqontrol              : iobroker                                 - disabled, compact disabled
      system.adapter.iwg-vpn.0                : iwg-vpn               : iobroker                                 - disabled, compact disabled
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled, compact disabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
    + system.adapter.kisshome-research.0      : kisshome-research     : iobroker                                 -  enabled, compact disabled
    + system.adapter.mercedesme.0             : mercedesme            : iobroker                                 -  enabled, compact disabled
    + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled, compact disabled
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, compact disabled, port: 54321
      system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
    + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled, compact disabled
      system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, compact disabled, port: 1886, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 - disabled, compact disabled
    + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled, compact disabled
      system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, compact disabled, port: 80, 7575, 8000, 8080, 8081, 8899
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 - disabled, compact disabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, compact disabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled, compact disabled
    + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled, compact disabled
    + system.adapter.scheduler.0              : scheduler             : iobroker                                 -  enabled, compact disabled
      system.adapter.scheppach-roboticmower.0 : scheppach-roboticmower: iobroker                                 - disabled, compact disabled
      system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled, compact disabled
      system.adapter.schoolfree.1             : schoolfree            : iobroker                                 -  enabled, compact disabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1886, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled, compact disabled
      system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 - disabled, compact disabled
    + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled, compact disabled
      system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, compact disabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.solaredge-modbus.0       : solaredge-modbus      : iobroker                                 - disabled, compact disabled, port: 502
      system.adapter.solaredge.0              : solaredge             : iobroker                                 -  enabled, compact disabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1887, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled, compact disabled
      system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker                                 - disabled, compact disabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled, compact disabled
      system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled, compact disabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tesla-motors.0           : tesla-motors          : iobroker                                 -  enabled, compact disabled
      system.adapter.text2command.0           : text2command          : iobroker                                 - disabled, compact disabled
    + system.adapter.tibberlink.0             : tibberlink            : iobroker                                 -  enabled, compact disabled
      system.adapter.tibberlink.1             : tibberlink            : iobroker                                 - disabled, compact disabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled, compact disabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled, compact disabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled, compact disabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled, compact disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled, compact disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled, compact disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled, compact disabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled, compact disabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.welcome.0                : welcome               : iobroker                                 -  enabled, compact disabled, port: 80, bind: 0.0.0.0, run as: admin
    + system.adapter.wireless-mbus.0          : wireless-mbus         : iobroker                                 -  enabled, compact disabled
      system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled, compact disabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, compact disabled, port: tcp://192.168.178.188:6638
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name                   │ url                                                     │ auto upgrade │
    │ 0       │ 'Beta (latest)'        │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
    │ 1       │ 'Stable (default)'     │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
    │ 2       │ 'default.ursprünglich' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 3       │ 'latest.ursprünglich'  │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Instances
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "airconwithme" : 0.0.4    , installed 0.0.4
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "awtrix-light" : 1.4.1    , installed 1.4.1
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "deyeidc"      : 0.1.1    , installed 0.1.1
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
    Adapter    "evcc"         : 0.1.1    , installed 0.1.1
    Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "go-e"         : 1.0.41   , installed 1.0.41
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "iwg-vpn"      : 3.0.0    , installed 3.0.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.3    , installed 7.0.3
    Adapter    "kisshome-research": 1.2.5, installed 1.2.5
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
    Adapter    "reolink"      : 1.1.2    , installed 1.1.2
    Adapter    "scheduler"    : 1.4.1    , installed 1.4.1
    Adapter    "schoolfree"   : 1.1.6    , installed 1.1.6
    Adapter    "shelly"       : 8.2.1    , installed 8.4.0
    Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
    Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "telegram-menu": 2.1.3    , installed 2.1.3
    Adapter    "tesla-motors" : 1.3.2    , installed 1.4.5
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tibberlink"   : 3.5.4    , installed 3.5.4
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.10.8
    Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.3.5
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "welcome"      : 1.0.2    , installed 1.0.2
    Adapter    "wireless-mbus": 0.9.4    , installed 0.9.4
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        72662
    States:         56413
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       78415875   993130/io.shelly.1
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       78412777   993137/io.sonoff.0
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       78409630   992629/iobroker.js-
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12100      1/systemd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14041      543/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      104        14030      510/redis-server 12
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       78411365   992647/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       78418952   994076/io.web.0
    tcp6       0      0 ::1:6379                :::*                    LISTEN      104        14031      510/redis-server 12
    tcp6       0      0 :::111                  :::*                    LISTEN      0          13700      1/systemd
    tcp6       0      0 :::80                   :::*                    LISTEN      1001       78418079   994136/io.welcome.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14043      543/sshd: /usr/sbin
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       78414190   993266/io.mihome-va
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       78415877   993119/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       78415922   993179/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       78415923   993179/io.tuya.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13966      475/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          417        1/systemd
    udp6       0      0 :::111                  :::*                                0          12101      1/systemd
    2024-12-19 17:55:12.403  - info: modbus.2 (993030) Disconnected from slave 192.168.178.44
    2024-12-19 17:56:12.405  - info: modbus.2 (993030) Connected to slave 192.168.178.44
    2024-12-19 17:58:42.539  - info: mercedesme.0 (993438) Lost WebSocket connection. Reconnect WebSocket
    2024-12-19 18:00:00.008  - info: go-e.0 (999210) Scheduled restart.
    2024-12-19 18:00:00.011  - info: go-e.0 (999210) terminating
    2024-12-19 18:00:00.011  - info: go-e.0 (999210) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2024-12-19 18:00:00.511  - info: go-e.0 (999210) terminating
    2024-12-19 18:00:00.653  - info: host.iobroker instance system.adapter.go-e.0 scheduled normal terminated and will be restarted on schedule.
    2024-12-19 18:00:00.653  - info: host.iobroker Restart adapter system.adapter.go-e.0 because enabled
    2024-12-19 18:00:02.192  - info: host.iobroker instance system.adapter.go-e.0 in version "1.0.41" started with pid 1005844
    2024-12-19 18:00:05.093  - warn: trashschedule.0 (994008) no events matches type "Wertstofftonne / gelber Sack" with match "Abfuhrtermin Wertstofftonne / gelber Sack (GELB)"
    2024-12-19 18:00:05.333  - info: go-e.0 (1005844) starting. Version 1.0.41 in /opt/iobroker/node_modules/iobroker.go-e, node: v20.18.1, js-controller: 7.0.3
    2024-12-19 18:00:05.384  - info: go-e.0 (1005844) Adapter is staring in Version setByGitHubActions
    2024-12-19 18:00:05.385  - info: go-e.0 (1005844) Server: 192.168.178.171
    2024-12-19 18:00:05.385  - info: go-e.0 (1005844) Intervall: 60
    2024-12-19 18:00:05.385  - info: go-e.0 (1005844) Calculation Method: iob
    2024-12-19 18:00:05.386  - info: go-e.0 (1005844) Set value V2 false of id fup
    2024-12-19 18:00:32.017  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 1006159
    2024-12-19 18:00:34.745  - info: dwd.0 (1006159) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.3
    2024-12-19 18:00:35.183  - info: dwd.0 (1006159) State value to set for "dwd.0.warning1.begin" has to be type "string" but received type "number"
    2024-12-19 18:00:35.184  - info: dwd.0 (1006159) State value to set for "dwd.0.warning1.end" has to be type "string" but received type "number"
    2024-12-19 18:00:35.194  - info: dwd.0 (1006159) State value to set for "dwd.0.warning2.begin" has to be type "string" but received type "number"
    2024-12-19 18:00:35.195  - info: dwd.0 (1006159) State value to set for "dwd.0.warning2.end" has to be type "string" but received type "number"
    2024-12-19 18:00:35.206  - info: dwd.0 (1006159) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-12-19 18:00:35.721  - info: host.iobroker instance system.adapter.dwd.0 having pid 1006159 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    iob diag has finished.
    • K kiste01
      ich hatte heute während des Editieren eines Blockly den Hinweis gelesen, dass die javascript Instanz nicht läuft. Den Fehler hatte ich immermal - im log war aber nichts zur Instanz. Also dachte ich es ist Zeit für Updates. Mein System läuft auf proxmox in einer VM.
      Die Fehlermeldung beim Host lautet:
      Ihr System verfügt nicht mehr über den vom Benutzer eingestellten Speicherplatz. Bitte geben Sie Speicherplatz auf der Festplatte frei, um Probleme zu vermeiden.
      Die VM und der iobroker sind up to date
      Wo kann ich ansetzen?
      Hier die
      iob diag
                              v.2024-10-19
               Chassis: vm 🖴
        Virtualization: kvm
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      Recommended versions are nodejs 20.18.1 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:             16G        4.3G        9.4G        598K        3.4G         12G
      Swap:           1.0G          0B        1.0G
      Total:           17G        4.3G         10G
      ioBroker Core:          js-controller           7.0.3
                              admin                   7.1.5
      Objects type: jsonl
      States  type: redis
      Objects:                72662
      States:                 56497
      Size of iob-Database:
      716K    /opt/iobroker/iobroker-data/states.jsonl
      12K     /opt/iobroker/iobroker-data/states.json.bak
      reutli
      @kiste01 sagte in Fehler Host: Probleme mit unzureichendem Speicherplatz ...:
      z.B. mal die Proxmox Instanz aufmachen und schauen, was da so geht:
      iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
      *Wer freundlich ist, dem wird freundlich geholfen *
      • K kiste01
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
          Virtualization: kvm
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 4
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           1.0G          0B        1.0G
        Total:           17G        4.2G         10G
                 3997 M used memory
                 9121 M free memory
                  224 M buffer memory
                 2979 M swap cache
                  974 M total swap
                    0 M used swap
                  974 M free swap
        *** FILESYSTEM ***
        /var:
        2.0G    /var/
        1.5G    /var/log
        353M    /var/cache
        USB-Devices by-id:
        HINT:
        tcp
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        Hosts:
        admin:          7.1.5
        javascript:     8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        72662
        States:         56413
        Pending Updates: 0
        voll!
        • K kiste01
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
            Virtualization: kvm
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           1.0G          0B        1.0G
          Total:           17G        4.2G         10G
                   3997 M used memory
                   9121 M free memory
                    224 M buffer memory
                   2979 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          *** FILESYSTEM ***
          /var:
          2.0G    /var/
          1.5G    /var/log
          353M    /var/cache
          USB-Devices by-id:
          HINT:
          tcp
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: redis
          Hosts:
          admin:          7.1.5
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        72662
          States:         56413
          Pending Updates: 0
          @kiste01
          Ja, sda1 ist (fast) voll.
          Entweder machst du im ioBroker Platz oder du musst im Host-System der VM mehr Platz einräumen.
            @kiste01
            kiste01
            Ok. Es ist noch nicht so lange her, da hatte ich das System extra neu aufgesetzt und dachte alle Stellschrauben deutlich erhöht zu haben.
            Ist das der Punkt in proxmox?
            Thomas BraunT R 2 Antworten Letzte Antwort
            • K kiste01
              Dann solltest du mal hinterfragen, was denn da so heftig viel Platz einnimmt.
              Kann man u. a. per
              sudo ncdu /
              machen.
              • K kiste01
                reutli
                @kiste01
                und nach der Analyse, was Dir die Platte "zumüllt":
                Hardware → Hard Disk → Disk Aktion → Resize
                  Kann man u. a. per
                  sudo ncdu /
                  machen.
                  kiste01
                  Du meinst so was in etwa?
                  pi@iobroker:~$ du -h -a /var/log | sort -hr | head -n 20
                  du: cannot read directory '/var/log/private': Permission denied
                  du: cannot read directory '/var/log/redis': Permission denied
                  1.5G    /var/log
                  121M    /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001.journal
                  101M    /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-0000000000014765-00061ed627ea6251.journal
                  99M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-000000000032250b-000620918fa918f7.journal
                  98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-00000000002604b4-00062032f7da632c.journal
                  98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-00000000001fec6d-00062032e20da8b0.journal
                  98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-000000000019d425-00062032cb9cb472.journal
                  98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-000000000013bbe0-00062032b71061c0.journal
                  98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-00000000000da39a-00062032a26fbce3.journal
                  98M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-0000000000078b53-000620328e069c1e.journal
                  97M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-00000000002c1d00-000620330e737063.journal
                  93M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-00000000003c2af7-000622e1a3054ded.journal
                  75M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-000000000041d75d-000625466f7bd335.journal
                  65M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@000622cbcddff43a-72f9757d9babbe30.journal~
                  17M     /var/log/journal/f78de3547b0149a78c6e67d9bf816f18/user-1001@12b480d14ba14cd7bf7db9b1010aef9e-0000000000000938-0006196a726470ea.journal
                  14M     /var/log/installer/cdebconf/templates.dat
                  Dann könnte ich in dem Ordner /var/log/journal/ einiges löschen
                  • K kiste01
                    1.5G    /var/log
                    NICHT einfach stumpf irgendwas löschen!
                    Und du solltest das per
                    ncdu machen, da siehst du eher die dicken Brummer. Dein journal ist nämlich nicht ungewöhnlich groß.
                      kiste01
                      ah. Habs gefunden. Musste ich installieren.
                      --- /home/pi ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
                        135.9 MiB [#############################################################] /.npm
                         62.9 MiB [############################                                 ] /.cache
                         12.0 KiB [                                                             ]  .bash_history
                         12.0 KiB [                                                             ] /.iobroker
                          8.0 KiB [                                                             ] /.config
                          4.0 KiB [                                                             ]  .bashrc
                          4.0 KiB [                                                             ]  .profile
                          4.0 KiB [                                                             ]  .bash_logout
                          4.0 KiB [                                                             ]  .rediscli_history
                          4.0 KiB [                                                             ]  .npmrc
                          0.0   B [                                                             ]  .sudo_as_admin_successful
                       /home/pi/.npm/_cacache/content-v2 -----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
                        126.9 MiB [#############################################################] /sha512
                      Davon hab ich überhaupt keine Ahnung, was ich da machen könnte. Da bin ich ehrlich
                      • K kiste01
                            4.0 KiB [                                                             ]  .bashrc
                            4.0 KiB [                                                             ]  .npmrc
                        kiste01
                        falsche Ebene
                            4.6 GiB [#############################################################] /opt
                        .   3.9 GiB [####################################################         ] /usr
                            2.5 GiB [#################################                            ] /home
                        .   2.0 GiB [##########################                                   ] /var
                          328.3 MiB [####                                                         ] /boot
                        .   4.1 MiB [                                                             ] /etc
                        . 556.0 KiB [                                                             ] /run
                        . 172.0 KiB [                                                             ] /tmp
                        !  16.0 KiB [                                                             ] /lost+found
                            8.0 KiB [                                                             ] /media
                            4.0 KiB [                                                             ] /dev
                        e   4.0 KiB [                                                             ] /srv
                        !   4.0 KiB [                                                             ] /root
                        e   4.0 KiB [                                                             ] /mnt
                        .   0.0   B [                                                             ] /proc
                        .   0.0   B [                                                             ] /sys
                        @   0.0   B [                                                             ]  initrd.img.old
                        @   0.0   B [                                                             ]  vmlinuz.old
                        @   0.0   B [                                                             ]  vmlinuz
                        @   0.0   B [                                                             ]  lib64
                        @   0.0   B [                                                             ]  sbin
                        @   0.0   B [                                                             ]  lib
                        @   0.0   B [                                                             ]  bin
                         2.7 GiB [#############################################################] /node_modules
                            1.8 GiB [########################################                     ] /iobroker-data
                          kiste01
                          @reutli
                          Muss ich nach dem risize noch was machen? Neustart VM und Proxmox hab ich gemacht. Es werden jetzt 36G angezeigt, aber es bleibt bei den ursprünglichen15G
                          pi@iobroker:~$ df -h
                          Filesystem      Size  Used Avail Use% Mounted on
                          udev            7.8G     0  7.8G   0% /dev
                          tmpfs           1.6G  576K  1.6G   1% /run
                          /dev/sda1        15G   14G  482M  97% /
                          R Thomas BraunT 2 Antworten Letzte Antwort
                          • K kiste01
                            @reutli
                            reutli
                            @kiste01
                            Keine Ahnung bei mir war nach dem risize immer alles in Butter.
                            Wahrscheinlich musst Du die vorhandene root Partition mit 'gparted' oder anderem Tool vergrößern?
                            Da müssen aber Linux Spezis wie @Thomas-Braun ran...
                            • K kiste01
                              @reutli
                              Ja, der 'von außen' nun zur Verfügung gestellte zusätzliche Platz muss jetzt auch 'im Inneren der VM' zugeteilt werden.
                              Bei nativen Systemen starte ich dazu extern GParted oder sonst ein Live-Linux und vergrößere die Partition dann darüber. Bei VMs hab ich aber keine Aktien.
                                @thomas-braun sagte in Fehler Host: Probleme mit unzureichendem Speicherplatz ...:
                                läuft genauso.
                                gparted live Image in der PVE Zur Verfügung stellen.
                                Diese dann als boot festlegen und proxmox neu starten
                                Partition snpassen
                                Boot zurückstellen
                                Neustart
                                fertig
                                • R Offline
                                  reutli
                                  @homoran sagte in Fehler Host: Probleme mit unzureichendem Speicherplatz ...:
                                  läuft genauso.
                                  Hier (https://pve.proxmox.com/wiki/Resize_disks) auch genau beschrieben und zu gparted gibt es auch genug im Netz
                                  • R reutli
                                    läuft genauso.
                                    kiste01
                                    @reutli
                                    Ich hab die größe der Partition vergrößert.
                                    Falls jemand ein step-by-step Anleitung braucht: https://youtu.be/-BjkHOxUqYc?si=911Sz85lnDcGq943
                                    Ich musste die UID (ca. bei 13:00) nicht umstellen
                                    R Meister MopperM 2 Antworten Letzte Antwort
                                    • K kiste01
                                      @reutli
                                      reutli
                                      schrieb am zuletzt editiert von reutli
                                      @kiste01
                                      Sehr gut. Dann stell' bitte den thread auf gelöst (Titel editieren und "gelöst" hinzufügen).
                                      • K kiste01
                                        @reutli
                                        Meister MopperM Offline
                                        Meister Mopper
                                        @kiste01 sagte in gelöst: Host: Probleme mit unzureichendem Speicherplatz ...:
                                        @reutli
                                        Das ist keine gute Anleitung! Als root mit sudo arbeiten und eine VM in der Proxmox GUI mit stop beenden ist ein NOGO.
                                        Zudem ist das Ändern der UUID nicht erforderlich.
                                        Also für Lesende: Bitte nicht SO machen!
                                        Proxmox und HA - dank KI/AI endlich "blocklyfrei"
