  4. Owntracks läuft nicht mehr richtig nach Fritzbox tausch
dyndnsfritzbox 7590owntracks adapter
65 Beiträge 3 Kommentatoren 10.2k Aufrufe
  • Ro75R Ro75
    @rebel85 ja was sagt bzw. steht denn im Log?
    Ro75
    rebel85
    @ro75 lade ich morgen hoch, muss ich erst noch prüfen und dann copy paste hier rein
    • R Offline
      rebel85
      hier der letzte uszug aus dem log
      2024-11-14 17:40:29.691 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
      2024-11-14 17:40:30.115 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
      2024-11-14 17:40:30.156 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
      2024-11-14 17:40:30.362 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
      2024-11-14 17:40:30.400 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
      2024-11-14 17:40:31.280 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
      2024-11-14 17:40:31.291 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
      2024-11-14 17:40:31.686 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
      2024-11-14 17:40:31.729 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
      2024-11-14 17:40:31.730 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
      2024-11-14 17:40:31.934 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
      2024-11-14 17:40:31.972 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
      2024-11-14 17:41:13.741 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
      Verbindung wurde getrennt (32109) - java.net.SocketException: Software caused connection abort
      	at org.eclipse.paho.client.mqttv3.internal.CommsSender.run(SourceFile:261)
      	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:487)
      	at java.util.concurrent.FutureTask.run(FutureTask.java:264)
      	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:307)
      	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
      	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:644)
      	at java.lang.Thread.run(Thread.java:1012)
      Caused by: java.net.SocketException: Software caused connection abort
      	at java.net.SocketInputStream.socketRead0(Native Method)
      	at java.net.SocketInputStream.socketRead(SocketInputStream.java:118)
      	at java.net.SocketInputStream.read(SocketInputStream.java:173)
      	at java.net.SocketInputStream.read(SocketInputStream.java:143)
      	at java.net.SocketInputStream.read(SocketInputStream.java:205)
      	at java.io.DataInputStream.readByte(DataInputStream.java:273)
      	at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(SourceFile:14)
      	at org.eclipse.paho.client.mqttv3.internal.CommsSender.run(SourceFile:88)
      	... 6 more
      2024-11-14 17:41:13.839 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
      2024-11-14 17:41:14.372 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
      2024-11-14 17:41:14.419 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
      2024-11-14 17:41:14.633 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
      2024-11-14 17:41:14.670 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
      2024-11-14 18:23:10.427 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
      	... 6 more
      2024-11-14 18:23:38.940 I [DefaultDispatcher-worker-5] MQTTReconnectWorker: MQTT reconnect worker job started
      2024-11-14 18:23:38.957 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
      2024-11-14 18:24:00.659 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
      2024-11-14 18:24:04.646 E [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
      MqttException (0) - java.net.UnknownHostException: mqttowntracks.ddns.net
      	at androidx.work.impl.utils.WorkForegroundUpdater$1.run(SourceFile:233)
      Caused by: java.net.UnknownHostException: mqttowntracks.ddns.net
      	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:208)
      	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:436)
      	at java.net.Socket.connect(Socket.java:646)
      	at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(SourceFile:50)
      	at androidx.work.impl.utils.WorkForegroundUpdater$1.run(SourceFile:66)
      	... 6 more
      2024-11-14 18:24:04.654 E [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpointKt: BOO
      kotlinx.coroutines.JobCancellationException: Job was cancelled; job=JobImpl{Cancelling}@xyz
      2024-11-14 18:24:04.655 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
      2024-11-14 18:24:04.669 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
      2024-11-14 18:24:04.671 E [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
      	... 6 more
      2024-11-14 18:24:04.672 E [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpointKt: BOO
      2024-11-14 18:24:04.672 I [DefaultDispatcher-worker-5] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
      2024-11-14 18:24:16.494 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
      2024-11-14 18:24:16.498 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
      2024-11-14 18:24:16.883 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
      2024-11-14 18:24:16.889 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
      2024-11-14 18:24:16.890 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
      2024-11-14 18:24:17.127 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
      2024-11-14 18:24:17.130 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
      2024-11-14 19:27:42.963 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
      Verbindung wurde getrennt (32109) - java.net.SocketException: Connection reset
      Caused by: java.net.SocketException: Connection reset
      	at java.net.SocketInputStream.read(SocketInputStream.java:191)
      	... 6 more
      2024-11-14 19:29:18.016 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
      2024-11-14 19:29:18.038 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
      2024-11-14 19:29:18.544 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
      2024-11-14 19:29:18.552 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
      2024-11-14 19:29:18.555 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
      2024-11-14 19:29:18.782 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
      2024-11-14 19:29:18.797 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
      2024-11-14 19:34:47.810 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
      2024-11-14 19:34:47.810 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
      2024-11-14 19:34:47.872 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
      2024-11-14 19:34:47.872 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
      2024-11-14 19:34:49.031 I [DefaultDispatcher-worker-8] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
      2024-11-14 19:34:49.033 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 2.055834ms
      2024-11-14 19:34:49.067 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
      2024-11-14 19:34:50.207 I [DefaultDispatcher-worker-8] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
      2024-11-14 19:34:50.210 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 710.052us
      2024-11-14 19:34:50.234 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
      Ro75R 1 Antwort Letzte Antwort
      • R rebel85
        	... 6 more
        	... 6 more
        	... 6 more
        	... 6 more
        	... 6 more
        Ro75R Online
        Ro75R Online
        Ro75
        schrieb am zuletzt editiert von Ro75
        @rebel85 als Port 1886? Im Adapter steht 1884, in der App 1886 und welchen Port schleifst du in der Fritzbox durch? So klappt das nicht.
        Ro75
        • Ro75R Ro75
          Ro75
          rebel85
          @ro75 Moin, doch so klappt das, weil im Adapter und in der Fritzbox auch der Selbe Port freigegeben ist. nur leider die App oder irgendwas noch den weg versperrt. hatte doch gesagt das ich die Ports mal gewechselt habe, es dann zu der ecovacs meldung kahm und dann habe ich den nächsten genommen.
          aktuell alle ports 1886...
          brauchst du dazu auch Bilder?
          • R rebel85
            Ro75R Online
            Ro75R Online
            Ro75
            @rebel85 nein, keine Bilder. Nur der Port darf dann nicht von mehreren Adaptern genutzt werden. Laut Log klappt mit dem Port 1886 etwas nicht.
            Ro75.
            • R Offline
              rebel85
              hier der log mit dem Port 1884
              2024-11-15 20:04:50.111 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
              2024-11-15 20:05:03.606 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1882?# timeout = 30s
              2024-11-15 20:05:03.975 E [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
              Benutzername oder Kennwort falsch (4)
              	at kotlin.ranges.RangesKt.createMqttException(SourceFile:16)
              	at org.eclipse.paho.client.mqttv3.internal.ClientState.notifyReceivedAck(SourceFile:294)
              	at org.eclipse.paho.client.mqttv3.internal.CommsSender.run(SourceFile:128)
              2024-11-15 20:05:04.974 W [main] MapViewModel: no location available
              2024-11-15 20:05:06.272 W [main] MapViewModel: no location available
              2024-11-15 20:05:10.130 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job started
              2024-11-15 20:05:10.136 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1882?# timeout = 30s
              2024-11-15 20:05:10.530 E [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
              2024-11-15 20:05:10.531 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
              2024-11-15 20:05:40.555 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job started
              2024-11-15 20:05:40.563 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1882?# timeout = 30s
              2024-11-15 20:05:41.026 E [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
              2024-11-15 20:05:41.028 I [DefaultDispatcher-worker-1] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
              2024-11-15 20:06:10.760 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
              2024-11-15 20:06:16.174 I [main] MemoryContactsRepo: Clearing all contacts. Waiting for lock
              2024-11-15 20:06:16.175 I [main] MessageProcessor: Clearing outgoing message queue length=0
              2024-11-15 20:06:16.187 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
              2024-11-15 20:06:16.590 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
              2024-11-15 20:06:16.597 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
              2024-11-15 20:06:16.836 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=f9e7a9e4
              2024-11-15 20:06:16.838 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=2fa06e39
              2024-11-15 20:06:17.118 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
              2024-11-15 20:06:17.531 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
              2024-11-15 20:06:17.538 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
              2024-11-15 20:06:17.759 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
              2024-11-15 20:06:17.764 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
              2024-11-15 20:06:19.720 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
              2024-11-15 20:06:19.720 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
              2024-11-15 20:06:19.744 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
              2024-11-15 20:06:19.745 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
              2024-11-15 20:06:21.116 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
              2024-11-15 20:06:21.124 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@4351761] dispatched in 6.844844ms
              2024-11-15 20:06:21.154 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
              2024-11-15 20:06:39.155 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@59c1bed]
              2024-11-15 20:06:39.157 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@59c1bed] dispatched in 589.739us
              2024-11-15 20:06:39.216 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
              • Ro75R Ro75
                Ro75.
                rebel85
                @ro75 wo liest du das in dem log?
                • R rebel85
                  Ro75R Online
                  Ro75R Online
                  Ro75
                  @rebel85
                  Hast du noch einen MQTT laufen?
                  Ro75.
                  • Ro75R Ro75
                    @rebel85
                    Ro75.
                    rebel85
                    @ro75 ich habe nur selbst aktiv den Sonoff Adapter auf 1883.
                    mit den aktuellen Einstellungen 1884 bekomme ich in den Objekten nur die Connect Info aber keine weiteren Informationen... hab ich im Handy noch was ein zu stellen?
                    maybee ?
                    https://www.android-hilfe.de/forum/android-allgemein.20/standort-services-nicht-verfuegbar-deaktivieren-falschen-standort.1044041.html
                    will ich noch mal prüfen bzw. probieren
                    • R rebel85
                      maybee ?
                      Ro75R Online
                      Ro75R Online
                      Ro75
                      @rebel85 tut mir leid, ich bin jetzt raus. Habe dir die Diskrepanzen genannt. Für meine Begriffe drehen wir uns im Kreis.
                      Ro75
                      • Ro75R Ro75
                        Ro75
                        rebel85
                        @ro75 App und Adapter sind alles gleich, Portfreigeben sind überall auch gleich auf 1884 gestellt.
                        wenn einen anderen Port teste ändere ich den Natürlich und selbstverständlich in allen 3 Orten.
                        mir kommt es vor als wenn noch irgendwie irgendwo was geblockt wird oder so....
                        • R rebel85
                          Ro75R Online
                          Ro75R Online
                          Ro75
                          @rebel85 sagte in Owntracks läuft nicht mehr richtig nach Fritzbox tausch:
                          Scheint aber nicht so zu sein.
                          Ro75.
                          • Ro75R Ro75
                            Ro75.
                            Samson71S Offline
                            Samson71S Offline
                            Samson71
                            @ro75 sagte in Owntracks läuft nicht mehr richtig nach Fritzbox tausch:
                            Stimmt. Keine Ahnung was er da noch so treibt, aber sieht irgendwie nach Würfeln von Ports aus, denn das
                            stimmt ja so auch nicht. Da taucht zur Abwechslung mal der Port 1882 auf.
                            Markus
                            Bitte beachten:
                            R 2 Antworten Letzte Antwort
                            • Samson71S Samson71
                              rebel85
                              @samson71 da hatte ich mal den Port 1882 probiert und dann alles auf 1884 umgestellt wie es aktuell auch ist....
                              kann die fritzbox ein weg haben?
                              gibt es versteckte fritzbox Einstellungen dazu ?
                                rebel85
                                aktueller test...
                                aber warum geht dann nichts weiter... oder kann die app nichts senden?
                                z.b.
                                • R rebel85
                                  aktueller test...
                                  z.b.
                                  Samson71S Offline
                                  Samson71S Offline
                                  Samson71
                                  Ich kann zum Problem inhaltlich nichts beitragen. Ich nutze weder Adapter noch die App.
                                  Markus
                                  Bitte beachten:
                                  • R Offline
                                    rebel85
                                    2024-11-17 11:32:17.411 I [main] App: Historical process exited at 2024-11-17T10:32:16.181Z. reason: permissions revoked
                                    2024-11-17 11:32:17.580 I [main] GeocoderProvider: Setting geocoding provider to DEVICE
                                    2024-11-17 11:32:17.600 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
                                    2024-11-17 11:32:17.620 I [DefaultDispatcher-worker-1] BackgroundService$setupGeofences: Setting up geofences for 5 waypoints
                                    2024-11-17 11:32:17.626 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
                                    2024-11-17 11:32:18.004 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
                                    2024-11-17 11:32:18.012 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
                                    2024-11-17 11:32:18.307 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
                                    2024-11-17 11:32:18.308 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
                                    2024-11-17 11:35:42.849 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                    2024-11-17 11:35:42.849 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                    2024-11-17 11:35:42.849 W [main] MapViewModel: no location available
                                    2024-11-17 11:35:43.020 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                    2024-11-17 11:35:43.020 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                    2024-11-17 11:35:43.020 W [main] MapViewModel: no location available
                                    2024-11-17 11:35:43.105 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
                                    2024-11-17 11:35:43.112 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                    2024-11-17 11:35:43.112 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                    2024-11-17 11:35:46.139 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                    2024-11-17 11:35:46.143 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@9d0d7e0] dispatched in 3.592448ms
                                    2024-11-17 11:35:46.202 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
                                    2024-11-17 11:36:10.035 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                    2024-11-17 11:36:10.036 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                    2024-11-17 11:36:10.077 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                    2024-11-17 11:36:10.077 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                    2024-11-17 11:37:15.444 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
                                    Verbindung wurde getrennt (32109) - java.io.EOFException
                                    Caused by: java.io.EOFException
                                    	at java.io.DataInputStream.readByte(DataInputStream.java:275)
                                    	... 6 more
                                    2024-11-17 11:37:20.484 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                    2024-11-17 11:37:20.484 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                    2024-11-17 11:37:20.485 W [main] MapViewModel: no location available
                                    2024-11-17 11:37:20.496 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
                                    2024-11-17 11:37:20.498 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                    2024-11-17 11:37:20.498 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                    2024-11-17 11:37:22.126 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                    2024-11-17 11:37:22.127 W [DefaultDispatcher-worker-2] MessageProcessor: Error sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]. Re-queueing
                                    org.owntracks.android.net.mqtt.MQTTMessageProcessorEndpoint$NotConnectedException
                                    	at org.owntracks.android.net.mqtt.MQTTMessageProcessorEndpoint.sendMessage-gIAlu-s(SourceFile:55)
                                    	at org.owntracks.android.services.MessageProcessor.sendAvailableMessages(SourceFile:640)
                                    	at org.owntracks.android.services.MessageProcessor.access$sendAvailableMessages(SourceFile:1)
                                    	at org.owntracks.android.services.MessageProcessor$loadOutgoingMessageProcessor$3.invokeSuspend(SourceFile:38)
                                    	at kotlin.coroutines.jvm.internal.ContinuationImpl.resumeWith(SourceFile:9)
                                    	at kotlinx.coroutines.DispatchedTask.run(SourceFile:109)
                                    	at androidx.work.Worker$2.run(SourceFile:148)
                                    	at kotlinx.coroutines.scheduling.TaskImpl.run(SourceFile:3)
                                    	at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(SourceFile:93)
                                    2024-11-17 11:37:22.128 I [DefaultDispatcher-worker-3] MessageProcessor$resendDelayWait: Waiting for 1s before retrying send
                                    2024-11-17 11:37:23.134 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                    2024-11-17 11:37:23.135 W [DefaultDispatcher-worker-3] MessageProcessor: Error sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@55d1946]. Re-queueing
                                    	at org.owntracks.android.services.MessageProcessor$sendAvailableMessages$1.invokeSuspend(Unknown Source:11)
                                    2024-11-17 11:37:23.136 I [DefaultDispatcher-worker-3] MessageProcessor$resendDelayWait: Waiting for 2s before retrying send
                                    2024-11-17 11:37:25.140 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                    2024-11-17 11:37:25.140 W [DefaultDispatcher-worker-2] MessageProcessor: Error sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]. Re-queueing
                                    2024-11-17 11:37:25.141 I [DefaultDispatcher-worker-1] MessageProcessor$resendDelayWait: Waiting for 4s before retrying send
                                    2024-11-17 11:37:25.456 I [DefaultDispatcher-worker-1] MQTTReconnectWorker: MQTT reconnect worker job started
                                    2024-11-17 11:37:25.463 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
                                    2024-11-17 11:37:25.872 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
                                    2024-11-17 11:37:25.876 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
                                    2024-11-17 11:37:25.877 I [DefaultDispatcher-worker-1] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
                                    2024-11-17 11:37:25.879 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                    2024-11-17 11:37:25.880 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 288.594us
                                    2024-11-17 11:37:25.881 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                    2024-11-17 11:37:25.882 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 209.115us
                                    2024-11-17 11:37:25.888 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=ff41afab
                                    2024-11-17 11:37:25.892 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=ef299e38
                                    2024-11-17 11:37:26.104 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=1ea7b569
                                    2024-11-17 11:37:26.105 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                    2024-11-17 11:37:26.108 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=813205fc
                                    2024-11-17 11:37:26.108 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                    2024-11-17 11:37:27.443 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                    2024-11-17 11:37:27.443 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                    2024-11-17 11:37:27.465 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                    2024-11-17 11:37:27.465 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                    2024-11-17 11:37:28.880 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                    2024-11-17 11:37:28.886 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 1.741823ms
                                    2024-11-17 11:37:28.951 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=2310e70f
                                    2024-11-17 11:37:51.457 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                    2024-11-17 11:37:51.457 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                    2024-11-17 11:37:51.501 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                    2024-11-17 11:37:51.501 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
