    6.3k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.4m Aufrufe 260 Beobachtet
  • L ltreff
    @armilar Rule2 ist aus dem Skript:
    Rule2 on Button1#state do Publish %topic%/tele/RESULT {"CustomRecv":"event,button1"} endon on Button2#state do Publish %topic%/tele/RESULT {"CustomRecv":"event,button2"} endon
    Tasten-Config im Skript:
    button1: {
    // DE: Mögliche Werte wenn Rule2 definiert: 'page', 'toggle', 'set' - Wenn nicht definiert --> mode: null
    // EN: Possible values if Rule2 defined: 'page', 'toggle', 'set' - If not defined --> mode: null
    mode: 'toggle',
    // DE: Zielpage - Verwendet wenn mode = page
    // EN: Target page - Used if mode = page
    page: null,
    // DE: Zielentity - Verwendet wenn mode = set oder toggle
    // EN: Target entity - Used if mode = set or toggle
    entity: AliasPath + 'Config.Screensaver.alternativeScreensaverLayout.SET',
    // DE: Zielwert - Verwendet wenn mode = set
    // EN: Target value - Used if mode = set
    setValue: true
    // DE: Konfiguration des rechten Schalters des NSPanels
    // EN: Configuration of the right switch of the NSPanel
    button2: {
        mode: 'toggle',
        page: null,
        entity: AliasPath + 'Config.Screensaver.ScreensaverAdvanced.SET',
        setValue: null
    /***** 1. Tasmota-Config *****/
    // DE: Anpassen an die Verzeichnisse der MQTT-Adapter-Instanz
    // EN: Adapt to the MQTT adapter instance directories
    const NSPanelReceiveTopic: string = 'mqtt.0.MyHome.NSPanel1.tele.RESULT';
    const NSPanelSendTopic: string = 'mqtt.0.MyHome.NSPanel1.cmnd.CustomSend';
    TT-Tom
    #6637
    @ltreff
    Also doch die Rule2 falsch, die muss den selben Topic haben wie dein Tasmota Topic. Da fehlt dein Myhome.
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    • L ltreff
      button1: {
      mode: 'toggle',
      page: null,
      setValue: true
      button2: {
          mode: 'toggle',
          page: null,
          setValue: null
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      #6638
      @ltreff
      Rule2 on Button1#state do Publish MyHome/%topic%/tele/RESULT {"CustomRecv":"event,button1"} endon on Button2#state do Publish MyHome/%topic%/tele/RESULT {"CustomRecv":"event,button2"} endon
      Rule2 1
      L 1 Antwort Letzte Antwort
      • ArmilarA Armilar
        @ltreff
        Rule2 1
        ltreff
        #6639
        @armilar Das klappt jetzt.
        Der Wechsel der Anzeige ist auch noch vom Wert 0_userdata.0.NSPanel.1.Config.Screensaver.timeoutScreensaver abhängig.
        Vielen Dank, ich beende dann diesen Topic.
        • K Kuckuckmann
          @losossos & @tomsport2022
          Ich habe das Thema die Tage mit Armilar diskutiert und wir haben es auf der Roadmap auf dem Screensaver neben den Wetter-Daten und dem Wetter-Forcast noch weitere - ich nenne es mal "Reihen" - einzuführen, die man dann individuell belegen kann. Wir denken auch darüber nach, dann x zusätzliche dynamisch verwendbare "Reihen" hinzuzufügen.
          Dafür müssen wir aber an der jetzigen Logik ein wenig arbeiten.
          Ich kann noch nicht sagen, wann genau wir diese Ergänzung haben werden, nur so viel, es steht auf dem ToDo Zettel :-)
          @losossos Du kannst das XML vom Blockly (Export Button nutzen) hier als Spoiler rein packen, dann kann man es sich ziehen und importieren. Wärst Du so nett es zu posten?
          Dein Ansatz klingt durchaus interessant.
          losossos
          #6640
          @kuckuckmann
          Mahlzeit, ist schon 'ne Weile her seit meinem letztem post.
          Ich habe eine Frage zur Aktualisierung bzw. Aktivierung des Screensavers;
          Wie gesagt, ich hab lange nichts mehr an den Panels "gemacht". Alles lief prima und das Motto ist ja beakanntlicher Weise "never touch a running...."
          Nun habe ich aber doch mal wieder etwas angepasst/hinzugefügt und dabei dann auch das Skript von v 4.3.1 auf aktuell hochgezogen. Soweit läuft alles. Allerdings ist es jetzt so, daß mein Wetterscreensaver (accuweather) nicht mehr (automatisch) aktiviert wird wenn ich zuvor ne popup-nachricht 0_userdata.0.NSPanel.2.ScreensaverInfo.popupNotifyHeading und 0_userdata.0.NSPanel.2.ScreensaverInfo.popupNotifyText ausgegeben habe. Zuvor war es so, daß nach einem timeout der Wetter screensaver automatisch wieder aktiviert wurde. Jetzt klappt das nur noch wenn ich das Display kurz "antatsche".
          (ich zeige in bestimmten Abständen diverse "news" über diese Infozeilen an)
          An welcher "Schraube müßte ich denn drehen" ums wieder so hinzubekommen wie's zuvor war?
          • L losossos
            @kuckuckmann
            TT-Tom
            #6641
            @losossos
            Ja da hat sich in der Zeit einiges geändert. Hier kannst du alles nachlesen.
            https://github.com/joBr99/nspanel-lovelace-ui/wiki/Changelog
            https://github.com/joBr99/nspanel-lovelace-ui/wiki/Release-Notes
            und hier die Lösung für dein Problem
            https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Config-Screensaver#popupnotify-im-screensaver
            Gruß Tom
            Public Transport
            • T TT-Tom
              @losossos
              losossos
              #6642
              @tt-tom said in SONOFF NSPanel mit Lovelace UI:
              Oh, ja da hat sich ne ganze Menge getan! Gute Arbeit 👍 😊
              Supi, klar , hätt natürlich auch alles nachlesen können, aber so geht's natürlich viiiiiel schneller.
              1000-Dank und schöne 🎅 🎄
                Kerschte_de
                schrieb am zuletzt editiert von Kerschte_de
                #6643
                Guten Abend zusammen.
                Mein Test-NSPanel hatte ich mit Eurer Unterstützung zum Funktionieren bekommen. Die Kommunikation zwischen Panel und ioB lief.
                Inzwischen habe ich meine beiden ioB-Instanzen zu einer neuen und einzigen ioB-Instanz neu aufgesetzt (jetzt kein Raspi mehr, sondern in miniPC (Proxmox). Entsprechend habe ich versucht, auch das Panel umzuziehen. Geflasht und eingerichtet war es ja bereits, also habe ich lediglich auf NSPanel-Tasmota die neue IPv4 hinterlegt. Meinen extern geführten MQTT-Broker habe ich entsprechend der Empfehlung auf einen neuen Port umgestellt ... und ebenfalls im Tasmota des NSPanels aktualisiert.
                Die Ojektzeile "mqtt.0.RagowSmartHome.NSPanel_85C180.cmnd.CustomSend" habe ich über einen MQTT-Explorer angelegt. Das hatte funktioniert. Jedoch fiel mir dabei auf, dass ich nicht aus der Konsole des NSPanels heraus einen Befehl übermitteln konnte.
                Inzwischen kommuniziert die Wetter-App mit dem Screensaver auf dem NSP. Auch Seiten kann ich im TS-Script des ioB anlegen. TS-Script habe ich auf der neuesten Version. Leider werden aber keine darin verknüpften Werte übertragen. Ich habe alles probiert, was ich mir von Euch dazu anlesen konnte. Ich bekomme es jedoch nicht wieder hin.
                Meine Vermutung ist, dass es irgendwie mit dem Abo auf die beiden mqtt-Datenpunkte nicht ganz klappt (CustomSend und stat.RESULT). Dazu kenne ich aber auch nicht die Funktionsweise des Panels, was worüber kommuniziert wird. Wie erwähnt, Wetter im Screensaver und eigene Seitenstrukturen gehen, aber keine Werte/Datenpunkte. Kann mich bitte jemand begleiten, den Fehler bei mir systematisch einzugrenzen?
                • K Kerschte_de
                  TT-Tom
                  #6644
                  @kerschte_de
                  Setze das Script bitte in den Debug-Modus und starte es neu, dann poste das Log vom Start des Script bis zum erscheinen des Screensaver.
                  Debugmodus im Panel unter Einstellung -> Script -> Debug Modus(an/aus)
                  oder im Script unter
                  // DE: liefert bei true detailliertere Meldundgen im Log.
                  // EN: if true, provides more detailed messages in the log.
                  var Debug: boolean = true;
                  Gruß Tom
                  Public Transport
                  • T TT-Tom
                    @kerschte_de
                    Kerschte_de
                    #6645
                    @tt-tom
                    Hallo Tom. Vielen Dank, dass Du Dich der Sache so schnell annimmst. Ich bin gerade auch nochmal das Video von Matthias durchgegangen, ob ich irgendwas entdecke ... habe einige Datenpunkte auch nochmal exakt nach seinem Video angelegt und dann im Script hinterlegt. Leider weiter ohne Erfolg.
                    14.12.2024, 18:20:28.125	[info ]: javascript.0 (363) Compiling TypeScript source script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT
                    14.12.2024, 18:20:28.391	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: source code did not change, using cached compilation result...
                    14.12.2024, 18:20:28.456	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    14.12.2024, 18:20:28.459	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: setObjects enabled - create Alias Channels possible
                    14.12.2024, 18:20:28.460	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: weather alias for accuweather.0. already exists
                    14.12.2024, 18:20:28.464	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    14.12.2024, 18:20:28.502	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Desired TFT Firmware: 53 / v4.4.0
                    14.12.2024, 18:20:28.502	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Installed TFT Firmware: 53 / v4.4.0
                    14.12.2024, 18:20:28.720	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Debug mode activated
                    14.12.2024, 18:20:28.788	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Tasmota Buzzer disabled
                    14.12.2024, 18:20:28.800	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: NaN W
                    14.12.2024, 18:20:28.801	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: get_current_tasmota_ip_address: 192.168.188.240
                    14.12.2024, 18:20:28.809	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting tasmota firmware version
                    14.12.2024, 18:20:28.810	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting current berry driver version
                    14.12.2024, 18:20:28.811	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: get_current_tasmota_ip_address: 192.168.188.240
                    14.12.2024, 18:20:28.811	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online berry driver version
                    14.12.2024, 18:20:28.811	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online TFT version
                    14.12.2024, 18:20:28.813	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online firmware version
                    14.12.2024, 18:20:28.828	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: import adbase as ad
                    from luibackend.config import LuiBackendConfig
                    from luibackend.controller import LuiController
                    from luibackend.mqtt import LuiMqttListener, LuiMqttSender
                    from luibackend.updater import Updater
                    import apis
                    import json
                    from typing import Literal
                    class NsPanelLovelaceUIManager(ad.ADBase):
                        def initialize(self):
                            self.adapi = self.get_ad_api()
                            self.adapi.log('Starting')
                            apis.ad_api = self.adapi
                            apis.ha_api   = self.get_plugin_api("HASS")
                            apis.mqtt_api = self.get_plugin_api("MQTT")
                            cfg = self._cfg = LuiBackendConfig(apis.ha_api, self.args["config"])
                            use_api = cfg.get("use_api") == True
                            topic_send = cfg.get("panelSendTopic")
                            topic_recv = cfg.get("panelRecvTopic")
                            api_panel_name = cfg.get("panelName")
                            api_device_id = cfg.get("panelDeviceId")
                            quiet = cfg.get("quiet")
                            mqttsender = self._mqttsender = LuiMqttSender(apis.ha_api, use_api, topic_send, api_panel_name, quiet)
                            self._controller = LuiController(cfg, mqttsender.send_mqtt_msg)
                            desired_tasmota_driver_version   = 8
                            desired_display_firmware_version = 53
                            version     = "v4.3.3"
                            model       = cfg.get("model")
                            if model == "us-l":
                                desired_display_firmware_url = cfg._config.get("displayURL-US-L", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-l-{version}.tft")
                            elif model == "us-p":
                                desired_display_firmware_url = cfg._config.get("displayURL-US-P", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-p-{version}.tft")
                            else:
                                desired_display_firmware_url = cfg._config.get("displayURL-EU",   f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-{version}.tft")
                            desired_tasmota_driver_url       = cfg._config.get("berryURL",         "https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be")
                            mode = cfg.get("updateMode")
                            updater = Updater(self.adapi.log, mqttsender, topic_send, mode, desired_display_firmware_version, model, desired_display_firmware_url, desired_tasmota_driver_version, desired_tasmota_driver_url)
                            # Request Tasmota Driver Version
                            updater.request_berry_driver_version()
                            LuiMqttListener(use_api, topic_recv, api_panel_name, api_device_id, self._controller, updater)
                            self.adapi.log(f'Started ({version})')
                        # helpers
                        def show_card(self, card_key: str) -> None:
                            """Used to show card on panel"""
                            msg = json.dumps({"CustomRecv":f"event,buttonPress2,navigate.{card_key},button"})
                            topic = self._cfg.get("panelRecvTopic")
                            self._mqttsender.send_mqtt_msg(msg, topic)
                        def navigate(self, direction: Literal['up', 'prev', 'next']) -> None:
                            """Used to navigate different directions on the panel"""
                            msg = json.dumps({"CustomRecv":f"event,buttonPress2,nav{direction.title()},button"})
                        @property
                        def current_card(self) -> str:
                            """Used to get the panel's current card"""
                            return self._controller.current_card.key
                    14.12.2024, 18:20:28.832	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: # Sonoff NSPanel Tasmota Lovelace UI Berry Driver (Extended Flashing to faster speeds; improved Error Handling)| code by joBr99
                    # based on;
                    # Sonoff NSPanel Tasmota (Nextion with Flashing) driver | code by peepshow-21
                    # based on;
                    # Sonoff NSPanel Tasmota driver v0.47 | code by blakadder and s-hadinger
                    # Example Flash
                    # FlashNextion http://ip-address-of-your-homeassistant:8123/local/nspanel.tft
                    # FlashNextion http://nspanel.pky.eu/lui.tft
                    class Nextion : Driver
                        static header = bytes('55BB')
                        static flash_block_size = 4096
                        var flash_mode
                        var flash_start_millis
                        var flash_size
                        var flash_written
                        var flash_buff
                        var flash_offset
                        var flash_proto_version
                        var flash_proto_baud
                        var awaiting_offset
                        var tcp
                        var ser
                        var last_per
                        var url
                        def split_55(b)
                          var ret = []
                          var s = size(b)
                          var i = s-2   # start from last-1
                          while i > 0
                            if b[i] == 0x55 && b[i+1] == 0xBB
                              ret.push(b[i..s-1]) # push last msg to list
                              b = b[(0..i-1)]   # write the rest back to b
                            end
                            i -= 1
                          end
                          ret.push(b)
                          return ret
                        end
                        def crc16(data, poly)
                          if !poly  poly = 0xA001 end
                          # CRC-16 MODBUS HASHING ALGORITHM
                          var crc = 0xFFFF
                          for i:0..size(data)-1
                            crc = crc ^ data[i]
                            for j:0..7
                              if crc & 1
                                crc = (crc >> 1) ^ poly
                              else
                                crc = crc >> 1
                              end
                            end
                          end
                          return crc
                        end
                        # encode using custom protocol 55 BB [payload length] [payload length] [payload] [crc] [crc]
                        def encode(payload)
                          var b = bytes()
                          b += self.header
                          b.add(size(payload), 2)   # add size as 2 bytes, little endian
                          b += bytes().fromstring(payload)
                          var msg_crc = self.crc16(b)
                          b.add(msg_crc, 2)       # crc 2 bytes, little endian
                          return b
                        end
                        def encodenx(payload)
                            var b = bytes().fromstring(payload)
                            b += bytes('FFFFFF')
                            return b
                        end
                        def sendnx(payload)
                            import string
                            var payload_bin = self.encodenx(payload)
                            self.ser.write(payload_bin)
                            log(string.format("NXP: Nextion command sent = %s",str(payload_bin)), 3)
                        end
                        def send(payload)
                            var payload_bin = self.encode(payload)
                            if self.flash_mode==1
                                log("NXP: skipped command becuase still flashing", 3)
                            else
                                log("NXP: payload sent = " + str(payload_bin), 3)
                            end
                        end
                        def write_to_nextion(b)
                            self.ser.write(b)
                        end
                        def screeninit()
                            log("NXP: Screen Initialized")
                            self.sendnx("recmod=1")
                        end
                        def write_block()
                            import string
                            log("FLH: Read block",3)
                            while size(self.flash_buff)<self.flash_block_size && self.tcp.connected()
                                if self.tcp.available()>0
                                    self.flash_buff += self.tcp.readbytes(4096)
                                else
                                    tasmota.delay(50)
                                    log("FLH: Wait for available...",3)
                                end
                            end
                            log("FLH: Buff size "+str(size(self.flash_buff)),3)
                            var to_write
                            if size(self.flash_buff)>self.flash_block_size
                                to_write = self.flash_buff[0..self.flash_block_size-1]
                                self.flash_buff = self.flash_buff[self.flash_block_size..]
                            else
                                self.flash_buff = bytes()
                            end
                            log("FLH: Writing "+str(size(to_write)),3)
                            var per = (self.flash_written*100)/self.flash_size
                            if (self.last_per!=per)
                                self.last_per = per
                                tasmota.publish_result(string.format("{\"Flashing\":{\"complete\": %d, \"time_elapsed\": %d}}",per , (tasmota.millis()-self.flash_start_millis)/1000), "RESULT")
                            end
                            if size(to_write)>0
                                self.flash_written += size(to_write)
                                self.ser.write(to_write)
                            end
                            log("FLH: Total "+str(self.flash_written),3)
                            if (self.flash_written==self.flash_size)
                                log("FLH: Flashing complete - Time elapsed: %d", (tasmota.millis()-self.flash_start_millis)/1000)
                                self.flash_mode = 0
                                self.ser.deinit()
                                self.ser = serial(17, 16, 115200, serial.SERIAL_8N1)
                            end
                        end
                        def every_100ms()
                            import string
                            if self.ser.available() > 0
                                var msg = self.ser.read()
                                if size(msg) > 0
                                    log(string.format("NXP: Received Raw = %s",str(msg)), 3)
                                    if (self.flash_mode==1)
                                        var strv = msg[0..-4].asstring()
                                        if string.find(strv,"comok 2")>=0
                                            tasmota.delay(50)
                                            log("FLH: Send (High Speed) flash start")
                                            self.flash_start_millis = tasmota.millis()
                                            #self.sendnx(string.format("whmi-wris %d,115200,res0",self.flash_size))
                                            if self.flash_proto_version == 0
                                                self.sendnx(string.format("whmi-wri %d,%d,res0",self.flash_size,self.flash_proto_baud))
                                            else
                                                self.sendnx(string.format("whmi-wris %d,%d,res0",self.flash_size,self.flash_proto_baud))
                                            end
                                            if self.flash_proto_baud != 115200
                                                tasmota.delay(50)
                                                self.ser.deinit()
                                                self.ser = serial(17, 16, self.flash_proto_baud, serial.SERIAL_8N1)
                                            end
                                        elif size(msg)==1 && msg[0]==0x08
                                            log("FLH: Waiting offset...",3)
                                            self.awaiting_offset = 1
                                        elif size(msg)==4 && self.awaiting_offset==1
                                            self.awaiting_offset = 0
                                            self.flash_offset = msg.get(0,4)
                                            log("FLH: Flash offset marker "+str(self.flash_offset),3)
                                            if self.flash_offset != 0
                                                self.open_url_at(self.url, self.flash_offset)
                                                self.flash_written = self.flash_offset
                                            end
                                            self.write_block()
                                        elif size(msg)==1 && msg[0]==0x05
                                            self.write_block()
                                        else
                                            log("FLH: Something has gone wrong flashing display firmware ["+str(msg)+"]",2)
                                        end
                                    else
                                        var msg_list = self.split_55(msg)
                                        for i:0..size(msg_list)-1
                                            msg = msg_list[i]
                                            if size(msg) > 0
                                                if msg == bytes('000000FFFFFF88FFFFFF')
                                                    self.screeninit()
                                                elif size(msg)>=2 && msg[0]==0x55 && msg[1]==0xBB
                                                    var jm = string.format("{\"CustomRecv\":\"%s\"}",msg[4..-3].asstring())
                                                    tasmota.publish_result(jm, "RESULT")
                                                elif msg[0]==0x07 && size(msg)==1 # BELL/Buzzer
                                                    tasmota.cmd("buzzer 1,1")
                                                else
                                                    var jm = string.format("{\"nextion\":\"%s\"}",str(msg[0..-4]))
                                                end
                                            end
                                        end
                                    end
                                end
                            end
                        end
                        def begin_nextion_flash()
                            self.flash_written = 0
                            self.flash_offset = 0
                            self.sendnx('DRAKJHSUYDGBNCJHGJKSHBDN')
                            self.sendnx('recmod=0')
                            self.flash_mode = 1
                            self.sendnx("connect")
                        end
                        def open_url_at(url, pos)
                            self.url = url
                            import string
                            var host
                            var port
                            var s1 = string.split(url,7)[1]
                            var i = string.find(s1,":")
                            var sa
                            if i<0
                                port = 80
                                i = string.find(s1,"/")
                                sa = string.split(s1,i)
                                host = sa[0]
                            else
                                host = sa[0]
                                s1 = string.split(sa[1],1)[1]
                                port = int(sa[0])
                            end
                            var get = sa[1]
                            log(string.format("FLH: host: %s, port: %s, get: %s",host,port,get))
                            self.tcp = tcpclient()
                            self.tcp.connect(host,port)
                            log("FLH: Connected:"+str(self.tcp.connected()),3)
                            var get_req = "GET "+get+" HTTP/1.0\r\n"
                            get_req += string.format("Range: bytes=%d-\r\n", pos)
                            get_req += string.format("HOST: %s:%s\r\n\r\n",host,port)
                            self.tcp.write(get_req)
                            var a = self.tcp.available()
                            i = 1
                            while a==0 && i<5
                              tasmota.delay(100*i)
                              tasmota.yield()
                              i += 1
                              log("FLH: Retry "+str(i),3)
                            end
                            if a==0
                                log("FLH: Nothing available to read!",3)
                                return
                            end
                            var b = self.tcp.readbytes()
                            i = 0
                            var end_headers = false;
                            var headers
                            while i<size(b) && headers==nil
                                if b[i..(i+3)]==bytes().fromstring("\r\n\r\n")
                                    headers = b[0..(i+3)].asstring()
                                    self.flash_buff = b[(i+4)..]
                                else
                                    i += 1
                                end
                            end
                            #print(headers)
                            # check http respose for code 200/206
                            if string.find(headers,"200 OK")>0 || string.find(headers,"206 Partial Content")>0
                                log("FLH: HTTP Respose is 200 OK or 206 Partial Content",3)
                            else
                                log("FLH: HTTP Respose is not 200 OK or 206 Partial Content",3)
                                print(headers)
                                return -1
                            end
                            # only set flash size if pos is zero
                            if pos == 0
                                # check http respose for content-length
                                var tag = "Content-Length: "
                                i = string.find(headers,tag)
                                if (i>0)
                                    var i2 = string.find(headers,"\r\n",i)
                                    var s = headers[i+size(tag)..i2-1]
                                    self.flash_size=int(s)
                                end
                                log("FLH: Flash file size: "+str(self.flash_size),3)
                            end
                        end
                        def flash_nextion(url)
                            self.flash_size = 0
                            var res = self.open_url_at(url, 0)
                            if res != -1
                                self.begin_nextion_flash()
                            end
                        end
                        def init()
                            log("NXP: Initializing Driver")
                            self.flash_mode = 0
                            self.flash_proto_version = 1
                            self.flash_proto_baud = 921600
                        end
                    end
                    var nextion = Nextion()
                    tasmota.add_driver(nextion)
                    def get_current_version(cmd, idx, payload, payload_json)
                        import string
                        var version_of_this_script = 9
                        var jm = string.format("{\"nlui_driver_version\":\"%s\"}", version_of_this_script)
                    end
                    tasmota.add_cmd('GetDriverVersion', get_current_version)
                    def update_berry_driver(cmd, idx, payload, payload_json)
                        def task()
                            import path
                            import string
                    		if string.find(payload, ".tapp") > 0
                    		    print("tapp in URL; will do .tapp update and migration if necessary")
                    			if path.exists("autoexec.be")
                    			    print("autoexec.be found; will check for migration")
                    				var autoexecfile = open('autoexec.be')
                    				var line = autoexecfile.readline()
                    				autoexecfile.close()
                    				if string.find(line, "NSPanel Tasmota Lovelace UI Berry Driver") > 0
                    			        print("found lovelace berry driver, going to delete autoexec.be and .bec")
                    					path.remove("autoexec.be")
                    					path.remove("autoexec.bec")
                    				end
                    			end
                    			var r = tasmota.urlfetch(payload, "nsp-lovelace-driver.tapp")
                                if r < 0
                                    print("Update failed")
                                else
                                    tasmota.cmd("Restart 1")
                                end
                    		elif string.find(payload, ".be") > 0
                    		    print("be in URL; will do .be update")
                    			if path.exists("nsp-lovelace-driver.tapp")
                    			    print("Error: there is the tapp version of the berry driver installed; cannot do .be update.")
                    			else
                                    var cl = webclient()
                                    cl.begin(payload)
                                    var r = cl.GET()
                                    if r == 200
                                        print("Sucessfully downloaded nspanel-lovelace-ui berry driver")
                                    else
                                        print("Error while downloading nspanel-lovelace-ui berry driver")
                                    end
                                    r = cl.write_file("autoexec.be")
                                    if r < 0
                                        print("Error while writeing nspanel-lovelace-ui berry driver")
                                    else
                                        print("Sucessfully written nspanel-lovelace-ui berry driver")
                                    end
                    			end
                    		else
                    			print("invalid url filetype")
                    		end
                                var r = string.find(payload, ".tapp")
                                if r < 0
                                    print("URL doesn't contain .tapp skipping update")
                                else
                                end
                            else
                                var r = string.find(payload, ".be")
                                if r < 0
                                    print("URL doesn't contain .be skipping update")
                                else
                                end
                            end
                        end
                        tasmota.set_timer(0,task)
                        tasmota.resp_cmnd_done()
                    end
                    tasmota.add_cmd('UpdateDriverVersion', update_berry_driver)
                    def flash_nextion(cmd, idx, payload, payload_json)
                        def task()
                        nextion.flash_proto_version = 1
                        nextion.flash_proto_baud = 921600
                            nextion.flash_nextion(payload)
                        end
                    end
                    def flash_nextion_adv(cmd, idx, payload, payload_json)
                        def task()
                            if idx==0
                            elif idx==1
                                nextion.flash_proto_version = 0
                            elif idx==2
                                nextion.flash_proto_baud = 115200
                            elif idx==3
                            elif idx==4
                                nextion.flash_proto_baud = 256000
                            elif idx==5
                            elif idx==6
                                nextion.ser.deinit()
                                nextion.ser = serial(17, 16, 9600, serial.SERIAL_8N1)
                            else
                            end
                        end
                    end
                    def send_cmd(cmd, idx, payload, payload_json)
                        nextion.sendnx(payload)
                    end
                    def send_cmd2(cmd, idx, payload, payload_json)
                        nextion.send(payload)
                    end
                    tasmota.add_cmd('Nextion', send_cmd)
                    tasmota.add_cmd('CustomSend', send_cmd2)
                    tasmota.add_cmd('FlashNextion', flash_nextion)
                    tasmota.add_cmd('FlashNextionAdv', flash_nextion_adv)
                    14.12.2024, 18:20:28.835	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online display firmware version => 53
                    14.12.2024, 18:20:28.852	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: {"nlui_driver_version":"9"}
                    14.12.2024, 18:20:28.855	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: current tasmota firmware version => 14.3.0
                    14.12.2024, 18:20:28.855	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online berry driver version => 9
                    14.12.2024, 18:20:28.882	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: current berry driver version => 9
                    14.12.2024, 18:20:28.926	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: hidden Cards disabled
                    K T 4 Antworten Letzte Antwort
                    • K Kerschte_de
                      @tt-tom
                      import apis
                      import json
                              version     = "v4.3.3"
                              if model == "us-l":
                              else:
                          # helpers
                          @property
                      # based on;
                      # based on;
                      # Example Flash
                          var flash_mode
                          var flash_size
                          var flash_written
                          var flash_buff
                          var flash_offset
                          var awaiting_offset
                          var tcp
                          var ser
                          var last_per
                          var url
                          def split_55(b)
                            var ret = []
                            var s = size(b)
                            while i > 0
                              end
                              i -= 1
                            end
                            ret.push(b)
                            return ret
                          end
                            var crc = 0xFFFF
                              crc = crc ^ data[i]
                              for j:0..7
                                if crc & 1
                                else
                                  crc = crc >> 1
                                end
                              end
                            end
                            return crc
                          end
                          def encode(payload)
                            var b = bytes()
                            b += self.header
                            return b
                          end
                              return b
                          end
                          def sendnx(payload)
                              import string
                          end
                          def send(payload)
                              else
                              end
                          end
                              self.ser.write(b)
                          end
                          def screeninit()
                          end
                          def write_block()
                              import string
                                  else
                                      tasmota.delay(50)
                                  end
                              end
                              var to_write
                              else
                              end
                                  self.last_per = per
                              end
                              if size(to_write)>0
                              end
                                  self.flash_mode = 0
                                  self.ser.deinit()
                              end
                          end
                          def every_100ms()
                              import string
                                  if size(msg) > 0
                                              tasmota.delay(50)
                                              else
                                              end
                                                  tasmota.delay(50)
                                                  self.ser.deinit()
                                              end
                                              end
                                              self.write_block()
                                              self.write_block()
                                          else
                                          end
                                      else
                                              msg = msg_list[i]
                                              if size(msg) > 0
                                                      self.screeninit()
                                                  else
                                                  end
                                              end
                                          end
                                      end
                                  end
                              end
                          end
                              self.flash_mode = 1
                          end
                              self.url = url
                              import string
                              var host
                              var port
                              var sa
                              if i<0
                                  port = 80
                                  host = sa[0]
                              else
                                  host = sa[0]
                                  port = int(sa[0])
                              end
                              var get = sa[1]
                              i = 1
                              while a==0 && i<5
                                tasmota.yield()
                                i += 1
                              end
                              if a==0
                                  return
                              end
                              i = 0
                              var headers
                                  else
                                      i += 1
                                  end
                              end
                              #print(headers)
                              else
                                  print(headers)
                                  return -1
                              end
                              if pos == 0
                                  if (i>0)
                                  end
                              end
                          end
                              self.flash_size = 0
                              if res != -1
                              end
                          end
                          def init()
                              self.flash_mode = 0
                          end
                      end
                          import string
                      end
                          def task()
                              import path
                              import string
                      				end
                      			end
                                  if r < 0
                                  else
                                  end
                      			else
                                      cl.begin(payload)
                                      var r = cl.GET()
                                      if r == 200
                                      else
                                      end
                                      if r < 0
                                      else
                                      end
                      			end
                      		else
                      		end
                                  if r < 0
                                  else
                                  end
                              else
                                  if r < 0
                                  else
                                  end
                              end
                          end
                      end
                          def task()
                          end
                      end
                          def task()
                              if idx==0
                              elif idx==1
                              elif idx==2
                              elif idx==3
                              elif idx==4
                              elif idx==5
                              elif idx==6
                              else
                              end
                          end
                      end
                      end
                      end
                      Kerschte_de
                      #6646
                      @kerschte_de
                      14.12.2024, 18:20:29.007	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: {"url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/releases/149090497","assets_url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/releases/149090497/assets","upload_url":"https://uploads.github.com/repos/joBr99/nspanel-lovelace-ui/releases/149090497/assets{?name,label}","html_url":"https://github.com/joBr99/nspanel-lovelace-ui/releases/tag/v4.4.0","id":149090497,"author":{"login":"joBr99","id":29555657,"node_id":"MDQ6VXNlcjI5NTU1NjU3","avatar_url":"https://avatars.githubusercontent.com/u/29555657?v=4","gravatar_id":"","url":"https://api.github.com/users/joBr99","html_url":"https://github.com/joBr99","followers_url":"https://api.github.com/users/joBr99/followers","following_url":"https://api.github.com/users/joBr99/following{/other_user}","gists_url":"https://api.github.com/users/joBr99/gists{/gist_id}","starred_url":"https://api.github.com/users/joBr99/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/joBr99/subscriptions","organizations_url":"https://api.github.com/users/joBr99/orgs","repos_url":"https://api.github.com/users/joBr99/repos","events_url":"https://api.github.com/users/joBr99/events{/privacy}","received_events_url":"https://api.github.com/users/joBr99/received_events","type":"User","user_view_type":"public","site_admin":false},"node_id":"RE_kwDOGo1zRM4I4vDB","tag_name":"v4.4.0","target_commitish":"main","name":"v4.4.0 - Update for HA 2024.04","draft":false,"prerelease":false,"created_at":"2024-03-30T11:18:31Z","published_at":"2024-03-30T12:26:37Z","assets":[],"tarball_url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/tarball/v4.4.0","zipball_url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/zipball/v4.4.0","body":"## Besides the Update of the App in HACS you need to do the following things:\r\n\r\n🔄 **Restart the AppDaemon Container**\r\n\r\n**Add the following workaround to your Home Assistant configuration.yaml**\r\n\r\nhttps://docs.nspanel.pky.eu/stable/prepare_ha/#workaround-for-homeassistant-202404\r\n\r\n🔄 **Restart Home Assistant**\r\n\r\n## New Features:\r\n\r\n- **Implemented changes to work with upcoming Homeassistant Version 2024.04 @joBr99**\r\n","mentions_count":1}
                      14.12.2024, 18:20:29.052	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online TFT firmware version => 4.4.0
                      14.12.2024, 18:20:29.083	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: {"url":"https://api.github.com/repos/arendst/Tasmota/releases/190153880","assets_url":"https://api.github.com/repos/arendst/Tasmota/releases/190153880/assets","upload_url":"https://uploads.github.com/repos/arendst/Tasmota/releases/190153880/assets{?name,label}","html_url":"https://github.com/arendst/Tasmota/releases/tag/v14.4.0","id":190153880,"author":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"node_id":"RE_kwDOBMkSUM4LVYSY","tag_name":"v14.4.0","target_commitish":"master","name":"Tasmota v14.4.0 Rudolph","draft":false,"prerelease":false,"created_at":"2024-12-11T09:17:21Z","published_at":"2024-12-11T09:35:47Z","assets":[{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594561","id":212594561,"node_id":"RA_kwDOBMkSUM4Mq--B","name":"map_all.zip","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/zip","state":"uploaded","size":50218975,"download_count":20,"created_at":"2024-12-11T09:35:49Z","updated_at":"2024-12-11T09:35:50Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/map_all.zip"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594403","id":212594403,"node_id":"RA_kwDOBMkSUM4Mq-7j","name":"tasmota-4M.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":739968,"download_count":41,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-4M.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594404","id":212594404,"node_id":"RA_kwDOBMkSUM4Mq-7k","name":"tasmota-4M.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":518013,"download_count":42,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-4M.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594417","id":212594417,"node_id":"RA_kwDOBMkSUM4Mq-7x","name":"tasmota-AD.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669280,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-AD.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594409","id":212594409,"node_id":"RA_kwDOBMkSUM4Mq-7p","name":"tasmota-AD.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469581,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-AD.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594407","id":212594407,"node_id":"RA_kwDOBMkSUM4Mq-7n","name":"tasmota-AF.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":668704,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-AF.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594405","id":212594405,"node_id":"RA_kwDOBMkSUM4Mq-7l","name":"tasmota-AF.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469296,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-AF.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594412","id":212594412,"node_id":"RA_kwDOBMkSUM4Mq-7s","name":"tasmota-BG.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":674672,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-BG.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594421","id":212594421,"node_id":"RA_kwDOBMkSUM4Mq-71","name":"tasmota-BG.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":470721,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-BG.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594406","id":212594406,"node_id":"RA_kwDOBMkSUM4Mq-7m","name":"tasmota-BR.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669520,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-BR.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594411","id":212594411,"node_id":"RA_kwDOBMkSUM4Mq-7r","name":"tasmota-BR.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469616,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-BR.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594410","id":212594410,"node_id":"RA_kwDOBMkSUM4Mq-7q","name":"tasmota-CN.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":668096,"download_count":37,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-CN.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594415","id":212594415,"node_id":"RA_kwDOBMkSUM4Mq-7v","name":"tasmota-CN.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469483,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-CN.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594425","id":212594425,"node_id":"RA_kwDOBMkSUM4Mq-75","name":"tasmota-CZ.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669248,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-CZ.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594414","id":212594414,"node_id":"RA_kwDOBMkSUM4Mq-7u","name":"tasmota-CZ.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469625,"download_count":35,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-CZ.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594419","id":212594419,"node_id":"RA_kwDOBMkSUM4Mq-7z","name":"tasmota-DE.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":668576,"download_count":84,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-DE.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594418","id":212594418,"node_id":"RA_kwDOBMkSUM4Mq-7y","name":"tasmota-DE.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469239,"download_count":66,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-DE.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594408","id":212594408,"node_id":"RA_kwDOBMkSUM4Mq-7o","name":"tasmota-display.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":626128,"download_count":36,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-display.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594413","id":212594413,"node_id":"RA_kwDOBMkSUM4Mq-7t","name":"tasmota-display.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":430756,"download_count":40,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-display.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594427","id":212594427,"node_id":"RA_kwDOBMkSUM4Mq-77","name":"tasmota-ES.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669424,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-ES.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594416","id":212594416,"node_id":"RA_kwDOBMkSUM4Mq-7w","name":"tasmota-ES.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469393,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-ES.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594454","id":212594454,"node_id":"RA_kwDOBMkSUM4Mq-8W","name":"tasmota-FR.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669648,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-FR.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594422","id":212594422,"node_id":"RA_kwDOBMkSUM4Mq-72","name":"tasmota-FR.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469519,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-FR.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594436","id":212594436,"node_id":"RA_kwDOBMkSUM4Mq-8E","name":"tasmota-FY.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":668944,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-FY.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594434","id":212594434,"node_id":"RA_kwDOBMkSUM4Mq-8C","name":"tasmota-FY.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469568,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-FY.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594420","id":212594420,"node_id":"RA_kwDOBMkSUM4Mq-70","name":"tasmota-GR.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":672832,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-GR.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594423","id":212594423,"node_id":"RA_kwDOBMkSUM4Mq-73","name":"tasmota-GR.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":470557,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-GR.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594437","id":212594437,"node_id":"RA_kwDOBMkSUM4Mq-8F","name":"tasmota-HE.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":670192,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-HE.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594431","id":212594431,"node_id":"RA_kwDOBMkSUM4Mq-7_","name":"tasmota-HE.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469550,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-HE.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594438","id":212594438,"node_id":"RA_kwDOBMkSUM4Mq-8G","name":"tasmota-HU.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669552,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-HU.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594426","id":212594426,"node_id":"RA_kwDOBMkSUM4Mq-76","name":"tasmota-HU.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469699,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-HU.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594430","id":212594430,"node_id":"RA_kwDOBMkSUM4Mq-7-","name":"tasmota-ir.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":681296,"download_count":36,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-ir.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594443","id":212594443,"node_id":"RA_kwDOBMkSUM4Mq-8L","name":"tasmota-ir.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":458199,"download_count":40,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-ir.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594428","id":212594428,"node_id":"RA_kwDOBMkSUM4Mq-78","name":"tasmota-IT.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669680,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-IT.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594432","id":212594432,"node_id":"RA_kwDOBMkSUM4Mq-8A","name":"tasmota-IT.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469256,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-IT.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594439","id":212594439,"node_id":"RA_kwDOBMkSUM4Mq-8H","name":"tasmota-knx.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":664736,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-knx.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594424","id":212594424,"node_id":"RA_kwDOBMkSUM4Mq-74","name":"tasmota-knx.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":462131,"download_count":36,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-knx.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594442","id":212594442,"node_id":"RA_kwDOBMkSUM4Mq-8K","name":"tasmota-KO.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669168,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-KO.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594457","id":212594457,"node_id":"RA_kwDOBMkSUM4Mq-8Z","name":"tasmota-KO.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469713,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-KO.bin.gz"},
                      • K Kerschte_de
                        @tt-tom
                        Hallo Tom. Vielen Dank, dass Du Dich der Sache so schnell annimmst. Ich bin gerade auch nochmal das Video von Matthias durchgegangen, ob ich irgendwas entdecke ... habe einige Datenpunkte auch nochmal exakt nach seinem Video angelegt und dann im Script hinterlegt. Leider weiter ohne Erfolg.
                        14.12.2024, 18:20:28.125	[info ]: javascript.0 (363) Compiling TypeScript source script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT
                        14.12.2024, 18:20:28.391	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: source code did not change, using cached compilation result...
                        14.12.2024, 18:20:28.456	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                        14.12.2024, 18:20:28.459	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: setObjects enabled - create Alias Channels possible
                        14.12.2024, 18:20:28.460	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: weather alias for accuweather.0. already exists
                        14.12.2024, 18:20:28.464	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        14.12.2024, 18:20:28.502	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Desired TFT Firmware: 53 / v4.4.0
                        14.12.2024, 18:20:28.502	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Installed TFT Firmware: 53 / v4.4.0
                        14.12.2024, 18:20:28.720	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Debug mode activated
                        14.12.2024, 18:20:28.788	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Tasmota Buzzer disabled
                        14.12.2024, 18:20:28.800	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: NaN W
                        14.12.2024, 18:20:28.801	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: get_current_tasmota_ip_address: 192.168.188.240
                        14.12.2024, 18:20:28.809	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting tasmota firmware version
                        14.12.2024, 18:20:28.810	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting current berry driver version
                        14.12.2024, 18:20:28.811	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: get_current_tasmota_ip_address: 192.168.188.240
                        14.12.2024, 18:20:28.811	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online berry driver version
                        14.12.2024, 18:20:28.811	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online TFT version
                        14.12.2024, 18:20:28.813	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online firmware version
                        14.12.2024, 18:20:28.828	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: import adbase as ad
                        from luibackend.config import LuiBackendConfig
                        from luibackend.controller import LuiController
                        from luibackend.mqtt import LuiMqttListener, LuiMqttSender
                        from luibackend.updater import Updater
                        import apis
                        import json
                        from typing import Literal
                        class NsPanelLovelaceUIManager(ad.ADBase):
                            def initialize(self):
                                self.adapi = self.get_ad_api()
                                self.adapi.log('Starting')
                                apis.ad_api = self.adapi
                                apis.ha_api   = self.get_plugin_api("HASS")
                                apis.mqtt_api = self.get_plugin_api("MQTT")
                                cfg = self._cfg = LuiBackendConfig(apis.ha_api, self.args["config"])
                                use_api = cfg.get("use_api") == True
                                topic_send = cfg.get("panelSendTopic")
                                topic_recv = cfg.get("panelRecvTopic")
                                api_panel_name = cfg.get("panelName")
                                api_device_id = cfg.get("panelDeviceId")
                                quiet = cfg.get("quiet")
                                mqttsender = self._mqttsender = LuiMqttSender(apis.ha_api, use_api, topic_send, api_panel_name, quiet)
                                self._controller = LuiController(cfg, mqttsender.send_mqtt_msg)
                                desired_tasmota_driver_version   = 8
                                desired_display_firmware_version = 53
                                version     = "v4.3.3"
                                model       = cfg.get("model")
                                if model == "us-l":
                                    desired_display_firmware_url = cfg._config.get("displayURL-US-L", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-l-{version}.tft")
                                elif model == "us-p":
                                    desired_display_firmware_url = cfg._config.get("displayURL-US-P", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-p-{version}.tft")
                                else:
                                    desired_display_firmware_url = cfg._config.get("displayURL-EU",   f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-{version}.tft")
                                desired_tasmota_driver_url       = cfg._config.get("berryURL",         "https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be")
                                mode = cfg.get("updateMode")
                                updater = Updater(self.adapi.log, mqttsender, topic_send, mode, desired_display_firmware_version, model, desired_display_firmware_url, desired_tasmota_driver_version, desired_tasmota_driver_url)
                                # Request Tasmota Driver Version
                                updater.request_berry_driver_version()
                                LuiMqttListener(use_api, topic_recv, api_panel_name, api_device_id, self._controller, updater)
                                self.adapi.log(f'Started ({version})')
                            # helpers
                            def show_card(self, card_key: str) -> None:
                                """Used to show card on panel"""
                                msg = json.dumps({"CustomRecv":f"event,buttonPress2,navigate.{card_key},button"})
                                topic = self._cfg.get("panelRecvTopic")
                                self._mqttsender.send_mqtt_msg(msg, topic)
                            def navigate(self, direction: Literal['up', 'prev', 'next']) -> None:
                                """Used to navigate different directions on the panel"""
                                msg = json.dumps({"CustomRecv":f"event,buttonPress2,nav{direction.title()},button"})
                            @property
                            def current_card(self) -> str:
                                """Used to get the panel's current card"""
                                return self._controller.current_card.key
                        14.12.2024, 18:20:28.832	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: # Sonoff NSPanel Tasmota Lovelace UI Berry Driver (Extended Flashing to faster speeds; improved Error Handling)| code by joBr99
                        # based on;
                        # Sonoff NSPanel Tasmota (Nextion with Flashing) driver | code by peepshow-21
                        # based on;
                        # Sonoff NSPanel Tasmota driver v0.47 | code by blakadder and s-hadinger
                        # Example Flash
                        # FlashNextion http://ip-address-of-your-homeassistant:8123/local/nspanel.tft
                        # FlashNextion http://nspanel.pky.eu/lui.tft
                        class Nextion : Driver
                            static header = bytes('55BB')
                            static flash_block_size = 4096
                            var flash_mode
                            var flash_start_millis
                            var flash_size
                            var flash_written
                            var flash_buff
                            var flash_offset
                            var flash_proto_version
                            var flash_proto_baud
                            var awaiting_offset
                            var tcp
                            var ser
                            var last_per
                            var url
                            def split_55(b)
                              var ret = []
                              var s = size(b)
                              var i = s-2   # start from last-1
                              while i > 0
                                if b[i] == 0x55 && b[i+1] == 0xBB
                                  ret.push(b[i..s-1]) # push last msg to list
                                  b = b[(0..i-1)]   # write the rest back to b
                                end
                                i -= 1
                              end
                              ret.push(b)
                              return ret
                            end
                            def crc16(data, poly)
                              if !poly  poly = 0xA001 end
                              # CRC-16 MODBUS HASHING ALGORITHM
                              var crc = 0xFFFF
                              for i:0..size(data)-1
                                crc = crc ^ data[i]
                                for j:0..7
                                  if crc & 1
                                    crc = (crc >> 1) ^ poly
                                  else
                                    crc = crc >> 1
                                  end
                                end
                              end
                              return crc
                            end
                            # encode using custom protocol 55 BB [payload length] [payload length] [payload] [crc] [crc]
                            def encode(payload)
                              var b = bytes()
                              b += self.header
                              b.add(size(payload), 2)   # add size as 2 bytes, little endian
                              b += bytes().fromstring(payload)
                              var msg_crc = self.crc16(b)
                              b.add(msg_crc, 2)       # crc 2 bytes, little endian
                              return b
                            end
                            def encodenx(payload)
                                var b = bytes().fromstring(payload)
                                b += bytes('FFFFFF')
                                return b
                            end
                            def sendnx(payload)
                                import string
                                var payload_bin = self.encodenx(payload)
                                self.ser.write(payload_bin)
                                log(string.format("NXP: Nextion command sent = %s",str(payload_bin)), 3)
                            end
                            def send(payload)
                                var payload_bin = self.encode(payload)
                                if self.flash_mode==1
                                    log("NXP: skipped command becuase still flashing", 3)
                                else
                                    log("NXP: payload sent = " + str(payload_bin), 3)
                                end
                            end
                            def write_to_nextion(b)
                                self.ser.write(b)
                            end
                            def screeninit()
                                log("NXP: Screen Initialized")
                                self.sendnx("recmod=1")
                            end
                            def write_block()
                                import string
                                log("FLH: Read block",3)
                                while size(self.flash_buff)<self.flash_block_size && self.tcp.connected()
                                    if self.tcp.available()>0
                                        self.flash_buff += self.tcp.readbytes(4096)
                                    else
                                        tasmota.delay(50)
                                        log("FLH: Wait for available...",3)
                                    end
                                end
                                log("FLH: Buff size "+str(size(self.flash_buff)),3)
                                var to_write
                                if size(self.flash_buff)>self.flash_block_size
                                    to_write = self.flash_buff[0..self.flash_block_size-1]
                                    self.flash_buff = self.flash_buff[self.flash_block_size..]
                                else
                                    self.flash_buff = bytes()
                                end
                                log("FLH: Writing "+str(size(to_write)),3)
                                var per = (self.flash_written*100)/self.flash_size
                                if (self.last_per!=per)
                                    self.last_per = per
                                    tasmota.publish_result(string.format("{\"Flashing\":{\"complete\": %d, \"time_elapsed\": %d}}",per , (tasmota.millis()-self.flash_start_millis)/1000), "RESULT")
                                end
                                if size(to_write)>0
                                    self.flash_written += size(to_write)
                                    self.ser.write(to_write)
                                end
                                log("FLH: Total "+str(self.flash_written),3)
                                if (self.flash_written==self.flash_size)
                                    log("FLH: Flashing complete - Time elapsed: %d", (tasmota.millis()-self.flash_start_millis)/1000)
                                    self.flash_mode = 0
                                    self.ser.deinit()
                                    self.ser = serial(17, 16, 115200, serial.SERIAL_8N1)
                                end
                            end
                            def every_100ms()
                                import string
                                if self.ser.available() > 0
                                    var msg = self.ser.read()
                                    if size(msg) > 0
                                        log(string.format("NXP: Received Raw = %s",str(msg)), 3)
                                        if (self.flash_mode==1)
                                            var strv = msg[0..-4].asstring()
                                            if string.find(strv,"comok 2")>=0
                                                tasmota.delay(50)
                                                log("FLH: Send (High Speed) flash start")
                                                self.flash_start_millis = tasmota.millis()
                                                #self.sendnx(string.format("whmi-wris %d,115200,res0",self.flash_size))
                                                if self.flash_proto_version == 0
                                                    self.sendnx(string.format("whmi-wri %d,%d,res0",self.flash_size,self.flash_proto_baud))
                                                else
                                                    self.sendnx(string.format("whmi-wris %d,%d,res0",self.flash_size,self.flash_proto_baud))
                                                end
                                                if self.flash_proto_baud != 115200
                                                    tasmota.delay(50)
                                                    self.ser.deinit()
                                                    self.ser = serial(17, 16, self.flash_proto_baud, serial.SERIAL_8N1)
                                                end
                                            elif size(msg)==1 && msg[0]==0x08
                                                log("FLH: Waiting offset...",3)
                                                self.awaiting_offset = 1
                                            elif size(msg)==4 && self.awaiting_offset==1
                                                self.awaiting_offset = 0
                                                self.flash_offset = msg.get(0,4)
                                                log("FLH: Flash offset marker "+str(self.flash_offset),3)
                                                if self.flash_offset != 0
                                                    self.open_url_at(self.url, self.flash_offset)
                                                    self.flash_written = self.flash_offset
                                                end
                                                self.write_block()
                                            elif size(msg)==1 && msg[0]==0x05
                                                self.write_block()
                                            else
                                                log("FLH: Something has gone wrong flashing display firmware ["+str(msg)+"]",2)
                                            end
                                        else
                                            var msg_list = self.split_55(msg)
                                            for i:0..size(msg_list)-1
                                                msg = msg_list[i]
                                                if size(msg) > 0
                                                    if msg == bytes('000000FFFFFF88FFFFFF')
                                                        self.screeninit()
                                                    elif size(msg)>=2 && msg[0]==0x55 && msg[1]==0xBB
                                                        var jm = string.format("{\"CustomRecv\":\"%s\"}",msg[4..-3].asstring())
                                                        tasmota.publish_result(jm, "RESULT")
                                                    elif msg[0]==0x07 && size(msg)==1 # BELL/Buzzer
                                                        tasmota.cmd("buzzer 1,1")
                                                    else
                                                        var jm = string.format("{\"nextion\":\"%s\"}",str(msg[0..-4]))
                                                    end
                                                end
                                            end
                                        end
                                    end
                                end
                            end
                            def begin_nextion_flash()
                                self.flash_written = 0
                                self.flash_offset = 0
                                self.sendnx('DRAKJHSUYDGBNCJHGJKSHBDN')
                                self.sendnx('recmod=0')
                                self.flash_mode = 1
                                self.sendnx("connect")
                            end
                            def open_url_at(url, pos)
                                self.url = url
                                import string
                                var host
                                var port
                                var s1 = string.split(url,7)[1]
                                var i = string.find(s1,":")
                                var sa
                                if i<0
                                    port = 80
                                    i = string.find(s1,"/")
                                    sa = string.split(s1,i)
                                    host = sa[0]
                                else
                                    host = sa[0]
                                    s1 = string.split(sa[1],1)[1]
                                    port = int(sa[0])
                                end
                                var get = sa[1]
                                log(string.format("FLH: host: %s, port: %s, get: %s",host,port,get))
                                self.tcp = tcpclient()
                                self.tcp.connect(host,port)
                                log("FLH: Connected:"+str(self.tcp.connected()),3)
                                var get_req = "GET "+get+" HTTP/1.0\r\n"
                                get_req += string.format("Range: bytes=%d-\r\n", pos)
                                get_req += string.format("HOST: %s:%s\r\n\r\n",host,port)
                                self.tcp.write(get_req)
                                var a = self.tcp.available()
                                i = 1
                                while a==0 && i<5
                                  tasmota.delay(100*i)
                                  tasmota.yield()
                                  i += 1
                                  log("FLH: Retry "+str(i),3)
                                end
                                if a==0
                                    log("FLH: Nothing available to read!",3)
                                    return
                                end
                                var b = self.tcp.readbytes()
                                i = 0
                                var end_headers = false;
                                var headers
                                while i<size(b) && headers==nil
                                    if b[i..(i+3)]==bytes().fromstring("\r\n\r\n")
                                        headers = b[0..(i+3)].asstring()
                                        self.flash_buff = b[(i+4)..]
                                    else
                                        i += 1
                                    end
                                end
                                #print(headers)
                                # check http respose for code 200/206
                                if string.find(headers,"200 OK")>0 || string.find(headers,"206 Partial Content")>0
                                    log("FLH: HTTP Respose is 200 OK or 206 Partial Content",3)
                                else
                                    log("FLH: HTTP Respose is not 200 OK or 206 Partial Content",3)
                                    print(headers)
                                    return -1
                                end
                                # only set flash size if pos is zero
                                if pos == 0
                                    # check http respose for content-length
                                    var tag = "Content-Length: "
                                    i = string.find(headers,tag)
                                    if (i>0)
                                        var i2 = string.find(headers,"\r\n",i)
                                        var s = headers[i+size(tag)..i2-1]
                                        self.flash_size=int(s)
                                    end
                                    log("FLH: Flash file size: "+str(self.flash_size),3)
                                end
                            end
                            def flash_nextion(url)
                                self.flash_size = 0
                                var res = self.open_url_at(url, 0)
                                if res != -1
                                    self.begin_nextion_flash()
                                end
                            end
                            def init()
                                log("NXP: Initializing Driver")
                                self.flash_mode = 0
                                self.flash_proto_version = 1
                                self.flash_proto_baud = 921600
                            end
                        end
                        var nextion = Nextion()
                        tasmota.add_driver(nextion)
                        def get_current_version(cmd, idx, payload, payload_json)
                            import string
                            var version_of_this_script = 9
                            var jm = string.format("{\"nlui_driver_version\":\"%s\"}", version_of_this_script)
                        end
                        tasmota.add_cmd('GetDriverVersion', get_current_version)
                        def update_berry_driver(cmd, idx, payload, payload_json)
                            def task()
                                import path
                                import string
                        		if string.find(payload, ".tapp") > 0
                        		    print("tapp in URL; will do .tapp update and migration if necessary")
                        			if path.exists("autoexec.be")
                        			    print("autoexec.be found; will check for migration")
                        				var autoexecfile = open('autoexec.be')
                        				var line = autoexecfile.readline()
                        				autoexecfile.close()
                        				if string.find(line, "NSPanel Tasmota Lovelace UI Berry Driver") > 0
                        			        print("found lovelace berry driver, going to delete autoexec.be and .bec")
                        					path.remove("autoexec.be")
                        					path.remove("autoexec.bec")
                        				end
                        			end
                        			var r = tasmota.urlfetch(payload, "nsp-lovelace-driver.tapp")
                                    if r < 0
                                        print("Update failed")
                                    else
                                        tasmota.cmd("Restart 1")
                                    end
                        		elif string.find(payload, ".be") > 0
                        		    print("be in URL; will do .be update")
                        			if path.exists("nsp-lovelace-driver.tapp")
                        			    print("Error: there is the tapp version of the berry driver installed; cannot do .be update.")
                        			else
                                        var cl = webclient()
                                        cl.begin(payload)
                                        var r = cl.GET()
                                        if r == 200
                                            print("Sucessfully downloaded nspanel-lovelace-ui berry driver")
                                        else
                                            print("Error while downloading nspanel-lovelace-ui berry driver")
                                        end
                                        r = cl.write_file("autoexec.be")
                                        if r < 0
                                            print("Error while writeing nspanel-lovelace-ui berry driver")
                                        else
                                            print("Sucessfully written nspanel-lovelace-ui berry driver")
                                        end
                        			end
                        		else
                        			print("invalid url filetype")
                        		end
                                    var r = string.find(payload, ".tapp")
                                    if r < 0
                                        print("URL doesn't contain .tapp skipping update")
                                    else
                                    end
                                else
                                    var r = string.find(payload, ".be")
                                    if r < 0
                                        print("URL doesn't contain .be skipping update")
                                    else
                                    end
                                end
                            end
                            tasmota.set_timer(0,task)
                            tasmota.resp_cmnd_done()
                        end
                        tasmota.add_cmd('UpdateDriverVersion', update_berry_driver)
                        def flash_nextion(cmd, idx, payload, payload_json)
                            def task()
                            nextion.flash_proto_version = 1
                            nextion.flash_proto_baud = 921600
                                nextion.flash_nextion(payload)
                            end
                        end
                        def flash_nextion_adv(cmd, idx, payload, payload_json)
                            def task()
                                if idx==0
                                elif idx==1
                                    nextion.flash_proto_version = 0
                                elif idx==2
                                    nextion.flash_proto_baud = 115200
                                elif idx==3
                                elif idx==4
                                    nextion.flash_proto_baud = 256000
                                elif idx==5
                                elif idx==6
                                    nextion.ser.deinit()
                                    nextion.ser = serial(17, 16, 9600, serial.SERIAL_8N1)
                                else
                                end
                            end
                        end
                        def send_cmd(cmd, idx, payload, payload_json)
                            nextion.sendnx(payload)
                        end
                        def send_cmd2(cmd, idx, payload, payload_json)
                            nextion.send(payload)
                        end
                        tasmota.add_cmd('Nextion', send_cmd)
                        tasmota.add_cmd('CustomSend', send_cmd2)
                        tasmota.add_cmd('FlashNextion', flash_nextion)
                        tasmota.add_cmd('FlashNextionAdv', flash_nextion_adv)
                        14.12.2024, 18:20:28.835	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online display firmware version => 53
                        14.12.2024, 18:20:28.852	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: {"nlui_driver_version":"9"}
                        14.12.2024, 18:20:28.855	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: current tasmota firmware version => 14.3.0
                        14.12.2024, 18:20:28.855	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online berry driver version => 9
                        14.12.2024, 18:20:28.882	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: current berry driver version => 9
                        14.12.2024, 18:20:28.926	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: hidden Cards disabled
                        Kerschte_de
                        #6647
                        @kerschte_de
                        {"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594433","id":212594433,"node_id":"RA_kwDOBMkSUM4Mq-8B","name":"tasmota-lite.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":520208,"download_count":62,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-lite.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594444","id":212594444,"node_id":"RA_kwDOBMkSUM4Mq-8M","name":"tasmota-lite.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":364868,"download_count":59,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-lite.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594429","id":212594429,"node_id":"RA_kwDOBMkSUM4Mq-79","name":"tasmota-minimal.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":374432,"download_count":108,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-minimal.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594435","id":212594435,"node_id":"RA_kwDOBMkSUM4Mq-8D","name":"tasmota-minimal.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":264238,"download_count":113,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-minimal.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594456","id":212594456,"node_id":"RA_kwDOBMkSUM4Mq-8Y","name":"tasmota-NL.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669024,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-NL.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594441","id":212594441,"node_id":"RA_kwDOBMkSUM4Mq-8J","name":"tasmota-NL.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469232,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-NL.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594448","id":212594448,"node_id":"RA_kwDOBMkSUM4Mq-8Q","name":"tasmota-PL.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669680,"download_count":36,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-PL.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594440","id":212594440,"node_id":"RA_kwDOBMkSUM4Mq-8I","name":"tasmota-PL.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469819,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-PL.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594445","id":212594445,"node_id":"RA_kwDOBMkSUM4Mq-8N","name":"tasmota-PT.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669744,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-PT.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594463","id":212594463,"node_id":"RA_kwDOBMkSUM4Mq-8f","name":"tasmota-PT.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469557,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-PT.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594447","id":212594447,"node_id":"RA_kwDOBMkSUM4Mq-8P","name":"tasmota-RO.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669024,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-RO.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594458","id":212594458,"node_id":"RA_kwDOBMkSUM4Mq-8a","name":"tasmota-RO.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469329,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-RO.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594449","id":212594449,"node_id":"RA_kwDOBMkSUM4Mq-8R","name":"tasmota-RU.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":673744,"download_count":35,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-RU.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594462","id":212594462,"node_id":"RA_kwDOBMkSUM4Mq-8e","name":"tasmota-RU.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":470822,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-RU.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594469","id":212594469,"node_id":"RA_kwDOBMkSUM4Mq-8l","name":"tasmota-SE.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669104,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-SE.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594451","id":212594451,"node_id":"RA_kwDOBMkSUM4Mq-8T","name":"tasmota-SE.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469458,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-SE.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594455","id":212594455,"node_id":"RA_kwDOBMkSUM4Mq-8X","name":"tasmota-sensors.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":736896,"download_count":48,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-sensors.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594446","id":212594446,"node_id":"RA_kwDOBMkSUM4Mq-8O","name":"tasmota-sensors.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":510956,"download_count":53,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-sensors.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594472","id":212594472,"node_id":"RA_kwDOBMkSUM4Mq-8o","name":"tasmota-SK.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669328,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-SK.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594467","id":212594467,"node_id":"RA_kwDOBMkSUM4Mq-8j","name":"tasmota-SK.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469668,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-SK.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594452","id":212594452,"node_id":"RA_kwDOBMkSUM4Mq-8U","name":"tasmota-TR.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":669248,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-TR.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594466","id":212594466,"node_id":"RA_kwDOBMkSUM4Mq-8i","name":"tasmota-TR.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469588,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-TR.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594453","id":212594453,"node_id":"RA_kwDOBMkSUM4Mq-8V","name":"tasmota-TW.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":668704,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-TW.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594450","id":212594450,"node_id":"RA_kwDOBMkSUM4Mq-8S","name":"tasmota-TW.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469967,"download_count":32,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-TW.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594461","id":212594461,"node_id":"RA_kwDOBMkSUM4Mq-8d","name":"tasmota-UK.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":673856,"download_count":38,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-UK.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594459","id":212594459,"node_id":"RA_kwDOBMkSUM4Mq-8b","name":"tasmota-UK.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":470776,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-UK.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594474","id":212594474,"node_id":"RA_kwDOBMkSUM4Mq-8q","name":"tasmota-VN.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":670496,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-VN.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594464","id":212594464,"node_id":"RA_kwDOBMkSUM4Mq-8g","name":"tasmota-VN.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":469736,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-VN.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594468","id":212594468,"node_id":"RA_kwDOBMkSUM4Mq-8k","name":"tasmota-zbbridge.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":765456,"download_count":37,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-zbbridge.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594475","id":212594475,"node_id":"RA_kwDOBMkSUM4Mq-8r","name":"tasmota-zbbridge.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":527313,"download_count":40,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-zbbridge.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594460","id":212594460,"node_id":"RA_kwDOBMkSUM4Mq-8c","name":"tasmota-zigbee.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":857760,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-zigbee.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594465","id":212594465,"node_id":"RA_kwDOBMkSUM4Mq-8h","name":"tasmota-zigbee.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":590540,"download_count":36,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota-zigbee.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594482","id":212594482,"node_id":"RA_kwDOBMkSUM4Mq-8y","name":"tasmota.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":668064,"download_count":84,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594479","id":212594479,"node_id":"RA_kwDOBMkSUM4Mq-8v","name":"tasmota.bin.gz","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/gzip","state":"uploaded","size":468540,"download_count":83,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota.bin.gz"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594473","id":212594473,"node_id":"RA_kwDOBMkSUM4Mq-8p","name":"tasmota32-AD.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":2066048,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota32-AD.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594471","id":212594471,"node_id":"RA_kwDOBMkSUM4Mq-8n","name":"tasmota32-AD.factory.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":2983552,"download_count":34,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota32-AD.factory.bin"},{"url":"https://api.github.com/repos/arendst/Tasmota/releases/assets/212594478","id":212594478,"node_id":"RA_kwDOBMkSUM4Mq-8u","name":"tasmota32-AF.bin","label":"","uploader":{"login":"github-actions[bot]","id":41898282,"node_id":"MDM6Qm90NDE4OTgyODI=","avatar_url":"https://avatars.githubusercontent.com/in/15368?v=4","gravatar_id":"","url":"https://api.github.com/users/github-actions%5Bbot%5D","html_url":"https://github.com/apps/github-actions","followers_url":"https://api.github.com/users/github-actions%5Bbot%5D/followers","following_url":"https://api.github.com/users/github-actions%5Bbot%5D/following{/other_user}","gists_url":"https://api.github.com/users/github-actions%5Bbot%5D/gists{/gist_id}","starred_url":"https://api.github.com/users/github-actions%5Bbot%5D/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/github-actions%5Bbot%5D/subscriptions","organizations_url":"https://api.github.com/users/github-actions%5Bbot%5D/orgs","repos_url":"https://api.github.com/users/github-actions%5Bbot%5D/repos","events_url":"https://api.github.com/users/github-actions%5Bbot%5D/events{/privacy}","received_events_url":"https://api.github.com/users/github-actions%5Bbot%5D/received_events","type":"Bot","user_view_type":"public","site_admin":false},"content_type":"application/octet-stream","state":"uploaded","size":2065568,"download_count":33,"created_at":"2024-12-11T09:35:48Z","updated_at":"2024-12-11T09:35:49Z","browser_download_url":"https://github.com/arendst/Tasmota/releases/download/v14.4.0/tasmota32-AF.bin"},
                        • K Kerschte_de
                          @tt-tom
                          Hallo Tom. Vielen Dank, dass Du Dich der Sache so schnell annimmst. Ich bin gerade auch nochmal das Video von Matthias durchgegangen, ob ich irgendwas entdecke ... habe einige Datenpunkte auch nochmal exakt nach seinem Video angelegt und dann im Script hinterlegt. Leider weiter ohne Erfolg.
                          14.12.2024, 18:20:28.125	[info ]: javascript.0 (363) Compiling TypeScript source script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT
                          14.12.2024, 18:20:28.391	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: source code did not change, using cached compilation result...
                          14.12.2024, 18:20:28.456	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                          14.12.2024, 18:20:28.459	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: setObjects enabled - create Alias Channels possible
                          14.12.2024, 18:20:28.460	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: weather alias for accuweather.0. already exists
                          14.12.2024, 18:20:28.464	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          14.12.2024, 18:20:28.502	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Desired TFT Firmware: 53 / v4.4.0
                          14.12.2024, 18:20:28.502	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Installed TFT Firmware: 53 / v4.4.0
                          14.12.2024, 18:20:28.720	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Debug mode activated
                          14.12.2024, 18:20:28.788	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Tasmota Buzzer disabled
                          14.12.2024, 18:20:28.800	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: NaN W
                          14.12.2024, 18:20:28.801	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: get_current_tasmota_ip_address: 192.168.188.240
                          14.12.2024, 18:20:28.809	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting tasmota firmware version
                          14.12.2024, 18:20:28.810	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting current berry driver version
                          14.12.2024, 18:20:28.811	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: get_current_tasmota_ip_address: 192.168.188.240
                          14.12.2024, 18:20:28.811	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online berry driver version
                          14.12.2024, 18:20:28.811	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online TFT version
                          14.12.2024, 18:20:28.813	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online firmware version
                          14.12.2024, 18:20:28.828	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: import adbase as ad
                          from luibackend.config import LuiBackendConfig
                          from luibackend.controller import LuiController
                          from luibackend.mqtt import LuiMqttListener, LuiMqttSender
                          from luibackend.updater import Updater
                          import apis
                          import json
                          from typing import Literal
                          class NsPanelLovelaceUIManager(ad.ADBase):
                              def initialize(self):
                                  self.adapi = self.get_ad_api()
                                  self.adapi.log('Starting')
                                  apis.ad_api = self.adapi
                                  apis.ha_api   = self.get_plugin_api("HASS")
                                  apis.mqtt_api = self.get_plugin_api("MQTT")
                                  cfg = self._cfg = LuiBackendConfig(apis.ha_api, self.args["config"])
                                  use_api = cfg.get("use_api") == True
                                  topic_send = cfg.get("panelSendTopic")
                                  topic_recv = cfg.get("panelRecvTopic")
                                  api_panel_name = cfg.get("panelName")
                                  api_device_id = cfg.get("panelDeviceId")
                                  quiet = cfg.get("quiet")
                                  mqttsender = self._mqttsender = LuiMqttSender(apis.ha_api, use_api, topic_send, api_panel_name, quiet)
                                  self._controller = LuiController(cfg, mqttsender.send_mqtt_msg)
                                  desired_tasmota_driver_version   = 8
                                  desired_display_firmware_version = 53
                                  version     = "v4.3.3"
                                  model       = cfg.get("model")
                                  if model == "us-l":
                                      desired_display_firmware_url = cfg._config.get("displayURL-US-L", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-l-{version}.tft")
                                  elif model == "us-p":
                                      desired_display_firmware_url = cfg._config.get("displayURL-US-P", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-p-{version}.tft")
                                  else:
                                      desired_display_firmware_url = cfg._config.get("displayURL-EU",   f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-{version}.tft")
                                  desired_tasmota_driver_url       = cfg._config.get("berryURL",         "https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be")
                                  mode = cfg.get("updateMode")
                                  updater = Updater(self.adapi.log, mqttsender, topic_send, mode, desired_display_firmware_version, model, desired_display_firmware_url, desired_tasmota_driver_version, desired_tasmota_driver_url)
                                  # Request Tasmota Driver Version
                                  updater.request_berry_driver_version()
                                  LuiMqttListener(use_api, topic_recv, api_panel_name, api_device_id, self._controller, updater)
                                  self.adapi.log(f'Started ({version})')
                              # helpers
                              def show_card(self, card_key: str) -> None:
                                  """Used to show card on panel"""
                                  msg = json.dumps({"CustomRecv":f"event,buttonPress2,navigate.{card_key},button"})
                                  topic = self._cfg.get("panelRecvTopic")
                                  self._mqttsender.send_mqtt_msg(msg, topic)
                              def navigate(self, direction: Literal['up', 'prev', 'next']) -> None:
                                  """Used to navigate different directions on the panel"""
                                  msg = json.dumps({"CustomRecv":f"event,buttonPress2,nav{direction.title()},button"})
                              @property
                              def current_card(self) -> str:
                                  """Used to get the panel's current card"""
                                  return self._controller.current_card.key
                          14.12.2024, 18:20:28.832	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: # Sonoff NSPanel Tasmota Lovelace UI Berry Driver (Extended Flashing to faster speeds; improved Error Handling)| code by joBr99
                          # based on;
                          # Sonoff NSPanel Tasmota (Nextion with Flashing) driver | code by peepshow-21
                          # based on;
                          # Sonoff NSPanel Tasmota driver v0.47 | code by blakadder and s-hadinger
                          # Example Flash
                          # FlashNextion http://ip-address-of-your-homeassistant:8123/local/nspanel.tft
                          # FlashNextion http://nspanel.pky.eu/lui.tft
                          class Nextion : Driver
                              static header = bytes('55BB')
                              static flash_block_size = 4096
                              var flash_mode
                              var flash_start_millis
                              var flash_size
                              var flash_written
                              var flash_buff
                              var flash_offset
                              var flash_proto_version
                              var flash_proto_baud
                              var awaiting_offset
                              var tcp
                              var ser
                              var last_per
                              var url
                              def split_55(b)
                                var ret = []
                                var s = size(b)
                                var i = s-2   # start from last-1
                                while i > 0
                                  if b[i] == 0x55 && b[i+1] == 0xBB
                                    ret.push(b[i..s-1]) # push last msg to list
                                    b = b[(0..i-1)]   # write the rest back to b
                                  end
                                  i -= 1
                                end
                                ret.push(b)
                                return ret
                              end
                              def crc16(data, poly)
                                if !poly  poly = 0xA001 end
                                # CRC-16 MODBUS HASHING ALGORITHM
                                var crc = 0xFFFF
                                for i:0..size(data)-1
                                  crc = crc ^ data[i]
                                  for j:0..7
                                    if crc & 1
                                      crc = (crc >> 1) ^ poly
                                    else
                                      crc = crc >> 1
                                    end
                                  end
                                end
                                return crc
                              end
                              # encode using custom protocol 55 BB [payload length] [payload length] [payload] [crc] [crc]
                              def encode(payload)
                                var b = bytes()
                                b += self.header
                                b.add(size(payload), 2)   # add size as 2 bytes, little endian
                                b += bytes().fromstring(payload)
                                var msg_crc = self.crc16(b)
                                b.add(msg_crc, 2)       # crc 2 bytes, little endian
                                return b
                              end
                              def encodenx(payload)
                                  var b = bytes().fromstring(payload)
                                  b += bytes('FFFFFF')
                                  return b
                              end
                              def sendnx(payload)
                                  import string
                                  var payload_bin = self.encodenx(payload)
                                  self.ser.write(payload_bin)
                                  log(string.format("NXP: Nextion command sent = %s",str(payload_bin)), 3)
                              end
                              def send(payload)
                                  var payload_bin = self.encode(payload)
                                  if self.flash_mode==1
                                      log("NXP: skipped command becuase still flashing", 3)
                                  else
                                      log("NXP: payload sent = " + str(payload_bin), 3)
                                  end
                              end
                              def write_to_nextion(b)
                                  self.ser.write(b)
                              end
                              def screeninit()
                                  log("NXP: Screen Initialized")
                                  self.sendnx("recmod=1")
                              end
                              def write_block()
                                  import string
                                  log("FLH: Read block",3)
                                  while size(self.flash_buff)<self.flash_block_size && self.tcp.connected()
                                      if self.tcp.available()>0
                                          self.flash_buff += self.tcp.readbytes(4096)
                                      else
                                          tasmota.delay(50)
                                          log("FLH: Wait for available...",3)
                                      end
                                  end
                                  log("FLH: Buff size "+str(size(self.flash_buff)),3)
                                  var to_write
                                  if size(self.flash_buff)>self.flash_block_size
                                      to_write = self.flash_buff[0..self.flash_block_size-1]
                                      self.flash_buff = self.flash_buff[self.flash_block_size..]
                                  else
                                      self.flash_buff = bytes()
                                  end
                                  log("FLH: Writing "+str(size(to_write)),3)
                                  var per = (self.flash_written*100)/self.flash_size
                                  if (self.last_per!=per)
                                      self.last_per = per
                                      tasmota.publish_result(string.format("{\"Flashing\":{\"complete\": %d, \"time_elapsed\": %d}}",per , (tasmota.millis()-self.flash_start_millis)/1000), "RESULT")
                                  end
                                  if size(to_write)>0
                                      self.flash_written += size(to_write)
                                      self.ser.write(to_write)
                                  end
                                  log("FLH: Total "+str(self.flash_written),3)
                                  if (self.flash_written==self.flash_size)
                                      log("FLH: Flashing complete - Time elapsed: %d", (tasmota.millis()-self.flash_start_millis)/1000)
                                      self.flash_mode = 0
                                      self.ser.deinit()
                                      self.ser = serial(17, 16, 115200, serial.SERIAL_8N1)
                                  end
                              end
                              def every_100ms()
                                  import string
                                  if self.ser.available() > 0
                                      var msg = self.ser.read()
                                      if size(msg) > 0
                                          log(string.format("NXP: Received Raw = %s",str(msg)), 3)
                                          if (self.flash_mode==1)
                                              var strv = msg[0..-4].asstring()
                                              if string.find(strv,"comok 2")>=0
                                                  tasmota.delay(50)
                                                  log("FLH: Send (High Speed) flash start")
                                                  self.flash_start_millis = tasmota.millis()
                                                  #self.sendnx(string.format("whmi-wris %d,115200,res0",self.flash_size))
                                                  if self.flash_proto_version == 0
                                                      self.sendnx(string.format("whmi-wri %d,%d,res0",self.flash_size,self.flash_proto_baud))
                                                  else
                                                      self.sendnx(string.format("whmi-wris %d,%d,res0",self.flash_size,self.flash_proto_baud))
                                                  end
                                                  if self.flash_proto_baud != 115200
                                                      tasmota.delay(50)
                                                      self.ser.deinit()
                                                      self.ser = serial(17, 16, self.flash_proto_baud, serial.SERIAL_8N1)
                                                  end
                                              elif size(msg)==1 && msg[0]==0x08
                                                  log("FLH: Waiting offset...",3)
                                                  self.awaiting_offset = 1
                                              elif size(msg)==4 && self.awaiting_offset==1
                                                  self.awaiting_offset = 0
                                                  self.flash_offset = msg.get(0,4)
                                                  log("FLH: Flash offset marker "+str(self.flash_offset),3)
                                                  if self.flash_offset != 0
                                                      self.open_url_at(self.url, self.flash_offset)
                                                      self.flash_written = self.flash_offset
                                                  end
                                                  self.write_block()
                                              elif size(msg)==1 && msg[0]==0x05
                                                  self.write_block()
                                              else
                                                  log("FLH: Something has gone wrong flashing display firmware ["+str(msg)+"]",2)
                                              end
                                          else
                                              var msg_list = self.split_55(msg)
                                              for i:0..size(msg_list)-1
                                                  msg = msg_list[i]
                                                  if size(msg) > 0
                                                      if msg == bytes('000000FFFFFF88FFFFFF')
                                                          self.screeninit()
                                                      elif size(msg)>=2 && msg[0]==0x55 && msg[1]==0xBB
                                                          var jm = string.format("{\"CustomRecv\":\"%s\"}",msg[4..-3].asstring())
                                                          tasmota.publish_result(jm, "RESULT")
                                                      elif msg[0]==0x07 && size(msg)==1 # BELL/Buzzer
                                                          tasmota.cmd("buzzer 1,1")
                                                      else
                                                          var jm = string.format("{\"nextion\":\"%s\"}",str(msg[0..-4]))
                                                      end
                                                  end
                                              end
                                          end
                                      end
                                  end
                              end
                              def begin_nextion_flash()
                                  self.flash_written = 0
                                  self.flash_offset = 0
                                  self.sendnx('DRAKJHSUYDGBNCJHGJKSHBDN')
                                  self.sendnx('recmod=0')
                                  self.flash_mode = 1
                                  self.sendnx("connect")
                              end
                              def open_url_at(url, pos)
                                  self.url = url
                                  import string
                                  var host
                                  var port
                                  var s1 = string.split(url,7)[1]
                                  var i = string.find(s1,":")
                                  var sa
                                  if i<0
                                      port = 80
                                      i = string.find(s1,"/")
                                      sa = string.split(s1,i)
                                      host = sa[0]
                                  else
                                      host = sa[0]
                                      s1 = string.split(sa[1],1)[1]
                                      port = int(sa[0])
                                  end
                                  var get = sa[1]
                                  log(string.format("FLH: host: %s, port: %s, get: %s",host,port,get))
                                  self.tcp = tcpclient()
                                  self.tcp.connect(host,port)
                                  log("FLH: Connected:"+str(self.tcp.connected()),3)
                                  var get_req = "GET "+get+" HTTP/1.0\r\n"
                                  get_req += string.format("Range: bytes=%d-\r\n", pos)
                                  get_req += string.format("HOST: %s:%s\r\n\r\n",host,port)
                                  self.tcp.write(get_req)
                                  var a = self.tcp.available()
                                  i = 1
                                  while a==0 && i<5
                                    tasmota.delay(100*i)
                                    tasmota.yield()
                                    i += 1
                                    log("FLH: Retry "+str(i),3)
                                  end
                                  if a==0
                                      log("FLH: Nothing available to read!",3)
                                      return
                                  end
                                  var b = self.tcp.readbytes()
                                  i = 0
                                  var end_headers = false;
                                  var headers
                                  while i<size(b) && headers==nil
                                      if b[i..(i+3)]==bytes().fromstring("\r\n\r\n")
                                          headers = b[0..(i+3)].asstring()
                                          self.flash_buff = b[(i+4)..]
                                      else
                                          i += 1
                                      end
                                  end
                                  #print(headers)
                                  # check http respose for code 200/206
                                  if string.find(headers,"200 OK")>0 || string.find(headers,"206 Partial Content")>0
                                      log("FLH: HTTP Respose is 200 OK or 206 Partial Content",3)
                                  else
                                      log("FLH: HTTP Respose is not 200 OK or 206 Partial Content",3)
                                      print(headers)
                                      return -1
                                  end
                                  # only set flash size if pos is zero
                                  if pos == 0
                                      # check http respose for content-length
                                      var tag = "Content-Length: "
                                      i = string.find(headers,tag)
                                      if (i>0)
                                          var i2 = string.find(headers,"\r\n",i)
                                          var s = headers[i+size(tag)..i2-1]
                                          self.flash_size=int(s)
                                      end
                                      log("FLH: Flash file size: "+str(self.flash_size),3)
                                  end
                              end
                              def flash_nextion(url)
                                  self.flash_size = 0
                                  var res = self.open_url_at(url, 0)
                                  if res != -1
                                      self.begin_nextion_flash()
                                  end
                              end
                              def init()
                                  log("NXP: Initializing Driver")
                                  self.flash_mode = 0
                                  self.flash_proto_version = 1
                                  self.flash_proto_baud = 921600
                              end
                          end
                          var nextion = Nextion()
                          tasmota.add_driver(nextion)
                          def get_current_version(cmd, idx, payload, payload_json)
                              import string
                              var version_of_this_script = 9
                              var jm = string.format("{\"nlui_driver_version\":\"%s\"}", version_of_this_script)
                          end
                          tasmota.add_cmd('GetDriverVersion', get_current_version)
                          def update_berry_driver(cmd, idx, payload, payload_json)
                              def task()
                                  import path
                                  import string
                          		if string.find(payload, ".tapp") > 0
                          		    print("tapp in URL; will do .tapp update and migration if necessary")
                          			if path.exists("autoexec.be")
                          			    print("autoexec.be found; will check for migration")
                          				var autoexecfile = open('autoexec.be')
                          				var line = autoexecfile.readline()
                          				autoexecfile.close()
                          				if string.find(line, "NSPanel Tasmota Lovelace UI Berry Driver") > 0
                          			        print("found lovelace berry driver, going to delete autoexec.be and .bec")
                          					path.remove("autoexec.be")
                          					path.remove("autoexec.bec")
                          				end
                          			end
                          			var r = tasmota.urlfetch(payload, "nsp-lovelace-driver.tapp")
                                      if r < 0
                                          print("Update failed")
                                      else
                                          tasmota.cmd("Restart 1")
                                      end
                          		elif string.find(payload, ".be") > 0
                          		    print("be in URL; will do .be update")
                          			if path.exists("nsp-lovelace-driver.tapp")
                          			    print("Error: there is the tapp version of the berry driver installed; cannot do .be update.")
                          			else
                                          var cl = webclient()
                                          cl.begin(payload)
                                          var r = cl.GET()
                                          if r == 200
                                              print("Sucessfully downloaded nspanel-lovelace-ui berry driver")
                                          else
                                              print("Error while downloading nspanel-lovelace-ui berry driver")
                                          end
                                          r = cl.write_file("autoexec.be")
                                          if r < 0
                                              print("Error while writeing nspanel-lovelace-ui berry driver")
                                          else
                                              print("Sucessfully written nspanel-lovelace-ui berry driver")
                                          end
                          			end
                          		else
                          			print("invalid url filetype")
                          		end
                                      var r = string.find(payload, ".tapp")
                                      if r < 0
                                          print("URL doesn't contain .tapp skipping update")
                                      else
                                      end
                                  else
                                      var r = string.find(payload, ".be")
                                      if r < 0
                                          print("URL doesn't contain .be skipping update")
                                      else
                                      end
                                  end
                              end
                              tasmota.set_timer(0,task)
                              tasmota.resp_cmnd_done()
                          end
                          tasmota.add_cmd('UpdateDriverVersion', update_berry_driver)
                          def flash_nextion(cmd, idx, payload, payload_json)
                              def task()
                              nextion.flash_proto_version = 1
                              nextion.flash_proto_baud = 921600
                                  nextion.flash_nextion(payload)
                              end
                          end
                          def flash_nextion_adv(cmd, idx, payload, payload_json)
                              def task()
                                  if idx==0
                                  elif idx==1
                                      nextion.flash_proto_version = 0
                                  elif idx==2
                                      nextion.flash_proto_baud = 115200
                                  elif idx==3
                                  elif idx==4
                                      nextion.flash_proto_baud = 256000
                                  elif idx==5
                                  elif idx==6
                                      nextion.ser.deinit()
                                      nextion.ser = serial(17, 16, 9600, serial.SERIAL_8N1)
                                  else
                                  end
                              end
                          end
                          def send_cmd(cmd, idx, payload, payload_json)
                              nextion.sendnx(payload)
                          end
                          def send_cmd2(cmd, idx, payload, payload_json)
                              nextion.send(payload)
                          end
                          tasmota.add_cmd('Nextion', send_cmd)
                          tasmota.add_cmd('CustomSend', send_cmd2)
                          tasmota.add_cmd('FlashNextion', flash_nextion)
                          tasmota.add_cmd('FlashNextionAdv', flash_nextion_adv)
                          14.12.2024, 18:20:28.835	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online display firmware version => 53
                          14.12.2024, 18:20:28.852	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: {"nlui_driver_version":"9"}
                          14.12.2024, 18:20:28.855	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: current tasmota firmware version => 14.3.0
                          14.12.2024, 18:20:28.855	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online berry driver version => 9
                          14.12.2024, 18:20:28.882	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: current berry driver version => 9
                          14.12.2024, 18:20:28.926	[info ]: javascript.0 (363) script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: hidden Cards disabled
                          Kerschte_de
                          #6648
                          @kerschte_de
                          da ist was durcheinandergekommen, da ich die maximale Zeichenzahl übersteige. Ich versuche es nochmal ab Zeile 572
                          javascript.0	18:20:28.125	info	Compiling TypeScript source script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT
                          javascript.0	18:20:28.391	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: source code did not change, using cached compilation result...
                          javascript.0	18:20:28.456	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                          javascript.0	18:20:28.459	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: setObjects enabled - create Alias Channels possible
                          javascript.0	18:20:28.460	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: weather alias for accuweather.0. already exists
                          javascript.0	18:20:28.464	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          javascript.0	18:20:28.502	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Desired TFT Firmware: 53 / v4.4.0
                          javascript.0	18:20:28.502	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Installed TFT Firmware: 53 / v4.4.0
                          javascript.0	18:20:28.720	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Debug mode activated
                          javascript.0	18:20:28.788	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Tasmota Buzzer disabled
                          javascript.0	18:20:28.800	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: NaN W
                          javascript.0	18:20:28.801	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: get_current_tasmota_ip_address: 192.168.188.240
                          javascript.0	18:20:28.809	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting tasmota firmware version
                          javascript.0	18:20:28.810	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting current berry driver version
                          javascript.0	18:20:28.811	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: get_current_tasmota_ip_address: 192.168.188.240
                          javascript.0	18:20:28.811	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online berry driver version
                          javascript.0	18:20:28.811	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online TFT version
                          javascript.0	18:20:28.813	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: Requesting online firmware version
                          javascript.0	18:20:28.828	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: import adbase as ad from luibackend.config import LuiBackendConfig from luibackend.controller import LuiController from luibackend.mqtt import LuiMqttListener, LuiMqttSender from luibackend.updater import Updater import apis import json from typing import Literal class NsPanelLovelaceUIManager(ad.ADBase): def initialize(self): self.adapi = self.get_ad_api() self.adapi.log('Starting') apis.ad_api = self.adapi apis.ha_api = self.get_plugin_api("HASS") apis.mqtt_api = self.get_plugin_api("MQTT") cfg = self._cfg = LuiBackendConfig(apis.ha_api, self.args["config"]) use_api = cfg.get("use_api") == True topic_send = cfg.get("panelSendTopic") topic_recv = cfg.get("panelRecvTopic") api_panel_name = cfg.get("panelName") api_device_id = cfg.get("panelDeviceId") quiet = cfg.get("quiet") mqttsender = self._mqttsender = LuiMqttSender(apis.ha_api, use_api, topic_send, api_panel_name, quiet) self._controller = LuiController(cfg, mqttsender.send_mqtt_msg) desired_tasmota_driver_version = 8 desired_display_firmware_version = 53 version = "v4.3.3" model = cfg.get("model") if model == "us-l": desired_display_firmware_url = cfg._config.get("displayURL-US-L", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-l-{version}.tft") elif model == "us-p": desired_display_firmware_url = cfg._config.get("displayURL-US-P", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-us-p-{version}.tft") else: desired_display_firmware_url = cfg._config.get("displayURL-EU", f"http://nspanel.pky.eu/lovelace-ui/github/nspanel-{version}.tft") desired_tasmota_driver_url = cfg._config.get("berryURL", "https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be") mode = cfg.get("updateMode") updater = Updater(self.adapi.log, mqttsender, topic_send, mode, desired_display_firmware_version, model, desired_display_firmware_url, desired_tasmota_driver_version, desired_tasmota_driver_url) # Request Tasmota Driver Version updater.request_berry_driver_version() LuiMqttListener(use_api, topic_recv, api_panel_name, api_device_id, self._controller, updater) self.adapi.log(f'Started ({version})') # # helpers # def show_card(self, card_key: str) -> None: """Used to show card on panel""" msg = json.dumps({"CustomRecv":f"event,buttonPress2,navigate.{card_key},button"}) topic = self._cfg.get("panelRecvTopic") self._mqttsender.send_mqtt_msg(msg, topic) def navigate(self, direction: Literal['up', 'prev', 'next']) -> None: """Used to navigate different directions on the panel""" msg = json.dumps({"CustomRecv":f"event,buttonPress2,nav{direction.title()},button"}) topic = self._cfg.get("panelRecvTopic") self._mqttsender.send_mqtt_msg(msg, topic) @property def current_card(self) -> str: """Used to get the panel's current card""" return self._controller.current_card.key
                          javascript.0	18:20:28.832	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: # Sonoff NSPanel Tasmota Lovelace UI Berry Driver (Extended Flashing to faster speeds; improved Error Handling)| code by joBr99 # based on; # Sonoff NSPanel Tasmota (Nextion with Flashing) driver | code by peepshow-21 # based on; # Sonoff NSPanel Tasmota driver v0.47 | code by blakadder and s-hadinger # Example Flash # FlashNextion http://ip-address-of-your-homeassistant:8123/local/nspanel.tft # FlashNextion http://nspanel.pky.eu/lui.tft class Nextion : Driver static header = bytes('55BB') static flash_block_size = 4096 var flash_mode var flash_start_millis var flash_size var flash_written var flash_buff var flash_offset var flash_proto_version var flash_proto_baud var awaiting_offset var tcp var ser var last_per var url def split_55(b) var ret = [] var s = size(b) var i = s-2 # start from last-1 while i > 0 if b[i] == 0x55 && b[i+1] == 0xBB ret.push(b[i..s-1]) # push last msg to list b = b[(0..i-1)] # write the rest back to b end i -= 1 end ret.push(b) return ret end def crc16(data, poly) if !poly poly = 0xA001 end # CRC-16 MODBUS HASHING ALGORITHM var crc = 0xFFFF for i:0..size(data)-1 crc = crc ^ data[i] for j:0..7 if crc & 1 crc = (crc >> 1) ^ poly else crc = crc >> 1 end end end return crc end # encode using custom protocol 55 BB [payload length] [payload length] [payload] [crc] [crc] def encode(payload) var b = bytes() b += self.header b.add(size(payload), 2) # add size as 2 bytes, little endian b += bytes().fromstring(payload) var msg_crc = self.crc16(b) b.add(msg_crc, 2) # crc 2 bytes, little endian return b end def encodenx(payload) var b = bytes().fromstring(payload) b += bytes('FFFFFF') return b end def sendnx(payload) import string var payload_bin = self.encodenx(payload) self.ser.write(payload_bin) log(string.format("NXP: Nextion command sent = %s",str(payload_bin)), 3) end def send(payload) var payload_bin = self.encode(payload) if self.flash_mode==1 log("NXP: skipped command becuase still flashing", 3) else self.ser.write(payload_bin) log("NXP: payload sent = " + str(payload_bin), 3) end end def write_to_nextion(b) self.ser.write(b) end def screeninit() log("NXP: Screen Initialized") self.sendnx("recmod=1") end def write_block() import string log("FLH: Read block",3) while size(self.flash_buff)<self.flash_block_size && self.tcp.connected() if self.tcp.available()>0 self.flash_buff += self.tcp.readbytes(4096) else tasmota.delay(50) log("FLH: Wait for available...",3) end end log("FLH: Buff size "+str(size(self.flash_buff)),3) var to_write if size(self.flash_buff)>self.flash_block_size to_write = self.flash_buff[0..self.flash_block_size-1] self.flash_buff = self.flash_buff[self.flash_block_size..] else to_write = self.flash_buff self.flash_buff = bytes() end log("FLH: Writing "+str(size(to_write)),3) var per = (self.flash_written*100)/self.flash_size if (self.last_per!=per) self.last_per = per tasmota.publish_result(string.format("{\"Flashing\":{\"complete\": %d, \"time_elapsed\": %d}}",per , (tasmota.millis()-self.flash_start_millis)/1000), "RESULT") end if size(to_write)>0 self.flash_written += size(to_write) self.ser.write(to_write) end log("FLH: Total "+str(self.flash_written),3) if (self.flash_written==self.flash_size) log("FLH: Flashing complete - Time elapsed: %d", (tasmota.millis()-self.flash_start_millis)/1000) self.flash_mode = 0 self.ser.deinit() self.ser = serial(17, 16, 115200, serial.SERIAL_8N1) end end def every_100ms() import string if self.ser.available() > 0 var msg = self.ser.read() if size(msg) > 0 log(string.format("NXP: Received Raw = %s",str(msg)), 3) if (self.flash_mode==1) var strv = msg[0..-4].asstring() if string.find(strv,"comok 2")>=0 tasmota.delay(50) log("FLH: Send (High Speed) flash start") self.flash_start_millis = tasmota.millis() #self.sendnx(string.format("whmi-wris %d,115200,res0",self.flash_size)) if self.flash_proto_version == 0 self.sendnx(string.format("whmi-wri %d,%d,res0",self.flash_size,self.flash_proto_baud)) else self.sendnx(string.format("whmi-wris %d,%d,res0",self.flash_size,self.flash_proto_baud)) end if self.flash_proto_baud != 115200 tasmota.delay(50) self.ser.deinit() self.ser = serial(17, 16, self.flash_proto_baud, serial.SERIAL_8N1) end elif size(msg)==1 && msg[0]==0x08 log("FLH: Waiting offset...",3) self.awaiting_offset = 1 elif size(msg)==4 && self.awaiting_offset==1 self.awaiting_offset = 0 self.flash_offset = msg.get(0,4) log("FLH: Flash offset marker "+str(self.flash_offset),3) if self.flash_offset != 0 self.open_url_at(self.url, self.flash_offset) self.flash_written = self.flash_offset end self.write_block() elif size(msg)==1 && msg[0]==0x05 self.write_block() else log("FLH: Something has gone wrong flashing display firmware ["+str(msg)+"]",2) end else var msg_list = self.split_55(msg) for i:0..size(msg_list)-1 msg = msg_list[i] if size(msg) > 0 if msg == bytes('000000FFFFFF88FFFFFF') self.screeninit() elif size(msg)>=2 && msg[0]==0x55 && msg[1]==0xBB var jm = string.format("{\"CustomRecv\":\"%s\"}",msg[4..-3].asstring()) tasmota.publish_result(jm, "RESULT") elif msg[0]==0x07 && size(msg)==1 # BELL/Buzzer tasmota.cmd("buzzer 1,1") else var jm = string.format("{\"nextion\":\"%s\"}",str(msg[0..-4])) tasmota.publish_result(jm, "RESULT") end end end end end end end def begin_nextion_flash() self.flash_written = 0 self.awaiting_offset = 0 self.flash_offset = 0 self.sendnx('DRAKJHSUYDGBNCJHGJKSHBDN') self.sendnx('recmod=0') self.sendnx('recmod=0') self.flash_mode = 1 self.sendnx("connect") end def open_url_at(url, pos) self.url = url import string var host var port var s1 = string.split(url,7)[1] var i = string.find(s1,":") var sa if i<0 port = 80 i = string.find(s1,"/") sa = string.split(s1,i) host = sa[0] else sa = string.split(s1,i) host = sa[0] s1 = string.split(sa[1],1)[1] i = string.find(s1,"/") sa = string.split(s1,i) port = int(sa[0]) end var get = sa[1] log(string.format("FLH: host: %s, port: %s, get: %s",host,port,get)) self.tcp = tcpclient() self.tcp.connect(host,port) log("FLH: Connected:"+str(self.tcp.connected()),3) var get_req = "GET "+get+" HTTP/1.0\r\n" get_req += string.format("Range: bytes=%d-\r\n", pos) get_req += string.format("HOST: %s:%s\r\n\r\n",host,port) self.tcp.write(get_req) var a = self.tcp.available() i = 1 while a==0 && i<5 tasmota.delay(100*i) tasmota.yield() i += 1 log("FLH: Retry "+str(i),3) a = self.tcp.available() end if a==0 log("FLH: Nothing available to read!",3) return end var b = self.tcp.readbytes() i = 0 var end_headers = false; var headers while i<size(b) && headers==nil if b[i..(i+3)]==bytes().fromstring("\r\n\r\n") headers = b[0..(i+3)].asstring() self.flash_buff = b[(i+4)..] else i += 1 end end #print(headers) # check http respose for code 200/206 if string.find(headers,"200 OK")>0 || string.find(headers,"206 Partial Content")>0 log("FLH: HTTP Respose is 200 OK or 206 Partial Content",3) else log("FLH: HTTP Respose is not 200 OK or 206 Partial Content",3) print(headers) return -1 end # only set flash size if pos is zero if pos == 0 # check http respose for content-length var tag = "Content-Length: " i = string.find(headers,tag) if (i>0) var i2 = string.find(headers,"\r\n",i) var s = headers[i+size(tag)..i2-1] self.flash_size=int(s) end log("FLH: Flash file size: "+str(self.flash_size),3) end end def flash_nextion(url) self.flash_size = 0 var res = self.open_url_at(url, 0) if res != -1 self.begin_nextion_flash() end end def init() log("NXP: Initializing Driver") self.ser = serial(17, 16, 115200, serial.SERIAL_8N1) self.flash_mode = 0 self.flash_proto_version = 1 self.flash_proto_baud = 921600 end end var nextion = Nextion() tasmota.add_driver(nextion) def get_current_version(cmd, idx, payload, payload_json) import string var version_of_this_script = 9 var jm = string.format("{\"nlui_driver_version\":\"%s\"}", version_of_this_script) tasmota.publish_result(jm, "RESULT") end tasmota.add_cmd('GetDriverVersion', get_current_version) def update_berry_driver(cmd, idx, payload, payload_json) def task() import path import string if string.find(payload, ".tapp") > 0 print("tapp in URL; will do .tapp update and migration if necessary") if path.exists("autoexec.be") print("autoexec.be found; will check for migration") var autoexecfile = open('autoexec.be') var line = autoexecfile.readline() autoexecfile.close() if string.find(line, "NSPanel Tasmota Lovelace UI Berry Driver") > 0 print("found lovelace berry driver, going to delete autoexec.be and .bec") path.remove("autoexec.be") path.remove("autoexec.bec") end end var r = tasmota.urlfetch(payload, "nsp-lovelace-driver.tapp") if r < 0 print("Update failed") else tasmota.cmd("Restart 1") end elif string.find(payload, ".be") > 0 print("be in URL; will do .be update") if path.exists("nsp-lovelace-driver.tapp") print("Error: there is the tapp version of the berry driver installed; cannot do .be update.") else var cl = webclient() cl.begin(payload) var r = cl.GET() if r == 200 print("Sucessfully downloaded nspanel-lovelace-ui berry driver") else print("Error while downloading nspanel-lovelace-ui berry driver") end r = cl.write_file("autoexec.be") if r < 0 print("Error while writeing nspanel-lovelace-ui berry driver") else print("Sucessfully written nspanel-lovelace-ui berry driver") tasmota.cmd("Restart 1") end end else print("invalid url filetype") end if path.exists("nsp-lovelace-driver.tapp") var r = string.find(payload, ".tapp") if r < 0 print("URL doesn't contain .tapp skipping update") else end else var r = string.find(payload, ".be") if r < 0 print("URL doesn't contain .be skipping update") else end end end tasmota.set_timer(0,task) tasmota.resp_cmnd_done() end tasmota.add_cmd('UpdateDriverVersion', update_berry_driver) def flash_nextion(cmd, idx, payload, payload_json) def task() nextion.flash_proto_version = 1 nextion.flash_proto_baud = 921600 nextion.flash_nextion(payload) end tasmota.set_timer(0,task) tasmota.resp_cmnd_done() end def flash_nextion_adv(cmd, idx, payload, payload_json) def task() if idx==0 nextion.flash_proto_version = 1 nextion.flash_proto_baud = 921600 elif idx==1 nextion.flash_proto_version = 0 nextion.flash_proto_baud = 921600 elif idx==2 nextion.flash_proto_version = 1 nextion.flash_proto_baud = 115200 elif idx==3 nextion.flash_proto_version = 0 nextion.flash_proto_baud = 115200 elif idx==4 nextion.flash_proto_version = 1 nextion.flash_proto_baud = 256000 elif idx==5 nextion.flash_proto_version = 0 nextion.flash_proto_baud = 256000 elif idx==6 nextion.ser.deinit() nextion.ser = serial(17, 16, 9600, serial.SERIAL_8N1) nextion.flash_proto_version = 0 nextion.flash_proto_baud = 921600 else nextion.flash_proto_version = 0 nextion.flash_proto_baud = 115200 end nextion.flash_nextion(payload) end tasmota.set_timer(0,task) tasmota.resp_cmnd_done() end def send_cmd(cmd, idx, payload, payload_json) nextion.sendnx(payload) tasmota.resp_cmnd_done() end def send_cmd2(cmd, idx, payload, payload_json) nextion.send(payload) tasmota.resp_cmnd_done() end tasmota.add_cmd('Nextion', send_cmd) tasmota.add_cmd('CustomSend', send_cmd2) tasmota.add_cmd('FlashNextion', flash_nextion) tasmota.add_cmd('FlashNextionAdv', flash_nextion_adv)
                          javascript.0	18:20:28.835	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online display firmware version => 53
                          javascript.0	18:20:28.852	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: {"nlui_driver_version":"9"}
                          javascript.0	18:20:28.855	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: current tasmota firmware version => 14.3.0
                          javascript.0	18:20:28.855	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: online berry driver version => 9
                          javascript.0	18:20:28.882	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: current berry driver version => 9
                          javascript.0	18:20:28.926	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: hidden Cards disabled
                          javascript.0	18:20:29.007	info	script.js.common.NSPanel.NSPanel_WZ_4_4_0_11_KeT: {"url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/releases/149090497","assets_url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/releases/149090497/assets","upload_url":"https://uploads.github.com/repos/joBr99/nspanel-lovelace-ui/releases/149090497/assets{?name,label}","html_url":"https://github.com/joBr99/nspanel-lovelace-ui/releases/tag/v4.4.0","id":149090497,"author":{"login":"joBr99","id":29555657,"node_id":"MDQ6VXNlcjI5NTU1NjU3","avatar_url":"https://avatars.githubusercontent.com/u/29555657?v=4","gravatar_id":"","url":"https://api.github.com/users/joBr99","html_url":"https://github.com/joBr99","followers_url":"https://api.github.com/users/joBr99/followers","following_url":"https://api.github.com/users/joBr99/following{/other_user}","gists_url":"https://api.github.com/users/joBr99/gists{/gist_id}","starred_url":"https://api.github.com/users/joBr99/starred{/owner}{/repo}","subscriptions_url":"https://api.github.com/users/joBr99/subscriptions","organizations_url":"https://api.github.com/users/joBr99/orgs","repos_url":"https://api.github.com/users/joBr99/repos","events_url":"https://api.github.com/users/joBr99/events{/privacy}","received_events_url":"https://api.github.com/users/joBr99/received_events","type":"User","user_view_type":"public","site_admin":false},"node_id":"RE_kwDOGo1zRM4I4vDB","tag_name":"v4.4.0","target_commitish":"main","name":"v4.4.0 - Update for HA 2024.04","draft":false,"prerelease":false,"created_at":"2024-03-30T11:18:31Z","published_at":"2024-03-30T12:26:37Z","assets":[],"tarball_url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/tarball/v4.4.0","zipball_url":"https://api.github.com/repos/joBr99/nspanel-lovelace-ui/zipball/v4.4.0","body":"## Besides the Update of the App in HACS you need to do the following things:\r\n\r\n🔄 **Restart the AppDaemon Container**\r\n\r\n**Add the following workaround to your Home Assistant configuration.yaml**\r\n\r\nhttps://docs.nspanel.pky.eu/stable/prepare_ha/#workaround-for-homeassistant-202404\r\n\r\n🔄 **Restart Home Assistant**\r\n\r\n## New Features:\r\n\r\n- **Implemented changes to work with upcoming Homeassistant Version 2024.04 @joBr99**\r\n","mentions_count":1}
                          • K Kerschte_de
                            @tt-tom
                            import apis
                            import json
                                    version     = "v4.3.3"
                                    if model == "us-l":
                                    else:
                                # helpers
                                @property
                            # based on;
                            # based on;
                            # Example Flash
                                var flash_mode
                                var flash_size
                                var flash_written
                                var flash_buff
                                var flash_offset
                                var awaiting_offset
                                var tcp
                                var ser
                                var last_per
                                var url
                                def split_55(b)
                                  var ret = []
                                  var s = size(b)
                                  while i > 0
                                    end
                                    i -= 1
                                  end
                                  ret.push(b)
                                  return ret
                                end
                                  var crc = 0xFFFF
                                    crc = crc ^ data[i]
                                    for j:0..7
                                      if crc & 1
                                      else
                                        crc = crc >> 1
                                      end
                                    end
                                  end
                                  return crc
                                end
                                def encode(payload)
                                  var b = bytes()
                                  b += self.header
                                  return b
                                end
                                    return b
                                end
                                def sendnx(payload)
                                    import string
                                end
                                def send(payload)
                                    else
                                    end
                                end
                                    self.ser.write(b)
                                end
                                def screeninit()
                                end
                                def write_block()
                                    import string
                                        else
                                            tasmota.delay(50)
                                        end
                                    end
                                    var to_write
                                    else
                                    end
                                        self.last_per = per
                                    end
                                    if size(to_write)>0
                                    end
                                        self.flash_mode = 0
                                        self.ser.deinit()
                                    end
                                end
                                def every_100ms()
                                    import string
                                        if size(msg) > 0
                                                    tasmota.delay(50)
                                                    else
                                                    end
                                                        tasmota.delay(50)
                                                        self.ser.deinit()
                                                    end
                                                    end
                                                    self.write_block()
                                                    self.write_block()
                                                else
                                                end
                                            else
                                                    msg = msg_list[i]
                                                    if size(msg) > 0
                                                            self.screeninit()
                                                        else
                                                        end
                                                    end
                                                end
                                            end
                                        end
                                    end
                                end
                                    self.flash_mode = 1
                                end
                                    self.url = url
                                    import string
                                    var host
                                    var port
                                    var sa
                                    if i<0
                                        port = 80
                                        host = sa[0]
                                    else
                                        host = sa[0]
                                        port = int(sa[0])
                                    end
                                    var get = sa[1]
                                    i = 1
                                    while a==0 && i<5
                                      tasmota.yield()
                                      i += 1
                                    end
                                    if a==0
                                        return
                                    end
                                    i = 0
                                    var headers
                                        else
                                            i += 1
                                        end
                                    end
                                    #print(headers)
                                    else
                                        print(headers)
                                        return -1
                                    end
                                    if pos == 0
                                        if (i>0)
                                        end
                                    end
                                end
                                    self.flash_size = 0
                                    if res != -1
                                    end
                                end
                                def init()
                                    self.flash_mode = 0
                                end
                            end
                                import string
                            end
                                def task()
                                    import path
                                    import string
                            				end
                            			end
                                        if r < 0
                                        else
                                        end
                            			else
                                            cl.begin(payload)
                                            var r = cl.GET()
                                            if r == 200
                                            else
                                            end
                                            if r < 0
                                            else
                                            end
                            			end
                            		else
                            		end
                                        if r < 0
                                        else
                                        end
                                    else
                                        if r < 0
                                        else
                                        end
                                    end
                                end
                            end
                                def task()
                                end
                            end
                                def task()
                                    if idx==0
                                    elif idx==1
                                    elif idx==2
                                    elif idx==3
                                    elif idx==4
                                    elif idx==5
                                    elif idx==6
                                    else
                                    end
                                end
                            end
                            end
                            end
                            TT-Tom
                            #6649
                            @kerschte_de
                            aus dem Script diese Zeilen zeigen und ein Screenshot vom MQTT baum des Panel
                            // DE: Anpassen an die Verzeichnisse der MQTT-Adapter-Instanz
                            // EN: Adapt to the MQTT adapter instance directories
                            const NSPanelReceiveTopic: string = 'mqtt.0.SmartHome.NSPanel_1.tele.RESULT';
                            const NSPanelSendTopic: string = 'mqtt.0.SmartHome.NSPanel_1.cmnd.CustomSend';
                            Gruß Tom
                            Public Transport
                            NSPanel Adapter Wiki
                            • K Kerschte_de
                              @kerschte_de
                              TT-Tom
                              #6650
                              @kerschte_de
                              kannst zurück setzen
                              Gruß Tom
                              Public Transport
                              • T TT-Tom
                                @kerschte_de
                                Kerschte_de
                                #6651
                                @tt-tom
                                ... ja, mache ich:
                                /***** 1. Tasmota-Config *****/
                                    const NSPanelReceiveTopic: string = 'mqtt.0.RagowSmartHome.NSPanel_85C180.tele.RESULT';
                                    const NSPanelSendTopic: string = 'mqtt.0.RagowSmartHome.NSPanel_85C180.cmnd.CustomSend';
                                    // DE: nur ändern, falls der User im Tasmota vor dem Kompilieren umbenannt wurde (Standard Tasmota: admin)
                                    // EN: only change if the user was renamed in Tasmota before compiling (default Tasmota: admin)
                                    const tasmota_web_admin_user: string = 'admin';
                                    // DE: setzten, falls "Web Admin Password" in Tasmota vergeben
                                    // EN set if "Web Admin Password" is assigned in Tasmota
                                    const tasmota_web_admin_password: string = '';
                                    // DE: Setzen der bevorzugten Tasmota32-Version (für Updates)
                                    // EN: Set preferred Tasmota32 version (for updates)
                                    const tasmotaOtaVersion: string = 'tasmota32-DE.bin';
                                        // DE: Es können ebenfalls andere Versionen verwendet werden wie zum Beispiel:
                                        // EN: Other versions can also be used, such as:
                                        // 'tasmota32-nspanel.bin' or 'tasmota32.bin' or 'tasmota32-DE.bin' or etc.
                                • K Kerschte_de
                                  @tt-tom
                                  ... ja, mache ich:
                                  TT-Tom
                                  #6652
                                  @kerschte_de
                                  der tele fehlt, der ist entscheidend
                                  Gruß Tom
                                  Public Transport
                                  • T TT-Tom
                                    @kerschte_de
                                    Kerschte_de
                                    #6653
                                    @tt-tom ... oh, sorry.
                                    • K Kerschte_de
                                      TT-Tom
                                      #6654
                                      @kerschte_de
                                      okay hier stimmt alles, jetzt bitte die Config einer Seite wo keine Werte kommen und den passenden Objektbaum vom ioBroker
                                      Gruß Tom
                                      Public Transport
                                      K 2 Antworten Letzte Antwort
                                      • T TT-Tom
                                        @kerschte_de
                                        Kerschte_de
                                        #6655
                                        @tt-tom ja, gern.
                                        Die Hauptseite ("HOME") dient der Navigation auf Unterseiten. Aktuell habe ich nur noch die im Erdgeschoss aktiv. Dort sind testweise 2 Temperatur-Sensoren verlinkt ... es kommt jedoch nichts an Werten an. Die Seiten selbst funktionieren alle ... so auch wie der Screensaver und das komplette Service-Menu:
                                        //-- Anfang für eigene Seiten -- z.T. selbstdefinierte Aliase erforderlich ----------------
                                        //-- Start for your own pages -- some self-defined aliases required ----------------
                                            //-- https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Page-%E2%80%90-Typen_How-2_Beispiele
                                        //-- ##### ##### ##### KERSTEN #### ##### #####
                                        //Level 0
                                        let Navigation1: PageType =
                                            'type': 'cardGrid',
                                            'heading': 'HOME',
                                            'useColor': true,
                                            'items': [
                                                /*PageItem*/{ navigate: true, id: 'SensorenEG', icon: 'home-floor-0',offColor: Menu, onColor: Menu, name: 'Sensoren EG'},
                                                //*PageItem*/{ navigate: true, id: 'SensorenOG', icon: 'home-floor-1',offColor: Menu, onColor: Menu, name: 'Sensoren OG'},
                                                //*PageItem*/{ navigate: true, id: 'SensorenKeller', icon: 'home-floor-negative-1',offColor: Menu, onColor: Menu, name: 'Sensoren Keller'},
                                                /*PageItem*/{ navigate: true, id: 'NSPanel_Service', icon: 'hammer-screwdriver',offColor: Menu, onColor: Menu, name: 'ServiceMenu'},
                                                //{ id: 'alias.0.NSPanel_1.TestFenster', offColor: MSRed, onColor: MSGreen, name: 'Büro Fenster'},
                                                //{ id: 'alias.0.NSPanel_1.Luftreiniger', icon: 'power', offColor: MSRed, onColor: MSGreen},
                                                //{ id: 'alias.0.NSPanel_1.TestBlind', icon: 'projector-screen', onColor: White, name: 'Beamer', secondRow: 'auch Text'},
                                                //{ id: 'alias.0.NSPanel_1.Kippfenster', useValue: true }
                                             //Level 1
                                             let SensorenEG: PageType =
                                                 'type': 'cardGrid',
                                                 'heading': 'Zigbee-Geräte EG',
                                                 'useColor': true,
                                                 'subPage': true,
                                                 'parent': Navigation1,
                                                 'items': [
                                                     { id: 'alias.0.NSPanel.1.1_Haus.EG.TempWZ.ACTUAL', name: 'WZ Temp.°C', offColor: MSRed, onColor: MSGreen, useValue: true, fontSize: 3, colorScale: {'val_min': 15, 'val_max': 35, 'val_best': 21} },
                                                     { id: 'alias.0.NSPanel.1.1_Haus.EG.TempWZ.SECOND', name: 'WZ Luft %', offColor: MSYellow, onColor: MSYellow , useValue: true, fontSize: 3, colorScale: {'val_min': 30, 'val_max': 100, 'val_best': 60} },
                                                     { id: 'alias.0.NSPanel.1.1_Haus.EG.TempKueche.ACTUAL', name: 'Küche Temp.°C', offColor: MSRed, onColor: MSGreen, useValue: true, fontSize: 3, colorScale: {'val_min': 15, 'val_max': 35, 'val_best': 21} },
                                                     { id: 'alias.0.NSPanel.1.1_Haus.EG.TempKueche.SECOND', name: 'Küche Luft %', offColor: MSYellow, onColor: MSYellow , useValue: true, fontSize: 3, colorScale: {'val_min': 30, 'val_max': 100, 'val_best': 60} },
                                        //-- ENDE für eigene Seiten -- z.T. selbstdefinierte Aliase erforderlich -------------------------
                                        Hier noch die Einbindung der Seiten selbst:
                                         **                           Configuration                           **
                                        export const config: Config = {
                                            // Seiteneinteilung / Page division
                                            // Hauptseiten / Mainpages
                                            pages: [
                                                Navigation1,
                                                //NSPanel_Service, //Auto-Alias Service Page
                                                //Unlock_Service            //Auto-Alias Service Page (Service Pages used with cardUnlock)
                                            // Unterseiten / Subpages
                                            subPages: [
                                                SensorenEG, // --> KeT hinzugefügt
                                                NSPanel_Service, //Auto-Alias Service Page --> KeT von der Hauptseite auf die Sub-Seite verschoben (über Auskommentierung)
                                                NSPanel_Service_SubPage, //Auto-Alias Service Page (only used with cardUnlock)
                                                NSPanel_Infos, //Auto-Alias Service Page
                                                NSPanel_Wifi_Info_1, //Auto-Alias Service Page
                                                NSPanel_Wifi_Info_2, //Auto-Alias Service Page
                                                NSPanel_Sensoren, //Auto-Alias Service Page
                                                NSPanel_Hardware, //Auto-Alias Service Page
                                                NSPanel_IoBroker, //Auot-Alias Service Page
                                                NSPanel_Einstellungen, //Auto-Alias Service Page
                                                NSPanel_Screensaver, //Auto-Alias Service Page
                                                NSPanel_ScreensaverDimmode, //Auto-Alias Service Page
                                                NSPanel_ScreensaverBrightness, //Auto-Alias Service Page
                                                NSPanel_ScreensaverLayout, //Auto-Alias Service Page
                                                NSPanel_ScreensaverWeather, //Auto-Alias Service Page
                                                NSPanel_ScreensaverDateformat, //Auto-Alias Service Page
                                                NSPanel_ScreensaverIndicators, //Auto-Alias Service Page
                                                NSPanel_Relays, //Auto-Alias Service Page
                                                NSPanel_Script, //Auto-Alias Service Page
                                                NSPanel_Firmware, //Auto-Alias Service Page
                                                NSPanel_FirmwareTasmota, //Auto-Alias Service Page
                                                NSPanel_FirmwareBerry, //Auto-Alias Service Page
                                                NSPanel_FirmwareNextion, //Auto-Alias Service Page
                                        und hier der Sreenshot der beiden Temperatur-Sensoren:
                                        • T TT-Tom
                                          @kerschte_de
                                          Kerschte_de
                                          #6656
                                          @tt-tom
                                          Das Konstrukt hatte in der alten Umgebung funktioniert. Testweise hatte ich es auf etliche Sensoren in den unterschiedlichen Etagen mal aufgebaut. Aktuell funktionieren die Seiten weiterhin, nur die Inhalte der Sensoren werden nicht transferiert.
