  4. Tahoma Adapter - Funktioniert er bei euch noch?
    6.6k
14 Beiträge 4 Kommentatoren 1.3k Aufrufe 4 Beobachtet
  • M Matt77CHE
    Seit wohl einigen Tagen scheint bei mir der Tahoma Adapter nicht mehr zu funktionieren;
    tahoma.0
    2024-12-07 09:30:44.154	warn	error during request: Error: connect ECONNREFUSED 192.168.1.93:8443, request path: setup/gateways with payload:{}
    tahoma.0
    2024-12-07 09:30:44.139	debug	GET request on https://gateway-2048-4815-4750.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
    tahoma.0
    2024-12-07 09:30:44.139	debug	Update gateway status for id undefined
    tahoma.0
    2024-12-07 09:30:14.138	warn	error during request: Error: connect ECONNREFUSED 192.168.1.93:8443, request path: setup/gateways with payload:{}
    tahoma.0
    2024-12-07 09:30:14.098	debug	GET request on https://gateway-2048-4815-4750.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
    tahoma.0
    2024-12-07 09:30:14.098	debug	Update gateway status for id undefined
    tahoma.0
    2024-12-07 09:30:04.185	warn	{"error":{"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.93","port":8443}}
    tahoma.0
    2024-12-07 09:30:04.185	warn	setup failed!
    tahoma.0
    2024-12-07 09:30:04.184	warn	error during request: Error: connect ECONNREFUSED 192.168.1.93:8443, request path: setup with payload:{}
    tahoma.0
    2024-12-07 09:30:04.149	debug	stateChange tahoma.0.update {"val":false,"ack":true,"ts":1733560204147,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1733508840950}
    tahoma.0
    2024-12-07 09:30:04.148	debug	stateChange tahoma.0.info.connection {"val":true,"ack":true,"ts":1733560204147,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1733560204147}
    tahoma.0
    2024-12-07 09:30:04.098	debug	GET request on https://gateway-2048-4815-4750.local:8443/enduser-mobile-web/1/enduserAPI/setup with payload:{}
    tahoma.0
    2024-12-07 09:30:04.097	info	Using stored bearer token 6618c48391938be89f0d
    tahoma.0
    2024-12-07 09:30:04.096	info	Adapter will connect to Tahoma Box via local API.
    tahoma.0
    2024-12-07 09:30:04.095	debug	[START] Started Adapter
    Der Adapter ist auf grün.
    Keine Reaktion der Storen, wenn ich versuche sie anzusteuern über den Adapter.
    Sie funktionieren über die Fernbedienung und über die App.
    Der Developer-Mode der Box ist noch aktiv.
    Matt77CHE
    .... Auf Github habe ein Issue angelegt - wird der Adapter überhaupt noch gepflegt, oder gäbe es Alternativen?
    • haus-automatisierungH Offline
      @matt77che Siehe
      https://forum.iobroker.net/topic/43907/tahoma-adapter-noch-gewartet-weiterentwickelt
      Der Adapter wurde wohl damals übergeben und die letzte Version ist ja von April. Sieht also ganz okay aus, oder?
      📚 Meine Dokumentation
        @matt77che Siehe
        Matt77CHE
        @haus-automatisierung sagte in Tahoma Adapter - Funktioniert er bei euch noch?:
        @matt77che Siehe
        ... dann hoffe ich auf eine baldige Lösung des Problems....🤞
          @matt77che sagte in Tahoma Adapter - Funktioniert er bei euch noch?:
          Ich kenne mich mit dem System nicht aus, aber anscheinend werden ja alle Anfragen abgelehnt
          Nicht dass da (mit einem Update?) der Port dich gemacht wurde.
          • M Matt77CHE
            @matt77che Siehe
            mcm1957M Online
            mcm1957M Online
            mcm1957
            @matt77che
            Also bei mir funktioniert der Adapter.
            ioBroker.tohoma 0.10.4
            Tohoma Switch FW 2024.4.3-12 (lt. ioBroker)
            Ich benutze allerdings nicht die local connection (war mir bisher gar nicht bewusst dass es die gibt) sondern die Cloud.
            Support Repositoryverwaltung.
            LESEN - gute Forenbeitrage
              Matt77CHE
              @mcm1957
              ioBroker.tahoma 0.10.4
              Bei mir ist es die 2024.5.4-13
              Hat aber mit dieser Version bis vor einigen Tagen funktioniert
              ... Aber wenn da etwas dicht wäre, wäre der Adapter trotzdem auf grün und in den Objekten der Status "online"?
              Und über die App habe ich auch Verbindung zum Tahoma Switch....
              • M Matt77CHE
                @mcm1957
                mcm1957M Online
                mcm1957M Online
                mcm1957
                @matt77che
                sieht für mich nach einem lokalen Zugriff / lokaler Api aus. Deswegen schrieb ich auch dass ich derzeit die Cloud Version / Cloud Zugriff verwende. Ich hab unter
                Ich kenn mich mit dem lokalen Zugriff nicht aus, aber es wäre denkbar dass da z.B. dein Pin nicht passt oder so was. Ev. kann da er was dazu sagen der den lokalen Api Zugriff zumindest benutzt.
                Ich hab unter 'Local Api Settings' nichts eingtragen:
                • mcm1957M mcm1957
                  @matt77che
                  Matt77CHE
                  @mcm1957
                  Über die Cloud funktioniert es auch bei mir
                  Eigentlich wollte ich die Cloud vermeiden wegen möglichen Verbindungsproblemen etc.... aber manchmal frisst jetzt halt der Teufel Fliegen....
                  Werde vorerst über die Cloud gehen - hoffentlich gibt es für die lokale Verbindung bald einen Fix.
                  • M Matt77CHE
                    @mcm1957
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    @matt77che said in Tahoma Adapter - Funktioniert er bei euch noch?:
                    @mcm1957
                    So ich hab jetzt mal die lokale Api eingerichtet.
                    Abgesehen davon dass der Adapetr ohne msdn anzuhaken nicht funktiomiert (da er sich Addresse der Box nicht findet) läuft er bei mir auch mit lokalem Api
                    tahoma.0
                    2024-12-07 12:15:41.665	info	eventRegisterID = xxxxxx-5601-4f9c-91ed-xxxxxxx
                    tahoma.0
                    2024-12-07 12:15:39.889	info	Using stored bearer token xxxxxxxxxxxxxxxxx
                    tahoma.0
                    2024-12-07 12:15:39.886	info	Adapter will connect to Tahoma Box via local API.
                    tahoma.0
                    2024-12-07 12:15:39.881	info	Configured polling interval: 20000
                    tahoma.0
                    2024-12-07 12:15:39.880	info	[START] Starting adapter tahoma v0.10.4.3
                    tahoma.0
                    2024-12-07 12:15:39.845	info	starting. Version 0.10.4 in /opt/iobroker/node_modules/iobroker.tahoma, node: v18.20.4, js-controller: 7.0.3
                    host.pi4
                    2024-12-07 12:15:36.497	info	instance system.adapter.tahoma.0 in version "0.10.4" started with pid 11495
                    host.pi4
                    2024-12-07 12:15:35.326	info	"system.adapter.tahoma.0" enabled
                    • mcm1957M mcm1957
                      @mcm1957
                      tahoma.0
                      tahoma.0
                      tahoma.0
                      tahoma.0
                      tahoma.0
                      tahoma.0
                      host.pi4
                      host.pi4
                      Matt77CHE
                      @mcm1957
                      Komisch, dass er bei mir nicht will.... gibt wohl wieder ein langes Wochenende am Laptop....
                      • M Matt77CHE
                        @mcm1957
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        @matt77che
                        Anbei noch der log mit DEBUG
                        2024-12-07 12:22:47.299 - info: tahoma.0 (11836) starting. Version 0.10.4 in /opt/iobroker/node_modules/iobroker.tahoma, node: v18.20.4, js-controller: 7.0.3
                        2024-12-07 12:22:47.338 - info: tahoma.0 (11836) [START] Starting adapter tahoma v0.10.4.3
                        2024-12-07 12:22:47.340 - info: tahoma.0 (11836) Configured polling interval: 20000
                        2024-12-07 12:22:47.342 - debug: tahoma.0 (11836) [START] Started Adapter
                        2024-12-07 12:22:47.348 - info: tahoma.0 (11836) Adapter will connect to Tahoma Box via local API.
                        2024-12-07 12:22:47.352 - info: tahoma.0 (11836) Using stored bearer token 67542e01415bcb27e16b
                        2024-12-07 12:22:47.354 - debug: tahoma.0 (11836) GET request on https://gateway-2003-xxxx-xxxx.local:8443/enduser-mobile-web/1/enduserAPI/setup with payload:{}
                        2024-12-07 12:22:47.559 - debug: tahoma.0 (11836) stateChange tahoma.0.info.connection {"val":true,"ack":true,"ts":1733570567554,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1733570567554}
                        20
                        • mcm1957M mcm1957
                          @matt77che
                          20
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          Könnte damit zusammen hängen:
                          https://github.com/Somfy-Developer/Somfy-TaHoma-Developer-Mode/issues/139
                          or
                          https://github.com/Somfy-Developer/Somfy-TaHoma-Developer-Mode/issues/149
                          In general browse the issues at somfy. Looks like they have several issues with local API access
                          • SMSS Offline
                            SMSS Offline
                            SMS
                            gibt es für dieses Problem denn eine Lösung?
                            tahoma -> error during request: ->401 retry login
                            Hat denn mal jemand versucht einen neuen Account bei Somfy anzulegen und die Box dort einzulernen? Irgendwie scheint es ja ein Problem mit dem Passwort zu geben. Fehleingabe schließe ich jetzt mal aus.
                            tahoma.0
                            	2025-08-02 15:21:36.345	info	Login failed 3 times, waiting 120 seconds before retrying.
                            tahoma.0
                            	2025-08-02 15:21:36.345	warn	error during request: ->401 retry login
                            tahoma.0
                            	2025-08-02 15:21:36.280	info	Login attempt #3
                            tahoma.0
                            	2025-08-02 15:21:06.280	warn	error during request: ->401 retry login
                            tahoma.0
                            	2025-08-02 15:21:06.216	info	Login attempt #2
                            tahoma.0
                            	2025-08-02 15:20:36.216	warn	error during request: ->401 retry login
                            tahoma.0
                            	2025-08-02 15:20:36.150	info	Login attempt #1
                            tahoma.0
                            	2025-08-02 15:20:06.147	warn	error during request: ->401 retry login
                            tahoma.0
                            	2025-08-02 15:20:06.088	info	Executing Timeout (retry login).
                            Danke und Grüße
