  3. Entwicklung
  4. Anker Adapter
Anker Adapter
437 Beiträge 63 Kommentatoren 159.9k Aufrufe 60 Beobachtet
  • S Solardach
    @ronny130286
    Bei einem Internet Ausfall kommt es zu einem Fehler beim Neustart des Adapters.
    Manueller Neustart über die Instanzen funktioniert dann sofort.
    ankersolix2.0
    2024-10-16 12:18:10.240	info	terminating
    ankersolix2.0
    2024-10-16 12:18:09.737	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    ankersolix2.0
    2024-10-16 12:18:09.734	info	terminating
    ankersolix2.0
    2024-10-16 12:18:09.714	warn	Conifg Email Adresse are not the same in storedata or auth_token or token_expires_at are null
    ankersolix2.0
    2024-10-16 12:18:09.712	error	Exception-Code: ENOENT: ENOENT: no such file or directory, unlink '/opt/iobroker/iobroker-data/ankersolix2.0/session.data'
    ankersolix2.0
    2024-10-16 12:18:09.711	error	Error: ENOENT: no such file or directory, unlink '/opt/iobroker/iobroker-data/ankersolix2.0/session.data' at Object.unlinkSync (node:fs:1884:11) at Ankersolix2.refreshDate (/opt/iobroker/node_modules/iobroker.ankersolix2/build/main.js:76:25) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    ankersolix2.0
    2024-10-16 12:18:09.709	error	unhandled promise rejection: ENOENT: no such file or directory, unlink '/opt/iobroker/iobroker-data/ankersolix2.0/session.data'
    ankersolix2.0
    2024-10-16 12:18:09.708	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ankersolix2.0
    2024-10-16 12:17:19.945	warn	Failed fetching or publishing printer data Error: getaddrinfo EAI_AGAIN ankerpower-api-eu.anker.com
    ankersolix2.0
    2024-10-16 12:17:09.710	warn	Conifg Email Adresse are not the same in storedata or auth_token or token_expires_at are null
    ankersolix2.0
    2024-10-16 12:17:09.663	info	starting. Version 0.1.0-beta.0 (non-npm: ronny130286/ioBroker.ankersolix2#dc3b88da2aa953a95b8e2511c68a11984bc04f36) in /opt/iobroker/node_modules/iobroker.ankersolix2, node: v20.17.0, js-controller: 6.0.11
    ronny130286
    #113
    @solardach
    Ok :D das Scenario habe ich noch nicht gehabt :D ich versuche das mal nachzustellen und lass die Änderung einfließen.
    Und er fängt sich dann aber überhaupt nicht mehr von alleine oder?
    S J 2 Antworten Letzte Antwort
    • R ronny130286
      @solardach
      S Online
      S Online
      Solardach
      #114
      @ronny130286
      Nein er fängt sich nicht mehr von alleine.
      Manuelles Starten funktioniert sofort ohne das man was ändern muss.
      Auch beim Start von IOB startet der adapter ohne Probleme.
      • R ronny130286
        @solardach
        Jensemann200
        schrieb am zuletzt editiert von Jensemann200
        #115
        @ronny130286 Lieber Ronny,
        vielen Dank für Deine Arbeit an Deinem Anker-Adapter! Ich würde ihn gerne installieren, scheitere aber schon in den Anfängen.
        Ich habe über den iMac über das Terminal auf meinen Raspberry sudo npm i iobroker.ankersolix2 gestartet. Ich bekomme folgende Antwort:
        up to date, audited 66 packages in 4s
        12 packages are looking for funding
        run npm fund for details
        found 0 vulnerabilities
        Nun finde ich im ioBroker nirgends den Adapter. Eine Installation direkt im ioBroker wird mit diversen Fehlermeldungen abgebrochen. Was mache ich bloß falsch?
        Liebe Grüße
        Jens
        • J Jensemann200
          Liebe Grüße
          Jens
          #116
          @jensemann200 sagte in Anker Adapter:
          Du verwendest npm im Zusammenhang mit sudo.
          Dann tust du das in einem unbekannten Verzeichnis.
          Du sagst nicht, welcher Art die 'diversen Fehlermeldungen' sind.
          So kann man dir nicht sagen, was du falsch machst.
          Über npm kann man den Adapter aussuchen:
          Per Kommandozeile:
          iobroker url https://github.com/ronny130286/ioBroker.ankersolix2 --debug
            Per Kommandozeile:
            Jensemann200
            #117
            @thomas-braun said in Anker Adapter:
            Vielen lieben Dank für die schnelle Antwort, das ist richtig toll!
            Wenn ich im ioBroker über npm den Adapter installieren möchte, taucht er dort leider nicht auf. ;(
            Über die Kommandozeile ergibt sich folgendes Bild:
            pi@raspberrypi:~ $ iobroker url https://github.com/ronny130286/ioBroker.ankersolix2 --debug
            install ronny130286/ioBroker.ankersolix2#dc3b88da2aa953a95b8e2511c68a11984bc04f36
            NPM version: 10.9.0
            Installing ronny130286/ioBroker.ankersolix2#dc3b88da2aa953a95b8e2511c68a11984bc04f36... (System call)
            npm error code ENOTEMPTY
            npm error syscall rename
            npm error path /opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core
            npm error dest /opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/.adapter-core-AoxIRjN8
            npm error errno -39
            npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core' -> '/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/.adapter-core-AoxIRjN8'
            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-26T22_12_18_763Z-debug-0.log
            Try to solve ENOTEMPTY error automatically
            Could not handle ENOTEMPTY, because no deletable files were found
            npm error errno -39
            host.raspberrypi Cannot install ronny130286/ioBroker.ankersolix2#dc3b88da2aa953a95b8e2511c68a11984bc04f36: 217
            Irgendetwas hakt da leider...
            • J Jensemann200
              NPM version: 10.9.0
              npm error errno -39
              npm error errno -39
              #118
              Jag den
              iob fix
              über das System
                Jag den
                iob fix
                über das System
                Jensemann200
                #119
                @thomas-braun Volltreffer, vielen Dank!!
                  Krys
                  #120
                  Guten Morgen,
                  wird euer Log auch zugespamt mit folgender Meldung?
                  S Thomas BraunT 2 Antworten Letzte Antwort
                  • K Krys
                    Guten Morgen,
                    spoeh-man
                    #121
                    @krys
                    ja bei mir neuerdings auch so
                    • K Krys
                      Guten Morgen,
                      #122
                      @krys
                      Hier auch.
                      Hast du ein Issue eröffnet?
                        @krys
                        Hier auch.
                        Krys
                        #123
                        @thomas-braun Hab ich soeben gemacht
                          BigMike71
                          schrieb am zuletzt editiert von BigMike71
                          #124
                          moin, habe seit 3 Tagen die Version 1.0.0 drauf.
                          heute nacht ist der Adapter amok gelaufen und hat mein komplettes system zum stillstand gebracht!
                          anbei der Log:
                          log.txt
                          da die fehlermeldungen im msek aufliefen haben sie das logfile in ca. 5 stunden auf 45mb ansteigen lassen, dann igrendwann war das system platt. nach neustart geht wiede alles... aber irgend einen grund muss es ja geben....
                          • B BigMike71
                            anbei der Log:
                            log.txt
                            Badwater
                            #125
                            @bigmike71 1.0.1 habe ich gestern installiert, läuft ...
                            • R Offline
                              ronny130286
                              schrieb am zuletzt editiert von ronny130286
                              #126
                              Danke für den Log, ich habe es mir heute noch mal angesehen und nachstellen können.
                              Das große Problem liegt scheinbar auf der Ankerzeit :( ich bekomme heute nur noch alle 5min überhaupt Daten und den Rest der Zeit bekomme ich ein ERR_BAD_REQUEST zurück :(
                              Ich habe das mal noch versucht abzufangen, dass zumindest nicht innerhalb kürzester Zeit vollgeschrieben wird der Log.
                                spoeh-man
                                #127
                                Habe jetzt die 1.0.2 drauf beim start wirft er einen fehler aus aber sonst scheint es zu laufen
                                Object ankersolix2.0.ddd81a33-8cd1-4369-a48f-a43eea963666.solarbank_info.backup_info is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, json This will throw an error up from js-controller version 7.0.0!
                                • S spoeh-man
                                  mcm1957M Offline
                                  mcm1957M Offline
                                  mcm1957
                                  #128
                                  Da dieses Thread nicht im TESTER Bereich angesiedelt ist, möchte ich hier zwischendurch mal festhalten:
                                  Der Adapter ankersolix2 (https://github.com/ronny130286/ioBroker.ankersolix2) befindet sich nach wie vor im ALPHA Status. Er wurde bisher nicht zur Aufnahme in die Repos (und das damit verbundene Review) eingereicht. Bitte - sollte der Adapter für einen Beta Test ausreichend stabil sein - bitte doch mal an eine Aufnahme in die Repos nachdenken.
                                  -> https://github.com/ioBroker/ioBroker.repositories#requirements-for-adapter-to-get-added-to-the-latest-repository
                                  Solange der Adapter nicht via Repositories installiert werden kann sollte er nicht auf produktiven Systemen eingesetzt werden.
                                  Der Vollständigkeit halber für User die sich nicht als Entwickler / Alpha Tester sehen zur Erinnerung:
                                  Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten. GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                                  Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                                  Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                                  Und falls es irgendwie unklar ist:
                                  ioBroker unterstützt folgende Arten von Installation:
                                  • aus dem STABLE Repository
                                    Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
                                  • aus dem LATEST Repository
                                    Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
                                  • direkt von GITHUB
                                    Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
                                  • direkt von npm
                                    Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
                                  Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit Sicherheit minimalistisch.
                                  Support Repositoryverwaltung.
                                  LESEN - gute Forenbeitrage
                                  • mcm1957M mcm1957
                                    • direkt von GITHUB
                                    • direkt von npm
                                    spoeh-man
                                    #129
                                    @mcm1957
                                    Und warum soll die Antwort direkt an mich gehen ?. Ich glaube du kennst weder mein system noch hast du sonstige Informationen. Oder war dass algemein und du bist einfach auf den falschen Antworten Button gekommen?.
                                    Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
                                    • S spoeh-man
                                      @mcm1957
                                      #130
                                      @spoeh-man
                                      Das ist eine allgemeine Anmerkung grundsätzlicher Art zu Installationen via GitHub.
                                      Du bist ja auch nicht (anders als in dieser Antwort) als Adressat des Textes markiert.
                                      • S spoeh-man
                                        @mcm1957
                                        mcm1957M Offline
                                        mcm1957M Offline
                                        mcm1957
                                        #131
                                        @spoeh-man said in Anker Adapter:
                                        @mcm1957
                                        Sorry, die Antwort sollte natürlich NICHT an dich direkt gehen.
                                        Ich hab auch kein Mention an dich drinnen wie das sonst üblich ist. Offenbar hat die Forums-SW aber trotzdem das als Antwort n dich gewertet.
                                        Ich habe an sich explizit geschrieben :
                                        "Der Vollständigkeit halber für User die sich nicht als Entwickler / Alpha Tester sehen zur Erinnerung:"
                                        Falls du dir bewusst bist dass du Testest / Alpha SW verwendest ist alles OK und ich sage explizit DANKE fürs Testen eines Adapters. Es kommt nur leider immer wieder vor dass User fristriert sind, weil ein direkzt von GitHub installierter Adapter auf einmal wegen des "bösen ioBroker systems" nicht mehr funktioniert. Deswegen versuchen wir möglichst klar zu machen, dass ioBroker keinerlei Beschränkungen auf "geprüfte" Adapter oder ähnliches hat (und acuh nicht plant) dass aber andrerseits jedem der Adapetr verwendet die nur von Github / npm verfügbar sind, dies auch bewußt sein sollte.
                                        Aber sorry - wollte dich persönlich weder angreifen noch direkt ansprechen. War total als allgemeine Feststellung gedacht.
                                        • mcm1957M mcm1957
                                          @mcm1957
                                          mcm1957M Offline
                                          mcm1957M Offline
                                          mcm1957
                                          #132
                                          Und noch was:
                                          Die ronny130286 hat die Repo Aufnahme auch schon bestellt. Ganz großes DANKE für die rasche Reaktion.
                                          P.S:
                                          Und ich hätt besser den Mund gehalten - weil jetzt hab ich wieder eine Aufgabe mehr :-)
