Grafana per Browser nicht mehr erreichbar
@crunchip said in Grafana per Browser nicht mehr erreichbar:
sudo systemctl status grafana-server
Da kommt failed:
The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Sat Dec 14 12:50:58 2024 from 192.168.178.15 Wi-Fi is currently blocked by rfkill. Use raspi-config to set the country before use. Henning@Henning:~ $ sudo systemctl status grafana-server × grafana-server.service - Grafana instance Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; prese> Active: failed (Result: exit-code) since Sat 2024-12-14 13:15:06 CET; 8min> Duration: 111ms Docs: http://docs.grafana.org Process: 3663 ExecStart=/usr/share/grafana/bin/grafana server --config=${CO> Main PID: 3663 (code=exited, status=1/FAILURE) CPU: 141ms Dec 14 13:15:06 Henning systemd[1]: grafana-server.service: Scheduled restart j> Dec 14 13:15:06 Henning systemd[1]: Stopped grafana-server.service - Grafana in> Dec 14 13:15:06 Henning systemd[1]: grafana-server.service: Start request repea> Dec 14 13:15:06 Henning systemd[1]: grafana-server.service: Failed with result > Dec 14 13:15:06 Henning systemd[1]: Failed to start grafana-server.service - Gr> lines 1-14/14 (END) -
Mach das Mäusekino mal auf Breitformat.
Dann sieht man auch mehr von den Meldugen.sorry, jetzt auch gesehen:
Henning@Henning:~ $ sudo systemctl status grafana-server × grafana-server.service - Grafana instance Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; preset: enabled) Active: failed (Result: exit-code) since Sat 2024-12-14 13:30:29 CET; 17min ago Duration: 121ms Docs: http://docs.grafana.org Process: 4521 ExecStart=/usr/share/grafana/bin/grafana server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=deb cfg:default.paths.logs=${LOG_DIR} cfg:d> Main PID: 4521 (code=exited, status=1/FAILURE) CPU: 147ms Dec 14 13:30:29 Henning systemd[1]: grafana-server.service: Main process exited, code=exited, status=1/FAILURE Dec 14 13:30:29 Henning systemd[1]: grafana-server.service: Failed with result 'exit-code'. Dec 14 13:30:29 Henning systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5. Dec 14 13:30:29 Henning systemd[1]: Stopped grafana-server.service - Grafana instance. Dec 14 13:30:29 Henning systemd[1]: grafana-server.service: Start request repeated too quickly. Dec 14 13:30:29 Henning systemd[1]: grafana-server.service: Failed with result 'exit-code'. Dec 14 13:30:29 Henning systemd[1]: Failed to start grafana-server.service - Grafana instance. lines 1-16/16 (END) -
Henning@Henning:~ $ sudo systemctl status grafana-server × grafana-server.service - Grafana instance Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; preset: enabled) Active: failed (Result: exit-code) since Sat 2024-12-14 13:30:29 CET; 17min ago Duration: 121ms Docs: http://docs.grafana.org Process: 4521 ExecStart=/usr/share/grafana/bin/grafana server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=deb cfg:default.paths.logs=${LOG_DIR} cfg:d> Main PID: 4521 (code=exited, status=1/FAILURE) CPU: 147ms Dec 14 13:30:29 Henning systemd[1]: grafana-server.service: Main process exited, code=exited, status=1/FAILURE Dec 14 13:30:29 Henning systemd[1]: grafana-server.service: Failed with result 'exit-code'. Dec 14 13:30:29 Henning systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5. Dec 14 13:30:29 Henning systemd[1]: Stopped grafana-server.service - Grafana instance. Dec 14 13:30:29 Henning systemd[1]: grafana-server.service: Start request repeated too quickly. Dec 14 13:30:29 Henning systemd[1]: grafana-server.service: Failed with result 'exit-code'. Dec 14 13:30:29 Henning systemd[1]: Failed to start grafana-server.service - Grafana instance. lines 1-16/16 (END)Da wird der Service zu schnell versucht wieder herzustellen.
Das kann eine Folge von falschen Token / Passworten sein.
Dann startet der nämlich durch und ein Neustart wird versucht. -
Dann startet der nämlich durch und ein Neustart wird versucht.und wie kann ich das unterbinden oder reparieren?
@martinp said in Grafana per Browser nicht mehr erreichbar:
/var/log/grafana/grafana.log
da kommt das hier:
Henning@Henning:~ $ /var/log/grafana/grafana.log -bash: /var/log/grafana/grafana.log: Permission denied@gmt94 sagte in Grafana per Browser nicht mehr erreichbar:
-bash: /var/log/grafana/grafana.log: Permission deniedless /var/log/grafana/grafana.logwäre ein richtiges Kommando an der Stelle.
@thomas-braun said in Grafana per Browser nicht mehr erreichbar:
Henning@Henning:~ $ less /var/log/grafana/grafana.log /var/log/grafana/grafana.log: Permission denied Henning@Henning:~ $ -
Richtiges PW verwenden (wenn es denn an den Credentials liegt)
@gmt94 dass die Grafana log files von einem normalen User nicht gelesen dürfen ist merkwürdig.
Versuche es mal mit vorangestelltem sudoHenning@Henning:~ $ sudo less /var/log/grafana/grafana.log logger=settings t=2024-12-14T11:42:28.980263952+01:00 level=info msg="Starting Grafana" version=11.2.0 commit=c57667e4481563f5e6cf945b03bc0626caa4dbeb branch=HEAD compiled=2024-12-14T11:42:28+01:00 logger=settings t=2024-12-14T11:42:28.980816251+01:00 level=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini logger=settings t=2024-12-14T11:42:28.980858548+01:00 level=info msg="Config loaded from" file=/etc/grafana/grafana.ini logger=settings t=2024-12-14T11:42:28.980869288+01:00 level=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana" logger=settings t=2024-12-14T11:42:28.980878807+01:00 level=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana" logger=settings t=2024-12-14T11:42:28.98088664+01:00 level=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins" logger=settings t=2024-12-14T11:42:28.980894752+01:00 level=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning" logger=settings t=2024-12-14T11:42:28.980903381+01:00 level=info msg=Target target=[all] logger=settings t=2024-12-14T11:42:28.980925752+01:00 level=info msg="Path Home" path=/usr/share/grafana logger=settings t=2024-12-14T11:42:28.980933085+01:00 level=info msg="Path Data" path=/var/lib/grafana logger=settings t=2024-12-14T11:42:28.980940363+01:00 level=info msg="Path Logs" path=/var/log/grafana logger=settings t=2024-12-14T11:42:28.980947733+01:00 level=info msg="Path Plugins" path=/var/lib/grafana/plugins logger=settings t=2024-12-14T11:42:28.98100553+01:00 level=info msg="Path Provisioning" path=/etc/grafana/provisioning logger=settings t=2024-12-14T11:42:28.981014345+01:00 level=info msg="App mode production" logger=featuremgmt t=2024-12-14T11:42:28.981466069+01:00 level=info msg=FeatureToggles lokiQueryHints=true alertingNoDataErrorExecution=true prometheusDataplane=true topnav=true prometheusConfigOverhaulAuth=true logsContextDatasourceUi=true addFieldFromCalculationStatFunctions=true logsExploreTableVisualisation=true annotationPermissionUpdate=true recordedQueriesMulti=true managedPluginsInstall=true dashgpt=true alertingSimplifiedRouting=true angularDeprecationUI=true nestedFolders=true prometheusAzureOverrideAudience=true transformationsRedesign=true recoveryThreshold=true cloudWatchRoundUpEndTime=true lokiStructuredMetadata=true transformationsVariableSupport=true groupToNestedTableTransformation=true dataplaneFrontendFallback=true prometheusMetricEncyclopedia=true awsAsyncQueryCaching=true logsInfiniteScrolling=true formatString=true logRowsPopoverMenu=true correlations=true exploreMetrics=true tlsMemcached=true panelMonitoring=true publicDashboards=true influxdbBackendMigration=true ssoSettingsApi=true cloudWatchNewLabelParsing=true alertingInsights=true cloudWatchCrossAccountQuerying=true lokiMetricDataplane=true autoMigrateXYChartPanel=true lokiQuerySplitting=true kubernetesPlaylists=true logger=sqlstore t=2024-12-14T11:42:28.981636774+01:00 level=info msg="Connecting to DB" dbtype=sqlite3 logger=sqlstore t=2024-12-14T11:42:28.981669422+01:00 level=info msg="Creating SQLite database file" path=/var/lib/grafana/grafana.db logger=migrator t=2024-12-14T11:42:28.984510714+01:00 level=info msg="Locking database" logger=migrator t=2024-12-14T11:42:28.984566955+01:00 level=info msg="Starting DB migrations" logger=migrator t=2024-12-14T11:42:28.985813369+01:00 level=info msg="Executing migration" id="create migration_log table" logger=migrator t=2024-12-14T11:42:28.988262455+01:00 level=info msg="Migration successfully executed" id="create migration_log table" duration=2.446456ms logger=migrator t=2024-12-14T11:42:28.994678727+01:00 level=info msg="Executing migration" id="create user table" logger=migrator t=2024-12-14T11:42:28.996875479+01:00 level=info msg="Migration successfully executed" id="create user table" duration=2.195715ms logger=migrator t=2024-12-14T11:42:29.00007505+01:00 level=info msg="Executing migration" id="add unique index user.login" logger=migrator t=2024-12-14T11:42:29.001292001+01:00 level=info msg="Migration successfully executed" id="add unique index user.login" duration=1.218414ms logger=migrator t=2024-12-14T11:42:29.005608041+01:00 level=info msg="Executing migration" id="add unique index user.email" logger=migrator t=2024-12-14T11:42:29.006858899+01:00 level=info msg="Migration successfully executed" id="add unique index user.email" duration=1.251839ms logger=migrator t=2024-12-14T11:42:29.009465189+01:00 level=info msg="Executing migration" id="drop index UQE_user_login - v1" logger=migrator t=2024-12-14T11:42:29.010295879+01:00 level=info msg="Migration successfully executed" id="drop index UQE_user_login - v1" duration=831.004µs logger=migrator t=2024-12-14T11:42:29.016269779+01:00 level=info msg="Executing migration" id="drop index UQE_user_email - v1" logger=migrator t=2024-12-14T11:42:29.017043171+01:00 level=info msg="Migration successfully executed" id="drop index UQE_user_email - v1" duration=773.207µs logger=migrator t=2024-12-14T11:42:29.019526258+01:00 level=info msg="Executing migration" id="Rename table user to user_v1 - v1" logger=migrator t=2024-12-14T11:42:29.022404809+01:00 level=info msg="Migration successfully executed" id="Rename table user to user_v1 - v1" duration=2.876588ms logger=migrator t=2024-12-14T11:42:29.025288416+01:00 level=info msg="Executing migration" id="create user table v2" logger=migrator t=2024-12-14T11:42:29.026734701+01:00 level=info msg="Migration successfully executed" id="create user table v2" duration=1.445748ms logger=migrator t=2024-12-14T11:42:29.02972879+01:00 level=info msg="Executing migration" id="create index UQE_user_login - v2" logger=migrator t=2024-12-14T11:42:29.030753554+01:00 level=info msg="Migration successfully executed" id="create index UQE_user_login - v2" duration=1.026264ms logger=migrator t=2024-12-14T11:42:29.0333339+01:00 level=info msg="Executing migration" id="create index UQE_user_email - v2" logger=migrator t=2024-12-14T11:42:29.034199608+01:00 level=info msg="Migration successfully executed" id="create index UQE_user_email - v2" duration=865.486µs logger=migrator t=2024-12-14T11:42:29.036884585+01:00 level=info msg="Executing migration" id="copy data_source v1 to v2" logger=migrator t=2024-12-14T11:42:29.037544273+01:00 level=info msg="Migration successfully executed" id="copy data_source v1 to v2" duration=658.744µs logger=migrator t=2024-12-14T11:42:29.040558918+01:00 level=info msg="Executing migration" id="Drop old table user_v1" logger=migrator t=2024-12-14T11:42:29.04135607+01:00 level=info msg="Migration successfully executed" id="Drop old table user_v1" duration=797.319µs logger=migrator t=2024-12-14T11:42:29.044195213+01:00 level=info msg="Executing migration" id="Add column help_flags1 to user table" logger=migrator t=2024-12-14T11:42:29.045865592+01:00 level=info msg="Migration successfully executed" id="Add column help_flags1 to user table" duration=1.669638ms logger=migrator t=2024-12-14T11:42:29.048629254+01:00 level=info msg="Executing migration" id="Update user table charset" logger=migrator t=2024-12-14T11:42:29.048692606+01:00 level=info msg="Migration successfully executed" id="Update user table charset" duration=65.316µs /var/log/grafana/grafana.log -
ja okay, wo soll ich das richtige PW eingeben? Sorry ich stehe da gerade auf dem Schlauch
Keine Ahnung. Ich verwende kein grafana.
@gmt94 lösch doch nochmal grafana, vllt hatte es vorhin nicht funktioniert und die fehlerhafte config, bzw Datenbank war noch vorhanden, dann kommt ebenfalls die Meldung
Als ich jedoch in der grafana.ini Einstellungen für die Vis geändert habe und im Anschluss den Service neu gestartet habe, komme ich über den 3000 Port nicht auf mehr drauf.
Kurz zurück zur Ursache: Wie du es bescheibst, hast du ganz offensichtlich einen Fehler in die ini eingebaut, der dann ein Starten verhinderte. Also in Zukunft vorher ein Backup der Datei machen, die man editiert, damit man in Sekunden wieder zurück kann.
Das bringt dir jetzt natürlich nichts mehr viel.
Was auch komisch ist bzw. War, ist dass nach der neuen Installation, die Änderungen in der Ini noch vorhanden waren. Die müssten doch eigentlich dort nicht mehr drauf sein oder?
Ich habe mein altes lauffähige System noch auf der SD Karte. Wie kann ich dort die Ini exportieren und hier einügen?
Das würde ich so nicht unterschreiben. Je nach Art der Neu-/Deinstallation bleiben die Konfigurationsdateien erhalten, was ja auch gut sein KANN.
