  5. [ gelöst ] JSON aufteilen in DP
    6.5k
48 Beiträge 5 Kommentatoren 6.0k Aufrufe 2 Beobachtet
  • I ioBrokerMike
    Vielen Dank euch drei.
    Habe es so umgesetzt, nur leider ohne Erfolg.
    Es kommt werde in dem DP noch beim Debug was an.
    In den Protokollen bekomme ich die Daten.
    2024-11-29 18:50:39.120	debug	stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"18:50:38.443 MQT: umluft_350pic/tele/SENSOR = {\"Time\":\"2024-11-29T18:50:38\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":10.81},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":9.31},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":5.06},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":14.13},\"TempUnit\":\"C\"}","ack":true,"ts":1732902639113,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.XXXXX","lc":1732902639113}
    mqtt.0
    2024-11-29 18:50:39.117	debug	stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"18:50:38.434 MQT: umluft_350pic/tele/STATE = {\"Time\":\"2024-11-29T18:50:38\",\"Uptime\":\"0T01:32:30\",\"UptimeSec\":5550,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":3,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":76,\"Signal\":-62,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732902639113,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732902639113}
    mqtt.0
    2024-11-29 18:50:38.125	debug	stateChange mqtt.0.umluft_350pic.tele.SENSOR: {"val":"{\"Time\":\"2024-11-29T18:50:38\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":10.81},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":9.31},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":5.06},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":14.13},\"TempUnit\":\"C\"}","ack":true,"ts":1732902638120,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.XXXXX","lc":1732902638120}
    mqtt.0
    2024-11-29 18:50:38.123	debug	stateChange mqtt.0.umluft_350pic.tele.STATE: {"val":"{\"Time\":\"2024-11-29T18:50:38\",\"Uptime\":\"0T01:32:30\",\"UptimeSec\":5550,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":3,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":76,\"Signal\":-62,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732902638119,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732902638119}
    mqtt.0
    2024-11-29 18:50:29.241	debug	stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"18:50:28.462 MQT: umluft_350pic/tele/SENSOR = {\"Time\":\"2024-11-29T18:50:28\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":10.81},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":9.31},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":5.13},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":14.13},\"TempUnit\":\"C\"}","ack":true,"ts":1732902629236,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.XXXXX","lc":1732902629236}
    mqtt.0
    2024-11-29 18:50:29.239	debug	stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"18:50:28.453 MQT: umluft_350pic/tele/STATE = {\"Time\":\"2024-11-29T18:50:28\",\"Uptime\":\"0T01:32:20\",\"UptimeSec\":5540,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":3,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":76,\"Signal\":-62,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732902629236,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.XXXXX","lc":1732902629236}
    mqtt.0
    2024-11-29 18:50:28.185	debug	stateChange mqtt.0.umluft_350pic.tele.SENSOR: {"val":"{\"Time\":\"2024-11-29T18:50:28\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":10.81},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":9.31},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":5.13},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":14.13},\"TempUnit\":\"C\"}","ack":true,"ts":1732902628181,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.XXXXX","lc":1732902628181}
    mqtt.0
    2024-11-29 18:50:28.184	debug	stateChange mqtt.0.umluft_350pic.tele.STATE: {"val":"{\"Time\":\"2024-11-29T18:50:28\",\"Uptime\":\"0T01:32:20\",\"UptimeSec\":5540,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":3,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":76,\"Signal\":-62,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732902628180,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.XXXXX","lc":1732902628180}
    mqtt.0
    2024-11-29 18:50:27.116	debug	Client [Umluft] pingreq
    mqtt.0
    2024-11-29 18:50:19.101	debug	stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"18:50:18.429 MQT: umluft_350pic/tele/SENSOR = {\"Time\":\"2024-11-29T18:50:18\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":10.81},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":9.31},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":5.06},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":14.13},\"TempUnit\":\"C\"}","ack":true,"ts":1732902619098,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.XXXXX","lc":1732902619098}
    mqtt.0
    2024-11-29 18:50:19.100	debug	stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"18:50:18.420 MQT: umluft_350pic/tele/STATE = {\"Time\":\"2024-11-29T18:50:18\",\"Uptime\":\"0T01:32:10\",\"UptimeSec\":5530,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":3,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":76,\"Signal\":-62,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732902619098,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.XXXXX","lc":1732902619098}
    mqtt.0
    2024-11-29 18:50:18.111	debug	stateChange mqtt.0.umluft_350pic.tele.SENSOR: {"val":"{\"Time\":\"2024-11-29T18:50:18\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":10.81},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":9.31},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":5.06},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":14.13},\"TempUnit\":\"C\"}","ack":true,"ts":1732902618106,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.XXXXX","lc":1732902618106}
    mqtt.0
    2024-11-29 18:50:18.109	debug	stateChange mqtt.0.umluft_350pic.tele.STATE: {"val":"{\"Time\":\"2024-11-29T18:50:18\",\"Uptime\":\"0T01:32:10\",\"UptimeSec\":5530,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":3,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":76,\"Signal\":-62,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732902618105,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.XXXXX","lc":1732902618105}
    mqtt.0
    2024-11-29 18:50:09.109	debug	stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"18:50:08.434 MQT: umluft_350pic/tele/SENSOR = {\"Time\":\"2024-11-29T18:50:08\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":10.81},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":9.31},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":5.13},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":14.13},\"TempUnit\":\"C\"}","ack":true,"ts":1732902609105,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.XXXXX","lc":1732902609105}
    PS. Ebend kam im DP ein (null) an.
    @iobrokermike sagte:
    Hier fehlt "sn".
    • I ioBrokerMike
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      CodierknechtC Offline
      Codierknecht
      @iobrokermike
      Da sehe ich aber kein "sn".
      Zeig bitte nochmal, was genau in dem DP mqtt.0.umluft_350pic.tele.SENSOR steht.
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      HomoranH I 2 Antworten Letzte Antwort
      • CodierknechtC Codierknecht
        @iobrokermike
        @codierknecht sagte in JSON aufteilen in DP:
        ich auch nicht.
        und aus dem log klappts wegen der Escapes nicht
          @iobrokermike
          I Online
          I Online
          ioBrokerMike
          schrieb am zuletzt editiert von ioBrokerMike
          @codierknecht
          Unter diesen JSON ist kein "sn".
          Nur dieser wird aktualisiert.
          SORRY 🙄
            "Time": "2024-11-29T19:26:38",
            "DS18B20-1": {
              "Id": "01131B71E34F",
              "Temperature": 10.56
            "DS18B20-2": {
              "Id": "01131B8507D6",
              "Temperature": 9.06
            "DS18B20-3": {
              "Id": "01131BE31350",
              "Temperature": 4.94
            "DS18B20-4": {
              "Id": "021313CCB0AA",
              "Temperature": 14.06
            "TempUnit": "C"
          Mfg
          IOBrokerMike
          Achtung ! Sehkraft 25% | 60% , kein scherz
          Systeme : GEEKOM MiniAir 11 | Linux : Trixie 13.6 | HMIP | OpenCCU / RasPi3 | SMA PV Anlage | Robonect Hx | RTL_433
          • I ioBrokerMike
            @codierknecht
            SORRY 🙄
              "DS18B20-1": {
              "DS18B20-2": {
                "Temperature": 9.06
              "DS18B20-3": {
                "Temperature": 4.94
              "DS18B20-4": {
              "TempUnit": "C"
            die zweite Zeile ist für dich interessant, eigentlich nur das Attribut korrigieren
            EDIT:
            Das hast du ja schon.
            Dann muss das so klappen.
            I 1 Antwort Letzte Antwort
              EDIT:
              I Online
              I Online
              ioBrokerMike
              @homoran sagte in JSON aufteilen in DP:
              Leider nein.
              Habe es auch mal deinem nachgebaut, auch das nicht.
              Glaube bin zu du.. dazu.
              Mfg
              IOBrokerMike
              HomoranH mickymM 2 Antworten Letzte Antwort
              • I ioBrokerMike
                Leider nein.
                @iobrokermike was steht denn im großen log (Protokolle)?
                • I ioBrokerMike
                  Leider nein.
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @iobrokermike Du musst den Text noch in ein Objekt wandeln.
                  Also vor den grünen Text.
                  • mickymM mickym
                    @mickym sagte in JSON aufteilen in DP:
                    warum muss ich das nicht 🤔
                      I Online
                      I Online
                      ioBrokerMike
                      2024-11-29 20:18:41.186 - debug: mqtt.0 (392491) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2024-11-29 20:18:41.203 - debug: mqtt.0 (392491) Objects client ready ... initialize now
                      2024-11-29 20:18:41.203 - debug: mqtt.0 (392491) Objects create System PubSub Client
                      2024-11-29 20:18:41.204 - debug: mqtt.0 (392491) Objects create User PubSub Client
                      2024-11-29 20:18:41.226 - debug: mqtt.0 (392491) Objects client initialize lua scripts
                      2024-11-29 20:18:41.229 - debug: mqtt.0 (392491) Objects connected to redis: 127.0.0.1:9001
                      2024-11-29 20:18:41.245 - debug: mqtt.0 (392491) Redis States: Use Redis connection: 127.0.0.1:9000
                      2024-11-29 20:18:41.252 - debug: mqtt.0 (392491) States create System PubSub Client
                      2024-11-29 20:18:41.252 - debug: mqtt.0 (392491) States create User PubSub Client
                      2024-11-29 20:18:41.312 - debug: mqtt.0 (392491) States connected to redis: 127.0.0.1:9000
                      2024-11-29 20:18:41.349 - debug: mqtt.0 (392491) Plugin sentry Initialize Plugin (enabled=true)
                      2024-11-29 20:18:41.497 - info: mqtt.0 (392491) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.18.1, js-controller: 7.0.3
                      2024-11-29 20:18:41.556 - info: mqtt.0 (392491) Starting MQTT authenticated server on 0.0.0.0:1882
                      2024-11-29 20:18:41.637 - debug: mqtt.0 (392491) stateChange mqtt.0.info.clients.Umluft: {"val":false,"ack":true,"ts":1732907921635,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907921635}
                      2024-11-29 20:18:41.690 - debug: mqtt.0 (392491) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1732907921686,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907921686}
                      2024-11-29 20:18:49.153 - info: mqtt.0 (392491) Client [Umluft] connected with secret 1732907929142_5833
                      2024-11-29 20:18:49.180 - debug: mqtt.0 (392491) Client [Umluft] with keepalive 30 set timeout to 45 seconds
                      2024-11-29 20:18:49.188 - debug: mqtt.0 (392491) Client [Umluft] with last will {"retain":true,"qos":1,"topic":"umluft_350pic/tele/LWT","payload":{"type":"Buffer","data":[79,102,102,108,105,110,101]}}
                      2024-11-29 20:18:49.199 - debug: mqtt.0 (392491) Client [Umluft] Handle subscribe: {"topic":"umluft_350pic/cmnd/#","qos":0}
                      2024-11-29 20:18:49.200 - info: mqtt.0 (392491) Client [Umluft] subscribes on "umluft_350pic/cmnd/#" with regex /^umluft_350pic\.cmnd\..*/
                      2024-11-29 20:18:49.200 - info: mqtt.0 (392491) Client [Umluft] subscribes on "umluft_350pic/cmnd/#" with regex /^mqtt\.0\.umluft_350pic\.cmnd\..*/
                      2024-11-29 20:18:49.205 - debug: mqtt.0 (392491) Client [Umluft] Handle subscribe: {"topic":"tasmotas/cmnd/#","qos":0}
                      2024-11-29 20:18:49.206 - info: mqtt.0 (392491) Client [Umluft] subscribes on "tasmotas/cmnd/#" with regex /^tasmotas\.cmnd\..*/
                      2024-11-29 20:18:49.206 - info: mqtt.0 (392491) Client [Umluft] subscribes on "tasmotas/cmnd/#" with regex /^mqtt\.0\.tasmotas\.cmnd\..*/
                      2024-11-29 20:18:49.206 - debug: mqtt.0 (392491) Client [Umluft] Handle subscribe: {"topic":"cmnd/Umluft_fb/#","qos":0}
                      2024-11-29 20:18:49.207 - info: mqtt.0 (392491) Client [Umluft] subscribes on "cmnd/Umluft_fb/#" with regex /^cmnd\.Umluft_fb\..*/
                      2024-11-29 20:18:49.207 - info: mqtt.0 (392491) Client [Umluft] subscribes on "cmnd/Umluft_fb/#" with regex /^mqtt\.0\.cmnd\.Umluft_fb\..*/
                      2024-11-29 20:18:49.209 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.tele.LWT: {"val":"Online","ack":true,"ts":1732907929197,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732897154587}
                      2024-11-29 20:18:49.250 - info: mqtt.0 (392491) Client [Umluft] unsubscribes on unknown topic "homeassistant/status"
                      2024-11-29 20:18:49.255 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.cmnd.POWER: {"val":null,"ack":true,"ts":1732907929252,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929252}
                      2024-11-29 20:18:49.259 - debug: mqtt.0 (392491) stateChange mqtt.0.info.clients.Umluft: {"val":true,"ack":true,"ts":1732907929256,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929256}
                      2024-11-29 20:18:49.337 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:48.406 RSL: STATE = {\"Time\":\"2024-11-29T20:18:48\",\"Uptime\":\"0T03:00:40\",\"UptimeSec\":10840,\"Heap\":28,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":4,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":76,\"Signal\":-62,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732907929335,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929335}
                      2024-11-29 20:18:49.387 - debug: mqtt.0 (392491) stateChange mqtt.0.info.connection: {"val":"Umluft","ack":true,"ts":1732907929380,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929380}
                      2024-11-29 20:18:49.403 - info: mqtt.0 (392491) Client [Umluft] publishOnSubscribe send all known states
                      2024-11-29 20:18:49.407 - info: mqtt.0 (392491) Client [Umluft] publishOnSubscribe send all known states
                      2024-11-29 20:18:49.408 - info: mqtt.0 (392491) Client [Umluft] publishOnSubscribe send all known states
                      2024-11-29 20:18:49.428 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:48.412 RSL: SENSOR = {\"Time\":\"2024-11-29T20:18:48\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.75},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"}","ack":true,"ts":1732907929426,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929426}
                      2024-11-29 20:18:49.429 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:49.252 MQT: Verbindungsversuch...","ack":true,"ts":1732907929427,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929427}
                      2024-11-29 20:18:49.430 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:49.308 MQT: verbunden","ack":true,"ts":1732907929427,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929427}
                      2024-11-29 20:18:49.430 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:49.311 MQT: umluft_350pic/tele/LWT = Online (beibehalten)","ack":true,"ts":1732907929427,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929427}
                      2024-11-29 20:18:49.430 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:49.315 MQT: umluft_350pic/cmnd/POWER = ","ack":true,"ts":1732907929427,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929427}
                      2024-11-29 20:18:49.445 - debug: mqtt.0 (392491) stateChange mqtt.0.tasmota.discovery.98CDAC23FB50.config: {"val":"{\"ip\":\"192.168.178.15\",\"dn\":\"Umluft\",\"fn\":[\"EI-OT Modul\",null,null,null,null,null,null,null],\"hn\":\"umluft--topic--6992\",\"mac\":\"98CDAC23FB50\",\"md\":\"EI-OT 2CH 1Wire\",\"ty\":0,\"if\":0,\"ofln\":\"Offline\",\"onln\":\"Online\",\"state\":[\"OFF\",\"ON\",\"TOGGLE\",\"HOLD\"],\"sw\":\"110.00.1\",\"t\":\"umluft_350pic\",\"ft\":\"%topic%/%prefix%/\",\"tp\":[\"cmnd\",\"stat\",\"tele\"],\"rl\":[0,0,0,0,0,0,0,0],\"swc\":[-1,-1,-1,-1,-1,-1,-1,-1],\"swn\":[null,null,null,null,null,null,null,null],\"btn\":[0,0,0,0,0,0,0,0],\"so\":{\"4\":0,\"11\":0,\"13\":0,\"17\":0,\"20\":0,\"30\":0,\"68\":0,\"73\":0,\"82\":0,\"114\":0,\"117\":0},\"lk\":0,\"lt_st\":0,\"sho\":[0,0,0,0],\"ver\":1}","ack":true,"ts":1732907929427,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732897155037}
                      2024-11-29 20:18:49.445 - debug: mqtt.0 (392491) stateChange mqtt.0.tasmota.discovery.98CDAC23FB50.sensors: {"val":"{\"sn\":{\"Time\":\"2024-11-29T20:18:49\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.75},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"},\"ver\":1}","ack":true,"ts":1732907929427,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929427}
                      2024-11-29 20:18:49.512 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.RESULT: {"val":"{\"Command\":\"Error\"}","ack":true,"ts":1732907929509,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732897154861}
                      2024-11-29 20:18:49.516 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.RESULT: {"val":"{\"Command\":\"Error\"}","ack":true,"ts":1732907929513,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732897154861}
                      2024-11-29 20:18:49.605 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.RESULT: {"val":"{\"Command\":\"Error\"}","ack":true,"ts":1732907929602,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732897154861}
                      2024-11-29 20:18:50.312 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:49.574 MQT: umluft_350pic/stat/RESULT = {\"Command\":\"Error\"}","ack":true,"ts":1732907930310,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907930310}
                      2024-11-29 20:18:50.313 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:49.623 MQT: umluft_350pic/stat/RESULT = {\"Command\":\"Error\"}","ack":true,"ts":1732907930310,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907930310}
                      2024-11-29 20:18:50.313 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:49.675 MQT: umluft_350pic/stat/RESULT = {\"Command\":\"Error\"}","ack":true,"ts":1732907930311,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907930311}
                      2024-11-29 20:18:51.267 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.RESULT: {"val":"{\"Command\":\"Error\"}","ack":true,"ts":1732907931264,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732897154861}
                      2024-11-29 20:18:51.315 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:51.376 MQT: umluft_350pic/stat/RESULT = {\"Command\":\"Error\"}","ack":true,"ts":1732907931313,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907931313}
                      2024-11-29 20:18:58.343 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.tele.STATE: {"val":"{\"Time\":\"2024-11-29T20:18:58\",\"Uptime\":\"0T03:00:50\",\"UptimeSec\":10850,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":5,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":76,\"Signal\":-62,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732907938340,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907938340}
                      2024-11-29 20:18:58.346 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.tele.SENSOR: {"val":"{\"Time\":\"2024-11-29T20:18:58\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.75},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"}","ack":true,"ts":1732907938340,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907938340}
                      2024-11-29 20:18:59.333 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:58.445 MQT: umluft_350pic/tele/STATE = {\"Time\":\"2024-11-29T20:18:58\",\"Uptime\":\"0T03:00:50\",\"UptimeSec\":10850,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":5,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":76,\"Signal\":-62,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732907939330,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907939330}
                      2024-11-29 20:18:59.335 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:58.456 MQT: umluft_350pic/tele/SENSOR = {\"Time\":\"2024-11-29T20:18:58\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.75},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"}","ack":true,"ts":1732907939331,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907939331}
                      2024-11-29 20:19:08.329 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.tele.STATE: {"val":"{\"Time\":\"2024-11-29T20:19:08\",\"Uptime\":\"0T03:01:00\",\"UptimeSec\":10860,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":5,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":74,\"Signal\":-63,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732907948326,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907948326}
                      2024-11-29 20:19:08.331 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.tele.SENSOR: {"val":"{\"Time\":\"2024-11-29T20:19:08\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.75},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"}","ack":true,"ts":1732907948326,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907948326}
                      2024-11-29 20:19:09.328 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:19:08.431 MQT: umluft_350pic/tele/STATE = {\"Time\":\"2024-11-29T20:19:08\",\"Uptime\":\"0T03:01:00\",\"UptimeSec\":10860,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":5,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":74,\"Signal\":-63,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732907949325,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907949325}
                      2024-11-29 20:19:09.330 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:19:08.441 MQT: umluft_350pic/tele/SENSOR = {\"Time\":\"2024-11-29T20:19:08\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.75},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"}","ack":true,"ts":1732907949325,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907949325}
                      2024-11-29 20:19:18.303 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.tele.STATE: {"val":"{\"Time\":\"2024-11-29T20:19:18\",\"Uptime\":\"0T03:01:10\",\"UptimeSec\":10870,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":5,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":70,\"Signal\":-65,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732907958300,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907958300}
                      2024-11-29 20:19:18.305 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.tele.SENSOR: {"val":"{\"Time\":\"2024-11-29T20:19:18\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.81},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"}","ack":true,"ts":1732907958301,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907958301}
                      2024-11-29 20:19:19.363 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:19:18.406 MQT: umluft_350pic/tele/STATE = {\"Time\":\"2024-11-29T20:19:18\",\"Uptime\":\"0T03:01:10\",\"UptimeSec\":10870,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":5,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":70,\"Signal\":-65,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732907959360,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907959360}
                      2024-11-29 20:19:19.365 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:19:18.416 MQT: umluft_350pic/tele/SENSOR = {\"Time\":\"2024-11-29T20:19:18\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.81},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"}","ack":true,"ts":1732907959360,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907959360}
                      Mfg
                      IOBrokerMike
                      • I ioBrokerMike
                        @iobrokermike ich seh nichts von Javascript!
                        läuft das Skript?
                        und die Instanz?
                          mickymM Offline
                          mickymM Offline
                          mickym
                          Wenn Du Wert nimmst und das Ganze aus einem Trigger stammt und Wert keine selbst erstellte Variable ist, dann ist das ein Objekt. Wenn Du aber nur einen JSON als Text nimmst, musst Du den erst in ein Objekt wandeln.
                          Deshalb ist es auch nicht gut, wenn man eine selbst erstellte Variable Wert nennt - dann verwechselt man das.
                          • mickymM mickym
                            Da stimme ich dir zu! Mir fiel nur auf die Schnelle kein kurzer Begriff für "extrahierter Wert" ein.
                            hier jedoch nicht
                            hier
                            https://forum.iobroker.net/assets/uploads/files/1732905391106-screenshot_20241129-193612_firefox.jpg
                            klappt es ohne Objekt
                              hier jedoch nicht
                              hier
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @homoran Ja Du hast Recht - ist für mich auch neu - früher ging das glaub nicht. Aber jetzt geht das anscheinend.
                              geht sogar direkt aus dem Text
                              Aber irgendwie habe ich es in Erinnerung, dass das früher nicht ging.
                              • mickymM mickym
                                ich hab's immer so gemacht.
                                Ich wusste nicht dass das nicht geht, dadurch ging es 😂
                                • mickymM Offline
                                  mickymM Offline
                                  mickym
                                  Nur wenn @iobrokerMike solche Probleme mit JSON hat, sollte er sich vielleicht doch mal meinen NodeRed Flow anschauen und einfach alles in einzelne Datenpunkte aufdröseln. ;)
                                  • mickymM mickym
                                    ich denke das Skript läuft nicht.
                                    Wie du in meinem output siehst, müsste mindestens der Stop, der Start und die subscriptions zu sehen sein.
                                    bei deinem Flow käme dann auch nichts.
                                      läuft das Skript?
                                      und die Instanz?
                                      I Online
                                      I Online
                                      ioBrokerMike
                                      @mickym
                                      Das habe ich im Hinterkopf.
                                      Danke für den Hinweis
                                      Wenn ich das erstmal von @Homoran zum laufen bekomme werde ich mich mit den Rest (Eigentlichen) beschäftigen.
                                      Mfg
                                      IOBrokerMike
                                      mickymM HomoranH 2 Antworten Letzte Antwort
                                      • I ioBrokerMike
                                        @mickym
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @iobrokermike
                                        @Homoran hat ja Recht, dass in Deinem Debug Fenster ja gar nichts steht. Hast Du noch irgendwas anderes nicht deaktiviertes im Skript.
                                        Hast Du mal Dein gestartetes Skript mit dem Wiederholungssymbol neu gestartet? - Das muss im Debugfenster zu sehen sein.
                                        • mickymM mickym
                                          @mickym sagte: früher ging das glaub nicht.
                                          Das ging mit getAttr() schon immer. Siehe Doku. Die Funktion wurde speziell für Blockly geschaffen.
