  4. Owntracks läuft nicht mehr richtig nach Fritzbox tausch
dyndnsfritzbox 7590owntracks adapter
65 Beiträge 3 Kommentatoren 10.2k Aufrufe
  • R Offline
    rebel85
    hier der letzte uszug aus dem log
    2024-11-14 17:40:29.691 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
    2024-11-14 17:40:30.115 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
    2024-11-14 17:40:30.156 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
    2024-11-14 17:40:30.362 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
    2024-11-14 17:40:30.400 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
    2024-11-14 17:40:31.280 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-14 17:40:31.291 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
    2024-11-14 17:40:31.686 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
    2024-11-14 17:40:31.729 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
    2024-11-14 17:40:31.730 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
    2024-11-14 17:40:31.934 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
    2024-11-14 17:40:31.972 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
    2024-11-14 17:41:13.741 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
    Verbindung wurde getrennt (32109) - java.net.SocketException: Software caused connection abort
    	at org.eclipse.paho.client.mqttv3.internal.CommsSender.run(SourceFile:261)
    	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:487)
    	at java.util.concurrent.FutureTask.run(FutureTask.java:264)
    	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:307)
    	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
    	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:644)
    	at java.lang.Thread.run(Thread.java:1012)
    Caused by: java.net.SocketException: Software caused connection abort
    	at java.net.SocketInputStream.socketRead0(Native Method)
    	at java.net.SocketInputStream.socketRead(SocketInputStream.java:118)
    	at java.net.SocketInputStream.read(SocketInputStream.java:173)
    	at java.net.SocketInputStream.read(SocketInputStream.java:143)
    	at java.net.SocketInputStream.read(SocketInputStream.java:205)
    	at java.io.DataInputStream.readByte(DataInputStream.java:273)
    	at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(SourceFile:14)
    	at org.eclipse.paho.client.mqttv3.internal.CommsSender.run(SourceFile:88)
    	... 6 more
    2024-11-14 17:41:13.839 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
    2024-11-14 17:41:14.372 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
    2024-11-14 17:41:14.419 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
    2024-11-14 17:41:14.633 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
    2024-11-14 17:41:14.670 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
    2024-11-14 18:23:10.427 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
    	... 6 more
    2024-11-14 18:23:38.940 I [DefaultDispatcher-worker-5] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-14 18:23:38.957 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
    2024-11-14 18:24:00.659 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-14 18:24:04.646 E [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
    MqttException (0) - java.net.UnknownHostException: mqttowntracks.ddns.net
    	at androidx.work.impl.utils.WorkForegroundUpdater$1.run(SourceFile:233)
    Caused by: java.net.UnknownHostException: mqttowntracks.ddns.net
    	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:208)
    	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:436)
    	at java.net.Socket.connect(Socket.java:646)
    	at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(SourceFile:50)
    	at androidx.work.impl.utils.WorkForegroundUpdater$1.run(SourceFile:66)
    	... 6 more
    2024-11-14 18:24:04.654 E [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpointKt: BOO
    kotlinx.coroutines.JobCancellationException: Job was cancelled; job=JobImpl{Cancelling}@xyz
    2024-11-14 18:24:04.655 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
    2024-11-14 18:24:04.669 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
    2024-11-14 18:24:04.671 E [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
    	... 6 more
    2024-11-14 18:24:04.672 E [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpointKt: BOO
    2024-11-14 18:24:04.672 I [DefaultDispatcher-worker-5] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
    2024-11-14 18:24:16.494 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-14 18:24:16.498 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
    2024-11-14 18:24:16.883 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
    2024-11-14 18:24:16.889 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
    2024-11-14 18:24:16.890 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
    2024-11-14 18:24:17.127 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
    2024-11-14 18:24:17.130 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
    2024-11-14 19:27:42.963 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
    Verbindung wurde getrennt (32109) - java.net.SocketException: Connection reset
    Caused by: java.net.SocketException: Connection reset
    	at java.net.SocketInputStream.read(SocketInputStream.java:191)
    	... 6 more
    2024-11-14 19:29:18.016 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
    2024-11-14 19:29:18.038 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
    2024-11-14 19:29:18.544 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
    2024-11-14 19:29:18.552 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
    2024-11-14 19:29:18.555 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
    2024-11-14 19:29:18.782 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
    2024-11-14 19:29:18.797 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
    2024-11-14 19:34:47.810 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
    2024-11-14 19:34:47.810 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
    2024-11-14 19:34:47.872 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
    2024-11-14 19:34:47.872 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
    2024-11-14 19:34:49.031 I [DefaultDispatcher-worker-8] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
    2024-11-14 19:34:49.033 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 2.055834ms
    2024-11-14 19:34:49.067 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
    2024-11-14 19:34:50.207 I [DefaultDispatcher-worker-8] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
    2024-11-14 19:34:50.210 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 710.052us
    2024-11-14 19:34:50.234 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
    Ro75R 1 Antwort Letzte Antwort
    • R rebel85
      	... 6 more
      	... 6 more
      	... 6 more
      	... 6 more
      	... 6 more
      Ro75R Online
      Ro75R Online
      Ro75
      schrieb am zuletzt editiert von Ro75
      @rebel85 als Port 1886? Im Adapter steht 1884, in der App 1886 und welchen Port schleifst du in der Fritzbox durch? So klappt das nicht.
      Ro75
      • Ro75R Ro75
        Ro75
        rebel85
        @ro75 Moin, doch so klappt das, weil im Adapter und in der Fritzbox auch der Selbe Port freigegeben ist. nur leider die App oder irgendwas noch den weg versperrt. hatte doch gesagt das ich die Ports mal gewechselt habe, es dann zu der ecovacs meldung kahm und dann habe ich den nächsten genommen.
        aktuell alle ports 1886...
        brauchst du dazu auch Bilder?
        • R rebel85
          Ro75R Online
          Ro75R Online
          Ro75
          @rebel85 nein, keine Bilder. Nur der Port darf dann nicht von mehreren Adaptern genutzt werden. Laut Log klappt mit dem Port 1886 etwas nicht.
          Ro75.
          • R Offline
            rebel85
            hier der log mit dem Port 1884
            2024-11-15 20:04:50.111 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
            2024-11-15 20:05:03.606 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1882?# timeout = 30s
            2024-11-15 20:05:03.975 E [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
            Benutzername oder Kennwort falsch (4)
            	at kotlin.ranges.RangesKt.createMqttException(SourceFile:16)
            	at org.eclipse.paho.client.mqttv3.internal.ClientState.notifyReceivedAck(SourceFile:294)
            	at org.eclipse.paho.client.mqttv3.internal.CommsSender.run(SourceFile:128)
            2024-11-15 20:05:04.974 W [main] MapViewModel: no location available
            2024-11-15 20:05:06.272 W [main] MapViewModel: no location available
            2024-11-15 20:05:10.130 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job started
            2024-11-15 20:05:10.136 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1882?# timeout = 30s
            2024-11-15 20:05:10.530 E [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
            2024-11-15 20:05:10.531 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
            2024-11-15 20:05:40.555 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job started
            2024-11-15 20:05:40.563 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1882?# timeout = 30s
            2024-11-15 20:05:41.026 E [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
            2024-11-15 20:05:41.028 I [DefaultDispatcher-worker-1] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
            2024-11-15 20:06:10.760 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
            2024-11-15 20:06:16.174 I [main] MemoryContactsRepo: Clearing all contacts. Waiting for lock
            2024-11-15 20:06:16.175 I [main] MessageProcessor: Clearing outgoing message queue length=0
            2024-11-15 20:06:16.187 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
            2024-11-15 20:06:16.590 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
            2024-11-15 20:06:16.597 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
            2024-11-15 20:06:16.836 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=f9e7a9e4
            2024-11-15 20:06:16.838 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=2fa06e39
            2024-11-15 20:06:17.118 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
            2024-11-15 20:06:17.531 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
            2024-11-15 20:06:17.538 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
            2024-11-15 20:06:17.759 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
            2024-11-15 20:06:17.764 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
            2024-11-15 20:06:19.720 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
            2024-11-15 20:06:19.720 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
            2024-11-15 20:06:19.744 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
            2024-11-15 20:06:19.745 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
            2024-11-15 20:06:21.116 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
            2024-11-15 20:06:21.124 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@4351761] dispatched in 6.844844ms
            2024-11-15 20:06:21.154 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
            2024-11-15 20:06:39.155 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@59c1bed]
            2024-11-15 20:06:39.157 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@59c1bed] dispatched in 589.739us
            2024-11-15 20:06:39.216 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
            • Ro75R Ro75
              Ro75.
              rebel85
              @ro75 wo liest du das in dem log?
              • R rebel85
                Ro75R Online
                Ro75R Online
                Ro75
                @rebel85
                Hast du noch einen MQTT laufen?
                Ro75.
                • Ro75R Ro75
                  @rebel85
                  Ro75.
                  rebel85
                  @ro75 ich habe nur selbst aktiv den Sonoff Adapter auf 1883.
                  mit den aktuellen Einstellungen 1884 bekomme ich in den Objekten nur die Connect Info aber keine weiteren Informationen... hab ich im Handy noch was ein zu stellen?
                  maybee ?
                  https://www.android-hilfe.de/forum/android-allgemein.20/standort-services-nicht-verfuegbar-deaktivieren-falschen-standort.1044041.html
                  will ich noch mal prüfen bzw. probieren
                  • R rebel85
                    maybee ?
                    Ro75R Online
                    Ro75R Online
                    Ro75
                    @rebel85 tut mir leid, ich bin jetzt raus. Habe dir die Diskrepanzen genannt. Für meine Begriffe drehen wir uns im Kreis.
                    Ro75
                    • Ro75R Ro75
                      Ro75
                      rebel85
                      @ro75 App und Adapter sind alles gleich, Portfreigeben sind überall auch gleich auf 1884 gestellt.
                      wenn einen anderen Port teste ändere ich den Natürlich und selbstverständlich in allen 3 Orten.
                      mir kommt es vor als wenn noch irgendwie irgendwo was geblockt wird oder so....
                      • R rebel85
                        Ro75R Online
                        Ro75R Online
                        Ro75
                        @rebel85 sagte in Owntracks läuft nicht mehr richtig nach Fritzbox tausch:
                        Scheint aber nicht so zu sein.
                        Ro75.
                        • Ro75R Ro75
                          Ro75.
                          Samson71S Offline
                          Samson71S Offline
                          Samson71
                          @ro75 sagte in Owntracks läuft nicht mehr richtig nach Fritzbox tausch:
                          Stimmt. Keine Ahnung was er da noch so treibt, aber sieht irgendwie nach Würfeln von Ports aus, denn das
                          stimmt ja so auch nicht. Da taucht zur Abwechslung mal der Port 1882 auf.
                          Markus
                          Bitte beachten:
                          R 2 Antworten Letzte Antwort
                          • Samson71S Samson71
                            rebel85
                            @samson71 da hatte ich mal den Port 1882 probiert und dann alles auf 1884 umgestellt wie es aktuell auch ist....
                            kann die fritzbox ein weg haben?
                            gibt es versteckte fritzbox Einstellungen dazu ?
                              rebel85
                              aktueller test...
                              aber warum geht dann nichts weiter... oder kann die app nichts senden?
                              z.b.
                              • R rebel85
                                aktueller test...
                                z.b.
                                Samson71S Offline
                                Samson71S Offline
                                Samson71
                                Ich kann zum Problem inhaltlich nichts beitragen. Ich nutze weder Adapter noch die App.
                                Markus
                                Bitte beachten:
                                • R Offline
                                  rebel85
                                  2024-11-17 11:32:17.411 I [main] App: Historical process exited at 2024-11-17T10:32:16.181Z. reason: permissions revoked
                                  2024-11-17 11:32:17.580 I [main] GeocoderProvider: Setting geocoding provider to DEVICE
                                  2024-11-17 11:32:17.600 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
                                  2024-11-17 11:32:17.620 I [DefaultDispatcher-worker-1] BackgroundService$setupGeofences: Setting up geofences for 5 waypoints
                                  2024-11-17 11:32:17.626 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
                                  2024-11-17 11:32:18.004 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
                                  2024-11-17 11:32:18.012 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
                                  2024-11-17 11:32:18.307 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
                                  2024-11-17 11:32:18.308 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
                                  2024-11-17 11:35:42.849 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                  2024-11-17 11:35:42.849 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                  2024-11-17 11:35:42.849 W [main] MapViewModel: no location available
                                  2024-11-17 11:35:43.020 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                  2024-11-17 11:35:43.020 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                  2024-11-17 11:35:43.020 W [main] MapViewModel: no location available
                                  2024-11-17 11:35:43.105 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
                                  2024-11-17 11:35:43.112 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                  2024-11-17 11:35:43.112 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                  2024-11-17 11:35:46.139 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                  2024-11-17 11:35:46.143 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@9d0d7e0] dispatched in 3.592448ms
                                  2024-11-17 11:35:46.202 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
                                  2024-11-17 11:36:10.035 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                  2024-11-17 11:36:10.036 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                  2024-11-17 11:36:10.077 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                  2024-11-17 11:36:10.077 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                  2024-11-17 11:37:15.444 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
                                  Verbindung wurde getrennt (32109) - java.io.EOFException
                                  Caused by: java.io.EOFException
                                  	at java.io.DataInputStream.readByte(DataInputStream.java:275)
                                  	... 6 more
                                  2024-11-17 11:37:20.484 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                  2024-11-17 11:37:20.484 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                  2024-11-17 11:37:20.485 W [main] MapViewModel: no location available
                                  2024-11-17 11:37:20.496 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
                                  2024-11-17 11:37:20.498 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                  2024-11-17 11:37:20.498 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                  2024-11-17 11:37:22.126 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                  2024-11-17 11:37:22.127 W [DefaultDispatcher-worker-2] MessageProcessor: Error sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]. Re-queueing
                                  org.owntracks.android.net.mqtt.MQTTMessageProcessorEndpoint$NotConnectedException
                                  	at org.owntracks.android.net.mqtt.MQTTMessageProcessorEndpoint.sendMessage-gIAlu-s(SourceFile:55)
                                  	at org.owntracks.android.services.MessageProcessor.sendAvailableMessages(SourceFile:640)
                                  	at org.owntracks.android.services.MessageProcessor.access$sendAvailableMessages(SourceFile:1)
                                  	at org.owntracks.android.services.MessageProcessor$loadOutgoingMessageProcessor$3.invokeSuspend(SourceFile:38)
                                  	at kotlin.coroutines.jvm.internal.ContinuationImpl.resumeWith(SourceFile:9)
                                  	at kotlinx.coroutines.DispatchedTask.run(SourceFile:109)
                                  	at androidx.work.Worker$2.run(SourceFile:148)
                                  	at kotlinx.coroutines.scheduling.TaskImpl.run(SourceFile:3)
                                  	at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(SourceFile:93)
                                  2024-11-17 11:37:22.128 I [DefaultDispatcher-worker-3] MessageProcessor$resendDelayWait: Waiting for 1s before retrying send
                                  2024-11-17 11:37:23.134 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                  2024-11-17 11:37:23.135 W [DefaultDispatcher-worker-3] MessageProcessor: Error sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@55d1946]. Re-queueing
                                  	at org.owntracks.android.services.MessageProcessor$sendAvailableMessages$1.invokeSuspend(Unknown Source:11)
                                  2024-11-17 11:37:23.136 I [DefaultDispatcher-worker-3] MessageProcessor$resendDelayWait: Waiting for 2s before retrying send
                                  2024-11-17 11:37:25.140 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                  2024-11-17 11:37:25.140 W [DefaultDispatcher-worker-2] MessageProcessor: Error sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]. Re-queueing
                                  2024-11-17 11:37:25.141 I [DefaultDispatcher-worker-1] MessageProcessor$resendDelayWait: Waiting for 4s before retrying send
                                  2024-11-17 11:37:25.456 I [DefaultDispatcher-worker-1] MQTTReconnectWorker: MQTT reconnect worker job started
                                  2024-11-17 11:37:25.463 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
                                  2024-11-17 11:37:25.872 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
                                  2024-11-17 11:37:25.876 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
                                  2024-11-17 11:37:25.877 I [DefaultDispatcher-worker-1] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
                                  2024-11-17 11:37:25.879 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                  2024-11-17 11:37:25.880 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 288.594us
                                  2024-11-17 11:37:25.881 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                  2024-11-17 11:37:25.882 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 209.115us
                                  2024-11-17 11:37:25.888 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=ff41afab
                                  2024-11-17 11:37:25.892 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=ef299e38
                                  2024-11-17 11:37:26.104 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=1ea7b569
                                  2024-11-17 11:37:26.105 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                  2024-11-17 11:37:26.108 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=813205fc
                                  2024-11-17 11:37:26.108 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                  2024-11-17 11:37:27.443 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                  2024-11-17 11:37:27.443 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                  2024-11-17 11:37:27.465 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                  2024-11-17 11:37:27.465 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                  2024-11-17 11:37:28.880 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                  2024-11-17 11:37:28.886 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 1.741823ms
                                  2024-11-17 11:37:28.951 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=2310e70f
                                  2024-11-17 11:37:51.457 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                  2024-11-17 11:37:51.457 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                  2024-11-17 11:37:51.501 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                  2024-11-17 11:37:51.501 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
