  4. iob started nicht nach raspi os update
55 Beiträge 4 Kommentatoren 8.4k Aufrufe 2 Beobachtet
    @hukio
    Mach doch bitte das Mäusekino größer...
    Siehst du nicht, dass da rechts was fehlt??
    hukio
    pi@raspi5:/opt/iobroker $ iobroker --help
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all        instances of an adapter
      iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all        instances of an adapter
      iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all i        nstances of an adapter  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub, if a package n        ame is provided instead of an url, it will be installed from npm
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: dele        te]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBrok        er installation
      iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v        ]
    Options:
      --help  Show help  [boolean]
    pi@raspi5:/opt/iobroker $ iob status admin.0
    Instance "admin.0" is not running
    pi@raspi5:/opt/iobroker $ iob start admin.0
    pi@raspi5:/opt/iobroker $ iob status admin.0\
    > ^C
    pi@raspi5:/opt/iobroker $ journalctl -u iobroker --since=today
    Dec 18 08:24:09 raspi5 bash[81679]: Send diag info: {"uuid":"3b3c55d5-65cb-4bbe-b729-697aa735019c","language":"en","hosts":[{"version":"6.0.11","platform":"Javascript/Node.js","type":"linux"}],"no>
    Dec 18 08:24:14 raspi5 sudo[211350]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
    Dec 18 08:24:14 raspi5 sudo[211350]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 08:24:14 raspi5 sudo[211350]: pam_unix(sudo:session): session closed for user root
    Dec 18 08:24:14 raspi5 sudo[211355]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
    Dec 18 08:24:14 raspi5 sudo[211355]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 08:24:14 raspi5 sudo[211355]: pam_unix(sudo:session): session closed for user root
    Dec 18 09:41:17 raspi5 bash[81679]: Send diag info: {"uuid":"3b3c55d5-65cb-4bbe-b729-697aa735019c","language":"en","hosts":[{"version":"6.0.11","platform":"Javascript/Node.js","type":"linux"}],"no>
    Dec 18 09:41:17 raspi5 sudo[211755]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
    Dec 18 09:41:17 raspi5 sudo[211755]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 09:41:17 raspi5 sudo[211755]: pam_unix(sudo:session): session closed for user root
    Dec 18 09:41:18 raspi5 sudo[211760]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
    Dec 18 09:41:18 raspi5 sudo[211760]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 09:41:18 raspi5 sudo[211760]: pam_unix(sudo:session): session closed for user root
    Dec 18 09:42:57 raspi5 bash[81679]: Send diag info: {"uuid":"3b3c55d5-65cb-4bbe-b729-697aa735019c","language":"en","hosts":[{"version":"6.0.11","platform":"Javascript/Node.js","type":"linux"}],"no>
    Dec 18 09:42:58 raspi5 sudo[211770]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
    Dec 18 09:42:58 raspi5 sudo[211770]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 09:42:58 raspi5 sudo[211770]: pam_unix(sudo:session): session closed for user root
    Dec 18 09:42:58 raspi5 sudo[211775]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
    Dec 18 09:42:58 raspi5 sudo[211775]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 09:42:58 raspi5 sudo[211775]: pam_unix(sudo:session): session closed for user root
    Dec 18 09:44:00 raspi5 bash[81679]: Send diag info: {"uuid":"3b3c55d5-65cb-4bbe-b729-697aa735019c","language":"en","hosts":[{"version":"6.0.11","platform":"Javascript/Node.js","type":"linux"}],"no>
    Dec 18 09:44:01 raspi5 sudo[211785]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
    Dec 18 09:44:01 raspi5 sudo[211785]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 09:44:01 raspi5 sudo[211785]: pam_unix(sudo:session): session closed for user root
    Dec 18 09:44:01 raspi5 sudo[211790]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
    Dec 18 09:44:01 raspi5 sudo[211790]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 09:44:01 raspi5 sudo[211790]: pam_unix(sudo:session): session closed for user root
    Dec 18 11:25:34 raspi5 bash[81679]: Send diag info: {"uuid":"3b3c55d5-65cb-4bbe-b729-697aa735019c","language":"en","hosts":[{"version":"6.0.11","platform":"Javascript/Node.js","type":"linux"}],"no>
    Dec 18 11:25:35 raspi5 sudo[211943]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
    Dec 18 11:25:35 raspi5 sudo[211943]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 11:25:35 raspi5 sudo[211943]: pam_unix(sudo:session): session closed for user root
    Dec 18 11:25:35 raspi5 sudo[211948]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
    Dec 18 11:25:35 raspi5 sudo[211948]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 11:25:35 raspi5 sudo[211948]: pam_unix(sudo:session): session closed for user root
    Dec 18 12:20:48 raspi5 bash[81679]: Send diag info: {"uuid":"3b3c55d5-65cb-4bbe-b729-697aa735019c","language":"en","hosts":[{"version":"6.0.11","platform":"Javascript/Node.js","type":"linux"}],"no>
    Dec 18 12:20:48 raspi5 sudo[212038]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
    Dec 18 12:20:48 raspi5 sudo[212038]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 12:20:48 raspi5 sudo[212038]: pam_unix(sudo:session): session closed for user root
    Dec 18 12:20:48 raspi5 sudo[212043]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
    Dec 18 12:20:48 raspi5 sudo[212043]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 12:20:49 raspi5 sudo[212043]: pam_unix(sudo:session): session closed for user root
    Dec 18 12:21:00 raspi5 sudo[212052]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
    Dec 18 12:21:00 raspi5 sudo[212052]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 12:21:00 raspi5 sudo[212052]: pam_unix(sudo:session): session closed for user root
    Dec 18 12:21:00 raspi5 sudo[212057]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
    Dec 18 12:21:00 raspi5 sudo[212057]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 12:21:00 raspi5 sudo[212057]: pam_unix(sudo:session): session closed for user root
    Dec 18 12:22:23 raspi5 sudo[212065]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/systemd-run --no-ask-password /usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/build/esm/lib/upg>
    Dec 18 12:22:23 raspi5 sudo[212065]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 12:22:23 raspi5 sudo[212065]: pam_unix(sudo:session): session closed for user root
    Dec 18 12:22:24 raspi5 systemd[1]: Stopping iobroker.service - ioBroker Server...
    Dec 18 12:22:27 raspi5 bash[81679]: ================================== > LOG REDIRECT system.adapter.iot.0 => false [Process stopped]
    Dec 18 12:22:27 raspi5 bash[81679]: ================================== > LOG REDIRECT system.adapter.iot.0 => false [system.adapter.iot.0.logging]
    Dec 18 12:22:27 raspi5 bash[81679]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
    Dec 18 12:22:27 raspi5 bash[81679]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    Dec 18 12:22:28 raspi5 bash[81679]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
    Dec 18 12:22:28 raspi5 bash[81679]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
    Dec 18 12:22:31 raspi5 systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
    Dec 18 12:22:31 raspi5 systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Dec 18 12:22:31 raspi5 systemd[1]: Stopped iobroker.service - ioBroker Server.
    Dec 18 12:22:31 raspi5 systemd[1]: iobroker.service: Consumed 4d 16h 1min 2.021s CPU time.
    Dec 18 12:23:05 raspi5 systemd[1]: Started iobroker.service - ioBroker Server.
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.admin.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.email.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.email.1" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.history.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.influxdb.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.javascript.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.scenes.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.telegram.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.alexa2.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.backitup.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.broadlink2.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.daikin.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.daikin.1" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.lgtv.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.mqtt.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.netatmo.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.nuki-extended.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.onkyo.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.ping.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.robonect.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.shelly.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.shelly.1" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.sonoff.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.tr-064.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.weatherunderground.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.zigbee.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.adb.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.discovery.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.doorbird.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.fritzdect.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.fullybrowser.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.iot.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.iqontrol.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.onvif.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.onvif.1" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.signal-cmb.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.simple-api.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.socketio.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.text2command.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.web.0" for host "raspi5"
    Dec 18 12:23:07 raspi5 bash[212136]: host.raspi5 check instance "system.adapter.ble.0" for host "raspi5"
    Dec 18 12:23:11 raspi5 bash[212136]: Send diag info: {"uuid":"3b3c55d5-65cb-4bbe-b729-697aa735019c","language":"en","hosts":[{"version":"7.0.3","platform":"Javascript/Node.js","type":"linux"}],"no>
    Dec 18 12:23:11 raspi5 bash[212136]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
    Dec 18 12:23:12 raspi5 sudo[212186]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
    Dec 18 12:23:12 raspi5 sudo[212186]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 12:23:12 raspi5 sudo[212186]: pam_unix(sudo:session): session closed for user root
    Dec 18 12:23:12 raspi5 sudo[212191]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
    Dec 18 12:23:12 raspi5 sudo[212191]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 12:23:13 raspi5 sudo[212191]: pam_unix(sudo:session): session closed for user root
    Dec 18 12:23:36 raspi5 sudo[212292]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
    Dec 18 12:23:36 raspi5 sudo[212292]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 12:23:36 raspi5 sudo[212292]: pam_unix(sudo:session): session closed for user root
    Dec 18 12:23:36 raspi5 sudo[212302]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
    Dec 18 12:23:36 raspi5 sudo[212302]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 12:23:37 raspi5 sudo[212302]: pam_unix(sudo:session): session closed for user root
    Dec 18 12:23:41 raspi5 sudo[212336]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
    Dec 18 12:23:41 raspi5 sudo[212336]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 12:23:41 raspi5 sudo[212336]: pam_unix(sudo:session): session closed for user root
    Dec 18 12:23:41 raspi5 sudo[212342]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
    Dec 18 12:23:41 raspi5 sudo[212342]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 12:23:42 raspi5 sudo[212342]: pam_unix(sudo:session): session closed for user root
    Dec 18 12:24:28 raspi5 bash[212136]: zhc:lixee: Was not able to detect the Linky linky_mode. Default to historique
    Dec 18 12:24:28 raspi5 bash[212136]: zhc:lixee: Was not able to detect the Linky energy_phase. Default to single_phase
    Dec 18 12:24:28 raspi5 bash[212136]: zhc:lixee: Not able to detect the current tarif. Not filtering any expose...
    Dec 18 12:24:28 raspi5 bash[212136]: TICMeter: Exposes: No endpoint
    Dec 18 13:12:20 raspi5 bash[212136]: Send diag info: {"uuid":"3b3c55d5-65cb-4bbe-b729-697aa735019c","language":"en","hosts":[{"version":"7.0.3","platform":"Javascript/Node.js","type":"linux"}],"no>
    Dec 18 13:12:21 raspi5 sudo[212751]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
    Dec 18 13:12:21 raspi5 sudo[212751]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 13:12:21 raspi5 sudo[212751]: pam_unix(sudo:session): session closed for user root
    Dec 18 13:12:21 raspi5 sudo[212756]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
    Dec 18 13:12:21 raspi5 sudo[212756]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Dec 18 13:12:21 raspi5 sudo[212756]: pam_unix(sudo:session): session closed for user root
    Dec 18 13:27:24 raspi5 systemd[1]: Stopping iobroker.service - ioBroker Server...
    Dec 18 13:27:27 raspi5 bash[212136]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
    Dec 18 13:27:27 raspi5 bash[212136]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    Dec 18 13:27:28 raspi5 bash[212136]: ================================== > LOG REDIRECT system.adapter.iot.0 => false [Process stopped]
    Dec 18 13:27:28 raspi5 bash[212136]: ================================== > LOG REDIRECT system.adapter.iot.0 => false [system.adapter.iot.0.logging]
    Dec 18 13:27:28 raspi5 bash[212136]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
    Dec 18 13:27:28 raspi5 bash[212136]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
    Dec 18 13:27:31 raspi5 systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
    Dec 18 13:27:31 raspi5 systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Dec 18 13:27:31 raspi5 systemd[1]: Stopped iobroker.service - ioBroker Server.
    Dec 18 13:27:31 raspi5 systemd[1]: iobroker.service: Consumed 9min 24.891s CPU time.
    -- Boot d57274f8efaa435aab48a659f7527847 --
    Dec 18 16:36:35 raspi5 systemd[1]: Failed to start iobroker.service.
    -- Boot 6b8f15901852445aa413e7d3d2617704 --
    Dec 18 17:33:25 raspi5 systemd[1]: Failed to start iobroker.service.
    lines 81-150/150 (END)
    • H hukio
      iobroker [command]
      Commands:
      Options:
      > ^C
      @hukio sagte in iob started nicht nach raspi os update:
      13:27:31
      Bis dahin hat es also funktioniert. Was hast du da gemacht?
      H 1 Antwort Letzte Antwort
        13:27:31
        hukio
        das ist die Zeit als ich das OS update gemacht habe und dann ein reboot. Bin zum Mittagessen gegangen ohne das reboot abzuwarten
        • H hukio
          @hukio
          Update von welchem Ausgangspunkt aus? Von Raspberry 11 auf 12 oder sowas?
            @hukio
            hukio
            im iobroker wurde auf ein neues update des OS hingewiesen und dies habe ich mit sudo apt update und sudo apt full-upgrade gemacht. Es ist einwandfrei durchgelaufen. Dann das reboot
            • H hukio
              @hukio
              Schau mal nach, welche Pakete da angepackt wurden:
              less /var/log/apt/history.log
                @hukio
                hukio
                pi@raspi5:~ $ less /var/log/apt/history.log
                pt2+deb12u8, 2.36-9+rpt2+deb12u9), python3.11-minimal:arm64 (3.11.2-6+deb12u3, 3.11.2-6+deb12u4), libdrm2:arm64 (2.4.114-1+b1, 2.4.123-1~bpo12+1+rpt1), libc-bin:arm64 (2.36-9+rpt2+deb12u8, 2.36-9+rpt2+deb12u9), libsystemd-shared:arm64 (252.30-1~deb12u2, 252.31-1~deb12u1), libc-devtools:arm64 (2.36-9+rpt2+deb12u8, 2.36-9+rpt2+deb12u9), initramfs-tools:arm64 (0.142+deb12u1, 0.142+rpt2+deb12u1), libc6-dbg:arm64 (2.36-9+rpt2+deb12u8, 2.36-9+rpt2+deb12u9), libc6-dev:arm64 (2.36-9+rpt2+deb12u8, 2.36-9+rpt2+deb12u9), systemd-sysv:arm64 (252.30-1~deb12u2, 252.31-1~deb12u1), libblkid1:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), curl:arm64 (7.88.1-10+deb12u7, 7.88.1-10+deb12u8), zlib1g:arm64 (1:1.2.13.dfsg-1, 1:1.2.13.dfsg-1+rpt1), libpixman-1-dev:arm64 (0.42.2-1+rpt1, 0.42.2-1+rpt3), bsdutils:arm64 (1:2.38.1-5+deb12u1, 1:2.38.1-5+deb12u2), raspberrypi-sys-mods:arm64 (20240911, 20241202), bsdextrautils:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), openssl:arm64 (3.0.14-1~deb12u2+rpt1, 3.0.15-1~deb12u1+rpt1), linux-libc-dev:arm64 (1:6.6.51-1+rpt3, 1:6.6.62-1+rpt1)
                Remove: linux-headers-6.6.31+rpt-rpi-v8:arm64 (1:6.6.31-1+rpt1), linux-image-6.6.31+rpt-rpi-2712:arm64 (1:6.6.31-1+rpt1), linux-headers-6.6.31+rpt-rpi-2712:arm64 (1:6.6.31-1+rpt1), linux-image-6.6.31+rpt-rpi-v8:arm64 (1:6.6.31-1+rpt1)
                End-Date: 2024-12-18  13:27:10
                Start-Date: 2024-12-18  16:16:46
                Commandline: apt autoremove
                Requested-By: pi (1000)
                Remove: linux-headers-6.6.47+rpt-common-rpi:arm64 (1:6.6.47-1+rpt1), linux-image-6.6.47+rpt-rpi-2712:arm64 (1:6.6.47-1+rpt1), linux-image-6.6.47+rpt-rpi-v8:arm64 (1:6.6.47-1+rpt1), linux-kbuild-6.6.31+rpt:arm64 (1:6.6.31-1+rpt1), linux-headers-6.6.47+rpt-rpi-v8:arm64 (1:6.6.47-1+rpt1), linux-kbuild-6.6.47+rpt:arm64 (1:6.6.47-1+rpt1), linux-headers-6.6.47+rpt-rpi-2712:arm64 (1:6.6.47-1+rpt1), linux-headers-6.6.31+rpt-common-rpi:arm64 (1:6.6.31-1+rpt1)
                End-Date: 2024-12-18  16:16:54
                Start-Date: 2024-12-18  16:36:03
                Commandline: apt-get install -yq --no-install-recommends -yqq distro-info
                Install: distro-info:arm64 (1.5+deb12u1)
                End-Date: 2024-12-18  16:36:05
                (END)
                • H hukio
                  (END)
                  @hukio
                  Da fehlt doch auch wieder was...
                    @hukio
                    hukio
                    zweiter Versuch
                    Start-Date: 2024-12-18  13:22:21
                    Commandline: apt full-upgrade
                    Install: linux-headers-6.6.62+rpt-rpi-v8:arm64 (1:6.6.62-1+rpt1, automatic), libdconf1:arm64 (0.40.0-4, automatic), dconf-cli:arm64 (0.40.0-4, automatic), linux-headers-6.6.62+rpt-rpi-2712:arm64 (1:6.6.62-1+rpt1, automatic), linux-kbuild-6.6.62+rpt:arm64 (1:6.6.62-1+rpt1, automatic), linux-image-6.6.62+rpt-rpi-v8:arm64 (1:6.6.62-1+rpt1, automatic), linux-headers-6.6.62+rpt-common-rpi:arm64 (1:6.6.62-1+rpt1, automatic), linux-image-6.6.62+rpt-rpi-2712:arm64 (1:6.6.62-1+rpt1, automatic)
                    Upgrade: libblkid-dev:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), libcurl4:arm64 (7.88.1-10+deb12u7, 7.88.1-10+deb12u8), initramfs-tools-core:arm64 (0.142+deb12u1, 0.142+rpt2+deb12u1), libglib2.0-dev-bin:arm64 (2.74.6-2+deb12u3, 2.74.6-2+deb12u4), libsmartcols1:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), udev:arm64 (252.30-1~deb12u2, 252.31-1~deb12u1), python3.11:arm64 (3.11.2-6+deb12u3, 3.11.2-6+deb12u4), libnghttp2-14:arm64 (1.52.0-1+deb12u1, 1.52.0-1+deb12u2), libcurl3-gnutls:arm64 (7.88.1-10+deb12u7, 7.88.1-10+deb12u8), iputils-ping:arm64 (3:20221126-1, 3:20221126-1+deb12u1), libmount-dev:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), rpicam-apps-lite:arm64 (1.5.2-2, 1.5.3-1), libglib2.0-bin:arm64 (2.74.6-2+deb12u3, 2.74.6-2+deb12u4), systemd-timesyncd:arm64 (252.30-1~deb12u2, 252.31-1~deb12u1), rpi-eeprom:arm64 (26.0-1, 26.7-1), tzdata:arm64 (2024a-0+deb12u1, 2024b-0+deb12u1), libntfs-3g89:arm64 (1:2022.10.3-1+b1, 1:2022.10.3-1+deb12u2), libglib2.0-dev:arm64 (2.74.6-2+deb12u3, 2.74.6-2+deb12u4), ntfs-3g:arm64 (1:2022.10.3-1+b1, 1:2022.10.3-1+deb12u2), userconf-pi:arm64 (0.9, 0.10), libpam-systemd:arm64 (252.30-1~deb12u2, 252.31-1~deb12u1), libarchive13:arm64 (3.6.2-1+deb12u1, 3.6.2-1+deb12u2), libheif1:arm64 (1.15.1-1, 1.15.1-1+deb12u1), raspi-config:arm64 (20240708, 20241210), linux-headers-rpi-v8:arm64 (1:6.6.51-1+rpt3, 1:6.6.62-1+rpt1), libpixman-1-0:arm64 (0.42.2-1+rpt1, 0.42.2-1+rpt3), libsystemd0:arm64 (252.30-1~deb12u2, 252.31-1~deb12u1), libmount1:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), grafana:arm64 (11.2.2, 11.4.0), libudev-dev:arm64 (252.30-1~deb12u2, 252.31-1~deb12u1), python3.11-venv:arm64 (3.11.2-6+deb12u3, 3.11.2-6+deb12u4), libpython3.11-minimal:arm64 (3.11.2-6+deb12u3, 3.11.2-6+deb12u4), zlib1g-dev:arm64 (1:1.2.13.dfsg-1, 1:1.2.13.dfsg-1+rpt1), linux-headers-rpi-2712:arm64 (1:6.6.51-1+rpt3, 1:6.6.62-1+rpt1), libcamera-ipa:arm64 (0.3.2+rpt20240927-1, 0.3.2+rpt20241119-1), linux-image-rpi-2712:arm64 (1:6.6.51-1+rpt3, 1:6.6.62-1+rpt1), libglib2.0-data:arm64 (2.74.6-2+deb12u3, 2.74.6-2+deb12u4), util-linux:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), util-linux-extra:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), systemd:arm64 (252.30-1~deb12u2, 252.31-1~deb12u1), libudev1:arm64 (252.30-1~deb12u2, 252.31-1~deb12u1), fdisk:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), libcamera0.3:arm64 (0.3.2+rpt20240927-1, 0.3.2+rpt20241119-1), libfdisk1:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), libdrm-common:arm64 (2.4.114-1, 2.4.123-1~bpo12+1+rpt1), eject:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), libc6:arm64 (2.36-9+rpt2+deb12u8, 2.36-9+rpt2+deb12u9), locales:arm64 (2.36-9+rpt2+deb12u8, 2.36-9+rpt2+deb12u9), libssl3:arm64 (3.0.14-1~deb12u2+rpt1, 3.0.15-1~deb12u1+rpt1), nodejs:arm64 (20.18.0-1nodesource1, 20.18.1-1nodesource1), libpython3.11:arm64 (3.11.2-6+deb12u3, 3.11.2-6+deb12u4), libuuid1:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), base-files:arm64 (12.4+deb12u7, 12.4+deb12u8), libnss3:arm64 (2:3.87.1-1, 2:3.87.1-1+deb12u1), raspi-firmware:arm64 (1:1.20240924-1, 1:1.20241126-1), libpython3.11-stdlib:arm64 (3.11.2-6+deb12u3, 3.11.2-6+deb12u4), libsqlite3-0:arm64 (3.40.1-2, 3.40.1-2+deb12u1), uuid-dev:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), distro-info-data:arm64 (0.58+deb12u2, 0.58+deb12u3), raspberrypi-net-mods:arm64 (1.4.1, 1.4.3), linux-image-rpi-v8:arm64 (1:6.6.51-1+rpt3, 1:6.6.62-1+rpt1), rfkill:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), libc-dev-bin:arm64 (2.36-9+rpt2+deb12u8, 2.36-9+rpt2+deb12u9), mount:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), libglib2.0-0:arm64 (2.74.6-2+deb12u3, 2.74.6-2+deb12u4), libc-l10n:arm64 (2.36-9+rpt2+deb12u8, 2.36-9+rpt2+deb12u9), python3.11-minimal:arm64 (3.11.2-6+deb12u3, 3.11.2-6+deb12u4), libdrm2:arm64 (2.4.114-1+b1, 2.4.123-1~bpo12+1+rpt1), libc-bin:arm64 (2.36-9+rpt2+deb12u8, 2.36-9+rpt2+deb12u9), libsystemd-shared:arm64 (252.30-1~deb12u2, 252.31-1~deb12u1), libc-devtools:arm64 (2.36-9+rpt2+deb12u8, 2.36-9+rpt2+deb12u9), initramfs-tools:arm64 (0.142+deb12u1, 0.142+rpt2+deb12u1), libc6-dbg:arm64 (2.36-9+rpt2+deb12u8, 2.36-9+rpt2+deb12u9), libc6-dev:arm64 (2.36-9+rpt2+deb12u8, 2.36-9+rpt2+deb12u9), systemd-sysv:arm64 (252.30-1~deb12u2, 252.31-1~deb12u1), libblkid1:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), curl:arm64 (7.88.1-10+deb12u7, 7.88.1-10+deb12u8), zlib1g:arm64 (1:1.2.13.dfsg-1, 1:1.2.13.dfsg-1+rpt1), libpixman-1-dev:arm64 (0.42.2-1+rpt1, 0.42.2-1+rpt3), bsdutils:arm64 (1:2.38.1-5+deb12u1, 1:2.38.1-5+deb12u2), raspberrypi-sys-mods:arm64 (20240911, 20241202), bsdextrautils:arm64 (2.38.1-5+deb12u1, 2.38.1-5+deb12u2), openssl:arm64 (3.0.14-1~deb12u2+rpt1, 3.0.15-1~deb12u1+rpt1), linux-libc-dev:arm64 (1:6.6.51-1+rpt3, 1:6.6.62-1+rpt1)
                    /var/log/apt/history.log (END)
                    • H hukio
                      zweiter Versuch
                      Das dürfte das Paket sein, wo es bei dir klemmt.
                      Was da aber genau bei dir ist kann ich dir nicht sagen.
                      Hier funktioniert alles auch mit dieser Version.
                      Insgesamt häufiger updaten, damit da nicht so eine lange Liste aufläuft.
                        hukio
                        kann ich da etwas machen?
                        • H hukio
                          @hukio
                          Installier neu und hau dein Backup rein.
                          Geht vermutlich am schnellsten von der Hand.
                            @hukio
                            hukio
                            OK DANKE für /deine Mühe
                            • H Offline
                              hukio
                              I tried to start iob with root privileges. This works:
                              iob start --allow-root
                              Is there a way to get back to normal user (iobroker)?
                              • H hukio
                                @hukio
                                Warum?
                                Der ioBroker läuft nicht als root!
                                Der wird rein mit user-Rechten angepackt!
                                • H hukio
                                  jetzt erst recht!
                                  @thomas-braun sagte in iob started nicht nach raspi os update:
                                  da ist anscheinend richtig was verbogen.
                                  Die Suche danach wird wesentlich länger dauern als eine Neuinstallation
                                    @hukio
                                    Warum?
                                    hukio
                                    wir haben doch versucht den iobroker zum Starten zu bringen, was nicht gelungen ist. Jetzt habe ich einfach mal mit --allow-root versucht und das system startet. Ich hoffe ich brauche nicht neu zu installieren.
                                    • H hukio
                                      Doch, würde ich dringend anraten.
                                      • H hukio
                                        @hukio jetzt hast du mit Dynamit die Haustür gesprengt.
                                        Dahinter ist aber noch alles beim alten
                                          hukio
                                          ja. Es wäre schön, wenn ich wieder normal starten könnte.
